G24P02S
G24P02S
    JASN(建旭电子)
    SMD,15.1x7.1mm
    网口/脉冲变压器 10/100/1000Base-T 1.5KVrns X-FMR_15.1X7.1MM_SM
G24P02S 数据手册
10/100/1000 BASE-T SINGLE PORT MAGNETICS MODULE Rev:A/0 P/N: G24P02S DATA SHEET Feature Compliant with IEEE 802.3ab standard. Comply with RoHS requirements. Operating temperature range: 0℃ to +70℃. Storage temperature range: -25℃ to +105℃. Electrical Specifications @ 25℃ OCL: 350uH Min. @100KHz/0.1V with 8mA DC Bias Hi-POT : 1500Vrms Turn Ratio: 1:1±3% LK: 0.5uH Max @100KHz/0.2V Cw/w 30PF Max @100KHz/0.2V D.C.R: 1.2 ohm Max Insertion Loss: 1-100MHz: -1.0dB Max Cross Talk : 1-100MHz:-30dB Min CMRR: 1-100MHz:-30dB Min Return Loss: 1-30MHz 40MHz 50MHz -18dB Min -14.4dB Min -13.1dB Min Schematic 60-80MHZ 80-100MHZ -12dB Min -10dB Min Mechanical 1 24 2 23 3 22 4 21 5 20 6 19 7 18 8 17 9 16 10 15 11 14 12 13 Unless otherwise specified, all tolerances are ±0.25 Http://www.jansum.cn E-mail:sales@jansum.cn Tel:+86-769-86299641 Fax:+86-769-86299645
G24P02S 价格&库存
很抱歉,暂时无法提供与“G24P02S”相匹配的价格&库存,您可以联系我们找货
G24P02S
G24P02S
    • 1+2.89440
    • 10+2.22480
    • 30+1.94400
    • 100+1.58760
    • 500+1.50120
    • 800+1.41480
    库存:27005
