TS2937
Taiwan Semiconductor
500mA Ultra Low Dropout Voltage Regulator
DESCRIPTION
FEATURES
TS2937 of fixed-voltage monolithic micro-power voltage
This device excellent choice of use in battery-power
Dropout voltage typically 0.6V @ Io=500mA
Output voltage trimmed before assembly
-18V Reverse peak voltage
application.
current
+30V Input over voltage protection
increases on slightly at dropout, which prolongs battery
+60V Transient peak voltage
Internal current limit
Thermal shutdown protection
regulators is designed for a wide range of applications.
Furthermore,
the
quiescent
life. This series of fixed-voltage regulators features very
low ground current (200uA Typ.) and very low drop
output voltage (Typ. 60mV at light load and 600mV at
500mA). This includes a tight initial tolerance of 2%,
APPLICATION
extremely good line regulation of 0.05% typ., and very
Post Regulator for SMPS
low output temperature coefficient.
Industrial Instrumentation
TO-220
2
TO-263 (D PAK)
TO-252 (DPAK)
SOT-223
Pin Definition:
1. Input
2. Ground
3. Output
Notes: Moisture sensitivity level: level 3. Per J-STD-020
TYPICAL APPLICATION CIRCUIT
Document Number: DS_P0000215
1
Version: E15
TS2937
ABSOLUTE MAXIMUM RATINGS (Note 1)
PARAMETER
Input Supply Voltage
SYMBOL
LIMIT
UNIT
VIN
-18 ~ +60
V
VOPR
26
V
PD
Internally Limited
(Note 2)
Operation Input Supply Voltage
(Note 3)
Power Dissipation
Operating Junction Temperature Range
TJ
TSTG
Storage Temperature Range
W
-40 ~ +125
o
-65 ~ +150
o
C
C
THERMAL PERFORMANCE
PARAMETER
LIMIT
SYMBOL
UNIT
TO-220 TO-263 TO-252 SOT-223
RӨJA
Junction to Ambient Thermal Resistance
60
80
150
170
°C/W
Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined
at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board
design. RӨJA shown below for single device operation on FR-4 PCB in still air.
ELECTRICAL SPECIFICATIONS
(VIN=VOUT+1V, IL=5mA, CO=10uF, TA=25oC, unless otherwise noted)
PARAMETER
CONDITIONS
MIN
TYP
MAX
0.980|Vo|
12 / 10
1.020|Vo|
0.970|Vo|
5.0 / 3.3
1.030|Vo|
26
V
Output Voltage Temperature Coefficient
50
150
ppm/ C
5mA ≤ IL ≤ 500mA,
Output Voltage
Vo+1V ≤ VIN≤ 26V
UNIT
V
o
Line Regulation
Vo+1V ≤ VIN ≤ 26V
0.05
0.5
Load Regulation
5mA ≤ IL ≤ 500mA
0.2
1.0
IL=100mA
100
300
IL=300mA
400
500
IL=500mA
600
700
IL=100µA
200
IL=300mA
12
IL=500mA
25
VOUT =0
1.3
CL=2.2µF
500
CL=3.3µF
350
CL=33µF
120
Dropout Voltage
(Note 4)
Quiescent Current
(Note 5)
Short Circuit Current
(Note 6)
Output Noise,
10Hz to 100KHz, IL=10mA
2
mV
µA
mA
A
µVrms
Version: E15
TS2937
Note:
1. Absolute Maximum Rating is limits beyond which damage to the device may occur.
For guaranteed specifications and test conditions see the electrical characteristics.
2. Maximum positive supply voltage of 60V must be limited duration (
很抱歉,暂时无法提供与“TS2937CP50 ROG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2500+5.257152500+0.65755
- 5000+5.133185000+0.64205
- 7500+5.071147500+0.63429
- 12500+5.0023712500+0.62569
- 17500+4.9622217500+0.62066
- 国内价格 香港价格
- 2500+3.993542500+0.49950
- 国内价格 香港价格
- 1+17.526801+2.19220
- 10+10.9316610+1.36730
- 25+9.2151225+1.15260
- 50+8.2213350+1.02830
- 100+7.31789100+0.91530
- 250+6.68548250+0.83620
- 国内价格 香港价格
- 1+10.880151+1.36086
- 10+7.8563210+0.98265
- 25+7.1080725+0.88906
- 100+6.28647100+0.78630
- 250+5.89415250+0.73723
- 500+5.65759500+0.70764
- 1000+5.462831000+0.68328
