MUS-2412-2W
MUS-2412-2W
    DIWELL
    SIP-4
    隔离模块 直流转换器 1 输出 12V 167mA 21.6V - 26.4V 输入
MUS-2412-2W 数据手册
MU-2W SERIES 2W UNREGULATED FEATURES            SINGLE IN LINE PACKAGE UP TO 2W UNREGULATED OUTPUT POWER 100% BURN IN HIGH EFFICIENCY INTERNAL SMD TECHNOLOGY LOW COST NO HEATSINK REQUIRED UL 94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE RoHS COMPLIANT 3 YEARS WARRANTY OUTPUT SPECIFICATIONS INPUT SPECIFICATIONS Voltage Set-point Accuracy +/-2% max. Input Voltage Range Temperature Coefficient +/-0.05%/°C Input Filter Capacitor typ. 100mVp-p max. Protection Fuse Recommended Ripple & Noise (20MHz BW)1 2 Line Regulation +/-1.2% max. Load Regulation3 Minimum Load +/-10% max. +/-8% max. 10% of Full Load Short Circuit Protection GENERAL SPECIFICATIONS Momentary Efficiency 77%-85% 4 Isolation Voltage 1500VDC min. 9 Isolation Resistance ENVIRONMENTAL SPECIFICATIONS Isolation Capacitance 80pF max. Switching Frequency 100KHz min. 5 MTBF >1,100,000 Hours -40 °C to +71 °C Weight Operating Temperature Storage Temperature 10 ohms min. -55 °C to +125 °C Case Material Humidity 95% max. Case Size Cooling Free-Air Convection Radiated Emissions 1.3g typ. Non-Conductive Plastic 11.7mm*7.5mm*10.1mm EN55022 Class B ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD AND 25 °C UNLESS OTHERWISE NOTED. 1 2 3 4 5 Measured with 1uF ceramic capacitor connects to the output pins. Line Regulation is for a 1.0% change in input Voltage. Load Regulation is for output load current change from 20% to 100%. 1500 For 10 seconds. MIL-HDBK-217F @25 °C , Ground Benign. DANUBE http://www.danube.com.tw 5-1 2016/09/22  SELECTION GUIDE 2W OUTPUT INPUT6 MODEL NUMBER INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) CURRENT(mA) FULL NO LOAD LOAD EFF ISOLATION (%)7 (VDC) MUS-0505-2W 5 5 400 520 55 77 1500 MUS-0512-2W 5 12 167 500 55 80 1500 MUS-0515-2W 5 15 133 488 55 82 1500 MUS-1205-2W 12 5 400 214 16 78 1500 MUS-1212-2W 12 12 167 207 16 81 1500 MUS-1215-2W 12 15 133 203 16 82 1500 MUS-2405-2W 24 5 400 107 15 78 1500 MUS-2412-2W 24 12 167 103 15 81 1500 MUS-2415-2W 24 15 133 101 15 82 1500 Note: Other input to output voltages may be available. Please contact factory. 6 7 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 5-2 2016/09/22  MECHANICAL DIMENSIONS & RECOMMENDED FOOTPRINT DETAILS PIN SINGLE 1 -Vin 2 +Vin 3 -Vout 4 +Vout NOTE : All dimensions are in mm [inches] 1. Pin Size is 0.50x0.30mm[0.02x0.01”] 2. Pin is Tolerance .XX= ±0.05mm 3. Tolerance .X or .XX= ±0.5mm GRID:2.54 mm TOP VIEW 1 2 3 4 0.8Φ+0.2/-0  SIMPLIFIED SCHEMATIC +Vin +Vout OSCILLATOR DRIVER -Vout -Vin DANUBE http://www.danube.com.tw 5-3 2016/09/22  TYPICAL APPLICATIONS INPUT OUTPUT +Vin +Vout DC-DC CONVERTER -Vin LOAD -Vout  TYPICAL PERFORMANCE CURVES Specifications typical at TA=25 °C, nominal input voltage, rated output current unless otherwise specified. VOUT VS LOAD (12Vout Models) 6.4 13.5 6.0 13.0 Vout(V) Vout(V) VOUT VS LOAD (5Vout Models) 5.6 5.2 12.5 12.0 11.5 4.8 0 100 200 300 0 400 42 Output Current(mA) 126 167 Output Current(mA) VOUT VS LOAD (15Vout Models) DERATING CURVE 16.5 % OF RATED LOAD(%) 125% 16.0 Vout(V) 84 15.5 15.0 14.5 0 34 67 101 133 Output Current(mA) 100% SAFE OPERATING AREA 75% 50% 25% 0% -40 -20 0 30 70 100 120 TA(degree C) EFFICIENCY VS LOAD EFFICIENCY(%) 80.0 60.0 40.0 20.0 0.0 0 20 40 60 80 100 % OF RATED LOAD(%) DANUBE http://www.danube.com.tw 5-4 2016/09/22  INPUT FUSE SELECTION GUIDE 4.5-5.5V INPUT VOLTAGE(VDC) 10.8-13.2V INPUT VOLTAGE(VDC) 21.6-26.4V INPUT VOLTAGE(VDC) 1500mA Slow-Blow Type 600mA Slow-Blow Type 300mA Slow-Blow Type INP UT OUTPUT +Vin +Vout Fuse DC-DC CONVERTER -Vin -Vout Note: Certain applications may require the installation of external fuse in front of the input. MU-2W SERIES APPLICATION NOTES: EXTERNAL CAPACITANCE REQUIREMENTS: Output filtering is required for operation. A minimum of 10uF is needed. Output capacitance may be increased for additional filtering, not to exceed 220uF. To meet the reflected ripple requirements of the converter, an input impedance of less than 0.5ohm from DC to 250KHz is required. We Can Offer EMC-Filter According To EN55011/22 Class B. Negative Outputs: A negative output voltage may be obtained by connecting the +OUT to circuit ground and connecting –OUT as the negative output. FOR MORE INFORMATION CALL: Danube Enterprise Co., Ltd. Tel: 886-7-3755165 Fax: 886-7-3755330 Home Page http://www.danube.com.tw DANUBE E-mail: danube@ms10.hinet.net http://www.danube.com.tw 5-5 2016/09/22
MUS-2412-2W 价格&库存
很抱歉,暂时无法提供与“MUS-2412-2W”相匹配的价格&库存,您可以联系我们找货
