CWS-2405A12M
CWS-2405A12M
    DIWELL
    DIP8 模块
    隔离模块 直流转换器 1 输出 5V 2.4A 18V - 36V 输入
CWS-2405A12M 数据手册
CW SERIES 10W ~ 12W WIDE INPUT RANGE FEATURES   10W ~ 12W DIL PACKAGE 9-18V,18-36V,36-75V WIDE INPUT RANGE   100% BURNED IN HIGH EFFICIENCY    UL94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE RoHS COMPLIANT  3 YEARS WARRANTY OUTPUT SPECIFICATIONS INPUT SPECIFICATIONS +/-2% max Input Voltage Range Voltage Setpoint Accuracy Temperature Coefficient 1 Ripple & Noise(20MHz BW) 2 Line Regulation 2:1 Input Range +/-0.05%/°C Input Filter Pi Network 100mVp-p max Protection Fuse Recommended +/-0.5% max 3 Load Regulation +/-0.5% max Output: 2.5V , 3.3V GENERAL SPECIFICATIONS +/-1% max Efficiency 78% min 4 Minimum Load 20% of Full Load Isolation Voltage Short Circuit Protection Short Circuit Restart Over Load Protection 5 Transient Response 1500VDC min 9 Continuous Isolation Resistance 10 ohms min Automatic Isolation Capacitance 2200pF max 110%~180% Switching Frequency 400KHz Typ 6 350uS max MTBF >600,000 Hours Weight ENVIRONMENTAL SPECIFICATIONS 18.5g Typ Case Material Operating Temperature -40°C to +85°C Case Size Case Temperature (with derating) Potting Material +95°C max Conducted Emissions Storage Temperature Humidity Cooling Five-Side Shielded Case 31.8mm*20.3mm*12.2mm Epoxy (UL94V-0) EN55022 Class A -55°C to +105°C Radiated Emissions EN55022 Class A 95% max Remote On/Off Free-Air Convection -ON 3.0…12V/DC or open circuit (referenced to-Vin) -Off 0…1.2V/DC or short circuit pin 1 and pin 2/3 -Off idle current 2.5mA ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD , AND 25 °C UNLESS OTHERWISE NOTED. 1 2 3 4 5 6 Measured with 1uF ceramic capacitor connect to the output pins. High Line to Low Line. Load Regulation is for output load current change from 20% to 100%. 1500VDC for 10 seconds. 25% Step Load Change. MIL-HDBK-217F @25 °C , Ground Benign. DANUBE http://www.danube.com.tw 1 2012/09/18  SELECTION GUIDE(1) 2:1 10W~12W OUTPUT 7 MODEL NUMBER INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT INPUT8 CURRENT(mA) EFF FULL NO (%) 9 PACKAGE Capacitor Load max (VDC) (VDC) (mA) CWS-1202.5A10M 9-18 2.5 3000 802 70 78 A 1000uF CWS-1203.3A10M 9-18 3.3 3000 1025 70 80 A 1000uF CWS-1205A12M 9-18 5 2400 1190 70 84 A 1000uF CWS-1212A12M 9-18 12 1000 1204 70 83 A 220uF CWS-1215A12M 9-18 15 800 1204 70 83 A 220uF CWD-1205A12M 9-18 +/-5 +/-1200 1235 70 81 A +/-670uF CWD-1212A12M 9-18 +/-12 +/-500 1190 70 84 A +/-100uF CWD-1215A12M 9-18 +/-15 +/-400 1204 70 83 A +/-47uF CWS-2402.5A10M 18-36 2.5 3000 401 35 78 A 1000uF CWS-2403.3A10M 18-36 3.3 3000 513 35 80 A 1000uF CWS-2405A12M 18-36 5 2400 602 35 83 A 1000uF CWS-2412A12M 18-36 12 1000 602 35 83 A 220uF CWS-2415A12M 18-36 15 800 590 35 85 A 220uF CWD-2405A12M 18-36 +/-5 +/-1200 618 35 81 A +/-670uF CWD-2412A12M 18-36 +/-12 +/-500 595 35 84 A +/-100uF CWD-2415A12M 18-36 +/-15 +/-400 595 35 84 A +/-47uF CWS-4802.5A10M 36-75 2.5 3000 201 25 78 A 1000uF CWS-4803.3A10M 36-75 3.3 3000 252 25 83 A 1000uF CWS-4805A12M 36-75 5 2400 298 25 84 A 1000uF CWS-4812A12M 36-75 12 1000 301 25 83 A 220uF CWS-4815A12M 36-75 15 800 294 25 85 A 220uF CWD-4805A12M 36-75 +/-5 +/-1200 309 25 81 A +/-670uF CWD-4812A12M 36-75 +/-12 +/-500 298 25 84 A +/-100uF CWD-4815A12M 36-75 +/-15 +/-400 298 25 84 A +/-47uF LOAD LOAD Note: Other input to output voltages may be available. Please contact factory. 7 CW*-*****A12M AND CW*-*****A10M (Isolation For 1500 VDC) 8 NOMINAL INPUT VOLTAGE. 9 NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 2 2012/09/18  MECHANICAL DIMENSIONS PACKAGE "A" 20.3[0.80] 23 22 2.54[0.10] PIN SINGLE DUAL 1 Remote On/Off Remote On/Off 2&3 -Vin -Vin 9 NC Common 1 2 3 BOTTOM VIEW SIDE VIEW 31.8[1.25] 16 9 11 NC -Vout 14 11 14 +Vout +Vout 16 -Vout Common 22 & 23 +Vin +Vin 12.2[0.48] 15.24[0.60] 5.08[0.20] NOTE: 3.81[0.15] Pin Size is Tolerance 0.6Φ ²0.05mm All Dimensions In mm(Inches) All dimensions are in mm[inches] Tolerance .X or .XX= ²0.5mm Remote On/Off Control Control Input PIN1 Control Common Control Voltage ON Converter Shutdown Idle Current >+2.5VDC or Open Circuit 10mA CMOS or Open Logic Compatibility OFF PIN2&PIN3
CWS-2405A12M 价格&库存
很抱歉,暂时无法提供与“CWS-2405A12M”相匹配的价格&库存,您可以联系我们找货
