CARS-2415M
CARS-2415M
    DIWELL
    DIP12 模块
    隔离模块 直流转换器 1 输出 15V 133mA 21.6V - 26.4V 输入
CARS-2415M 数据手册
CAR SERIES 2W REGULATED FEATURES           DUAL IN LINE PACKAGE UP TO 2W REGULATED OUTPUT POWER 100% BURNED IN HIGH EFFICIENCY FIVE-SIDED SHIELD TO REDUCE EMI LOW COST NO EXTERNAL COMPONENTS REQUIRED UL 94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE 3 YEARS WARRANTY OUTPUT SPECIFICATIONS INPUT SPECIFICATIONS Voltage Setpoint Accuracy +/-3% max Input Voltage Range +/-0.05%/OC Input Filter Pi Network 100mVp-p max Protection Fuse Recommended Temperature Coefficient Ripple & Noise(20MHz BW) +/-10% max 1 Line Regulation +/-1% max 2 Load Regulation +/-1% max Minimum Load GENERAL SPECIFICATIONS 10% of Full Load Efficiency Short Circuit Protection 58% min 3 Current Limit Protection Isolation Voltage Short Circuit Restart 1500 VDC min 9 Automatic Isolation Resistance 4 Transient Response 10 ohms min 200uS max Isolation Capacitance 80pF max Switching Frequency 50KHz min 5 >850,000 Hours Weight 12.0g-14.4g MTBF ENVIRONMENTAL SPECIFICATIONS Operating Temperature Storage Temperature -25 OC to +71 OC Case Material -55 O C to +125 Non-Conductive Plastic Or O C Five-Sided Shield Case Humidity 95% max Case Size Cooling Free-Air Convection Conducted Emissions 31.8mm*20.3mm*10.2mm Radiated Emissions EN55022 Class A EN55022 Class A ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD , AND 25 OC UNLESS OTHERWISE NOTED. 1 2 3 4 5 High Line to Low Line. Load Regulation is for output load current change from 10% to 100%. For 10 seconds. 25% Step Load Change. MIL-HDBK-217F @25 OC , Ground Benign. DANUBE http://www.danube.com.tw 15-1 2011/08/23  SELECTION GUIDE 2W OUTPUT INPUT MODEL 6 NUMBER OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) INPUT 7 CURRENT(mA) FULL NO LOAD LOAD EFF (%) 8 ISOLATION (VDC) CARS-0505(M) 4.5-5.5 5 400 727 64 55 1500 CARS-0509(M) 4.5-5.5 9 222 635 50 63 1500 CARS-0512(M) 4.5-5.5 12 167 615 50 65 1500 CARS-0515(M) 4.5-5.5 15 133 625 50 64 1500 CARD-0505(M) 4.5-5.5 +/-5 +/-200 696 70 57 1500 CARD-0512(M) 4.5-5.5 +/-12 +/-84 680 63 59 1500 CARD-0515(M) 4.5-5.5 +/-15 +/-67 641 80 62 1500 CARS-1205(M) 10.8-13.2 5 400 273 20 61 1500 CARS-1209(M) 10.8-13.2 9 222 265 20 63 1500 CARS-1212(M) 10.8-13.2 12 167 252 20 66 1500 CARS-1215(M) 10.8-13.2 15 133 242 20 69 1500 CARD-1205(M) 10.8-13.2 +/-5 +/-200 273 20 61 1500 CARD-1212(M) 10.8-13.2 +/-12 +/-84 270 40 62 1500 CARD-1215(M) 10.8-13.2 +/-15 +/-67 257 38 65 1500 CARS-2405(M) 21.6-26.4 5 400 132 13 63 1500 CARS-2409(M) 21.6-26.4 9 222 126 20 66 1500 CARS-2412(M) 21.6-26.4 12 167 121 13 69 1500 CARS-2415(M) 21.6-26.4 15 133 121 13 69 1500 CARD-2405(M) 21.6-26.4 +/-5 +/-200 132 13 63 1500 CARD-2412(M) 21.6-26.4 +/-12 +/-84 129 16 65 1500 CARD-2415(M) 21.6-26.4 +/-15 +/-67 132 16 63 1500 CARS-2805(M) 25.2-30.8 5 400 114 13 63 1500 CARS-4805(M) 43.2-52.8 5 400 66 8 63 1500 CARS-4809(M) 43.2-52.8 9 222 63 8 66 1500 CARS-4812(M) 43.2-52.8 12 167 60 8 69 1500 CARS-4815(M) 43.2-52.8 15 133 60 8 69 1500 CARD-4805(M) 43.2-52.8 +/-5 +/-200 66 8 63 1500 CARD-4812(M) 43.2-52.8 +/-12 +/-84 60 8 69 1500 CARD-4815(M) 43.2-52.8 +/-15 +/-67 66 8 63 1500 Note: Other input to output voltages may be available. Please contact factory. 6 7 8 CAR*-**** ------ Non-Conductive Plastic NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE CAR*-****M ------ Five -sided shield case http://www.danube.com.tw 15-2 2011/08/23  SIMPLIFIED SCHEMATIC SINGLE OUTPUT DUAL OUTPUT REGULATOR +Vin REGULATOR +Vin +Vout OSCILLATOR DRIVER +Vout OSCILLATOR DRIVER Com. -Vout -Vout -Vin -Vin REGULATOR  MECHANICAL DIMENSIONS & RECOMMENDED FOOTPRINT DETAILS 20.3[0.80] 24 23 22 1 2 3 BOTTOM VIEW 15 14 13 2.06[0.08] SIDE VIEW 31.8[1.25] 10 11 12 15.24[0.60] PIN SINGLE DUAL 1 & 24 +Vin +Vin 2 & 23 NC -Vout 3 & 22 NC Common 10 & 15 -Vout Common 11 & 14 +Vout +Vout 12 & 13 -Vin -Vin 10.2[0.40] 2.54[0.10] 3.81[0.15] 2.54mm All dimensions are in mm[inches] 2.54mm 2423 22 151413 1 2 3 10 11 12 TOP VIEW  TYPICAL APPLICATIONS SINGLE OUTPUT INPUT OUTPUT +Vin DUAL OUTPUT INPUT +Vout OUTPUT +Vin +Vout LOAD1 DC-DC CONVERTER -Vin -Vout DANUBE LOAD Common DC-DC CONVERTER -Vin LOAD2 -Vout http://www.danube.com.tw 15-3 2011/08/23  TYPICAL PERFORMANCE CURVES Specifications typical at ta=25 OC,nominal input voltage , rated output current unless otherwise specified. OUTPUT LOAD VS OUTPUT VOLTAGE 80% 60% 40% 20% 0% 0% 20% 40% 60% 80% 100% OUTPUT VOLTAGE CHANGE(%) EFFICIENCY(%) OUTPUT LOAD VS EFFICIENCY 10% 5% 0% -5% -10% 0% OUTPUT LOAD(%) OUTPUT LOAD(%) TEMPERATURE DERATING INPUT VOLTAGE VS EFFICIENCY 125% 100% EFFICIENCY(%) OUTPUT POWER(%) 20% 40% 60% 80% 100% 100% SAFE OPERATING AREA 75% 50% 25% 80% 60% 40% 20% 0% 0% -25 0 25 50 70 -10 100 -5 Nom 5 10 INPUT VOLTAGE(%) TA(degree C)  INPUT FUSE SELECTION GUIDE 4.5-5.5V 10.8-13.2V 21.6-30.8V 43.2-52.8V INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) 1200mA Slow-Blow Type 400mA Slow-Blow Type 250mA Slow-Blow Type 100mA Slow-Blow Type INPUT OUTPUT Fuse +Vin +Vout DC-DC CONVERTER -Vin -Vout Note: Certain applications may require the installation of external fuse in front of the input. DANUBE http://www.danube.com.tw 15-4 2011/08/23 CAR SERIES APPLICATION NOTES: EXTERNAL CAPACITANCE REQUIREMENTS: No external capacitance is required for operation of the CAR series. To meet the reflected ripple requirements of the converter, an input impedance of less than 0.5 ohm from DC to 100KHz is required. External output capacitance is not required for operation, however it is recommended that 10uF tantalum and 0.1uF ceramic capacitance be selected for reduced system noise. Additional output capacitance may be added for increased filtering, but should not exceed 220uF. We Can Offer EMC-Filter According To EN55011/22 Class B. Negative Outputs: A negative output voltage may be obtained by connecting the +OUT to circuit ground and connecting –OUT as the negative output. FOR MORE INFORMATION CALL: Danube Enterprise Co., Ltd. Tel: 886-7-3755165 Fax: 886-7-3755330 Home Page http://www.danube.com.tw DANUBE E-mail: danube@ms10.hinet.net http://www.danube.com.tw 15-5 2011/08/23
CARS-2415M 价格&库存
很抱歉,暂时无法提供与“CARS-2415M”相匹配的价格&库存,您可以联系我们找货
