KWS-2405-3K
KWS-2405-3K
    DIWELL
    DIP4 模块
    隔离模块 直流转换器 1 输出 5V 3A 18V - 36V 输入
KWS-2405-3K 数据手册
KW SERIES 15W WIDE INPUT RANGE FEATURES            15W DIL PACKAGE INDUSTRY STANDARD PACKAGE 9-18V,18-36V,36-72V,9-27V,18-54V, 9-36V,18-72V WIDE INPUT RANGE NO EXTERNAL COMPONENTS REQUIRED REGULATED OUTPUT 100% BURN IN HIGH EFFICIENCY UL 94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE RoHS COMPLIANT 3 YEARS WARRANTY OUTPUT SPECIFICATIONS INPUT SPECIFICATIONS Voltage Setpoint Accuracy +/-2% max Input Voltage Range 2:1 3:1 4:1 Input Range ° Temperature Coefficient 1 Ripple & Noise(20MHz BW) 2 Line Regulation +/-0.05%/ C Input Filter Pi Network 100mVp-p max Protection Fuse Recommended +/-0.5% max 3 Load Regulation GENERAL SPECIFICATIONS +/-0.5% max Efficiency 70% min 4 Minimum Load 10% of Full Load Isolation Voltage Short Circuit Protection Continuous 1500 VDC min Standard Models 3000 VDC min Suffix “3K” Models 9 Short Circuit Restart Automatic Isolation Resistance Over Load Protection 180% Typ Isolation Capacitance 550pF max 200uS max Switching Frequency 150 KHz min 5 Transient Response 10 ohms min 6 MTBF >320,000 Hours Weight ENVIRONMENTAL SPECIFICATIONS Operating Temperature Operating Temperature Case Storage Temperature Humidity Cooling Case Material 60.0g Typ Six-Side Shielded Case ° ° 50.8mm*50.8mm*11mm ° ° Epoxy(UL94-V0) ° EN55022 Class A -25 C to +71 C Case Size -25 C to +90 C Potting Material ° -55 C to +125 C Conducted Emissions 95% max Radiated Emissions EN55022 Class A Free-Air Convection ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD , AND 25 ° C UNLESS OTHERWISE NOTED. 1 Measured with 1uF ceramic capacitor connect to the output pins. High Line to Low Line. 3 Load Regulation is for output load current change from 10% to 100%. 4 1500VDC for 10 seconds,3000VDC for 3 seconds. 5 25% Step Load Change. 6 MIL-HDBK-217F @25 °C , Ground Benign. 2 DANUBE http://www.danube.com.tw 1 2013/07/01  SELECTION GUIDE(1) 2:1 12W-15W OUTPUT 1 MODEL NUMBER INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) INPUT CURRENT(mA) EFF CAPACITOR FULL NO (%)2 LOAD MAX. LOAD LOAD KWS-1203.3(-3K) 9-18 3.3 3600 1320 40 75 2700uF KWS-1205(-3K) 9-18 5 3000 1623 40 77 2700uF KWS-1209(-3K) 9-18 9 1670 1580 30 79 2200uF KWS-1212(-3K) 9-18 12 1250 1563 40 80 1800uF KWS-1215(-3K) 9-18 15 1000 1545 38 81 1500uF KWS-1224(-3K) 9-18 24 625 1543 38 81 1000uF KWD-1205(-3K) 9-18 +/-5 +/-1500 1623 40 77 +/-1200uF KWD-1212(-3K) 9-18 +/-12 +/-625 1563 40 80 +/-820uF KWD-1215(-3K) 9-18 +/-15 +/-500 1525 38 82 +/-680uF KWD-1224(-3K) 9-18 +/-24 +/-313 1510 40 83 +/-560uF KWS-2403.3(-3K) 18-36 3.3 3600 643 20 77 2700uF KWS-2405(-3K) 18-36 5 3000 780 20 80 2700uF KWS-2409(-3K) 18-36 9 1670 770 20 81 2200uF KWS-2412(-3K) 18-36 12 1250 762 18 82 1800uF KWS-2415(-3K) 18-36 15 1000 762 18 82 1500uF KWS-2424(-3K) 18-36 24 625 753 18 83 1000uF KWS-2427(-3K) 18-36 27 556 749 21 83 820uF KWD-2405(-3K) 18-36 +/-5 +/-1500 750 20 83 +/-1200uF KWD-2412(-3K) 18-36 +/-12 +/-625 762 18 82 +/-820uF KWD-2415(-3K) 18-36 +/-15 +/-500 753 25 83 +/-680uF KWD-2424(-3K) 18-36 +/-24 +/-313 750 35 83 +/-560uF KWS-4803.3(-3K) 36-72 3.3 3600 321 10 77 660uF KWS-4805(-3K) 36-72 5 3000 396 10 79 660uF KWS-4809(-3K) 36-72 9 1670 385 10 81 470uF KWS-4812(-3K) 36-72 12 1250 381 9 82 470uF KWS-4815(-3K) 36-72 15 1000 381 9 82 470uF KWS-4824(-3K) 36-72 24 625 375 9 83 330uF KWD-4805(-3K) 36-72 +/-5 +/-1500 375 10 83 +/-100uF KWD-4812(-3K) 36-72 +/-12 +/-625 381 9 82 +/-100uF KWD-4815(-3K) 36-72 +/-15 +/-500 381 17 82 +/-100uF KWD-4824(-3K) 36-72 +/-24 +/-313 375 9 83 +/-100uF Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: 1 2 KW*-****-3K(Isolation Voltage For 3000VDC) NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE,FULL LOAD. DANUBE http://www.danube.com.tw 2 2013/07/01  SELECTION GUIDE(2) 3:1 15W OUTPUT 3 MODEL NUMBER INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) INPUT CURRENT(mA) EFF CAPACITOR FULL NO (%) LOAD LOAD 4 LOAD MAX. KWS-1205G(-3K) 9-27 5 3000 1623 40 77 2700uF KWS-1209G(-3K) 9-27 9 1670 1600 30 78 2200uF KWS-1212G(-3K) 9-27 12 1250 1562 40 80 1800uF KWS-1215G(-3K) 9-27 15 1000 1562 38 80 1500uF KWS-1224G(-3K) 9-27 24 625 1562 28 80 1000uF KWD-1205G(-3K) 9-27 +/-5 +/-1500 1623 40 77 +/-1200uF KWD-1212G(-3K) 9-27 +/-12 +/-625 1562 40 80 +/-820uF KWD-1215G(-3K) 9-27 +/-15 +/-500 1562 38 80 +/-680uF KWS-2405G(-3K) 18-54 5 3000 791 20 79 2700uF KWS-2409G(-3K) 18-54 9 1670 782 20 80 2200uF KWS-2412G(-3K) 18-54 12 1250 771 18 81 1800uF KWS-2415G(-3K) 18-54 15 1000 762 18 82 1500uF KWS-2424G(-3K) 18-54 24 625 762 15 82 1000uF KWD-2405G(-3K) 18-54 +/-5 +/-1500 791 20 79 +/-1200uF KWD-2412G(-3K) 18-54 +/-12 +/-625 771 18 81 +/-820uF KWD-2415G(-3K) 18-54 +/-15 +/-500 762 18 82 +/-560uF Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: 3 4 KW*-*****-3K(Isolation Voltage For 3000VDC) NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE,FULL LOAD. DANUBE http://www.danube.com.tw 3 2013/07/01  SELECTION GUIDE(3) 4:1 15W OUTPUT 5 MODEL NUMBER INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) INPUT CURRENT(mA) EFF CAPACITOR FULL NO (%) LOAD LOAD 6 LOAD MAX. KWS-1203.3TA 9-36 3.3 4000 1430 40 77 2700uF KWS-1205T(-3K) 9-36 5 3000 1623 40 77 2700uF KWS-1209T(-3K) 9-36 9 1670 1600 30 78 2200uF KWS-1212T(-3K) 9-36 12 1250 1562 40 80 1800uF KWS-1215T(-3K) 9-36 15 1000 1562 38 80 1500uF KWS-1224T(-3K) 9-36 24 625 1562 28 80 1000uF KWD-1205T(-3K) 9-36 +/-5 +/-1500 1623 40 77 +/-1200uF KWD-1212T(-3K) 9-36 +/-12 +/-625 1562 40 80 +/-820uF KWD-1215T(-3K) 9-36 +/-15 +/-500 1562 38 80 +/-680uF KWS-2405T(-3K) 18-72 5 3000 791 20 79 2700uF KWS-2409T(-3K) 18-72 9 1670 782 20 80 2200uF KWS-2412T(-3K) 18-72 12 1250 771 18 81 1800uF KWS-2415T(-3K) 18-72 15 1000 762 18 82 1500uF KWS-2424T(-3K) 18-72 24 625 780 18 80 1000uF KWD-2405T(-3K) 18-72 +/-5 +/-1500 791 20 79 +/-1200uF KWD-2412T(-3K) 18-72 +/-12 +/-625 771 18 81 +/-820uF KWD-2415T(-3K) 18-72 +/-15 +/-500 762 18 82 +/-680uF Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: KW*-*****-3K(Isolation Voltage For 3000VDC) KWS-1203.3A(PACKAGE “A” For REMOTE CONTROL) 5 6 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE,FULL LOAD. DANUBE http://www.danube.com.tw 4 2013/07/01  SIMPLIFIED SCHEMATIC SINGLE OUTPUT DUAL OUTPUT +Vin +Vout +Vin +Vout Common -Vout -Vout -Vin -Vin PWM CONTROLLER REFERENCE & ERROR AMP ISOLATION PWM CONTROLLER ISOLATION REFERENCE & ERROR AMP  MECHANICAL DIMENSIONS & RECOMMENDED FOOTPRINT DETAILS 11[0.43] 50.8[2.00] 22.82[0.90] PIN SINGLE DUAL 1 +Vin +Vin 2 -Vin -Vin 4 3 +Vout +Vout 5 4 NO PIN Common 5 -Vout -Vout BOTTOM VIEW SIDE VIEW 3 50.8[2.00] 1 2 5.12[0.20] 10.2[0.40] 15.2[0.60] 20.32[0.80] All dimensions are in millimeters[inches] 5.8[0.23] TOP VIEW 5 2 1 4 3 GRID : 2.54mm DANUBE http://www.danube.com.tw 5 2013/07/01  TYPICAL APPLICATIONS SINGLE OUTPUT INPUT OUTPUT +Vin DUAL OUTPUT INPUT OUTPUT +Vout +Vin +Vout LOAD1 DC-DC CONVERTER LOAD DC-DC CONVERTER -Vin Common -Vin -Vout LOAD2 -Vout  TYPICAL PERFORMANCE CURVES Specifications typical at Ta=25 °C ,nominal input voltage , rated output current unless otherwise specified. 80.0 60.0 40.0 20.0 0.0 0 20 40 60 80 100 TEMPERATURE DERATING OUTPUT POWER(W) EFFICIENCY(%) OUTPUT LOAD VS EFFICIENCY 15.0 12.0 SAFE 9.0 OPERATING 6.0 AREA 3.0 0.0 -25 % OF RATED LOAD(%) 0 25 50 70 90 TA(degre e C)  INPUT FUSE SELECTION GUIDE 9-18V or 9-27V or 9-36V 18-36V or 18-54V or 18-72V 36-72V INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) 3000mA Slow-Blow Type 1500mA Slow-Blow Type 750mA Slow-Blow Type INPUT OUTPUT Fuse +Vin +Vout DC-DC CONVERTER -Vin -Vout Note: Certain applications may require the installation of external fuse in front of the input. DANUBE http://www.danube.com.tw 6 2013/07/01 KW SERIES APPLICATION NOTES: EXTERNAL CAPACITANCE REQUIREMENTS: No external capacitance is required for operation of the KW series. To meet the reflected ripple requirements of the converter, an input impedance of less than 0.5 ohm from DC to 220KHz is required. External output capacitance is not required for operation, however it is recommended that 10uF tantalum and 0.1uF ceramic capacitance be selected for reduced system noise. Additional output capacitance may be added for increased filtering, but should not exceed 1000uF. We Can Offer EMC-Filter According To EN55011/22 Class B. Negative Outputs: A negative output voltage may be obtained by connecting the +OUT to circuit ground and connecting –OUT as the negative output. FOR MORE INFORMATION CALL: Danube Enterprise Co., Ltd. Tel: 886-7-3755165 Fax: 886-7-3755330 Home Page http://www.danube.com.tw DANUBE E-mail: danube@ms10.hinet.net http://www.danube.com.tw 7 2013/07/01
KWS-2405-3K 价格&库存
很抱歉,暂时无法提供与“KWS-2405-3K”相匹配的价格&库存,您可以联系我们找货
