FAWS-2405
FAWS-2405
    DIWELL
    DIP4 模块
    隔离模块 直流转换器 1 输出 5V 2A 18V - 36V 输入
FAWS-2405 数据手册
FAW SERIES 10W WIDE INPUT RANGE FEATURES            10W DIL PACKAGE INDUSTRY STANDARD PACKAGE 9-18V,18-36V,36-72V,9-27V,18-54V, 9-36V,18V-72V WIDE INPUT RANGE SHORT CIRCUIT PROTECTION REGULATED OUTPUT 100% BURN IN HIGH EFFICIENCY UL 94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE RoHS COMPLIANT 3 YEARS WARRANTY OUTPUT SPECIFICATIONS Voltage Setpoint Accuracy Temperature Coefficient Ripple & Noise(20MHz BW) Line Regulation 1 2 Load Regulation INPUT SPECIFICATIONS +/-2% max Input Voltage Range Pi Network 100mVp-p max Protection Fuse Recommended +/-0.5% max 3 2:1 3:1 4:1 Input Range +/-0.05%/°C Input Filter GENERAL SPECIFICATIONS +/-0.5% max Efficiency Minimum Load 10% of Full Load Isolation Voltage Short Circuit Protection 70% min 4 Continuous 1500 VDC min Standard Models 3000 VDC min Suffix “3K” Models 9 Short Circuit Restart Automatic Isolation Resistance Over Load Protection 180% Typ Isolation Capacitance 500pF max 200uS max Switching Frequency 200 KHz min Transient Response 5 10 ohms min 6 >342,000 Hours Weight 31.2g Typ MTBF ENVIRONMENTAL SPECIFICATIONS Operating Temperature Storage Temperature Humidity Cooling Case Material ° ° -25 C to +71 C Case Size Six-Side Shielded Case 50.8mm*25.4mm*11.2mm -55°C to +125°C Potting Material Epoxy(UL94-V0) 95% max Conducted Emissions EN55022 Class A Free-Air Convection Radiated Emissions EN55022 Class A REMOTE CONTROL ON Suffix “A” Models 2.5 to 5.5Vdc or open circuit OFF 0 to 0.8Vdc ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD , AND 25 °C UNLESS OTHERWISE NOTED. 1 2 3 4 5 6 Measured with 1uF ceramic capacitor connect to the output pins. High Line to Low Line. Load Regulation is for output load current change from 10% to 100%. 1500VDC for 10 seconds,3000VDC for 3 seconds. 25% Step Load Change. MIL-HDBK-217F @25°C , Ground Benign. DANUBE http://www.danube.com.tw 1 2013/10/29  SELECTION GUIDE(1) 2:1 7W-10W OUTPUT 7 INPUT MODEL NUMBER OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) INPUT CURRENT(mA) EFF CAPACITOR FULL NO (%) LOAD LOAD 8 LOAD MAX. FAWS-1203.3(A)(-3K) 9-18 3.3 2400 891 30 74 2700uF FAWS-1205(A)(-3K) 9-18 5 2000 1068 30 78 2700uF FAWS-1209(A)(-3K) 9-18 9 1111 1046 30 80 2200uF FAWS-1212(A)(-3K) 9-18 12 830 1040 28 80 1800uF FAWS-1215(A)(-3K) 9-18 15 670 1020 28 81 1500uF FAWS-1224(A)(-3K) 9-18 24 416 1020 28 82 1000uF FAWD-1205(A)(-3K) 9-18 +/-5 +/-1000 1068 30 78 +/-1200uF FAWD-1209(A)(-3K) 9-18 +/-9 +/-556 1046 30 80 +/-1000uF FAWD-1212(A)(-3K) 9-18 +/-12 +/-416 1029 40 81 +/-820uF FAWD-1215(A)(-3K) 9-18 +/-15 +/-333 1020 45 82 +/-680uF FAWD-1224(A)(-3K) 9-18 +/-24 +/-208 1052 45 79 +/-560uF FAWS-2403.3(A)(-3K) 18-36 3.3 2400 434 16 76 2700uF FAWS-2405(A)(-3K) 18-36 5 2000 527 25 79 2700uF FAWS-2409(A)(-3K) 18-36 9 1111 523 20 80 2200uF FAWS-2412(A)(-3K) 18-36 12 830 508 22 82 1800uF FAWS-2415(A)(-3K) 18-36 15 670 502 30 83 1500uF FAWS-2424(A)(-3K) 18-36 24 416 515 28 81 1000uF FAWS-2442(A)(-3K) 18-36 42 238 527 15 79 560uF FAWD-2405(A)(-3K) 18-36 +/-5 +/-1000 527 23 79 +/-1200uF FAWD-2409(A)(-3K) 18-36 +/-9 +/-556 523 18 80 +/-1000uF FAWD-2412(A)(-3K) 18-36 +/-12 +/-416 508 30 82 +/-820uF FAWD-2415(A)(-3K) 18-36 +/-15 +/-333 510 25 82 +/-680uF FAWD-2424(A)(-3K) 18-36 +/-24 +/-208 520 20 80 +/-560uF Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: FAW*-****A(PACKAGE “A” For REMOTE CONTROL) FAW*-*****-3K(Isolation Voltage For 3000VDC) 7 8 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE,FULL LOAD. DANUBE http://www.danube.com.tw 2 2013/10/29  SELECTION GUIDE(2) 2:1 8W-10W OUTPUT 9 INPUT MODEL NUMBER OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) INPUT CURRENT(mA) EFF CAPACITOR FULL NO (%) LOAD LOAD 10 LOAD MAX. FAWS-4803.3(A)(-3K) 36-72 3.3 2400 217 20 76 1000uF FAWS-4805(A)(-3K) 36-72 5 2000 264 20 79 1000uF FAWS-4809(A)(-3K) 36-72 9 1111 254 20 80 470uF FAWS-4812(A)(-3K) 36-72 12 830 254 20 82 330uF FAWS-4815(A)(-3K) 36-72 15 670 254 20 82 330uF FAWS-4824(A)(-3K) 36-72 24 416 264 20 82 330uF FAWD-4805(A)(-3K) 36-72 +/-5 +/-1000 262 20 79 +/-470uF FAWD-4809(A)(-3K) 36-72 +/-9 +/-556 254 20 80 +/-220uF FAWD-4812(A)(-3K) 36-72 +/-12 +/-416 254 20 82 +/-100uF FAWD-4815(A)(-3K) 36-72 +/-15 +/-333 257 20 81 +/-100uF FAWD-4824(A)(-3K) 36-72 +/-24 +/-208 254 20 82 +/-100uF Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: FAW*-****A(PACKAGE “A” For REMOTE CONTROL) FAW*-*****-3K(Isolation Voltage For 3000VDC) 9 10 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE,FULL LOAD. DANUBE http://www.danube.com.tw 3 2013/10/29  SELECTION GUIDE(3) 3:1 8W-10W OUTPUT 11 INPUT MODEL NUMBER OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) INPUT CURRENT(mA) EFF CAPACITOR FULL NO (%) LOAD LOAD 12 LOAD MAX. FAWS-1203.3G(A)(-3K) 9-27 3.3 2400 880 40 76 2700uF FAWS-1205G(A)(-3K) 9-27 5 2000 1082 40 77 2700uF FAWS-1209G(A)(-3K) 9-27 9 1111 1065 40 78 2200uF FAWS-1212G(A)(-3K) 9-27 12 830 1054 40 79 1800uF FAWS-1215G(A)(-3K) 9-27 15 670 1041 40 80 1500uF FAWS-1224G(A)(-3K) 9-27 24 417 1057 40 79 1000uF FAWD-1205G(A)(-3K) 9-27 +/-5 +/-1000 1082 40 77 +/-1200uF FAWD-1209G(A)(-3K) 9-27 +/-9 +/-556 1068 40 78 +/-1000uF FAWD-1212G(A)(-3K) 9-27 +/-12 +/-416 1041 40 80 +/-820uF FAWD-1215G(A)(-3K) 9-27 +/-15 +/-333 1028 40 81 +/-680uF FAWS-2403.3G(A)(-3K) 18-54 3.3 2400 434 20 76 2700uF FAWS-2405G(A)(-3K) 18-54 5 2000 527 20 79 2700uF FAWS-2409G(A)(-3K) 18-54 9 1111 515 20 81 2200uF FAWS-2412G(A)(-3K) 18-54 12 830 520 20 80 1800uF FAWS-2415G(A)(-3K) 18-54 15 670 514 20 81 1500uF FAWS-2424G(A)(-3K) 18-54 24 416 510 20 81 1000uF FAWD-2405G(A)(-3K) 18-54 +/-5 +/-1000 527 20 79 +/-1200uF FAWD-2409G(A)(-3K) 18-54 +/-9 +/-556 526 20 79 +/-1000uF FAWD-2412G(A)(-3K) 18-54 +/-12 +/-416 520 20 80 +/-820uF FAWD-2415G(A)(-3K) 18-54 +/-15 +/-333 514 20 81 +/-560uF Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: FAWS-1005A(PACKAGE “A1” For REMOTE CONTROL) FAW*-****A(PACKAGE “A” For REMOTE CONTROL) FAW*-*****-3K(Isolation Voltage For 3000VDC) 11 12 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE,FULL LOAD. DANUBE http://www.danube.com.tw 4 2013/10/29  SELECTION GUIDE(4) 4:1 8W-10W OUTPUT INPUT MODEL NUMBER VOLTAGE OUTPUT VOLTAG (VDC) E (VDC) 13 OUTPUT CURRENT (mA) INPUT CURRENT(mA) EFF CAPACITOR FULL NO (%) LOAD LOAD 14 LOAD MAX. FAWS-1203.3T(A)(-3K) 9-36 3.3 2400 880 40 76 2700uF FAWS-1205T(A)(-3K) 9-36 5 2000 1082 40 77 2700uF FAWS-1209T(A)(-3K) 9-36 9 1111 1065 40 78 2200uF FAWS-1212T(A)(-3K) 9-36 12 830 1054 40 79 1800uF FAWS-1215T(A)(-3K) 9-36 15 670 1041 40 80 1500uF FAWS-1224T(A)(-3K) 9-36 24 417 1057 40 79 1000uF FAWD-1205T(A)(-3K) 9-36 +/-5 +/-1000 1082 40 77 +/-1200uF FAWD-1209T(A)(-3K) 9-36 +/-9 +/-556 1063 40 78 +/-1000uF FAWD-1212T(A)(-3K) 9-36 +/-12 +/-416 1041 40 80 +/-820uF FAWD-1215T(A)(-3K) 9-36 +/-15 +/-333 1028 40 81 +/-680uF FAWS-2403.3T(A)(-3K) 18-72 3.3 2400 434 20 76 2700uF FAWS-2405T(A)(-3K) 18-72 5 2000 527 20 79 2700uF FAWS-2409T(A)(-3K) 18-72 9 1111 515 20 81 2200uF FAWS-2412T(A)(-3K) 18-72 12 830 520 20 80 1800uF FAWS-2415T(A)(-3K) 18-72 15 670 514 20 81 1500uF FAWS-2424T(A)(-3K) 18-72 24 417 510 20 81 1000uF FAWD-2405T(A)(-3K) 18-72 +/-5 +/-1000 527 20 79 +/-1200uF FAWD-2409T(A)(-3K) 18-72 +/-9 +/-556 525 20 79 +/-1000uF FAWD-2412T(A)(-3K) 18-72 +/-12 +/-416 520 20 80 +/-820uF FAWD-2415T(A)(-3K) 18-72 +/-15 +/-333 514 20 81 +/-680uF Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: FAW*-****A(PACKAGE “A” For REMOTE CONTROL) FAW*-*****-3K(Isolation Voltage For 3000VDC) 13 14 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE,FULL LOAD. DANUBE http://www.danube.com.tw 5 2013/10/29  MECHANICAL DIMENSIONS & RECOMMENDED FOOTPRINT DETAILS PIN SINGLE DUAL 1 +Vin +Vin 2 -Vin -Vin 3 +Vout +Vout 4 NO PIN Common 5 -Vout -Vout NOTE: Pin Size is Tolerance 1.0Φ ±0.10mm All Dimensions In mm(Inches) Tolerance .X TOP VIEW or .XX= ±0.80mm GRID : 2.54mm 5 2 1 4 3  MECHANICAL DIMENSIONS & RECOMMENDED FOOTPRINT DETAILS REMOTE CONTROL (Standard Models) PACKAGE ”A” PIN SINGLE DUAL 1 +Vin +Vin 2 -Vin -Vin 3 +Vout +Vout 4 NO PIN Common 5 -Vout -Vout 6 Remote ON/OFF NOTE: Pin Size is Tolerance 1.00Φ ±0.10mm All Dimensions In mm(Inches) Tolerance .X DANUBE or .XX= ±0.80mm http://www.danube.com.tw 6 2013/10/29  MECHANICAL DIMENSIONS & RECOMMENDED FOOTPRINT DETAILS REMOTE CONTROL (Specially Models) PACKAGE ”A1” SIDE VIEW 11.27[0.44] 5.8[0.23] 20.32[0.80] 15.24[0.60] 3 5.08[0.20] 10.2[0.40] 1 BOTTOM 4 2 VIEW 20.4[0.80] 7.62[0.30] 25.4[1.00] 5 6 PIN SINGLE 1 +Vin 2 -Vin 3 +Vout 4 NO PIN 5 -Vout 6 Remote ON/OFF NOTE: 50.8[2.00] Pin Size is Tolerance 1.00Φ ±0.10mm All Dimensions In mm(Inches) All dimensions are in millimeters[inches] Tolerance .X or .XX= ±0.80mm  TYPICAL APPLICATIONS SINGLE OUTPUT INPUT DUAL OUTPUT OUTPUT +Vin INPUT +Vout OUTPUT +Vin +Vout LOAD1 DC-DC CONVERTER LOAD DC-DC CONVERTER -Vin Common -Vin -Vout LOAD2 -Vout  SIMPLIFIED SCHEMATIC SINGLE OUTPUT +Vin DUAL OUTPUT +Vout +Vin +Vout Common -Vout -Vout -Vin -Vin PWM CONTROLLER ISOLATION DANUBE REFERENCE & ERROR AMP PWM CONTROLLER ISOLATION http://www.danube.com.tw REFERENCE & ERROR AMP 7 2013/10/29  TYPICAL PERFORMANCE CURVES Specifications typical at Ta=25 OC, nominal input voltage , rated output current unless otherwise specified. OUTPUT LOAD VS EFFICIENCY TEMPERATURE DERATING OUTPUT POWER(W) EFFICIENCY(%) 10.0 80.0 60.0 40.0 20.0 0.0 0 20 40 60 80 100 8.0 SAFE 6.0 OPERATING 4.0 AREA 2.0 0.0 -25 0 % OF RATED LOAD(%) 25 50 70 90 TA(degree C)  INPUT FUSE SELECTION GUIDE 4.7-7.25V 9-18V or 9-27V or 9-36V 18-36V or 18-54V or 18-72V 36-72V INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) 2000mA Slow-Blow Type 900mA Slow-Blow Type 450mA Slow-Blow Type 3800mA Slow-Blow Type INPUT OUTPUT Fuse +Vin +Vout DC-DC CONVERTER -Vin -Vout Note: Certain applications may require the installation of external fuse in front of the input. FAW SERIES APPLICATION NOTES: EXTERNAL CAPACITANCE REQUIREMENTS: No external capacitance is required for operation of the FAW series. To meet the reflected ripple requirements of the converter, an input impedance of less than 0.5 ohm from DC to 220KHz is required. External output capacitance is not required for operation, however it is recommended that 10uF tantalum and 0.1uF ceramic capacitance be selected for reduced system noise. Additional output capacitance may be added for increased filtering, but should not exceed 1000uF. We Can Offer EMC-Filter According To EN55011/22 Class B. Negative Outputs: A negative output voltage may be obtained by connecting the +OUT to circuit ground and connecting –OUT as the negative output. FOR MORE INFORMATION CALL: Danube Enterprise Co., Ltd. Tel: 886-7-3755165 Fax: 886-7-3755330 Home Page http://www.danube.com.tw DANUBE E-mail: danube@ms10.hinet.net http://www.danube.com.tw 8 2013/10/29 Additional Information : 한국 총판점 : ㈜디웰전자 (Diwell Electronics Co., Ltd.) Phone : 070-8235-0820 (+82-70-8235-0820) Fax : 031-429-0821 (+82-31-429-0821) Homepage: http:// www.diwell.com http:// www.diwellshop.com 기술 및 구매 문의 email : expoeb2@diwell.com, dsjeong@diwell.com http:// www.diwell.com
FAWS-2405 价格&库存
很抱歉,暂时无法提供与“FAWS-2405”相匹配的价格&库存,您可以联系我们找货
