TPAZ3028-04P.RDG
TPAZ3028-04P.RDG
    TECHPUBLIC(台舟)
    SO-8
    2.8V截止 峰值浪涌电流:10A@8/20US
TPAZ3028-04P.RDG 数据手册
TPAZ 3028-04P.RDG TVS Array For ESD and Latch Up Protection WWW.SOT23.COM.TW Features Mechanical Characteristics  Protects two line pairs(four lines)  Ultra low leakage:nA level        Low operating voltage:2.8V     www.kxw-esd.com CH PU BL IC Low capacitance www.kxw-esd.com Ultra low clamping voltage JEDEC SO-8 package www.kxw-esd.com Complies with following standards: – IEC 61000-4-2 (ESD) immunity test www.kxw-esd.com Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 10A (8/20µs)  RoHS Compliant TE Ordering Information Part Number Qty per Reel TPAZ3028-04P.RDG 2500 Package: SO-8 Lead Finish: Matte Tin Case Material: “Green” Molding Compound. UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 3 per J-STD-020 Terminal Connections: See Diagram Below Reel Size Applications        Base Station Analog Inputs Switch Systems 10/100/1000 Ethernet WAN/LAN Equipment Desktops, Servers, and Notebooks Low Voltage Interfaces 13Inch Dimensions and Pin Configuration w .kxw-esd.com w .kxw-esd.com w.kx-esd.com w .kxw-esd.com w .kxw-esd.com Circuit and Pin Schematic Marking: 302804P TECHPUBLIC TPAZ 3028-04P.RDG TVS Array For ESD and Latch Up Protection WWW.SOT23.COM.TW Absolute Maximum Ratings (TA=25°C unless otherwise specified) www.kxw-esd.com ESD per IEC 61000−4−2 (Contact) Unit Ppk 100 W IPP 10 A VESD www.kxw-esd.com PU Operating Temperature Range www.kxw-esd.com Value BL ESD per IEC 61000−4−2 (Air) Symbol IC www.kxw-esd.com Peak Pulse Power(8/20µs) www.kxw-esd.com Peak Pulse Current(8/20µs) www.kxw-esd.com Parameter Storage Temperature Range ±30 kV ±30 TJ −40 to +125 °C Tstg −55 to +150 °C Parameter www.kxw-esd.com Symbol Min V 4.3 V www.kxw-esd.com µA VC 5.5 V IPP = 1A (8 x 20µs pulse) VC 10 V IPP = 10A (8 x 20µs pulse) Snap-Back Voltage VSB 2.8 Variation in capacitance with www.kxw-esd.com www.kxw-esd.com Junction Capacitance 2.8 Test Condition 1.0 3.5 www.kxw-esd.com Clamping Voltage www.kxw-esd.com Unit IR VPT Clamping Voltage Max www.kxw-esd.com I = 2µA www.kxw-esd.com I = 50mA www.kxw-esd.com V = 2.8V www.kxw-esd.com Punch-Through Voltage Reverse Leakage Current Typ VRWM TE Reverse Working Voltage CH Electrical Characteristics (TA=25°C unless otherwise specified) 3.8 SB CJ 4.7 RWM Pins 1,8 to 2,7 and pins 3,6 to 4,5 1.3 reverse bias PT pF 6 pF VR = 0 to 2.8V, f = 1MHz Pins 1,8 to 2,7 and pins 3,6 to 4,5 VR = 2.8V, f = 1MHz TPAZ 3028-04P.RDG TVS Array For ESD and Latch Up Protection WWW.SOT23.COM.TW Typical characteristics (TA=25 C, unless otherwise noted) Non-Repetitive Peak Pulse Power vs. Pulse Time Clamping Voltage vs. Peak Pulse Current 10 10 Clamping Voltage - VC (V) 1 0.1 8 7 6 5 4 3 Waveform Parameters: tr = 8μs td = 20μs 2 1 0.01 0.1 1 10 IC Peak Pulse Power - PPP (kW) 9 0 100 0 Pulse Duration - tp (us) 2 4 6 8 10 12 Peak Pulse Current - IPP (A) Typical Insertion Loss (S21) BL Normalized Junction Capacitance vs. Reverse Voltage CH1 S21 2 PU 1.8 1.4 1.2 CH 1 0.8 0.6 0.4 0.2 0 0 0.5 TE Cj(VR) / Cj(VR=0V) 1.6 1 1.5 2 6 dB / REF 0 dB 1: -1.8892 dB 800 MHz 2: -2.1247 dB 900 MHz 0 dB 12 -6 dB 3: -6.9338 dB 1.8 GHz 3 -12 dB 5 -18 dB 4: -15.047 dB 2.5 GHz 4 -24 dB -30 dB -36 dB f = 1 MHz -42 dB 2.5 Reverse Voltage (VR) ESD Clamping (8kV Contact per IEC 61000-4-2) Note: Data is taken with a 10x attenuator LOG 3 -48 dB 1 MHz START . 030 MHz 10 MHz 100 MHz 3 1 GHz GHz STOP 3000. 000000 MHz ESD Clamping (-8kV Contact per IEC 61000-4-2) Note: Data is taken with a 10x attenuator TPAZ 3028-04P.RDG TVS Array For ESD and Latch Up Protection WWW.SOT23.COM.TW A e N H E1 E 2 0.25 ccc C 2X N/2 TIPS e/2 D aaa C CH A2 A C A1 01 A SEE DETAIL A DIM A A1 A2 b c D E1 E e h L L1 N 01 aaa bbb ccc DIMENSIONS INCHES MILLIMETERS MIN NOM MAX MIN NOM MAX .069 .053 .010 .004 .065 .049 .020 .012 .010 .007 .189 .193 .197 .150 .154 .157 .236 BSC .050 BSC .010 .020 .016 .028 .041 (.041) 8 8° 0° .004 .010 .008 1.75 1.35 0.25 0.10 1.65 1.25 0.51 0.31 0.25 0.17 4.80 4.90 5.00 3.80 3.90 4.00 6.00 BSC 1.27 BSC 0.25 0.50 0.40 0.72 1.04 (1.04) 8 8° 0° 0.10 0.25 0.20 SIDE VIEW C A-B D TE bxN bbb L (L1) DETAIL B SEATING PLANE c GAGE PLANE BL 1 w w.kxw-esd.com h PU 2X E/2 h D IC Outline Drawing - SOP-8 Land Pattern - SOP-8 WWW.TECHPUBLIC.COM.TW
TPAZ3028-04P.RDG 价格&库存
很抱歉,暂时无法提供与“TPAZ3028-04P.RDG”相匹配的价格&库存,您可以联系我们找货
