电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
NUD-0505E1K
NUD-0505E1K
    DIWELL
    SMD10 模块
    隔离模块 直流转换器 2 输出 5V -5V 100mA,100mA 4.5V - 5.5V 输入
NUD-0505E1K 数据手册
NU-E1K SERIES 1W UNREGULATED FEATURES           UP TO 1W UNREGULATED OUTPUT POWER 100% BURN IN HIGH EFFICIENCY SMD TECHNOLOGY LOW COST UL 94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE MTBF>888,000 HOURS RoHS COMPLIANT 3 YEARS WARRANTY OUTPUT SPECIFICATIONS INPUT SPECIFICATIONS Voltage Set-point Accuracy +/-2% max. Input Voltage Range Temperature Coefficient +/-0.03%/°C Input Filter Capacitor Type 100mVp-p max. Protection Fuse Recommended Ripple & Noise(20MHz BW)1 2 Line Regulation Load Regulation3 Minimum Load Short Circuit Protection S-Suffix +/-1.2% max. +/-8% max. S-Suffix Storage Temperature GENERAL SPECIFICATIONS 10% of Full Load Efficiency 72%-82% Momentary Isolation Voltage4 3000 VDC min. Continuous Isolation Resistance 10 ohms min. ENVIRONMENTAL SPECIFICATIONS Operating Temperature +/-10% max. 9 Isolation Capacitance 80pF max. Switching Frequency 100KHz max. -40 °C to +85°C MTBF5 >880,000 Hours -40 °C to +100°C Weight 1.2g typ. -55°C to +125°C Case Material Humidity 95% max. Case Size Cooling Free-Air Convection Radiated Emissions Non-Conductive Plastic 15.24mm*11.1mm*7.1mm EN55032 Class B ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD , AND 25°C UNLESS OTHERWISE NOTED. 1 2 3 4 5 Measured with 1uF ceramic capacitor connect to the output pins. Line Regulation is for a 1.0% change in input Voltage. Load Regulation is for output load current change from 20% to 100%. For 3 seconds. MIL-HDBK-217F@25°C, Ground Benign. DANUBE http://www.danube.com.tw 1 2018/03/15  SELECTION GUIDE 1W 3000VDC ISOLATION INPUT MODEL NUMBER OUTPUT OUTPUT INPUT6 VOLTAGE VOLTAGE CURRENT CURRENT(mA) EFF (VDC) NUS-03.303.3E1K(S) (VDC) (mA) FULL NO LOAD LOAD ISOLATION PACKAGE (%)7 (VDC) 3.3 3.3 300 415 40 73 3000 E NUS-0503.3E1K(S) 5 3.3 300 267 30 75 3000 E NUS-0505E1K(S) 5 5 200 260 30 77 3000 E NUS-0512E1K(S) 5 12 84 257 30 78 3000 E NUS-0515E1K(S) 5 15 67 253 30 79 3000 E NUD-0505E1K(S) 5 +/-5 +/-100 260 30 77 3000 E NUD-0512E1K(S) 5 +/-12 +/-42 257 30 78 3000 E NUD-0515E1K(S) 5 +/-15 +/-34 253 30 79 3000 E NUS-1205E1K(S) 12 5 200 104 12 80 3000 E NUS-1212E1K(S) 12 12 84 103 12 81 3000 E NUS-1215E1K(S) 12 15 67 102 12 82 3000 E NUD-1205E1K(S) 12 +/-5 +/-100 104 12 80 3000 E NUD-1212E1K(S) 12 +/-12 +/-42 103 12 81 3000 E NUD-1215E1K(S) 12 +/-15 +/-34 102 12 82 3000 E NUS-2405E1K(S) 24 5 200 55 10 76 3000 E NUS-2412E1K(S) 24 12 84 55 10 76 3000 E NUS-2415E1K(S) 24 15 67 55 10 76 3000 E NUD-2405E1K(S) 24 +/-5 +/-100 55 10 76 3000 E NUD-2412E1K(S) 24 +/-12 +/-42 55 10 76 3000 E NUD-2415E1K(S) 24 +/-15 +/-34 55 10 76 3000 E Note: Other input to output voltages may be available. Please contact factory. 6 7 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 2 2018/03/15  MECHANICAL DIMENSIONS & RECOMMENDED FOOTPRINT DETAILS PACKAGE ”E” PIN SINGLE DUAL 1 -Vin -Vin 2 +Vin +Vin 3 NC NC 5 -Vout Com 6 NC -Vout 7 NC NC 8 +Vout +Vout 10 NC NC 11 NC NC 12 NC NC NOTE : All Dimensions are in mm [inches] 1. Pin Size is 0.50x0.30mm[0.02x0.01”] 2. Pin is Tolerance .XX= ±0.07mm 3. Tolerance .X or .XX= ±0.5mm DANUBE http://www.danube.com.tw 3 2018/03/15  REFLOW SOLDERING CURVE Remark:The curve applies only to the hot air reflow soldering.  SIMPLIFIED SCHEMATIC SINGLE OUTPUT DUAL OUTPUT +Vin +Vout OSCILLATOR DRIVER +Vin +Vout OSCILLATOR DRIVER -Vout -Vin COMMON -Vin -Vout  TYPICAL APPLICATIONS SINGLE OUTPUT INPUT DUAL OUTPUT OUTPUT +Vin +Vout INPUT OUTPUT +Vin +Vout LOAD1 DC-DC CONVERTER -Vin LOAD Common DC-DC CONVERTER -Vin -Vout LOAD2 -Vout  TYPICAL PERFORMANCE CURVES Specifications typical at ta=25 °C, nominal input voltage, rated output current unless otherwise specified. EFFICIENCY(%) OUTPUT LOAD VS EFFICIENCY TEMPERATURE DERATING 80.0 60.0 40.0 20.0 0.0 0 20 40 60 80 100 % OF RATED LOAD(%) DANUBE http://www.danube.com.tw 4 2018/03/15  INPUT FUSE SELECTION GUIDE 1W 3000VDC ISOLATION 4.5-5.5V 10.8-13.2V 21.6-26.4V INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) 750mA Slow-Blow Type 300mA Slow-Blow Type INPUT 150mA Slow-Blow Type OUTPUT +Vin +Vout Fuse DC-DC CONVERTER -Vi n -Vout Note: Certain applications may require the installation of external fuse in front of the input. NU-E1K SERIES APPLICATION NOTES: EXTERNAL CAPACITANCE REQUIREMENTS: Output filtering is required for operation. A minimum of 10uF is needed. Output capacitance may be increased for additional filtering, not to exceed 220uF. To meet the reflected ripple requirements of the converter, an input impedance of less than 0.5 ohm from DC to 250KHz is required. We Can Offer EMC-Filter According To EN55032 Class B. Negative Outputs: A negative output voltage may be obtained by connecting the +OUT to circuit ground and connecting –OUT as the negative output. FOR MORE INFORMATION CALL: Danube Enterprise Co., Ltd. Tel: 886-7-3755165 Fax: 886-7-3755330 Home Page http://www.danube.com.tw DANUBE E-mail: danube@ms10.hinet.net http://www.danube.com.tw 5 2018/03/15
NUD-0505E1K 价格&库存
很抱歉,暂时无法提供与“NUD-0505E1K”相匹配的价格&库存,您可以联系我们找货
