TDA2030A(XBLW)
TDA2030A(XBLW)
    XBLW(芯伯乐)
    TO220B
    18W音频放大器,工作电压:44V,输出电流4.5A
TDA2030A(XBLW) 数据手册
XBLW TDA2030A 18W Hi-Fi AMPLIFIER AND 35W DRIVER General Description The XBLW TDA2030A is a monolithic integrated circuit in Pentawatt package, intended for use as an audio class AB audio amplifier. Thanks to its high power capability the TDA2030A is able to provide up to 35W true rms power into 4 ohm load@ THD =10%, VS = 36V, f = 1KHz and up to 32W into 8ohm load @THD = 10%, VS = 44V, f = 1KHz. Moreover, the TDA2050A delivers typically 50W music power into 4 ohm load over 1 sec at VS=22.5V, f = 1KHz. The high power and very low harmonic and crossover distortion (THD = 0.05% typ, @ VS = 44V, PO = 0.1 to 15W, RL=8ohm, f = 100Hz to 15KHz) make the device most suitable for both HiFi and high class TV sets.) Ordering Information Product Model XBLW TDA2030A Package Type TO-220B Marking Packing Packing Qty TDA2030A Tube 1000PCS/Box TYPICAL APPLICATIONS XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第1页共7页 XBLW TDA2030A 18W Hi-Fi AMPLIFIER AND 35W DRIVER ABSOLUTE MAXIMUM RATINGS Symbol Vs Vi Vi Io Pto t Tst g , Tj Parameter Unit Value Supply Voltage Input Voltage Differential Input Voltage Peak Output Current ( internally limited ) Total Power Dissipation at T case = 9 0 ° C Storage and Junction Temperature ± 25 Vs ± 15 4.5 25 – 4 0 to + 1 5 0 V V A W °C THERMAL DATA Symbol Rth (j- case ) Parameter Thermal Resistance Junction - case Max Value Unit 3 ° C/ W ELECTRICAL CHARACTERISTICS ( Refer to the test circuit , VS = ± 1 8 V , Tam b = 2 5 o C unless otherwise specified ) Symbol Parameter Test Conditions Vs Id Ib Vo s Io s Supply Voltage Quie scent Drain Current Input Bi a s Current Input Offset Voltage Input Offs et Current PO Output Pow er ± 4.5 VS = ± 2 2 V VS = ± 2 2 V d = 0 . 5 % , G v = 2 6 dB f = 4 0 to 1 5 KHz RL = 4 Ω RL = 8 Ω VS = ± 2 2 V RL = 8 Ω BW Pow er B andwidth SR Gv Gv Slew Rate Open Loop Voltage G ain Clo sed Loop Voltage G ain d d2 d3 eN iN S/N Ri S VR Tj Po = 1 5 W 24 22 RL = 4 Ω f = 1 kHz f = 1 kHz 30 Po = 0 . 1 to 1 4 W RL = 4 Ω Total H arm onic Di stor tion f = 4 0 to 1 5 KHz f = 1 kHz Po = 0 . 1 to 9 W f = 4 0 to 1 5 0 0 0 Hz RL = 8 Ω Secon d Order CC IF Inter m odul ation Di stortion Third Order CC IF Inter m odul ation Di stortion B = Curv e A Input Noi s e Voltage B = 2 2 Hz to 2 2 kHz B = Curv e A Input Noi s e Current B = 2 2 Hz to 2 2 kHz RL = 4 Ω , Rg = 1 0 k Ω , B = Curve A Sign al to Noi s e Ratio PO = 1 5 W PO = 1 W Input Re si stan ce ( pin 1 ) ( open loop ) f = 1 kHz Supply Voltage Rejection RL = 4 Ω , Rg = 2 2 k Ω G v = 2 6 dB , f = 1 0 0 Hz Therm al Shut - down Jun ction XBLWversion1.0 Min . Ty p . 26 0.2 ± 2 ± 20 ± 25 35 2 ± 20 ±200 V mA µA mV nA W 18 W 25 W 40 kHz 6 80 30.5 V / µ sec dB dB 31 0.08 % 0.03 % 0.5 % 0.03 % 0.08 % 10 200 µV µV pA pA 106 94 5 45 dB dB MΩ dB 140 °C 文档仅供参考,实际应用测试为准 www.xinboleic.com Unit 28 2 3 50 80 0.5 Max . 技术支持热线:4009682003 第2页共7页 XBLW TDA2030A 18W Hi-Fi AMPLIFIER AND 35W DRIVER Figure 1 : Single Supply Amplifier XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第3页共7页 XBLW TDA2030A 18W Hi-Fi AMPLIFIER AND 35W DRIVER XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第4页共7页 XBLW TDA2030A 18W Hi-Fi AMPLIFIER AND 35W DRIVER Figure 12 : Typical Amplifier with Spilt Power Supply Figure 13 : Bridge Amplifier with Split Power Supply (PO = 34W , VS = ± 16V ) XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第5页共7页 XBLW TDA2030A 18W Hi-Fi AMPLIFIER AND 35W DRIVER Outline Drawing TO - 2 2 0 B : mm XBLWversion1.0 Un it 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第6页共7页 XBLW TDA2030A 18W Hi-Fi AMPLIFIER AND 35W DRIVER Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第7页共7页
TDA2030A(XBLW) 价格&库存
很抱歉,暂时无法提供与“TDA2030A(XBLW)”相匹配的价格&库存,您可以联系我们找货
TDA2030A(XBLW)
  • 5+1.38346
  • 50+1.09906
  • 150+0.97717
  • 500+0.82511
  • 2000+0.75740
  • 5000+0.71667
库存:234
