BUK9K25-40RAX
BUK9K25-40RAX
    NEXPERIA(安世)
    SOT-1205,LFPAK56-8
    MOSFET - 阵列 40V 18.2A(Ta) 32W(Ta) 表面贴装型 LFPAK56D
BUK9K25-40RAX 数据手册
BUK9K25-40RA Dual N-channel 40 V, 29 mOhm logic level MOSFET in LFPAK56D using Repetitive Avalanche technology 2 December 2020 Product data sheet 1. General description Dual, logic level N-channel MOSFET in an LFPAK56D package, using Application Specific (ASFET) repetitive avalanche silicon technology. This product has been designed and qualified to AEC-Q101 for use in repetitive avalanche applications. 2. Features and benefits • • • Fully automotive qualified to AEC-Q101 at 175 °C Repetitive Avalanche rated to 30 °C Tj rise: • Tested to 1 Bn avalanche events LFPAK copper clip package technology: • High robustness and reliability • Gull wing leads for high manufacturability and AOI 3. Applications • • • • • 12 V, 24 V and 48 V automotive systems Repetitive avalanche topologies Engine control Transmission control Actuator and auxiliary loads 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - - 40 V ID drain current VGS = 5 V; Tmb = 25 °C; Fig. 2 - - 18.2 A Ptot total power dissipation Tmb = 25 °C; Fig. 1 - - 32 W VGS = 5 V; ID = 5 A; Tj = 25 °C; Fig. 14 - 24 29 mΩ - 2.4 - nC Static characteristics FET1 and FET2 RDSon drain-source on-state resistance Dynamic characteristics FET1 and FET2 QGD gate-drain charge ID = 5 A; VDS = 32 V; VGS = 5 V; Tj = 25 °C; Fig. 16; Fig. 17 BUK9K25-40RA Nexperia Dual N-channel 40 V, 29 mOhm logic level MOSFET in LFPAK56D using Repetitive Avalanche technology 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 S1 source1 2 G1 gate1 3 S2 source2 4 G2 gate2 5 D2 drain2 6 D2 drain2 7 D1 drain1 8 D1 drain1 Simplified outline 8 7 6 Graphic symbol 5 D1 D1 S1 D2 D2 G1 S2 G2 mbk725 1 2 3 4 LFPAK56D; Dual LFPAK (SOT1205) 6. Ordering information Table 3. Ordering information Type number Package BUK9K25-40RA Name Description Version LFPAK56D; Dual LFPAK plastic, single ended surface mounted package (LFPAK56D); 8 leads SOT1205 7. Marking Table 4. Marking codes Type number Marking code BUK9K25-40RA 92540RA 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - 40 V VDGR drain-gate voltage RGS = 20 kΩ - 40 V VGS gate-source voltage Pulsed; Tj ≤ 175 °C -15 15 V DC; Tj ≤ 175 °C -10 10 V [1] [2] Ptot total power dissipation Tmb = 25 °C; Fig. 1 - 32 W ID drain current VGS = 5 V; Tmb = 25 °C; Fig. 2 - 18.2 A VGS = 5 V; Tmb = 100 °C; Fig. 2 - 16.6 A pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3 - 94 A IDM peak drain current Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode FET1 and FET2 IS source current Tmb = 25 °C - 18.2 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 94 A BUK9K25-40RA Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2020 © Nexperia B.V. 2020. All rights reserved 2 / 13 BUK9K25-40RA Nexperia Dual N-channel 40 V, 29 mOhm logic level MOSFET in LFPAK56D using Repetitive Avalanche technology Symbol Parameter Conditions Min Max Unit [3] [4] [5] - 19 mJ [6] [7] - 15 mJ Avalanche ruggedness EDS(AL)R repetitive drain-source avalanche energy ID = 0.73 A; Vsup ≤ 40 V; RGS = 10 Ω; VGS =10 V; Tj(rise) ≤ 30 °C; unclamped; Fig. 4; Fig. 5; Fig. 6 Avalanche ruggedness FET1 and FET2 EDS(AL)S [1] [2] [3] [4] [5] [6] [7] non-repetitive drainID = 18.2 A; Vsup ≤ 40 V; VGS = 10 V; source avalanche energy Tj(init) = 25 °C; Fig. 7 Accumulated Pulse duration up to 50 hours delivers zero defect ppm. Significantly longer life times are achieved by lowering Tj and or VGS. Repetitive avalanche rating is limited by maximum junction temperature of 175 °C and junction rise of 30 °C Refer to Fig. 5 for the limiting number of avalanche events Refer to Fig. 6 Rdson at Vgs=5V will increase as a function of repetitive avalanche cycles Refer to application note AN10273 for further information Single-pulse avalanche rating limited by maximum junction temperature of 175 °C 03aa16 120 ID (A) Pder (%) 003aak328 30 25 80 20 15 40 10 5 0 0 50 100 150 Tmb (°C) 0 200 Fig. 2. Fig. 1. ID (A) Normalized total power dissipation as a function of mounting base temperature 0 25 50 75 100 125 150 175 Tmb (°C) Continuous drain current as a function of mounting base temperature 003aak327 103 102 200 Limit RDSon = VDS / ID tp = 10 us 100 us 10 1 1 ms DC 10-1 10-1 Fig. 3. 1 10 10 ms 100 ms VDS (V) 102 Safe operating area; continuous and peak drain current as a function of drain-source voltage BUK9K25-40RA Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2020 © Nexperia B.V. 2020. All rights reserved 3 / 13 BUK9K25-40RA Nexperia Dual N-channel 40 V, 29 mOhm logic level MOSFET in LFPAK56D using Repetitive Avalanche technology IAL (A) aaa-032797 102 aaa-031643 1010 No. Events 10 109 1 10-1 10-3 10-2 10-1 1 tAL (ms) 108 10-1 10 Tj is limited to 175 °C and Tj(rise) is limited to 30 °C Repetitive avalanche rating; avalanche current as a function of avalanche time % Increase of Rdson at 5V Vgs Fig. 4. Fig. 5. 1 10 EDS(AL) Per Event (mJ) 102 Repetitive avalanche rating; maximum number of avalanche events as a function of avalanche energy aaa-032338 50 40 30 20 10 0 Fig. 6. 1 10 % of cycle limit 102 Percentage Rdson at 5V increase as a function of avalanche cycles IAL (A) aaa-032799 102 10 1 10-1 10-3 10-2 10-1 1 tAL (ms) 10 Tj (init) = 25 °C Fig. 7. Single pulse avalanche rating; avalanche current as a function of avalanche time BUK9K25-40RA Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2020 © Nexperia B.V. 2020. All rights reserved 4 / 13 BUK9K25-40RA Nexperia Dual N-channel 40 V, 29 mOhm logic level MOSFET in LFPAK56D using Repetitive Avalanche technology 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from Fig. 8 junction to mounting base - - 4.68 K/W Rth(j-a) thermal resistance from Minimum footprint; mounted on a junction to ambient printed circuit board - 95 - K/W 003aaj557 10 Zth(j-mb) (K/W) δ = 0.5 0.2 1 0.1 0.05 0.02 10 P -1 single shot δ= tp 10-2 10-6 Fig. 8. 10-5 10-4 10-3 10-2 tp T t T 10-1 1 tp (s) Transient thermal impedance from junction to mounting base as a function of pulse duration 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics FET1 and FET2 V(BR)DSS drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = -55 °C 36 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 40 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS=VGS; Tj = 25 °C; Fig. 12; Fig. 13 1.4 1.7 2.1 V ID = 1 mA; VDS=VGS; Tj = 175 °C; Fig. 12; Fig. 13 0.5 - - V ID = 1 mA; VDS=VGS; Tj = -55 °C; Fig. 12; Fig. 13 - - 2.45 V VDS = 40 V; VGS = 0 V; Tj = 175 °C - - 500 µA VDS = 40 V; VGS = 0 V; Tj = 25 °C - 0.02 1 µA VGS = -10 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 10 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 5 V; ID = 5 A; Tj = 25 °C; Fig. 14 - 24 29 mΩ VGS = 5 V; ID = 5 A; Tj = 175 °C; Fig. 14; Fig. 15 - 48.2 58 mΩ VGS = 10 V; ID = 5 A; Tj = 25 °C; Fig. 14 - 19 24 mΩ IDSS drain leakage current IGSS gate leakage current RDSon drain-source on-state resistance BUK9K25-40RA Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2020 © Nexperia B.V. 2020. All rights reserved 5 / 13 BUK9K25-40RA Nexperia Dual N-channel 40 V, 29 mOhm logic level MOSFET in LFPAK56D using Repetitive Avalanche technology Symbol Parameter Conditions Min Typ Max Unit - 6.3 - nC - 1.4 - nC - 2.4 - nC - 528 701 pF - 95 114 pF - 56 76 pF - 6.2 - ns - 9.2 - ns Dynamic characteristics FET1 and FET2 QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time - 10.8 - ns tf fall time - 8.9 - ns ID = 5 A; VDS = 32 V; VGS = 5 V; Tj = 25 °C; Fig. 16; Fig. 17 VDS = 25 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; Fig. 18 VDS = 32 V; RL = 6.4 Ω; VGS = 5 V; RG(ext) = 5 Ω; Tj = 25 °C Source-drain diode FET1 and FET2 VSD source-drain voltage IS = 5 A; VGS = 0 V; Tj = 25 °C; Fig. 19 - 0.83 1.2 V trr reverse recovery time - 15.9 - ns Qr recovered charge IS = 5 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 20 V; Tj = 25 °C - 7.6 - nC ID (A) 003aak319 25 20 80 15 60 10 40 5 0 Fig. 9. 175°C 0 0.8 1.6 20 Tj = 25°C 2.4 3.2 VGS (V) Product data sheet 0 4 Transfer characteristics; drain current as a function of gate-source voltage; typical values BUK9K25-40RA 003aak320 100 RDSon 0 4 8 12 VGS (V) 16 Fig. 10. Drain-source on-state resistance as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 2 December 2020 © Nexperia B.V. 2020. All rights reserved 6 / 13 BUK9K25-40RA Nexperia Dual N-channel 40 V, 29 mOhm logic level MOSFET in LFPAK56D using Repetitive Avalanche technology ID (A) 003aak321 40 10 V 55VV 4.5 V 32 003aah025 3 VGS(th) (V) 2.5 max 2 VGS = 3.5 V 24 typ 1.5 16 2.8 V 8 0.5 2.6 V 0 2.4 V 0 1 2 3 VDS (V) min 1 3V 0 -60 4 0 60 120 Tj (° C) 180 Tj = 25 °C; tp = 300 μs Fig. 11. Output characteristics; drain current as a Fig. 12. Gate-source threshold voltage as a function of function of drain-source voltage; typical values junction temperature 003aah026 10-1 150 RDSon 2.8 V ID (A) 10-2 003aak326 3V 3.5 V 120 min 10-3 typ max 90 10-4 4.5 V 60 5V 10-5 30 VGS = 10 V 10 -6 0 1 2 V GS (V) 0 3 0 10 20 30 ID (A) 40 Tj = 25 °C; tp = 300 μs Fig. 13. Sub-threshold drain current as a function of gate-source voltage BUK9K25-40RA Product data sheet Fig. 14. Drain-source on-state resistance as a function of drain current; typical values All information provided in this document is subject to legal disclaimers. 2 December 2020 © Nexperia B.V. 2020. All rights reserved 7 / 13 BUK9K25-40RA Nexperia Dual N-channel 40 V, 29 mOhm logic level MOSFET in LFPAK56D using Repetitive Avalanche technology 003aaj814 2.4 VGS (V) a 003aak323 10 8 1.6 VDS = 14 V 6 32 V 4 0.8 2 0 -60 0 60 120 Tj ( °C) 0 180 Fig. 15. Normalized drain-source on-state resistance factor as a function of junction temperature 0 2.5 5 7.5 10 15 Fig. 16. Gate-source voltage as a function of gate charge; typical values 003aak324 103 C (pF) VDS 12.5 QG (nC) Ciss ID VGS(pl) Coss 102 VGS(th) Crss VGS QGS2 QGS1 QGS 10 10-1 QGD QG(tot) Product data sheet 10 VDS (V) 102 003aaa508 Fig. 17. Gate charge waveform definitions BUK9K25-40RA 1 Fig. 18. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. 2 December 2020 © Nexperia B.V. 2020. All rights reserved 8 / 13 BUK9K25-40RA Nexperia Dual N-channel 40 V, 29 mOhm logic level MOSFET in LFPAK56D using Repetitive Avalanche technology IS (A) 003aak325 40 32 24 16 8 0 Tj = 25°C 175°C 0 0.2 0.4 0.6 0.8 1 VSD (V) 1.2 Fig. 19. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values BUK9K25-40RA Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2020 © Nexperia B.V. 2020. All rights reserved 9 / 13 BUK9K25-40RA Nexperia Dual N-channel 40 V, 29 mOhm logic level MOSFET in LFPAK56D using Repetitive Avalanche technology 11. Package outline Plastic single ended surface mounted package LFPAK56D; 8 leads E SOT1205 A A b1 c1 L1 mounting base D H D1 D2 L 1 2 3 e b (8x) 4 w X c A E1 E2 A1 C θ Lp detail X 0 2.5 A max 1.05 nom min 1.02 mm 5 mm scale Dimensions Unit y C D(1) D1(1) D2 (ref) E(1) E1(1) 4.4 0.25 0.30 4.70 4.55 3.5 5.30 1.8 0.85 4.1 0.19 0.24 4.45 4.35 3.4 4.95 1.6 0.60 A1 b b1 0.1 0.50 0.0 0.35 c c1 E2 e 1.27 H L L1 Lp 6.2 1.3 0.55 0.85 5.9 0.8 0.30 0.40 w y 0.25 0.1 Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. Outline version References IEC JEDEC JEITA θ 8° 0° sot1205_po European projection Issue date 14-08-21 14-10-28 SOT1205 Fig. 20. Package outline LFPAK56D; Dual LFPAK (SOT1205) BUK9K25-40RA Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2020 © Nexperia B.V. 2020. All rights reserved 10 / 13 BUK9K25-40RA Nexperia Dual N-channel 40 V, 29 mOhm logic level MOSFET in LFPAK56D using Repetitive Avalanche technology 12. Soldering Footprint information for reflow soldering of LFPAK56D package SOT1205 5.85 0.57 0.025 0.57 0.7 1.97 0.65 1.27 1.9 3.325 3.175 3.2 2.0 1.275 0.8 1.875 2.1 2.7 1.0 3.85 3.975 0.025 1.1 1.15 0.65 1.27 1.1 1.44 solder land solder land plus solder paste solder paste deposit solder resist occupied area Dimensions in mm Issue date 0.7 14-07-28 20-04-20 sot1205_fr Fig. 21. Reflow soldering footprint for LFPAK56D; Dual LFPAK (SOT1205) BUK9K25-40RA Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2020 © Nexperia B.V. 2020. All rights reserved 11 / 13 BUK9K25-40RA Nexperia Dual N-channel 40 V, 29 mOhm logic level MOSFET in LFPAK56D using Repetitive Avalanche technology equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 13. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or BUK9K25-40RA Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2020 © Nexperia B.V. 2020. All rights reserved 12 / 13 BUK9K25-40RA Nexperia Dual N-channel 40 V, 29 mOhm logic level MOSFET in LFPAK56D using Repetitive Avalanche technology Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 2 9. Thermal characteristics............................................... 5 10. Characteristics............................................................ 5 11. Package outline........................................................ 10 12. Soldering................................................................... 11 13. Legal information......................................................12 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 2 December 2020 BUK9K25-40RA Product data sheet All information provided in this document is subject to legal disclaimers. 2 December 2020 © Nexperia B.V. 2020. All rights reserved 13 / 13
BUK9K25-40RAX
物料型号:BUK9K25-40RA 器件简介:BUK9K25-40RA是一款双N沟道40V、29mΩ逻辑电平MOSFET,采用LFPAK56D封装,并使用Repetitive Avalanche技术。
引脚分配:1-S1源极1,2-G1栅极1,3-S2源极2,4-D2漏极2,5-D2漏极2,6-D1漏极1,7-D1漏极1,8-D1漏极1。
参数特性:包括漏源电压(Vps)最大40V,漏电流(J)最大18.2A,总功耗(Ptot)最大32W等。
功能详解:该产品已通过AEC-Q101认证,适用于12V、24V和48V汽车系统,以及重复雪崩拓扑结构。
应用信息:适用于汽车电子的引擎控制、传动控制、执行器和辅助负载等。
封装信息:LFPAK56D封装,具有8个引脚,使用SOT1205的简化外形。
BUK9K25-40RAX 价格&库存
很抱歉,暂时无法提供与“BUK9K25-40RAX”相匹配的价格&库存,您可以联系我们找货
BUK9K25-40RAX
  • 50+5.94630
  • 100+5.83696
  • 250+5.72137
  • 500+5.60577
库存:1440
BUK9K25-40RAX
  • 10+6.25872
  • 50+6.14833
  • 100+6.03482
  • 250+5.91506
  • 500+5.79530
库存:1440
BUK9K25-40RAX
    • 1+7.02000
    • 50+6.48000
    • 100+6.37200
    • 500+6.15600
    • 1000+6.04800
    BUK9K25-40RAX
    • 1+16.147201+2.09865
    • 10+10.2731710+1.33521
    • 50+7.7118150+1.00231
    • 100+6.88385100+0.89470
    • 500+5.42943500+0.70567
    库存:4414
    BUK9K25-40RAX
    • 1500+4.723171500+0.61387
    • 4500+4.186464500+0.54412
    库存:4414
