PUS-03.305-2W
PUS-03.305-2W
    DIWELL
    SIP-4
    隔离模块 直流转换器 1 输出 5V 400mA 2.97V - 3.63V 输入
PUS-03.305-2W 数据手册
PU-2W SERIES 2W UNREGULATED FEATURES            SINGLE IN LINE PACKAGE 2W UNREGULATED OUTPUT POWER 100% BURN IN HIGH EFFICIENCY INTERNAL SMD TECHNOLOGY LOW COST NO HEATSINK REQUIRED UL 94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE RoHS COMPLIANT 3 YEARS WARRANTY OUTPUT SPECIFICATIONS Voltage Set-point Accuracy Temperature Coefficient 1 Ripple & Noise(20MHz BW) 2 Line Regulation 3 Load Regulation Minimum Load Short Circuit Protection INPUT SPECIFICATIONS +/-2% max Input Voltage Range +/-10% max +/-0.05%/°C Input Filter Capacitor Type 100mVp-p max Protection Fuse Recommended +/-1.2% max +/-8% max GENERAL SPECIFICATIONS 10% of Full Load Efficiency 70%-85% 4 Momentary Isolation Voltage 1500 VDC min Standard Models 3000 VDC min Suffix “D” Models 9 Isolation Resistance 10 ohms min Isolation Capacitance 80pF max Switching Frequency 100KHz min 5 >1,800,000 Hours Weight 2.3g Typ MTBF ENVIRONMENTAL SPECIFICATIONS Operating Temperature Storage Temperature Humidity Cooling -40 °C to +71 °C Case Material -55 °C to +125 °C Case Size Non-Conductive Plastic 19.6mm*7.1mm*10.2mm 95% max Conducted Emissions Free-Air Convection Radiated Emissions EN55022 Class A EN55022 Class B ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD AND 25 OC UNLESS OTHERWISE NOTED. 1 2 3 4 5 Measured with 1uF ceramic capacitor connect to the output pins. Line Regulation is for a 1.0% change in input Voltage. Load Regulation is for output load current change from 20% to 100%. 1500VDC for 10 seconds,3000VDC for 3 seconds. MIL-HDBK-217F @25 °C , Ground Benign. DANUBE http://www.danube.com.tw 7-1 2012/05/25  SELECTION GUIDE(1) 2W OUTPUT 6 INPUT INPUT OUTPUT OUTPUT MODEL CURRENT(mA) EFF VOLTAGE VOLTAGE CURRENT NUMBER (VDC) (VDC) (mA) FULL NO LOAD LOAD (%) 7 ISOLATION PACKAGE (VDC) PUS-03.305-2W 3.3 5 400 782 65 78 1500 C PUS-03.324-2W 3.3 24 84 782 65 78 1500 C PUS-0503.3-2W 5 3.3 500 452 60 73 1500 C PUS-0505-2W 5 5 400 520 60 77 1500 C PUS-0509-2W 5 9 222 506 60 79 1500 C PUS-0512-2W 5 12 167 500 60 80 1500 C PUS-0515-2W 5 15 133 488 60 82 1500 C 3.3 +/-15 +/-67 740 65 82 1500 C PUD-0505-2W 5 +/-5 +/-200 488 60 82 1500 C PUD-0512-2W 5 +/-12 +/-84 500 60 80 1500 C PUD-0515-2W 5 +/-15 +/-67 488 60 82 1500 C PUD-0524-2W 5 +/-24 +/-42 504 60 79 1500 C PUS-1203.3-2W 12 3.3 500 185 15 74 1500 C PUS-1205-2W 12 5 400 214 15 78 1500 C PUS-1209-2W 12 9 222 214 15 78 1500 C PUS-1212-2W 12 12 167 200 15 83 1500 C PUS-1215-2W 12 15 133 196 15 85 1500 C PUD-1205-2W 12 +/-5 +/-200 214 15 78 1500 C PUD-1212-2W 12 +/-12 +/-84 200 17 83 1500 C PUD-1215-2W 12 +/-15 +/-67 196 15 85 1500 C PUS-2403.3-2W 24 3.3 500 92 15 74 1500 C PUS-2405-2W 24 5 400 107 15 78 1500 C PUS-2409-2W 24 9 222 107 15 78 1500 C PUS-2412-2W 24 12 167 104 15 80 1500 C PUS-2415-2W 24 15 133 101 15 83 1500 C PUD-2405-2W 24 +/-5 +/-200 107 15 78 1500 C PUD-2412-2W 24 +/-12 +/-84 103 15 81 1500 C PUD-2415-2W 24 +/-15 +/-67 103 15 81 1500 C PUD-03.315-2W Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: PUS-****-2W(2W SINGLE OUTPUT) PUD-****-2W(2W DUAL OUTPUT) 6 7 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 7-2 2012/05/25  SELECTION GUIDE(2) 2W OUTPUT 8 INPUT INPUT OUTPUT OUTPUT MODEL CURRENT(mA) EFF VOLTAGE VOLTAGE CURRENT NUMBER (VDC) (VDC) (mA) FULL NO LOAD LOAD (%) 9 ISOLATION PACKAGE (VDC) PUS-0503.3D-2W 5 3.3 500 452 60 73 3000 D PUS-0505D-2W 5 5 400 520 60 77 3000 D PUS-0509D-2W 5 9 222 510 60 78 3000 D PUS-0512D-2W 5 12 167 500 60 80 3000 D PUS-0515D-2W 5 15 133 492 60 81 3000 D PUD-0505D-2W 5 +/-5 +/-200 520 60 77 3000 D PUD-0509D-2W 5 +/-9 +/-111 512 60 78 3000 D PUD-0512D-2W 5 +/-12 +/-84 500 60 80 3000 D PUD-0515D-2W 5 +/-15 +/-67 488 60 82 3000 D PUS-1203.3D-2W 12 3.3 500 185 15 74 3000 D PUS-1205D-2W 12 5 400 210 15 79 3000 D PUS-1209D-2W 12 9 222 210 15 79 3000 D PUS-1212D-2W 12 12 167 205 15 81 3000 D PUS-1215D-2W 12 15 133 200 15 83 3000 D PUD-1205D-2W 12 +/-5 +/-200 214 15 78 3000 D PUD-1212D-2W 12 +/-12 +/-84 203 15 82 3000 D PUD-1215D-2W 12 +/-15 +/-67 200 15 83 3000 D PUD-1218D-2W 12 +/-18 +/-55 199 20 83 3000 D PUS-2403.3D-2W 24 3.3 500 92 15 74 3000 D PUS-2405D-2W 24 5 400 108 15 77 3000 D PUS-2409D-2W 24 9 222 108 15 77 3000 D PUS-2412D-2W 24 12 167 104 15 80 3000 D PUS-2415D-2W 24 15 133 102 15 82 3000 D PUD-2405D-2W 24 +/-5 +/-200 107 15 78 3000 D PUD-2412D-2W 24 +/-12 +/-84 103 15 81 3000 D PUD-2415D-2W 24 +/-15 +/-67 102 15 81 3000 D Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: PUS-****D-2W(2W SINGLE OUTPUT) PUD-****D-2W(2W DUAL OUTPUT) 8 9 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 7-3 2012/05/25  MECHANICAL DIMENSIONS & RECOMMENDED FOOTPRINT DETAILS PACKAGE ”C” 19.6[0.77] FRONT VIEW 10.14[0.40] 3.81[0.15] 2.54[0.10] 7.1[0.28] SINGLE DUAL 1 +Vin +Vin 2 -Vin -Vin 4 -Vout -Vout 5 NP COMMON 6 +Vout +Vout NOTE : All Dimensions In mm(Inches) BOTTOM VIEW 1 2 PIN 1. Pin Size is 0.50x0.30mm[0.02x0.01”] 4 5 6 2. Pin is Tolerance .XX= ±0.05mm 3. Tolerance .X 1.2[0.05] or .XX= ±0.5mm SINGLE OUTPUT 2.54mm TOP VIEW 1 2 4 DUAL OUTPUT 2.54mm 2.54mm All dimensions are in mm[inches] 2.54mm TOP VIEW 6 4 5 6 1 2 PACKAGE ”D” 19.6[0.77] FRONT VIEW 10.14[0.40] 3.81[0.15] 2.54[0.10] 7.1[0.28] SINGLE DUAL 1 +Vin +Vin 2 -Vin -Vin 5 -Vout -Vout 6 NP COMMON 7 +Vout +Vout NOTE : All Dimensions In mm(Inches) BOTTOM VIEW 1 2 PIN 1. Pin Size is 0.50x0.30mm[0.02x0.01”] 5 6 7 2. Pin is Tolerance .XX= ±0.05mm 3. Tolerance .X 1.2[0.05] or .XX= ±0.5mm SINGLE OUTPUT TOP VIEW 1 2 5 DANUBE 7 DUAL OUTPUT 2.54mm TOP VIEW 1 2 2.54mm 2.54mm All dimensions are in mm[inches] 2.54mm 5 6 7 http://www.danube.com.tw 7-4 2012/05/25  SIMPLIFIED SCHEMATIC SINGLE OUTPUT DUAL OUTPUT +Vin +Vin +Vout OSCILLATOR DRIVER +Vout OSCILLATOR DRIVER -Vout COMMON -Vin -Vin -Vout  TYPICAL APPLICATIONS SINGLE OUTPUT INPUT OUTPUT +Vin DUAL OUTPUT INPUT +Vout OUTPUT +Vin +Vout LOAD1 DC-DC CONVERTER LOAD DC-DC CONVERTER -Vin Common -Vin -Vout LOAD2 -Vout  TYPICAL PERFORMANCE CURVES Specifications typical at TA=25 OC,nominal input voltage , rated output current unless otherwise specified. VOUT VS LOAD(5Vout Models) 4.2 6.4 3.9 6.0 Vout(V) Vout(V) VOUT VS LOAD(3.3Vout Models) 3.6 3.3 5.6 5.2 3.0 4.8 0 125 250 375 500 0 100 Output Current(mA) 6.0 10.0 Vout(V) Vout(V) 10.4 5.6 9.6 5.2 9.2 4.8 8.8 +/-100 +/-150 Output Current(mA) DANUBE 400 VOUT VS LOAD(9Vout Models) 6.4 +/-50 300 Output Current(mA) VOUT VS LOAD(+/- 5Vout Models) 0 200 +/-200 0 56 111 167 222 Output Current(mA) http://www.danube.com.tw 7-5 2012/05/25 VOUT VS LOAD(+/- 12Vout Models) 13.5 13.5 13.0 13.0 Vout(V) Vout(V) VOUT VS LOAD(12Vout Models) 12.5 12.5 12.0 12.0 11.5 11.5 0 42 84 126 167 0 Output Current(mA) 16.0 16.0 Vout(V) Vout(V) 16.5 15.5 +/-84 15.5 15.0 15.0 14.5 14.5 67 +/-63 VOUT VS LOAD(+/- 15Vout Models) 16.5 34 +/-42 Output Current(mA) VOUT VS LOAD(15Vout Models) 0 +/-21 101 133 0 Output Current(mA) +/-17 +/-34 +/-52 +/-67 Output Current(mA) DERATING CURVES EFFICIENCY VS LOAD 100 % 75% EFFICIENCY(%) OU TPUT POW ER(%) 125 % SA F E O P E R AT IN G A R EA 50% 25% -40 -2 0 0 20 40 TA (d e gr ee C ) 60 80 100 80.0 60.0 40.0 20.0 0.0 0 20 40 60 80 100 % OF RATED LOAD(%) DANUBE http://www.danube.com.tw 7-6 2012/05/25  INPUT FUSE SELECTION GUIDE 2.97-3.63V 4.5-5.5V 10.8-13.2V 21.6-26.4V INPUT VOLTAGE (VDC) INPUT VOLTAGE (VDC) INPUT VOLTAGE (VDC) INPUT VOLTAGE (VDC) 1200mA Slow-Blow Type 800mA Slow-Blow Type 300mA Slow-Blow Type 170mA Slow-Blow Type INPUT OUTPUT Fuse +Vin +Vout DC-DC CONVERTER -Vin -Vout Note: Certain applications may require the installation of external fuse in front of the input. PU-2W SERIES APPLICATION NOTES: EXTERNAL CAPACITANCE REQUIREMENTS: Output filtering is required for operation. A minimum of 10uF is needed. Output capacitance may be increased for additional filtering, not to exceed 220uF. To meet the reflected ripple requirements of the converter, an input impedance of less than 0.5ohm from DC to 250KHz is required. We Can Offer EMC-Filter According To EN55011/22 Class B. Negative Outputs: A negative output voltage may be obtained by connecting the +OUT to circuit ground and connecting –OUT as the negative output. FOR MORE INFORMATION CALL: Danube Enterprise Co., Ltd. Tel: 886-7-3755165 Fax: 886-7-3755330 Home Page http://www.danube.com.tw DANUBE E-mail: danube@ms10.hinet.net http://www.danube.com.tw 7-7 2012/05/25 Additional Information : 한국 총판점 : ㈜디웰전자 (Diwell Electronics Co., Ltd.) 경기도 군포시 당정동 358 군포창업보육센터 202호 202, Kunpo Business Incubator Center, 358, Dangjung-Dong, Gunpo-City, Gyeonggi-Do, South Korea Phone : 070-8235-0820 (+82-70-8235-0820) Fax : 031-429-0821 (+82-31-429-0821) Homepage: http:// www.diwell.com 기술 및 구매 문의 email : expoeb2@diwell.com, dsjeong@diwell.com
PUS-03.305-2W 价格&库存
很抱歉,暂时无法提供与“PUS-03.305-2W”相匹配的价格&库存,您可以联系我们找货
