R1518J501D-T1-FE
R1518J501D-T1-FE
    NISSHINBO(日清纺)
    TO-252-5-P2
    PMIC - 稳压器 - 线性 正 固定 1 输出 1A TO-252-5-P2
R1518J501D-T1-FE 数据手册
R1518x Series 1 A 36V Input Low Supply Current LDO NO.EA−329−230124 OUTLINE R1518x is a CMOS-based LDO that specifically designed for automotive applications featuring 1 A output current and 36 V input voltage. In addition to a conventional regulator circuit, R1518x consists of a constant slope circuit as a soft-start function, a fold-back protection circuit, a short current limit circuit, and a thermal shutdown circuit. Besides the low supply current by CMOS, the operating temperature is −40°C to 105°C and the maximum input voltage is 36 V, the R1518x is very suitable for power source of car accessories. R1518x is available in R1518xxxxB/D/E/F with the internally fixed output voltage, and R1518xxxxD/F with the auto-discharge function at standby. The output voltage of R1518x001C can be set with an external resistor, and the setting range is from 2.5V to Max 20V.R1518xxxxB/C/D internally fixes the soft-start time at 120 µs (Typ). R1518xxxxE/F can adjust the soft-start time with an external capacitor. R1518x is available in two packages for ultra high wattage: HSOP-6J and TO-252-5-P2. FEATURES  Input Voltage Range (Maximum Rating) ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ 3.5 V to 36.0 V (50.0V)  Operating Temperature rang ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ 40°C to 105°C  Supply Currentꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 18 µA  Standby Current ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 0.1 µA  Dropout Voltage ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 0.7 V (IOUT = 1 A, VOUT = 5.0 V)  Output Voltage Accuracy ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ ±0.8% (VOUT ≤ 5.0 V)  Line Regulation ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 0.01%/V   Packages ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ HSOP-6J, TO-252-5-P2 Output Voltage Range ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ R1518xxxxB/D/E/F: 2.5V/3.3V/3.4V/5.0V/6.0V/8.5V/9.0V R1518x001C: Adjustable from 2.5 V to 20.0 V with external resistor Feedback Voltage: 2.5 V  Built-in Short Current Limit Circuit ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 150 mA  Built-in Fold-Back Protection Circuitꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Min. 1A  Built-in Thermal Shutdown Circuit ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 160°C  Built-in Soft-start Circuit ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ.120 µs R1518xxxxE/F: Adjustable Time Setting with External Capacitors.  Ceramic Capacitors can be used ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ R1518xxxxB/D/E/F: 0.1 µF or more R1518x001C: 1.0 µF or more 1 R1518x NO.EA−329−230124 APPLICATIONS    Power source for home appliances such as refrigerators, rice cookers, electric water warmers. Power source for notebook PCs, digital TVs, telephones, private LAN systems. Power source for office equipment such as copiers, printers, facsimiles, scanners, and projectors SELECTION GUIDE The output voltage, version, and package type for this device can be selected at the user’s request. Product Name Package Quantity per Reel Pb Free Halogen Free R1518Sxx1-E2-FE HSOP-6J 1,000 pcs Yes Yes R1518Jxx1-T1-FE TO-252-5-P2 3,000 pcs Yes Yes xx: Specify the set output voltage (VSET) 2.5 V (25) / 3.3 V (33) / 3.4 V (34) / 5.0 V (50) / 6.0 V (60) / 8.5 V (85) / 9.0 V (90) Adjustable output voltage setting type is fixed to (00) Note: R1518x001C-T1-#E only support   Specify the version with desired functions B: No auto-discharge function C: No auto-discharge function / Adjustable output voltage setting D: Auto-discharge function E: No auto-discharge function / Adjustable soft-start time setting F: Auto-discharge function / Adjustable soft-start time setting Auto-Discharge function quickly lowers the output voltage to 0 V by releasing the electrical charge in the external capacitor when the chip enable signal is switched from the active mode to the standby mode. 2 R1518x NO.EA−329−230124 BLOCK DIAGRAMS R1518xxxxB VDD Internal VR R1518x001C VOUT VDD Soft Start Internal VR VFB Soft Start Vref VOUT Vref Current Limit Thermal Shutdown CE Current Limit Thermal Shutdown GND CE GND R1518xxxxE R1518xxxxD VOUT VDD VDD Internal VR Internal VR Soft Start Soft Start DELAY Vref Current Limit Thermal Shutdown Vref Current Limit Thermal Shutdown GND VOUT GND CE CE R1518xxxxF VDD Internal VR VOUT Soft Start DELAY Vref Current Limit Thermal Shutdown CE GND 3 R1518x NO.EA−329−230124 PIN DESCRIPTION 6 5 4 * 1 2 3 1 HSOP-6J 2 3 4 5 TO-252-5-P2 HSOP-6J Pin No. Symbol 1 VDD Input Pin 2 GND Ground Pin 3 Description NC No Connection R1518SxxxB/D VFB Feedback Pin R1518S001C Adjustable Soft-start Time Pin R1518SxxxE/F DELAY 4 CE Chip Enable Pin, Active-high 5 GND Ground Pin 6 VOUT Output Pin  TO-252-5-P2 Pin No. Symbol 1 VDD 2 Description Input Pin NC No Connection R1518Jxx1B/D VFB Feedback Pin R1518J001C Adjustable Soft-start Time Pin R1518Jxx1E/F DELAY 3 GND 4 CE 5 VOUT Ground Pin Chip Enable Pin, Active-high Output Pin * The tab on the bottom of the package enhances thermal performance and is electrically connected to GND (substrate level). The tab is recommended to connect to the ground plane on the board. Otherwise it may be left floating. 4 R1518x NO.EA−329−230124 PIN EQUIVALENT CIRCUIT DIAGRAMS Driver CE VOUT VOUT Pin CE Pin Internal VR VFB DELAY DELAY Pin VFB Pin (R1518xxxxE/F) (R1518x001C) 5 R1518x NO.EA−329−230124 ABSOLUTE MAXMUM RATINGS Symbol Item Rating Unit −0.3 to 50 V VIN Input Voltage VIN Peak Input Voltage (1) 60 V VCE Input Voltage (CE Pin) −0.3 to 50 V VFB Input Voltage (VFB Pin) −0.3 to 50 V VOUT Output Voltage −0.3 to VIN + 0.3 ≤ 50 V PD Power Dissipation (2) HSOP-6J 2700 (JEDEC STD.51-7) TO-252-5-P2 3800 mW Tj Junction Temperature Range −40 to 125 °C Tstg Storage Temperature Range −55 to 125 °C ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damage and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. RECCOMENDED OPERATING CONDITIONS Recommended Operating Conditions Symbol Parameter VIN Input Voltage Ta Operating Temperature Range Rating Unit 3.5 to 36 V −40 to 105 C RECOMMENDED OPERATING CONDITIONS All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if they are used over such ratings by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. (1) Duration time = 200 ms to POWER DISSIPATION for detailed information (2) Refer 6 R1518x NO.EA−329−230124 ELECTRICAL CHARACTERISTICS VIN = VSET + 1.0 V, IOUT = 1 mA, CIN = COUT = 0.1 F, unless otherwise noted. The specifications surrounded by are guaranteed by design engineering at -40°C ≤ Ta ≤ 105°C. R1518xxxxB/D Symbol (Ta = 25°C) Item Conditions Ta = 25°C VOUT Output Voltage −40°C ≤ Ta ≤ 105°C Max. Unit VSET ≤ 5.0 V 0.992 1.008 V 0.99 1.01 V VSET ≤ 5.0 V 0.982 1.018 V 0.98 1.02 V VSET > 5.0 V VSET > 5.0 V Min. Typ. VIN = VSET + 2.0 V, 1mA ≤ IOUT ≤ 250 mA −15 3 25 mV VIN = VSET + 2.0 V, 1mA ≤ IOUT ≤ 1 A −60 10 60 mV Dropout Voltage IOUT = 1 A Refer to the Product-specific Electrical Characteristics Supply Current IOUT = 0 mA 18 36 µA Istandby Standby Current VCE = 0 V 0.1 2.0 µA VOUT /VIN Line Regulation VSET + 0.5 V ≤ VIN ≤ 36 V, Under the condition of VIN ≥ 3.5 V 0.01 0.02 %/V VOUT /Ta Output Voltage −40°C ≤ Ta ≤ 105°C Temperature Coefficient VOUT /IOUT Load Regulation VDIF ISS ppm /°C ±60 ILIM Output Current Limit VIN = VSET +2.0 V 1 A ISC Short Current Limit VIN =5.0 V, VOUT = 0 V 150 IPD CE Pull-down Current VCE = 5.0 V 0.2 0.6 µA VCE = 36 V 0.5 1.3 µA tD1 Soft-start Time 1 mA 120 µs VCEH CE Input Voltage "H" 2.2 V VCEL CE Input Voltage "L" TTSD Thermal Shutdown Temperature Junction Temperature 160 °C TTSR Thermal Shutdown Released Temperature Junction Temperature 135 °C RLOW Low Output Nch Tr. ON Resistance (R1518xxxxD) VIN = 14.0 V, VCE = 0 V 3.2 kΩ 1.0 V All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25°C) except for Output Voltage Temperature Coefficient and Soft-start Time 1. 7 R1518x NO.EA−329−230124 VIN = VFB ( = 2.5 V) + 1.0 V = 3.5 V, IOUT = 1 mA, CIN = 0.1 µF, COUT = 1.0 µF unless otherwise noted. The specifications surrounded by are guaranteed by design engineering at -40°C ≤ Ta ≤ 105°C. R1518x001C Symbol VFB (Ta = 25C) Item Feedback Voltage Conditions /IOUT Load Regulation Typ. Max. Unit Ta = 25°C 2.480 2.520 V −40°C ≤ Ta ≤ 105°C 2.455 2.545 V VIN = 4.5 V, VOUT Min. 1mA ≤ IOUT ≤ 250 mA VIN = 4.5 V, 1 mA ≤ IOUT ≤ 1 A −10 3 10 mV −25 5 35 mV VDIF Dropout Voltage IOUT = 1 A 1.0 1.8 V ISS Supply Current IOUT = 0 mA 18 36 µA Standby Current VCE = 0 V 0.1 2.0 µA Line Regulation 3.5 V ≤ VIN ≤ 36 V 0.01 0.02 %/V −40°C ≤ Ta ≤ 105°C ±60 Istandby VOUT /VIN VOUT Output Voltage /Ta Temperature Coefficient ppm /°C ILIM Output Current Limit VIN = 4.5 V ISC Short Current Limit VCE = 5.0 V, VOUT = VFB = 0 V 150 VCE = 5.0 V 0.2 0.6 µA IPD CE Pull-down Current VCE = 36 V 0.5 1.3 µA tD1 Soft-start Time 1 VCEH CE Input Voltage "H" VCEL CE Input Voltage "L" TTSD TTSR Thermal Shutdown Temperature Thermal Shutdown Released Temperature 1 A mA 120 µs 2.2 V 1.0 V Junction Temperature 160 °C Junction Temperature 135 °C VOUT = VFB = 2.5 V (excluding short circuit current) All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25°C) except for Output Voltage Temperature coefficient and Soft-start Time 1. 8 R1518x NO.EA−329−230124 VIN = VSET + 1.0 V, IOUT = 1 mA, CIN = COUT = 0.1 F, unless otherwise noted. are guaranteed by design engineering at -40°C ≤ Ta ≤ 105°C. The specifications surrounded by R1518xxxxE/F Symbol (Ta = 25C) Item Conditions Ta = 25°C VOUT Output Voltage −40°C ≤ Ta ≤ 105°C Min. Typ. Max. Unit VSET ≤ 5.0 V 0.992 1.008 V VSET > 5.0 V 0.99 1.01 V VSET ≤ 5.0 V 0.982 1.018 V VSET > 5.0 V 0.98 1.02 V VIN = VSET +2.0 V, 1 mA ≤ IOUT ≤ 250 mA −15 3 25 mV VIN = VSET +2.0 V, 1 mA ≤ IOUT ≤ 1 A −60 10 60 mV Dropout Voltage IOUT = 1 A Refer to the Product-specific Electrical Characteristics Supply Current IOUT = 0 mA 18 36 µA VCE = 0 V 0.1 2.0 µA 0.02 %/V VOUT /IOUT Load Regulation VDIF ISS Istandby Standby Current VOUT /VIN Line Regulation VSET +0.5 V ≤ VIN ≤ 36 V, Under the condition of VIN ≥ 3.5 V 0.01 VOUT /Ta Output Voltage Temperature Coefficient −40°C ≤ Ta ≤ 105°C ±60 ILIM Output Current Limit VIN = VSET +2.0 V ISC Short Current Limit VIN = 5.0 V, VOUT = 0 V 150 IPD CE Pull-down Current VCE = 5.0 V 0.2 0.6 µA VCE = 36 V 0.5 1.3 µA 2.5 3.5 µA IDELAY DELAY Current DELAY = GND tD1 Soft-start Time 1 DELAY = OPEN tD2 Soft-start Time 2 DELAY = 0.001 F ppm /°C 1 1.5 A mA 26 210 290 µs 415 2.2 µs VCEH CE Input Voltage "H" V VCEL CE Input Voltage "L" TTSD Thermal Shutdown Temperature Junction Temperature 160 °C TTSR Thermal Shutdown Released Temperature Junction Temperature 135 °C RLOW Low Output Nch Tr. ON VIN = 14.0 V, VCE = 0 V Resistance (R1518xxx1F) 3.2 kΩ 1.0 V All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25°C) except for Output Voltage Temperature Coefficient, Soft-start Time 1, and Soft-start Time 2. 9 R1518x NO.EA−329−230124 The specifications surrounded by are guaranteed by design engineering at -40°C ≤ Ta ≤ 105°C. R1518xxxxB/D/E/F Product-specific Electrical Characteristics Product Name VOUT [V] (Ta = 25°C) (Ta = 25C) VOUT [V] (−40C ≤ Ta ≤ 105C) VDIF [V] Min. Typ. Max. Min. Typ. Max. Typ. Max. R1518x251x 2.480 2.500 2.520 2.455 2.500 2.545 1.00 1.80 R1518x331x 3.274 3.300 3.326 3.241 3.300 3.359 R1518x341x 3.373 3.400 3.427 3.339 3.400 3.461 0.90 1.60 R1518x501x 4.960 5.000 5.040 4.910 5.000 5.090 R1518x601x 5.940 6.000 6.060 5.880 6.000 6.120 0.70 1.30 R1518x851x 8.415 8.500 8.585 8.330 8.500 8.670 0.65 1.10 R1518x901x 8.910 9.000 9.090 8.820 9.000 9.180 0.65 1.10 10 R1518x NO.EA−329−230124 OPERATION DESCRIPTION Thermal Shutdown Function Thermal shutdown function is included in this device. If the junction temperature is more than or equal to 160°C (Typ.), the operation of the regulator would stop. After that, when the junction temperature is less than or equal to 135°C (Typ.), the operation of the regulator would restart. Unless the cause of rising temperature is removed, the regulator repeats on and off, and output waveform would be like consecutive pulses. Adjustable Output Voltage Setting (R1518x001C) The output voltage of R1518x001C can be adjusted by using the external divider resistors (R1, R2). By using the following equation, the output voltage (VOUT) can be determined. The voltage which is fixed inside the IC is described as VFB. VOUT = VFB x ((R1 + R2) / R2) Recommended Range: 2.5 V ≤ VOUT ≤ 20.0 V VFB = 2.5 V VOUT R1 I1 VFB RIC VOUT IIC R2 I2 GND VFB Output Voltage Adjustment Using External Divider Resistors (R1, R2) RIC of the R1518x001C is approximately Typ. 1.35 MΩ (Ta=25C, guaranteed by design engineering). For better accuracy, setting R1
R1518J501D-T1-FE 价格&库存
很抱歉,暂时无法提供与“R1518J501D-T1-FE”相匹配的价格&库存,您可以联系我们找货
R1518J501D-T1-FE
  • 1+14.421601+1.87216
  • 10+10.5800910+1.37347
  • 25+9.6114225+1.24772
  • 100+8.54267100+1.10898
  • 250+8.03339250+1.04287
  • 500+7.72645500+1.00302
  • 1000+7.670161000+0.99571
库存:1238
R1518J501D-T1-FE
  • 3000+7.161723000+0.92971
  • 6000+7.009026000+0.90989
  • 9000+6.932579000+0.89996
库存:1238
