POLYMER PTC
RESETTABLE FUSE
Product: Resettable Fuse
Revision: B
Date: 2021-05-10
Page No.: 1 OF 1
电路保护元器件专业制造商
Web: http://www.tlcet.com.cn
Part Number:TLC-MSMD050/24
1、Physical Dimensions(size of 1812)
Unit:mm
A
Part Number
TLC-MSMD050/24
B
C
D
Min
Max
Min
Max
Min
Max
Min
4.37
4.73
3.07
3.41
0.60
1.00
0.30
Top and Bottom View
Marking
Marking
T050
IH
(A)
IT
(A)
Vmax
(V)
I max
(A)
Ttrip
(Max time to trip)
Current(A)
Time(S)
TLC-MSMD050/24
0.50
1.00
24
40
8.0
0.15
IH: Holding Current: maximum current at which the device will not trip in 25℃ still air.
IT: Tripping Current minimum current at which the device will trip in 25℃ still air.
Vmax: Maximum voltage device can withstand without damage at rated current.
I max: Maximum fault current device can withstand without damage at rated voltage.
T trip: Maximum time to trip(s) at assigned current.
Pd typ: Rated working power.
R min: Minimum resistance of device prior to trip at 25℃.
R1 max: Maximum resistance of device is measured one hours post reflow at 25℃.
Noted: All electrical function test is conducted after PCB mounted.
C
B
D
2、Electrical Characteristics
Part Number
Side View
A
Pd typ
(W)
R min
(Ω)
R1max
(Ω)
0.8
0.15
1.00
3、Thermal Derating
TLC-MSMD050/24
Hold Current(A)
Trip Current(A)
Maximum ambient operating temperature
-40℃
-20℃
0℃
25℃
40℃
50℃
60℃
70℃
85℃
0.77
1.54
0.68
1.36
0.59
1.18
0.50
1.00
0.44
0.88
0.40
0.80
0.37
0.74
0.33
0.66
0.29
0.58
4、Solder Reflow Recommendations
20-40s
260℃
Critlcal Zone
Temperature
217℃
Recommended Pad Layout(mm)
1.5±0.05
Ramp-up
1.5±0.05
60-150s
200℃
25℃
60-180s
8 minutes max
Average Ramp-Up Rate:3 ℃ /second max
3.2±0.1
Ramp-down
Preheat
150℃
2.7±0.1
Time
Ramp-Down Rate:6 ℃ /second max
Notes:If reflow temperatures exceed the recommended
profile,devices may not meet the performance requirements.
5、Package Information
Packing quantity:2000PCS/Reel
Note:Reel packaging per EIA-481-1 standard
6、Agency Recognition:TUV
Caution:Operation beyond the rated voltage or current may result in rupture electrical arcing or flame.Specifications are
subject to change without notice.
TEL: 86-0769-3892 0554
FAX: 86-0769-8793 2077
E-mail:Tina@tlcet.com.cn
Address:No.18,5th GaoLi Road,TangXia Town,DongGuan,GuangDong,P.R China 523710
很抱歉,暂时无法提供与“TLC-MSMD050/24”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.47391
- 100+0.37023
- 300+0.31839
- 2000+0.27357
- 4000+0.24246
- 10000+0.22680
