WS05-4R2P
WS05-4R2P
    WAYON(上海维安)
    DFN2510-10
    ESD抑制器/TVS二极管 VRWM=5V VBR(Min)=6V VC=15V@IPP=4.5A
WS05-4R2P 数据手册
Document: W03010017, Rev: J WS05-4R2P Transient Voltage Suppressor Features  Solid-state silicon-avalanche technology  Low operating and clamping voltage  Up to four I/O Lines of Protection  Ultra low capacitance: 0.3pF typical(I/O to I/O)  Low Leakage  Low operating voltage:5V  Flow-Through design 1 DFN2.5x1-10L IEC COMPATIBILITY (EN61000-4)  IEC 61000-4-2 (ESD) ±25kV (air), ±22kV (contact)  IEC 61000-4-4 (EFT) 40A (5/50ns)  IEC 61000-4-5 (Lightning) 4.5A (8/20μs) Mechanical Characteristics Applications  DFN-10L package (2.5×1.0×0.50mm)  Digital Visual Interface(DVI)  Marking: Marking Code  MDDI Ports  Packaging: Tape and Reel  DisplayPort TM Interface  RoHS Compliant  PCI Express  High Definition Multi-Media Interface(HDMI) Circuit Diagram Pin 1 Pin 2 Schematic & PIN Configuration Pin 4 Pin 5 3,8 Pin 4-Line Protection ©2019 WAYON Corporation 1,2,4,5 Identificaion Input Lines 6,7,9,10 Output Lines (No Internal Connection) 3,8 Ground www.way-on.com 1/5 Transient Voltage Suppressor WS05-4R2P Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 68 Watts Peak Pulse Current ( tp =8/20μs ) Ipp 4.5 A Operating Temperature TJ -55 to + 125 °C TSTG -55 to +150 °C Storage Temperature Electrical Parameters (T=25°C) Symbol I Parameter IPP Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IF Reverse Stand-Off Voltage VC VBRVRWM Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IF Forward Current VF Forward Voltage @ IF V IR VF IT IPP Electrical Characteristics Parameter Reverse Stand-Off Voltage Reverse Breakdown Voltage Symbol VRWM VBR Reverse Leakage Current IR Clamping Voltage Vc Clamping Voltage Vc Dynamic Resistance1,2 RDYN Conditions Minimum Typical Any I/O pin to ground IT = 1mA Any I/O pin to ground VRWM = 5V, T=25°C Any I/O pin to ground Ipp=1A, tp=8/20µs Any I/O pin to ground Ipp=4.5A, tp=8/20µs Any I/O pin to ground ©2019 WAYON Corporation Units 5 V 6 TLP=0.2/100ns V 500 nA 9 V 15 V Ω 0.5 IPP = 4A, 10 tp = 0.2/100ns (TLP) IPP = 16A, ESD Clamping Voltage1 VC 16 tp = 0.2/100ns (TLP) VR = 0V, f = 1MHz I/O pin to GND Junction Capacitance V Pin3,8=0V VR = 0V, Cj f = 1MHz 0.3 Between I/O pins Notes:1、TLP Setting:tp=100ns, tr=0.2ns, ITLP and VTLP sample window:t1=70ns to t2=90ns. 2、Dynamic resistance calculated from IPP=4A to IPP=16A using “Best Fit”. ESD Clamping Voltage1 Maximum VC www.way-on.com V V 0.8 pF 0.4 pF 2/5 Transient Voltage Suppressor WS05-4R2P Typical Characteristics Figure 2: Power Derating Curve Ppp – Peak Pulse Power - Ppp(W) Figure 1: Peak Pulse Power vs. Pulse Time 1000 Percent of Rated Power for Ipp 110 68w 8/20µs Waveform 100 10 1 100 90 80 70 60 50 40 30 20 10 0 td – Pulse Duration - µs Ambient Temperature - TA (℃) Figure 4: Normalized Junction Capacitance vs. Reverse Voltage 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 00 Cj(VR)/Cj(VR=0) Clamping Voltage -Vc(V) Figure 3: Clamping Voltage vs. Peak Pulse Current 1 2 3 4 1.5 1.4 1.3 1.2 1.1 1.0 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 F=1MHz 5 Peak Pulse Current -Ipp(A) Reverse Voltage -VR(V) Figure 5: 8/20µs Pulse Waveform Figure 6: TLP I-V Curve tr=8µs 25 110 Waveform Paramters tr=8µs td=20µs Percent Ipp 90 80 70 60 50 40 Half Value Ipp/2 30 20 td=20µs 20 TLP Current (A) 100 15 RDYN=0.50 Ohms 10 5 TLP Parameters: tp=100ns tr=0.2ns 0 10 -5 0 0 Time (µs) ©2019 WAYON Corporation 5 10 15 20 TLP Voltage (V) www.way-on.com 3/5 Transient Voltage Suppressor WS05-4R2P Soldering Parameters Pb – Free assembly Reflow Condition Pre Heat Temperature Min (Ts(min)) Temperature Max (Ts(max)) Time (min to max) (ts ) Average ramp up rate (Liquidus Temp) (TL) to peak TS(max) to TL——Ramp-up Rate Temperature (TL) (Liquidus) Reflow Temperature (tL) Peak Temperature (TP) 150°C 200°C 60 – 190 secs 5°C/second max 5°C/second max 217°C 60 – 150 seconds 260+0/-5 °C Time within actual peak Temperature (tp ) 20 – 40 seconds Ramp-down Rate Time 25°C to peak Temperature (TP) Do not exceed 5°C/second max 8 minutes Max. 280°C Reflow Condition ©2019 WAYON Corporation www.way-on.com 4/5 Transient Voltage Suppressor WS05-4R2P Outline Drawing –DFN2510-10L D 1 DFN2.5x1-10L E PIN1 INDICATOR (LASER MARK) DIMENSIONS DIM A A2 A1 b1xN1 b2 L 2 L2 L1 h 1 MIN NOM MAX MIN NOM MAX 0.018 0.020 0.022 0.45 0.50 0.55 A1 0.000 0.001 0.002 0.00 0.02 0.05 0.006 bxN D/2 0.15 b 0.006 0.008 0.010 0.15 0.20 0.25 b1 0.014 0.016 0.018 0.35 0.40 0.45 b2 0.008 0.010 0.018 0.20 0.25 0.45 D 0.096 0.098 0.100 2.45 2.50 2.55 E 0.037 0.039 0.041 0.95 1.00 1.05 e e MILLIMETERS A A2 R0.1 E/2 INCHES 0.020 BSC 0.50 BSC L 0.014 0.016 0.018 0.35 0.40 0.45 L1 0.000 0.003 0.004 0.00 0.075 0.10 L2 0.000 0.002 0.003 0.00 0.05 0.08 h 0.000 0.005 0.006 0.00 0.12 0.15 N 8 8 N1 2 2 DIMENSIONS P1 P Y C Y1 G X X1 DIM INCHES MILLIMETERS C 0.034 0.875 G 0.008 0.20 P 0.020 0.50 P1 0.039 1.00 X 0.010 0.25 X1 0.018 0.45 Y 0.027 0.675 Y1 0.061 1.55 Notes: Controlling Dimension: Millimeter. Marking Codes Part Number WS05-4R2P Marking Code 5R2P Package Information Qty:3k/Reel CONTACT INFORMATION No.1001, Shiwan (7) Road, Pudong District, Shanghai, P.R.China.201207 Tel: 86-21-68969993 Fax: 86-21-50757680 Email: market@way-on.com WAYON website: http://www.way-on.com For additional information, please contact your local Sales Representative. ® is registered trademark of Wayon Corporation. Specifications are subject to change without notice. The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time. Users should verify actual device performance in their specific applications. ©2019 WAYON Corporation www.way-on.com 5/5
WS05-4R2P 价格&库存
很抱歉,暂时无法提供与“WS05-4R2P”相匹配的价格&库存,您可以联系我们找货
WS05-4R2P
  • 1+0.34210
  • 200+0.22000
  • 1500+0.19140
  • 3000+0.16940
库存:11483
WS05-4R2P
  • 10+0.20000
  • 50+0.18800
  • 200+0.17800
  • 600+0.16800
  • 1500+0.16000
  • 3000+0.15500
库存:2235
