KQWS-2412THS
KQWS-2412THS
    DIWELL
    DIP8 模块
    隔离模块 直流转换器 1 输出 12V 3.333A 18V - 75V 输入
KQWS-2412THS 数据手册
KQWS SERIES 40W WIDE INPUT RANGE FEATURES         40W DIL PACKAGE INDUSTRY STANDARD PACKAGE 9-18V,18-36V,36-75V,9-36V,18-75V WIDE INPUT RANGE 100% BURNED IN HIGH EFFICIENCY UL 94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE 3 YEARS WARRANTY OUTPUT SPECIFICATIONS INPUT SPECIFICATIONS Voltage Setpoint Accuracy +/-2% max. Input Voltage Range Over Voltage Protection Built-in Input Filter +/-0.03%/°C Protection Temperature Coefficient Ripple & Noise(20MHz BW) 1 Line Regulation2 Load Regulation Fuse Recommended 10% of Full Load Isolation Voltage Short Circuit Protection Short Circuit Restart External Trim Adj. Range Over Load Protection 5 90% typ. (Input / Output / case) 1500 VDC min. Continuous Isolation Voltage4 Automatic Isolation Resistance 2500pF max. 150% typ. Switching Frequency 250KHz typ. 500uS max. Weight Operating Temperature Six-Side Shielded Case Case Size 50.8mm*50.8mm*11mm Radiated Emissions No Heat Sink -40°C to +60°C With Heat Sink -40°C to +75°C Humidity Cooling 50g typ. Case Material ENVIRONMENTAL SPECIFICATIONS Conducted Emissions Storage Temperature 1500 VDC min. 9 10 ohms min. +/-10% Isolation Capacitance Potting Material Case Temperature 10ms max. GENERAL SPECIFICATIONS +/-0.5% max. Efficiency Minimum load Transient Response Pi Network 100mVp-p max. Start up time(Nominal input) +/-0.5% max. 3 2:1 or 4:1 Input Range Epoxy(UL94-V0) EN55022 Class A EN55022 Class A +100°C max. -55°C to +100°C 95% max. Free-Air Convection ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD , AND 25 °C UNLESS OTHERWISE NOTED. 1 2 3 4 5 Measured with 1uF ceramic capacitor connect to the output pins. High Line to Low Line. Load Regulation is for output load current change from 10% to 100%. For 10 seconds. 50% Step Load Change. DANUBE http://www.danube.com.tw 1 2016/03/11  SELECTION GUIDE(1) 2:1 33W~40W OUTPUT MODEL NUMBER INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) INPUT6 CURRENT(mA) EFF FULL NO LOAD LOAD (%)7 CAPACITOR LOAD (Max) KQWS-1203.3(HS) 9-18 3.3 10000 3125 150 88 4700uF KQWS-1205(HS) 9-18 5 8000 3663 150 91 4700uF KQWS-1209(HS) 9-18 9 4444 3663 150 91 3300uF KQWS-1212(HS) 9-18 12 3333 3703 150 90 1500uF KQWS-1215(HS) 9-18 15 2667 3703 150 90 820uF KQWS-2403.3(HS) 18-36 3.3 10000 1545 100 89 4700uF KQWS-2405(HS) 18-36 5 8000 1785 100 93 4700uF KQWS-2409(HS) 18-36 9 4444 1832 100 91 3300uF KQWS-2412(HS) 18-36 12 3333 1832 100 91 1500uF KQWS-2415(HS) 18-36 15 2667 1825 100 91 820uF KQWS-4803.3(HS) 36-75 3.3 10000 764 40 90 4700uF KQWS-4805(HS) 36-75 5 8000 906 40 92 4700uF KQWS-4809(HS) 36-75 9 4444 916 40 91 3300uF KQWS-4812(HS) 36-75 12 3333 920 40 91 1500uF KQWS-4815(HS) 36-75 15 2667 920 40 91 820uF Note: Other input to output voltages may be available. Please contact factory. 6 7 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE,FULL LOAD. DANUBE http://www.danube.com.tw 2 2016/03/11  SELECTION GUIDE(2) 4:1 33W~40W OUTPUT MODEL NUMBER INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) INPUT8 CURRENT(mA) EFF FULL NO LOAD LOAD (%)9 CAPACITOR LOAD (Max) KQWS-1203.3T(HS) 9-36 3.3 10000 3161 150 87 4700uF KQWS-1205T(HS) 9-36 5 8000 3745 150 89 4700uF KQWS-1209T(HS) 9-36 9 4444 3745 150 89 3300uF KQWS-1212T(HS) 9-36 12 3333 3704 150 90 950uF KQWS-1215T(HS) 9-36 15 2667 3704 150 90 820uF KQWS-2403.3T(HS) 18-75 3.3 10000 1580 100 87 4700uF KQWS-2405T(HS) 18-75 5 8000 1873 100 89 4700uF KQWS-2409T(HS) 18-75 9 4444 1873 100 89 3300uF KQWS-2412T(HS) 18-75 12 3333 1894 100 88 950uF KQWS-2415T(HS) 18-75 15 2667 1852 100 90 820uF Note: Other input to output voltages may be available. Please contact factory.  PART NUMBERS STRUCTURE Model Name KQWv-x1x2T(HSJ) Difference KQ=Series Name W=Wide Input Range v=Type of output voltage (S=single output) x1=Input voltage(9~18V;18~36V;36~75V;9~36V;18-75V) x2=Output voltage(03.3;05;09;12;15 ) T= Input Range 4:1 HS=With Heat Sink zzz= 0~9,A~Z or blank for market purpose. J=Pin Length 3.5 mm 8 9 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE,FULL LOAD. DANUBE http://www.danube.com.tw 3 2016/03/11  SIMPLIFIED SCHEMATIC +Vin +Vout -Vout -Vin PWM CONTROLLER ISOLATION REFERENCE & ERROR AMP  MECHANICAL DIMENSIONS PIN SINGLE 1 Remote On/Off 2 -Vin 3 +Vin 4 -Sense 5 +Sense 6 +Vout 7 -Vout 8 Trim NOTE:Pin Size is Tolerance 1.0Φ ±0.10mm All Dimensions In mm(Inches) Tolerance .X DANUBE http://www.danube.com.tw or .XX= ±0.5mm 4 2016/03/11 Remote On/Off Control Control Input PIN1 Control Voltage ON Control Common Converter Shutdown Idle Current >+2.5VDC or Open Circuit 10mA CMOS or Open Logic Compatibility OFF PIN2
KQWS-2412THS 价格&库存
很抱歉,暂时无法提供与“KQWS-2412THS”相匹配的价格&库存,您可以联系我们找货
