26700-220-559WB
26700-220-559WB
    AVENTOOLS(艾文)
    显微镜,数字式 8x ~ 25x LED
26700-220-559WB 数据手册
AVEN Tools for Advancing Innovation Mighty Scope ClearVue All-In-One Digital Microscope ezImage Software Included Measure, Share and Annotate Magnification 8x-25x 5” High Resolution LED Screen Micro SD Card Slot Adjustable LEDs & Focus Wheel 1080P Full HD Process, Save & Share Images w/Spring Balanced Arm & Weighted Base Mighty Scope ClearVue has a built in 5” high resolution LED screen and offers a magnification range of 8x -25x. The included rechargeable battery allows you to operate the microscope without a power supply for hours thus making it suitable for field projects. You can also connect this microscope to an external monitor via an HDMI output for viewing images on a larger screen. Images can be saved on the included Micro SD card. Can also be mounted onto a variety of stands to suit your application. Includes Aven’s Spring Balanced Arm. This arm can be raised, lowered, and tilted as needed. The swivel motion makes it easy to move the ClearVue out of the way when not in use. Features: •Compact All-in-one system •Save high resolution image/video files directly to microSD card •Enhances productivity - eliminates eye strain and body fatigue •1080p Full HD Imaging at 60 FPS •HDMI Output for additional monitor viewing •ezImageX3 software download included •1080p Full HD Output •5” built-in HD screen Crystal Clear 5” Screen EzImage X3 Download Included Mighty Scope ClearVue w/ Spring Arm Item # Aven’s Dual Gooseneck LED Task Light Recommended for improved imaging & color control Sold Separately #26537 26700-220-559WB Magnification 8x-25x | 40x-120x (on 24” Monitor) Effective Pixels 1920(H) x 1080(V) Image Sensor 2M CMOS Sensor Working Dist. 45mm-95mm Interface Mini USB - Type A / HDMI PC Software EZImage X3 Illumination Integrated Ring Light Package Contents Mighty Scope ClearVue digital microscope, USB cable, Power supply, Snap shot remote control, 32gb MicroSD Card, 2600mAh 18650 Li-ion battery, User guide, Spring Balanced Arm, Free ezImageX3 software download aventools.com | sales@aventools.com | 734.973.0099 Mighty Scope ClearVue AVEN Tools for Advancing Innovation Mighty Scope ClearVue on Post Stand #26700-220-MNT •7”x8.5” Metal Base • Vertical adjustment along 10” Post Mighty Scope ClearVue on Flex Arm Stand w/ Table Clamp #26700-220-557 This arm easily bends and stays put in any position. Tilt, rotate, and position as needed •18” Steady Mobile Flex Arm •360° Swivel Head •2” Table Clamp Mighty Scope ClearVue on Flex Arm Stand w/ Magnetic Base #26700-220-558 This arm easily bends and stays put in any position. Tilt, rotate, and position as needed •18” Steady Mobile Flex Arm •360° Swivel Head •3” Magnetic Base Mighty Scope ClearVue on Post Stand w/ Gliding Stage XYR #26700-220-479 •10” Post w/ 7”x8.5” Metal Base •Gliding Stage offers smooth vertical and horizontal movement w/ built in rotating stage, compact design, & metal rack and pinion construction Compact Gliding Stage XYR #26800B-479 •Smooth vertical and horizontal movement w/ Built-in rotating stage •Compact design (5.3 x 4.7 x 3.6 inch base) •Metal rack and pinion construction •Designed to be used with optical and digital microscope systems Dual Gooseneck LED Task Light With Magnetic Base And 4” Table Clamp #26537 •Smooth vertical and horizontal movement w/ Built-in rotating stage •Powerful, long lasting ultra-bright LEDs provide 500lm of flicker and ghost-free illumination •On/Off button toggles between the lamps for single-lamp or dual-lamp lighting •Can be powered 3 ways: with included power supply, 3 AA batteries, or with a rechargeable lithium ion battery aventools.com | sales@aventools.com | 734.973.0099
26700-220-559WB 价格&库存
很抱歉,暂时无法提供与“26700-220-559WB”相匹配的价格&库存,您可以联系我们找货
