UMW
R
UMW SI2319A
SOT-23 Plastic-Encapsulate MOSFETS
Features
VDS (V) = -40V
SOT–23
RDS(ON)
70m
(VGS = 10V) ,ID = -4.4A
RDS(ON)
95m
(VGS = 4.5V) ,ID = -3.5A
1. GATE
2. SOURCE
3. DRAIN
Equivalent Circuit
Maximum ratings ( Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
-40
Gate-Source Voltage
VGS
±20
Continuous Drain Current
ID
-4.4
Pu lsed Di od e C urren
IDM
-12
Continuous Source-Drain Current(Diode Conduction)
IS
-1. 25
Power Dissipation
PD
1.25
W
RthJF
166
℃ /W
TJ
150
TSTG
-55 ~+15 0
V
Thermal Resistance from Junction to Ambient (t?5s)
Operating Junction
Storage Temperature
www.umw-ic.com
1
A
友台半导体有限公司
UMW
R
UMW SI2319A
MOSFET ELECTRICAL CHARACTERISTICS
Static Electrical Characteristics (Ta = 25 ℃ Unless Otherwise Noted)
Parameter
Symbol
Test Condition
Min
V(BR)DSS
VGS = 0V, ID = -250µA
-40
VGS(th)
VDS =VGS, ID = -250µA
-1
Gate-source leakage
IGSS
Zero gate voltage drain current
IDSS
Typ
Max
Unit
Static
Drain-source breakdown voltage
Gate-source threshold voltage
Drain-source on-state resistancea
Forward transconductancea
Diode forward voltage
V
-3
V
VDS =0V, VGS = ±20V
±100
nA
VDS = -40V, VGS =0V
-1
µA
VGS = -10V, ID = -4.4A
70
mΩ
VGS = -4.5V, ID = -3.5A
95
mΩ
RDS(on)
gfs
VDS = -5V, ID = -3A
7
VSD
IS= -1.25A, VGS=0V
-0.8
S
-1.25
V
Dynamic
Input capacitance
Ciss
Output capacitance
Coss
Reverse transfer capacitanceb
Crss
Total gate charge
Qg
Gate-source charge
Qgs
Gate-drain charge
Qgd
Gate resistance
VDS = -20V, VGS =0V,
f=1MHz
VDS = -20V, VGS = 10V,
ID = -3A
f=1MHz
Rg
470
pF
85
pF
65
pF
11.5
17
nC
1.8
nC
3.3
nC
9
Switchingb
Turn-on delay time
Rise time
Turn-off delay time
Fall time
td(on)
tr
td(off)
VDS=-20V
RL=20? , ID = -1A,
VGEN=-4.5 V,Rg=6?
tf
7
15
ns
15
25
ns
25
40
ns
25
42
ns
-1.25
A
-20
A
Drain-source body diode characteristics
Continuous Source-Drain Diode Current
Pulsed Diode forward Curren
IS
Tc=25℃
ISM
Note :
1. Repetitive Rating : Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t < 5 sec.
3. Pulse Test : Pulse Width≤300µs, Duty Cycle ≤ 2%.
4. Guaranteed by design, not subject to production testing.
www.umw-ic.com
2
友台半导体有限公司
UMW
R
UMW SI2319A
TYPICAL ELEC TRICAL AND THERMAL CHARACTERISTICS
www.umw-ic.com
3
友台半导体有限公司
UMW
R
UMW SI2319A
www.umw-ic.com
4
友台半导体有限公司
UMW
R
UMW SI2319A
www.umw-ic.com
5
友台半导体有限公司
UMW
R
UMW SI2319A
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
Dimensions In Millimeters
Min.
Max.
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP.
1.800
2.000
0.550 REF.
0.300
0.500
0°
8°
Dimensions In Inches
Min.
Max.
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP.
0.071
0.079
0.022 REF.
0.012
0.020
0°
8°
Marking
A19
U
Ordering information
Order code
Package
Baseqty
Deliverymode
UMW SI2319
SOT-23
3000
Tape and reel
www.umw-ic.com
6
友台半导体有限公司
很抱歉,暂时无法提供与“SI2319A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.31752
- 100+0.25132
- 300+0.21816
- 3000+0.17054
- 6000+0.15066
- 9000+0.14073
- 国内价格
- 1+0.33220
- 200+0.21450
- 1500+0.18700
- 3000+0.16500
- 国内价格
- 20+0.72300
- 100+0.43120
- 800+0.30190
- 3000+0.21560
- 6000+0.20480
- 30000+0.18980
- 国内价格 香港价格
- 3000+0.829223000+0.10389
- 6000+0.751466000+0.09415
- 9000+0.711819000+0.08918
- 15000+0.6672415000+0.08359
- 21000+0.6408421000+0.08029
- 30000+0.6151830000+0.07707
- 75000+0.5588675000+0.07002
- 150000+0.54782150000+0.06863
- 国内价格 香港价格
- 1+3.858191+0.48335
- 10+2.3403510+0.29320
- 100+1.47957100+0.18536
- 500+1.10459500+0.13838
- 1000+0.983361000+0.12320
- 国内价格
- 10+0.34856
- 100+0.27664
- 300+0.24073
