PMM4218TWP
PMM4218TWP
    FLEX(伟创力)
    DIP20 模块
    非隔离 PoL 模块 直流转换器 1 输出 0.8 ~ 2.5V 60A 2.95V - 5.5V 输入
PMM4218TWP 数据手册
E EricssonInternal Limited Internal TABLE OF CONTENTS PRODUCT SPECIFICATION Prepared (also subject responsible if other) MPM/BY/P Stella TAO Henrik Sundh Approved 1 (1) (3) No. series PoL Regulators PMM 4000[Krister series MPM/BY/M Lundberg] Checked 1/1301 00152-EN/LZT146316 BMR 651Technical 4 Uen Specification Specification Date 2006-02-22 2006-04-19 Inputregulator, 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL Input 2.95-5.5 Output 60 60 A/150 A/150 W W Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April A © Flex Ericsson AB Power Modules AB Key Features • • • • • • • • • 60A output current 2.95 -5.5 V input voltage range Output voltages from 0.8V up to 2.5V Industry standard POLATM compatible 52 x 26.7 x 9.07 mm (2.05 x 1.05 x 0.357 in.) High efficiency, up to. 93% Auto TrackTM sequencing pin Differential output voltage sense More than 1.12 million hours MTBF General Characteristics • • • • • • • • Operating temperature: -40oC to 85 oC Start up into a pre-biased output safe Output short-circuit protection Over temperature protection On/Off inhibit control Margin up/down control Highly automated manufacturing ensures quality ISO 9001/14001 certified supplier Safety Approvals Design for Environment Meets requirements in hightemperature lead-free soldering processes. Contents General Information Safety Specification Absolute Maximum Ratings ............................................................. 2 ............................................................. 3 ............................................................. 4 Product Program 0.8-2.5 V/60 A 1.0 V/60 A Electrical Specification 1.2 V/60 A Electrical Specification 1.5 V/60 A Electrical Specification 1.8 V/60 A Electrical Specification 2.5 V/60 A Electrical Specification Ordering No. PMM 4218T ........................................... ............................................................. 5 ........................................................... 11 ........................................................... 17 ........................................................... 23 ........................................................... 26 EMC Specification Operating Information Thermal Consideration Connections Mechanical Information Soldering Information Delivery Information Product Qualification Specification ........................................................... 29 ........................................................... 29 ........................................................... 31 ........................................................... 32 ........................................................... 33 ........................................................... 35 ........................................................... 36 ........................................................... 37 E Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 2 (3) No. Stella TAO Approved series PoL Regulators PMM 4000[Krister series MPM/BY/M Lundberg] Checked 1/1301 BMR 651Technical 4 Uen Specification Specification Date 2006-04-19 Inputregulator, 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL Input 2.95-5.5 Output 60 60 A/150 A/150 W W Rev Reference 2 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April A © Flex Ericsson AB Power Modules AB Compatibility with RoHS requirements General Information Ordering Information See Contents for individual product ordering numbers. Option Through hole pin Suffix P Ordering No. PMM 4218T WP SMD pin, leadfree reflow temperature capable SR PMM 4218T WSR Reliability The Mean Time Between Failure (MTBF) is calculated at full output power and an operating ambient temperature (TA) of +40°C, which is a typical condition in Information and Communication Technology (ICT) equipment. Different methods could be used to calculate the predicted MTBF and failure rate which may give different results. Flex currently uses Telcordia SR332. Predicted MTBF for the series is: 1.12 million hours according to Telcordia SR332, issue 1, Black box technique. Telcordia SR332 is a commonly used standard method intended for reliability calculations in ICT equipment. The parts count procedure used in this method was originally modelled on the methods from MIL-HDBK-217F, Reliability Predictions of Electronic Equipment. It assumes that no reliability data is available on the actual units and devices for which the predictions are to be made, i.e. all predictions are based on generic reliability parameters. The products are compatible with the relevant clauses and requirements of the RoHS directive 2011/65/EU and have a maximum concentration value of 0.1% by weight in homogeneous materials for lead, mercury, hexavalent chromium, PBB and PBDE and of 0.01% by weight in homogeneous materials for cadmium. Exemptions in the RoHS directive utilized in Flex products are found in the Statement of Compliance document. Flex fulfills and will continuously fulfill all its obligations under regulation (EC) No 1907/2006 concerning the registration, evaluation, authorization, and restriction of chemicals (REACH) as they enter into force and is through product materials declarations preparing for the obligations to communicate information on substances in the products. Quality Statement The products are designed and manufactured in an industrial environment where quality systems and methods like ISO 9000, 6σ (sigma), and SPC are intensively in use to boost the continuous improvements strategy. Infant mortality or early failures in the products are screened out and they are subjected to an ATE-based final test. Conservative design rules, design reviews and product qualifications, plus the high competence of an engaged work force, contribute to the high quality of our products. Warranty Warranty period and conditions are defined in Flex General Terms and Conditions of Sale. Limitation of Liability Flex does not make any other warranties, expressed or implied including any warranty of merchantability or fitness for a particular purpose (including, but not limited to, use in life support applications, where malfunctions of product can cause injury to a person’s health or life). © Flex 2017 The information and specifications in this technical specification is believed to be correct at the time of publication. However, no liability is accepted for inaccuracies, printing errors or for any consequences thereof. Flex reserves the right to change the contents of this technical specification at any time without prior notice. E Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) Stella TAO Approved series PoL Regulators PMM 4000[Krister series MPM/BY/M Lundberg] 3 (3) No. Checked 1/1301 BMR 651Technical 4 Uen Specification Specification Date Rev 2006-04-19 Inputregulator, 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL Input 2.95-5.5 Output 60 60 A/150 A/150 W W Reference 3 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April A © Flex Ericsson AB Power Modules AB Safety Specification General information Flex DC/DC converters and DC/DC regulators are designed in accordance with safety standards IEC/EN/ UL60950, Safety of Information Technology Equipment. IEC/EN/UL60950 contains requirements to prevent injury or damage due to the following hazards: • • • • • • Electrical shock Energy hazards Fire Mechanical and heat hazards Radiation hazards Chemical hazards On-board DC-DC converters are defined as component power supplies. As components they cannot fully comply with the provisions of any Safety requirements without “Conditions of Acceptability”. It is the responsibility of the installer to ensure that the final product housing these components complies with the requirements of all applicable Safety standards and Directives for the final product. Component power supplies for general use should comply with the requirements in IEC60950, EN60950 and UL60950 “Safety of information technology equipment”. There are other more product related standards, e.g. IEEE802.3af “Ethernet LAN/MAN Data terminal equipment power”, and ETS300132-2 “Power supply interface at the input to telecommunications equipment; part 2: DC”, but all of these standards are based on IEC/EN/UL60950 with regards to safety. Flex DC/DC converters and DC/DC regulators are UL60950 recognized and certified in accordance with EN60950. The flammability rating for all construction parts of the products meets requirements for V-0 class material according to IEC 60695-11-10. The products should be installed in the end-use equipment, in accordance with the requirements of the ultimate application. Normally the output of the DC/DC converter is considered as SELV (Safety Extra Low Voltage) and the input source must be isolated by minimum Double or Reinforced Insulation from the primary circuit (AC mains) in accordance with IEC/EN/UL60950. Isolated DC/DC converters It is recommended that a slow blow fuse with a rating twice the maximum input current per selected product be used at the input of each DC/DC converter. If an input filter is used in the circuit the fuse should be placed in front of the input filter. In the rare event of a component problem in the input filter or in the DC/DC converter that imposes a short circuit on the input source, this fuse will provide the following functions: • • Isolate the faulty DC/DC converter from the input power source so as not to affect the operation of other parts of the system. Protect the distribution wiring from excessive current and power loss thus preventing hazardous overheating. The galvanic isolation is verified in an electric strength test. The test voltage (Viso) between input and output is 1500 Vdc or 2250 Vdc for 60 seconds (refer to product specification). Leakage current is less than 1 μA at nominal input voltage. 24 V DC systems The input voltage to the DC/DC converter is SELV (Safety Extra Low Voltage) and the output remains SELV under normal and abnormal operating conditions. 48 and 60 V DC systems If the input voltage to Flex DC/DC converter is 75 Vdc or less, then the output remains SELV (Safety Extra Low Voltage) under normal and abnormal operating conditions. Single fault testing in the input power supply circuit should be performed with the DC/DC converter connected to demonstrate that the input voltage does not exceed 75 Vdc. If the input power source circuit is a DC power system, the source may be treated as a TNV2 circuit and testing has demonstrated compliance with SELV limits and isolation requirements equivalent to Basic Insulation in accordance with IEC/EN/UL60950. Non-isolated DC/DC regulators The input voltage to the DC/DC regulator is SELV (Safety Extra Low Voltage) and the output remains SELV under normal and abnormal operating conditions. Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 1 (25) No. Approved PMM 4000 series PoL Regulators SEC/D LINDAseries 4 2/1301-BMR 651Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Checked Date Rev 2006-3-13 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April PA1 © Flex Ericsson AB Power Modules AB Absolute Maximum Ratings Characteristics min typ max Unit Tamb Operating Temperature (see Thermal Consideration section) –40 85 °C TS Storage temperature –40 125 °C VI Input voltage Vinh Inhibit On/Off pin voltage (see Operating Information section) 2.95 3.3 4.5 (1) 4.5 5.0 5.5 (2) V Positive logic option 2.5 Open V Negative logic option N/A N/A V Stress in excess of Absolute Maximum Ratings may cause permanent damage. Absolute Maximum Ratings, sometimes referred to as no destruction limits, are normally tested with one parameter at a time exceeding the limits of Output data or Electrical Characteristics. If exposed to stress above these limits, function and performance may degrade in an unspecified manner. Note 1: For input voltage between 2.95-4.5 V, the output adjust range is limited to 0.8-1.65 V. Note 2: For input voltage between 4.5-5.5 V, the output adjust range is limited to 0.8-2.5 V. Fundamental Circuit Diagram +VSEN 3 VIN 2 1 2 VOUT 1 -VSEN 3 1 2 Differential GND Auto Track PWM Controller TRK ADJ Error Amplifier Ref INH RC Block GND GND GND MARDN UVLO UVLO Prog Block GND MARUP Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 2 (25) No. SEC/D KEVIN YAN Approved PMM 4000 series PoL Regulators SEC/D LINDAseries Checked 5 2/1301-BMR 651Technical 4 Uen Specification Specifi cation Date Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W © Flex Ericsson AB Power Modules AB 1.0 V/60 A Electrical Specification PMM 4218T Tref = -40 to +85ºC, VI = 2.95 to 5.5 V, Radj = 36.5 kΩ, unless otherwise specified under Conditions. Typical values given at: Tref = +25°C, VI = 3.3/5.0 V, max IO , unless otherwise specified under Conditions. Additional Cin= 1000µF and Cout= 660µF. See Operating Information section for selection of capacitor types. Connect the sense pin, where available, to the output pin. Characteristics VI UVLO Conditions Input voltage range Undervoltage lockout CI Internal input capacitance PO Output power Efficiency VI = 5.0 V Pd 2.95 Pin 8 open On-threshold 2.6 Hysterisis 0.6 Power Dissipation 89.5 max IO 84.9 50 % of max IO 86.0 max IO 83.4 VI = 3.3 V, max IO 10.7 VI = 5.0 V, max IO 11.9 IO = 0, VI = 3.3 V 840 IO = 0, VI = 5.0 V 930 VI = 3.3 V (turned off with INHIBIT) 198 VI = 5.0 V (turned off with INHIBIT) 300 VI = 3.3 V, max IO 21.6 VI = 5.0 V, max IO 14.5 Pinh Input standby power IS Static Input current fs Switching frequency VOi Output voltage initial setting and Tref = +25°C, VI = 5.0 V, max IO accuracy Vtr ttr tr ts Idling voltage Unit 5.5 V V 0-100 % of max IO 10-100 % of max IO µF 60 50 % of max IO Input idling power Output voltage tolerance band max 180 Pli VO typ 0 VI = 3.3 V η min W % W mW mW A 675 825 975 kHz 0.980 1.000 1.020 V 1.030 V 0.970 IO = 0, VI = 3.3 V 1.005 IO = 0, VI = 5.0 V 1.005 V Line regulation max IO ±5 mV Load regulation VI = 3.3/5.0 V, 0-100 % of max IO ±5 mV Load transient voltage deviation Load transient recovery time VI = 3.3 V, Load step 50-100-50 % of max IO, di/dt = 1 A/µs, see Note 1 VI = 5.0 V, Load step 50-100-50 % of max IO, di/dt = 1 A/µs, see Note 1 VI = 3.3 V, Load step 50-100-50 % of max IO, di/dt = 1 A/µs, see Note 1 VI = 5.0 V, Load step 50-100-50 % of max IO, di/dt = 1 A/µs, see Note 1 ±80 mV ±50 160 µS 150 Ramp-up time VI = 3.3 V, max IO 3.3 (from 10. 90 % of VOi) VI = 5.0 V, max IO 3.4 Start-up time VI = 3.3 V, max IO VI = 5.0 V, max IO 9.0 8.8 (from VI connection to 90 % of VOi) ms ms Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved PMM 4000 series PoL Regulators SEC/D LINDAseries Checked tf Ramp-down time (from 90. 10 % of VOi) Conditions VI = 3.3 V VI = 5.0 V INHIBIT start-up time Tinh INHIBIT shutdown fall time VI = 3.3 V (From INHIBIT off to 10 % of VO) VI = 5.0 V 6 2/1301-BMR 651Technical 4 Uen Specification Specifi cation Date Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W Characteristics 3 (25) No. © Flex Ericsson AB Power Modules AB min typ max Unit Max IO 180 µS IO = 0.1 A 24.6 ms Max IO 150 µS IO = 0.1 A 21.2 ms VI = 3.3 V, Max IO 6.7 VI = 5.0 V, Max IO 6.7 ms Max IO 30 µS IO = 0.1 A 6.5 ms Max IO 30 µS IO = 0.1 A 6.6 ms IO Output current Ilim Current limit threshold Tref < max Tref, 90 A Output ripple & noise See ripple & noise section, max IO, VOi 15 mVp-p VOac 0 Note 1: Output filter according to Ripple & Noise section 60 A Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 4 (25) No. Approved PMM 4000 series PoL Regulators SEC/D LINDAseries 7 2/1301-BMR 651Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Checked Date Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W © Flex Ericsson AB Power Modules AB 1.0 V/60 A Typical Characteristics (VI = 2.95-4.5 V) Efficiency PMM 4218T Power Dissipation [%] [W] 100 15 95 12 90 2.95 V 85 3.3 V 80 4.5 V 75 2.95 V 9 3.3 V 6 4.5 V 3 0 70 0 10 20 30 40 50 0 60 [A] 10 20 30 40 50 60 [A] Dissipated power vs. load current and input voltage at Tref = +25°C Efficiency vs. load current and input voltage at Tref = +25°C Output Current Derating Output Characteristics [A] 70 [V] 1.10 60 2.0 m/s 1.05 50 2.95 V 40 1.0 m/s 30 1.00 3.3 V 4.5 V 20 0.95 Nat. Conv. 10 0.90 0 0 20 40 60 80 [°C] Available load current vs. ambient air temperature and airflow at VI = 3.3 V, VOUT = 2.0 V. See Thermal Consideration section. 0 10 20 30 40 50 Output voltage vs. load current at Tref = +25°C 60 [A] Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 5 (25) No. Approved PMM 4000 series PoL Regulators SEC/D LINDAseries 8 2/1301-BMR 651Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Checked Date Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W © Flex Ericsson AB Power Modules AB 1.0 V/60 A Typical Characteristics (VI = 4.5-5.5 V) Efficiency PMM 4218T Power Dissipation [%] [W] 100 15 95 12 90 4.5 V 85 5.0 V 80 4.5 V 9 5.0 V 6 5.5 V 5.5 V 3 75 70 0 0 10 20 30 40 50 60 [A] 0 10 20 30 40 50 60 [A] Dissipated power vs. load current and input voltage at Tref = +25°C Efficiency vs. load current and input voltage at Tref = +25°C Output Current Derating Output Characteristics [A] 70 [V] 1.10 60 2.0 m/s 1.05 50 4.5 V 40 1.0 m/s 30 1.00 5.0 V 5.5 V 20 0.95 Nat. Conv. 10 0.90 0 0 20 40 60 80 [°C] Available load current vs. ambient air temperature and airflow at VI = 3.3 V, VOUT = 2.0 V. See Thermal Consideration section. 0 10 20 30 40 50 Output voltage vs. load current at Tref = +25°C 60 [A] Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved 6 (25) No. PMM 4000 series PoL Regulators SEC/D LINDAseries Checked 2/1301-BMR 651Technical 4 Uen Specification Specifi cation Date 2006-3-13 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April PA1 © Flex Ericsson AB Power Modules AB 1.0 V/60 A Typical Characteristics (VI = 2.95-4.5 V) Start-up Start-up enabled by connecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 3.3 V. Output Ripple & Noise Output voltage ripple (5 mV/div.) at: Tref = +25°C, IO = 60 A electrical load, VI = 3.3 V. Time scale: 5 µs/div. PMM 4218T Shut-down Top trace: output voltage (1.0 V/div.). Bottom trace: input voltage (2.0 V/div.). Time scale: 10 ms/div. Shut-down enabled by disconnecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 3.3 V. Top trace: output voltage (1.0 V/div.). Time scale: 1.0 ms/div. Output Load Transient Response Output capacitor: 660 µF electrolysis type. See the filter in the Output ripple and noise section (EMC Specification). 9 Output voltage response to load current stepchange (30-60-30 A) at: Tref =+25°C, VI = 3.3 V. Top trace: output voltage (100 mV/div.). Bottom trace: load current (20 A/div.). Time scale: 0.1 ms/div. Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved 7 (25) No. PMM 4000 series PoL Regulators SEC/D LINDAseries Checked 2/1301-BMR 651Technical 4 Uen Specification Specifi cation Date 2006-3-13 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April PA1 © Flex Ericsson AB Power Modules AB 1.0 V/60 A Typical Characteristics (VI = 4.5-5.5 V) Start-up Start-up enabled by connecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 5.0 V. PMM 4218T Shut-down Top trace: output voltage (1.0 V/div.). Bottom trace: input voltage (2.0 V/div.). Time scale: 10 ms/div. Output Ripple & Noise Output voltage ripple (5 mV/div.) at: Tref = +25°C, IO = 60 A electrical load, VI = 5 V. Time scale: 5 µs/div. 10 Shut-down enabled by disconnecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 5.0 V. Top trace: output voltage (1.0 V/div.). Time scale: 0.5 ms/div. Output Load Transient Response Output capacitor: 660 µF electrolysis type. See the filter in the Output ripple and noise section (EMC Specification). Output voltage response to load current step- Top trace: output voltage (100 mV/div.). change (30-60-30 A) at: Bottom trace: load current (20 A/div.). Tref =+25°C, VI = 5.0 V. Time scale: 0.2 ms/div. Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 8 (25) No. SEC/D KEVIN YAN Approved PMM 4000 series PoL Regulators SEC/D LINDAseries Checked 2/1301-BMR 651Technical 4 Uen Specification Specifi cation Date Rev Reference 11 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W © Flex Ericsson AB Power Modules AB 1.2 V/60 A Electrical Specification PMM 4218T Tref = -40 to +85ºC, VI = 2.95 to 5.5 V, Radj = 17.4 kΩ, unless otherwise specified under Conditions. Typical values given at: Tref = +25°C, VI = 3.3/5.0 V, max IO , unless otherwise specified under Conditions. Additional Cin= 1000µF and Cout= 660µF. See Operating Information section for selection of capacitor types. Connect the sense pin, where available, to the output pin. Characteristics VI UVLO Conditions Input voltage range Undervoltage lockout CI Internal input capacitance PO Output power Efficiency VI = 5.0 V Pd 2.95 Pin 8 open On-threshold 2.6 Hysterisis 0.6 Power Dissipation 90.5 max IO 87.1 50 % of max IO 86.8 max IO 85.6 VI = 3.3 V, max IO 10.8 VI = 5.0 V, max IO 12.0 IO = 0, VI = 3.3 V 880 IO = 0, VI = 5.0 V 1000 VI = 3.3 V (turned off with INHIBIT) 198 VI = 5.0 V (turned off with INHIBIT) 300 VI = 3.3 V, max IO 25.2 VI = 5.0 V, max IO 16.9 Pinh Input standby power IS Static Input current fs Switching frequency VOi Output voltage initial setting and Tref = +25°C, VI = 5.0 V, max IO accuracy Vtr ttr tr ts Idling voltage Unit 5.5 V V 0-100 % of max IO 10-100 % of max IO µF 72 50 % of max IO Input idling power Output voltage tolerance band max 180 Pli VO typ 0 VI = 3.3 V η min W % W mW mW A 675 825 975 kHz 1.176 1.200 1.224 V 1.236 V 1.164 IO = 0, VI = 3.3 V 1.202 IO = 0, VI = 5.0 V 1.202 V Line regulation max IO ±5 mV Load regulation VI = 3.3/5.0 V, 0-100 % of max IO ±5 mV Load transient voltage deviation Load transient recovery time VI = 3.3 V, Load step 50-100-50 % of max IO, di/dt = 1 A/µs, see Note 1 VI = 5.0 V, Load step 50-100-50 % of max IO, di/dt = 1 A/µs, see Note 1 VI = 3.3 V, Load step 50-100-50 % of max IO, di/dt = 1 A/µs, see Note 1 VI = 5.0 V, Load step 50-100-50 % of max IO, di/dt = 1 A/µs, see Note 1 ±80 mV ±50 160 µS 150 Ramp-up time VI = 3.3 V, max IO 3.4 (from 10. 90 % of VOi) VI = 5.0 V, max IO 3.4 Start-up time VI = 3.3 V, max IO VI = 5.0 V, max IO 9.1 8.9 (from VI connection to 90 % of VOi) ms ms Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved PMM 4000 series PoL Regulators SEC/D LINDAseries Checked 2/1301-BMR 651Technical 4 Uen Specification Specifi cation Date Rev tf Ramp-down time (from 90. 10 % of VOi) Conditions VI = 3.3 V VI = 5.0 V INHIBIT start-up time Tinh INHIBIT shutdown fall time VI = 3.3 V (From INHIBIT off to 10 % of VO) VI = 5.0 V Reference 12 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W Characteristics 9 (25) No. © Flex Ericsson AB Power Modules AB min typ max Unit Max IO 180 µS IO = 0.1 A 24.6 ms Max IO 200 µS IO = 0.1 A 24.4 ms VI = 3.3 V, Max IO 6.7 VI = 5.0 V, Max IO 6.7 ms Max IO 40 µS IO = 0.1 A 7.8 ms Max IO 40 µS IO = 0.1 A 7.8 ms IO Output current Ilim Current limit threshold Tref < max Tref, 90 A Output ripple & noise See ripple & noise section, max IO, VOi 15 mVp-p VOac 0 Note 1: Output filter according to Ripple & Noise section 60 A Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 10 (25) No. Approved PMM 4000 series PoL Regulators SEC/D LINDAseries 13 2/1301-BMR 651Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Checked Date Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W © Flex Ericsson AB Power Modules AB 1.2 V/60 A Typical Characteristics (VI = 2.95-4.5 V) Efficiency PMM 4218T Power Dissipation [%] [W] 100 15 95 12 90 2.95 V 85 3.3 V 80 2.95 V 9 3.3 V 6 4.5 V 4.5 V 3 75 70 0 0 10 20 30 40 50 60 [A] 0 10 20 30 40 50 60 [A] Dissipated power vs. load current and input voltage at Tref = +25°C Efficiency vs. load current and input voltage at Tref = +25°C Output Current Derating Output Characteristics [A] 70 [V] 1.30 60 2.0 m/s 1.25 50 2.95 V 40 1.0 m/s 30 1.20 3.3 V 4.5 V 20 1.15 Nat. Conv. 10 1.10 0 0 20 40 60 80 [°C] Available load current vs. ambient air temperature and airflow at VI = 3.3 V, VOUT = 2.0 V. See Thermal Consideration section. 0 10 20 30 40 50 Output voltage vs. load current at Tref = +25°C 60 [A] Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 11 (25) No. Approved PMM 4000 series PoL Regulators SEC/D LINDAseries 14 2/1301-BMR 651Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Checked Date Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W © Flex Ericsson AB Power Modules AB 1.2 V/60 A Typical Characteristics (VI = 4.5-5.5 V) Efficiency PMM 4218T Power Dissipation [%] [W] 100 15 95 12 90 4.5 V 85 5.0 V 80 4.5 V 9 5.0 V 6 5.5 V 5.5 V 3 75 70 0 0 10 20 30 40 50 60 [A] 0 10 20 30 40 50 60 [A] Dissipated power vs. load current and input voltage at Tref = +25°C Efficiency vs. load current and input voltage at Tref = +25°C Output Current Derating Output Characteristics [A] 70 [V] 1.30 60 2.0 m/s 1.25 50 4.5 V 40 1.0 m/s 30 1.20 5.0 V 5.5 V 20 1.15 Nat. Conv. 10 1.10 0 0 20 40 60 80 [°C] Available load current vs. ambient air temperature and airflow at VI = 3.3 V, VOUT = 2.0 V. See Thermal Consideration section. 0 10 20 30 40 50 Output voltage vs. load current at Tref = +25°C 60 [A] Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved 12 (25) No. PMM 4000 series PoL Regulators SEC/D LINDAseries Checked 2/1301-BMR 651Technical 4 Uen Specification Specifi cation Date 2006-3-13 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April PA1 © Flex Ericsson AB Power Modules AB 1.2 V/60 A Typical Characteristics (VI = 2.95-4.5 V) Start-up Start-up enabled by connecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 3.3 V. PMM 4218T Shut-down Top trace: output voltage (1.0 V/div.). Bottom trace: input voltage (2.0 V/div.). Time scale: 10 ms/div. Output Ripple & Noise Output voltage ripple (5 mV/div.) at: Tref = +25°C, IO = 60 A electrical load, VI =  V. Time scale: 5 µs/div. 15 Shut-down enabled by disconnecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 3.3 V. Top trace: output voltage (1.0 V/div.). Time scale: 1.0 ms/div. Output Load Transient Response Output capacitor: 660 µF electrolysis type. See the filter in the Output ripple and noise section (EMC Specification). Output voltage response to load current stepchange (30-60-30 A) at: Tref =+25°C, VI = 3.3 V. Top trace: output voltage (100 mV/div.). Bottom trace: load current (20 A/div.). Time scale: 0.1 ms/div. Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved 13 (25) No. PMM 4000 series PoL Regulators SEC/D LINDAseries Checked 2/1301-BMR 651Technical 4 Uen Specification Specifi cation Date 2006-3-13 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April PA1 © Flex Ericsson AB Power Modules AB 1.2 V/60 A Typical Characteristics (VI = 4.5-5.5 V) Start-up Start-up enabled by connecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 5.0 V. PMM 4218T Shut-down Top trace: output voltage (1.0 V/div.). Bottom trace: input voltage (2.0 V/div.). Time scale: 10 ms/div. Output Ripple & Noise Output voltage ripple (5 mV/div.) at: Tref = +25°C, IO = 60 A electrical load, VI = 5 V. Time scale: 5 µs/div. 16 Shut-down enabled by disconnecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 5.0 V. Top trace: output voltage (1.0 V/div.). Time scale: 0.5 ms/div. Output Load Transient Response Output capacitor: 660 µF electrolysis type. See the filter in the Output ripple and noise section (EMC Specification). Output voltage response to load current step- Top trace: output voltage (100 mV/div.). change (30-60-30 A) at: Bottom trace: load current (20 A/div.). Tref =+25°C, VI = 5.0 V. Time scale: 0.2 ms/div. Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 14 (25) No. SEC/D KEVIN YAN Approved PMM 4000 series PoL Regulators SEC/D LINDAseries Checked 2/1301-BMR 651Technical 4 Uen Specification Specifi cation Date Rev Reference 17 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W © Flex Ericsson AB Power Modules AB 1.5 V/60 A Electrical Specification PMM 4218T Tref = -40 to +85ºC, VI = 2.95 to 5.5 V, Radj = 8.87 kΩ, unless otherwise specified under Conditions. Typical values given at: Tref = +25°C, VI = 3.3/5.0 V, max IO , unless otherwise specified under Conditions. Additional Cin= 1000µF and Cout= 660µF. See Operating Information section for selection of capacitor types. Connect the sense pin, where available, to the output pin. Characteristics VI UVLO Conditions Input voltage range Undervoltage lockout CI Internal input capacitance PO Output power Efficiency VI = 5.0 V Pd 2.95 Pin 8 open On-threshold 2.6 Hysterisis 0.6 Power Dissipation 91.6 max IO 89.4 50 % of max IO 90.4 max IO 88.0 VI = 3.3 V, max IO 11.0 VI = 5.0 V, max IO 12.2 IO = 0, VI = 3.3 V 940 IO = 0, VI = 5.0 V 1200 VI = 3.3 V (turned off with INHIBIT) 198 VI = 5.0 V (turned off with INHIBIT) 300 VI = 3.3 V, max IO 30.8 VI = 5.0 V, max IO 20.6 Pinh Input standby power IS Static Input current fs Switching frequency VOi Output voltage initial setting and Tref = +25°C, VI = 5.0 V, max IO accuracy Vtr ttr tr ts Idling voltage Unit 5.5 V V 0-100 % of max IO 10-100 % of max IO µF 90 50 % of max IO Input idling power Output voltage tolerance band max 180 Pli VO typ 0 VI = 3.3 V η min W % W mW mW A 675 825 975 kHz 1.470 1.500 1.530 V 1.545 V 1.455 IO = 0, VI = 3.3 V 1.505 IO = 0, VI = 5.0 V 1.505 V Line regulation max IO ±5 mV Load regulation VI = 3.3/5.0 V, 0-100 % of max IO ±5 mV Load transient voltage deviation Load transient recovery time VI = 3.3 V, Load step 50-100-50 % of max IO, di/dt = 1 A/µs, see Note 1 VI = 5.0 V, Load step 50-100-50 % of max IO, di/dt = 1 A/µs, see Note 1 VI = 3.3 V, Load step 50-100-50 % of max IO, di/dt = 1 A/µs, see Note 1 VI = 5.0 V, Load step 50-100-50 % of max IO, di/dt = 1 A/µs, see Note 1 ±80 mV ±60 160 µS 150 Ramp-up time VI = 3.3 V, max IO 3.3 (from 10. 90 % of VOi) VI = 5.0 V, max IO 3.3 Start-up time VI = 3.3 V, max IO VI = 5.0 V, max IO 9.1 8.8 (from VI connection to 90 % of VOi) ms ms Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved PMM 4000 series PoL Regulators SEC/D LINDAseries Checked 2/1301-BMR 651Technical 4 Uen Specification Specifi cation Date Rev tf Ramp-down time (from 90. 10 % of VOi) Conditions VI = 3.3 V VI = 5.0 V INHIBIT start-up time Tinh INHIBIT shutdown fall time VI = 3.3 V (From INHIBIT off to 10 % of VO) VI = 5.0 V Reference 18 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W Characteristics 15 (25) No. © Flex Ericsson AB Power Modules AB min typ max Unit Max IO 190 µS IO = 0.1 A 29.6 ms Max IO 220 µS IO = 0.1 A 29.3 ms VI = 3.3 V, Max IO 6.7 VI = 5.0 V, Max IO 6.8 Max IO 180 µS IO = 0.1 A 9.7 ms Max IO 180 µS IO = 0.1 A ms 9.7 ms IO Output current Ilim Current limit threshold Tref < max Tref, 90 A Output ripple & noise See ripple & noise section, max IO, VOi 15 mVp-p VOac 0 Note 1: Output filter according to Ripple & Noise section 60 A Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 16 (25) No. Approved PMM 4000 series PoL Regulators SEC/D LINDAseries 19 2/1301-BMR 651Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Checked Date Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W © Flex Ericsson AB Power Modules AB 1.5 V/60 A Typical Characteristics (VI = 2.95-4.5 V) Efficiency PMM 4218T Power Dissipation [%] [W] 100 15 95 12 90 2.95 V 85 3.3 V 80 2.95 V 9 3.3 V 6 4.5 V 4.5 V 3 75 70 0 0 10 20 30 40 50 60 [A] 0 10 20 30 40 50 60 [A] Dissipated power vs. load current and input voltage at Tref = +25°C Efficiency vs. load current and input voltage at Tref = +25°C Output Current Derating Output Characteristics [A] 70 [V] 1.60 60 2.0 m/s 1.55 50 2.95 V 40 1.0 m/s 30 3.3 V 1.50 4.5 V 20 Nat. Conv. 10 0 1.45 1.40 0 20 40 60 80 [°C] Available load current vs. ambient air temperature and airflow at VI = 3.3 V, VOUT = 2.0 V. See Thermal Consideration section. 0 10 20 30 40 50 Output voltage vs. load current at Tref = +25°C 60 [A] Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 17 (25) No. Approved PMM 4000 series PoL Regulators SEC/D LINDAseries 20 2/1301-BMR 651Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Checked Date Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W © Flex Ericsson AB Power Modules AB 1.5 V/60 A Typical Characteristics (VI = 4.5-5.5 V) Efficiency PMM 4218T Power Dissipation [%] [W] 100 15 95 12 90 4.5 V 85 5.0 V 4.5 V 9 5.0 V 6 80 5.5 V 5.5 V 75 3 70 0 10 20 30 40 50 0 60 [A] 0 10 20 30 40 50 60 [A] Dissipated power vs. load current and input voltage at Tref = +25°C Efficiency vs. load current and input voltage at Tref = +25°C Output Current Derating Output Characteristics [V] [A] 70 1.60 60 2.0 m/s 1.55 50 4.5 V 40 1.0 m/s 30 1.50 5.0 V 5.5 V 20 1.45 Nat. Conv. 10 1.40 0 0 20 40 60 80 [°C] Available load current vs. ambient air temperature and airflow at VI = 3.3 V, VOUT = 2.0 V. See Thermal Consideration section. 0 10 20 30 40 50 Output voltage vs. load current at Tref = +25°C 60 [A] Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved 18 (25) No. PMM 4000 series PoL Regulators SEC/D LINDAseries Checked 2/1301-BMR 651Technical 4 Uen Specification Specifi cation Date 2006-3-13 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April PA1 © Flex Ericsson AB Power Modules AB 1.5 V/60 A Typical Characteristics (VI = 2.95-4.5 V) Start-up Start-up enabled by connecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 3.3 V. PMM 4218T Shut-down Top trace: output voltage (1.0 V/div.). Bottom trace: input voltage (2.0 V/div.). Time scale: 10 ms/div. Output Ripple & Noise Output voltage ripple (5 mV/div.) at: Tref = +25°C, IO = 60 A electrical load, VI =  V. Time scale: 5 µs/div. 21 Shut-down enabled by disconnecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 3.3 V. Top trace: output voltage (1.0 V/div.). Time scale: 1.0 ms/div. Output Load Transient Response Output capacitor: 660 µF electrolysis type. See the filter in the Output ripple and noise section (EMC Specification). Output voltage response to load current stepchange (30-60-30 A) at: Tref =+25°C, VI = 3.3 V. Top trace: output voltage (100 mV/div.). Bottom trace: load current (20 A/div.). Time scale: 0.1 ms/div. Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved 19 (25) No. PMM 4000 series PoL Regulators SEC/D LINDAseries Checked 2/1301-BMR 651Technical 4 Uen Specification Specifi cation Date 2006-3-13 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April PA1 © Flex Ericsson AB Power Modules AB 1.5 V/60 A Typical Characteristics (VI = 4.5-5.5 V) Start-up Start-up enabled by connecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 5.0 V. PMM 4218T Shut-down Top trace: output voltage (1.0 V/div.). Bottom trace: input voltage (2.0 V/div.). Time scale: 10 ms/div. Output Ripple & Noise Output voltage ripple (5 mV/div.) at: Tref = +25°C, IO = 60 A electrical load, VI = 5 V. Time scale: 5 µs/div. 22 Shut-down enabled by disconnecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 5.0 V. Top trace: output voltage (1.0 V/div.). Time scale: 0.5 ms/div. Output Load Transient Response Output capacitor: 660 µF electrolysis type. See the filter in the Output ripple and noise section (EMC Specification). Output voltage response to load current stepchange (30-60-30 A) at: Tref =+25°C, VI = 5.0 V. Top trace: output voltage (100 mV/div.). Bottom trace: load current (20 A/div.). Time scale: 0.2 ms/div. Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 20 (25) No. 2/1301-BMR 651Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Approved PMM 4000 series PoL Regulators SEC/D LINDAseries Checked Date Rev Reference 23 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W © Flex Ericsson AB Power Modules AB 1.8 V/60 A Electrical Specification PMM 4218T Tref = -40 to +85ºC, VI = 4.5 to 5.5 V, Radj = 5.49 kΩ, unless otherwise specified under Conditions. Typical values given at: Tref = +25°C, VI= 5.0 V, max IO , unless otherwise specified under Conditions. Additional Cin= 1000µF and Cout= 660µF. See Operating Information section for selection of capacitor types. Connect the sense pin, where available, to the output pin. Characteristics VI UVLO Conditions min Input voltage range Undervoltage lockout CI Internal input capacitance PO Output power typ 4.5 Pin 8 open On-threshold 2.6 Hysterisis 0.6 max Unit 5.5 V V 180 0 µF 108 50 % of max IO 91.8 max IO 89.6 W η Efficiency Pd Power Dissipation max IO 12.5 W Pli Input idling power IO= 0, VI = 5.0 V 1300 mW Pinh Input standby power VI = 5.0 V (turned off with INHIBIT) 300 mW IS Static Input current VI = 5.0 V, max IO fs Switching frequency 0-100 % of max IO VOi VO Vtr ttr tr ts tf % 24.2 A 675 825 975 kHz Output voltage initial setting and Tref = +25°C, VI = 5.0 V, max IO accuracy 1.764 1.800 1.836 V Output voltage tolerance band 1.746 1.854 V 10-100 % of max IO Idling voltage IO = 0 1.804 V Line regulation max IO ±5 mV Load regulation VI = 5.0 V, 0-100 % of max IO ±5 mV Load transient voltage deviation VI = 5.0 V, Load step 50-100-50 % of max IO, di/dt = 1 A/μs, see Note 1 ±60 mV 150 µs 3.4 ms 8.8 ms Load transient recovery time Ramp-up time (from 10. 90 % of VOi) Start-up time max IO (from VI connection to 90% of VOi) Ramp-down time Max IO 260 µs (from 90. 10 % of VOi) IO = 0.1 A 31.2 ms INHIBIT start-up time Max IO 6.7 ms tInh INHIBIT shutdown fall time (From INHIBIT off to 10% of VO) Max IO 200 µs IO Output current Ilim Current limit threshold Tref < max Tref, 90 A VOac Output ripple & noise See ripple & noise section, max IO, VOi 15 mVp-p IO = 0.1 A 11.5 0 Note 1: Output filter according to Ripple & Noise section ms 60 A Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 21 (25) No. Approved PMM 4000 series PoL Regulators SEC/D LINDAseries 24 2/1301-BMR 651Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Checked Date Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W © Flex Ericsson AB Power Modules AB 1.8 V/60 A Typical Characteristics PMM 4218T Efficiency Power Dissipation [%] [W] 100 15 95 12 90 4.5 V 85 5.0 V 80 5.5 V 75 4.5 V 9 5.0 V 6 5.5 V 3 0 70 0 10 20 30 40 50 0 60 [A] 10 20 30 40 50 60 [A] Dissipated power vs. load current and input voltage at Tref = +25°C Efficiency vs. load current and input voltage at Tref = +25°C Output Current Derating Output Characteristics [V] [A] 70 1.90 60 2.0 m/s 1.85 50 4.5 V 40 1.0 m/s 30 1.80 5.0 V 5.5 V 20 1.75 Nat. Conv. 10 1.70 0 0 20 40 60 80 [°C] Available load current vs. ambient air temperature and airflow at VI = 3.3 V, VOUT = 2.0 V. See Thermal Consideration section. 0 10 20 30 40 50 Output voltage vs. load current at Tref = +25°C 60 [A] Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 22 (25) No. SEC/D KEVIN YAN Approved PMM 4000 series PoL Regulators SEC/D LINDAseries Checked 2/1301-BMR 651Technical 4 Uen Specification Specifi cation Date 2006-3-13 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April PA1 © Flex Ericsson AB Power Modules AB 1.8 V/60 A Typical Characteristics Start-up Start-up enabled by connecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 5.0 V. PMM 4218T Shut-down Top trace: output voltage (1.0 V/div.). Bottom trace: input voltage (2 V/div.). Time scale: 10 ms/div. Output Ripple & Noise Output voltage ripple (5 mV/div.) at: Tref = +25°C, IO = 60 A electrical load, VI = 5 V. Time scale: 5 µs/div. 25 Shut-down enabled by disconnecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 5.0 V. Top trace: output voltage (1.0 V/div.). Time scale: 0.5 ms/div. Output Load Transient Response Output capacitor: 660 µF electrolysis type. See the filter in the Output ripple and noise section (EMC Specification). Output voltage response to load current stepchange (30-60-30 A) at: Tref =+25°C, VI = 5.0 V. Top trace: output voltage (100 mV/div.). Bottom trace: load current (20 A/div.). Time scale: 0.2 ms/div. Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 23 (25) No. 2/1301-BMR 651Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Approved PMM 4000 series PoL Regulators SEC/D LINDAseries Checked Date Rev Reference 26 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W © Flex Ericsson AB Power Modules AB 2.5 V/60 A Electrical Specification PMM 4218T Tref = -40 to +85ºC, VI = 4.5 to 5.5 V, Radj = 2.21 kΩ, unless otherwise specified under Conditions. Typical values given at: Tref = +25°C, VI= 5.0 V, max IO , unless otherwise specified under Conditions. Additional Cin= 1000µF and Cout= 660µF. See Operating Information section for selection of capacitor types. Connect the sense pin, where available, to the output pin. Characteristics VI UVLO Conditions min Input voltage range Undervoltage lockout CI Internal input capacitance PO Output power typ 4.5 Pin 8 open On-threshold 2.6 Hysterisis 0.6 max Unit 5.5 V V 180 0 µF 150 50 % of max IO 94.0 max IO 91.6 W η Efficiency Pd Power Dissipation max IO 13.5 W Pli Input idling power IO= 0, VI = 5.0 V 1500 mW Pinh Input standby power VI = 5.0 V (turned off with INHIBIT) 300 mW IS Static Input current VI = 5.0 V, max IO fs Switching frequency 0-100 % of max IO VOi VO Vtr ttr tr ts tf % 32.7 A 675 825 975 kHz Output voltage initial setting and Tref = +25°C, VI = 5.0 V, max IO accuracy 2.450 2.500 2.550 V Output voltage tolerance band 2.425 2.575 V 10-100 % of max IO Idling voltage IO = 0 2.506 V Line regulation max IO ±5 mV Load regulation VI = 5.0 V, 0-100 % of max IO ±5 mV Load transient voltage deviation VI = 5.0 V, Load step 50-100-50 % of max IO, di/dt = 1 A/μs, see Note 1 ±80 mV 180 µs 3.4 ms 8.9 ms Load transient recovery time Ramp-up time (from 10. 90 % of VOi) Start-up time max IO (from VI connection to 90% of VOi) Ramp-down time Max IO 280 µs (from 90. 10 % of VOi) IO = 0.1 A 34.6 ms INHIBIT start-up time Max IO 6.8 ms tInh INHIBIT shutdown fall time (From INHIBIT off to 10% of VO) Max IO 220 µs IO Output current Ilim Current limit threshold Tref < max Tref, 90 A VOac Output ripple & noise See ripple & noise section, max IO, VOi 15 mVp-p IO = 0.1 A 15.3 0 Note 1: Output filter according to Ripple & Noise section ms 60 A Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 24 (25) No. 2/1301-BMR 651Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Approved PMM 4000 series PoL Regulators SEC/D LINDAseries Checked Date Rev Reference 27 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-13 PA1 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W © Flex Ericsson AB Power Modules AB 2.5 V/60 A Typical Characteristics PMM 4218T Efficiency Power Dissipation [%] [W] 100 15 95 12 90 4.5 V 85 5.0 V 80 4.5 V 9 5.0 V 6 5.5 V 5.5 V 3 75 70 0 0 10 20 30 40 50 0 60 [A] 10 20 30 40 50 60 [A] Dissipated power vs. load current and input voltage at Tref = +25°C Efficiency vs. load current and input voltage at Tref = +25°C Output Current Derating Output Characteristics [V] [A] 70 2.60 60 2.0 m/s 2.55 50 4.5 V 40 1.0 m/s 30 2.50 5.0 V 5.5 V 20 2.45 Nat. Conv. 10 2.40 0 0 20 40 60 80 [°C] Available load current vs. ambient air temperature and airflow at VI = 3.3 V, VOUT = 2.0 V. See Thermal Consideration section. 0 10 20 30 40 50 Output voltage vs. load current at Tref = +25°C 60 [A] Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 25 (25) No. SEC/D KEVIN YAN Approved PMM 4000 series PoL Regulators SEC/D LINDAseries Checked 2/1301-BMR 651Technical 4 Uen Specification Specifi cation Date 2006-3-13 Input 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL regulator, Input 2.95-5.5 Output 60 60 A/150 A/150 W W Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April PA1 © Flex Ericsson AB Power Modules AB 2.5 V/60 A Typical Characteristics Start-up Start-up enabled by connecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 5.0 V. PMM 4218T Shut-down Top trace: output voltage (1.0 V/div.). Bottom trace: input voltage (2 V/div.). Time scale: 10 ms/div. Output Ripple & Noise Output voltage ripple (5 mV/div.) at: Tref = +25°C, IO = 60 A electrical load, VI = 5 V. Time scale: 5 µs/div. 28 Shut-down enabled by disconnecting VI at: Tref = +25°C, IO = 60 A resistive load, VI = 5.0 V. Top trace: output voltage (1.0 V/div.). Time scale: 0.5 ms/div. Output Load Transient Response Output capacitor: 660 µF electrolysis type. See the filter in the Output ripple and noise section (EMC Specification). Output voltage response to load current stepchange (30-60-30 A) at: Tref =+25°C, VI = 5.0 V. Top trace: output voltage (100 mV/div.). Bottom trace: load current (20 A/div.). Time scale: 0.2 ms/div. E Ericsson Internal PRODUCT SPEC. Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved series PMM 4000 series SEC/D Wei Zhang A PoL Regulators 1 (5) No. Checked 3/1301-BMR 651Technical 4 Uen Specification Specification Date 2006-3-16 Inputregulator, 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL Input 2.95-5.5 Output 60 60 A/150 A/150 W W EMC Specification Rev Reference 29 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April PA1 © Flex Ericsson AB Power Modules AB Output ripple and noise Conducted EMI measured according to test set-up. The fundamental switching frequency is 825 kHz for PMM 4218T @ VI = 3.3V or 5 V, max IO. Output ripple and noise measured according to figure below. See Design Note 022 for detailed information. Conducted EMI Input terminal value (typ) TBD Output ripple and noise test setup EMI without filter Operating information Extended information for POLA products is found in Application Note POLA (AN205). Input Voltage TBD The input voltage range 2.95 to 5.5 Vdc makes the product easy to use in intermediate bus applications when powered by a regulated 3.3 V or 5 V bus converter. The PMM product family is also available with 12 Vin. Turn on/off Input Voltage The POL regulators monitor the input voltage and will turn on and turn off at predetermined levels. The typical hysteresis between turn on and turn off input voltage is 0.6 V. Test set-up Layout recommendation The radiated EMI performance of the POL regulator will depend on the PCB layout and ground layer design. It is also important to consider the stand-off of the POL regulator. If a ground layer is used, it should be connected to the output of the POL regulator and the equipment ground or chassis. A ground layer will increase the stray capacitance in the PCB and improve the high frequency EMC performance. Inhibit Control (INH) The products are equipped with a Inhibit control function referenced to the primary negative input connection (- In), positive logic. The INHIBIT function allows the regulator to be turned on/off by an external device like a semiconductor or mechanical switch. The regulator will turn on when the input voltage is applied with the INHIBIT pin open. Turn off is achieved by connecting the INHIBIT pin to the - In. To ensure safe turn off, the voltage difference between INHIBIT pin and the - In pin shall be less than 0.5V. The regulator will restart automatically when this connection is opened. E Ericsson Internal PRODUCT SPEC. Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved series PMM 4000 series SEC/D Wei Zhang A PoL Regulators 2 (5) No. Checked 3/1301-BMR 651Technical 4 Uen Specification Specification Date 2006-3-16 Inputregulator, 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL Input 2.95-5.5 Output 60 60 A/150 A/150 W W External Capacitors Input capacitors: The recommended input capacitors are determined by the 940 μF minimum capacitance and 400 mArms minimum ripple current rating. For high performance applications, or wherever the transient capability of the input source is limited, 2200 μF of input capacitance is recommended. Output capacitors (optional): The recommended output capacitance of 660 μF will allow the module to meet its transient response specification as defined in the electrical specification. Rev Reference 30 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April PA1 © Flex Ericsson AB Power Modules AB Output Voltage Adjust (Vadj) The output voltage can be set by means of an external resistor, connected to the Vadj pin. Nominal output voltage 0.8 V is set by leaving the Vadj pin open. Adjustment can only be made to increase the output voltage setting. To increase the voltage a resistor should be connected between the Vadj pin and GND pin. The resistor value of the Output voltage adjust function is according to information given under the Output section for the respective product. When using one or more non-ceramic capacitors, the calculated equivalent ESR should be no lower than 4 mΩ (7mΩ using the manufacturer’s maximum ESR for a single capacitor). Input And Output Impedance The impedance of both the input source and the load will interact with the impedance of the POL regulator. It is important that the input source has low characteristic impedance. The regulators are designed for stable operation without external capacitors connected to the input or output. The performance in some applications can be enhanced by addition of external capacitance as described under External Decoupling Capacitors. If the input voltage source contains significant inductance, the addition of a 100 μF capacitor across the input of the POL regulator will ensure stable operation. The capacitor is not required when powering the POL regulator from an input source with an inductance below 10 μH. External Decoupling Capacitors When powering loads with significant dynamic current requirements, the voltage regulation at the point of load can be improved by addition of decoupling capacitors at the load. The most effective technique is to locate low ESR ceramic and electrolytic capacitors as close to the load as possible, using several parallel capacitors to lower the effective ESR. The ceramic capacitors will handle high-frequency dynamic load changes while the electrolytic capacitors are used to handle low frequency dynamic load changes. Ceramic capacitors will also reduce any high frequency noise at the load. It is equally important to use low resistance and low inductance PCB layouts and cabling. External decoupling capacitors will become part of the control loop of the POL regulator and may affect the stability margins. As a “rule of thumb”, 100 μF/A of output current can be added without any additional analysis. The ESR of the capacitors is a very important parameter. Power Modules guarantee stable operation with a verified ESR value of >10 mΩ across the output connections. For further information please contact your local Flex representative. UVLO Adjustment The UVLO feature of the PMM family module allows for limited adjustment of both the on threshold and hysterisis voltages. The adjustment is made via the UVLO Prog control pin. When the UVLO Prog pin is left open circuit, the on threshold and hysterisis voltages are internally set to their default values. The on threshold has a nominal voltage of 2.63 V, and the hysteris is 0.62 V. This ensures that the module produces a regulated output when the minimum input voltage is applied. The combination correlates to an off threshold of approximately 2.0 V. The adjustments are limited. The on threshold can only be adjusted higher, and the hysterisis voltage can only be reduced in magnitude. Parallel Operation Two POL regulators may be paralleled for redundancy if the total power is equal or less than PO max. It is not recommended to parallel the POL regulators without using external current sharing circuits. Remote Sense The POL regulators have remote sense that can be used to compensate for voltage drops between the output and the point of load. The sense traces should be located close to the PCB ground layer to reduce noise susceptibility. The remote sense circuitry will compensate for up to 0.3v voltage drop between output pins and the point of load. If the remote sense is not needed +Sense and —Sense should be left open. E Ericsson Internal PRODUCT SPEC. Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved series PMM 4000 series SEC/D Wei Zhang A PoL Regulators 3 (5) No. Checked 3/1301-BMR 651Technical 4 Uen Specification Specification Date Rev The PMM family of POL regulators are protected from thermal overload by an internal over temperature shutdown circuit. When the internal temperature exceeds the OTP threshold, the POL regulator will shut down. The POL regulator will make continuous attempts to start up (soft-start mode) and resume normal operation automatically when the temperature has dropped >10°C below the temperature threshold. Over Current Protection (OCP) The POL regulators include current limiting circuitry for protection at continuous overload. The output voltage will decrease towards zero for output currents in excess of the over-current threshold. The regulator will resume normal operation after removal of the overload. The load distribution should be designed for the maximum output short circuit current specified. The current limit operation is a “hick up” mode current limit. Soft-start Power Up From the moment a valid input voltage is applied, the softstart control introduces a short time-delay (typically 5-10 ms) before allowing the output voltage to rise. The initial rise in input current when the input voltage first starts to rise is the charge current drawn by the input capacitors. Power-up is complete within 15 ms. Auto-Track™ Function The AutoTrack function is designed so that 2 or more POL regulators can track each others output voltage tightly together. This can be accomplished by connection the AutoTrack pin to the output of another POL regulator or by feeding an external voltage ramp on the pin. The AutoTrack will automatically track any external voltage that is applied within the given rules in Application Note POLA (AN205). Margin Up/Down controls The margin control allows the input voltage to be momentarily adjusted, either up or down, by a nominal 5 %. This provides a convenient method for dynamically testing the operation of the load circuit over its supply margin or range. It can also be used to verify the function of supply voltage supervisors. Pre-Bias Startup Capability This often occurs in complex digital systems when current from another power source is backfed through a dual-supply logic component, such as FPGA or ASIC. The PMM family incorporate synchronous rectifiers, but will not sink current during startup, or whenever the Inhibit pin is held low. However, to ensure satisfactory operation of this function, the input voltage must always be greater than the output voltage throughout the power-up and power down sequence. 31 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-16 PA1 Inputregulator, 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL Input 2.95-5.5 Output 60 60 A/150 A/150 W W Over Temperature Protection (OTP) Reference © Flex Ericsson AB Power Modules AB Thermal Consideration General The POL regulators are designed to operate in different thermal environments and sufficient cooling must be provided to ensure reliable operation. Cooling is achieved mainly by conduction, from the pins to the host board, and convection, which is dependant on the airflow across the regulator. Increased airflow enhances the cooling of the POL regulator. The Output Current Derating graph found in the Output section for each model provides the available output current vs. ambient air temperature and air velocity at Vin = 3.3 V. The POL regulator is tested on a 254 x 254 mm, 35 μm (1 oz), 8-layer test board mounted vertically in a wind tunnel with a cross-section of 305 x 305 mm. Proper cooling of the POL regulator can be verified by measuring the temperature at positions P1, P2 and P3. The temperature at these positions should not exceed the max values provided in the table below. Note that the max value is the absolute maximum rating (non destruction) and that the electrical Output data is guaranteed up to Tamb +85°C. See Design Note 019 for further information. Position Device P1 Pcb P2 Mosfet P3 Inductor Designation max value Tref 135º C 130º C 125º C E Ericsson Internal PRODUCT SPEC. Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved series PMM 4000 series SEC/D Wei Zhang A PoL Regulators 4 (5) No. Checked 3/1301-BMR 651Technical 4 Uen Specification Specification Date Rev 32 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April 2006-3-16 PA1 Inputregulator, 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL Input 2.95-5.5 Output 60 60 A/150 A/150 W W Thermal Consideration continued Reference © Flex Ericsson AB Power Modules AB Connections Definition of reference temperature (Tref) The reference temperature is used to monitor the temperature limits of the product. Temperatures above maximum Tref are not allowed and may cause degradation or permanent damage to the product. Tref is also used to define the temperature range for normal operating conditions. Tref is defined by the design and used to guarantee safety margins, proper operation and high reliability of the module. Ambient Temperature Calculation TBD Pin 1, 3, 5,10, 13,16 2, 4, 6 7 8 Designation Function GND Common ground connection for the Vin and Vout power connections. Vin The positive input voltage power node to the module. Inhibit Applying a low-level ground signal to this input disables the module’s output. Connecting a resistor from this pin to ground allows the on threshold of the input UVLO Prog undervoltage lockout (UVLO) to be adjusted higher than the default value. Vout The regulated positive power output with respect to the GND node. 11 +Sense The sense input allows the regulation circuit to compensate for voltage drop between the module and the load. If used, it should be connected to Vo. 14 -Sense If used, -Sense should be connected to the ground return at the load. 17 Vo Adjust 18 Track 19 Margin Up When this input is asserted to GND, the output voltage is increased by 5%. 20 Margin Down When this input is asserted to GND, the output voltage is decreased by 5% from the nominal. 9, 12 ,15 A 0.05 W 1% resistor must be directly connected between this pin and GND to set the output voltage. This is an analog control input that enables the output voltage to follow an external voltage. E Prepared (also subject responsible if other) 1 (6) 4/1301-BMR 651Technical Specification Specification 33 No. SEC/D EPANHON Approved Ericsson Internal PRODUCT SPECIFICATION Checked PMM 4000 series SEC/D (Linda series Zhong) PoL Regulators See end Date 2006-3-17 Inputregulator, 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL Input 2.95-5.5 Output 60 60 A/150 A/150 W W Mechanical Information (Surface mount version) Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April B © Flex Ericsson AB Power Modules AB E Prepared (also subject responsible if other) 2 (6) 4/1301-BMR 651Technical Specification Specification 34 No. SEC/D EPANHON Approved Ericsson Internal PRODUCT SPECIFICATION Checked PMM 4000 series SEC/D (Linda series Zhong) PoL Regulators See end Date 2006-3-17 Inputregulator, 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL Input 2.95-5.5 Output 60 60 A/150 A/150 W W Mechanical Information (Through hole mount version) Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April B © Flex Ericsson AB Power Modules AB E Prepared (also subject responsible if other) Ericsson Internal PRODUCT SPECIFICATION 3 (6) 4/1301-BMR 651Technical Specification Specification 35 No. SEC/D EPANHON Approved Checked PMM 4000 series SEC/D (Linda series Zhong) PoL Regulators See end Date 2006-3-17 Inputregulator, 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL Input 2.95-5.5 Output 60 60 A/150 A/150 W W Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April B © Flex Ericsson AB Power Modules AB Soldering Information - Surface mounting Maximum regulator temperature requirements The surface mount version of product is intended for convection or vapor phase reflow Pb-free processes. To achieve a good and reliable soldering result, make sure to follow the recommendations from the solder paste supplier, to use state-of-the-art reflow equipment and reflow profiling techniques as well as the following guidelines. To avoid damage or performance degradation of the product, the reflow profile should be optimized to avoid excessive heating. The maximum product temperature shall be monitored by attaching a thermal coupler to the top of the main transformer. A no-clean flux is recommended to avoid entrapment of cleaning fluids in cavities inside of the DC/DC regulator. The cleaning residues may affect long time reliability and isolation voltage. A sufficiently extended preheat time is recommended to ensure an even temperature across the host PCB, for both small and large devices. To reduce the risk of excessive heating is also recommended to reduce the time in the reflow zone as much as possible. Minimum pin temperature recommendations SnPb solder processes Pin number 12 is recommended as reference location for the minimum pin temperature recommendations since this will be the coolest solder joint during the reflow process. For conventional SnPb solder processes, the product is qualified for MSL 1 according to IPC/JEDEC standard J-STD-020C. During reflow, TP must not exceed +225 °C at any time. PIN 12 for measurement of minimum solder joint temperature, TPIN Lead-free (Pb-free) solder processes For Pb-free solder processes, the product is qualified for MSL 3 according to IPC/JEDEC standard J-STD-020C. Main transformer for measurement of Max product temperature, TP During reflow, TP must not exceed +260 °C at any time. Temperature SnPb solder processes For Pb solder processes, a pin temperature (TPIN) in excess of the solder melting temperature, (TL, +183 °C for Sn63/Pb37) for more than 30 seconds, and a peak temperature of +210 °C is recommended to ensure a reliable solder joint. Ramp-up TP Ramp-down (cooling) TL Reflow Lead-free (Pb-free) solder processes For Pb-free solder processes, a pin temperature (TPIN) in excess of the solder melting temperature (TL, +217 to +221 °C for Sn/Ag/Cu solder alloys) for more than 30 seconds, and a peak temperature of +235 °C on all solder joints is recommended to ensure a reliable solder joint. Preheat 25 °C Time 25 °C to peak Time Profile features Sn/Pb eutectic assembly Average ramp-up rate Pb-free assembly 3 °C/s max 3 °C/s max Solder melting temperature (typical) TL +183 °C +221 °C Peak converter temperature TP +225 °C +260 °C Average ramp-down rate 6 °C/s max 6 °C/s max Time 25 °C to peak temperature 6 minutes max 8 minutes max E Prepared (also subject responsible if other) 4 (6) 4/1301-BMR 651Technical Specification Specification 36 No. SEC/D EPANHON Approved Ericsson Internal PRODUCT SPECIFICATION Checked PMM 4000 series SEC/D (Linda series Zhong) PoL Regulators See end Date 2006-3-17 Inputregulator, 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL Input 2.95-5.5 Output 60 60 A/150 A/150 W W Soldering Information — Through Hole Mounting The through hole mount version of the product is intended for through hole mounting on a PCB. When wave soldering is used, the temperature on the pins is specified to maximum 260 °C for maximum 10 seconds. Maximum preheat rate of 4 °C/s and temperature of max 150 °C is suggested. When hand soldering, care should be taken to avoid direct contact between the hot soldering iron tip and the pins for more than a few seconds in order to prevent overheating. A no-clean (NC) flux is recommended to avoid entrapment of cleaning fluids in cavities inside of the DC/DC power module. The residues may affect long time reliability and isolation voltage. Delivery package information The products are delivered antistatic trays. Tray specifications Material PET Surface resistance 10E3 to 10E5 ohms/square Bake ability The trays cannot be baked Tray capacity 12 converters/tray Box capacity 60 converters (full trays/box) Dry pack information The products are delivered in trays. These inner shipment containers are dry packed in standard moisture barrier bags according to IPC/JEDEC standard J-STD-033A (Handling, packing, shipping and use of moisture/reflow sensitivity surface mount devices). Using products in high temperature Pb-free soldering processes requires dry pack storage and handling. In case the products have been stored in an uncontrolled environment and no longer can be considered dry, the modules must be baked according to the referred IPC/JEDEC standard. Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April B © Flex Ericsson AB Power Modules AB E Prepared (also subject responsible if other) Ericsson Internal PRODUCT SPECIFICATION 5 (6) 4/1301-BMR 651Technical Specification Specification 37 No. SEC/D EPANHON Approved Checked PMM 4000 series SEC/D (Linda series Zhong) PoL Regulators See end Date 2006-3-17 Inputregulator, 2.95-5.5 V, Output 60 A V, /V,150W 2.95-5.5 Output POL Input 2.95-5.5 Output 60 60 A/150 A/150 W W Rev Reference 1/ 28701BMR A2006 November 2017 EN/LZT R1BRev. March 2013 146 337651 R1A April B © Flex Ericsson AB Power Modules AB Product Qualification Specification (pending) Characteristics Visual inspection JESD22-B101 Temperature cycling JESD22-A104-B Dwell time Transfer time Temperature range Number of cycles 30 min 0-1 min -40 °C to +125 °C 300 cycles High temperature storage life JESD22-A103-B Temperature Duration 125 °C 1000 h Cold (in operation) IEC 68-2-1A, test Ad Temperature TA Duration -45 °C 72 h Lead integrity JESD22-B105-C Test condition A Weight Duration 1000 g 30 s Solder ability(only apply to through hole version) IEC 68-2-54 Solder immersion depth Duration of immersion (FC time) TA (time for onset of wetting) Time to FB Wetting strength FB Stability FC /FB 1 mm 15 s 100 mN/m >0.8 Steady State Temperature Humidity Bias Life Test JESD22-A101-B Temperature Humidity Duration Input Voltage +85 °C 85 % RH 1000 hours Maximum Mechanical shock JESD22-B104-B Peak acceleration Duration Number of shocks 200 g 1.5 ms 5 in each of two directions of three axes Vibration, variable freq JESD22-B103-B Frequency range Acceleration amplitude 10-1000 Hz 10 g or displacement amplitude 1.0 mm Random vibration JESD22-B103-B Frequency Acceleration density 2-500 Hz 0.008-0.2 g2/Hz Temperature Load ON OFF Test duration 85 °C Maximum 9 min 3 min 1000 h Operational life test Moisture reflow sensitivity classification test J-STD-020C Resistance to cleaning agents IEC 68-2-45 Xa Method 2 SnPb eutectic MSL 1 225 °C Pb free MSL 3 260 °C Water Glycol ether Isopropyl alcohol +55 ±5 °C +35 ±5 °C +35 ±5 °C
PMM4218TWP 价格&库存
很抱歉,暂时无法提供与“PMM4218TWP”相匹配的价格&库存,您可以联系我们找货
