PU-S SERIES
1W UNREGULATED
FEATURES
CONTINOUS SHORT CIRCUIT
PROTECTION
SINGLE IN LINE PACKAGE
100% BURN IN
HIGH EFFICIENCY
INTERNAL SMD TECHNOLOGY
NO HEATSINK REQUIRED
UL 94V-0 PACKAGE MATERIAL
RoHS COMPLIANT
3 YEARS WARRANTY
OUTPUT SPECIFICATIONS
Voltage Set-point Accuracy
Temperature Coefficient
Ripple & Noise(20MHz BW)
Line Regulation
1
Load Regulation
2
Minimum Load
Short Circuit Protection
Short Circuit Restart
INPUT SPECIFICATIONS
+/-2% max Input Voltage Range
+/-0.05%/°C Input Filter
Capacitor Typ
100mVp-p max Protection
Fuse Recommended
+/-1.2% max
+/-8% max
Storage Temperature
Humidity
Cooling
GENERAL SPECIFICATIONS
20% of Full Load Efficiency
Continuous Isolation Voltage
74%-83%
3
3000 VDC min
9
Automatic Isolation Resistance
ENVIRONMENTAL SPECIFICATIONS
Operating Temperature
+/-10% max
10 ohms min
Isolation Capacitance
20pF max
Switching Frequency
100KHz max
4
>2,000,000 Hours
-55°C to +125°C Weight
2.1g Typ
-40°C to +85°C MTBF
95% max Case Material
Free-Air Convection Case Size
Non-Conductive Plastic
19.6mm*7.5mm*10.2mm
Conducted Emissions
EN55022 Class A
Radiated Emissions
EN55022 Class A
ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD , AND 25 OC UNLESS OTHERWISE NOTED.
1
2
3
4
Line Regulation is for a 1.0% change in input Voltage.
Load Regulation is for output load current change from 20% to 100%.
1500VDC for 10 seconds,3000VDC for 3 seconds.
MIL-HDBK-217F @25 °C , Ground Benign.
DANUBE
http://www.danube.com.tw
5-1
2012/11/21
SELECTION GUIDE
INPUT
MODEL
NUMBER
OUTPUT
OUTPUT
5
INPUT
VOLTAGE VOLTAGE CURRENT CURRENT(mA) EFF ISOLATION
(VDC)
(VDC)
(mA)
FULL
NO
LOAD
LOAD
6
PACKAGE
(VDC)
PUS-0505BS
5
5
200
256
38
78
3000
B
PUS-0509BS
5
9
111
253
38
79
3000
B
PUS-0512BS
5
12
84
253
39
79
3000
B
PUS-0515BS
5
15
67
251
39
80
3000
B
PUD-0505BS
5
+/-5
+/-100
256
40
78
3000
B
PUD-0512BS
5
+/-12
+/-42
253
40
79
3000
B
PUD-0515BS
5
+/-15
+/-34
251
40
80
3000
B
PUS-1205BS
12
5
200
108
15
77
3000
B
PUS-1209BS
12
9
111
105
15
79
3000
B
PUS-1212BS
12
12
84
105
14
80
3000
B
PUS-1215BS
12
15
67
103
14
81
3000
B
PUD-1205BS
12
+/-5
+/-100
106
15
78
3000
B
PUD-1212BS
12
+/-12
+/-42
105
14
80
3000
B
PUD-1215BS
12
+/-15
+/-34
103
14
81
3000
B
PUS-2405BS
24
5
200
54
8
77
3000
B
PUS-2409BS
24
9
111
53
7
78
3000
B
PUS-2412BS
24
12
84
53
7
79
3000
B
PUS-2415BS
24
15
67
52
7
80
3000
B
PUD-2405BS
24
+/-5
+/-100
53
8
78
3000
B
PUD-2412BS
24
+/-12
+/-42
53
7
79
3000
B
PUD-2415BS
24
+/-15
+/-34
53
7
80
3000
B
Note: Other input to output voltages may be available. Please contact factory.
5
6
NOMINAL INPUT VOLTAGE.
NOMINAL INPUT VOLTAGE, FULL LOAD.
DANUBE
5-2
2012/11/21
MECHANICAL DIMENSIONS &
RECOMMENDED FOOTPRINT DETAILS
PACKAGE ”B”
19.6[0.77]
FRONT
VIEW
PIN
SINGLE
DUAL
1
+Vin
+Vin
2
-Vin
-Vin
5
-Vout
-Vout
6
NP
COMMON
7
+Vout
+Vout
10.2[0.40]
3.81[0.15]
5.08[0.20]
2.54[0.10]
7.5[0.3]
NOTE : All Dimensions In mm(Inches)
BOTTOM VIEW
1 2
1. Pin Size is 0.50x0.30mm[0.02x0.01”]
5 6 7
2.18[0.086]
2. Pin is Tolerance .XX= ±0.05mm
3. Tolerance .X
1.2[0.05]
or
.XX= ±0.5mm
SINGLE
OUTPUT
TOP VIEW
1 2
5
DUAL
OUTPUT
2.54mm
TOP VIEW
7
1 2
2.54mm
2.54mm
All dimensions are in mm[inches]
2.54mm
5 6 7
SIMPLIFIED SCHEMATIC
SINGLE OUTPUT
DUAL OUTPUT
+Vin
+Vin
+Vout
OSCILLATOR
DRIVER
+Vout
OSCILLATOR
DRIVER
-Vout
COMMON
-Vin
-Vin
-Vout
TYPICAL APPLICATIONS
SINGLE OUTPUT
INPUT
OUTPUT
+Vin
DUAL OUTPUT
INPUT
+Vout
OUTPUT
+Vin
+Vout
LOAD1
DC-DC
CONVERTER
-Vin
-Vout
DANUBE
LOAD
Common
DC-DC
CONVERTER
-Vin
LOAD2
-Vout
5-3
2012/11/21
TYPICAL PERFORMANCE CURVES
Specifications typical at TA=25 °C,nominal input voltage , rated output current unless otherwise specified.
VOUT VS LOAD(+/-5Vout Models)
6.4
6.4
6.0
6.0
Vout(V)
Vout(V)
VOUT VS LOAD(5Vout Models)
5.6
5.6
5.2
5.2
4.8
4.8
100
150
200
Output Current(mA)
+/-25
+/-50
+/-75
+/-100
Output Current(mA)
VOUT VS LOAD(9Vout Models)
Vout(V)
10.4
10.0
9.6
9.2
8.8
56
84
111
Output Current(mA)
VOUT VS LOAD(+/- 12Vout Models)
13.5
13.5
13.0
13.0
Vout(V)
Vout(V)
VOUT VS LOAD(12Vout Models)
12.5
12.0
12.5
12.0
11.5
11.5
60
80
Output Current(mA)
+/-20
+/-30
+/-40
Output Current(mA)
VOUT VS LOAD(15Vout Models)
VOUT VS LOAD(+/- 15Vout Models)
16.5
16.5
16.0
16.0
Vout(V)
Vout(V)
+/-10
15.5
15.0
15.5
15.0
14.5
14.5
30
45
Output Current(mA)
DANUBE
60
+/-15
+/-22.5
+/-30
Output Current(mA)
5-4
2012/11/21
DERATING CURVE
EFFICIENCY VS LOAD
EFFICIENCY(%)
OUTPUT POWER(%)
125%
100%
75%
SAFE
OPERATING
AREA
50%
25%
80.0
60.0
40.0
20.0
0.0
-40
-20
60
80
60
80
100
100
% OF RATED LOAD(%)
TA(degree C)
INPUT FUSE SELECTION GUIDE
4.5-5.5V
10.8-13.2V
21.6-26.4V
INPUT VOLTAGE(VDC)
INPUT VOLTAGE(VDC)
INPUT VOLTAGE(VDC)
800mA Slow-Blow Type
300mA Slow-Blow Type
INPUT
150mA Slow-Blow Type
OUTPUT
Fuse
+Vin
+Vout
DC-DC
CONVERTER
-Vin
-Vout
Note: Certain applications may require the installation of external fuse in front of the input.
PU-S SERIES APPLICATION NOTES:
EXTERNAL CAPACITANCE REQUIREMENTS:
Output filtering is required for operation. A minimum of 10uF is needed. Output capacitance may be
increased for additional filtering, not to exceed 220uF.
To meet the reflected ripple requirements of the converter, an input impedance of less than 0.5ohm
from DC to 250KHz is required.
We Can Offer EMC-Filter According To EN55011/22 Class B.
Negative Outputs:
A negative output voltage may be obtained by connecting the +OUT to circuit ground and
connecting –OUT as the negative output.
FOR MORE INFORMATION CALL:
Danube Enterprise Co., Ltd.
Tel: 886-7-3755165
Fax: 886-7-3755330
Home Page
DANUBE
E-mail: danube@ms10.hinet.net
5-5
2012/11/21
很抱歉,暂时无法提供与“PUD-0515BS”相匹配的价格&库存,您可以联系我们找货
