MGDSK10CE
MGDSK10CE
    GAIA
    DIP5
    隔离模块 直流转换器 1 输出 12V 800mA 4.5V - 5.5V 输入
MGDSK10CE 数据手册
MGDK10 10W POWER BOARD MOUNTED ISOLATED DC/DC CONVERTER 0.3’’ LOW PROFILE Description The MGDK10 series features a Quality Cost Effective range of 10W board mounted isolated dc/dc converters. With multiple selection of wide input voltage ranges, the MGDK10 is proposed with a single, double, symmetrical or triple output channel. The converter embeds an output overload protection, and comes encapsulated in a low profile fully potted 1.6’’x0.3’’x1’’ metallic case. Fields of Application General purpose application Transportation Telecom Rnewable Energy Part-numbering MGD S K 10 H C output nb. Input range S = single B = double T = Triple C = 4.5-5.5 D = 4.5-16 H = 9-36 I = 18-36 O = 18-75 Q = 36-140 Output B = 3.3 C=5 E = 12 F = 15 (voltage value) Selection Guide Part Number Part Number Output Voltage (Vdc) Output Power (Watt) Output Current (Adc) +/-0.4 MGDSK10HF 12 10 0.8 10 0.66 MGDBK10HC +/-5 10 +/-1 +/-12 10 +/-0.4 MGDBK10HE +/-12 10 +/-0.4 MGDBK10CF +/-15 10 +/-0.33 MGDBK10HF +/-15 10 +/-0.33 MGDSK10DC 5 10 2 MGDTK10H3E +3,8 +/-12 10 +1 +/-0.2 MGDBK10DC +/-5 10 +/-1 MGDTK10HCE +5 +/-12 10 +1 +/-0.2 MGDBK10DF 5 10 2 MGDTK10HCF +5 +/-15 10 +1 +/-0.17 MGDSK10HB 3.3 6.6 2 MGDTK10ICE +5 +/-12 10 +1 +/-0.2 MGDSK10HC 5 10 2 MGDTK10ICF +5 +/-15 10 +1 +/-0.17 MGDSK10H5.5 5.5 10 1.8 MGDSK10OC 5 10 2 MGDSK10HE 12 10 0.8 MGDBK10OF +/-15 10 +/-0.33 Output Voltage (Vdc) Output Power (Watt) Output Current (Adc) MGDSK10CE +/-12 10 MGDSK10CF 15 MGDBK10CE for more information go to https://www.gaia-converter.com FC19-097.01/21 Revision C 1/5 WWW.GAIA-CONVERTER.COM MGDK10 10W POWER BOARD MOUNTED ISOLATED DC/DC CONVERTER 0.3’’ LOW PROFILE Selection Guide (continued) Part Number Part Number Output Voltage (Vdc) Output Power (Watt) Output Current (Adc) 2 MGDBK10QE 12 10 0.8 10 2 MGDBK10QE/Y 12 10 0.8 5 10 2 MGDBK10QF 15 10 0.66 +/-5 10 +/-1 Output Voltage (Vdc) Output Power (Watt) Output Current (Adc) MGDSK10QB 3.3 6.6 MGDSK10QC 5 MGDSK10QC/Y MGDBK10QC 1-ELECTRICAL SPECIFICATIONS Specification Data are valid at +25°C, unless otherwise specified Parameter Conditions Limit Units C input D input H input I input Nominal Input Voltage (Ui nom) Full temperature range Nominal Vdc 5 9 20 24 Input Voltage Range Full temperature range Min.-Max. Vdc 4.5-5.5 4.5-16 9-36 18-36 Transient Input Voltage Full temperature range Maximum Vdc/s / / 36 36 Start-up input voltage Turn on -turn off Full temperature range Min.-Max. Vdc 4-4.5 7-8.5 12-15.5 16-17.5 Start-up time Full temperature range Maximum ms 50 Ui Nominal 75% load Typical % 80 Ui nominal (hic-up mode) Maximum mA 30 30 Conditions Limit Units O input Qinput Nominal Input Voltage (Ui nom) Full temperature range Nominal Vdc 48 72 Input Voltage Range Full temperature range Min.-Max. Vdc 18-75 36-140 Transient Input Voltage Full temperature range Maximum Vdc/s 75 175/0.1 Start-up input voltage Turn on -turn off Full temperature range Min.-Max. Vdc 12-15 33-36 Start-up time Full temperature range Maximum ms 50 Ui Nominal 75% load Typical % 80 Ui nominal (hic-up mode) Maximum mA INPUT Power efficiency Input current in short circuit mode (Average) Parameter 50 50 INPUT Power efficiency Input current in short circuit mode (Average) FC19-097.01/21 Revision C 2/5 WWW.GAIA-CONVERTER.COM 30 20 MGDK10 10W POWER 1-ELECTRICAL SPECIFICATIONS (Continued) Specification Data are valid at +25°C, unless otherwise specified Parameter Conditions Limit Units All inputs Ui nom @75% load Maximum % +/- 2.5 Output regulation (Line) 25% to full load Maximum % +/- 1.5 Output regulation (Load) Ui min. To Ui max 25% to full load 0% to 25% load Maximum Typical OUTPUT Set Point accuracy +/- 2.5 +20 to +/-2.5 % Minimum 10% load is recommended, operation with no load during more than 1s may partially damage the converter output. Output ripple voltage B output (3V3) C output (5V) E output (12V) F output (15V) Admissible capacitor B output (3V3) C output (5V) E output (12V) F output (15V) Ui min. To Ui max Ui min. Full load ( per output) Maximum mVpp 150 150 300 450 500 500 150 100 Maximum µF Typical Khz 480 Vdc 1500 MISCELLANEOUS Switching Frequency Isolation Strength (Input output) EMC Compliance FC19-0967 01/21 Revision C 3/5 Input output With input capacitor With input filter WWW.GAIA-CONVERTER.COM EN555032 class A EN555032 class B MGDK10 10W POWER 2-THERMAL & MECHANICAL SPECIFICATIONS Parameter Conditions Case temperature range Storage temperature range Not operating Case Material Limit Units Parameter Mini.Max. °C -40 to 95 Mini.Max. °C Regular model 110 Metallic black anodized coated Pin Material Copper plated with pure matte tin over nickel underplate Case to Air thermal resistance Typical °C/W Connections Pin# 1 2 3 4 5 6 7 8 MGDSK10 (Single) MGDBK10 (Double) MGDTK10 (Triple) +Input (Vi) Do Not Connect -Input (Gi) Output (Vo) / Common (Go) No pin No pin +Input (Vi) Do Not Connect -Input (Gi) Output+ (Vo) Common (Go) Output-(-Vo) No pin No pin +Input (Vi) Do Not Connect -Input (Gi) Output1 (Vo1) No pin Common (Go) Output2+ (+V2) Output2- (-V2) White dot on top side Dimensions MGDK10 Dimensions are given in mm (inches) . Tolerance : +/-0.25mm (0.01’’) unless otherwise specified weight : < 15gr (0.5oz) max. FC19-0967 01/21 Revision C 4/5 WWW.GAIA-CONVERTER.COM 12 MGDK10 10W POWER 3-APPLICATION Typical connections Input and output capacitor values are given as suggestion OCP FUNCTION The converter series incorporates an over current protection circuit. When the output current reaches a value above typically 200% of it’s full-rated current, the converter falls into hiccup mode by testing periodically if an overload is applied. The module restarts automatically to normal operation when overcurrent is removed. International Headquarters GAÏA Converter - France 18 rue caroline Aigle 33186 LE HAILLAN - FRANCE Tel. : + (33)-5-57-92-12-80 Fax : + (33)-5-57-92-12-89 FC19-0967 01/21 Revision C 5/5 North American Headquarters GAÏA Converter Canada, Inc 4038 Le Corbusier Blvd LAVAL, QUEBEC - CANADA H7L 5R2 Tel. : (514)-333-3169 Fax : (514)-333-4519 WWW.GAIA-CONVERTER.COM
MGDSK10CE 价格&库存
很抱歉,暂时无法提供与“MGDSK10CE”相匹配的价格&库存,您可以联系我们找货
