UMHVP-1250
UMHVP-1250
    HVMTECHNOLOGY
    DIP4 模块
    高电压 - 隔离模块 直流转换器 1 输出 5000V 100µA 0V - 12V 输入
UMHVP-1250 数据手册
UMHVP Series High Voltage DC to DC Converter D1111111111111 11111111111111 11111111111111 11111111111111 11111111111111 11111111111111 11111111111111 11111111111111 11111111111111 11111111111111 11111111111111 11111111111111 Case Size (0.5” x 0.5” x 0.5”) PCB Mountable No External Components Required Extremely Low Quiescent Current Low Ripple and EMI/RFI High Input/Output Isolation Wide Operating Temp Range (-55°C to +70°C) Available in positive or negative outputs Description The UMHVP Series is a family of low cost ultra-miniature single-output DC to DC converters supplying up to 5kV in 0.125 cubic inches (0.5” x 0.5” x 0.5”). These ultra-compact converters are ideal for applications requiring small size and ease of use. HVM’s proprietary resonant converter design minimizes quiescent current and operating noise while delivering maximum performance and reliability. A special feature of this power supply is its extremely low input current at no load, making it ideal for battery powered applications. The output voltage is directly proportional to the input voltage from approximately 0.7V input to maximum input voltage, allowing for a controllable output voltage and features excellent linearity. Mechanical Characteristics • • • • Size: 0.5” x 0.5” x 0.5” Weight: 4.1 grams typical Packaging: Encapsulated in high performance epoxy Case Material: Thermoset plastic (Diallyl Phthalate) The output power rating is 0.5W and the input to output isolation is ± 500V. The UMHVP Series is very stable over a wide operating temperature range. Environmental Characteristics • • Operating Temp Range: -55°C to +70°C Storage Temp Range: -55°C to +85°C HVM TECHNOLOGY 2967 Oak Run Pkwy, Ste 515, New Braunfels TX, 78132 Tel: (830) 626-5552/ www.hvmtech.com/ email: sales@hvmtech.com Rev F MECHANICAL APPLICATION SCHEMATIC NOTE : C1 OP TIONAL FOR LOWE R OUTPUT RIPPLE IN+ ( 0 - 5VDC or 0 - 12VDC) IN+ HVOUT C1 IN- LOAD 0.50 0.50 HVRTN 0. 50 FLOATING GND ( +/- 500V IS OLATION) 0.21 BOTTOM VIE W ELECTRICAL CHARACTERISTICS Input Voltage (IN+) 3 0 - 5VDC or 0 - 12VDC 2 Typical Input Current Output Voltage (HVOUT) 5V input:
UMHVP-1250 价格&库存
很抱歉,暂时无法提供与“UMHVP-1250”相匹配的价格&库存,您可以联系我们找货
