R1172N301D-TR-FE
R1172N301D-TR-FE
    NISSHINBO(日清纺)
    SOT23-5
    PMIC - 稳压器 - 线性 正 固定 1 输出 1A SOT-23-5
R1172N301D-TR-FE 数据手册
R1172x SERIES SUPER LOW ON RESISTANCE / LOW VOLTAGE 1A LDO NO.EA-122-130924 OUTLINE The R1172x Series are CMOS-based positive voltage regulator ICs. The R1172x Series have features of super low dropout, 1A output current capability. Even the output voltage is set at 1.5V, on resistance of internal FET is typically 0.32Ω. Therefore, applications that require a large current at small dropout are suitable for the R1172x series. Low input voltage is acceptable and low output voltage can be set. The minimum input voltage is 1.4V, and the lowest set output voltage is 0.8V. Each of these ICs consists of a voltage reference unit, an error amplifier, resistor net for setting output voltage, a current limit circuit at over-current, a chip enable circuit, a thermal-shutdown circuit, and so on. A stand-by mode with ultra low consumption current can be realized with the chip enable pin. The output voltage of R1172 is fixed in the IC. Since the packages for these ICs are SOT-23-5, SOT-89-5, HSON-6, and HSOP-6J with high power dissipation, high density mounting of the ICs on boards is possible. FEATURES • • • • • • • • • • • • • • • • • Output Current ............................................................ 1A Supply Current ............................................................. Typ. 60μA Standby Current .......................................................... Typ. 0.1μA Input Voltage Range ................................................... 1.4V to 6.0V Output Voltage.............................................................. 0.8V to 5.0V (0.1V steps) (For other voltages, please refer to MARK INFORMATIONS.) Dropout Voltage............................................................ Typ. 0.32V (VOUT=1.5V, IOUT=1A) Typ. 0.18V (VOUT=2.8V, IOUT=1A) Ripple Rejection ........................................................... Typ. 70dB (VOUT=2.8V) Output Voltage Accuracy .............................................. ±2.0% Temperature-Drift Coefficient of Output Voltage .......... Typ. ±100ppm/°C Line Regulation ............................................................ Typ. 0.05%/V Load Regulation ......................................................... Typ. 15mV at IOUT=300mA, Typ. 50mV at IOUT=1A Packages .................................................................... SOT-23-5, SOT-89-5, HSON-6, HSOP-6J Built-in Inrush current limit circuit ............................... Typ. 500 mA Built-in Fold-Back Protection Circuit ........................... Typ. 250mA (Current at short mode) Built-in Thermal Shutdown Circuit .............................. Thermal Shutdown Temperature ; Typ. 150°C Released Temperature ; Typ. 120°C Built-in Auto Discharge Function ................................ D Version Output capacitors ....................................................... CIN=COUT=Tantalum 4.7μF (VOUT < 1.0V) CIN=COUT=Ceramic 4.7μF (VOUT > = 1.0V) APPLICATIONS • Local Power source for Notebook PC. • Local Power source for portable communication equipments, cameras, and VCRs. • Local Power source for home appliances. 1 R1172x BLOCK DIAGRAMS R1172xxx1A VDD VOUT Vref Current Limit Thermal Shutdown CE GND R1172xxx1B R1172xxx1D VDD VOUT VDD VOUT Vref Vref Current Limit Thermal Shutdown Current Limit Thermal Shutdown CE GND CE GND SELECTION GUIDE The output voltage, chip-enable polarity, auto discharge function, and package for the ICs can be selected at the user’s request. Product Name Package Quantity per Reel Pb Free Halogen Free R1172Nxx1∗-TR-FE SOT-23-5 3,000 pcs Yes Yes R1172Hxx1∗-T1-FE SOT-89-5 1,000 pcs Yes Yes R1172Dxx1∗-TR-FE HSON-6 3,000 pcs Yes Yes R1172Sxx1∗-E2-FE HSOP-6J 1,000 pcs Yes Yes xx : The output voltage can be designated in the range from 0.8V(08) to 5.0V(50) in 0.1V steps. (HSOP-6J : 0.8V to 3.5V) (For other voltages, please refer to MARK INFORMATIONS.) ∗ : CE pin polarity and auto discharge function at off state are options as follows. (A) "L" active, without auto discharge function at off state (B) "H" active, without auto discharge function at off state (D) "H" active, with auto discharge function at off state 2 R1172x PIN CONFIGURATIONS z SOT-23-5 5 z SOT-89-5 4 5 4 z HSON-6 Top View 6 5 1 2 Bottom View 4 4 ∗ (mark side) 3 1 2 3 1 2 3 z HSOP-6J 5 5 4 1 2 3 6 ∗ 3 6 ∗ 2 1 PIN DESCRIPTIONS • SOT-23-5 Pin No. Symbol Description 1 VOUT Voltage Regulator Output Pin 2 GND Ground Pin 3 VDD Input Pin 4 NC No Connection 5 CE or CE Chip Enable Pin • SOT-89-5 Pin No. Symbol Description 1 CE or CE 2 GND 3 NC No Connection 4 VDD Input Pin 5 VOUT Voltage Regulator Output Pin Pin No. Symbol Chip Enable Pin Ground Pin • HSON-6 Description 1 VOUT* 1 Voltage Regulator Output Pin 2 VOUT*1 Voltage Regulator Output Pin 3 CE or CE 4 GND Ground Pin 5 VDD*1 Input Pin 6 VDD*1 Input Pin Chip Enable Pin ∗) Tab and tab suspension leads in the parts are GND level. (They are connected to the reverse side of the IC.) The tab is better to be connected to the GND, but leaving it open is also acceptable. The tab suspension leads should be open and do not connect to other wires or land patterns. ∗1) The VOUT pin and VDD pin must be wired each other when it is mounted on board. 3 R1172x • HSOP-6J Pin No. Symbol Description 1 VOUT 2 GND*1 3 CE or CE Chip Enable Pin 4 NC No Connection 5 GND*1 6 VDD Voltage Regulator Output Pin Ground Pin Ground Pin Input Pin ∗1) The GND pin must be wired together when it is mounted on board. ABSOLUTE MAXIMUM RATINGS Symbol Item VIN Input Voltage VCE Input Voltage ( CE or CE Input Pin) VOUT Output Voltage Rating Unit 6.5 V −0.3 to 6.5 V −0.3 to VIN+0.3 V Power Dissipation (SOT-23-5) * 420 Power Dissipation (SOT-89-5) * 900 Power Dissipation (HSON-6) * 900 Power Dissipation (HSOP-6J) * 1700 Topt Operating Temperature Range −40 to 85 °C Tstg Storage Temperature Range −55 to 125 °C PD mW ∗) For Power Dissipation, please refer to PACKAGE INFORMATION. ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damages and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. RECOMMENDED OPERATING CONDITIONS (ELECTRICAL CHARACTERISTICS) All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. 4 R1172x ELECTRICAL CHARACTERISTICS • R1172xxx1A Symbol Topt=25°C Item Conditions Min. Typ. Unit 6.0 V VIN Input Voltage ISS Supply Current VIN−VOUT=1.0V, VCE=0V, IOUT =0A 60 100 μA Standby Current VIN= 6.0V, VCE=VIN 0.1 1.0 μA Output Voltage VIN−VOUT=1.0V IOUT=100mA ×0.98 ×1.02 V 1.5V −30 +30 mV VIN−VOUT=0.3V 1mA < = IOUT < = 300mA If VOUT < = 1.1V, then VIN=1.4V −15 Istandby VOUT ΔVOUT/ ΔIOUT VDIF Load Regulation 1.4 Max. VOUT > 1.5V VOUT < = 50 Refer to Dropout Voltage Table Line Regulation IOUT=100mA VOUT+0.5V < = VIN < = 6.0V < If VOUT = 0.9V, 1.4V < = VIN < = 6.0V Ripple Rejection f=1kHz (VOUT < = 4.0V) f=1kHz (VOUT > 4.0V) Ripple 0.5Vp-p, VIN−VOUT=1.0V, IOUT=100mA If VOUT < = 1.2V, VIN−VOUT=1.5V, IOUT=100mA Output Voltage Temperature Coefficient IOUT=100mA −40°C < = Topt ILIM Output Current VIN−VOUT=1.0V ISC Short Current Limit VOUT=0V RPU Pull-up Resistance for CE pin 1.9 VCEH CE Input Voltage "H" VCEL CE Input Voltage "L" ΔVOUT/ ΔVIN RR ΔVOUT/ ΔTopt TTSD TTSR en Thermal Shutdown Temperature Thermal Shutdown Released Temperature Output Noise 30 mV VIN−VOUT=0.3V 1mA < = IOUT < = 1A 1.1V, then VIN=1.7V If VOUT < = Dropout Voltage 15 < = 0.05 0.20 %/V 70 60 dB ±100 85°C ppm/°C 1 A 250 5.0 mA 15.0 MΩ 1.0 6.0 V 0 0.4 V Junction Temperature 150 °C Junction Temperature 120 °C BW=10Hz to 100kHz 30 μVrms 5 R1172x • R1172xxx1B/D Symbol Item Conditions Min. Typ. Unit 6.0 V Input Voltage ISS Supply Current VIN−VOUT=1.0V, VIN=VCE, IOUT=0A 60 100 μA Standby Current VIN= 6.0V, VCE=0V 0.1 1.0 μA Output Voltage VIN−VOUT=1.0V IOUT=100mA VOUT ΔVOUT/ ΔIOUT VDIF Load Regulation 1.4 Max. VIN Istandby VOUT > 1.5V ×0.98 ×1.02 V < = 1.5V −30 +30 mV VIN−VOUT=0.3V 1mA < = IOUT < = 300mA If VOUT < = 1.1V, then VIN=1.4V −15 VOUT Dropout Voltage Refer to Dropout Voltage Table Ripple Rejection f=1kHz (VOUT < = 4.0V) f=1kHz (VOUT > 4.0V) Ripple 0.5Vp-p, VIN−VOUT=1.0V IOUT=100mA If VOUT < = 1.2V, VIN−VOUT=1.5V, IOUT=100mA Output Voltage Temperature Coefficient IOUT=100mA −40°C < = Topt ILIM Output Current VIN−VOUT=1.0V ISC Short Current Limit VOUT=0V RPD Pull-down Resistance for CE pin 1.9 VCEH CE Input Voltage "H" VCEL CE Input Voltage "L" ΔVOUT/ ΔTopt TTSD TTSR en Thermal Shutdown Temperature Thermal Shutdown Released Temperature Output Noise 30 50 Line Regulation RR 15 mV VIN−VOUT=0.3V 1mA < = IOUT < = 1A If VOUT < = 1.1V, then VIN=1.7V IOUT=100mA VOUT+0.5V < = VIN < = 6.0V If VOUT < = 0.9V, 1.4V < = VIN < = 6.0V ΔVOUT/ ΔVIN 6 Topt=25°C < = 0.05 0.20 %/V 70 60 dB ±100 85°C ppm/°C 1 A 250 5.0 mA 15.0 MΩ 1.0 6.0 V 0 0.4 V Junction Temperature 150 °C Junction Temperature 120 °C BW=10Hz to 100kHz 30 μVrms R1172x • Dropout Voltage by Output Voltage Topt=25°C Dropout Voltage VDIF (V) Output Voltage VOUT (V) IOUT=300mA IOUT=1A Typ. Max. Typ. 0.8 < = VOUT < 0.9 0.33 0.57 0.72 0.9 < = VOUT < 1.0 0.22 0.47 0.64 1.0 < = VOUT < 1.5 0.18 0.32 0.56 1.5 < = VOUT < 2.6 0.10 0.15 0.32 0.05 0.10 0.18 2.6 < = VOUT 7 R1172x TYPICAL APPLICATION (R1172xxx1B/D) VDD C1 VOUT R1172x Series CE VOUT C2 GND TECHNICAL NOTES When using these ICs, consider the following points: Phase Compensation In these ICs, phase compensation is made for securing stable operation even if the load current is varied. For this purpose, use a capacitor C2 with good frequency characteristics and ESR (Equivalent Series Resistance). The recommendation value is as follows. Output Voltage C2 recommendation value VOUT < 1.0V 1.0 < = VOUT < = 3.3V 3.3V < VOUT Components Recommendation Tantalum 4.7μF or more Ceramic 4.7μF or more Ceramic 4.7μF or more Kyocera 4.7μF (1608) Murata 4.7μF (1608) Murata 10μF (1608) Kyocera 4.7μF (thin 2012) Murata 10μF (2012) Part Number : CM105X5R475M06AB Part Number : GRM188R60J475KE19B Part Number : GRM188B30G106ME46B Part Number : CT21X5R475M06AB Part Number : GRM21BB30J106K ∗ If you use a tantalum type capacitor and ESR value of the capacitor is large, output might be unstable. Evaluate your circuit with considering frequency characteristics. ∗ Depending on the capacitor size, manufacturer, and part number, the bias characteristics and temperature characteristics are different. Evaluate the circuit with actual using capacitors. PCB Layout Make VDD and GND lines sufficient. If their impedance is high, noise pickup or unstable operation may result. Connect a capacitor C1 with a capacitance value as much as 4.7μF or more between VDD and GND pin, and as close as possible to the pins. Set external components, especially the output capacitor C2, as close as possible to the ICs, and make wiring as short as possible. 8 R1172x TYPICAL CHARACTERISTICS 1) Output Voltage vs. Output Current (Topt=25°C) R1172x151x 1.6 0.8 1.4 0.7 0.6 0.5 0.4 VDD=1.4V VDD=1.5V VDD=1.6V VDD=2.0V VDD=2.8V 0.3 0.2 0.1 Output Voltage VOUT(V) Output Voltage VOUT(V) R1172x081x 0.9 0.0 1.2 1.0 0.8 0.6 VDD=1.8V VDD=2.5V VDD=3.5V 0.4 0.2 0.0 0 500 1000 1500 Output Current IOUT(mA) 2000 0 3.2 4.5 2.8 4.0 2.4 2.0 1.6 1.2 VDD=3.3V VDD=4.0V VDD=5.0V 0.8 0.4 0.0 0 2000 R1172x401x 500 1000 1500 Output Current IOUT(mA) 2000 Output Voltage VOUT(V) Output Voltage VOUT(V) R1172x301x 500 1000 1500 Output Current IOUT(mA) 3.5 3.0 2.5 2.0 VDD=4.3V VDD=5.0V VDD=6.0V 1.5 1.0 0.5 0.0 0 500 1000 1500 Output Current IOUT(mA) 2000 R1172x501x Output Voltage VOUT(V) 6.0 5.0 4.0 3.0 VDD=5.3V VDD=6.0V 2.0 1.0 0.0 0 500 1000 1500 Output Current IOUT(mA) 2000 9 R1172x 2) Output Voltage vs. Input Voltage (Topt=25°C) R1172x081x R1172x151x 1.6 Output Voltage VOUT(V) Output Voltage VOUT(V) 1.2 1.0 0.8 0.6 IOUT=1mA IOUT=50mA IOUT=99mA IOUT=300mA 0.4 0.2 0.0 1.4 1.2 1.0 0.8 IOUT=1mA IOUT=50mA IOUT=99mA IOUT=300mA 0.6 0.4 0.2 0.0 0 1 2 3 4 Input Voltage VIN(V) 5 6 0 1 4.5 2.8 4.0 2.4 2.0 1.6 IOUT=1mA IOUT=50mA IOUT=99mA IOUT=300mA 1.2 0.8 0.4 0.0 1 2 3 4 Input Voltage VIN(V) 5 6 R1172x501x Output Voltage VOUT(V) 6 3.5 3.0 2.5 2.0 IOUT=1mA IOUT=50mA IOUT=99mA IOUT=300mA 1.5 1.0 0.5 0.0 0 5.5 5.0 4.5 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 IOUT=1mA IOUT=50mA IOUT=99mA IOUT=300mA 0 10 5 R1172x401x 3.2 Output Voltage VOUT(V) Output Voltage VOUT(V) R1172x301x 2 3 4 Input Voltage VIN(V) 1 2 3 4 Input Voltage VIN(V) 5 6 0 1 2 3 4 Input Voltage VIN(V) 5 6 R1172x 3) Supply Current vs. Input Current (Topt=25°C) R1172x151x 70 70 60 60 Supply Current ISS(μA) Supply Current ISS(µA) R1172x081x 50 40 30 20 10 50 40 30 20 10 0 0 0 1 2 3 4 Input Voltage VIN(V) 5 0 6 1 5 6 5 6 R1172x401x 70 70 60 60 Supply Current ISS(μA) Supply Current ISS(μA) R1172x301x 2 3 4 Input Voltage VIN(V) 50 40 30 20 10 0 50 40 30 20 10 0 0 1 2 3 4 Input Voltage VIN(V) 5 6 5 6 0 1 2 3 4 Input Voltage VIN(V) R1172x501x Supply Current ISS(μA) 70 60 50 40 30 20 10 0 0 1 2 3 4 Input Voltage VIN(V) 11 R1172x 4) Output Voltage vs. Temperature (IOUT=100mA) R1172x081x R1172x151x VIN=2.5V 1.53 0.82 1.52 Output Voltage VOUT(V) Output Voltage VOUT(V) VIN=1.8V 0.83 0.81 0.80 0.79 0.78 0.77 0.76 -50 -25 0 25 50 75 Temperature Topt(°C) 1.51 1.50 1.49 1.48 1.47 1.46 -50 100 -25 R1172x301x 0 25 50 75 Temperature Topt(°C) R1172x501x VIN=6.0V 5.02 3.04 5.00 Output Voltage VOUT(V) Output Voltage VOUT(V) VIN=4.0V 3.06 3.02 3.00 2.98 2.96 2.94 2.92 -50 -25 100 0 25 50 75 Temperature Topt(°C) 4.98 4.96 4.94 4.92 4.90 4.88 -50 100 -25 0 25 50 75 Temperature Topt(°C) 100 5) Supply Current vs. Temperature R1172x081x R1172x151x 80 70 70 60 50 40 30 20 10 0 -50 12 Supply Current ISS(μA) Supply Current ISS(μA) VIN=1.8V 80 -25 0 25 50 75 Temperature Topt(°C) 100 VIN=2.5V 60 50 40 30 20 10 0 -50 -25 0 25 50 75 Temperature Topt(°C) 100 R1172x R1172x301x R1172x501x VIN=6.0V 80 80 70 70 Supply Current ISS(μA) Supply Current ISS(μA) VIN=4.0V 60 50 40 30 20 10 0 -50 -25 0 25 50 75 Temperature Topt(°C) 60 50 40 30 20 10 0 -50 100 -25 0 25 50 75 Temperature Topt(°C) 100 6) Dropout Voltage vs. Output Current R1172x081x R1172x091x 700 700 600 500 400 300 85°C 25°C -40°C 200 100 Dropout Voltage VDIF(mV) Dropout Voltage VDIF(mV) 800 600 500 400 300 85°C 25°C -40°C 200 100 0 0 0 200 400 600 800 Output Current IOUT(mA) 1000 0 600 400 500 350 400 300 85°C 25°C -40°C 200 100 0 0 1000 R1172x151x 200 400 600 800 Output Current IOUT(mA) 1000 Dropout Voltage VDIF(mV) Dropout Voltage VDIF(mV) R1172x101x 200 400 600 800 Output Current IOUT(mA) 300 250 200 150 85°C 25°C -40°C 100 50 0 0 200 400 600 800 Output Current IOUT(mA) 1000 13 R1172x R1172x301x R1172x501x Dropout Voltage VDIF(mV) Dropout Voltage VDIF(mV) 250 200 150 100 85°C 25°C -40°C 50 0 0 200 400 600 800 Output Current IOUT(mA) 200 180 160 140 120 100 80 60 40 20 0 0 1000 7) Dropout Voltage vs. Set Output Voltage 85°C 25°C -40°C 200 400 600 800 Output Current IOUT(mA) 8) 0.8V Output type, Operating Input Voltage Range R1172xxx1x R1172x081x 800 1.8 100mA 200mA 400mA 600mA 800mA 1000mA 700 600 500 400 Input Voltage VIN(V) Dropout Voltage VDIF(mV) 1000 300 200 Operating Input Voltage Range 1.6 1.4 1.2 1.0 100 0.8 0 0 1 2 3 4 Set Output Voltage VREG(V) 5 0 200 400 600 800 Output Current IOUT(mA) 1000 9) Ripple Rejection vs. Input Bias R1172x301x R1172x301x VIN=4.0VDC+0.5Vp-p,IOUT=1mA 90 90 80 80 70 60 50 40 200Hz 1kHz 10kHz 100kHz 30 20 10 0 3.0 14 Ripple Rejection RR(dB) Ripple Rejection RR(dB) VIN=4.0VDC+0.2Vp-p,IOUT=1mA 3.1 3.2 3.3 3.4 Input Voltage VIN(V) 3.5 70 60 50 40 200Hz 1kHz 10kHz 100kHz 30 20 10 0 3.0 3.1 3.2 3.3 3.4 Input Voltage VIN(V) 3.5 R1172x R1172x301x R1172x301x VIN=4.0VDC+0.5Vp-p,IOUT=10mA 90 90 80 80 Ripple Rejection RR(dB) Ripple Rejection RR(dB) VIN=4.0VDC+0.2Vp-p,IOUT=10mA 70 60 50 40 200Hz 1kHz 10kHz 100kHz 30 20 10 0 3.0 3.1 3.2 3.3 3.4 Input Voltage VIN(V) 70 60 50 40 20 10 0 3.0 3.5 200Hz 1kHz 10kHz 100kHz 30 3.1 R1172x301x 90 80 80 Ripple Rejection RR(dB) Ripple Rejection RR(dB) VIN=4.0VDC+0.5Vp-p,IOUT=100mA 90 70 60 50 40 200Hz 1kHz 10kHz 100kHz 20 10 0 3.0 3.1 3.5 R1172x301x VIN=4.0VDC+0.2Vp-p,IOUT=100mA 30 3.2 3.3 3.4 Input Voltage VIN(V) 3.2 3.3 3.4 Input Voltage VIN(V) 60 50 40 30 20 10 0 3.0 3.5 200Hz 1kHz 10kHz 100kHz 70 3.1 3.2 3.3 3.4 Input Voltage VIN(V) 3.5 10) Ripple Rejection vs. Frequency R1172x081x R1172x101x VIN=2.0VDC+0.5Vp-p, COUT=Ceramic 4.7μF 80 90 70 80 Ripple Rejection RR(dB) Ripple Rejection RR(dB) VIN=1.8VDC+0.5Vp-p, COUT=Tantalum 4.7μF 60 50 40 30 20 10 0 0.1 IOUT=1mA IOUT=30mA IOUT=100mA 1 10 Frequency f(kHz) 100 70 60 50 40 30 20 10 0 0.1 IOUT=1mA IOUT=30mA IOUT=100mA 1 10 Frequency f(kHz) 100 15 R1172x R1172x301x R1172x401x VIN=5.0VDC+0.5Vp-p, COUT=Ceramic 4.7μF 90 90 80 80 Ripple Rejection RR(dB) Ripple Rejection RR(dB) VIN=4.0VDC+0.5Vp-p, COUT=Ceramic 4.7μF 70 60 50 40 30 20 10 0 0.1 IOUT=1mA IOUT=30mA IOUT=100mA 1 10 Frequency f(kHz) 100 70 60 50 40 30 10 0 0.1 R1172x451x 70 70 Ripple Rejection RR(dB) Ripple Rejection RR(dB) 80 60 50 40 30 IOUT=1mA IOUT=30mA IOUT=100mA 0 0.1 1 10 Frequency f(kHz) 100 VIN=6.0VDC+0.5Vp-p, COUT=Ceramic 4.7μF 80 10 1 10 Frequency f(kHz) R1172x501x VIN=5.5VDC+0.5Vp-p, COUT=Ceramic 4.7μF 20 IOUT=1mA IOUT=30mA IOUT=100mA 20 60 50 40 30 20 IOUT=1mA IOUT=30mA IOUT=100mA 10 0 0.1 100 1 10 Frequency f(kHz) 100 11) Line Transient Response (tr=tf=5μs, IOUT=100mA) R1172x081x R1172x101x Input Voltage 4 3 1.08 3 0.86 2 0.84 1 0.82 0 0.80 0.78 Output Voltage 0.76 1.06 Input Voltage 1.04 1.02 2 1 0 Output Voltage 1.00 0.98 0.96 0 10 20 30 40 50 60 70 80 90 100 Time t(μs) 16 1.10 Output Voltage VOUT(V) 0.88 COUT=Ceramic 4.7μF 4 Input Voltage VIN(V) Output Voltage VOUT(V) 0.90 0 10 20 30 40 50 60 70 80 90 100 Time t(μs) Input Voltage VIN(V) COUT=Tantalum 4.7μF R1172x R1172x301x R1172x501x COUT=Ceramic 4.7μF 5.15 3.12 5 5.12 3.09 Input Voltage 4 3.06 3 3.03 2 3.00 1 2.97 0 Output Voltage 2.94 7 6 Input Voltage 5.09 5 5.06 4 5.03 3 5.00 2 4.97 1 Output Voltage 0 4.94 0 10 20 30 40 50 60 70 80 90 100 Time t(μs) Input Voltage VIN(V) 6 Output Voltage VOUT(V) 3.15 Input Voltage VIN(V) Output Voltage VOUT(V) COUT=Ceramic 4.7μF 0 10 20 30 40 50 60 70 80 90 100 Time t(μs) 12) Load Transient Response (tr=tf=500ns) R1172x081x Output Current 0.92 200 0.86 0 0.80 Output Voltage 0.68 Output Current 0.92 0.88 50 0 0.84 Output Voltage 0.80 0.76 0 R1172x081x 0 0.84 0.80 Output Voltage VOUT(V) 20 Output Current 0.88 6 8 10 12 14 16 18 20 Time t(μs) 1.00 40 0.92 4 VIN=1.8V,CIN=Tantalum 4.7μF, COUT=Tantalum 10μF VIN=1.8V,CIN=COUT= Tantalum 4.7μF 0.96 2 R1172x081x Output Current IOUT(mA) Output Voltage VOUT(V) 100 0.96 0 10 20 30 40 50 60 70 80 90 100 Time t(μs) 1.00 150 40 0.96 20 Output Current 0 0.92 0.88 0.84 0.80 Output Current IOUT(mA) 0.74 Output Voltage VOUT(V) 400 0.98 VIN=1.8V,CIN=COUT= Tantalum 4.7μF 1.00 600 Output Current IOUT(mA) VIN=1.8V,CIN=COUT= Tantalum 4.7μF Output Current IOUT(mA) Output Voltage VOUT(V) 1.04 R1172x081x Output Voltage Output Voltage 0.76 0.76 0 10 20 30 40 50 60 70 80 90 100 Time t(μs) 0 10 20 30 40 50 60 70 80 90 100 Time t(μs) 17 R1172x R1172x101x 1.4 Output Current 1.2 200 1.1 0 1.0 0.9 Output Voltage Output Voltage VOUT(V) 400 1.3 Output Current IOUT(mA) 600 1.2 200 1.1 0 1.0 0.9 R1172x101x R1172x101x 100 1.16 Output Current 1.12 1.08 50 0 1.04 Output Voltage 1.00 Output Voltage VOUT(V) 150 1.20 150 1.16 100 Output Current 1.12 1.08 50 0 1.04 Output Voltage 1.00 Output Current IOUT(mA) VIN=2.0V,CIN=Ceramic 4.7μF, COUT=Ceramic 10μF VIN=2.0V,CIN=COUT= Ceramic 4.7μF 0.96 0.96 4 8 0 12 16 20 24 28 32 36 40 Time t(μs) R1172x101x 1.00 0.95 Output Voltage VOUT(V) 0 Output Voltage 8 10 12 14 16 18 20 Time t(μs) 1.20 Output Current IOUT(mA) 20 Output Current 1.05 6 R1172x101x 40 1.10 4 VIN=2.0V,CIN=Ceramic 4.7μF, COUT=Ceramic 10μF VIN=2.0V,CIN=COUT= Ceramic 4.7μF 1.15 2 40 1.15 20 Output Current 0 1.10 1.05 Output Voltage 1.00 0.95 0.90 0.90 0 10 20 30 40 50 60 70 80 90 100 Time t(μs) 0 10 20 30 40 50 60 70 80 90 100 Time t(μs) Output Current IOUT(mA) 0 Output Voltage VOUT(V) Output Voltage 0 10 20 30 40 50 60 70 80 90 100 Time t(μs) Output Current IOUT(mA) Output Voltage VOUT(V) Output Current 0 10 20 30 40 50 60 70 80 90 100 Time t(μs) 1.20 18 400 1.3 0.8 0.8 1.20 600 Output Current IOUT(mA) VIN=2.0V,CIN=COUT= Ceramic 4.7μF 1.4 Output Voltage VOUT(V) R1172x101x VIN=2.0V,CIN=Ceramic 4.7μF, COUT=Ceramic 10μF R1172x R1172x301x VIN=4.0V,CIN=COUT= Ceramic 4.7μF 3.4 200 3.2 0 3.0 2.8 Output Voltage Output Voltage VOUT(V) Output Current Output Current IOUT(mA) 400 3.6 3.8 2.6 600 400 3.6 Output Current 3.4 200 3.2 0 3.0 2.8 Output Voltage 2.6 0 40 80 120 160 200 240 280 320 360 400 Time t(μs) 0 40 80 120 160 200 240 280 320 360 400 Time t(μs) R1172x301x VIN=4.0V,CIN=Ceramic 4.7μF, COUT=Ceramic 10μF 100 3.16 Output Current 3.12 50 3.08 0 3.04 Output Voltage 3.00 Output Voltage VOUT(V) 150 Output Current IOUT(mA) 3.20 150 3.16 100 3.08 0 4 Output Voltage 3.00 0 8 12 16 20 24 28 32 36 40 Time t(μs) 0 3.00 Output Voltage Output Voltage VOUT(V) 20 Output Current 3.05 6 8 10 12 14 16 18 20 Time t(μs) 3.20 40 3.10 4 R1172x301x VIN=4.0V,CIN=COUT= Ceramic 4.7μF 3.15 2 VIN=4.0V,CIN=Ceramic 4.7μF, COUT=Ceramic 10μF Output Current IOUT(mA) Output Voltage VOUT(V) 0 3.04 R1172x301x 2.95 50 2.96 2.96 3.20 Output Current 3.12 40 20 3.15 Output Current 0 3.10 3.05 3.00 2.95 Output Voltage Output Current IOUT(mA) Output Voltage VOUT(V) R1172x301x VIN=4.0V,CIN=COUT= Ceramic 4.7μF 3.20 Output Current IOUT(mA) 600 Output Current IOUT(mA) 3.8 Output Voltage VOUT(V) R1172x301x VIN=4.0V,CIN=Ceramic 4.7μF, COUT=Ceramic 10μF 2.90 2.90 0 40 80 120 160 200 240 280 320 360 400 Time t(μs) 0 40 80 120 160 200 240 280 320 360 400 Time t(μs) 19 R1172x R1172x501x 5.50 200 5.25 0 5.00 4.75 Output Voltage 4.50 150 100 5.16 Output Current 5.12 50 5.08 0 5.04 Output Voltage 5.00 Output Current IOUT(mA) Output Current Output Voltage VOUT(V) 400 5.75 VIN=6.0V,CIN=COUT= Ceramic 4.7μF 5.20 600 Output Current IOUT(mA) Output Voltage VOUT(V) 6.00 R1172x501x VIN=6.0V,CIN=COUT= Ceramic 4.7μF 4.96 0 0 40 80 120 160 200 240 280 320 360 400 Time t(μs) 2 4 6 8 10 12 14 16 18 20 Time t(μs) R1172x501x VIN=6.0V,CIN=COUT= Ceramic 4.7μF 40 20 5.15 Output Current 0 5.10 5.05 5.00 4.95 Output Voltage Output Current IOUT(mA) Output Voltage VOUT(V) 5.20 4.90 0 40 80 120 160 200 240 280 320 360 400 Time t(μs) 13) Turn-on speed with CE pin control -20 0 20 20 40 60 80 100 120 140 160 180 Time t(μs) 10 VIN=6.0V,CIN=COUT= Ceramic 4.7μF 8 8 6 6 4 4 2 2 IOUT=0mA IOUT=100mA IOUT=300mA VIN(V) 0 -40 0 60 160 Time t(μs) 260 360 0 CE Input Voltage VCE(V) IOUT=0mA IOUT=100mA IOUT=300mA VCE 2.0 1.6 1.2 0.8 0.4 0.0 Output Voltage VOUT(V) 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 R1172x501x CE Input Voltage VCE(V) Output Voltage VOUT(V) R1172x081x VIN=1.8V,CIN=COUT= Tantalum 4.7μF R1172x 14) Turn-off speed with CE pin control 2.0 1.6 1.2 0.8 0.4 0.0 IOUT=0mA IOUT=100mA IOUT=300mA VIN(V) -0.4 0 0.6 1.6 Time t(ms) 2.8 14 VIN=6.0V,CIN=COUT= Tantalum 4.7μF 8 12 6 10 4 8 2 6 CE Input Voltage VCE(V) VIN=1.8V,CIN=COUT= Tantalum 4.7μF Output Voltage VOUT(V) 2.0 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 R1172x501D CE Input Voltage VCE(V) Output Voltage VOUT(V) R1172x081D 0 IOUT=0mA IOUT=100mA IOUT=300mA VIN(V) 4 2 0 -0.2 0 0.2 3.6 0.6 1.0 Time t(ms) 1.4 1.8 15) Inrush Current (IOUT=100mA, CIN=none) 1.6 CE Input Voltage 0.8 0.0 Output Voltage 600 400 200 0 Inrush Current -40 0 40 80 Time t(μs) 120 160 2.4 VIN=2.0V,COUT= Tantalum 10μF 1.6 CE Input Voltage 0.8 0.0 Output Voltage 600 400 200 0 Inrush Current -40 0 40 80 Time t(μs) 120 Inrush Current IVDD(mA) VIN=2.0V,COUT= Tantalum 4.7μF CE Input Voltage VCE ,Output Voltage VOUT(V) 2.4 R1172x081x Inrush Current IVDD(mA) CE Input Voltage VCE ,Output Voltage VOUT(V) R1172x081x 160 21 R1172x CE Input Voltage 3 2 Output Voltage 1 0 600 400 Inrush Current 200 0 -40 0 40 80 Time t(μs) 120 5 4 CE Input Voltage 3 2 Output Voltage 1 0 600 400 Inrush Current 200 0 160 -40 0 CE Input Voltage 6 4 Output Voltage 2 0 600 400 Inrush Current 200 0 -40 22 0 40 80 Time t(μs) 120 160 CE Input VoltageVCE ,Output Voltage VOUT(V) VIN=6.0V,COUT= Ceramic 4.7μF 8 120 160 R1172x501x Inrush Current IVDD(mA) CE Input VoltageVCE ,Output Voltage VOUT(V) R1172x501x 40 80 Time t(μs) Inrush Current IVDD(mA) 4 VIN=4.0V,COUT= Ceramic 10μF VIN=6.0V,COUT= Ceramic 10μF 8 CE Input Voltage 6 4 Output Voltage 2 0 600 Inrush Current 400 200 0 -40 0 40 80 Time t(μs) 120 160 Inrush Current IVDD(mA) 5 CE Input VoltageVCE ,Output Voltage VOUT(V) R1172x301x Inrush Current IVDD(mA) CE Input Voltage VCE ,Output Voltage VOUT(V) R1172x301x VIN=4.0V,COUT= Ceramic 4.7μF R1172x ESR vs. Output Current When using these ICs, consider the following points: CE VOUT R1172xxx1B COUT S.A VIN VIN GND CIN Spectrum Analyzer ESR IOUT 0.8V to 3.3V Output type: COUT=4.7μF (Kyocera CM105X5R475M06AB) 5.0V Output type : COUT=4.7μF (Kyocera CT21X5R475K06AB) As an output capacitor for this IC, Ceramic capacitor is recommendable. However, other low ESR type capacitor can be used with this IC. For your reference, noise level is tested, and if the noise level is 40μV or less than 40μV, the ESR values are plotted as stable area. Upper limit is described in the next five graphs, or ESR vs. Output Current. (Hatched area is the stable area.) Measurement conditions ⋅ VIN=VOUT+1V ⋅ Frequency Band: 10Hz to 1MHz ⋅ Temperature : 25°C R1172x081x R1172x081x VIN=1.4V to 6.0V, CIN=COUT=Ceramic 4.7μF VIN=1.4V to 6.0V, CIN=Ceramic 4.7μF, COUT=Ceramic 10μF 100 100 Topt=-40°C 1.0 10 ESR(Ω) ESR(Ω) Topt=85°C Topt=85°C 10 Topt=-40°C 1.0 0.1 0.1 0.01 0.01 0 200 400 600 800 Load Current IOUT(mA) 1000 0 200 400 600 800 Load Current IOUT(mA) 1000 23 R1172x R1172x101x R1172x301x VIN=1.4V to 6.0V, CIN=COUT=Ceramic 4.7μF VIN=3.1V to 6.0V, CIN=COUT=Ceramic 4.7μF 100 100 Topt=-40°C 1.0 0.1 0.01 0.01 0 200 400 600 800 1000 Load Current IOUT(mA) VIN=5.3V to 6.0V, CIN=COUT=Ceramic 4.7μF 100 Topt=85°C 10 Topt=-40°C 1.0 0.1 0.01 0 200 400 600 800 Load Current IOUT(mA) 0 200 400 600 800 Load Current IOUT(mA) R1172x501x ESR(Ω) 10 ESR(Ω) ESR(Ω) Topt=-40°C 1.0 0.1 24 Topt=85°C Topt=85°C 10 1000 1000 1. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. 2. The materials in this document may not be copied or otherwise reproduced in whole or in part without prior written consent of our company. 3. Please be sure to take any necessary formalities under relevant laws or regulations before exporting or otherwise taking out of your country the products or the technical information described herein. 4. The technical information described in this document shows typical characteristics of and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our company's or any third party's intellectual property rights or any other rights. 5. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death (aircraft, spacevehicle, nuclear reactor control system, traffic control system, automotive and transportation equipment, combustion equipment, safety devices, life support system etc.) should first contact us. 6. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. 7. Anti-radiation design is not implemented in the products described in this document. 8. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. 9. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. 10. There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. 11. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
R1172N301D-TR-FE 价格&库存
很抱歉,暂时无法提供与“R1172N301D-TR-FE”相匹配的价格&库存,您可以联系我们找货
R1172N301D-TR-FE
  • 1+9.426651+1.22188
  • 10+6.7829310+0.87920
  • 25+6.1199725+0.79327
  • 100+5.39609100+0.69944
  • 250+5.05039250+0.65463
  • 500+4.84234500+0.62766
  • 1000+4.716921000+0.61141
库存:2010
R1172N301D-TR-FE
  • 3000+4.459123000+0.57799
  • 6000+4.355516000+0.56456
  • 9000+4.303619000+0.55783
  • 15000+4.2461215000+0.55038
库存:2010
