Additional Resources:
Product Page
3D Model
date
08/29/2022
page 1 of 4
MODEL: CMR-4015-44-SP | DESCRIPTION: ELECTRET CONDENSER MICROPHONE
FEATURES
• noise cancelling
• 4 mm diameter
• solder pad
SPECIFICATIONS
parameter
conditions/description
directivity
noise cancelling
sensitivity (S)
at 1 kHz, 0 dB = 1 V/Pa
standard operating voltage (Vs)
min
typ
-47
-44
1.0
current consumption (IDSS)
Vs = 2.0 Vdc, RL = 2.2 kΩ
sensitivity reduction (∆S-Vs)
Vs = 2.0 ~ 1.5 Vdc
frequency (f)
100
signal to noise ratio (S/N)
f = 1 kHz, A-weighted
total harmonic distortion (THD)
at 94 dB SPL, 1 kHz
f = 1 kHz
dimensions
Ø4.0 x 1.5
material
Al-Mg alloy
terminal
solder pads
units
-41
dB
5.0
V
500
µA
-3
dB
10,000
55
Hz
dBA
acoustic overload point (AOP)
output impedance (Zout)
max
1
120
dB SPL
2.2
kΩ
mm
weight
0.07
g
operating temperature
-40
85
°C
storage temperature
-40
85
°C
RoHS
Notes:
yes
1. We use the “Pascal (Pa)” indication of sensitivity as per the recomendation of I.E.C. (International Electrotechnical Commission). The sensitivity of “Pa” will increase
20 dB compared to the “ubar” indication. Example: -60 dB (0 dB = 1 V/ubar) = -40 dB ( 1V/Pa)
2. All specifications measured at 20±2°C, humidity at 65±5%, unless otherwise noted.
SOLDERABILITY
parameter
hand soldering
for 1~2 seconds
min
cuidevices.com
typ
max
units
320
°C
Product Page
3D Model
CUI DEVICES | MODEL: CMR-4015-44-SP | DESCRIPTION: ELECTRET CONDENSER MICROPHONE
MECHANICAL DRAWING
units: mm
FREQUENCY RESPONSE CURVE
at L = 2.54 cm
APPLICATION CIRCUIT
RL = 2.2 kΩ
C = 1 µF
Vs=2.0 V
C1=10 pF
C2=33 pF
cuidevices.com
date 08/29/2022 | page 2 of 4
Product Page
3D Model
PACKAGING
units: mm
Anti-Static Bag: 100 x 100 x 2 mm
Inner Box Size: 205 x 105 x 50 mm
Outer Box Size: 550 x 230 x 235 mm
Small Box QTY: 100 pcs per box
Inner Box QTY: 1,000 pcs per box
Outer Box QTY: 30,000 pcs per box
X1
100PCS
X10
1000PCS
X30
30000PC
cuidevices.com
date 08/29/2022 | page 3 of 4
Product Page
3D Model
date 08/29/2022 | page 4 of 4
REVISION HISTORY
rev.
1.0
description
date
initial release
08/29/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CMR-4015-44-SP”相匹配的价格&库存,您可以联系我们找货
