MGDSK25OC
MGDSK25OC
    GAIA
    DIP8
    隔离模块 直流转换器 1 输出 5V 5A 16V - 40V 输入
MGDSK25OC 数据手册
MGDK25 25W POWER BOARD MOUNTED ISOLATED DC/DC CONVERTER 1500 Vdc ISOLATION Description The MGDK25 series features a Quality Cost Effective range of 25W board mounted isolated dc/dc converters. With multiple selection of wide input voltage ranges, the MGDK25 is proposed with a single, double, symmetrical or triple output channel. The converter embeds an output overload protection, and comes encapsulated in a low profile fully potted 2’’x2’’X0.5’’ metallic case. Fields of Application General purpose application Transportation Telecom Rnewable Energy Part-numbering MGD S K 25 H C output nb. Input voltage range Output voltage S = single B = double T = Triple H = 9-36 O = 18-75 B = 3.3 C=5 E = 12 F = 15 Selection Guide Part Number Part Number Output Voltage (Vdc) Output Power (Watt) Output Current (Adc) 6 MGDSK25OB 3.3 19.8 6 25 5 MGDSK25OC 5 25 5 12 25 2.1 MGDSK25OE 12 25 2.1 MGDSK25HF 15 25 1.67 MGDSK25OF 15 25 1.67 MGDBK25HE +/-12 25 +/-1.05 MGDBK25OCB +5 +3,3 22.5 2.5/ 3 MGDBK25HF +/-15 25 +/-0.83 MGDBK25OE +/-12 25 +/-1.05 MGDTK25HCE +5 +/-12 25 2.5 +/-0.5 MGDBK25OF +/-15 25 +/-0.83 MGDTK25HCF +5 +/-15 25 2.5 +/-0.4 MGDTK25OCE +5 +/-12 25 2.5 +/-0.5 Output Voltage (Vdc) Output Power (Watt) Output Current (Adc) MGDSK25HB 3.3 19.8 MGDSK25HC 5 MGDSK25HE for more information go to https://www.gaia-converter.com FC19-099. 08/22 Revision D 1/4 WWW.GAIA-CONVERTER.COM MGDK25 25W POWER 1-ELECTRICAL SPECIFICATIONS Specification Data are valid at +25°C, unless otherwise specified Parameter Conditions Limit Units H input O input Nominal Input Voltage (Ui nom) Full temperature range Nominal Vdc 20 48 Transient Input Voltage Full temperature range Maximum Vdc/s 40/- 80/0.1 Start-up input voltage Turn on -turn off Full temperature range Min. Vdc 8.5 15 Start-up time Full temperature range Maximum ms 30 Ui Nominal 75% load Typical % 87 Ui nominal (hic-up mode) Maximum mA 40 Ui min. To Ui max Typical Vdc 5 +/-11.5 5 +/-14.6 Ui nom @75% load Maximum % +/-2.5 Output regulation (Line) 25% to full load Maximum % +/- 1.5 Output regulation (Load) Ui min. To Ui max 25% to full load 0% to 25% load Maximum Typical INPUT Power efficiency Input current in short circuit mode (Average) 45 OUTPUT Specific Output Voltage MGDT25HCE MGDT25HCF MGDT25OCE Set Point accuracy 5 +/-11.8 +/- 2.5 +20 to +/-2.5 % Minimum 10% load is recommended, operation with no load during more than 1s may partially damage the converter output. Output ripple voltage B output (3V3) C output (5V) E output (12V) F output (15V) Admissible capacitor B output (3V3) C output (5V) E output (12V) F output (15V) Ui min. To Ui max Ui min. Full load ( per output) Maximum Maximum mVpp µF 100 100 200 200 1500 1500 330 330 MISCELLANEOUS Switching Frequency Isolation Strength (Input output) EMC Compliance FC19-099 08/22 Revision D 2/4 Typical Regular model /Y option Khz 250 Vdc 1500 3000 With input capacitor With input filter WWW.GAIA-CONVERTER.COM EN555032 class A EN555032 class B MGDK25 25W POWER 2-THERMAL & MECHANICAL SPECIFICATIONS Parameter Conditions Case temperature range Storage temperature range Not operating Case Material Limit Units Parameter Mini.Max. °C -40 to 95 Mini.Max. °C Regular model Pin Material Copper plated with pure matte tin over nickel underplate Case to Air thermal resistance Typical Connections Pin# 1 2 3 4 5 6 7 8 MGDSK25 (Single) MGDBK25 (Symetrical) MGDTK25 (Triple) +Input (Vi) -Input (Gi) case Not connected Do not connect Output (Vo) Common (Go) Do not connect +Input (Vi) -Input (Gi) case Not connected Output+ (Vo) Common (Go) Output-(-Vo) Do not connect +Input (Vi) -Input (Gi) case Not connected Output2+ (+V2) Output1+ (Vo1) Common (Go) Output2- (-V2) Dimensions MGDK25 Dimensions are given in mm (inches) . Tolerance : +/-0.25mm (0.01’’) unless otherwise specified weight : < 80gr (2.8oz) max. FC19-099 08/22 Revision D 3/4 110 Metallic black anodized coated WWW.GAIA-CONVERTER.COM °C/W 7 MGDK25 25W POWER 3-APPLICATION Typical connections Input and output capacitor values are given as suggestions OCP Function The converter series incorporates an over current protection circuit. When the output current reaches a value above typically 200% of it’s full-rated current, the converter falls into hiccup mode by testing periodically if an overload is applied. The module restarts automatically to normal operation when overcurrent is removed. International Headquarters GAÏA Converter - France 18 rue caroline Aigle 33186 LE HAILLAN - FRANCE Tel. : + (33)-5-57-92-12-80 Fax : + (33)-5-57-92-12-89 FC19-099 08/22 Revision D 4/4 North American Headquarters GAÏA Converter Canada, Inc 1405 Trans-Canada Hwy, Suite 520 DORVAL, QUEBEC H9P 2V9 Tel. : (514)-333-3169 Fax : (514)-333-4519 WWW.GAIA-CONVERTER.COM
MGDSK25OC 价格&库存
很抱歉,暂时无法提供与“MGDSK25OC”相匹配的价格&库存,您可以联系我们找货
