6098-3802
6098-3802
    SUMITOMO(住友)
6098-3802 数据手册
汽车用接插件 CONTENTS unsealed / Connector sealed Series 非防水/防水 接插件系列 Terminal Tab Size 端子大小 0.64 (025) 1.5 (060) 2.3 (090) 4.8 (187) 8.0 (312) TS 0.64+1.5 No. of Way Variation 极数种类 2, 5, 10, 14, 16, 19, ,22, 24, 28, 32, 36, ,40 0.13 - 0.5 A-02 2, 4, 8, 12 0.13 - 2.0 A-07 2, 6, 8, 9, 10, 11, 12, 13, 16, 20 0.22 - 2.0 A-10 1, 2, 3, 4, 6, 8, 10 0.3 - 3.0 A-14 1, 2, 3, 4 0.5 - 8.0 A-18 12, 18, 20 — A-20 0.64+2.3 17, 18, 20 — A-21 0.64+4.8 20 — A-22 14, 15, 20 — A-22 16, 33, 36, 56, 60, 68 — A-24 20 — A-26 2, 3, 4, 6, 7, 10, 12, 16, 20, 24, 34 0.22 - 0.75 C-02 2, 5, 6, 8, 13, 17, 21 0.22 - 0.85 C-06 2, 3, 4, 5, 6, 8, 10, 14, 16, 20 0.3 - 2.0 C-09 2, 4, 5 0.3 - 3.0 C-12 2.0 - 10.0 C-14 12, 13, 18, 20, 23, 28 — C-16 1.0+2.3 9, 10, 14, 23 — C-18 1.0+4.8 12, 14 — C-19 2.3+4.8 8, 14, 16, 18, 20 — C-20 4.8+8.0 6 — C-21 1.0 13 — C-22 1.0+2.3 23 — C-22 1.0+4.8 14 — C-23 2.3 6 — C-23 0.22 - 0.75 F-02 Hybrid 2.3+4.8 0.64 PCB 0.64+1.5 0.64 (025) 1.0 (040) 2.3 (090) 4.8 (187) 9.5 (375) 1, 2 0.64+2.3 unsealed HE Hybrid PCB NH 0.64 (025) Hybrid Hybrid DL 0.64+2.3 1.5 (060) 2.3 (090) 2.8 (110) SL Applicable Page Cable Size 适用电线大小 刊登页  1.5+2.8 0.64 (025) 1.0 (040) 2.3 (090) 3, 4, 8, 10, 12, 16, 24, 32, 40 — F-07 4, 12, 14, 16 0.3 - 2.0 I-02 2, 4, 6, 12, 14, 16, 18 0.3 - 2.0 I-05 4 0.3 - 3.0 I-08 14 — I-10 2 0.22 - 0.75 K-02 0.3 - 1.25 K-04 0.3 - 2.0 K-07 20 4, 8, 12, 16, 20 2, 4, 6, 10, 14, 16 Contact Resistance 接触电阻(包括压接部) Leak Current 漏电流 Insulation Resistance 绝缘电阻 Seal 密封性 8mΩ max.(initial) 16mΩ max.(after durability tests) 3mΩ max.(initial) 10mΩ max.(after durability tests) 3mA max. 100MΩ min. — 8mΩ max.(initial) 16mΩ max.(after durability tests) 3mΩ max.(initial) 10mΩ max.(after durability tests) 8mΩ max.(initial) 16mΩ max.(after durability tests) 8mΩ max.(initial) 16mΩ max.(after durability tests) Material 材质 接插件护套 端子 Housing / PBT Terminal / Brass, Heat-Resistant Copper Alloy 接插件护套 端子 Housing / PBT, PA6T Terminal / Brass, Heat-Resistant Copper Alloy 接插件护套 端子 Housing / PBT Terminal / Brass, Heat-Resistant Copper Alloy 接插件护套 端子 接插件护套 端子 Housing / PBT, SPS Terminal / Brass Housing / LCP Terminal / Brass 接插件护套 端子 Housing / PBT Terminal / Brass, Heat-Resistant Copper Alloy 接插件护套 端子 Housing / PBTG30 Terminal / Brass 接插件护套 端子 Housing / PBT Terminal / Brass, Heat-Resistant Copper Alloy 接插件护套 端子 接插件护套 端子 Housing / PBT Terminal / Heat-Resistant Copper Alloy Housing / PBT Terminal / Brass, Heat-Resistant Copper Alloy 接插件护套 端子 Housing / PBT Terminal / Heat-Resistant Copper Alloy 接插件护套 端子 Housing / PBT Terminal / Brass, Heat-Resistant Copper Alloy 5mΩ max.(initial) 10mΩ max.(after durability tests) 3mΩ max.(initial) 6mΩ max.(after durability tests) 2mΩ max.(initial) 4mΩ max.(after durability tests) 5mΩ max.(initial) 10mΩ max.(after durability tests) 1mA max. 100MΩ min. — 3mΩ max.(initial) 6mΩ max.(after durability tests) 5mΩ max.(initial) 10mΩ max.(after durability tests) 3mΩ max.(initial) 6mΩ max.(after durability tests) 10mΩ max.(initial) 30mΩ max.(after durability tests) 3mΩ max.(initial) 10mΩ max.(after durability tests) — 1mA max. 3mA max. 100MΩ min. 100MΩ min. — 5mΩ max.(initial) 10mΩ max.(after durability tests) 3mΩ max.(initial) 10mΩ max.(after durability tests) 3mA max. 100MΩ min. — unsealed / Connector sealed Series 非防水/防水 接插件系列 Terminal Tab Size 端子大小 0.64 (025) 0.64W (025W) No. of Way Variation 极数种类 2, 3, 4, 5, 6, 8, 10, 12, 13, 15, 17, 20, 30 4 Hybrid 0.64W+2.3+4.8 38, 46 TS sealed sealed HX sealed Hybrid B-02 0.3 - 0.6 B-08 — B-10 2, 3, 4, 5, 6, 7 0.3 - 2.0 B-12 4.8 (187) 1, 2, 3 0.3 - 3.0 B-19 8.0 (312) 1, 2 0.5 - 8.0 B-23 0.64+2.3 10, 13, 26 — B-26 0.64+4.8 4, 24, 34, 40, 46 — B-27 — B-28 2.3+4.8 4, 5, 6, 11 — B-29 4.8+8.0 3 — B-30 0.3 - 1.25 D-02 1.0 (040) 2, 3, 4, 5, 6, 10 1.0 (040) 1, 2, 3, 5, 6, 7 1.0 (040) 23, 33 Joint Connector Hybrid Joint Connector 0.13 - 0.5 2.3 (090) Hybrid 0.64+2.3+4.8 42, 52 HV/HVG sealed Applicable Page Cable Size 适用电线大小 刊登页 22 1.5 (060) 2, 3, 4, 8, 12 2.3 (090) 1, 2, 3, 4 Leak Current 漏电流 8mΩ max.(initial) 16mΩ max.(after durability tests) 50μA max. 3mΩ max.(initial) 10mΩ max.(after durability tests) 100μA max. 8mΩ max.(initial) 16mΩ max.(after durability tests) 50μA max. 3mΩ max.(initial) 10mΩ max.(after durability tests) 100μA max. 5mΩ max.(initial) 10mΩ max.(after durability tests) 100μA max. Insulation Resistance 绝缘电阻 Seal 密封性 Material 材质 100MΩ min 50kPa min. (initial) 30kPa min. (after durability tests) 接插件护套 端子 电线密封栓 Housing / PBT, PA6T Terminal / Brass, Heat-Resistant Copper Alloy Wire Seal / Silicon 100MΩ min 98kPa min. (initial) 49kPa min. (after durability tests) 接插件护套 端子 电线密封栓 Housing / PBT Terminal / Brass, Heat-Resistant Copper Alloy Wire Seal / Silicon 接插件护套 端子 电线密封栓 Housing / PBT Terminal / Brass, Heat-Resistant Copper Alloy Wire Seal / Silicon 接插件护套 端子 电线密封栓 Housing / PBT Terminal / Brass, Heat-Resistant Copper Alloy Wire Seal / Silicon, NBR 接插件护套 端子 电线密封栓 接插件护套 端子 电线密封栓 Housing / PBT Terminal / Brass, Heat-Resistant Copper Alloy Wire Seal / Silicon Housing / PBT Terminal / Brass, Heat-Resistant Copper Alloy Wire Seal / Silicon E-02 0.3 - 1.25 E-06 E-08 23 0.64+1.0 Contact Resistance 接触电阻(包括压接部) — E-10 0.13 - 2.0 E-13 0.3 - 2.0 E-17 1.0+4.8 13 — E-21 1.5+4.8 4, 5 — E-21 2.3+4.8 10 — E-22 5mΩ max.(initial) 10mΩ max.(after durability tests) 3mΩ max.(initial) 6mΩ max.(after durability tests) 100μA max. 100MΩ min 98kPa min. (initial) 49kPa min. (after durability tests) 5mΩ max.(initial) 10mΩ max.(after durability tests) 3mΩ max.(initial) 6mΩ max.(after durability tests) RS 2.3 (090) 1, 2, 3, 4, 5, 6, 8 0.3 - 2.0 G-02 3mΩ max.(initial) 10mΩ max.(after durability tests) 10μA max. 100MΩ min 98kPa min. (initial) 98kPa min. (after durability tests) TL 2.3 (090) 1, 2, 4, 5 0.3 - 2.0 H-02 5mΩ max.(initial) 10mΩ max.(after durability tests) 50μA max. 100MΩ min 98kPa min. (initial) 98kPa min. (after durability tests) 1.5 (060) 2, 3, 14 0.3 - 2.0 J-02 2.3 (090) 1, 2, 3, 4, 6 0.3 - 2.0 J-06 3mΩ max.(initial) 10mΩ max.(after durability tests) 100μA max. 100MΩ min 49.0kPa min. (initial) 29.4kPa min. (after durability tests) Housing / PBT Terminal / Brass, Heat-Resistant Copper Alloy Wire Seal / Silicon 8.0 (312) 接插件护套 端子 电线密封栓 2 2.0 - 8.0 J-09 2.3 (090) 1, 2, 3, 4, 6, 8, 10, 12, 16 0.3 - 2.0 L-02 3mΩ max.(initial) 10mΩ max.(after durability tests) 100μA max. 100MΩ min 49.0kPa min. (initial) 29.4kPa min. (after durability tests) 接插件护套 端子 电线密封栓 Housing / PBT Terminal / Brass, Heat-Resistant Copper Alloy Wire Seal / NBR SL sealed DL sealed Introduction 前言 Safety, amenity, and functionality, measure the essential performance of an automobile and these predominately depend on in-vehicle electronic controls. A variety of car electronic devices are systematically connected with each other using “automotive connectors”, and the connectors for this purpose are required to be smaller, lighter, and provide direct connection and advanced performance. At Sumitomo Wiring Systems, we are actively researching and developing components, including terminals and housings, with respect to the “total wiring system,” using our experience as an all-round automotive wiring harness manufacturer. This is how we are able to achieve high reliability for our products. In addition, we are searching for the optimum wiring system and layout, using as little space for wiring as is effectively possible. These are part of our activities to provide services that will further satisfy our customers, and we sincerely ask to be favored with your request for connectors made by Sumitomo Wiring Systems. 对汽车的安全性、舒适性以及功能性等要求,大多取决于电子控制。 这些具有系统性连接各种汽车电子模块功能的「汽车用接插件」 ,通常要求具有轻量化、小型化、直结化、高功能化等 性能。 住友电装以汽车线束综合生产厂商的丰富经验以及“综合汽车线束系统”的视点,积极研究与开发端子、接插件等汽车 构成部品,为提高产品的高信赖性而进行着不断的努力。 并且利用有限的配线空间内,不断地追求高效率的汽车线束系统,及其最佳配线布局。为客户提供更满意的服务,敬请 定购使用住友电装的汽车用接插件。 General Notes 关于汽车用接插件目录的查阅方法 2 . ◦ All length and area units in this catalog shall marked millimeter(mm)and square millimeter(mm ) ◦ This catalog focuses on series of terminals, housings, and does not include terminals and housings not  involved in these series. Similarly, some other series and custom-made parts are not included.  Please contact our sales staff for details. ◦We have also prepared a separate “Automotive Wire, Convoluted Tube” catalog, made by Sumitomo Wiring  Systems, and suitable for the connectors. This catalog can be obtained from our sales staff. ◦该目录中的长度单位全部为 mm( 毫米)、面积的单位全部为 mm2(平方毫米)。 ◦该目录主要是以成为系列的端子、接插件编写。未包括在系列中的端子、接插件护套及一部分系列、定制开发产品未予记载,详 细内容请向敝公司销售负责人问讯。 ◦另外,还备有最适合接插件的住友电装的「汽车用电线、波纹管」目录,需要时请向敝公司销售负责人索取。 Digital catalog 电子目录 A digital connector catalog is available on the Sumitomo Wiring Systems home page. Digital catalogue has connectors which are not on this catalogue. 住友电装主页中刊登有「接插件电子目录」 。 在电子目录中还刊登有该目录中未予记载的接插件。 URL: http://www.sws.co.jp * Product specifi cations may be subject to change without notice. Before using the product, please obtain a “customer drawing” “Specifi cations” “Instruction Manuals” from our sales staff. ※产品式样变更时可能不另行告知。  使用产品时, 请向敝公司销售负责人索取「客户用图纸」 「仕样书」 「使用说明书」。 TS SERIES Features The TS connector series has a mechanism of terminal position assurance. This series consists of 0.64mm, 1.5mm, 2.3mm, 4.8mm and 8.0mm types classified according to terminal size, covering an extensive array of applications from signal to power circuits. ◦ The connector mechanism only allows the retainer to be set when the terminal is completely inserted. ◦ R e t a i n e r s a r e p r e - m o u n t e d o n connector housings, and are structured to enable setting by the same simple operation regardless of the number of ways, improving operability. ◦ T hese connectors can be directly secured to a support on the car body. ◦ P CB models are also available for connection to printed circuit boards. ◦ RoHS/ELV Compliant 特 点 TS 系列接插件具有检测端子插入不足的功能。 按照端子尺寸划分为0.64mm·1.5mm·2.3mm· 4.8mm·8.0mm,从信号回路到电源回路,能广 泛应用。 ◦它具有当端子在半插入状态时,锁片无法安装 的结构。 ◦锁片预先组装在接插件护套上,无论多少极数 都能通过简单操作进行组合,有助于提高操作 效率。 ◦接插件可以直接固定在车体的支架上。 ◦我们还设定了能适用于印制线路板的 PCB 接插 件。 ◦可对应欧盟 RoHS 和 ELV 指令 TS SERIES for STANDARD 0.64mm (025) A- 02 Structure/构造 Housing M Terminal M Retainer sliding direction 通过压入锁片能够检知端子是否 插入到位 Retainer Connector M Connector F Terminal F Housing F Retainer sliding direction 通过压入锁片能够检知端子是否 插入到位 Retainer 0.64mm (025) Terminal(UNIT : mm) 端子(毫米) (S) (S) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 Au Cable size(mm2) 0.13 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment 22.3 0.64 表面处理 0.13 Brass 黄铜 Gold-plated 镀金 0.64 15.5 1.5 F (8240-0182) Cable size(mm2) 适用电线大小 Material 2 材 质 Surface treatment 表面处理 M (8230-5136) 15.5 1.5 0.13 Heat-resistant copper alloy Tin-plated 镀锡 (M) F(8240-0338) Cable size(mm2) 适用电线大小 Material 2 材 质 Surface treatment 表面处理 Cable size(mm ) 适用电线大小 Material 材 质 Surface treatment 表面处理 Cable size(mm ) 0.22〜0.35 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment 22.3 0.64 M (8100-3622) 15.5 1.5 表面处理 0.22〜0.35 Brass 黄铜 Gold-plated 镀金 Cable size(mm2) 适用电线大小 材 质 Surface treatment 表面处理 22.3 0.64 0.64 F (8100-3624) Material 2 0.22〜0.35 Heat-resistant copper alloy Tin-plated 镀锡 (L) M (8100-3626) 15.5 1.5 F(8100-3628) Cable size(mm2) 适用电线大小 Material 2 材 质 Surface treatment 表面处理 0.22〜0.35 Heat-resistant copper alloy Gold-plated 镀金 (L) Cable size(mm ) 2 适用电线大小 Material 材 质 Surface treatment Au Cable size(mm ) 2 0.3〜0.5 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment 22.3 0.64 表面处理 0.3〜0.5 Brass 黄铜 Gold-plated 镀金 M (8100-3623) 15.5 0.64 F (8100-3625) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 22.3 0.64 0.64 2 Heat-resistant copper alloy Gold-plated 镀金 Au 2 0.64 1.5 0.13 (M) 2 表面处理 A- 03 0.64 0.3〜0.5 Heat-resistant copper alloy Tin-plated 镀锡 M (8100-3627) 1.5 2 15.5 F(8100-3629) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 0.3〜0.5 Heat-resistant copper alloy Gold-plated 镀金 TS SERIES M (8230-4878) 22.3 0.64 2way 0.64mm (025) Color Natural 自然色 颜 色 12.9 A- 04 12.6 M (6098-6653) Housing(UNIT : mm) 35.2 F(6098-6662) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 Material A-02 11.8 11.6 PBT 材 质 21 Color 5way 10way Color Color Natural 自然色 颜 色 Natural 自然色 颜 色 12.8 15.8 16.4 M (6098-3802) 33.9 16.4 F (6098-3810) M (6098-3869) 12.8 13.2 33.9 F(6098-3909) 15.8 21 13.2 Color 21 Color Natural 自然色 颜 色 颜 色 Natural 自然色 14way 14way Color F(6098-7241) Natural 自然色 颜 色 15 15.8 20.8 33.9 18.8 21 Color 颜 色 M (6098-3877) F (6098-3917) 15.8 17.6 Natural 自然色 颜 色 21 Color 颜 色 Natural 自然色 Natural 自然色 16way 16way Color F(6098-6688) Natural 自然色 颜 色 13.75 12.8 29.6 26.4 33.9 A- 05 21 Color 颜 色 M (6098-7336) F (6098-4008) TS SERIES Natural 自然色 16way F(6098-6694) 12.8 12.8 21 26.4 26.4 Color 颜 色 21 Color Natural 自然色 19way Natural 自然色 颜 色 22way F (6098-7231) Color Natural 自然色 颜 色 15 15.8 21 23.2 Color 颜 色 29.6 Natural 自然色 M (6098-3885) 33.9 F(6098-3925) 15.8 26.4 21 Color 颜 色 24way 24way F (6098-4010) F(6098-6682) 12.8 35.2 12.8 21 Color 颜 色 Natural 自然色 28way 35.2 21 Color 颜 色 Natural 自然色 32way F (6098-4756) F(6098-4013) 12.8 39.6 Natural 自然色 12.8 21 44 Color 颜 色 Natural 自然色 21 Color 颜 色 Natural 自然色 40way 36way F(6098-4015) F (6098-4740) 12.8 A- 06 48.4 12.8 52.8 21 Color 颜 色 Natural 自然色 40way F (6098-4831) 12.8 52.8 21 Color 颜 色 Natural 自然色 21 Color 颜 色 Natural 自然色 TS SERIES for STANDARD 1.5mm (060) A- 07 Structure/构造 TS SERIES Housing M Terminal M Retainer sliding direction 通过压入锁片能够检知端子是否 插入到位 Retainer Connector M Connector F Terminal F Housing F Retainer sliding direction Retainer 通过压入锁片能够检知端子是否 插入到位 1.5mm(060) A- 08 Terminal(UNIT : mm) 端子(毫米) (3S) (S) F (8240-0339) Cable size(mm2) 0.3〜0.5 适用电线大小 Material 1.75 Cable size(mm ) 2 17.5 2.4 适用电线大小 Material 材 质 Surface treatment 表面处理 Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment 0.13 Heat-resistant copper alloy Tin-plated 镀锡 表面处理 M (8230-4925) (SS) 24 1.5 F(8240-0215) F (8240-0279) 1.75 Cable size(mm2) 18 2.4 适用电线大小 Material 材 质 Surface treatment 表面处理 0.22〜0.35 Heat-resistant copper alloy Tin-plated 镀锡 (M) Cable size(mm ) 适用电线大小 Material 材 质 Surface treatment 适用电线大小 Material 材 质 Surface treatment 表面处理 Cable size(mm2) 0.75〜1.25 0.3〜0.5 Heat-resistant copper alloy Tin-plated 镀锡 Material Surface treatment 表面处理 24 F (8240-0213) Cable size(mm2) 18 Heat-resistant copper alloy Tin-plated 镀锡 材 质 M (8230-4924) 1.75 2.0 适用电线大小 Brass 黄铜 Tin-plated 镀锡 1.5 2.4 2.4 Cable size(mm2) 18 (L) 2 表面处理 1.75 适用电线大小 Material 材 质 Surface treatment 表面处理 0.75〜1.25 Heat-resistant copper alloy Tin-plated 镀锡 24 1.5 M (8230-4923) 1.75 2.4 F(8240-0214) Cable size(mm2) 18 适用电线大小 Material 材 质 Surface treatment 表面处理 2.0 Heat-resistant copper alloy Tin-plated 镀锡 1.5mm(060) A- 09 TS SERIES Housing(UNIT : mm) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 A-08 Material 材 质 PBT 2way 4way Color Natural 自然色 颜 色 Color Natural 自然色 颜 色 13.05 13.05 36.4 M (6098-6050) 36.4 20.6 14.1 F (6098-6053) M (6098-5668) F(6098-5677) 12 12 21 11.7 21 17.4 Color Natural 自然色 颜 色 Color Natural 自然色 颜 色 8way 12way Color Color Natural 自然色 颜 色 Natural 自然色 颜 色 16.25 16.25 M (6098-5686) 36.4 36.4 19.1 25.5 F (6098-5695) M (6098-5704) F(6098-5713) 15.2 15.2 16 21 22.4 Color 颜 色 Natural 自然色 21 Color 颜 色 Natural 自然色 TS SERIES for STANDARD 2.3mm(090) A- 10 Structure/构造 Housing M Terminal M Retainer sliding direction 通过压入锁片能够检知端子是否 插入到位 Retainer Connector M Connector F Terminal F Housing F Retainer sliding direction Retainer 2.3mm(090) 通过压入锁片能够检知端子是否 插入到位 (SS) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 0.22〜0.35 Brass 黄铜 Tin-plated 镀锡 2.3 26.7 0.64 M (8230-4742) 3 Terminal(UNIT : mm) 端子(毫米) 18 F(8240-0029) Cable size(mm2) 适用电线大小 Material 2.8 材 质 Surface treatment 表面处理 0.22〜0.35 Brass 黄铜 Tin-plated 镀锡 (S)Au (S) Cable size(mm2) Cable size(mm2) 0.3〜0.5 适用电线大小 Material 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment 表面处理 材 质 26.7 2.3 Surface treatment 表面处理 0.3〜0.5 Brass 黄铜 Gold-plated 镀金 2.3 0.64 3 0.64 F (8240-4882) M (8100-1341) 3 18 Cable size(mm2) 适用电线大小 Material 材 质 2.8 Surface treatment 表面处理 0.3〜0.5 Brass 黄铜 Tin-plated 镀锡 (M) 18 F(8100-1346) Cable size(mm2) 适用电线大小 Material 材 质 2.8 Surface treatment 表面处理 Cable size(mm ) Cable size(mm2) 0.5〜1.25 适用电线大小 Material 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment 表面处理 材 质 26.7 2.3 M (8230-4502) 3 Surface treatment 表面处理 Brass 黄铜 Gold-plated 镀金 2.3 Cable size(mm2) Material 2.8 材 质 Surface treatment 表面处理 0.5〜1.25 Brass 黄铜 Tin-plated 镀锡 (L) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment M (8100-1342) 3 18 2.0 Brass 黄铜 Tin-plated 镀锡 26.7 2.3 0.64 M(8230-4512) 18 F (8240-4942) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 26.7 0.64 F(8240-4892) 适用电线大小 2.8 Brass 黄铜 Gold-plated 镀金 0.5〜1.25 0.64 3 0.3〜0.5 (M)Au 2 表面处理 A- 11 2.0 Heat-resistant copper alloy Tin-plated 镀锡 18 F(8100-1347) Cable size(mm2) 适用电线大小 2.8 Material 材 质 Surface treatment 表面处理 0.5〜1.25 Brass 黄铜 Gold-plated 镀金 TS SERIES M (8230-4492) 26.7 2way 2.3mm(090) Material 材 质 Color PA6T Natural 自然色 颜 色 14.6 A- 12 37.5 15.2 M (6520-0549) Housing(UNIT : mm) 6.7 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 F(6520-0550) 22 12.2 Material PA6T 材 质 A-10 Color Natural 自然色 颜 色 6way Material 材 质 Color 颜 色 Note 备 注 Material PBT 材 质 Color Natural 自然色 With clamp for 7mm dia. 带φ7用卡钉 PBT Natural 自然色 With body fastening clamp. 带防转卡钉 颜 色 Note 备 注 24.1 24.1 42.5 14.7 42.5 14.7 M (6240-1107) M (6249-1243) F(6240-5118) 17 10.8 22 Material PBT 材 质 Color Natural 自然色 颜 色 6way 9way M (6240-1120) Material 材 质 Color Natural 自然色 颜 色 16.4 PBT 19.4 21.1 38 Material 材 质 Color 颜 色 PBT 39.5 31.1 Natural 自然色 M (6249-1229) F(6248-5270) 8way M (6240-1077) 13.3 16.4 25.1 38 Material 材 质 Color 颜 色 PBT Natural 自然色 26.8 22 Material 材 质 Color 颜 色 PBT Natural 自然色 10way Material 材 质 Color 11way Material PBT Color Natural 自然色 颜 色 19.4 41 F (6248-5276) 18.4 22 30.8 Material Material PBT Color Natural 自然色 Natural 自然色 颜 色 22.4 21.4 40 25.1 F(6520-1004) M (6240-1122) 18.3 Material 22 21.1 PBT 材 质 Color F(6240-5175) Material 22 PBT 材 质 Color Natural 自然色 颜 色 Natural 自然色 颜 色 16way 20way Material PBT 材 质 Color Natural 自然色 颜 色 16.4 46.7 M (6240-1158) PBT Natural 自然色 16.4 54.7 38 F(6240-5088) 12 M (6240-1033) 38 F(6240-5035) 12 42.7 39.3 17 22.8 颜 色 PBT 材 质 M (6520-1009) Color Natural 自然色 颜 色 13way 27.1 材 质 PBT Color 12way Material Material 材 质 Natural 自然色 颜 色 颜 色 F(6248-5275) 22 PBT 材 质 Color Color M (6249-1234) 13.3 22.8 材 质 39.5 35.1 22 Material 材 质 Color 颜 色 51.7 PBT Natural 自然色 22 Material 材 质 Color 颜 色 PBT Natural 自然色 A- 13 TS SERIES M (6249-1235) Natural 自然色 颜 色 22 27.1 Material PBT 材 质 TS SERIES for STANDARD 4.8mm(187) A- 14 Structure/构造 Terminal M Housing M Retainer sliding direction Retainer 通过压入锁片能够检知端子是否 插入到位 Connector M Connector F Housing F Terminal F Retainer sliding direction Retainer 通过压入锁片能够检知端子是否 插入到位 4.8mm (187) Terminal(UNIT : mm) 端子(毫米) (S) (M) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 Cable size(mm2) 0.3〜0.5 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 材 质 4.8 26.7 Surface treatment 表面处理 0.5〜1.25 Brass 黄铜 Tin-plated 镀锡 4.8 0.8 6 18 F (8240-4912) 适用电线大小 Material 3.8 材 质 Surface treatment 表面处理 18 Cable size(mm2) Brass 黄铜 Tin-plated 镀锡 适用电线大小 Material 3.8 材 质 Surface treatment 表面处理 0.5〜1.25 Brass 黄铜 Tin-plated 镀锡 (L) Cable size(mm ) 2 适用电线大小 Material 材 质 Surface treatment F(8100-1555) 2.0〜3.0 Brass 黄铜 Tin-plated 镀锡 4.8 6 适用电线大小 材 质 3.8 Surface treatment 表面处理 2.0〜3.0 Heat-resistant copper alloy Tin-plated 镀锡 F(8240-4932) Cable size(mm2) 适用电线大小 3.8 Cable size(mm2) Material M (8230-4542) 18 18 26.7 0.8 6 F(8240-4922) 0.3〜0.5 (L) 表面处理 M (8230-4532) 6 Cable size(mm2) A- 15 0.8 Material 材 质 Surface treatment 表面处理 2.0〜3.0 Brass 黄铜 Tin-plated 镀锡 1way 4.8mm (187) Color Natural 自然色 颜 色 16.25 39 16.3 M (6098-0822) F(6098-0824) Housing(UNIT : mm) 接插件护套 (毫米) 14.8 Ref: Terminal part No. 端子参照页 A-14 Material 材 质 PBT 12.4 22 Color 颜 色 Natural 自然色 TS SERIES M (8230-4522) 26.7 2way 2way Color Color Natural 自然色 颜 色 Natural 自然色 颜 色 17.4 A- 16 17.4 39 20.4 M (6098-0323) 39 20.4 F (6098-0325) M (6098-0469) 18.75 F (6098-0471) 18.75 22 18.1 18.1 Color 22 Color Natural 自然色 颜 色 Natural 自然色 颜 色 3way 4way Color Natural 自然色 颜 色 Color Natural 自然色 颜 色 21.5 29.8 23.3 M (6098-0149) 39 F (6098-0151) 22.8 M (6098-1851) 39.5 F(6098-1489) 25.9 20.1 19.4 22 20.1 Color 22 Natural 自然色 颜 色 Color 颜 色 6way Natural 自然色 8way Color F(6098-0518) Natural 自然色 颜 色 26.6 29.8 42.5 29.6 M(6098-2211) F (6098-1716) 22 Color 颜 色 22 Color 颜 色 25.9 26.9 30.1 Natural 自然色 Natural 自然色 10way Color Natural 自然色 颜 色 21 47.6 F (6098-0156) 20.1 43.7 22 Color 颜 色 Natural 自然色 A- 17 TS SERIES M (6098-0154) 39 TS SERIES for STANDARD 8.0mm(312) A- 18 Structure/构造 Housing M Terminal M Retainer sliding direction 通过压入锁片能够检知端子是否 插入到位 Retainer Connector M Connector F Terminal F Housing F Retainer sliding direction 通过压入锁片能够检知端子是否 插入到位 Retainer 8.0mm(312) (S) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 0.5〜1.25 Brass 黄铜 Tin-plated 镀锡 8 32.3 0.8 M (8100-0520) 9.2 F(8100-0707) 23.4 Cable size(mm2) Terminal(UNIT : mm) 端子(毫米) 适用电线大小 5 Material 材 质 Surface treatment 表面处理 0.5〜1.25 Brass 黄铜 Tin-plated 镀锡 (M) (L) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 Cable size(mm2) 2.0〜3.0 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 材 质 32.3 8 Surface treatment 表面处理 5.0〜8.0 Brass 黄铜 Tin-plated 镀锡 32.3 8 A- 19 0.8 0.8 9.2 F (8100-2493) 23.4 9.2 Cable size(mm2) 适用电线大小 Material 5 M (8100-0522) 材 质 Surface treatment 表面处理 F (8100-1553) 23.4 Cable size(mm2) 2.0〜3.0 5.0〜8.0 适用电线大小 Heat-resistant copper alloy Tin-plated 镀锡 Material 5 Heat-resistant copper alloy Tin-plated 镀锡 材 质 Surface treatment 表面处理 1way 8.0mm (312) Color Natural 自然色 颜 色 20.5 20.5 44.8 M (6240-1093) Housing(UNIT : mm) F(6098-0441) 16.6 接插件护套 (毫米) 22.7 Ref: Terminal part No. 端子参照页 A-18 Material 材 质 PBT 27.8 Color 颜 色 Natural 自然色 3way 2way Color F(6520-1466) Natural 自然色 颜 色 24.55 19.85 28.3 M (6098-1278) 29.7 47.8 27.8 Color 颜 色 Natural 自然色 F (6098-1104) 4way F(6098-2137) 20.65 20.15 24 44.2 27.8 Color 颜 色 Natural 自然色 27.8 Color 颜 色 Natural 自然色 TS SERIES M (8100-0521) 0.64mm, 1.5mm (025, 060) A- 20 Housing(UNIT : mm) 接插件护套(毫米) Ref: Terminal part No. 端子参照页 [0.64mm] A-02 [1.5mm] A-08 TS SERIES for HYBRID No. of way/( )corresponds to 0.64mm, 1.5mm, in order from left to right. 极数/( )内显示 :从左向右为0.64mm 极数、1.5mm 极数 12way(4+8) 12way(6+6) Color Material 材 质 Color Natural 自然色 颜 色 PBT Natural 自然色 颜 色 17.15 16.95 36.4 36.4 26.3 M (6098-6055) 25.5 F (6098-6083) 15.7 M (6098-6104) F(6098-6111) 15.9 21 21 23.2 22.4 Color Color Natural 自然色 颜 色 18way(8+10) 12way(8+4) Color Color Natural 自然色 颜 色 Natural 自然色 颜 色 Natural 自然色 颜 色 16.95 20.15 36.4 36.4 24.3 M (6098-6090) F (6098-6097) 25.5 M (6098-5650) F(6098-5659) 15.7 15.7 21 21 21.2 22.4 Color 颜 色 Natural 自然色 Color 颜 色 Natural 自然色 18way(12+6) 18way(10+8) Color Color Natural 自然色 颜 色 Natural 自然色 颜 色 16.95 16.95 36.4 36.4 35.1 32.9 F (6098-5604) M (6098-5631) F(6098-5641) 15.7 15.7 21 21 32 29.8 Color Color Natural 自然色 颜 色 Natural 自然色 颜 色 20way(16+4) Color Natural 自然色 颜 色 16.95 36.4 33.1 M (6098-5613) F (6098-5622) 15.7 30 21 Color 颜 色 Natural 自然色 17way(8+9) 0.64mm, 2.3mm (025, 090) Color Natural 自然色 颜 色 23.9 25.4 Housing(UNIT : mm) M (6098-3893) F(6098-3933) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 Material 材 质 [0.64mm]A-02 [2.3mm] A-10 23.9 PBT No. of way/( )corresponds to 0.64mm, 2.3mm, in order from left to right. 极数/( )内显示 :从左向右为0.64mm 极数、2.3mm 极数 22.2 36 22 Color 颜 色 Natural 自然色 TS SERIES M (6098-5594) A- 21 18way(10+8) Color 20way(16+4) Color Natural 自然色 颜 色 Natural 自然色 颜 色 20.25 20.25 A- 22 32.6 M (6098-3901) 36 F (6098-3941) 31.2 M (6098-3818) 16.75 29.4 36 F(6098-3826) 16.75 22 22 28 Color 颜 色 Color Natural 自然色 Natural 自然色 颜 色 0.64mm, 4.8mm (025, 187) Housing(UNIT : mm) 20way(18+2) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 Material 材 质 F(6098-5903) [0.64mm]A-02 [4.8mm] A-14 16.6 PBT 38.9 No. of way/( )corresponds to 0.64mm, 4.8mm, in order from left to right. 极数/( )内显示 :从左向右为0.64mm 极数、4.8mm 极数 22 Color Natural 自然色 颜 色 14way(12+2) 2.3mm, 4.8mm (090, 187) Color 颜 色 Natural 自然色 23.9 34.8 Housing(UNIT : mm) M (6241-0261) 40 F(6245-0281) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 Material 材 质 [2.3mm]A-10 [4.8mm]A-14 20.1 PBT No. of way/( )corresponds to 2.3mm, 4.8mm, in order from left to right. 极数/( )内显示 :从左向右为2.3mm 极数、4.8mm 极数 30.9 22 Color 颜 色 Natural 自然色 15way(12+3) Color 20way(18+2) Natural 自然色 颜 色 Color 颜 色 Natural 自然色 23.9 30.2 F (6245-0261) F(6245-0301) 20.1 26.4 25.6 M (6241-0281) 40 38.9 22 Color 颜 色 Natural 自然色 22 Color 颜 色 Natural 自然色 TS SERIES M (6241-0241) A- 23 42.8 40 29.5 0.64mm (025) A- 24 TS SERIES for PCB Housing(UNIT : mm) 接插件护套(毫米) 16way M (6098-6790) ●Detailed dimension  详细尺寸 10 Connector F part No. 母端接插件产品号码 Material 材 质 Color 颜 色 6098-4008(A-05) 24.47 PBT ●Recommended demension of Circuit board  电路板推荐尺寸 38.3 Natural 自然色 t=1.6 16way M (6098-6793) ●Detailed dimension  详细尺寸 10 Connector F part No. 母端接插件产品号码 Material 材 质 Color 颜 色 ●Recommended demension of Circuit board  电路板推荐尺寸 6098-4008(A-05) 24.47 SPS 38.3 Natural 自然色 t=1.6 33way M (6098-7229) ●Detailed dimension  详细尺寸 11.5 Connector F part No. 母端接插件产品号码 Material 材 质 Color 颜 色 ●Recommended demension of Circuit board  电路板推荐尺寸 6098-7231(A-05) 6098-7241(A-04) SPS Natural 自然色 50.1 21.3 t=1.6 36way M (6098-6796) ●Detailed dimension  详细尺寸 10 Connector F part No. 母端接插件产品号码 材 质 Color 颜 色 24.47 PBT A- 25 ●Recommended demension of Circuit board  电路板推荐尺寸 60.3 Natural 自然色 t=1.6 36way M (6098-6798) ●Detailed dimension  详细尺寸 10 Connector F part No. 母端接插件产品号码 Material 材 质 Color 颜 色 ●Recommended demension of Circuit board  电路板推荐尺寸 6098-4740(A-06) 24.47 SPS 60.3 Natural 自然色 t=1.6 56way(16+16+24) M (6098-6848) ●Detailed dimension  详细尺寸 10 Connector F part No. 母端接插件产品号码 Material 材 质 Color 颜 色 6098-6688(A-05) 6098-6694(A-05) 6098-6682(A-05) 103.3 SPS 24.47 ●Recommended demension of Circuit board  电路板推荐尺寸 Natural 自然色 t=1.6 60way(36+24) M (6098-6803) ●Detailed dimension  详细尺寸 10 Connector F part No. 母端接插件产品号码 Material 材 质 Color 颜 色 ●Recommended demension of Circuit board  电路板推荐尺寸 6098-4010(A-05) 6098-4740(A-06) SPS 97.2 24.47 Natural 自然色 t=1.6 68way(40+28) M (6098-6805) ●Detailed dimension  详细尺寸 10 Connector F part No. 母端接插件产品号码 Material 材 质 Color 颜 色 ●Recommended demension of Circuit board  电路板推荐尺寸 6098-4756(A-05) 6098-4831(A-06) PBT Natural 自然色 106 24.47 t=1.6 TS SERIES Material 6098-4740(A-06) 68way(40+28) M (6098-7102) ●Detailed dimension  详细尺寸 10 A- 26 Connector F part No. 母端接插件产品号码 Material 材 质 Color 颜 色 ●Recommended demension of Circuit board  电路板推荐尺寸 6098-4756(A-05) 6098-4831(A-06) SPS 24.47 106 Natural 自然色 t=1.6 68way(40+28) M (6098-6810) Connector F part No. 母端接插件产品号码 Material 材 质 Color 颜 色 ●Detailed dimension  详细尺寸 ●Recommended demension of Circuit board  电路板推荐尺寸 6098-4756(A-05) 6098-4015(A-06) PBT Blue 蓝 t=1.6 0.64mm, 1.5mm (025, 060) Housing(UNIT : mm) 接插件护套 (毫米) No. of way/( )corresponds to 0.64mm, 1.5mm, in order from left to right. 极数/( )内显示 :从左向右为0.64mm 极数、1.5mm 极数 20way(14+6) M (6098-6869) ●Detailed dimension  详细尺寸 8.5 Connector F part No. 母端接插件产品号码 Material 材 质 Color 颜 色 ●Recommended demension of Circuit board  电路板推荐尺寸 6098-6876(A-●) LCP Black 黒 41.4 25 t=1.2 TS SEALED SERIES Features The TS sealed connector series has a mechanism of terminal position assurance. This series consists of 0.64mm, 2.3mm, 4. 8mm and 8.0 mm t ypes classified according to terminal size, covering an extensive array of applications from signal to power circuits. ◦ Retainers are pre-mounted on the connector housing, and are structured to enable setting by the same simple operation regardless of the number of ways, improving operability. ◦ T hese connectors can be directly secured to a bracket on the car body. ◦ RoHS/ELV Compliant 特 点 TS 防水系列接插件具有检测端子插入不足的结构。 按照端子尺寸划分为0.64mm·2.3mm·4.8mm· 8.0mm,从信号回路到电源回路,能广泛应用。 ◦锁片预先组装在接插件护套上,无论多少极数 都能通过简单操作组合,有助于提高操作效率。 ◦接插件可以直接固定在车体的支架上。 ◦可对应欧盟 RoHS 和 ELV 指令 TS SEALED SERIES for STANDARD 0.64mm (025) B- 02 Structure/构造 Wire seal Terminal M Wire seal Housing M Retainer Terminal M Housing M Connector M Retainer Connector F Housing F Wire seal Housing F Connector Seal Terminal F Front holder Wire seal Connector seal Retainer Front holder Retainer Terminal F 0.64mm (025) B- 03 TS SEALED SERIES Terminal(UNIT : mm) 端子(毫米) (S) F (8240-0336) (S) F(8240-0337) 2 1.5 2 15.8 Cable size(mm2) 适用电线大小 Material 材 质 2 Surface treatment 表面处理 1.5 0.13 Heat-resistant copper alloy Tin-plated 镀锡 适用电线大小 Material 材 质 Surface treatment 表面处理 Cable size(mm2) 适用电线大小 Material 材 质 2 Surface treatment 表面处理 Cable size(mm2) 0.22〜0.5 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 材 质 23.5 0.64 M (8100-3617) Surface treatment 表面处理 F (8100-3455) Cable size(mm2) Material 材 质 2 Surface treatment 表面处理 0.22〜0.35 Heat-resistant copper alloy Tin-plated 镀锡 0.22〜0.5 Brass 黄铜 Gold-plated 镀金 23.5 0.64 F(8100-3456) 1.5 15.8 Cable size(mm2) 适用电线大小 Material 材 质 2 Surface treatment 表面处理 0.22〜0.35 Heat-resistant copper alloy Gold-plated 镀金 (L) (L) Au F(8240-0288) F(8240-0287) 2 2 15.8 Cable size(mm2) 适用电线大小 Material 2 Heat-resistant copper alloy Gold-plated 镀金 2 15.8 适用电线大小 1.5 0.13 Au M (8100-3708) 2 1.5 15.8 (M) (M) Cable size(mm2) Au 材 质 Surface treatment 表面处理 0.5 Heat-resistant copper alloy Tin-plated 镀锡 1.5 15.8 Cable size(mm2) 适用电线大小 Material 2 材 质 Surface treatment 表面处理 0.5 Heat-resistant copper alloy Gold-plated 镀金 0.64mm (025) B- 04 Wire seals(UNIT : mm) (3S) (7165-1423) 电线密封栓 (毫米) Cable size(mm ) 2 ◦ The wire seals are common to M and F.  *A wireseal depends on a chosen cable. 适用电线大小 ◦电线密封栓为公端、母端共用。 材 质 (7165-1043) Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Color 颜 色 φ 2.75 (CHFUS/0.22) Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Color 颜 色 材 质 Color 颜 色 (7165-1198) 适用电线大小 适用电线大小 Material 7.4 (AVSS/0.3) (AVSSH/0.3) (AESSX/0.3) φ 2.9 Silicon 硅 Dark Yellow 深黄色 7 (CHFUS/0.35〜0.5) φ 2.9 1.1〜1.4 Silicon 硅 Violet 紫 7.4 (7165-1199) Cable size(mm2) Cable overall diameter(mm) 带绝缘层外径 Material 7.4 Silicon 硅 Light Brown 浅棕 (L) 适用电线大小 1.4〜1.5 0.85〜0.95 (7165-1312) Cable size(mm2) 带绝缘层外径 Silicon 硅 Green 绿 φ 2.9 (S) Cable overall diameter(mm) 0.95〜1.05 (M) Cable size(mm2) Material 颜 色 (SS) 适用电线大小 带绝缘层外径 Color ※不同的电线使用不同的电线密封栓。 Cable size(mm2) Cable overall diameter(mm) (CHFUS/0.13) 材 质 Color 颜 色 (AVSS/0.5) (AVSSH/0.5) (AVSSX/0.5) (AESSX/0.5) φ 2.9 1.6〜1.7 Silicon 硅 Red Violet 紫红 7.4 0.64mm (025) Dummy plugs(UNIT : mm) 盲塞(毫米) (7165-0797) ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 φ 2.8 Material 材 质 Color 颜 色 NBR Light Gray 浅灰 6.4 2way 0.64mm(025) Color Black 黒 颜 色 39.2 24.5 Housing(UNIT : mm) 18 M (6188-4797) Ref: Terminal part No. 端子参照页 B-03 Ref: wire seal No. 电线密封栓参照页 B-04 Ref: Dummy plug No. 盲塞参照页 B-04 Material 材 质 PBT F(6189-1161) 16.8 17.4 21.9 Color Black 黒 颜 色 2way 3way F (6189-7020) Color Black 黒 颜 色 16.8 18.3 17.4 21.9 39.2 Color 颜 色 18.2 Black 黒 M (6188-4920) F (6189-1129) 2way F (6189-7073) 16.8 16.8 17.4 21.9 20.4 Color 颜 色 21.9 Color Gray 灰 颜 色 Black 黒 4way 3way F(6189-1231) F (6189-1132) 19.8 16.8 20.4 21.9 Color 颜 色 17.4 Gray 灰 4way 21.9 Color 颜 色 Gray 灰 5way F (6189-7401) F(6189-1046) 16.8 16.8 23.4 21.9 Color 颜 色 Black 黒 26.4 21.9 Color 颜 色 Black 黒 TS SEALED SERIES 接插件护套 (毫米) B- 05 6way 6way Color F(6189-1083) Natural 自然色 颜 色 16.8 18.6 B- 06 29.4 39.2 11.4 21.9 Color Black 黒 颜 色 M (6188-0706) F (6189-1142) 6way F (6189-7100) 24.8 16.8 15.2 29.4 21.9 Color Natural 自然色 颜 色 21.9 Color Black 黒 颜 色 8way 10way Color Color Gray 灰 颜 色 Black 黒 颜 色 21.6 20.8 M (6188-0779) 18.6 39.2 F (6189-1240) 39.2 23.8 M (6188-0696) F(6189-1134) 19.8 19.8 23.4 26.4 21.9 Color 颜 色 21.9 Color Gray 灰 12way Black 黒 颜 色 13way F(6189-1128) Color Gray 灰 颜 色 19.8 21.7 29.4 21.9 39.2 Color 颜 色 Black 黒 29.8 M (6188-4914) F(6189-1092) 12way F(6189-1133) 19.8 19.8 29.4 32.4 21.9 Color 颜 色 Gray 灰 21.9 Color 颜 色 Gray 灰 15way 17way F (6189-1135) F(6189-7110) 30.8 30.8 32.3 32.3 48.2 Color 颜 色 57.2 Gray 灰 颜 色 Gray 灰 30way F (6189-7167) 32.1 F (6189-6987) 33.5 32.3 34.55 57.2 63 Color 颜 色 Black 黒 Color 颜 色 Gray 灰 B- 07 TS SEALED SERIES 20way Color TS SEALED SERIES for STANDARD 0.64W (025W) B- 08 Structure/构造 Wire seal Housing M Terminal M Retainer Housing M Terminal M Wire seal Connector M Connector F Housing F Housing F Retainer Connector Seal Wire seal Terminal F Front holder Wire seal Retainer Connector seal Front holder Retainer Terminal F 防水0.64W 型接插件与0.64型相比,因为扩大了端子孔腔间的距离,所以不具备互换性。 (为了区别于现有的防水0.64型,称呼为防水0.64W 型。 ) Since 0.64W has wider terminal pitch, there is no compatibility between 0.64 and 0.64W. (These connectors are called "0.64W series" to distinguish from existing 0.64 series.)  0.64W (025W) Terminal(UNIT : mm) 端子(毫米) Ref; 0.64mm Terminal detail 0.64mm端子参照页 M(Sn)M (8100-3617)  B-03 M(Au)M (8100-3708)  B-03 F(8100-3455)  B-03 F(8100-3456)  B-03 (LL) (LL) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 FPW/0.6 CIVUS/0.5  AVSS/0.5 AVSSX/0.5   AVSSH/0.5 IVSSH/0.5  AESSX/0.5 CHFUS/0.5  HFSS/0.5 Brass 黄铜 Tin-plated 镀锡 Cable size(mm2) 15.8 适用电线大小 Material 材 质 2 适用电线大小 23.5 0.64 Surface treatment 表面处理 Material 材 质 Surface treatment 表面处理 CIVUS/0.5 AVSS/0.5  AVSSX/0.5 AVSSH/0.5  IVSSH/0.5 AESSX/0.5  CHFUS/0.5 HFSS/0.5 Brass 黄铜 Gold-plated 镀金 23.5 0.64 B- 09 F (8240-0500) 2 1.5 Cable size(mm2) FPW/0.6 CIVUS/0.5  AVSS/0.5 AVSSX/0.5  AVSSH/0.5 IVSSH/0.5  AESSX/0.5 CHFUS/0.5   HFSS/0.5 Heat resistant copper-alloy 耐熱铜合金 Tin-plated 镀锡 M (8230-5361) F(8240-0501) 2 1.5 15.8 Cable size(mm2) 适用电线大小 Material 2 材 质 Surface treatment 表面处理 CIVUS/0.5 AVSS/0.5  AVSSX/0.5 AVSSH/0.5  IVSSH/0.5 AESSX/0.5  CHFUS/0.5 HFSS/0.5 Heat resistant copper-alloy  耐熱铜合金 Gold-plated 镀金 0.64W (025W) (S) Wire seals(UNIT : mm) (7165-1608) Cable size(mm2) 电线密封栓 (毫米) 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 The wire seals are common to M and F. Material 电线密封栓为公端、母端共用。 Color 材 质 颜 色 (M) (7165-1607) Cable size(mm ) 2 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Color 颜 色 AVSS/0.3 AVSSH/0.3  IVSSH/0.35 HFSS/0.35 φ 3.5 Silicon 硅 Dark Green 墨绿 Cable size(mm2) 适用电线大小 带绝缘层外径 Material 7 φ 3.5 1.1〜1.4 Silicon 硅 Dark Gray 深灰 7 (L) Cable overall diameter(mm) 1.3〜1.5 CIVUS/0.35〜0.5 CHFUS/0.35〜0.5 材 质 Color 颜 色 FPW/0.6 AVSS/0.5  AVSSH/0.5 AVSSX/0.5  IVSSH/0.5 HFSS/0.5 (7165-1606) φ 3.5 1.51〜1.73 Silicon 硅 Dark Brown 深棕 7 TS SEALED SERIES M (8230-5360) Au 0.64W (025W) B- 10 Dummy plugs(UNIT : mm) 盲塞(毫米) (7165-1605) ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 φ 3.4 Material Silicon 硅 Indian Red 印度紅 材 质 Color 颜 色 6.4 4way 0.64W (025W) Color Black 黒 颜 色 18.2 39.2 Housing(UNIT : mm) 接插件护套 (毫米) 16.3 M (6188-5516) Ref: Terminal part No. 端子参照页 B-08 Ref: wire seal No. 电线密封栓参照页 B-09 Ref: Dummy plug No. 盲塞参照页 B-10 Material 材 质 PA6T F(6189-7449) 24.75 19.4 24.4 Color 颜 色 Black 黒 0.64W, 2.3mm, 4.8mm (025W, 090, 187) Housing(UNIT : mm) 接插件护套(毫米) TS SEALED SERIES for HYBRID Ref: Terminal part No. 端子参照页 [0.64W]   B-08 [2.3mm]  B-13(for P06) [4.8mm]  B-19 Ref: wire seal No. 电线密封栓参照页 [0.64W]    B-09 [2.3mm]  B-14(for P06) [4.8mm]  B-20 Ref: Dummy plug No. 盲塞参照页 [0.64W]   B-10 [2.3mm]  B-15(for P06) [4.8mm]  B-21 Material 材 质 PBT No. of way/( )corresponds to 0.64W, 2.3mm, 4.8mm in order from left to right. 极数/( )内显示 :从左向右为0.64mm 极数、2.3mm 极数、4.8mm 极数   Slide Lever 38way (34+2+2) F (6189-7435) 29.9   Slide Lever 38way (34+2+2) F(6189-7436) 29.9 41.7 41.7 80.3 Color 颜 色 80.3 Black 黒 颜 色 F(6189-7433) 29.9 37.3 Black 黒 B- 11   Swing + Slide Lever 38way (34+2+2) F(6189-7434) 29.9 37.3 77.3 Color 颜 色 77.3 Black 黒 Color 颜 色 Black 黒 Lever Assy F (6911-5774) 88.3 43.5 Color 31.2 Black 黒 颜 色   Slide Lever 46way(38+4+4) F (6189-7546) 29.9 43.6   Slide Lever 46way(38+4+4) F(6189-7547) 29.9 43.6 95.5 Color 颜 色 Black 黒 95.5 Color 颜 色 Black 黒 TS SEALED SERIES   Swing + Slide Lever 38way (34+2+2) Color TS SEALED SERIES for STANDARD 2.3mm (090) B- 12 Structure/构造 Wire seal Housing M Wire seal Terminal M Retainer Housing M Terminal M Retainer Connector M Connector F Housing F Connector Seal Wire seal Terminal F Retainer Housing F Wire seal Connector seal Retainer 2.3mm (090) Terminal(UNIT : mm) 端子(毫米) Terminal F (S) (S) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 Au Cable size(mm2) 0.3〜0.5 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 材 质 25.9 2.3 Surface treatment 表面处理 0.3〜0.5 Brass 黄铜 Gold-plated 镀金 0.64 3 17 F (8100-0460) M (8100-1340) 3 Cable size(mm2) 适用电线大小 Material 2.8 0.64 材 质 Surface treatment 表面处理 17 0.3〜0.5 Heat-resistant copper alloy Tin-plated 镀锡 (M) F(8100-1344) Cable size(mm2) 适用电线大小 Material 2.8 材 质 Surface treatment 表面处理 Cable size(mm ) 适用电线大小 Material 材 质 Surface treatment 表面处理 Cable size(mm ) 0.5〜1.25 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 材 质 25.9 2.3 M (8100-0458) 3 Surface treatment 表面处理 0.5〜1.25 Brass 黄铜 Gold-plated 镀金 17 Material 2.8 M (8100-1007) 3 Cable size(mm2) 材 质 Surface treatment 表面处理 25.9 2.3 0.64 F (8100-0461) 适用电线大小 17 0.5〜1.25 Heat-resistant copper alloy Tin-plated 镀锡 (L) F (8100-0594) Cable size(mm2) 适用电线大小 Material 2.8 材 质 Surface treatment 表面处理 0.5〜1.25 Heat-resistant copper alloy Gold-plated 镀金 (L) Cable size(mm ) 2 适用电线大小 Material 材 质 Surface treatment Au Cable size(mm ) 2 2.0 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 材 质 25.9 2.3 Surface treatment 表面处理 2.0 Brass 黄铜 Gold-plated 镀金 M (8100-0459) 17 0.64 F (8100-0462) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 25.9 2.3 0.64 2.8 Heat-resistant copper alloy Gold-plated 镀金 Au 2 0.64 3 0.3〜0.5 (M) 2 表面处理 B- 13 M (8100-1008) 3 2.0 Heat-resistant copper alloy Tin-plated 镀锡 17 F (8100-0817) Cable size(mm2) 适用电线大小 2.8 Material 材 质 Surface treatment 表面处理 2.0 Heat-resistant copper alloy Gold-plated 镀金 TS SEALED SERIES M (8100-0457) 25.9 2.3 2.3mm(090) B- 14 Wire seals(UNIT : mm) 电线密封栓 (毫米) The wire seals are common to M and F. ◦ P5 : For 5mm pitch housing/Please inquire us  for the details. ◦ P6 : For 6mm pitch housing 电线密封栓为公端、母端共用。 ◦ P5 :5mm 间距用/请另行咨询。 ◦ P6 :6mm 间距用 (SS) (P6) (7165-0842) Cable size(mm2) 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Color 颜 色 (CHFUS/0.35〜0.5) 1.1〜1.4 φ 5.7 Silicon 硅 Blue 蓝 8.5 (S) (P6) (S) (P5) (7165-0342) (7165-0349) Cable size(mm2) 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Color 颜 色 (AVX・AEX/0.3) (AVS/0.3) (AVSS/0.3〜0.85) (AVSSX・AESSX/0.3〜0.75) (CAVUS/0.85〜1.25) 1.4〜2.0 Cable size(mm2) 适用电线大小 Cable overall diameter(mm) φ 5.7 带绝缘层外径 Material Silicon 硅 Dark Brown 深棕 材 质 Color 颜 色 8.5 (M) (P6) (AVX・AEX/0.3) (AVS/0.3) (AVSS/0.3〜0.85) (AVSSX・AESSX/0.3〜0.75) (CAVUS/0.85〜1.25) 1.4〜2.0 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Color 颜 色 (AV/0.5) (AVX・AEX/0.5〜0.75) (AVS/0.5〜0.85) (AVSS/1.25) (AVSSX・AESSX/1.25) 2.0〜2.5 (P5) (7165-0343) Cable size(mm2) 适用电线大小 Cable overall diameter(mm) φ 5.7 带绝缘层外径 Material Silicon 硅 Dark Green 墨绿 材 质 Color 颜 色 8.5 (L) (P6) (AV/0.5) (AVX・AEX/0.5〜0.75) (AVS/0.5〜0.85) (AVSS/1.25) (AVSSX・AESSX/1.25) 2.0〜2.5 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Color 颜 色 (AV/1.25) (AVX・AEX/1.25) (AVS/1.25) (AVSS/2.0) (AVSSX・AESSX/2.0) 2.5〜2.9 Silicon 硅 Dark Gray 深灰 (P5) (7165-0344) 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Color 8.5 8.5 (L) Cable size(mm2) φ 5.7 φ 4.9 Silicon 硅 Black 黒 (7165-0351) Cable size(mm2) 8.5 (M) (7165-0395) Cable size(mm2) φ 4.9 Silicon 硅 Brown 棕 颜 色 (AV/1.25) (AVX・AEX/1.25) (AVS/1.25) (AVSS/2.0) (AVSSX・AESSX/2.0) 2.5〜2.9 Silicon 硅 Dark Blue 藏青 φ 4.9 8.5 (P6) 2.3mm (090) (7160-9465) φ 5.6 Dummy plugs(UNIT : mm) 盲塞(毫米) Material NBR 材 质 Color ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 ◦ P5 :5mm 间距用/请另行咨询。 ◦ P6 :6mm 间距用 (P5) (7161-9787) φ 4.7 Material NBR 材 质 Color 6.4 Brown 棕 颜 色 2way 2.3mm(090) Color Gray 灰 颜 色 19.1 37.7 19.9 Housing(UNIT : mm) 接插件护套 (毫米) M (6188-0047) Ref: Terminal part No. 端子参照页 B-13 Ref: wire seal No. 电线密封栓参照页 B-14 Ref: Dummy plug No. 盲塞参照页 B-15 Material 材 质 PBT F(6189-0100) 26.3 30 23.7 Color Gray 灰 颜 色 2way 2way Color Gray 灰 颜 色 Color Gray 灰 颜 色 17.9 22.1 17.2 M (6188-0108) 17.4 37.7 F (6189-0199) M (6188-0266) F(6189-0249) 21.25 24.9 24 24 21 20.7 Color 颜 色 37.2 Gray 灰 Color 颜 色 Gray 灰 B- 15 TS SEALED SERIES ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. ◦ P5 : For 5mm pitch housing/Please inquire us  for the details. ◦ P6 : For 6mm pitch housing 6.4 Black 黒 颜 色 2way 2way Color Gray 灰 颜 色 Color Natural 自然色 颜 色 21.65 17.9 43.2 B- 16 M (6188-0229) 37.2 17.4 19.5 F (6189-0388) 15.1 M (6188-0624) F(6189-0264) 21.25 14.2 24 24 Color 20.7 Gray 灰 颜 色 Color Gray 灰 颜 色 P5 2way P5 2way F(6189-0573) F (6189-0566) 21.8 21.8 Ref: Wire seal No. B-10(For P5) 电线密封栓参照页 31 Ref: Dummy plug No. B-11(For P5) Color Gray 灰 盲塞参照页 22 颜 色 Ref: Wire seal No. B-10(For P5) Ref: Dummy plug No. B-11(For P5) Color Gray 灰 电线密封栓参照页 31 盲塞参照页 22 颜 色 P5 2way F(6189-0611) 26 24 Ref: Wire seal No. B-10(For P5) Ref: Dummy plug No. B-11(For P5) Color Gray 灰 电线密封栓参照页 盲塞参照页 15.55 颜 色 3way(T Type) 2way Color Gray 灰 颜 色 Color Gray 灰 颜 色 25.9 13.6 M (6188-0470) 37.7 20.8 17.2 F (6189-0682) 23 M (6188-0099) F(6189-0179) 28.9 28 24 22.8 Color 颜 色 Gray 灰 24.5 Color 颜 色 Gray 灰 3way(E Type) 4way Color F(6189-0694) Gray 灰 颜 色 18.9 26.4 38.2 25.2 26 Color 26.3 F (6189-0443) B- 17 4way F(6189-7398) 24 19.3 28.4 26 Material 29.5 Color 颜 色 PA6T 材 质 24.05 Gray 灰 Color Black 黒 颜 色 4way 4way Color Color Black 黒 颜 色 Gray 灰 颜 色 21.75 37.7 27.7 M (6188-0517) 37.7 21.8 20.35 F (6189-0629) M (6188-0066) F(6189-0126) 30.1 30.85 30 24 24.05 25.6 Color Color Gray 灰 颜 色 Gray 灰 颜 色 4way 4way Color Color Gray 灰 颜 色 Gray 灰 颜 色 28.4 30.6 43.2 42.6 20.3 18.8 M (6188-0141) Plate thickness range for clamp: t=0.7〜2.2 F (6189-0381) F(6189-0372) 21.2 21.4 14.2 M (6188-0217) 15.5 24 Color 颜 色 Gray 灰 24 Color 颜 色 Gray 灰 TS SEALED SERIES M (6188-0282) Black 黒 颜 色 5way 4way Color Color Gray 灰 颜 色 Gray 灰 颜 色 18.3 37.9 24.1 B- 18 M (6188-0472) F (6189-0685) M (6188-0327) F(6189-0504) 26.2 31.7 24 25.6 Color 28 Gray 灰 颜 色 Color Gray 灰 颜 色 6way 6way Color Color Gray 灰 颜 色 Gray 灰 颜 色 25.5 23.7 28.2 42.2 M (6188-0173) F (6189-0319) 24 24 37.9 F(6189-0323) 28.5 30.9 Color Color Gray 灰 颜 色 Gray 灰 颜 色 7way 6way 颜 色 M (6188-0175) 21.8 20.8 Color 25.6 Color Gray 灰 Gray 灰 颜 色 31.4 33.7 43.2 37.7 25.5 25.2 Plate thickness range for clamp: t=0.7〜2.2 M (6188-0209) F (6189-0368) M (6188-0067) F(6189-0127) 36.2 21.8 22.2 30 24 Color 颜 色 Gray 灰 29 Color 颜 色 Gray 灰 TS SEALED SERIES for STANDARD 4.8mm (187) Structure/构造 B- 19 Wire seal Wire seal Terminal M Retainer Housing M Terminal M Retainer Connector M Connector F Connector Seal Housing F Retainer Wire seal Terminal F Retainer Housing F Wire seal Connector seal 4.8mm(187) Terminal F (S) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 0.3〜0.5 Brass 黄铜 Tin-plated 镀锡 4.8 28.4 0.8 M (8100-0463) 6 F(8100-0466) 19.5 Cable size(mm2) Terminal(UNIT : mm) 端子(毫米) 适用电线大小 3.8 Material 材 质 Surface treatment 表面处理 0.3〜0.5 Brass 黄铜 Tin-plated 镀锡 TS SEALED SERIES Housing M (M) (L) Cable size(mm2) Cable size(mm2) 0.5〜1.25 适用电线大小 Material 材 质 Surface treatment 表面处理 2.0〜3.0 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment 4.8 表面处理 28.4 4.8 0.8 B- 20 M (8100-0464) 6 0.8 F (8100-0467) M (8100-0465) 6 19.5 Cable size(mm2) Material Cable size(mm2) Surface treatment 表面处理 2.0〜3.0 适用电线大小 Brass 黄铜 Tin-plated 镀锡 材 质 F (8100-0468) 19.5 0.5〜1.25 适用电线大小 3.8 28.4 Material 3.8 Heat-resistant copper alloy Tin-plated 镀锡 材 质 Surface treatment 表面处理 4.8mm(187) Wire seals(UNIT : mm) 电线密封栓 (毫米) The wire seals are common to M and F. 电线密封栓为公端、母端共用。 (M) (S) (7165-0347) (7165-0346) Cable size(mm2) 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material (AVS/0.3) (AVSS/0.3〜0.85) (AVSSX・AESSX/0.5〜0.75) (CAVUS/0.85〜1.25) Color 颜 色 适用电线大小 Cable overall diameter(mm) φ8 1.4〜2.0 带绝缘层外径 Material Silicon 硅 Dark Brown 深棕 材 质 Cable size(mm2) Color 颜 色 (7165-0356) (7165-0348) Cable size(mm ) 2 适用电线大小 Cable overall diameter(mm) Material 材 质 Color 颜 色 11.7 (LL) (L) 带绝缘层外径 φ8 2.0〜2.9 Silicon 硅 Dark Green 墨绿 材 质 11.7 (AV/0.5〜1.25) (AVX・AEX/0.5〜1.25) (AVS/0.5〜1.25) (AVSS/1.25〜2.0) (AVSSX・AESSX/1.25〜2.0) Cable size(mm ) 2 (AV/2.0) (AVX・AEX/2.0) (AVS/2.0) 2.9〜3.5 Silicon 硅 Dark Gray 深灰 适用电线大小 Cable overall diameter(mm) φ8 带绝缘层外径 Material 材 质 Color 11.7 颜 色 (AV/3.0) (AVX・AEX/3.0) (AVS/3.0) 3.5〜4.1 Silicon 硅 Dark Blue 藏青 φ8 11.7 4.8mm(187) B- 21 盲塞(毫米) (7165-0145) ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 φ8 Material NBR 材 质 Color Gray 灰 颜 色 8 1way 4.8mm(187) Color Gray 灰 颜 色 24.3 44 Housing(UNIT : mm) 16.4 接插件护套 (毫米) M (6188-0083) Ref: Terminal part No. 端子参照页 B-19 Ref: wire seal No. 电线密封栓参照页 B-20 Ref: Dummy plug No. 盲塞参照页 B-21 Material 材 质 PBT F(6189-0145) 26.2 34.9 20.2 Color Gray 灰 颜 色 1way 2way F (6189-0413) 13.9 Color Gray 灰 颜 色 25.5 20.18 28.9 Color 颜 色 Black 黒 23.7 M (6188-0259) 44 F(6189-0425) 26.5 27.5 28.9 Color 颜 色 Gray 灰 TS SEALED SERIES Dummy plugs(UNIT : mm) 3way Color Gray 灰 颜 色 25.7 44 32.1 B- 22 M (6188-0129) F (6189-0165) 28.6 34.9 35.9 Color 颜 色 Gray 灰 TS SEALED SERIES for STANDARD 8.0mm (312) Structure/构造 B- 23 Wire seal Retainer Terminal M Retainer Housing M Terminal M Connector M Connector F Connector seal Housing F Wire seal Wire seal Terminal F Retainer Housing F Retainer Connector seal 8.0mm(312) Terminal F (S) Cable size(mm2) 0.5〜1.25 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Surface treatment 表面处理 2.0〜2.7 Brass 黄铜 Tin-plated 镀锡 8.0 0.64 M (8100-0506) 9.2 31.3 F(8100-0451) Cable size(mm2) 22.4 适用电线大小 Cable overall diameter(mm) Terminal(UNIT : mm) 端子(毫米) 带绝缘层外径 Material 5 材 质 Surface treatment 表面处理 0.5〜1.25 2.0〜2.7 Brass 黄铜 Tin-plated 镀锡 TS SEALED SERIES Housing M Wire seal (M) (L) Cable size(mm2) Cable size(mm2) 2.0〜3.0 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material Cable overall diameter(mm) 2.6〜4.1 带绝缘层外径 8.0 Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment 表面处理 表面处理 F (8100-0452) Cable size(mm2) 2.0〜3.0 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material Surface treatment 表面处理 8.0 31.3 0.64 M (8100-0508) F(8100-2980) Cable size(mm2) 9.2 22.4 2.6〜4.1 5.0〜8.0 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material Brass 黄铜 Tin-plated 镀锡 材 质 5 4.4〜5.8 Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment M (8100-0507) 22.4 Material 31.3 0.64 B- 24 9.2 5.0〜8.0 适用电线大小 Heat-resistant copper alloy Tin-plated 镀锡 材 质 5 4.4〜5.8 Surface treatment 表面处理 8.0mm (312) Wire seals(UNIT : mm) 电线密封栓 (毫米) The wire seals are common to M and F. 电线密封栓为公端、母端共用。 (SS) (S) (7165-0683) Cable size(mm2) 适用电线大小 φ 11.5 (AVS・AVX/0.5〜1.25) (7165-0400) Cable size(mm2) 适用电线大小 Cable overall diameter(mm) Over 2.0 mm less than 2.9 mm Cable overall diameter(mm) Material Material 超过2.0mm在2.9mm以下 Silicon 硅 Dark Brown 深棕 带绝缘层外径 材 质 Color 颜 色 带绝缘层外径 (M) Color 颜 色 Cable size(mm ) 2 适用电线大小 Cable overall diameter(mm) Material 材 质 Color 颜 色 13.5 (L) (7165-0392) 带绝缘层外径 φ 11.5 3.6〜4.1 Silicon 硅 Dark Gray 深灰 材 质 13.5 (AV/3.0) (AVX・AEX/3.0) (AVS/3.0) (AV/5.0) (AVX・AEX/5.0) (AVS/5.0) φ 11.5 Cable size(mm ) 适用电线大小 Cable overall diameter(mm) 4.4〜4.9 Silicon 硅 Dark Blue 藏青 (7165-0393) 2 带绝缘层外径 Material 材 质 13.5 Color 颜 色 (AV/8.0) (AVX・AEX/8.0) (AVS/8.0) φ 11.5 5.3〜5.8 Silicon 硅 Black 黒 13.5 8.0mm (312) B- 25 盲塞(毫米) (7165-0180) ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. φ 11.5 Material ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 NBR 材 质 Color 9.3 Gray 灰 颜 色 1way 8.0mm (312) Color Gray 灰 颜 色 25.7 49.4 20.2 Housing(UNIT : mm) 接插件护套 (毫米) M (6188-0049) Ref: Terminal part No. 端子参照页 B-23 Ref: wire seal No. 电线密封栓参照页 B-24 Ref: Dummy plug No. 盲塞参照页 B-25 Material 材 质 PBT F(6189-0101) 29.9 45.3 24 Color 颜 色 Gray 灰 2way 2way Color F(6189-0856) Gray 灰 颜 色 31.6 22.35 60 40.6 35.2 Color 32.2 M (6188-0096) 颜 色 Gray 灰 F (6189-0172) 2way F(6189-6953) 18.85 31.6 33.3 40.6 29 Color 颜 色 Gray 灰 35.2 Color 颜 色 Gray 灰 TS SEALED SERIES Dummy plugs(UNIT : mm) 2way Color Gray 灰 颜 色 49.4 23 40 B- 26 M (6188-5295) F (6189-7256) 40.5 37.8 43.4 Color Gray 灰 颜 色 0.64mm, 2.3mm (025, 090) Housing(UNIT : mm) 接插件护套(毫米) Ref: Terminal part No. 端子参照页 [0.64mm] B-03 [2.3mm] B-13 Ref: wire seal No. 电线密封栓参照页 [0.64mm] B-04 [2.3mm] B-14 Ref: Dummy plug No. 盲塞参照页 [0.64mm] B-04 [2.3mm] B-15 TS SEALED SERIES for HYBRID No. of way/( )corresponds to 0.64mm, 2.3mm, in order from left to right. 极数/( )内显示 :从左向右为0.64mm 极数、2.3mm 极数 10way(6+4) 13way(10+3) Material 材 质 PBT F (6189-7691) F (6189-7077) 33.5 26.8 34.55 24 63 35.5 Color 颜 色 Black 黒 26way(23+3) F (6189-6934) 33.5 34.55 63 Color 颜 色 Black 黒 Color 颜 色 Gray 灰 4way(2+2) 0.64mm, 4.8mm (025, 187) Color Black 黒 颜 色 30.8 Housing(UNIT : mm) 46.3 接插件护套 (毫米) 22.4 [0.64mm] B-03 [4.8mm] B-19 Ref: wire seal No. 电线密封栓参照页 [0.64mm] B-04 [4.8mm] B-20 Ref: Dummy plug No. 盲塞参照页 [0.64mm] B-04 [4.8mm] B-21 Material 材 质 M (6188-5103) B- 27 F(6189-1048) 31.3 PBT 28.9 25.6 No. of way( )corresponds to 0.64mm, 4.8mm, in order from left to right. 极数/( )内显示 :从左向右为0.64mm 极数、4.8mm 极数 24way(22+2) Color 颜 色 Black 黒 34way(30+4) F (6189-7426) F(6189-6978) 31.7 42 30.2 28.9 76.8 68.7 Color 颜 色 Color Gray 灰 颜 色 Black 黒 34way(30+4) 34way(30+4) F(6189-6980) F (6189-6979) 42 42 28.9 28.9 68.7 Color 颜 色 68.7 Gray 灰 Color 颜 色 Black 黒 40way(36+4) 34way(30+4) F (6189-1160) F (6189-6981) 28.9 28.9 42 42 68.7 Color 颜 色 80.2 Gray 灰 Color 颜 色 Gray 灰 46way(42+4) 46way(42+4) F (6189-6894) F (6189-1136) 28.9 28.9 42 42 80.2 Color 颜 色 Black 黒 80.2 Color 颜 色 Black 黒 TS SEALED SERIES Ref: Terminal part No. 端子参照页 0.64mm, 2.3mm, 4.8mm (025, 090, 187) Housing(UNIT : mm) 接插件护套 (毫米) B- 28 Ref: Terminal part No. 端子参照页 Ref: wire seal No. 电线密封栓参照页 Ref: Dummy plug No. 盲塞参照页 Material 材 质 [0.64mm] [2.3mm] [4.8mm] [0.64mm] [2.3mm] [4.8mm] [0.64mm] [2.3mm] [4.8mm] B-03 B-13 B-19 B-04 B-14 B-20 B-04 B-15 B-21 52way(42+4+6) F (6189-7809) 49.3 28.9 Color 颜 色 Black 黒 Lever Assy (6911-5948) 95.4 48.7 43.9 F(6189-7094) 42 PBT No. of way/ ( ) corresponds to 0.64mm, 2.3mm, 4.8mm in order from left to right. 极数/( )内显示 :从左向右为0.64mm 极数、2.3mm 极数、4.8mm 极数 72.4 42way(36+2+4) Color 颜 色 Black 黒 80.2 28.9 Color 颜 色 Black 黒 4way(2+2) 2.3mm, 4.8mm (090, 187) Color Gray 灰 颜 色 29.9 Housing(UNIT : mm) 47 接插件护套 (毫米) 25.6 [2.3mm]B-13 [4.8mm]B-19 Ref: wire seal No. 电线密封栓参照页 [2.3mm]B-14(For P6) [4.8mm]B-20 Ref: Dummy plug No. 盲塞参照页 [2.3mm]B-15(For P6) [4.8mm]B-21 Material 材 质 M (6188-0415) F(6189-0144) 28.3 PBT 22.4 28.9 No. of way/ ( )corresponds to 2.3mm, 4.8mm in order from left to right. 极数/( )内显示 :从左向右为2.3mm 极数、4.8mm 极数 颜 色 Color Gray 灰 颜 色 5way(3+2) 5way(3+2) Color B- 29 Color Gray 灰 Gray 灰 颜 色 30.9 33.4 50.5 24.4 27.8 M (6188-0091) F (6189-0166) M (6188-0101) 44 F(6189-0181) 34.2 28.7 28.2 24.5 28.9 34.9 Color Color Gray 灰 颜 色 6way(4+2) Color 颜 色 Gray 灰 颜 色 11way(8+3) Color Gray 灰 颜 色 Gray 灰 41.5 26.9 49 32.55 M (6188-0187) F (6189-0143) 51.9 33.9 M (6188-0221) 28.3 F(6189-0376) 42.2 27.8 30.7 28.9 28.9 Color 颜 色 Gray 灰 Color 颜 色 Gray 灰 TS SEALED SERIES Ref: Terminal part No. 端子参照页 4.8mm, 8.0mm (187, 312) Housing(UNIT : mm) B- 30 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 [4.8mm]B-19 [8.0mm]B-23 Ref: wire seal No. 电线密封栓参照页 [4.8mm]B-20 [8.0mm]B-24 Ref: Dummy plug No. 盲塞参照页 [4.8mm]B-21 [8.0mm]B-25 Material 材 质 3way(1+2) F(6189-7156) 33.8 PBT No. of way/( )corresponds to 4.8mm, 8.0mm in order from left to right. 极数/( )内显示 :从左向右为4.8mm 极数、8.0mm 极数 52.5 37.75 Color 颜 色 Black 黒 HE SERIES Features The HE connector series is the highly reliable improved version of the conventional HD series, with a mechanism that minimizes the possibility of terminal back out and semiengagement of connectors. This series consists of 0.64mm, 1.0mm, 2.3mm, 4.8mm and 9.5mm types (0.64mm, 1.0mm, 2.3mm, 4.8mm and 8.0mm types for the hybrid model) classified according to terminal size, supporting use in a variety of control circuits and low power circuits. ◦A  n incompletely inserted terminal is automatically adjusted to the correct position by setting a retainer. ◦R  etainers are pre-mounted on the connector housing, and are structured to enable setting by the same simple operation regardless of the number of ways, improving operability. ◦A  n extra clip can be attached to the connector housing to secure it to the car body, and multiple connectors can be joined. ◦P  CB models are also available for connection to printed circuit boards. ◦ RoHS/ELV Compliant 特 点 HE 系列是将以往的 HD 系列改良后,提高了可信 性的接插件。 具有不易发生端子脱落及接插件半嵌合的构造。 按照端子尺寸划分为0.64mm·1.0mm·2.3mm· 4.8mm·9.5mm( 混 合 型 为 0.64mm·1.0mm· 2.3mm·4.8mm·8.0mm),可以应用于各种控制 回路与低功率。 ◦未完全插入的端子能够通过安装锁片插入到正 确的位置。 ◦锁片预先组装在接插件护套上,无论多少极数 都能通过简单操作组合,有助于提高操作效率。 ◦在接插件护套上可安装卡钉(卡子)用以固定在 车体上,并且可以将各个接插件相互连接。 ◦我们还设计了能适用于印刷电路板的 PCB 接插 件。 ◦可对应欧盟 RoHS 和 ELV 指令 HE SERIES for STANDARD 0.64mm (025) Structure/构造 C-02 Housing M Terminal M Retainer Before setting retainer After setting retainer 锁片安装到位前 锁片安装到位后 Housing M Retainer Terminal M Connector M Housing F Connector F Terminal F Before setting retainer After setting retainer 锁片安装到位前 锁片安装到位后 Housing F Retainer Retainer Terminal F 0.64mm (025) Terminal(UNIT : mm) 端子(毫米) (S) (M) Cable size(mm2) Cable size(mm2) 0.22〜0.35 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material Cable overall diameter(mm) 0.95〜1.4 Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment 表面处理 22.3 0.64 带绝缘层外径 Material 表面处理 F (8100-4029) 1.25〜1.6 Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment M (8100-4028) 22.3 0.64 M (8100-4027) F(8100-4030) 2 Cable size(mm2) 15.5 0.22〜0.35 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Surface treatment 表面处理 1.5 Cable size(mm2) 15.5 0.5〜0.75 适用电线大小 Cable overall diameter(mm) 0.95〜1.4 带绝缘层外径 Material Heat-resistant copper alloy Tin-plated 镀锡 材 质 Surface treatment 表面处理 1.25〜1.6 Heat-resistant copper alloy Tin-plated 镀锡 2way 0.64mm (025) Color 颜 色 Natural 自然色 12.2 34.7 12.2 M (6098-5070) F(6098-5071) Housing(UNIT : mm) Ref: Terminal part No. 端子参照页 7.7 C-02 19 6.6 Material 材 质 PBT Color Natural 自然色 颜 色 4way 3way F (6098-5833) Color 颜 色 Natural 自然色 4.1 12.4 8.8 19 34.7 Color 颜 色 13.2 Natural 自然色 M (6098-4944) F(6098-4978) 4.1 10 21 Color 颜 色 Natural 自然色 C-03 HE SERIES 2 1.5 0.5〜0.75 适用电线大小 6way 7way Color F(6098-5000) Natural 自然色 颜 色 4.1 12.4 21 16.6 34.7 Color 17.6 C-04 M (6098-4943) Natural 自然色 颜 色 F (6098-4979) 10way F(6098-4982) 4.1 7.1 14.4 21 Color 颜 色 Color Natural 自然色 颜 色 12.9 12.9 M (6098-4675) F (6098-4640) 7.1 M (6098-4333) 34.7 F(6098-4339) 7.1 15.4 19.8 21 Color 颜 色 21 Color Natural 自然色 20way 颜 色 23 34.7 18.6 Color Green 绿 16way Natural 自然色 颜 色 Color 颜 色 12way Color 21 13.2 Natural 自然色 颜 色 Natural 自然色 24way Color Natural 自然色 颜 色 M (6098-4589) F (6098-4595) Color 颜 色 Natural 自然色 Natural 自然色 M (6098-4588) F(6098-4594) Color 颜 色 Natural 自然色 34way Color 颜 色 Natural 自然色 M (6098-4590) F (6098-4596) C-05 HE SERIES Color 颜 色 Natural 自然色 HE SERIES for STANDARD 1.0mm(040) Structure/构造 C-06 Housing M Terminal M Before setting retainer After setting retainer 锁片安装到位前 锁片安装到位后 Housing M Retainer Retainer Retainer Terminal M Connector M Connector F Retainer Housing F Before setting retainer After setting retainer 锁片安装到位前 锁片安装到位后 Housing F Retainer Terminal F Retainer Retainer Terminal F 1.0mm (040) Terminal(UNIT : mm) 端子(毫米) (SS) (S) Cable size(mm2) Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Surface treatment 表面处理 Cable size(mm2) 0.22〜0.35 适用电线大小 Cable overall diameter(mm) 0.95〜1.1 带绝缘层外径 Brass 黄铜 Tin-plated 镀锡 Material 表面处理 F (8100-4308) Cable overall diameter(mm) 带绝缘层外径 15.9 Material 材 质 Surface treatment 表面处理 M (8100-2972) F(8100-2971) Cable size(mm2) 0.22〜0.35 适用电线大小 23.8 1 0.3〜0.85 适用电线大小 2.55 0.95〜1.1 Heat-resistant copper alloy Tin-plated 镀锡 Cable overall diameter(mm) 带绝缘层外径 Material 15.9 1.8 材 质 Surface treatment 表面处理 1.4〜1.8 Heat-resistant copper alloy Tin-plated 镀锡 2way 1.0mm(040) F(6098-5888) 9.4 20.6 7.5 Color 颜 色 Light Gray 浅灰 5way Housing(UNIT : mm) F(6098-2779) 接插件护套 (毫米) 9.65 Ref: Terminal part No. 端子参照页 C-06 Material 材 质 PBT 16.7 Color 颜 色 6way Color 颜 色 20.6 8way F(6098-2782) Natural 自然色 9.65 14.45 34.4 22.6 24.2 20.6 Color 颜 色 M (6098-2780) F (6098-2781) 9.65 19.2 Natural 自然色 20.6 Color 颜 色 Natural 自然色 Natural 自然色 C-07 HE SERIES Cable size(mm2) 1.8 Surface treatment 23.8 1 1.4〜1.8 Brass 黄铜 Tin-plated 镀锡 材 质 M (8100-4307) 2.55 0.3〜0.85 适用电线大小 13way Color 17way Color Natural 自然色 颜 色 Natural 自然色 颜 色 18.1 18.1 34.4 32.6 27.6 C-08 M (6098-2788) F (6098-2784) M (6098-3369) 34.4 F(6098-2785) 10.8 10.8 29.2 20.6 24.2 Color Color Natural 自然色 颜 色 颜 色 21way Color Natural 自然色 颜 色 18.1 34.4 37.6 M (6098-2789) F (6098-2764) 10.8 34.2 20.6 Color 颜 色 Natural 自然色 20.6 Natural 自然色 HE SERIES for STANDARD 2.3mm (090) Structure/构造 Retainer Housing M Before setting retainer After setting retainer 锁片安装到位前 锁片安装到位后 Housing M HE SERIES Retainer Terminal M Retainer Retainer Terminal M Connector M Connector F Retainer Housing F Before setting retainer After setting retainer 锁片安装到位前 锁片安装到位后 Retainer Housing F Terminal F Retainer Retainer Terminal F 2.3mm(090) (S) Cable size(mm2) 0.3〜0.5 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 1.4〜2.1 Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment 表面处理 2.3 M (8100-1571) 27.7 F(8100-1470) Cable size(mm2) 适用电线大小 2.4 Terminal(UNIT : mm) 端子(毫米) C-09 3 Cable overall diameter(mm) 21 带绝缘层外径 Material 材 质 Surface treatment 表面处理 0.3〜0.5 1.4〜2.1 Brass 黄铜 Tin-plated 镀锡 (M) (L) Cable size(mm2) Cable overall diameter(mm) 带绝缘层外径 Material Surface treatment 表面处理 Cable overall diameter(mm) 2.0〜2.9 带绝缘层外径 Material 2.3 27.7 F (8100-1472) Cable size(mm2) Cable overall diameter(mm) 3 带绝缘层外径 21 Material 材 质 Surface treatment 表面处理 Surface treatment 表面处理 2.3 27.7 M (8100-1572) F(8100-1471) Cable size(mm2) 0.5〜1.25 适用电线大小 2.6〜3.1 Brass 黄铜 Tin-plated 镀锡 材 质 M (8100-1573) 2.4 2.0 适用电线大小 Brass 黄铜 Tin-plated 镀锡 材 质 C-10 Cable size(mm2) 0.5〜1.25 适用电线大小 2.0〜2.9 Brass 黄铜 Tin-plated 镀锡 2.0 适用电线大小 2.4 Cable overall diameter(mm) 3 带绝缘层外径 21 Material 材 质 Surface treatment 表面处理 2.6〜3.1 Heat-resistant copper alloy Tin-plated 镀锡 2way 2.3mm(090) Color Natural 自然色 颜 色 16.3 36.9 14.3 M (6098-4901) F(6098-4069) Housing(UNIT : mm) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 C-09 Material 材 质 PBT 7.0 24.5 10.9 Color Natural 自然色 颜 色 3way 4way Color Natural 自然色 颜 色 Color Natural 自然色 颜 色 16.3 13.15 37.4 37.4 21.3 17.3 M (6098-5049) F (6098-4071) 6.85 M (6098-4902) F(6098-4073) 6.85 13.9 24 17.9 Color 颜 色 Natural 自然色 24 Color 颜 色 Natural 自然色 5way 6way Color Color Natural 自然色 颜 色 Sky Blue 天蓝 颜 色 13.15 17.7 37.4 25.3 M (6098-4664) F (6098-4669) 38.4 23.9 M (6098-1373) F(6098-1377) C-11 HE SERIES 11.3 6.85 24 21.9 20.5 Color 24 Color Natural 自然色 颜 色 颜 色 8way Sky Blue 天蓝 8way Color F(6098-1378) Natural 自然色 颜 色 11.3 17.7 24.5 38.4 27.4 24 Color 颜 色 M (6098-4661) Green 绿 F (6098-4670) 10way F(6240-5378) 11.3 11.3 24 24 28 Color 24 Natural 自然色 颜 色 Color 颜 色 14way Natural 自然色 16way Color F(6098-3563) Natural 自然色 颜 色 11.3 17.7 40 38.4 39.4 24 Color 颜 色 M (6098-4662) Natural 自然色 F (6098-4050) 20way F(6098-1380) 11.3 11.3 36 24 52.5 Color 颜 色 Natural 自然色 24 Color 颜 色 Green 绿 HE SERIES for STANDARD 4.8mm(187) C-12 (S) 4.8mm(187) Cable size(mm2) 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Surface treatment 表面处理 0.3 1.4〜1.9 Brass 黄铜 Tin-plated 镀锡 26.7 4.8 M (8100-1506) F(8100-1507) Cable size(mm2) 3.4 0.3 适用电线大小 Cable overall diameter(mm) Terminal(UNIT : mm) 6 18 Material 表面处理 (M) (L) Cable size(mm ) 2 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Surface treatment Cable size(mm2) 0.5〜1.25 适用电线大小 Cable overall diameter(mm) 1.6〜2.9 带绝缘层外径 Material Brass 黄铜 Tin-plated 镀锡 材 质 26.7 Surface treatment 表面处理 2.0〜3.0 2.6〜3.8 Brass 黄铜 Tin-plated 镀锡 26.7 4.8 4.8 M (8100-0664) F (8100-0606) Cable size(mm2) 适用电线大小 3.4 Cable overall diameter(mm) 带绝缘层外径 6 1.4〜1.9 Heat-resistant copper alloy Tin-plated 镀锡 材 质 Surface treatment 端子(毫米) 表面处理 带绝缘层外径 18 Material 材 质 Surface treatment 表面处理 0.5〜1.25 M (1500-0166) Cable size(mm2) 3.4 适用电线大小 Cable overall diameter(mm) 1.6〜2.9 Heat-resistant copper alloy Tin-plated 镀锡 F(8100-0782) 带绝缘层外径 6 18 Material 材 质 Surface treatment 表面处理 2.0〜3.0 2.6〜3.8 Heat-resistant copper alloy Tin-plated 镀锡 2way 4.8mm(187) Color Natural 自然色 颜 色 18.1 38.4 19.1 M (6098-5120) F(6098-5119) HE SERIES Housing(UNIT : mm) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 8.25 C-13 24.1 15.7 Material 材 质 PBT Color Natural 自然色 颜 色 4way 5way F (6098-4971) Color Natural 自然色 颜 色 8.25 21.3 29.3 24.1 Color 颜 色 C-13 38.4 33.3 Natural 自然色 M (6098-4663) F(6098-4667) 14.4 29 9.9 9 22.1 Color 颜 色 Natural 自然色 HE SERIES for STANDARD 9.5mm(375) C-14 (S) 9.5mm(375) F(8240-0152) Cable size(mm2) 2.0〜3.0 适用电线大小 5 Cable overall diameter(mm) 带绝缘层外径 27.5 11.1 Material 2.6〜4.1 Copper alloy 铜合金 Tin-plated 镀锡 材 质 Surface treatment 表面处理 (M) F(8240-0153) Cable size(mm2) 5.0〜8.0 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Terminal(UNIT : mm) Material Heat-resistant copper alloy Tin-plated 镀锡 材 质 Surface treatment 端子(毫米) 4.4〜5.8 表面处理 (L) F(8240-0154) Cable size(mm2) 10.0 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Surface treatment 表面处理 6.5〜6.9 Heat-resistant copper alloy Tin-plated 镀锡 1way 9.5mm(375) rib A F(6098-4973) 10.95 13.9 32.4 Color 颜 色 Housing(UNIT : mm) Natural 自然色 1way rib B F(6098-4974) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 C-15 Material 材 质 PBT 10.95 13.9 32.4 Color 颜 色 Black 黒 1way rib C 2way F (6098-4975) 10.95 10.95 13.9 F(6098-4977) 32.4 26.2 Color 颜 色 Dark Green 墨绿 32.4 Color 颜 色 Green 绿 C-15 HE SERIES 0.64mm, 2.3mm (025, 090) Housing(UNIT : mm) C-16 接插件护套(毫米) Ref: Terminal part No. 端子参照页 [0.64mm] C-02 [2.3mm] C-09 HE SERIES for HYBRID No. of way/( )corresponds to 0.64mm, 2.3mm, in order from left to right. 极数/( )内显示 :从左向右为0.64mm 极数、2.3mm 极数 12way(6+6) 13way(9+4) Color Material 材 质 Color Natural 自然色 颜 色 颜 色 PBT Natural 自然色 23.5 15.4 42.9 28 M (6098-6161) F (6098-6162) 37.4 27.9 M (6098-5180) F(6098-6562) 12.35 24 19.7 Color Color Natural 自然色 颜 色 20way(16+4) 18way(9+9) Color Color Natural 自然色 颜 色 Natural 自然色 颜 色 颜 色 Natural 自然色 12.9 23.4 42.9 39.4 37.4 22.9 M (6098-4908) F (6098-6478) F(6098-4597) 7.1 17.35 19.7 M (6098-4591) 36.2 24 Color 颜 色 Natural 自然色 24 Color 颜 色 Natural 自然色 23way(14+9) Color 28way(24+4) Color Natural 自然色 颜 色 Natural 自然色 颜 色 15.3 20.4 M (6098-4707) 48.2 42.9 27.3 F (6098-6559) M (6098-4725) 37.4 F(6098-4726) HE SERIES 7.1 17.2 24.1 45 24 Color 颜 色 Natural 自然色 C-17 24 Color 颜 色 Natural 自然色 9way(2+7) 1.0mm, 2.3mm (040, 090) F(6098-4075) 7.2 34.7 24 Color 颜 色 C-18 Natural 自然色 Housing(UNIT : mm) 10way(2+8) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 Material 材 质 [1.0mm] [2.3mm] C-06 C-09 F(6098-4076) 7.2 PBT 39.1 24 No. of way/( )corresponds to 1.0mm, 2.3mm, in order from left to right. 极数/( )内显示 :从左向右为1.0mm 极数、2.3mm 极数 Color 颜 色 Natural 自然色 10way(8+2) 10way(6+4) F(6098-3600) F (6098-4666) 10.8 12.5 24 24 17.8 Color 颜 色 22.9 Natural 自然色 14way(10+4) Color 颜 色 Natural 自然色 23way(19+4) F (6098-3601) 10.8 F(6098-3571) 10.8 29.4 24 24 40.2 Color 颜 色 Natural 自然色 23way(19+4) F (6098-4367) 10.8 40.2 24 Color 颜 色 Brown 棕 Color 颜 色 Natural 自然色 12way(10+2) 1.0mm, 4.8mm (040, 187) Color Natural 自然色 颜 色 20.2 32.6 Housing(UNIT : mm) M (6098-3370) 37.4 F(6098-2786) Ref: Terminal part No. 端子参照页 Material 材 质 [1.0mm] [4.8mm] C-06 C-13 12.9 PBT 29.2 No. of way/( )corresponds to 1.0mm, 4.8mm, in order from left to right. 极数/( )内显示 :从左向右为1.0mm 极数、4.8mm 极数 14way(10+4) F (6098-4017) 12.9 36.7 HE SERIES 接插件护套 (毫米) 21.1 Color 颜 色 Natural 自然色 C-19 21.1 Color 颜 色 Natural 自然色 8way(6+2) 2.3mm, 4.8mm (090, 187) Color Natural 自然色 颜 色 21.05 38.4 31.4 C-20 Housing(UNIT : mm) M (6098-5218) F(6098-5217) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 [2.3mm] [4.8mm] C-09 C-13 19.6 Material 材 质 PBT 28 24 No. of way/( )corresponds to 2.3mm, 4.8mm, in order from left to right. 极数/( )内显示 :从左向右为2.3mm 极数、4.8mm 极数 14way(12+2) Color Color 颜 色 16way(14+2) F(6950-1054) Natural 自然色 颜 色 Natural 自然色 13.2 19.65 47.5 38.4 43.4 24 Color 颜 色 M (6098-4660) F (6098-3565) Green 绿 18way(14+4) F(6950-1055) 13.2 13.2 40 24 55.5 Color 颜 色 Natural 自然色 20way(16+4) F (6950-1056) 13.2 59.5 24 Color 颜 色 Green 绿 24 Color 颜 色 Green 绿 (S) 8.0mm(312) Cable size(mm2) 0.5〜1.25 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 1.6〜2.9 Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment 表面处理 32.3 8 0.8 M (8100-0520) F(8100-0707) Cable overall diameter(mm) 带绝缘层外径 Terminal(UNIT : mm) Material 5 Surface treatment 表面处理 (M) (L) Cable size(mm2) Cable overall diameter(mm) 材 质 Surface treatment 表面处理 Cable size(mm2) 2.0〜3.0 适用电线大小 Material 5.0〜8.0 适用电线大小 Cable overall diameter(mm) 2.6〜4.1 带绝缘层外径 Brass 黄铜 Tin-plated 镀锡 32.3 8 Material 材 质 Surface treatment 表面处理 4.4〜5.8 Brass 黄铜 Tin-plated 镀锡 M (8100-0521) 0.8 F (8100-0706) Cable size(mm2) 23.4 5 2.0〜3.0 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Surface treatment 表面处理 32.3 8 0.8 9.2 1.6〜2.9 Brass 黄铜 Tin-plated 镀锡 材 质 端子(毫米) 带绝缘层外径 0.5〜1.25 适用电线大小 23.4 HE SERIES Cable size(mm2) 9.2 M (8100-0522) 5.0〜8.0 适用电线大小 23.4 2.6〜4.1 Brass 黄铜 Tin-plated 镀锡 F(8100-1553) Cable size(mm2) 9.2 Cable overall diameter(mm) 带绝缘层外径 Material 5 4.4〜5.8 Heat-resistant copper alloy Tin-plated 镀锡 材 质 Surface treatment 表面处理 6way(4+2) 4.8mm, 8.0mm (187, 312) Color Natural 自然色 颜 色 22.9 48.8 34.7 Housing(UNIT : mm) M (6098-3567) F(6098-3569) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 Material 材 质 [4.8mm] [8.0mm] C-13 C-21 15.6 PBT 27.8 31.3 No. of way/( )corresponds to 4.8mm, 8.0mm, in order from left to right. 极数/( )内显示 :从左向右为4.8mm 极数、8.0mm 极数 Color 颜 色 Natural 自然色 C-21 1.0mm (040) C-22 Housing(UNIT : mm) HE SERIES for PCB 接插件护套(毫米) Material 材 质 PBT G30 (Vertical type) (垂直) 13way M (6098-3239) ●Detailed dimension  详细尺寸 17.2 Connector F part No. 6098-2784(C-08) Color Natural 自然色 母端接插件产品号码 颜 色 ●Recommended demension of Circuit board  电路板推荐尺寸 24.5 27.6 1.0mm, 2.3mm (040, 090) Housing(UNIT : mm) 接插件护套 (毫米) Material 材 质 PBT G30 (Vertical type) (垂直) 23way M (6098-3572) ●Detailed dimension  详细尺寸 17.2 Connector F part No. 6098-3571(C-19) Color Natural 自然色 母端接插件产品号码 颜 色 43.6 21.1 ●Recommended demension of Circuit board  电路板推荐尺寸 1.0mm, 4.8mm (040, 187) C-23 HE SERIES Housing(UNIT : mm) 接插件护套 (毫米) Material 材 质 PBT G30 (Vertical type) (垂直) 14way M (6098-4018) ●Detailed dimension  详细尺寸 19.3 Connector F part No. 6098-4017(C-20) Color Natural 自然色 母端接插件产品号码 颜 色 22.1 ●Recommended demension of Circuit board  电路板推荐尺寸 40.1 2.3mm(090) Housing(UNIT : mm) 接插件护套 (毫米) Material 材 质 PBT G30 (Vertical type) (垂直) 6way M (6098-3616) ●Detailed dimension  详细尺寸 16.9 Connector F part No. 母端接插件产品号码 Color 颜 色 6098-1377(C-11) Sky Blue 天蓝 ●Recommended demension of Circuit board  电路板推荐尺寸 22.9 22.1 C-24 HE SERIES COMMON USE PARTS Body fastening clamp(mm) The clamp can be installed to connector M, if necessary, to fasten into the body side hole. 公端接插件在需要时可以安装卡钉用以固定在车体上。 (6810-1203) Clamp fitting hole size(mm) 适合孔穴尺寸 Clamp fitting thickness(mm) 卡钉适合板厚 Material 材 质 Color 颜 色 (6810-1217) Clamp fitting hole size(mm) φ7 适合孔穴尺寸 Clamp fitting thickness(mm) t=0.65〜1.6 卡钉适合板厚 11.8 Material 6 Nylon 12 Red 红 材 质 Color 颜 色 φ7 t=1.6〜2.6 12.8 6 Nylon Brown 棕 12 (6810-1204) Clamp fitting hole size(mm) 适合孔穴尺寸 Clamp fitting thickness(mm) 卡钉适合板厚 Material 材 质 Color 颜 色 (6810-1462) Clamp fitting hole size(mm) φ10 适合孔穴尺寸 Clamp fitting thickness(mm) t=0.65〜1.6 卡钉适合板厚 11.8 Material 6 Nylon Natural 自然色 12 材 质 Color 颜 色 6×12(Square hole) t=0.65〜1.6 11.8 6 Nylon 12 Orange 橙 (6910-0119) 14.8 Bracket direction 插入支架的方向 Material 材 质 Color 颜 色 Connector mating direction 接插件嵌合方向 6 Nylon Connector M can be accoupled with clamp, if necessary, to fasten to the body side bracket. 公端接插件在需要时可以安装卡钉用以固定在车体上。 17.2 Red 红 (6910-0120) Body fastening clamp (Bracket type)(mm) 7.2 14.8 Bracket direction 插入支架的方向 Material 材 质 Color 颜 色 Anti clock wise 接插件嵌合的反方向 7.2 6 Nylon Natural 自然色 17.2 HV/HVG SEALED SERIES Features The HV sealed connector series is an improved version of the existing HX sealed connector series and it is a highly reliable connector series. Also the HVG sealed series is what is added a finger holding portion to the side wall of the female connector of the HV sealed se r ies so as to imp rov ing mat t ing performance. It has a mechanism that detects terminal incomplete insertion. ◦ T he connector mechanism only allows the retainer to be set when the terminal is completely inserted. ◦ T hese connectors can be directly secured to a bracket on the car body. ◦ RoHS/ELV Compliant 特 点 HV 防水系列是将以往的 HX 防水系列改良后,提 高了可信性的接插件系列。 此外,HVG 防水系列在 HV 防水系列的母端接插 件的侧壁上还增加了指扣,提高了接插件插入作 业的操作性。 具备检测端子插入不到位的构造。 ◦具有当端子在半插入状态时,锁片无法组装到 位的检知构造。 ◦接插件可以直接固定在车体支架上。 ◦可对应欧盟 RoHS 和 ELV 指令 HV/HVG SEALED SERIES for STANDARD 1.0mm (040) Structure/构造 Retainer M D- 02 Connector M Wire seal Terminal M Connector M Connector F Connector seal Housing F Wire seal Retainer F Terminal F 1.0mm (040) 1.0mm (040) Wire seals(UNIT : mm) 电线密封栓(毫米) Ref; 1.0mm Wire Seals detail 1.0mm电线密封栓参照页 Terminal(UNIT : mm) SS (7165-1075) S (7165-0621) 端子(毫米) M (7165-0622) Ref; 1.0mm Terminal detail 1.0mm端子参照页 S M(8100-3177) E-02 M M(8100-3178) E-02 F (8100-3067) F (8100-3068) E-03 E-03 E-03 E-02 The wire seals are common to M and F. E-02 电线密封栓为公端、母端共用。 1.0mm(040) Dummy plugs(UNIT : mm) 盲塞(毫米) Ref; 1.0mm Dummy plug detail 1.0mm盲塞参照页 (7165-0432) D- 03 E-04 HV/HVG SEALED SERIES ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 2way 1.0mm (040) F(6189-7036) 19.3 7.5 15.4 9.4 Retainer No. (6918-1835) 24.5 Housing(UNIT : mm) Color Black 黒 颜 色 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 E-02 Ref: wire seal No. 电线密封栓参照页 E-03 Ref: Dummy plug No. 盲塞参照页 E-04 Material 材 质 PBT F(6189-7052) 7.5 15.7 9.4 19.3 Retainer No. (6918-1835) 24.5 Color (Rib difference) (Rib差异) 3way F(6189-7058) Black 黒 颜 色 7.5 15.7 13.5 35.7 20.1 17.7 23.4 Retainer No. (6918-1833) 24.5 Color 颜 色 M (6188-4775) F (6189-7037) 7.5 15.4 13.5 23.4 Dark Gray 深灰 颜 色 3way Color (Rib difference) (Rib差异) 2way 24.5 NOTE1) Color 颜 色 Retainer No. (6918-1833) Black 黒 Dark Gray 深灰 4way 5way Color F(6189-6909) Black 黒 颜 色 7.5 15.7 21.7 30.3 38.3 23.6 17.4 24.5 NOTE1) Color Black 黒 颜 色 M (6188-4776) Retainer No. (6918-2128) F (6189-7039) D- 04 13.2 21.4 10.4 19.3 26.1 Retainer No. (6918-2810) NOTE1) Color Black 黒 颜 色 10way 6way Color Color Black 黒 颜 色 Black 黒 颜 色 21.5 38.3 23.8 13.1 35.7 31.8 26.5 26.25 Retainer No. (6918-2804) M (6188-4908) F(6189-7040) 13.2 21.4 14.5 23.4 26.1 NOTE1) Color 颜 色 NOTE1) HV SEALED SERIES Retainer No. (6918-2913) Black 黒 M (6181-6481) F (6189-6906) 12.7 27.5 40.65 26.1 Retainer No. (6918-2806) 24.5 Color 颜 色 Black 黒 HX SEALED SERIES Features The HX sealed connector series is the highly rel iable imp roved ve r s ion of the conventional HW sealed series, with a mechanism that detects when terminals are not inserted completely. This series consists of 1.0mm・1.5mm・2.3mm types (0.64mm・1.0mm・1.5mm・2.3mm・4.8mm types for the hybrid model) classified according to terminal size, supporting use in a variety of control circuits and low power circuits. ◦ The connector mechanism only allows the retainer to be set when the terminal is completely inserted. ◦ T he hybrid model can be directly secured to a bracket on the car body, but this is only possible when the locking mechanism ensures the connectors are completely engaged, preventing semiengagement. ◦ RoHS/ELV Compliant 特 点 HX 系列是将以往的 HW 系列改良后、提高了可信 性的接插件。 具有检测端子插入不足的结构。 按照端子尺寸划分为1.0mm·1.5mm·2.3mm (混 合 为 0.64mm · 1.0mm · 1.5mm · 2.3mm· 4.8mm),可以应用于各种控制回路与低功率回路。 ◦拥有当端子在半插入状态时,锁片无法组装到 位的检知构造。 ◦混合型的接插件具有在未完全嵌合的状态下, 无法固定到车体支架上的锁定构造。 ◦混合型的接插件可以直接固定在车体的支架上。 ◦可对应欧盟 RoHS 和 ELV 指令 HX SEALED SERIES for STANDARD 1.0mm (040) Structure/构造 Retainer M E- 02 Connector M Wire seal Terminal M Connector M Connector F Connector seal Housing F Wire seal Retainer F Terminal F 1.0mm (040) Terminal(UNIT : mm) 端子(毫米) (M) (S) Cable size(mm ) 2 Cable size(mm2) 0.3〜0.5 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material Surface treatment 表面处理 Cable overall diameter(mm) 1.4〜2.0 Material 24 1 表面处理 F (8100-3067) 24 1 M (8100-3178) F(8100-3068) 2.2 2.2 Cable size(mm2) 17 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 2 1.4〜2.0 Surface treatment 表面处理 0.75〜1.25 适用电线大小 17 Cable overall diameter(mm) 带绝缘层外径 Material Heat-resistant copper alloy Tin-plated 镀锡 材 质 E- 03 Cable size(mm2) 0.3〜0.5 1.8〜2.2 Heat-resistant copper alloy Tin-plated 镀锡 材 质 Surface treatment 表面处理 1.0mm (040) (SS) Wire seals(UNIT : mm) (7165-1075) Cable size(mm ) 2 电线密封栓 (毫米) 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material The wire seals are common to M and F. 材 质 Color 电线密封栓为公端、母端共用。 颜 色 (S) (AVSS/0.3) (AVSSX/0.3) (AVSSH/0.3) (CHFUS/0.35) (CHFS/0.5) 1.1〜1.6 Silicon 硅 Orange 橙 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Color 颜 色 5.7 (M) (7165-0621) Cable size(mm2) φ 4.1 (AVS/0.3) (AVSS/0.5) (AVSSX/0.5) (AVSSH/0.5) (CHFS/0.75) φ 4.1 适用电线大小 Cable overall diameter(mm) 1.6〜1.9 Silicon 硅 Light Green 淡绿 (7165-0622) Cable size(mm2) 带绝缘层外径 Material 材 质 5.7 Color 颜 色 (AVS/0.5) (AVS/0.85) (AVSS/0.75〜1.25) (AVSSX/0.75〜1.25) (AVSSH/0.75〜1.25) (AVX/0.5) (AVX/0.75) (CHFS/1.0) φ 4.1 1.8〜2.2 Silicon 硅 Violet 紫 5.7 HX SEALED SERIES 2 Heat-resistant copper alloy Tin-plated 镀锡 材 质 Surface treatment M (8100-3177) 2.2 1.8〜2.2 带绝缘层外径 Brass 黄铜 Tin-plated 镀锡 材 质 0.75〜1.25 适用电线大小 2.2 1.0mm(040) Dummy plugs(UNIT : mm) 盲塞(毫米) E- 04 (7165-0432) ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. φ4 Material ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 材 质 Color 颜 色 NBR Black 黒 6 1way 1.0mm(040) Color 颜 色 Black 黒 35.7 15.2 17.55 Housing(UNIT : mm) 接插件护套 (毫米) M (6188-0657) Ref: Terminal part No. 端子参照页 E-02 Ref: wire seal No. 电线密封栓参照页 E-03 Ref: Dummy plug No. 盲塞参照页 E-04 Material 材 质 PBT 16.4 7.5 5.3 15.4 颜 色 Color Black 黒 颜 色 (Rib difference) (Rib差异) 2way Color Black 黒 颜 色 35.7 16 M (6188-0589) 7.5 Retainer No. (6918-1835) Color 颜 色 Black 黒 35.7 16 M (6188-0590) 17.7 F(6189-0891) 7.5 15.4 9.4 24.5 Dark Gray 深灰 17.7 F (6189-0890) 15.4 17.6 Retainer No. (6918-1979) 24.5 2way Color F(6189-0940) 9.4 17.6 24.5 Retainer No. (6918-1835) Color 颜 色 Dark Gray 深灰 3way (Rib difference) (Rib差异) 3way Color F(6189-0968) Black 黒 颜 色 7.5 17.7 20.1 13.5 24.5 35.7 21.7 Retainer No. (6918-1833) 15.4 Color Black 黒 颜 色 M (6188-4739) F (6189-0887) 5way F(6189-1081) E 05 7.5 13.5 24.5 21.7 Retainer No. (6918-1833) Color 7.5 15.7 21.7 30.1 24.5 Black 黒 颜 色 Retainer No. (6918-2128) Color Black 黒 颜 色 7way 6way Color F (6189-0855) Black 黒 颜 色 7.5 16 35.7 32.8 18.1 29.9 38.5 24.5 Retainer No. (6918-1762) Color 颜 色 M (6188-0658) F (6189-1012) 7.5 15.7 25.8 34.2 24.5 Retainer No. (6918-2056) Color 颜 色 Black 黒 Black 黒 HX SEALED SERIES 15.4 HX SEALED SERIES for 23way and 33way 1.0mm (040) Structure/构造 Dummy Plug Terminal F E- 06 Retainer M Housing F Housing M Retainer F Terminal M Housing F Housing F (Lock Type) Joint Connector Housing M (Lever Type) Housing F 1.0mm (040) Terminal(UNIT : mm) 端子(毫米) (S) (M) Cable size(mm2) Cable size(mm2) 0.3〜0.5 适用电线大小 Material 材 质 Surface treatment 表面处理 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 材 质 27.75 1 M (8100-3508) F (8100-3082) Surface treatment 表面处理 0.75〜1.25 Heat-resistant copper alloy Tin-plated 镀锡 27.75 1 M (8100-3507) F(8100-3083) E- 07 17.25 Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 0.3〜0.5 17.25 2 Cable size(mm2) 0.75〜1.25 适用电线大小 Material Heat-resistant copper alloy Tin-plated 镀锡 材 质 Surface treatment 表面处理 1.0mm(040) Heat-resistant copper alloy Tin-plated 镀锡 (6914-0050) Material PP 材 质 Color 颜 色 20.6 φ 1.5 Brown 棕 Dummy plugs(UNIT : mm) 盲塞(毫米) ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 23way 1.0mm (040) Color Black 黒 颜 色 40.3 19.5 23.3 32.7 58 Retainer No. (6918-2131) Housing(UNIT : mm) M (6188-0660) F(6189-1082) 接插件护套 (毫米) 30.4 Ref: Terminal part No. 端子参照页 E-07 Ref: Dummy plug No. 盲塞参照页 E-07 Material 材 质 PBT 19.1 34.1 32.3 Retainer No. (6918-2132) 47.25 Color 颜 色 Black 黒 HX SEALED SERIES 2 23way Joint Connector Coupling circuit is connected with busbers as shown gray hatched cavities. E- 08 M (6188-4787) Color 39.7 Black 黒 颜 色 38.3 39.7 39.7 M (6188-4789) Color 38.3 Dark Gray 深灰 颜 色 39.7 39.7 M (5010-8627) Color 38.3 Dark Blue 藏青 颜 色 39.7 39.7 M(5011-1590) Color 38.3 Brown 棕 颜 色 39.7 39.7 M (5011-6687) Color 38.3 Blue 蓝 颜 色 39.7 F (6189-1082) Lever Lock 30.4 F (6189-6914) 27.8 19.1 34.1 32.3 19.1 27.8 32.3 Retainer No. (6918-2132) 47.25 Color 颜 色 Black 黒 Retainer No. (6918-2132) 42.9 Color 颜 色 Black 黒 33way (Rib difference) (Rib差异) 33way Color Color Black 黒 颜 色 Dark Gray 深灰 颜 色 51.3 51.3 19.5 40.5 19.5 23.3 44.3 40.5 Retainer No. (6918-2103) Retainer No. (6918-2103) M (6188-0697) F (6189-1050) 30.4 M (6188-0698) E- 09 19.1 40.1 34.1 Retainer No. (6918-2104) Color Retainer No. (6918-2104) 55.05 Black 黒 颜 色 Color Dark Gray 深灰 颜 色 Bracket Holder Bracket Holder (6920-0886) (6920-0861) 25.7 25.7 Color 颜 色 87.5 45.8 51 Color Black 黒 颜 色 Bracket Holder Black 黒 51 Bracket Holder (6920-2376) (6920-2377) 25.7 25.7 77.6 Color 颜 色 Dark Blue 藏青 78.6 Color 60.9 颜 色 Bracket Holder Black 黒 Bracket Holder (6920-0884) Color 颜 色 60.9 Black 黒 40.3 (6920-2466) 25.8 9.8 Color 颜 色 Black 黒 40.3 25.7 HX SEALED SERIES 40.1 34.1 F(6189-1051) 30.4 19.1 55.05 23.3 44.3 HX SEALED SERIES 22way Joint Connector HYBRID 0.64mm,1.0mm(025, 040) Structure/构造 Dummy Plug E- 10 Joint Connector Terminal F Housing F Retainer F (Lever Type) (Lock Type) Retainer F (Lever Type) Housing F (Lock Type) Dummy Plug Terminal F Joint Connector 0.64mm(025) (SS) F(8240-0408) Cable size(mm2) Terminal(UNIT : mm) 端子(毫米) 适用电线大小 Material 材 质 Surface treatment 表面处理 AVSSH0.22 Heat-resistant copper alloy Tin-plated 镀锡 1.96 15.8 (S) (M) F (8240-0409) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 AVSSH0.3〜0.5 Heat-resistant copper alloy Tin-plated 镀锡 F(8240-0410) Cable size(mm2) 1.96 1.0mm (040) 15.8 适用电线大小 Material 材 质 Surface treatment 表面处理 AVSSH0.75 Heat-resistant copper alloy Tin-plated 镀锡 1.96 15.8 (S) F(8240-0411) 适用电线大小 Material 材 质 Surface treatment 表面处理 AVSSH0.3 〜AVSSH0.5 Heat-resistant copper alloy Tin-plated 镀锡 2 16 (M) F(8240-0412) Cable size(mm2) Terminal(UNIT : mm) 端子(毫米) 适用电线大小 Material 材 质 Surface treatment 表面处理 AVSSH0.75 〜AVSSH1.25 Heat-resistant copper alloy Tin-plated 镀锡 2 0.64mm,1.0mm (025,040) (6914-0127) Material 材 质 Color 颜 色 Dummy plugs(UNIT : mm) 盲塞(毫米) ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 16 PBT Blue 蓝 φ 1.7 13.4 HX SEALED SERIES Cable size(mm2) E- 11 0.64mm,1.0mm (025,040) Housing(UNIT : mm) 接插件护套 (毫米) E- 12 Ref: Terminal part No. 端子参照页 [0.64mm]  E-10 [1.0mm]  E-11 Ref: Dummy plug No. 盲塞参照页 [0.64mm]  E-11 [1.0mm]  E-11 Material 材 质 PBT 22way (10+12) Joint Connector Coupling circuit is connected with busbers as shown gray hatched cavities. 58.9 M (5011-6818) Color Brown 棕 颜 色 32.5 M(5011-7740) Color 39.35 58.9 Black 黒 颜 色 32.5 58.9 M (5011-7860) Color Dark Gray 深灰 颜 色 39.35 32.5 F (6189-7264) 39.35 Lever Lock 35.7 30.4 18.1 28.3 33.7 43.3 Retainer No. (6918-3166) Color 颜 色 Black 黒 F (6189-7263) 18.1 28.3 27.8 30.4 Retainer No. (6918-3166) Color 颜 色 Black 黒 HX SEALED SERIES for STANDARD 1.5mm(060) Structure/构造 Terminal M E- 13 Housing F Terminal F 1.5mm (060) Terminal(UNIT : mm) 端子(毫米) HX SEALED SERIES Housing M (SS) (S) Cable size(mm2) Cable size(mm2) 0.13〜0.22 适用电线大小 Material 材 质 Surface treatment 表面处理 0.3〜0.5 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 材 质 1.5 M (8230-5306) 22.35 F (8240-0489) Surface treatment 表面处理 Brass 黄铜 Tin-plated 镀锡 22.35 1.5 M (8230-5307) F(8240-0490) E- 14 15.5 2.6 Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 0.13〜0.22 15.5 Cable size(mm2) 适用电线大小 Material Heat-resistant copper alloy Tin-plated 镀锡 (M) 材 质 Surface treatment 表面处理 0.3〜0.5 Heat-resistant copper alloy Tin-plated 镀锡 (L) Cable size(mm ) 2 Cable size(mm2) 0.75〜1.25 适用电线大小 Material 材 质 Surface treatment 表面处理 Material Brass 黄铜 Tin-plated 镀锡 15.5 2.0 适用电线大小 材 质 1.5 M (8230-5308) 2.6 2.6 22.35 F(8240-0491) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 0.75〜1.25 Surface treatment 表面处理 Brass 黄铜 Tin-plated 镀锡 M (8230-5309) 2.6 15.5 F (8240-0492) Cable size(mm2) 适用电线大小 Material Heat-resistant copper alloy Tin-plated 镀锡 22.35 1.5 材 质 Surface treatment 表面处理 2.0 Heat-resistant copper alloy Tin-plated 镀锡 1.5mm(060) (SS) (7165-1562) Wire seals(UNIT : mm) 电线密封栓 (毫米) 电线密封栓为公端、母端共用。 φ 4.6 Cable overall diameter(㎜) 0.85〜1.2 带绝缘层外径 Silicon Material 硅 材 质 Violet Color 紫 颜 色 8.2 (S) (M) (7165-1563) φ 4.6 Cable overall diameter(㎜) 1.05〜1.5 带绝缘层外径 Silicon Material 硅 材 质 Sky Blue Color 天蓝 颜 色 8.2 (L) (7165-1564) φ 4.6 Cable overall diameter(㎜) 1.35〜1.9 带绝缘层外径 Silicon Material 硅 材 质 Light Green Color 淡绿 颜 色 8.2 (LL) (7165-1565) (7165-1566) E- 15 φ 4.6 φ 4.6 8.2 Cable overall diameter(㎜) 2.4〜3 带绝缘层外径 Silicon Material 硅 材 质 Dark Yellow Color 深黄色 颜 色 8.2 1.5mm (060) Dummy plugs(UNIT : mm) 盲塞(毫米) Ref; 1.5mm Dummy plug detail 1.5mm盲塞参照页 (7165-0193)  J-07 ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 2way 1.5mm (060) Color Black 黒 颜 色 35.8 17.25 Housing(UNIT : mm) 接插件护套 (毫米) 17 M (6181-6851) Ref: Terminal part No. 端子参照页 E-14 Ref: wire seal No. 电线密封栓参照页 E-14 Ref: Dummy plug No. 盲塞参照页 J-07 Material 材 质 PBT F(6189-7408) 16.25 19 23.25 Color 颜 色 Black 黒 HX SEALED SERIES Cable overall diameter(㎜) 1.75〜2.4 带绝缘层外径 Silicon Material 硅 材 质 Blue Color 蓝 颜 色 3way 4way F (6189-7494) Color Black 黒 颜 色 35.8 16.25 23.6 23.25 21.85 Color Black 黒 颜 色 17 M (6181-6783) F(6189-7409) E- 16 20.85 19 23.25 Color Black 黒 颜 色 8way 12way Color Color Black 黒 颜 色 Black 黒 颜 色 35.8 35.8 22.75 26.2 M (6181-6850) F(6189-7423) 22.75 35.4 M (6181-6784) F(6189-7410) 23.25 21.75 29 21.75 38.2 Color 颜 色 Black 黒 23.25 Color 颜 色 Black 黒 HX SEALED SERIES for STANDARD 2.3mm (090) Structure/构造 Retainer M E- 17 Terminal M Connector M Connector F Connector seal Housing F Wire seal Terminal F 2.3mm(090) Terminal(UNIT : mm) 端子(毫米) Ref; 2.3mm Terminal detail 2.3mm端子参照页 (S) F(8240-4862) Cable size(mm ) 2 适用电线大小 S M(8230-4472) L-02 Cable overall diameter(mm) M M(8230-4562) L-02 Material L M(8230-4552) L-02 Surface treatment 带绝缘层外径 材 质 表面处理 0.3〜0.5 1.4〜2.4 Heat-resistant copper alloy Tin-plated 镀锡 2.4 3 18 HX SEALED SERIES Connector M Wire seal (L) (M) F(8240-4952) F (8240-4992) Cable size(mm ) 2 0.75〜0.85 适用电线大小 Cable overall diameter(mm) 1.8〜2.6 带绝缘层外径 Material Heat-resistant copper alloy Tin-plated 镀锡 材 质 Surface treatment 表面处理 E- 18 Cable size(mm ) 2 适用电线大小 2.4 Cable overall diameter(mm) 18 3 带绝缘层外径 Material 材 质 Surface treatment 表面处理 1.25〜2.0 2.1〜2.9 Heat-resistant copper alloy Tin-plated 镀锡 2.4 18 3 2.3mm(090) (SS) (7165-0385) Wire seals(UNIT : mm) Cable size(mm2) 电线密封栓 (毫米) 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 The wire seals are common to M and F. Material 颜 色 (S) φ5 1.2〜1.7 Silicon 硅 Gray 灰 材 质 Color 电线密封栓为公端、母端共用。 (AVSS/0.3〜0.5) (AVSSX/0.5) 6.4 (M) (7165-0194) Cable size(mm ) 2 适用电线大小 (AV/0.5) (AVX・AEX/0.5〜0.75) (AVS/0.3〜0.85) (AVSS/0.85〜1.25) (AVSSX/0.75〜1.25) Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Color 颜 色 1.7〜2.4 Silicon 硅 Green 绿 2.3mm (090) Dummy plugs(UNIT : mm) 盲塞(毫米) Ref; 2.3mm Dummy plug detail 2.3mm盲塞参照页 (7165-0193)  J-07 ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 (7165-0198) Cable size(mm ) 2 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Color 颜 色 (AV/0.5〜1.25) (AVX・AEX/0.75〜1.25) (AVS/0.85〜1.25) (AVSS/1.25〜2.0) (AVSSX/1.25〜2.0) 2.1〜2.9 Silicon 硅 Yellow 黄 1way 2.3mm(090) Color Black 黒 颜 色 15.8 9.6 17.6 9.6 Housing(UNIT : mm) Retainer No. (6918-2665) 接插件护套 (毫米) M (6181-0803) E-17 Ref: wire seal No. 电线密封栓参照页 E-18 Ref: Dummy plug No. 盲塞参照页 Material 材 质 F(6189-0591) 9.4 21.6 J-07 19.4 PBT Retainer No. (6918-1370) 28.3 Color (Rib difference) (Rib差异) 2way 2way F (6189-0593) F (6189-0552) 9.4 9.4 28.3 21.4 13 Note) 21.6 Color 13 28.3 Retainer No. (6918-1260) Note) 21.4 Black 黒 颜 色 Retainer No. (6918-1260) Color Brown 棕 颜 色 4way 3way F(6189-0617) F(6189-0596) 9.4 23.1 29.0 Black 黒 颜 色 21.6 E- 19 9.4 19 28.3 Note) Color 颜 色 Retainer No. (6918-1371) Black 黒 9.4 21.6 34.0 28.3 22 Note) Color 颜 色 Retainer No. (6918-1469) Black 黒 HX SEALED SERIES Ref: Terminal part No. 端子参照页 38 E- 20 HX SEALED SERIES for HYBRID (S) 4.8mm (187) F(8100-0661) Cable size(mm2) 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Surface treatment 表面处理 Terminal(UNIT : mm) 端子(毫米) 1.4〜2.4 6 19.5 Heat-resistant copper alloy Tin-plated 镀锡 (M) F(8100-0660) Ref; 4.8mm Terminal detail 4.8mm端子参照页 Cable size(mm2) 适用电线大小 S M(8100-0463)B-19 Cable overall diameter(mm) M M(8100-0464) B-19 Material L M(8100-0465) B-19 0.3〜0.5 3.8 带绝缘层外径 材 质 F (8100-0468) B-19 4.8mm (187) Surface treatment 表面处理 0.5〜1.25 1.6〜2.6 (7165-0172) Cable overall diameter(mm) 带绝缘层外径 Material (AVS/0.3) (AVSS/0.3〜0.85) (AVSSX/0.5〜0.75) Color 1.4〜1.9 Brown 棕 颜 色 (M) 9 for 2.3mm, 4.8mm 10way (7165-0130) Cable size(mm ) 2 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 电线密封栓为公端、母端共用。 φ8 NBR 材 质 The wire seals are common to M and F. 19.5 for 2.3mm, 4.8mm 10way 适用电线大小 电线密封栓 (毫米) 6 Heat-resistant copper alloy Tin-plated 镀锡 (S) Cable size(mm2) Wire seals(UNIT : mm) 3.8 Material 材 质 Color 颜 色 (AV/0.5〜1.25) (AVX/0.5〜1.25) (AVS/0.3〜1.25) (AVSS/0.85〜2.0) (AVSSX/0.75〜2.0) φ8 1.8〜2.9 NBR Gray 灰 9 (L) for 2.3mm, 4.8mm 10way (7165-0131) Cable size(mm ) 2 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Color 颜 色 (AV/2.0〜3.0) (AVX/2.0〜3.0) (AVS/2.0〜3.0) 3.0〜4.1 NBR Black 黒 (M) for 1.0mm, 4.8mm 13way (L) for 1.0mm, 4.8mm 13way (7165-0148) (7165-0147) Cable size(mm2) Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Color 颜 色 (AVS/0.3〜1.25) 适用电线大小 Cable overall diameter(mm) 1.8〜2.9 带绝缘层外径 Silicon 硅 Dark Green 墨绿 Material 材 质 9 Color 颜 色 3.0〜4.1 Silicon 硅 Dark Blue 藏青 9 13way(12+1) 1.0mm, 4.8mm (040, 187) Color Black 黒 颜 色 Housing(UNIT : mm) 29.65 15.9 35.1 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 [1.0mm] [4.8mm] E-02 E-20 Ref: wire seal No. 电线密封栓参照页 [1.0mm] [4.8mm] E-03 E-21 Ref: Dummy plug No. 盲塞参照页 [1.0mm] [4.8mm] E-04 B-21 Material 材 质 φ8 (AVS/2.0〜3.0) 40.9 45.9 Retainer No. (6181-6465) M (6181-6464) F(6189-6863) 16.3 35.5 29.9 PBT No. of way/( )corresponds to 1.0mm, 4.8mm, in order from left to right. 极数/( )内显示 :从左向右为1.0mm 极数、4.8mm 极数 31.1 50.05 Retainer No. (6185-4596) Color Black 黒 颜 色 4way(2+2) 1.5mm, 4.8mm (060, 187) Color Black 黒 颜 色 44.8 Housing(UNIT : mm) 21.85 23.8 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 [1.5mm] [4.8mm] E-14 E-20 Ref: wire seal No. 电线密封栓参照页 [1.5mm] [4.8mm] E-15 E-20 Ref: Dummy plug No. 盲塞参照页 [1.5mm] [4.8mm] J-07 B-21 Material 材 质 PBT No. of way/( )corresponds to 1.5mm, 4.8mm, in order from left to right. 极数/( )内显示 :从左向右为1.5mm 极数、4.8mm 极数 M (6181-6785) F(6189-7411) 25.55 25.8 28.9 Color 颜 色 Black 黒 E- 21 HX SEALED SERIES 适用电线大小 Cable size(mm2) φ8 5way(3+2) Color Dark gray 深灰 颜 色 44.8 21.85 23.8 M (6181-6921) F (6189-7567) E- 22 25.55 25.8 28.9 Color 颜 色 Dark gray 深灰 10way(8+2) 2.3mm, 4.8mm (090, 187) Color 34.8 Housing(UNIT : mm) 24.7 接插件护套 (毫米) [2.3mm] [4.8mm] E-17 E-20 Ref: wire seal No. 电线密封栓参照页 [2.3mm] [4.8mm] E-18 E-21 Ref: Dummy plug No. 盲塞参照页 [2.3mm] [4.8mm] J-07 B-21 Retainer No. (6918-1263) M (6181-0381) F(6189-0555) 24.5 43.1 24.5 PBT No. of way/( )corresponds to 2.3mm, 4.8mm, in order from left to right. 极数/( )内显示 :从左向右为2.3mm 极数、4.8mm 极数 43.2 32.3 24.7 Ref: Terminal part No. 端子参照页 Material 材 质 Dark gray 深灰 颜 色 34.2 35.5 Retainer No. (6918-1267) Color 颜 色 Dark gray 深灰 NH SERIES Features The NH series connector is a highly reliable for connector mating and terminal insertion. This series consist of 0.64mm and hybrid type(0.64mm+2.3mm) terminal usable for control circuit and low power circuit. ◦ T he front mask of Female connector assists allure male terminal. ◦ B y set ti ng TPA ( Te r m i na l Position Assur rance) adjust the incomplete inserted terminal to the correct position. ◦A  n extra clip can be attached to the connector housing to secure it to the body. ◦ RoHS/ELV Compliant 特 点 NH 系列在接插件嵌合或端子插入不足等方面提高 了可信性。 端子尺寸由0.64mm 与混合型 (0.64mm+2.3mm) 构成,可以应用于信号回路与低功率回路。 ◦母端接插件由于采用了前锁制,在接插件嵌合 时提高了公端子的引导性。 ◦未完全插入的端子能够通过锁片的安装插入到  正确的位置。 ◦接插件护套能够安装夹钉以固定在车体上。 ◦可对应欧盟 RoHS 和 ELV 指令 NH SERIES for STANDARD 0.64mm (025) Structure/构造 Housing M Terminal M F- 02 Retainer Connector M Connector F Housing F Terminal F Retainer 0.64mm (025) Terminal(UNIT : mm) 端子(毫米) (S) (M) Cable size(mm2) Cable size(mm2) 0.22〜0.5 适用电线大小 Material 材 质 Surface treatment 表面处理 0.75 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment 表面处理 0.64 M (8230-5379) 0.64 22.6 F (8240-0552) 1.7 M (8230-5380) 22.6 F(8240-0523) 1.7 Cable size(mm2) 16.5 0.22〜0.5 适用电线大小 Material 16.5 Heat-resistant copper alloy Tin-plated 镀锡 材 质 Surface treatment 表面处理 1.6 适用电线大小 Material 材 质 Surface treatment 表面处理 F- 03 0.75 Heat-resistant copper alloy Tin-plated 镀锡 0.64mm (025) 3way Housing(UNIT : mm) F(6098-7063) 接插件护套 (毫米) 12.25 Ref: Terminal part No. 端子参照页 F-02 Material 材 质 PBT 21 6.4 Color Natural 自然色 颜 色 4way 8way Color Natural 自然色 颜 色 Color Natural 自然色 颜 色 15.1 12.15 33.9 33.9 14 M (6098-5310)TH 04 MW-NH TH 04 FW-NH 14.2 F (6098-5267) M (6098-5271)TH 08 MW-NH TH 08 FW-NH F (6098-5269) 10.05 15.45 19 11.8 21 Color 颜 色 Natural 自然色 11 Color 颜 色 Natural 自然色 NH SERIES 1.6 Cable size(mm2) 8way 8way TH 08 FB-NH F (6098-6451) TH 08 FGY-NH F (6098-6452) 15.45 15.45 21 21 Color 13 Black 黒 颜 色 Color 13 Gray 灰 颜 色 8way 8way TH 08 FL-NH F- 04 F (6098-6522) TH 08 FG-NH 15.45 F(6098-6523) 15.45 21 21 13 Color 13 Blue 蓝 颜 色 Color Green 绿 颜 色 8way 10way TH 08 FW-1V-NH F (6098-5312) TH 10 FB-NH 15.45 10.5 21 21.8 F(6098-5273) 21 Color 14.54 Natural 自然色 颜 色 Color Black 黒 颜 色 10way 10way TH 10 FW-NH F (6098-7066) TH 10 FGY-NH 15.45 15.45 21 16.54 F (6098-7067) Color 16.54 Natural 自然色 颜 色 12way 21 Color Gray 灰 颜 色 12way Color TH 12 FB-NH Natural 自然色 颜 色 15.45 15.1 33.9 18.6 M (6098-5277)TH 12 MW-NH TH 12 FW-NH F(6098-6455) 21 17.4 Color 颜 色 Black 黒 F (6098-5275) 12way TH 12 FGY-NH 15.45 15.45 21 15.4 F(6098-6456) 21 Color 颜 色 Natural 自然色 17.4 Color 颜 色 Gray 灰 12way 12way TH 12 FL-NH F (6098-6457) TH 12 FG-NH F(6098-6524) 15.45 21 Color 17.4 Blue 蓝 颜 色 Color Green 绿 颜 色 16way 16way Color TH 16 FB-NH ASSY Natural 自然色 颜 色 F- 05 15.1 15.45 21.8 23 TH 16 FW-NH 21 Color Black 黒 颜 色 F (6098-5279) 16way TH 16 FGY-NH ASSY 15.45 F (6098-7100) 15.45 21 19.8 Color 21.8 Natural 自然色 颜 色 颜 色 Color Gray 灰 颜 色 24way 24way Color 21 TH 24 FB-NH Natural 自然色 F(6098-7060) 15.1 15.45 33.9 28.6 31.8 M(6098-5285)TH 24 MW-NH TH 24 FW-NH 21 Color 颜 色 Black 黒 F(6098-5283) 24way TH 24 FGY-NH 15.45 15.45 21 28.6 F(6098-7061) Color 颜 色 Natural 自然色 28.6 21 Color 颜 色 Gray 灰 NH SERIES 33.9 M(6098-5281)TH 16 MW-NH F (6098-7099) 32way 40way Color Color Natural 自然色 颜 色 Natural 自然色 颜 色 15.1 15.1 33.9 33.9 49.4 40.6 M (6098-5289)TH 32 MW-NH F- 06 TH 32 FW-NH F (6098-5287) M (6098-5585)TH 40 MW-NH 15.45 TH 40 FW-NH F(6098-5291) 15.45 21 21 37.4 46.2 Color Color Natural 自然色 颜 色 40way 颜 色 Natural 自然色 40way TH 40 FB-NH F (6098-5293) TH 40 FGY-NH 15.45 46.2 15.45 21 Color 颜 色 Black 黒 40way TH 40 FG-NH F (6098-5297) 15.45 46.2 F(6098-5295) 21 Color 颜 色 Green 绿 46.2 21 Color 颜 色 Gray 灰 NH SERIES for HYBRID F- 07 NH SERIES (SS) 2.3mm (090) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 0.22 Brass 黄铜 Tin-plated 镀锡 2.3 M (8230-5168) 23.6 F(8240-0367) 2.55 Cable size(mm2) Terminal(UNIT : mm) 3 17.4 适用电线大小 Material 材 质 Surface treatment 端子(毫米) 表面处理 (S) 0.22 Heat-resistant copper alloy Tin-plated 镀锡 (M) Cable size(mm ) 2 适用电线大小 Material 材 质 Surface treatment 表面处理 Cable size(mm2) 0.3〜0.5 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment 2.3 M (8230-5169) 表面处理 0.75〜1.0 Brass 黄铜 Tin-plated 镀锡 2.3 23.6 F(8240-0368) 2.55 M (8230-5170) 23.6 F(8240-0369) 2.55 Cable size(mm2) 3 17.4 适用电线大小 Material 材 质 Surface treatment 表面处理 Cable size(mm2) 0.3〜0.5 Heat-resistant copper alloy Tin-plated 镀锡 3 17.4 适用电线大小 Material 材 质 Surface treatment 表面处理 0.75〜1.0 Heat-resistant copper alloy Tin-plated 镀锡 (L) (LL) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 Cable size(mm2) 1.25 Material Brass 黄铜 Tin-plated 镀锡 Brass 黄铜 Tin-plated 镀锡 材 质 Surface treatment 表面处理 2.3 M (8230-5171) F- 08 2.0〜2.5 适用电线大小 2.3 23.6 F (8240-0370) 2.55 M (8230-5172) 23.6 F(8240-0371) 2.55 Cable size(mm2) 3 17.4 适用电线大小 Material 材 质 Surface treatment 表面处理 Cable size(mm2) 1.25 3 Heat-resistant copper alloy Tin-plated 镀锡 适用电线大小 17.4 Material 材 质 Surface treatment 表面处理 2.0〜2.5 Heat-resistant copper alloy Tin-plated 镀锡 0.64mm, 2.3mm (025, 090) Housing(UNIT : mm) 20way(18+2) 接插件护套 (毫米) NH 18 FW-CS2 [0.64mm] F-03 [2.3mm] F-07 Ref: Terminal part No. 端子参照页 Material 材 质 PBT 15.55 22 No. of way/( )corresponds to 0.64mm, 2.3mm, in order from left to right. 极数/( )内显示 :从左向右为0.64mm 极数、2.3mm 极数 20way(10+10) Color 颜 色 F(6098-7261) 30.6 Color Natural 自然色 颜 色 20way(10+10) Color Natural 自然色 Black 黒 颜 色 35.35 38.3 M (6098-5989)NH 10 MW-CS10 NH 10 FW-CS10 35.35 19.65 F (6098-5988) 38.3 M (6098-7254)NH 10 MW-CS10-B 16.75 36.5 NH 10 FW-CS10-B 19.65 F(6098-7253) 16.75 21.55 Color 颜 色 Natural 自然色 36.5 21.55 Color 颜 色 Black 黒 RS SERIES Features RS series consists of a 2.3mm type classified according to terminal size, supporting use in a variety of control circuits and low power circuits. ◦ The RS-standard type connectors adopt an inertia locking system to prevent semi-engagement (this system is not incorporated in some connectors). *Please contact our sales representative for product numbers. ◦ RoHS/ELV Compliant 特 点 RS 系列的端子尺寸由2.3mm 构成,可以应用于各 种控制回路与低功率回路。 ◦ RS 标准类型接插件采用惯性锁闭方式,使接  插件不易发生半插入。 ◦可对应欧盟 RoHS 和 ELV 指令 RS SERIES for STANDARD Type1 2.3mm (090) Structure/构造 Retainer Wire seal Housing M Retainer G-02 Wire seal Terminal M Housing M Terminal M Connector M Connector F Terminal F Housing F Wire seal Retainer Wire seal Terminal F Retainer 2.3mm (090) Terminal(UNIT : mm) 端子(毫米) Housing F (S) (S) Cable size(mm2) 0.3〜0.5 适用电线大小 Material Surface treatment 表面处理 Material Surface treatment 表面处理 M (8100-3803) 适用电线大小 Material 材 质 表面处理 Heat-resistant copper alloy Tin-plated 镀锡 F(8240-0266) Cable size(mm2) 0.3〜0.5 (M) 适用电线大小 18 3 Material 材 质 Surface treatment 表面处理 0.3〜0.5 Heat-resistant copper alloy Gold-plated 镀金 (M) Cable size(mm ) 2 Material Cable size(mm ) Surface treatment 表面处理 Material Surface treatment 表面处理 M (8100-3804) 适用电线大小 Material 材 质 Surface treatment 表面处理 2.3 23.6 F (8240-0264) Cable size(mm2) 3 Brass 黄铜 Gold-plated 镀金 材 质 2.3 18 0.85〜1.25 适用电线大小 Brass 黄铜 Tin-plated 镀锡 材 质 Au 2 0.85〜1.25 适用电线大小 M (8100-3806) Heat-resistant copper alloy Tin-plated 镀锡 适用电线大小 18 3 23.6 F(8240-0267) Cable size(mm2) 0.85〜1.25 (L) Material 材 质 Surface treatment 表面处理 0.85〜1.25 Heat-resistant copper alloy Gold-plated 镀金 (L) Cable size(mm ) 2 Material Cable size(mm ) Surface treatment 表面处理 Material Brass 黄铜 Gold-plated 镀金 材 质 Surface treatment 表面处理 2.3 M (8100-4172) 适用电线大小 Material 材 质 Surface treatment 表面处理 2.3 23.6 F (8240-0265) Cable size(mm2) 18 2.0 适用电线大小 Brass 黄铜 Tin-plated 镀锡 材 质 Au 2 2.0 适用电线大小 3 M (8100-3805) 23.6 M (8100-4173) Heat-resistant copper alloy Tin-plated 镀锡 F(8240-0268) Cable size(mm2) 2.0 3 18 23.6 适用电线大小 Material 材 质 Surface treatment 表面处理 2.0 Heat-resistant copper alloy Gold-plated 镀金 G-03 RS SERIES Surface treatment 2.3 23.6 F (8240-0263) Cable size(mm2) 3 Brass 黄铜 Gold-plated 镀金 材 质 2.3 18 0.3〜0.5 适用电线大小 Brass 黄铜 Tin-plated 镀锡 材 质 Au Cable size(mm2) (US) 2.3mm (090) (7165-0474) Cable size(mm ) 2 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material (AVSS/0.3) (CAVUS/0.3〜0.5) Silicon 硅 Orange 橙 材 质 Color 颜 色 φ 5.4 1.0〜1.4 φ 4.2 7 (S) (7165-0473) Wire seals(UNIT : mm) Cable size(mm2) 电线密封栓 (毫米) G-04 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material The wire seals are common to M and F. Color 颜 色 φ 5.4 1.5〜1.9 Silicon 硅 Light Blue 淡蓝 材 质 电线密封栓为公端、母端共用。 (AVSS/0.5〜0.85) (CAVUS/0.85〜1.25) φ 4.2 (L) (M) (7165-0471) (7165-0472) Cable size(mm2) 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 Material 材 质 Color 颜 色 Cable size(mm ) 2 (AVSS/1.25) φ 5.4 2.0〜2.4 Silicon 硅 Violet 紫 适用电线大小 Cable overall diameter(mm) 带绝缘层外径 φ 4.2 Material 7 材 质 Color 颜 色 7 (AVSS/2.0) φ 5.4 2.5〜2.9 Silicon 硅 Light Green 淡绿 φ 4.2 7 2.3mm(090) Dummy plugs(UNIT : mm) 盲塞(毫米) (7165-1131) ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 Material 材 质 Color 颜 色 Silicon 硅 Blue 蓝 5.45 8 1way 2.3mm (090) Housing(UNIT : mm) 8.9 19.4 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 G-02 Ref: wire seal No. 电线密封栓参照页 G-04 Ref: Dummy plug No. 盲塞参照页 G-04 Material 材 质 PBT 42.2 5.05 20.4 Retainer No. (6918-1773) M (6188-0551)RS 01 MB RS 01 FB 8.9 ※ Detail dimensions for mounting portion of the bracket are specifi ed in the offi cial drawing. Please contact our sales staff. 16.2 Retainer No. (6918-1773) 2way 22.9 8.9 42.2 8.7 22.9 8.9 22.1 22.1 Retainer No. (6918-1774) Retainer No. (6918-1774) M (6188-0554)RS 02 MGY RS 02 FGY F (6185-0867) M (6188-0552)RS 02 MB 8.7 8.9 26.25 Retainer No. (6918-1774) 8.9 22.9 8.7 26.25 20.4 8.9 Retainer No. (6918-1774) 42.2 14.3 22.3 8.9 42.2 27.7 22.1 Retainer No. (6918-1774) M (6188-0553)RS 02 MBR M (6188-0663)RS 02 MBR-DGY Retainer No. (6918-1775) RS 02 FBR RS 02 FBR-DGY F(6185-0866) F(6185-1101) M (6188-0556)RS 03 MGY 19.7 20.4 F (6185-0865) 3way 2way 8.7 RS 02 FB 19.7 19.7 20.4 42.2 26.25 RS 03 FGY F(6185-0869) 18.4 8.7 8.9 Retainer No. (6918-1774) 26 14.3 8.9 26.25 Retainer No. (6918-1775) RS SERIES 2way G-05 5.05 26.25 18.7 ※关于固定用支架相关事宜,请向敝公司销售负责人问讯。 8.7 F(6185-0862) 3way 14.3 4way 22.3 8.9 8.9 8.7 26.2 42.2 42.2 22.2 27.7 Retainer No. (6918-1776) Retainer No. (6918-1775) M (6188-0555)RS 03 MB RS 03 FB F(6185-0868) M (6188-0558)RS 04 MGY 14.3 26.25 26 8.9 8.7 4way Retainer No. (6918-1776) 6way 8.9 26.2 14.3 8.9 26.4 42.2 42.2 27.8 22.2 Retainer No. (6918-1779) Retainer No. (6918-1776) M (6188-0557)RS 04 MB RS 04 FB-PR F (6185-1169) M (6188-5540)RS 06 MGY 23.05 RS 06 FGY-PR 8.7 8.9 14.3 26.1 6way 8.9 26.25 Retainer No. (6918-1776) Retainer No. (6918-1779) 8way 8.9 26.4 19.9 26.8 8.9 42.2 27.8 42.2 35.4 Retainer No. (6918-1780) Retainer No. (6918-1779) M (6188-5539)RS 06 MB RS 06 FB-PR F(6185-5175) M (6188-5544)RS 08 MGY-PR 23.25 RS 08 FGY-PR F(6185-5181) 22.15 14.3 26.1 F(6185-5177) 23.25 26.25 20.5 14.3 8.9 26.25 20.5 Retainer No. (6918-1775) 8.7 F(6185-1171) 23.05 18.4 G-06 RS 04 FGY-PR 8.9 26.25 19.9 31.7 Retainer No. (6918-1779) 8.9 26.25 Retainer No. (6918-1780) 8way 19.9 26.8 8.9 42.2 35.4 Retainer No. (6918-1780) M (6188-5542)RS 08 MB-PR RS 08 FB-PR F (6185-5179) 22.15 31.7 26.25 19.9 8.9 RS SERIES Retainer No. (6918-1780) G-07 RS SERIES for STANDARD Type2 2.3mm (090) Structure/构造 Housing M Retainer M Wire seal Wire seal G-08 Housing M Terminal M Terminal M Retainer M Connector M Connector F Housing F Terminal F Wire seal Retainer F Wire seal Terminal F Housing F Retainer F 2way 2.3mm (090) 10.8 19.7 9 13.9 Housing(UNIT : mm) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 G-02 Ref: wire seal No. 电线密封栓参照页 G-04 Ref: Dummy plug No. 盲塞参照页 G-04 Material 材 质 PBT 37.4 19.7 Retainer No. (6918-1653) M (6181-0515)RS 02 MSB M (6181-0670)RS 02 MSB-B RS 02 FSB RS 02 FSB-B 20.6 23.4 F(6189-0951) F (6189-1107) 10.2 28.7 13.3 8.3 Retainer No. (6918-1651) 2way 10.8 3way 19.7 9 13.9 10.8 20.3 37.4 20.45 RS 02 FLGY F (6189-0950) 37.4 27.1 Retainer No. (6918-1654) Retainer No. (6918-1653) M (6181-0532)RS 02 MLGY 19.7 9 M (6181-0516)RS 03 MSB M (6181-0671)RS 03 MSB-GY RS 03 FSB RS 03 FSB-GY 19.6 10.2 20.6 28.7 8.3 13.3 23.4 10.2 8.3 28.7 29.8 19.7 16.7 Retainer No. (6918-1652) 4way 9 16.7 26 9 26 15.6 15.6 40.2 22.8 Retainer No. (6918-1598) M (6181-0513)RS 04 MG M (6181-0668)RS 04 MG-GY RS 04 FG RS 04 FG-GY 27.5 F(6189-7756) F(6189-7757) 28.5 26.4 M (6181-0514)RS 04 ML M (6181-0669)RS 04 ML-B RS 04 FL RS 04 FL-B 27.5 16.1 32.05 15 8.7 16.7 32.05 28.5 26.4 8.7 15 Retainer No. (6918-1599) 6way 9 26 16.7 9 26 21.2 21.2 40.2 Retainer No. (6918-1600) 28.4 M (6181-0511)RS 06 MG M (6181-0665)RS 06 MG-DGY RS 06 FG RS 06 FG-DGY 27.5 32.0 F (6189-7758) F (6189-7759) 16.1 Retainer No. (6918-1599) 6way 40.2 22.8 Retainer No. (6918-1598) 32.05 28.5 F(6189-7760) F(6189-7761) 16.1 8.7 20.6 Retainer No. (6918-1601) 40.2 Retainer No. (6918-1600) 28.4 M (6181-0536)RS 06 ML M (6181-0664)RS 06 ML-B RS 06 FL RS 06 FL-B 16.1 27.5 32.0 F(6189-7762) F(6189-7763) 32.05 28.5 8.7 20.6 Retainer No. (6918-1601) G-09 RS SERIES Retainer No. (6918-1651) 4way F(6189-0928) F (6189-1104) 8way 8way 16.7 16.7 9 40.2 34 Retainer No. (6918-1602) M (6181-0512)RS 08 MG M (6181-0667)RS 08 MG-GY RS 08 FG RS 08 FG-GY 27.5 37.6 26 26.8 26.8 G-10 9 26 F (6189-0954) F (6189-1108) 16.1 32.05 28.5 8.7 26.2 Retainer No. (6918-1603) 40.2 34 Retainer No. (6918-1602) M (6181-0522)RS 08 ML M (6181-0666)RS 08 ML-B RS 08 FL RS 08 FL-B 16.1 27.5 32.05 37.6 F (6189-0955) F (6189-1109) 28.5 8.7 26.2 Retainer No. (6918-1603) RS SERIES for E-RS 2.3mm (090) Structure/构造 Housing F Mating portion (Connector M) Connector F (After setting retainer) G-11 Housing F RS SERIES Retainer F Wire seal Wire seal Retainer F Terminal F Terminal F 1way 2.3mm(090) E 01 FGY-RS 20.3 Housing(UNIT : mm) 19.1 F(6098-2329) 8.9 8.6 26.9 8.9 Retainer No. (6918-1636) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 G-02 Ref: wire seal No. 电线密封栓参照页 G-04 Ref: Dummy plug No. 盲塞参照页 G-04 Material 材 质 PBT 2way E 02 FGY-RS 20.6 F(6189-0772) 10.2 9.3 22.8 28.3 12.7 Retainer No. (6918-1594) 2way 2way E 02 FB-RS F (6189-0773) E 02 FBR-RS E 02 FBR-RS-GY 20.6 20.6 10.2 10.2 9.3 22.8 12.7 28.3 22.8 Retainer No. (6918-1594) F(6189-0775) E 02 FG-RS-LGY F (6189-1094) E 02 FR-RS E 02 FG-RS E 02 FR-RS-GY 20.6 20.6 9.3 28.3 12.7 22.8 9.3 28.3 12.7 Retainer No. (6918-1594) Retainer No. (6918-1594) 2way 2way E 02 FL-RS E 02 FL-RS-LGY 20.6 F (6189-0777) F (6189-1096) E 02 FPU-RS E 02 FPU-RS-B 10.2 9.3 28.3 F (6189-0778) F (6189-1097) 20.6 10.2 12.7 22.8 3way 9.3 28.3 12.7 Retainer No. (6918-1594) Retainer No. (6918-1594) 3way E 03 FGY-RS F(6189-7471) E 03 FBR-RS E 03 FBR-RS-B 19.6 28.3 F (6189-7710) F(6189-7711) 19.6 10.2 29.8 F (6189-0776) F (6189-1095) 10.2 10.2 22.8 12.7 2way 2way 22.8 9.3 28.3 Retainer No. (6918-1594) G-12 F (6189-0774) F (6189-1093) 10.2 9.3 19.7 29.8 19.7 Retainer No. (6918-1595) 4way 9.3 28.3 Retainer No. (6918-1595) 4way E 04 FGY-RS F(6189-7469) E 04 FBR-RS E 04 FBR-RS-LGY 19.6 19.6 10.2 F(6189-7713) F(6189-7714) 10.2 9.3 32.8 28.3 9.3 22.7 32.8 28.3 Retainer No. (6918-1596) 5way 22.7 Retainer No. (6918-1596) 5way E 05 FGY-RS F(6189-7470) E 05 FBR-RS E 05 FBR-RS-B 19.6 19.6 10.2 28.3 37.8 F(6189-7716) F(6189-7717) 10.2 9.3 27.7 Retainer No. (6918-1604) 9.3 37.8 28.3 27.7 Retainer No. (6918-1604) 6way E 06 FGY-RS F (6189-7393) 19.6 10.2 42.8 28.3 32.7 9.3 Retainer No. (6918-1597) G-13 RS SERIES TL SEALED SERIES Features The TL sealed connector series has a mechanism that detects terminal incomplete insertion by using a dedicated jig. This series consists of 2.3mm type supporting use in a variety of control circuits and low power circuits. ◦ T o restrain from incomplete engagement, this series is adopted a lock mechanism with effective clear sound. ◦These male connectors can be directly  secured to a bracket on the car body. (Note: Please contact our sales staff, if you have any questions regarding the dedicated jig.) ◦RoHS/ELV Compliant 特 点 TL 防水系列采用了以专用治具检测出端子半插入 的构造。 TL 系列的端子尺寸由2.3mm 构成,可以应用于各 种控制回路与低功率回路。 ◦为防止接插件半嵌合的发生,采用了增强锁闭 音的锁闭构造。 ◦公端接插件可以直接固定在车体支架上。  注意 :有关专用导通治具的详情请向敝公司销售 负责人确认。 ◦可对应欧盟 RoHS 和 ELV 指令 TL SEALED SERIES for STANDARD 2.3mm (090) Structure/构造 Housing M Housing M Wire seal Terminal M Retainer Wire seal Terminal M Housing M Body fastening braket mount 车体固定用支架安装部位 Terminal M H- 02 Connector M Connector F Housing F Housing F Housing F Wire seal Wire seal Terminal F Terminal F Retainer Connector seal Terminal F Connector seal 2.3mm (090) 2.3mm (090) Terminal(UNIT : mm) Wire seals(UNIT : mm) 端子(毫米) 电线密封栓(毫米) Ref; 2.3mm Terminal detail 2.3mm端子参照页 S M(8230-4472) L-02 Ref; 2.3mm Wire Seals detail 2.3mm电线密封栓参照页 M M(8230-4562) L-02 F (8100-1427) F (8100-1429) L M(8230-4552) L-02 F (8100-1428) L-02 S (7165-0516) M (7165-0515) L-02 L(7165-0514) L-02 J-06 J-06 J-06 2.3mm (090) Dummy plugs(UNIT : mm) 盲塞(毫米) Ref; 2.3mm Dummy plug detail 2.3mm盲塞参照页 (7165-0193)  J-07 ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 H- 03 TL SEALED SERIES 1way 2.3mm(090) Color Black 黒 颜 色 18.35 Housing(UNIT : mm) 接插件护套 (毫米) M (6181-6658) Ref: Terminal part No. 端子参照页 L-02 Ref: wire seal No. 电线密封栓参照页 J-06 Ref: Dummy plug No. 盲塞参照页 J-07 Material 材 质 PBT 40.3 13.7 F(6189-7214) 22.2 16 26.3 Color 颜 色 2way Black 黒 4way F (6189-7189) F (6189-7188) 22.2 22.2 21 31 26.3 Color 颜 色 Black 黒 5way F(6189-7190) 22.2 36 26.3 Color 颜 色 Black 黒 26.3 Color 颜 色 Black 黒 SL SERIES Features The SL connector series is adopted a mechanism that detects terminal incomplete insertion by using a dedicated jig. This series consists of 1.5mm, 2.3mm and 2.8mm types classified according to the terminal size, covering an extensive array of applications from signal circuits to low power circuits. ◦ T hese connectors can be directly secured to a bracket on the car body. In addition, an extra clip can be attached to the connector to secure it to the car body. (Note: Please contact our sales staff, if you have any questions regarding the dedicated jig.) ◦RoHS/ELV Compliant 特 点 SL 系列接插件采用了以专用治具检测端子半插入 的构造。 按照端子尺寸划分为1.5mm·2.3mm·2.8mm 类 型,从信号回路到电源回路,能广泛运用。 ◦接插件可以直接固定在车体的支架上。还可以 在接插件上安装用于固定到车体上的卡钉(卡 子)。 注意 :有关专用导通治具的详情请向敝公司销售 负责人确认。 ◦可对应欧盟 RoHS 和 ELV 指令 SL SERIES for STANDARD 1.5mm (060) Structure/构造 Terminal M Housing M Terminal M Housing M I- 02 Connector M Connector F Housing F Terminal F Housing F Terminal F 1.5mm (060) Terminal(UNIT : mm) 端子(毫米) Note) L size terminal can be used for 14 poled connectors with insertion cavity specifi ed. For details please contact our sales staff. ※ L 尺寸端子的可用接插件有限制。  务必向敝公司销售负责人问讯。 (S) (S) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 Au Cable size(mm2) 0.3〜0.5 适用电线大小 Material Heat-resistant copper alloy Tin-plated 镀锡 材 质 27.3 Surface treatment 表面处理 0.3〜0.5 Heat-resistant copper alloy Gold-plated 镀金 1.5 M (8100-3382) 适用电线大小 Material 材 质 2.8 1.5 F (8100-3391) Cable size(mm2) 18 2.6 Surface treatment 表面处理 0.3〜0.5 M (8230-4883) 18 2.6 F(8240-0135) Cable size(mm2) 适用电线大小 Heat-resistant copper alloy Tin-plated 镀锡 Material 2.8 材 质 Surface treatment 表面处理 0.3〜0.5 Heat-resistant copper alloy Gold-plated 镀金 (L) Cable size(mm ) 2 适用电线大小 Material 材 质 Surface treatment 表面处理 Cable size(mm2) 0.75, 0.85〜1.25 适用电线大小 Material Heat-resistant copper alloy Tin-plated 镀锡 材 质 Surface treatment 27.3 表面处理 2.0 Heat-resistant copper alloy Tin-plated 镀锡 1.5 M (8100-3383) 18 Cable size(mm2) 适用电线大小 2.8 Material 材 质 Surface treatment 表面处理 27.3 1.5 F (8100-3392) 0.75, 0.85〜1.25 M (8100-3384) 18 2.6 F(8100-3393) Cable size(mm2) 适用电线大小 Heat-resistant copper alloy Tin-plated 镀锡 Material 2.8 材 质 Surface treatment 表面处理 2.0 Heat-resistant copper alloy Tin-plated 镀锡 1.5mm(060) Housing(UNIT : mm) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 I-02 Material 材 质 PBT Note) Connector can be used together with 2mm2 wire are 14 poled connectors. For details of each product, please contact our sales staff. ※ L 尺寸端子的可用接插件有限制。  务必向敝公司销售负责人问讯。 I- 03 SL SERIES (M) 2.6 27.3 4way F(6098-3456) 10.4 17.35 22 Color 颜 色 Natural 自然色 12way 12way Color F(6098-4876) Natural 自然色 颜 色 13.75 14.95 22.4 41 25.6 22 Color 颜 色 M (6098-3449) Natural 自然色 F (6098-8482) 14way F (6098-4877) Note) 11.75 13.75 22.4 22 26.7 Color 颜 色 I- 04 Natural 自然色 16way F(6098-3453) 17.35 29.4 22 Color 颜 色 Natural 自然色 22 Color 颜 色 Natural 自然色 SL SERIES for STANDARD 2.3mm(090) Structure/构造 Connector F I- 05 Terminal F SL SERIES Housing F 2.3mm (090) Terminal(UNIT : mm) 端子(毫米) Ref; 2.3mm Terminal detail 2.3mm端子参照页 S M (8230-4492)  A-10 F(8240-4882)  A-10 M M (8230-4502)  A-10 F(8240-4892)  A-10 L M (8230-4512)  A-10 F(8240-4942)  A-10 Regarding "Gold-plated Terminal", please refer "A-10". 镀金端子记载在A-10上 2way 2.3mm(090) F(6240-5337) 6.8 22 12.3 Color Natural 自然色 颜 色 4way Housing(UNIT : mm) F (6098-8478) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 A-10 Material 材 质 PBT 12.1 22 10.8 Color I- 06 6way Natural 自然色 颜 色 6way F(6240-5339) Color 颜 色 Note 备 注 15.5 Natural 自然色 With body fastening clamp 带防转卡钉 14.7 18.8 22 Color 颜 色 Natural 自然色 42.5 24.1 Plate thickness range for clamp : t=0.6〜2.0mm Hole=7.2mm×12mm M (6098-2679) F(6098-2680) 10.8 19.1 22 Color 颜 色 Natural 自然色 14way 12way F (6098-1747) F(6098-1714) 15.5 14.5 26.8 22 Color 颜 色 Natural 自然色 34.8 22 Color 颜 色 Natural 自然色 14way 14way F(6098-1774) F(6098-2101) 15.5 12 33.1 22 Color 颜 色 Natural 自然色 34.8 22 Color 颜 色 Black 黒 16way Color 颜 色 18way F(6098-1627) Natural 自然色 14.5 19.5 39.5 43.1 38.8 22 Color 颜 色 M (6098-1744) Natural 自然色 F (6098-1746) 15.5 38.8 22 Color 颜 色 Natural 自然色 I- 07 SL SERIES SL SERIES for STANDARD 2.8mm (110) Structure/构造 Terminal M Housing M Terminal M Housing M I- 08 Connector M Connector F Housing F Terminal F Housing F 2.8mm(110) Terminal F (S) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 0.3〜0.5 Heat-resistant copper alloy Tin-plated 镀锡 27.3 2.8 M (8100-3385) Terminal(UNIT : mm) 端子(毫米) 4.1 18 3.1 F(8100-3394) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 0.3〜0.5 Heat-resistant copper alloy Tin-plated 镀锡 (M) (L) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 Cable size(mm2) 0.85〜1.25 适用电线大小 Material Heat-resistant copper alloy Tin-plated 镀锡 材 质 27.3 2.8 M (8100-3386) 18 4.1 3.1 F (8100-3395) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 0.85〜1.25 Surface treatment 表面处理 2.0〜3.0 Heat-resistant copper alloy Tin-plated 镀锡 27.3 2.8 M (8100-3387) F(8100-3396) 18 4.1 Heat-resistant copper alloy Tin-plated 镀锡 Cable size(mm2) 适用电线大小 Material 3.1 材 质 Surface treatment 表面处理 2.0〜3.0 Heat-resistant copper alloy Tin-plated 镀锡 SL SERIES 4way 2.8mm (110) Color Natural 自然色 With body fastening clamp 带防转卡钉 颜 色 Note 备 注 19.8 41 14.6 Plate thickness range for clamp: t=0.6〜2.0mm Hole=7.2mm×10.2mm M (6098-3452) F(6098-8480) Housing(UNIT : mm) 接插件护套 (毫米) 16.6 Ref: Terminal part No. 端子参照页 Material 材 质 I-08 11.4 PBT 22 Color 颜 色 I- 09 Natural 自然色 1.5mm, 2.8mm (060, 110) Housing(UNIT : mm) Ref: Terminal part No. 端子参照页 Material 材 质 I- 10 极数/( )内显示 :1.5mm 极数、2.8mm 极数 ※ L 尺寸端子的可用接插件有限制。  务必向敝公司销售负责人问讯。 14way(10+4) 颜 色 Natural 自然色 Note) 16.1 41 32.4 M (6098-3450) F (6098-3458) 15.7 29.2 22 Note) Color 颜 色 PBT No. of way/( )corresponds to 1.5mm, 2.8mm, in order from left to right. Note) Connector can be used together with 2mm2 wire are 14 poled connectors. For details of each product, please contact our sales staff. SL SERIES for HYBRID Color [1.5mm] I-02 [2.8mm] I-08 Natural 自然色 SL SEALED SERIES Features The SL sealed connector series is adopted a mechanism that detects terminal incomplete insertion by using a dedicated jig. This series consists of 1.5mm, 2.3mm and 8.0mm types classified according to the terminal size, covering an extensive array of applications from signal circuits to low power circuits. ◦ T hese connectors can be directly secured to a bracket on the car body. In addition, an extra clip can be attached to the connector to secure it to the car body. (Note: Please contact our sales staff, if you have any questions regarding the dedicated jig.) ◦RoHS/ELV Compliant 特 点 SL 防水系列接插件采用了以专用治具检测端子半 插入的构造。 按照端子尺寸划分为1.5mm·2.3mm·8.0mm 类 型,从信号回路到电源回路,能广泛运用。 ◦接插件可以直接固定在车体的支架上。另外在 接插件上可安装为固定到车体的卡钉(卡子) 注意 :有关专用导通治具的详情请向敝公司销售 负责人确认。 ◦可对应欧盟 RoHS 和 ELV 指令 SL SEALED SERIES for STANDARD 1.5mm(060) Structure/构造 Housing M Wire seal Wire seal Housing M Terminal M Terminal M Connector M J- 02 Connector F Stopper Connector seal Wire seal Terminal F Terminal F Wire seal Stopper Housing F Housing F Body fastening clamp and Body fastening bracket mount 车体固定用卡钉以及 车体固定用支架安装部位 Connector seal 1.5mm (060) Terminal(UNIT : mm) 端子(毫米) ※ For terminal selection, please contact our sales staff. ※选定端子时,请一定向敝公司销售负责人问讯。 (S) (S) Cable size(mm2) 0.3〜0.5 适用电线大小 Material Surface treatment 表面处理 Material 27.3 1.5 F (8100-3397) 18 Cable size(mm2) 适用电线大小 Material 2.8 材 质 Surface treatment 表面处理 0.3〜0.5 Heat-resistant copper alloy Tin-plated 镀锡 (M) Surface treatment 表面处理 M (8100-3504) 2.6 Material 材 质 Surface treatment 表面处理 F(8100-3402) 18 Cable size(mm2) 适用电线大小 Material 2.8 材 质 Surface treatment 表面处理 0.3〜0.5 Heat-resistant copper alloy Gold-plated 镀金 Heat-resistant copper alloy Tin-plated 镀锡 Cable size(mm2) 适用电线大小 27.3 Material 材 质 Surface treatment 表面处理 M (8100-3389) F (8100-3398) Cable size(mm2) 18 适用电线大小 Material 2.8 材 质 Surface treatment 表面处理 0.75〜0.85 Heat-resistant copper alloy Tin-plated 镀锡 (L) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 1.25〜2.0 Heat-resistant copper alloy Tin-plated 镀锡 1.5 M (8100-3390) 18 Au M (8100-3403) 0.75〜0.85 1.5 2.8 27.3 27.3 F (8100-3399) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 1.25〜2.0 Heat-resistant copper alloy Tin-plated 镀锡 0.75〜0.85 Heat-resistant copper alloy Gold-plated 镀金 1.5 27.3 J- 03 SL SEALED SERIES 适用电线大小 2.6 1.5 (M) Cable size(mm2) 2.6 Heat-resistant copper alloy Gold-plated 镀金 材 质 M (8100-3388) 2.6 0.3〜0.5 适用电线大小 Heat-resistant copper alloy Tin-plated 镀锡 材 质 Au Cable size(mm2) 1.5mm(060) 1.5mm (060) Wire seals(UNIT : mm) Dummy plugs(UNIT : mm) 电线密封栓 (毫米) 盲塞(毫米) Ref; 1.5mm Terminal detail 1.5mm端子参照页 S (7165-0516) M (7165-0515) L (7165-0514) J- 04 Ref; 1.5mm Dummy plug detail 1.5mm盲塞参照页 J-07 (7161-9787)  (7165-0193)  J-07 J-07 B-15 J-07 2way 1.5mm (060) Color 颜 色 Note 备 注 Black 黒 J-11 Clamp:TYPE2 15.9 37.6 14.9 Housing(UNIT : mm) 接插件护套 (毫米) M (6181-6614) Ref: Terminal part No. 端子参照页 J-02 Ref: wire seal No. 电线密封栓参照页 J-06 Ref: Dummy plug No. 盲塞参照页 B-15 J-07 Material 材 质 PBT 20.45 颜 色 Note 备 注 28.4 18.1 Color 2way Color Dark Gray 深灰 J-11 Clamp:TYPE2 颜 色 Note 备 注 Black 黒 J-11 Clamp:TYPE2 15.9 14.5 14.9 M (6181-6509) 37.6 F(6189-1073) 20.45 18.1 Black 黒 颜 色 2way Color F(6189-1076) 14.9 M (6181-6492) 37.6 F(6189-1115) 24.4 28.4 Color 颜 色 Dark Gray 深灰 18.1 28.4 Color 颜 色 Note 备 注 Black 黒 J-11 Clamp:TYPE1 2way 2way F(6189-1144) F (6189-1147) 24 18 18.7 26.9 27.8 17 Color 颜 色 Color Black 黒 Black 黒 颜 色 2way 2way F(6189-1149) F (6189-1150) 22.3 21.95 16.8 28.25 Color 颜 色 Dark Gray 深灰 3way 28.25 16.8 Color J- 05 14way Color 颜 色 Dark Gray 深灰 20.25 24.7 28.8 Color 颜 色 34.5 Black 黒 M (6181-0629) 40.3 F(6189-7262) Color 颜 色 Note 备 注 Dark Gray 深灰 J-11 Clamp:TYPE1 SL SEALED SERIES F (6189-7115) 22.8 Dark Gray 深灰 颜 色 SL SEALED SERIES for STANDARD 2.3mm(090) Structure/构造 Terminal M Wire seal Housing M Terminal M Housing M Wire seal Connector M Connector seal J- 06 Connector F Stopper Wire seal Terminal F Wire seal Stopper Housing F Connector seal 2.3mm (090) Body fastening clamp and Body fastening bracket mount Housing F 车体固定用卡钉以及 车体固定用支架安装部位 2.3mm (090) Terminal(UNIT : mm) 端子(毫米) Ref; 2.3mm Terminal detail 2.3mm端子参照页 S (8230-4472) L-02 M (8230-4562) L-02 F (8100-1427) F (8100-1429) L (8230-4552) F (8100-1428) L-02 L-02 Wire seals(UNIT : mm) L-02 电线密封栓(毫米) L-02 Regarding "Gold-plated Terminal", please refer "L-02". 镀金端子记载在L-02上 The wire seals are common to M and F. 电线密封栓为公端、母端共用。 (S) (M) (7165-0516) Cable overall diameter(mm) Over than 1.4 mm below 1.6 mm 带绝缘层外径 Material 材 质 Color 颜 色 φ 4.7 φ 4.7 超过1.4mm在1.6mm以下 Silicon 硅 Black 黒 (7165-0515) Cable overall diameter(mm) Over than 1.6 mm below 2.4 mm 带绝缘层外径 Material 材 质 8.3 Color 颜 色 超过1.6mm在2.4mm以下 Silicon 硅 Gray 灰 8.3 (L) (7165-0514) Cable overall diameter(mm) Over than 2.4 mm below 2.7 mm 带绝缘层外径 Material 材 质 Color 颜 色 φ 4.7 超过2.4mm在2.7mm以下 Silicon 硅 Dark Green 墨绿 8.3 J- 07 SL SEALED SERIES 2.3mm(090) Dummy plugs(UNIT : mm) 盲塞(毫米) Ref; 2.3mm Dummy plug detail 2.3mm盲塞参照页 (7161-9787)  B-15 (7165-0193) ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 φ 4.7 Material 材 质 Color 颜 色 Silicon 硅 Green 绿 6.4 1way 2.3mm(090) Color 颜 色 Dark Gray 深灰 16.3 14 38 Housing(UNIT : mm) 接插件护套 (毫米) M (6181-0436) Ref: Terminal part No. 端子参照页 L-02 Ref: wire seal No. 电线密封栓参照页 J-06 Ref: Dummy plug No. 盲塞参照页 B-11 J-07 Material 材 质 PBT F(6189-0639) 21.2 17.2 28 Color 颜 色 Note 备 注 Dark Gray 深灰 J-11 Clamp:TYPE1 2way Color 颜 色 3way Color Dark Gray 深灰 颜 色 Dark Gray 深灰 14.7 14.7 19 M (6181-0437) 38 25 F (6189-0640) 28 21.3 Color Dark Gray 深灰 J-11 Clamp:TYPE1 颜 色 Note 备 注 4way Color 颜 色 F(6189-7784) 19.5 19.5 J- 08 M (6181-0438) 38 28 27.3 Color Dark Gray 深灰 J-11 Clamp:TYPE1 颜 色 Note 备 注 6way Color Dark Gray 深灰 颜 色 Dark Gray 深灰 20.1 20.1 20.8 M (6181-0439) 38 F (6189-0643) 25.7 M (6181-0440) 38 F(6189-0648) 24.9 24.9 23.1 28 Color 颜 色 Note 备 注 Dark Gray 深灰 J-11 Clamp:TYPE1 28 28 Color 颜 色 Note 备 注 Dark Gray 深灰 J-11 Clamp:TYPE1 SL SEALED SERIES for STANDARD 8.0mm (312) Structure/构造 Housing M Wire seal Housing M Terminal M Terminal M Wire seal Connector M Connector F Connector seal Stopper Terminal F Stopper Terminal F Wire seal Housing F Body fastening clamp and Body fastening bracket mount Housing F 车体固定用卡钉以及 车体固定用支架安装部位 Connector seal 8.0mm (312) Terminal(UNIT : mm) 端子(毫米) ※For terminal selection, please contact our sales staff. ※选定端子时,请一定向敝公司销售负责人问讯。 SL SEALED SERIES Wire seal J- 09 (M) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 (L) Cable size(mm2) 2.0〜3.0 适用电线大小 Material Brass 黄铜 Tin-plated 镀锡 32 8 材 质 Surface treatment 表面处理 5.0〜8.0 Brass 黄铜 Tin-plated 镀锡 2.8 M (8100-3259) 9 24.4 适用电线大小 Material 4.2 材 质 Surface treatment 表面处理 J- 10 2.8 F (8100-3257) Cable size(mm2) 32 8 M (8100-3260) 9 2.0〜3.0 F(8100-3258) 24.4 Cable size(mm2) 5.0〜8.0 适用电线大小 Material Heat-resistant copper alloy Tin-plated 镀锡 Heat-resistant copper alloy Tin-plated 镀锡 材 质 4.2 Surface treatment 表面处理 8.0mm (312) 8.0mm(312) Wire seals(UNIT : mm) 电线密封栓 (毫米) Dummy plugs(UNIT : mm) 盲塞(毫米) Ref; 8.0mm Wire Seals detail 8.0mm电线密封栓参照页 Ref; 8.0mm Dummy plug detail 8.0mm盲塞参照页 SS(7165-0683) B-24 S (7165-0400) B-24 (7165-0180)  M (7165-0392) B-24 L(7165-0393) B-24 B-25 ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. The wire seals are common to M and F. 电线密封栓为公端、母端共用。 ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 2way 8.0mm(312) Color 颜 色 Dark Gray 深灰 18.4 30.4 Housing(UNIT : mm) 接插件护套 (毫米) M (6181-0613) Ref: Terminal part No. 端子参照页 J-09 Ref: wire seal No. 电线密封栓参照页 B-24 Ref: Dummy plug No. 盲塞参照页 B-25 Material 材 质 PBT 50 F(6189-0915) 25.6 33.6 38.7 Color 颜 色 Note 备 注 Dark Gray 深灰 J-11 Clamp:TYPE1 Body fastening clamp(mm) SL SEALED SERIES COMMON USE PARTS 车体固定用卡钉(毫米) 1.5mm standard type, 2.3mm standard type and 8.0mm standard type connectors, the clamp can be installed. ※ The detail dimensions for the mounting portion are specifi ed in drawing 根据需要,可以在1.5mm 标准·2.3mm 标准·8.0mm 标准的接插件上,安装 用于固定在车体上的卡钉。 ※安装部位的详细尺寸另行图纸规定。 Type 1 J- 11 Type 2 材 质 Color 颜 色 hole size 孔 径 Plate thickness range for clamp 卡钉适合板厚 PBT 14.3 Material Brown 棕 材 质 Color 7.2×10.2 t=0.7〜2.0 (6810-4982) 颜 色 15.6 Plate thickness range for clamp 卡钉适合板厚 PA66 Natural 自然色 t=2.0 16.1 25 SL SEALED SERIES (6810-1584) Material DL SERIES Features The DL connector series has a mechanism that detects when terminals are not inserted completely. This series consists of 0.64mm, 1.0mm and 2.3mm types classified according to the terminal size, supporting use in a variety of control circuits and low power circuits. ◦The connector mechanism only allows the retainer to be set when the terminal is completely inserted. ◦ These connectors can be directly secured to a bracket on the car body. ◦RoHS/ELV Compliant 特 点 DL 系列接插件具有检验端子插入不足的构造。 按照端子尺寸划分为0.64mm·1.0mm·2.3mm 类型,可以应用于各种控制回路与低功率回路。 ◦具有当端子在半插入狀態時,鎖片無法安裝到 位的檢驗功能︒ ◦接插件可以直接固定在车体的支架上。 ◦可对应欧盟 RoHS 和 ELV 指令 DL SERIES for STANDARD 0.64mm (025) Structure/构造 After setting retainer 安装锁片后 Housing M Terminal M Connector M Connector F After setting retainer K- 02 安装锁片后 Terminal F Housing F 0.64mm (025) Terminal(UNIT : mm) 端子(毫米) Ref; 0.64mm Terminal detail 0.64mm端子参照页 S M(8100-4028) C-02 F (8100-4029)C-02 M M(8100-4027) C-02 F (8100-4030)C-02 0.64mm (025) Housing(UNIT : mm) 接插件护套(毫米) Ref: Terminal part No. 端子参照页 C-02 Material 材 质 PBT 2way Color 颜 色 Color Natural 自然色 颜 色 Note 备 注 Natural 自然色 With body fastening clamp. 带防转卡钉 10.9 14.3 35.7 M (6098-4569) 35.7 11.8 Plate thickness range for clamp; t=0.6〜2.0mm Hole=7.2mm×10.2mm 12.6 M (6098-4567) F(6098-4565) 9.8 9 20.4 Color 颜 色 Natural 自然色 K- 03 DL SERIES DL SERIES for STANDARD 1.0mm(040) This connector has a terminal pitch of 2.5 mm. 端子间间距2.5mm的接插件 Structure/构造 Housing M Terminal M Retainer Retainer sliding direction 通过压入锁片能够检知端子是否 插入到位 K- 04 Connector M Connector F Terminal F Housing F Retainer Retainer sliding direction 通过压入锁片能够检知端子是否 插入到位 1.0mm (040) Terminal(UNIT : mm) 端子(毫米) ※For terminal selection, please contact our sales staff. Note)M size terminal can be used connector with insertion cavity specified. For details please contact our sales staff. ※ Surface treatment of gold-plated is available to meet your needs. Thick size is for the time being now. ※选定端子时,请一定向敝公司销售负责人问讯。 注)M 尺寸端子的可用接插件有限制。   请一定向敝公司销售负责人问讯。 ※ 有关镀金式样,根据需要可以定制。   此外、厚度仅供临时参考。 (S) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 (S) Au F(8240-0300) 0.3〜0.5 Brass 黄铜 Tin-plated 镀锡 1 Cable size(mm2) 1.8 22.0 2.55 15.25 适用电线大小 Material 材 质 Surface treatment 表面处理 M (8100-2512) 1.8 2.55 15.25 0.3〜0.5 Heat-resistant copper alloy Gold-plated 镀金 F(8100-1710) Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 0.3〜0.5 Heat-resistant copper alloy Tin-plated 镀锡 (M) Cable size(mm2) 适用电线大小 材 质 Surface treatment 表面处理 Brass 黄铜 Tin-plated 镀锡 Note) 1 M (8100-2513) DL SERIES Material K- 05 0.75, 0.85〜1.25 22.0 F (8100-2514) Note) Cable size(mm2) 1.8 2.55 15.25 适用电线大小 Material 材 质 Surface treatment 表面处理 0.75, 0.85〜1.25 Heat-resistant copper alloy Tin-plated 镀锡 4way 1.0mm (040) Color 颜 色 Natural 自然色 12.8 Housing(UNIT : mm) 32.8 17.6 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 K-04 Material 材 质 PBT Note)M size terminal can be used connector with insertion cavity specifi ed. For details please contact our sales staff. 注)M 尺寸端子的可用接插件有限制。 M (6098-2158) F(6098-2013) 10.3 14.4 18.5 Color 颜 色 Natural 自然色 8way 12way Color F(6098-2289) Natural 自然色 颜 色 Note) 15.8 22.0 16.1 M (6098-2206) 19.4 32.8 18.5 Color 颜 色 F (6098-2208) Natural 自然色 16way F(6098-1624) 13.5 15.8 15.5 18.5 Note) Color 颜 色 K- 06 Natural 自然色 20way F (6098-1626) 13.5 29.4 18.5 Color 颜 色 Natural 自然色 24.4 18.5 Color 颜 色 Natural 自然色 DL SERIES for STANDARD 2.3mm (090) Structure/构造 Housing M Terminal M Retainer sliding direction Retainer 通过压入锁片能够检知端子是否 插入到位 Connector M Connector F DL SERIES Terminal F Housing F Retainer sliding direction 通过压入锁片能够检知端子是否 插入到位 Retainer 2.3mm(090) 2.3mm (090) Terminal(UNIT : mm) 端子(毫米) Ref; 2.3mm Terminal detail 2.3mm端子参照页 S M(8230-4492)  A-10 F (8240-4882) A-10 M M(8230-4502)  A-10 F (8240-4892) A-10 L M(8230-4512) A-10 F (8240-4942) A-10 Regarding "Gold-plated Terminal", please refer "A-10". 镀金端子记载在A-10上 K- 07 Housing(UNIT : mm) 接插件护套(毫米) Ref: Terminal part No. 端子参照页 A-10 Material 材 质 Low water absorption Nylon 2way 4way Color Color Natural 自然色 颜 色 Natural 自然色 颜 色 20.4 14.6 37.5 38 15.2 M (6249-1248) 14.6 F (6249-1251) 14.1 M (6249-1249) 17 22 22 12.2 Color 10.7 Natural 自然色 颜 色 K- 08 F (6249-1252) Color Natural 自然色 颜 色 6way 10way Color F(6248-5311) Natural 自然色 颜 色 22.1 18.6 19.5 39.5 23.1 M (6249-1250) 22 22.8 Color Natural 自然色 颜 色 F(6249-1253) 15.5 13.3 22 18.8 Color Natural 自然色 颜 色 14way 16way Color Color Natural 自然色 颜 色 Natural 自然色 颜 色 19.5 19.5 39.1 M (6249-1265) F (6248-5309) 13.3 22 Color 颜 色 Natural 自然色 39.5 43.1 M (6249-1266) F (6248-5310) 13.3 15.5 34.8 39.5 15.5 34.8 22 Color 颜 色 Natural 自然色 DL SEALED SERIES Features The DL sealed connector series has a mechanism that detects when terminals are not inserted completely. The series consists of 2.3mm type covering an extensive array of applications from signal circuits to power circuits. ◦ T he connector mechanism only allows the retainer to be set when the terminal is completely inserted. ◦These connectors can be directly secured to a bracket on the car body. ◦ In addition, an extra clip can be attached to the connector to secure it to the car body. ◦RoHS/ELV Compliant 特 点 DL 防水系列接插件具有检验端子插入不足的功 能。 尺寸为2.3mm 的端子可广泛应用于信号回路或低 功率回路等。 ◦具有当端子在半插入状态时,锁片无法安装到 正确位置的检知功能。 ◦接插件可以直接固定在车体的支架上。 ◦另外在接插件上可安装为固定到车体的卡钉(卡 子)。 ◦可对应欧盟 RoHS 和 ELV 指令 DL SEALED SERIES for STANDARD 2.3mm(090) Structure/构造 Detecting structure for incomplete terminal insertion Retainer 检知端子插入不到位的构造 Terminal M Wire seal Retainer Housing M Housing M Terminal M Detection for incomplete terminal insertion Wire seal L- 02 检知端子插入不到位的状态 Connector M Connector F Wire seal Connector seal Wire seal Detecting structure for incomplete terminal insertion 检知端子插入不到位的构造 Retainer Terminal F Housing F Connector seal Retainer Housing F Body fastening clamp and Body fastening bracket mount 车体固定用卡钉以及 车体固定用支架安装部位 Detection for incomplete terminal insertion 检知端子插入不到位的状态 2.3mm (090) Terminal(UNIT : mm) 端子(毫米) ※ For terminal selection, please contact our sales staff. ※选定端子时,请一定向敝公司销售负责人问讯。 (S) (S)Au Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 Cable size(mm2) 0.3〜0.5 适用电线大小 2 Brass 黄铜 Tin-plated 镀锡 Material 材 质 26.4 2.3 M (8230-4472) F (8100-1427) 2.4 表面处理 2 Brass 黄铜 Gold-plated 镀金 26.4 2.3 M (1500-0159) F(8100-1458) 2.4 18 3 Cable size(mm2) 0.3〜0.5 适用电线大小 Material 3 18 Surface treatment 表面处理 (M) Cable size(mm2) Material Heat-resistant copper alloy Gold-plated 镀金 材 质 Surface treatment 表面处理 (M)Au Cable size(mm2) 适用电线大小 Material 材 质 表面处理 Cable size(mm2) 0.75〜0.85 适用电线大小 2 Brass 黄铜 Tin-plated 镀锡 Material 材 质 26.4 2.3 M (8230-4562) F(8100-1429) 2.4 Surface treatment 表面处理 0.75〜0.85 L- 03 2 Brass 黄铜 Gold-plated 镀金 26.4 2.3 M (1500-0169) F(8100-1460) 2.4 18 3 Cable size(mm2) 0.75〜0.85 适用电线大小 Material 3 18 Surface treatment 表面处理 (L) 0.75〜0.85 适用电线大小 Heat-resistant copper alloy Tin-plated 镀锡 材 质 Cable size(mm2) Material Heat-resistant copper alloy Gold-plated 镀金 材 质 Surface treatment 表面处理 (L)Au Cable size(mm ) 2 适用电线大小 Material 材 质 Surface treatment F(8100-1459) 1.25〜2.0 2 Brass 黄铜 Tin-plated 镀锡 2 2.4 26.4 2.3 3 18 Cable size(mm2) 适用电线大小 2.3 Material 材 质 Surface treatment 表面处理 M(8230-4552) F (8100-1428) 2.4 18 Cable size(mm2) 适用电线大小 Material 材 质 Surface treatment 表面处理 1.25〜2.0 Heat-resistant copper alloy Tin-plated 镀锡 1.25〜2.0 26.4 Heat-resistant copper alloy Gold-plated 镀金 DL SEALED SERIES Surface treatment 3 0.3〜0.5 适用电线大小 Heat-resistant copper alloy Tin-plated 镀锡 材 质 表面处理 Surface treatment 0.3〜0.5 2.3mm(090) (SS) Wire seals(UNIT : mm) (7165-0210) φ5 电线密封栓 (毫米) Cable overall diameter(mm) Over than 1.1 mm below 1.5 mm 带绝缘层外径 ◦ The wire seals are common to M and F. Material ◦电线密封栓为公端、母端共用。 Color 材 质 颜 色 (S) (7165-0118) L- 04 超过1.1mm在1.5mm以下 NBR 6.1 Red 红 (M) (7165-0119) φ5 Cable overall diameter(mm) Over than 1.5 mm below 2.0 mm 带绝缘层外径 Material 材 质 Color 颜 色 超过1.5mm在2.0mm以下 带绝缘层外径 Material NBR Blue 蓝 2.3mm(090) Dummy plugs(UNIT : mm) 盲塞(毫米) Ref; 2.3mm Dummy plug detail 2.3mm盲塞参照页 (7161-9787)  B-15 (7165-0193) J-07 ◦ Dummy plugs are common to M and F. ◦ Dummy plugs are used to blind unused  terminal holes. ◦盲塞为公端、母端共用。 ◦盲塞用于堵塞不使用的端子孔。 φ5 Cable overall diameter(mm) Over than 2.0 mm below 2.9 mm 6.1 材 质 Color 颜 色 超过2.0mm在2.9mm以下 NBR Brown 棕 6.1 1way 2.3mm(090) Color 颜 色 Dark Gray 深灰 16.3 14 Housing(UNIT : mm) 接插件护套 (毫米) M (6195-0240) Ref: Terminal part No. 端子参照页 L-02 Ref: wire seal No. 电线密封栓参照页 L-04 Ref: Dummy plug No. 盲塞参照页 B-11 J-07 Material 材 质 PBT or Low water absorption Nylon 颜 色 F(6195-0066) 21.2 16.6 Color 28 Note 3way Color Dark Gray 深灰 颜 色 Dark Gray 深灰 L- 05 19 M (6195-0006) F(6195-0003) M (6195-0012) 21.3 28 Color 27.3 Dark Gray 深灰 L-07 Bracket Clamp : TYPE2 颜 色 Note 备 注 4way F (6195-0009) 28 Color Dark Gray 深灰 L-07 Bracket Clamp : TYPE2 颜 色 Note 备 注 6way Color Dark Gray 深灰 颜 色 Dark Gray 深灰 20.1 20.1 20.8 M (6195-0018) 25.7 38 F(6195-0015) M (6195-0024) 38 F (6195-0021) 24.3 24.3 23.1 38 18.9 18.9 颜 色 25 38 28 Color 颜 色 Note 备 注 Dark Gray 深灰 L-07 Bracket Clamp : TYPE2 28 28 Color 颜 色 Note 备 注 Dark Gray 深灰 L-07 Bracket Clamp : TYPE2 DL SEALED SERIES 14.7 14.7 Color Dark Gray 深灰 L-07 Bracket Clamp : TYPE2 颜 色 备 注 2way Color 38 8way Color 颜 色 10way Color Dark Gray 深灰 Light Gray 浅灰 颜 色 20.1 25.7 31.7 30.5 38 M (6195-0054) F (6195-0051) 24.3 F(6195-0164) 31 Color 34 28 Dark Gray 深灰 L-07 Bracket Clamp : TYPE2 颜 色 Note 备 注 12way Color L- 06 M (6195-0167) 40 颜 色 33.2 Color Light Gray 浅灰 L-07 Bracket Clamp : TYPE2 颜 色 Note 备 注 16way Color Dark Gray 深灰 Dark Gray 深灰 L-07 Bracket Clamp : TYPE1 颜 色 Note 备 注 25.7 31.7 M(6195-0152) 33.8 40 F (6195-0149) 31 34.4 28 33.1 M (6188-0495) 45.3 F(6189-0715) 29.3 28 Color 颜 色 Note 备 注 Dark Gray 深灰 L-07 Bracket Clamp : TYPE2 30.6 25.5 Color 颜 色 Dark Gray 深灰 DL SEALED SERIES COMMON USE PARTS Body fastening clamp(mm) 2.3mm standard type connectors, the clamp can be installed. ※ The detail dimensions for the mounting portion are specified in drawing 根据需求可以在2.3mm 标准的接插件上,安装用于固定在车体上的卡钉。 ※安装部位的详细尺寸另行图纸规定。 L- 07 DL SEALED SERIES Type 1 Type 2 (6810-2653) Material 材 质 PA6T Color Natural 自然色 hole size φ7.0 颜 色 孔 径 Plate thickness range for clamp 卡钉适合板厚 t=0.6〜1.6 (6810-1584) Material 材 质 14.3 Color 颜 色 hole size 18 孔 径 Plate thickness range for clamp 卡钉适合板厚 PBT 14.3 Brown 棕 7.2×10.2 t=0.7〜2.0 15.6 HFCⅢ SERIES Features HFCⅢ (High Frequency Connector) series are connectors that connect on-board multimedia devices, such as GPS, TV, VICS and etc., and coaxial wires. These are also suitable for mobile telephone and sensor circuit. ◦ It reduces reflection/transmission loss and restraints noise radiation. It achieved smaller size with higher performance. ◦H  ybrid types for high frequency coaxial wire and automobile wire (AV) are estabished. (It supports diversity receiving system). ◦Retainer for secondary lock is preloaded and the strucrure allows the high frequency coaxial wire and AV wire to be s et by on e op e r at i on. T h e r efo r e improvement of assembling operation can be planned. ◦RoHS/ELV Compliant 特 点 HFC Ⅲ系列(高频接插件)使用于 GPS·TV·VICS 等车载多媒体模块相同的同轴线连接用接插件, 也适用于车载电话、传感器回路上。 ◦制止传送损失、反射、杂讯放射、实现了小型 高性能化。 ◦设定了高频同轴线和汽车用电线 (AV)的混合型。 (可以应用于多样性收信方式。) ◦通过预先安装双重锁定锁片、高频同轴线与 AV 线都能够通过简单的操作进行安装,可提高效 率。 ◦可对应欧盟 RoHS 和 ELV 指令 HFCⅢ SERIES for STANDARD Structure/构造 Inner conductor terminal 内导体端子 Interlock Female Housing Dielectric 母端接插件护套 感应体 Outer conductor terminal 外导体端子 Female Retainer 母端锁片 Male Retainer 公端锁片 Male Housing M-02 公端接插件护套 Outer Conductor terminal Standard bracket fixing part 外导体端子 标准支架固定部 Earthing terminal 接地线端子 Dielectric 感应体 Inner conductor terminal 内导体端子 Secondary lock part (End of stabilizer of outer conductor terminal) Primary lock part (End of box part of outer conductor terminal) 1次锁定部(外导体端子的箱部后端) 2次锁定部(外导体端子的稳定器后端) Secondary lock structure of HFCⅢ HFCⅢ的双重锁定结构 Basic specification/基本规格 Inner conductor 1 way coaxial wire 2 way coaxial wire + 1way AV wire 3 way coaxial wire 4 way coaxial wire + 2way AV wire Contact resistance 接触电阻 M Terminal 2 way coaxial wire + 2way AV wire Type Coaxial wire AV wire Insulation resistance 材质 Inner conductor 内导体 F Terminal Outer conductor 外导体 Min. 100MΩ 绝缘电阻 黄铜(镀锡) Material Max. 8mΩ (Initial/初期) AV线 Brass (Sn plating) Outer conductor 外导体 Max. 20mΩ(Initial/初期) 同轴线 内导体 Heat resistant cooper-alloy (Au plating) 耐热铜合金(镀金) Brass (Sn plating) 黄铜(镀锡) (Note) AV wire = MAX. AVSS 0.5mm2 (Terminal is TS 0.64 type: Ref. A-02). 注)AV线=最大AVSS 0.5mm(端子为TS0.64:参照A-02) 2 Working temperature -40℃〜+105℃ 使用温度 〜180MHz 75Ω系 〜770MHz VSWR 50Ω系 〜3GHz Wire to Wire PCB to Wire Wire to Wire PCB to Wire Max. 1.2 Max. 1.4 Wire to Wire Max. 1.4 PCB to Wire Max. 1.3 (mm)/内导体端子 (毫米) Inner conductor terminal (M) (F) S (8230-5015)M(8230-5016)L (8230-5017) S (8240-0276)M (8240-0277)L(8240-0278) M-03 HFC Ⅲ SERIES Outer conductor terminal (mm)/外导体端子 (毫米) (M) (F) S M(8230-5482)L (8230-5481) (8230-5484) 转 播 用:S (8240-0382)M (8240-0383)F (8240-0619) 无线电用:S (8240-0387)M (8240-0388) (Note) The terminal for radio can connecta condenser inside. On this occasion, a common crimping terminal is necessary. 注) 无线电用端子内部可以连接电容器。 此时需要共同的压接端子(8110-4493)。 Applicable coaxial wire/适用同轴线 Applicable coaxial wire (Note 1) 1.5C-2V 1.5C-2W 1.5D-2V 1.5D-2W 2.5D Inner conductor terminal 内导体端子 S S M M L Outer conductor terminal 外导体端子 S M S S F 适用同轴线 注1) (Note 1) For some coaxial wire and wire makers, it might be inapplicable. Please contact our sales representative for more details. 注1) 由于各电线商家的同轴线不同, 是否适用请向敝公司的销售负责人问询 (Note 2) When crimping the forming coaxial wire, need the sleeve. 注2) 泡沫聚乙烯绝缘同轴线压接时需要使用套管。 Housing(UNIT : mm) 接插件护套 (毫米) Ref: Terminal part No. 端子参照页 coaxial wire 同轴线 M-03 AV wire AV线 A-02 1way coaxial wire Color Rib R1 颜 色 1way coaxial wire Color Blue 蓝 颜 色 M-04 Rib L1 Gray 灰 13 13 27.7 27.7 13.2 M (6098-7143) 13.2 F (6098-6321) M (6098-6835) 12.8 12.8 8 18.15 Color 8 Blue 蓝 颜 色 1way coaxial wire Color 18.15 Color Rib R2 1way coaxial wire Color Rib L2 Natural 自然色 颜 色 13 13 27.7 27.7 13.2 13.2 M (6098-7544) F (6098-7445) M (6098-7546) 12.8 8 Gray 灰 颜 色 Black 黒 颜 色 F(6098-6323) F(6098-7446) 12.8 18.15 Color 颜 色 Black 黒 8 18.15 Color 颜 色 Natural 自然色 2 way coaxial wire + 1 way AV wire Color Rib R Color Gray 灰 颜 色 颜 色 Gray 灰 17.9 17.9 32.95 32.95 18.3 M (6098-6331) 18.3 M (6098-6373) F (6098-6336) 10.9 13 21 Color Gray 灰 颜 色 2 way coaxial wire + 1 way AV wire Color Rib L Color Natural 自然色 颜 色 颜 色 Natural 自然色 M-05 17.9 17.9 18.3 M (6098-6328) M (6098-6370) F (6098-6333) 10.9 13 21 Color Natural 自然色 颜 色 2 way coaxial wire + 2 way AV wire Color Rib R Color Gray 灰 颜 色 2 way coaxial wire + 2 way AV wire 颜 色 Natural 自然色 21.4 21.4 32.95 32.95 13 13 M (6098-7151) Rib L F (6098-7153) M (6098-7145) F(6098-7148) 16.2 16.2 12.8 18.35 Color 颜 色 Gray 灰 12.8 18.35 Color 颜 色 Natural 自然色 HFC Ⅲ SERIES 32.95 32.95 18.3 3 way coaxial wire Color Color Blue 蓝 颜 色 颜 色 Blue 蓝 20.8 20.8 27.7 18.2 27.7 18.2 M (6098-6340) M (6098-6369) F (6098-6343) 13.6 18.15 12.8 Color Blue 蓝 颜 色 3 way coaxial wire Color 4 way coaxial wire + 2 way AV wire Color Blue 蓝 颜 色 颜 色 M-06 Natural 自然色 13 15.7 27.7 24.2 M (6098-6838) F (6098-6841) M (6098-6844) 12.8 19 32.95 37.6 F(6098-6702) 12.3 18.35 32.4 Color 颜 色 Blue 蓝 18.35 Color 颜 色 Natural 自然色 HFCⅢ SERIES for PCB Housing(UNIT : mm) 接插件护套(毫米) Through Hall Type(Rib R) M-07 1 way coaxial wire M (6098-6157) 13.4 25.57 Connector F part No. 6098-6321(M-04) Color Blue 蓝 母端接插件产品号码 颜 色 ●Recommended demension of  Circuit board  电路板推荐尺寸 19.45 Through Hall Type(Rib L) 1 way coaxial wire M (6098-6159) ●Detailed dimension  详细尺寸 13.4 Connector F part No. 6098-6323(M-04) Color Gray 灰 母端接插件产品号码 颜 色 25.57 ●Recommended demension of  Circuit board  电路板推荐尺寸 19.45 4 way coaxial wire + 2 way AV wire Through Hall Type M (6098-6700) ●Detailed dimension  详细尺寸 14.7 Connector F part No. 6098-6702(M-06) Color Natural 自然色 母端接插件产品号码 颜 色 HFC Ⅲ SERIES ●Detailed dimension  详细尺寸 43.4 19.85 ●Recommended demension of  Circuit board  电路板推荐尺寸 SMT Type(Rib R1) 1 way coaxial wire M (6098-7132) ●Detailed dimension  详细尺寸 13 Connector F part No. 6098-6321(M-04) Color Blue 蓝 母端接插件产品号码 颜 色 24.6 ●Recommended demension of  Circuit board  电路板推荐尺寸 13.1 SMT Type(Rib R2) 1 way coaxial wire M (6098-7449) ●Detailed dimension  详细尺寸 13 Connector F part No. 母端接插件产品号码 Color 颜 色 M-08 24.6 6098-7445(M-04) ●Recommended demension of  Circuit board  电路板推荐尺寸 13.1 Black 黒 SMT Type(Rib L1) 1 way coaxial wire M (6098-7134) ●Detailed dimension  详细尺寸 13 Connector F part No. 母端接插件产品号码 Color 颜 色 24.6 6098-6323(M-04) ●Recommended demension of  Circuit board  电路板推荐尺寸 13.1 Gray 灰 SMT Type(Rib L2) 1 way coaxial wire M (6098-7450) ●Detailed dimension  详细尺寸 13 Connector F part No. 母端接插件产品号码 Color 颜 色 24.6 6098-7446(M-04) Natural 自然色 13.1 ●Recommended demension of  Circuit board  电路板推荐尺寸 HFCⅢ SERIES for RADIO 2 way coaxial wire + 1 way AV wire Color Natural 自然色 颜 色 M-09 21.2 HFC Ⅲ SERIES 40.05 13.45 M (6098-6861) F (6098-6037) 21.25 27.1 12.45 Color Natural 自然色 颜 色 2 way coaxial wire + 1 way AV wire Through Hall Type M (6098-5761) ●Detailed dimension  详细尺寸 28.9 Connector F part No. 6098-6037(M-09) Color Natural 自然色 母端接插件产品号码 颜 色 13.45 36.6 ●Recommended demension of  Circuit board  电路板推荐尺寸 INDEX INDEX Part No. Page Part No. Page Part No. Page Part No. Page 1500-0159 L-03 6098-2680 I-06 6098-4018 C-23 6098-4975 C-15 1500-0166 C-12 6098-2764 C-08 6098-4050 C-11 6098-4977 C-15 1500-0169 L-03 6098-2779 C-07 6098-4069 C-10 6098-4978 C-03 5010-8627 E-08 6098-2780 C-07 6098-4071 C-10 6098-4979 C-04 5011-1590 E-08 6098-2781 C-07 6098-4073 C-10 6098-4982 C-04 5011-6687 E-08 6098-2782 C-07 6098-4075 C-18 6098-5000 C-04 5011-6818 E-12 6098-2784 C-08 6098-4076 C-18 6098-5049 C-10 5011-7740 E-12 6098-2785 C-08 6098-4333 C-04 6098-5070 C-03 5011-7860 E-12 6098-2786 C-19 6098-4339 C-04 6098-5071 C-03 6098-0149 A-16 6098-2788 C-08 6098-4367 C-18 6098-5119 C-13 6098-0151 A-16 6098-2789 C-08 6098-4565 K-03 6098-5120 C-13 6098-0154 A-17 6098-3239 C-22 6098-4567 K-03 6098-5180 C-16 6098-0156 A-17 6098-3369 C-08 6098-4569 K-03 6098-5217 C-20 6098-0323 A-16 6098-3370 C-19 6098-4588 C-04 6098-5218 C-20 6098-0325 A-16 6098-3449 I-04 6098-4589 C-04 6098-5267 F-03 6098-0441 A-19 6098-3450 I-10 6098-4590 C-05 6098-5269 F-03 6098-0469 A-16 6098-3452 I-09 6098-4591 C-16 6098-5271 F-03 6098-0471 A-16 6098-3453 I-04 6098-4594 C-04 6098-5273 F-04 6098-0518 A-16 6098-3456 I-03 6098-4595 C-04 6098-5275 F-04 6098-0822 A-15 6098-3458 I-10 6098-4596 C-05 6098-5277 F-04 6098-0824 A-15 6098-3563 C-11 6098-4597 C-16 6098-5279 F-05 6098-1104 A-19 6098-3565 C-20 6098-4640 C-04 6098-5281 F-05 6098-1278 A-19 6098-3567 C-21 6098-4660 C-20 6098-5283 F-05 6098-1373 C-11 6098-3569 C-21 6098-4661 C-11 6098-5285 F-05 6098-1377 C-11 6098-3571 C-18 6098-4662 C-11 6098-5287 F-06 6098-1378 C-11 6098-3572 C-22 6098-4663 C-13 6098-5289 F-06 6098-1380 C-11 6098-3600 C-18 6098-4664 C-11 6098-5291 F-06 6098-1489 A-16 6098-3601 C-18 6098-4666 C-18 6098-5293 F-06 6098-1624 K-06 6098-3616 C-23 6098-4667 C-13 6098-5295 F-06 6098-1626 K-06 6098-3802 A-04 6098-4669 C-11 6098-5297 F-06 6098-1627 I-07 6098-3810 A-04 6098-4670 C-11 6098-5310 F-03 6098-1714 I-06 6098-3818 A-22 6098-4675 C-04 6098-5312 F-04 6098-1716 A-16 6098-3826 A-22 6098-4707 C-17 6098-5585 F-06 6098-1744 I-07 6098-3869 A-04 6098-4725 C-17 6098-5594 A-21 6098-1746 I-07 6098-3877 A-04 6098-4726 C-17 6098-5604 A-21 6098-1747 I-06 6098-3885 A-05 6098-4740 A-06 6098-5613 A-21 6098-1774 I-06 6098-3893 A-21 6098-4756 A-05 6098-5622 A-21 6098-1851 A-16 6098-3901 A-22 6098-4831 A-06 6098-5631 A-21 6098-2013 K-05 6098-3909 A-04 6098-4876 I-04 6098-5641 A-21 6098-2101 I-06 6098-3917 A-04 6098-4877 I-04 6098-5650 A-20 6098-2137 A-19 6098-3925 A-05 6098-4901 C-10 6098-5659 A-20 6098-2158 K-05 6098-3933 A-21 6098-4902 C-10 6098-5668 A-09 6098-2206 K-06 6098-3941 A-22 6098-4908 C-16 6098-5677 A-09 6098-2208 K-06 6098-4008 A-05 6098-4943 C-04 6098-5686 A-09 6098-2211 A-16 6098-4010 A-05 6098-4944 C-03 6098-5695 A-09 6098-2289 K-06 6098-4013 A-05 6098-4971 C-13 6098-5704 A-09 6098-2329 G-11 6098-4015 A-06 6098-4973 C-14 6098-5713 A-09 6098-2679 I-06 6098-4017 C-19 6098-4974 C-14 6098-5761 M-09 Part No. Page Part No. Page Part No. Page Part No. Page 6098-5833 C-03 6098-6793 A-24 6181-0439 J-08 6185-5181 G-06 6098-5888 C-07 6098-6796 A-25 6181-0440 J-08 6188-0047 B-15 6098-5903 A-22 6098-6798 A-25 6181-0511 G-09 6188-0049 B-25 6098-5988 F-08 6098-6803 A-25 6181-0512 G-10 6188-0066 B-17 6098-5989 F-08 6098-6805 A-25 6181-0513 G-09 6188-0067 B-18 6098-6037 M-09 6098-6810 A-26 6181-0514 G-09 6188-0083 B-21 6098-6050 A-09 6098-6835 M-04 6181-0515 G-08 6188-0091 B-29 6098-6053 A-09 6098-6838 M-06 6181-0516 G-09 6188-0096 B-25 6098-6055 A-20 6098-6841 M-06 6181-0522 G-10 6188-0099 B-16 6098-6083 A-20 6098-6844 M-06 6181-0532 G-09 6188-0101 B-29 6098-6090 A-20 6098-6848 A-25 6181-0536 G-09 6188-0108 B-15 6098-6097 A-20 6098-6861 M-09 6181-0613 J-10 6188-0129 B-22 6098-6104 A-20 6098-6869 A-26 6181-0629 J-05 6188-0141 B-17 6098-6111 A-20 6098-7060 F-05 6181-0664 G-09 6188-0173 B-18 6098-6157 M-07 6098-7061 F-05 6181-0665 G-09 6188-0175 B-18 6098-6159 M-07 6098-7063 F-03 6181-0666 G-10 6188-0187 B-29 6098-6161 C-16 6098-7066 F-04 6181-0667 G-10 6188-0209 B-18 6098-6162 C-16 6098-7067 F-04 6181-0668 G-09 6188-0217 B-17 6098-6321 M-04 6098-7099 F-05 6181-0669 G-09 6188-0221 B-29 6098-6323 M-04 6098-7100 F-05 6181-0670 G-08 6188-0229 B-16 6098-6328 M-05 6098-7102 A-26 6181-0671 G-09 6188-0259 B-21 6098-6331 M-05 6098-7132 M-08 6181-0803 E-19 6188-0266 B-15 6098-6333 M-05 6098-7134 M-08 6181-6464 E-21 6188-0282 B-17 6098-6336 M-05 6098-7143 M-04 6181-6465 E-21 6188-0327 B-18 6098-6340 M-06 6098-7145 M-05 6181-6481 D-04 6188-0415 B-29 6098-6343 M-06 6098-7148 M-05 6181-6492 J-04 6188-0470 B-16 6098-6369 M-06 6098-7151 M-05 6181-6509 J-04 6188-0472 B-18 6098-6370 M-05 6098-7153 M-05 6181-6614 J-04 6188-0495 L-06 6098-6373 M-05 6098-7229 A-24 6181-6658 H-03 6188-0517 B-17 6098-6451 F-04 6098-7231 A-05 6181-6783 E-16 6188-0551 G-05 6098-6452 F-04 6098-7241 A-04 6181-6784 E-16 6188-0552 G-05 6098-6455 F-04 6098-7253 F-08 6181-6785 E-21 6188-0553 G-05 6098-6456 F-04 6098-7254 F-08 6181-6850 E-16 6188-0554 G-05 6098-6457 F-05 6098-7261 F-08 6181-6851 E-15 6188-0555 G-06 6098-6478 C-16 6098-7336 A-05 6181-6921 E-22 6188-0556 G-05 6098-6522 F-04 6098-7445 M-04 6185-0862 G-05 6188-0557 G-06 6098-6523 F-04 6098-7446 M-04 6185-0865 G-05 6188-0558 G-06 6098-6524 F-05 6098-7449 M-08 6185-0866 G-05 6188-0589 E-04 6098-6559 C-17 6098-7450 M-08 6185-0867 G-05 6188-0590 E-04 6098-6562 C-16 6098-7544 M-04 6185-0868 G-06 6188-0624 B-16 6098-6653 A-04 6098-7546 M-04 6185-0869 G-05 6188-0657 E-04 6098-6662 A-04 6098-8478 I-06 6185-1101 G-05 6188-0658 E-05 6098-6682 A-05 6098-8480 I-09 6185-1169 G-06 6188-0660 E-07 6098-6688 A-05 6098-8482 I-04 6185-1171 G-06 6188-0663 G-05 6098-6694 A-05 6181-0381 E-22 6185-4596 E-21 6188-0696 B-06 6098-6700 M-07 6181-0436 J-07 6185-5175 G-06 6188-0697 E-09 6098-6702 M-06 6181-0437 J-08 6185-5177 G-06 6188-0698 E-09 6098-6790 A-24 6181-0438 J-08 6185-5179 G-07 6188-0706 B-06 INDEX INDEX INDEX Part No. Page Part No. Page Part No. Page Part No. Page 6188-0779 B-06 6189-0593 E-19 6189-1096 G-12 6189-7156 B-30 6188-4739 E-05 6189-0596 E-19 6189-1097 G-12 6189-7167 B-07 6188-4775 D-03 6189-0611 B-16 6189-1104 G-09 6189-7188 H-03 6188-4776 D-04 6189-0617 E-19 6189-1107 G-08 6189-7189 H-03 6188-4787 E-08 6189-0629 B-17 6189-1108 G-10 6189-7190 H-03 6188-4789 E-08 6189-0639 J-07 6189-1109 G-10 6189-7214 H-03 6188-4797 B-05 6189-0640 J-08 6189-1115 J-04 6189-7256 B-26 6188-4908 D-04 6189-0643 J-08 6189-1128 B-06 6189-7262 J-05 6188-4914 B-06 6189-0648 J-08 6189-1129 B-05 6189-7263 E-12 6188-4920 B-05 6189-0682 B-16 6189-1132 B-05 6189-7264 E-12 6188-5103 B-27 6189-0685 B-18 6189-1133 B-06 6189-7393 G-13 6188-5295 B-26 6189-0694 B-17 6189-1134 B-06 6189-7398 B-17 6188-5516 B-10 6189-0715 L-06 6189-1135 B-07 6189-7401 B-05 6188-5539 G-06 6189-0772 G-11 6189-1136 B-27 6189-7408 E-15 6188-5540 G-06 6189-0773 G-12 6189-1142 B-06 6189-7409 E-16 6188-5542 G-07 6189-0774 G-12 6189-1144 J-05 6189-7410 E-16 6188-5544 G-06 6189-0775 G-12 6189-1147 J-05 6189-7411 E-21 6189-0100 B-15 6189-0776 G-12 6189-1149 J-05 6189-7423 E-16 6189-0101 B-25 6189-0777 G-12 6189-1150 J-05 6189-7426 B-27 6189-0126 B-17 6189-0778 G-12 6189-1160 B-27 6189-7433 B-11 6189-0127 B-18 6189-0855 E-05 6189-1161 B-05 6189-7434 B-11 6189-0143 B-29 6189-0856 B-25 6189-1231 B-05 6189-7435 B-11 6189-0144 B-29 6189-0887 E-05 6189-1240 B-06 6189-7436 B-11 6189-0145 B-21 6189-0890 E-04 6189-6863 E-21 6189-7449 B-10 6189-0165 B-22 6189-0891 E-04 6189-6894 B-27 6189-7469 G-12 6189-0166 B-29 6189-0915 J-10 6189-6906 D-04 6189-7470 G-12 6189-0172 B-25 6189-0928 G-09 6189-6909 D-04 6189-7471 G-12 6189-0179 B-16 6189-0940 E-04 6189-6914 E-08 6189-7494 E-16 6189-0181 B-29 6189-0950 G-09 6189-6934 B-26 6189-7546 B-11 6189-0199 B-15 6189-0951 G-08 6189-6953 B-25 6189-7547 B-11 6189-0249 B-15 6189-0954 G-10 6189-6978 B-27 6189-7567 E-22 6189-0264 B-16 6189-0955 G-10 6189-6979 B-27 6189-7691 B-26 6189-0319 B-18 6189-0968 E-05 6189-6980 B-27 6189-7710 G-12 6189-0323 B-18 6189-1012 E-05 6189-6981 B-27 6189-7711 G-12 6189-0368 B-18 6189-1046 B-05 6189-6987 B-07 6189-7713 G-12 6189-0372 B-17 6189-1048 B-27 6189-7020 B-05 6189-7714 G-12 6189-0376 B-29 6189-1050 E-09 6189-7036 D-03 6189-7716 G-12 6189-0381 B-17 6189-1051 E-09 6189-7037 D-03 6189-7717 G-12 6189-0388 B-16 6189-1073 J-04 6189-7039 D-04 6189-7756 G-09 6189-0413 B-21 6189-1076 J-04 6189-7040 D-04 6189-7757 G-09 6189-0425 B-21 6189-1081 E-05 6189-7052 D-03 6189-7758 G-09 6189-0443 B-17 D-03 6189-7759 G-09 B-18 E-07 E-08 6189-7058 6189-0504 6189-1082 6189-7073 B-05 6189-7760 G-09 6189-0552 E-19 6189-1083 B-06 6189-7077 B-26 6189-7761 G-09 6189-0555 E-22 6189-1092 B-06 6189-7094 B-28 6189-7762 G-09 6189-0566 B-16 6189-1093 G-12 6189-7100 B-06 6189-7763 G-09 6189-0573 B-16 6189-1094 G-12 6189-7110 B-07 6189-7784 J-08 6189-0591 E-19 6189-1095 G-12 6189-7115 J-05 6189-7809 B-28 Part No. Page Part No. Page Part No. Page Part No. Page 6195-0003 L-05 6249-1250 K-08 6918-1653 G-09 7165-0147 E-21 6195-0006 L-05 6249-1251 K-08 6918-1654 G-09 7165-0148 E-21 6195-0009 L-05 6249-1252 K-08 6918-1762 E-05 7165-0172 E-20 6195-0012 L-05 6249-1253 K-08 6918-1773 G-05 6195-0015 L-05 6249-1265 K-08 6918-1774 G-05 7165-0180 B-25 J-10 6195-0018 L-05 6249-1266 K-08 6195-0021 L-05 6520-0549 A-12 6918-1775 G-05 G-06 6195-0024 L-05 6520-0550 A-12 6918-1776 G-06 6195-0051 L-06 6520-1004 A-13 6918-1779 G-06 7165-0193 6195-0054 L-06 6520-1009 A-13 6195-0066 L-05 6520-1466 A-19 6918-1780 G-06 G-07 E-07 E-18 H-03 J-04 J-07 L-04 6195-0149 L-06 6810-1203 C-24 E-18 L-06 6810-1204 C-24 D-03 E-05 7165-0194 6195-0152 6918-1833 7165-0198 E-18 6918-1835 D-03 E-04 7165-0210 L-04 7165-0342 B-14 6195-0164 L-06 6810-1217 C-24 6195-0167 L-06 6810-1462 C-24 6195-0240 L-05 6810-1584 J-11 6918-1979 E-04 7165-0343 B-14 6240-1033 A-13 6810-1584 L-07 6918-2056 E-05 7165-0344 B-14 6240-1077 A-12 6810-2653 L-07 6918-2103 E-09 7165-0346 B-20 6240-1093 A-19 6810-4982 J-11 6918-2104 E-09 7165-0347 B-20 6240-1107 A-12 6910-0119 C-24 B-20 A-12 6910-0120 C-24 D-04 E-05 7165-0348 6240-1120 6918-2128 7165-0349 B-14 6240-1122 A-13 6911-5774 B-11 6918-2131 E-07 7165-0351 B-14 6918-2132 E-07 E-08 7165-0356 B-20 7165-0385 E-18 7165-0392 B-24 J-10 7165-0393 B-24 J-10 7165-0395 B-14 7165-0400 B-24 J-10 7165-0432 D-03 E-04 6240-1158 A-13 6911-5948 B-28 6240-5035 A-13 6914-0050 E-07 6240-5088 A-13 6914-0127 E-11 6918-2665 E-19 6240-5118 A-12 6918-1260 E-19 6918-2804 D-04 6240-5175 A-13 6918-1263 E-22 6918-2806 D-04 6240-5337 I-06 6918-1267 E-22 6918-2810 D-04 6240-5339 I-06 6918-1370 E-19 6918-2913 D-04 6240-5378 C-11 6918-1371 E-19 6918-3166 E-12 E-09 6241-0241 A-23 6918-1469 E-19 6920-0861 6241-0261 A-22 6918-1594 G-11 6920-0884 E-09 E-09 6241-0281 A-23 6918-1594 G-12 6920-0886 6245-0261 A-23 6918-1595 G-12 6920-2376 E-09 7165-0471 G-04 6245-0281 A-22 6918-1596 G-12 6920-2377 E-09 7165-0472 G-04 6245-0301 A-23 6918-1597 G-13 6920-2446 E-09 7165-0473 G-04 6248-5270 A-12 6918-1598 G-09 6950-1054 C-20 7165-0474 G-04 6248-5275 A-13 6918-1599 G-09 6950-1055 C-20 6248-5276 A-13 6918-1600 G-09 6950-1056 C-20 7165-0514 6248-5309 K-08 6918-1601 G-09 7160-9465 B-15 H-02 J-04 J-07 6248-5310 K-08 6918-1602 G-10 7161-9787 B-15 J-04 L-04 7165-0515 H-02 J-04 J-07 7165-0516 H-02 J-04 J-07 7165-0621 D-02 E-03 6248-5311 K-08 6918-1603 G-10 6249-1229 A-12 6918-1604 G-12 6249-1234 A-13 6918-1636 G-11 7165-0118 L-04 6249-1235 A-13 A-12 G-08 G-09 L-04 6249-1243 6918-1651 7165-0119 7165-0130 E-20 6249-1248 K-08 6918-1652 G-09 7165-0131 E-21 6249-1249 K-08 6918-1653 G-08 7165-0145 B-21 INDEX INDEX INDEX Part No. Page Part No. Page Part No. Page Part No. Page 7165-0622 D-02 E-03 8100-0522 A-19 C-21 8100-2971 C-07 8100-3627 A-03 8100-2972 C-07 8100-3628 A-03 7165-0683 B-24 8100-0594 B-13 8100-2980 B-24 8100-3629 A-03 7165-0683 J-10 8100-0606 C-12 8100-3067 D-02 E-03 8100-3708 B-03 8100-3803 G-03 8100-3068 D-02 E-03 8100-3804 G-03 8100-3805 G-03 8100-3806 G-03 8100-4027 C-03 K-02 8100-4028 C-03 K-02 8100-4029 C-03 K-02 8100-4030 C-03 K-02 7165-0797 B-04 8100-0660 E-20 7165-0842 B-14 8100-0661 E-20 7165-1043 B-04 8100-0664 C-12 7165-1075 D-02 E-03 8100-0706 C-21 8100-3082 E-07 8100-0707 A-18 C-21 8100-3083 E-07 8100-3177 D-02 E-03 7165-1131 G-04 7165-1198 B-04 8100-0782 C-12 7165-1199 B-04 8100-0817 B-13 7165-1312 B-04 8100-1007 B-13 7165-1423 B-04 8100-1008 B-13 8100-3257 J-10 7165-1562 E-14 8100-1340 B-13 8100-3258 J-10 7165-1563 E-15 8100-1341 A-11 8100-3259 J-10 7165-1564 E-15 8100-1342 A-11 8100-3260 J-10 8100-4172 G-03 7165-1565 E-15 8100-1344 B-13 8100-3382 I-03 8100-4173 G-03 7165-1566 E-15 8100-1346 A-11 8100-3383 I-03 8100-4307 C-07 7165-1605 B-10 8100-1347 A-11 8100-3384 I-03 8100-4308 C-07 7165-1606 B-09 8100-3385 I-08 7165-1607 B-09 8100-1427 8100-3386 I-09 7165-1608 B-09 H-02 J-06 L-03 8100-3387 I-09 8230-4472 8100-0451 B-23 8100-3388 J-03 8100-0452 B-24 8100-3389 J-03 8100-0457 B-13 H-02 J-06 L-03 E-17 H-02 J-06 L-03 8100-3390 J-03 8230-4492 8100-0458 B-13 8100-3391 I-03 8100-0459 B-13 8100-3392 I-03 8100-0460 B-13 H-02 J-06 L-03 A-11 I-05 K-07 8100-3393 I-03 8230-4502 8100-0461 B-13 8100-1458 L-03 8100-3394 I-08 A-11 I-05 K-07 8100-0462 B-13 8100-1459 L-03 8100-3395 I-09 8100-0463 B-19 E-20 8100-1460 L-03 8100-3396 I-09 8230-4512 8100-1470 C-09 8100-3397 J-03 A-11 I-05 K-07 8100-0464 B-20 E-20 8100-1471 C-10 8100-3398 J-03 8230-4522 A-15 8100-1472 C-10 8100-3399 J-03 8230-4532 A-15 8100-0465 B-20 E-20 8100-1506 C-12 8100-3402 J-03 8230-4542 A-15 8100-1507 C-12 8100-3403 J-03 8100-0466 B-19 B-03 B-20 8100-1553 8100-3455 8100-0467 A-19 C-21 8100-3456 B-03 8230-4552 8100-0468 B-20 E-20 8100-1555 A-15 8100-3504 J-03 E-17 H-02 J-06 L-03 8100-1571 C-09 8100-3507 E-07 8100-0506 B-23 8100-1572 C-10 8100-3508 E-07 8100-0507 B-24 8100-1573 C-10 8100-3617 B-03 8230-4562 8100-0508 B-24 8100-1710 K-05 8100-3622 A-03 E-17 H-02 J-06 L-03 8100-0520 A-18 C-21 8100-2493 A-19 8100-3623 A-03 8230-4742 A-10 8100-2512 K-05 8100-3624 A-03 8230-4878 A-03 8100-0521 A-19 C-21 8100-2513 K-05 8100-3625 A-03 8230-4883 I-03 8100-2514 K-05 8100-3626 A-03 8230-4923 A-08 8100-1428 8100-1429 8100-3178 D-02 E-03 Part No. Page Part No. Page 8230-4924 A-08 8240-0367 F-07 8230-4925 A-08 8240-0368 F-07 8230-5015 M-03 8240-0369 F-07 8230-5016 M-03 8240-0370 F-08 8230-5017 M-03 8240-0371 F-08 8230-5136 A-03 8240-0382 M-03 8230-5168 F-07 8240-0383 M-03 8230-5169 F-07 8240-0385 M-03 8230-5170 F-07 8240-0387 M-03 8230-5171 F-08 8240-0388 M-03 8230-5172 F-08 8240-0408 E-10 8230-5306 E-14 8240-0409 E-11 8230-5307 E-14 8240-0410 E-11 8230-5308 E-14 8240-0411 E-11 8230-5309 E-14 8240-0412 E-11 8230-5360 B-09 8240-0489 E-14 8230-5361 B-09 8240-0490 E-14 8230-5379 F-03 8240-0491 E-14 8230-5380 F-03 8240-0492 E-14 8230-5481 M-03 8240-0500 B-09 8230-5482 M-03 8240-0501 B-09 8230-5484 M-03 8240-0523 F-03 8240-0029 A-10 8240-0552 F-03 8240-0135 I-03 8240-4862 E-17 8240-0152 C-14 8240-0153 C-14 8240-4882 8240-0154 C-14 A-11 I-05 K-07 8240-0182 A-03 8240-0213 A-08 8240-4892 8240-0214 A-08 A-11 I-05 K-07 8240-0215 A-08 8240-4912 A-15 8240-0263 G-03 8240-4922 A-15 8240-0264 G-03 8240-4932 A-15 8240-0265 G-03 8240-0266 G-03 8240-4942 8240-0267 G-03 A-11 I-05 K-07 8240-0268 G-03 8240-4952 E-18 8240-0276 M-03 8240-4992 E-18 8240-0277 M-03 8240-0278 M-03 8240-0279 A-08 8240-0287 B-03 8240-0288 B-03 8240-0300 K-05 8240-0336 B-03 8240-0337 B-03 8240-0338 A-03 8240-0339 A-08 INDEX WARNING Which may result in overheating or fire. 可能造成发热、起火! Do not exceed prescribed current to the connectors. Do not use a broken or cracked housing. Do not use a deformed or rusty terminal. ◦请不要使用超出规定的电流值。 ◦请不要使用有破损的或裂缝的接插件护套。 ◦请不要使用变形的或已生锈的端子。 CAUTION Precautions for Selection and Use of Connectors 选定、 使用接插件时的注意事项 ◦To select a suitable connector, please consult with our sales staff about operating environment, mounting conditions, and other information(e.g. unsealed type for indoor compartment use, sealed type for engine compartment use) . ◦The performance of a connector may significantly vary depending on changes in variable elements in the operating environment, such as the number of ways, wire size, ambient temperature, etc. For detailed electrical characteristics of each product, see the “Specifications” of the relevant series. ◦We have “Specifications” for connector performance and “Instruction Manuals” for connector usage, handling, and precautions, which are available for each connector series. Please be sure to read these in advance to select the appropriate connector and to use it correctly. ◦Some connector series require special attention during circuit checks, etc. ◦Although some connector specifications include drawings showing mating support, these drawings are provided only for reference. The manufacture of mating parts is not possible without consideration to dimensional tolerances, etc. ◦选定接插件时,针对使用环境、组装条件等问题,请与弊公司 销售负责人商量以便选择出适合用途的产品(例如 :室内选择 非防水性的,发动机仓内选择防水性的等) 。 ◦接插件的性能的数值受极数、使用电线大小、周围温度等各 种使用环境因素的影响,会产生很大的变化。  有关各产品的详细电流特性,请确认各系列的「式样书」。 ◦本公司备有各系列接插件性能相关的「式样书」和接插件使用 方法、处理方法、注意点相关的「使用说明书」。选定、使用 接插件时,请务必阅读并正确使用。 ◦针对不同系列的接插件,有需要注意导通检查的情况。 ◦在产品目录中虽然有一部分接插件固定用支架以及对接端的 内容,但仅为参考图使用,不可忽略相关的尺寸公差,随意 制造对接端。 ◦在产品目录中有一部分是与客户共同开发的产品。如需销售给 别的客户时,需要事先得到其允许,具体事宜请向弊公司销 售负责人问询。 ◦This catalogue include the parts that was designed and developed jointly with a customer and require prior approval before sales. Please contact our sales staff for details. *Product specifications may be subject to change without notice. Before using the product, please obtain a“customer drawing” “Specifications” “Instruction Manuals”from our sales staff. Please contact our sales staff for details. ※※ 产品式样变更时可能不另行告知。  使用产品时 , 请向敝公司销售负责人索取「客户用图纸」 「仕样 书」 「使用说明书」。  对上述相关详细内容,请向敝公司销售负责人问讯。 中国上海市长宁区遵义路100号 虹桥上海城B栋1503‒1506室 邮政编码 200051 电话 021‒20286588 传真 021‒20243251 ■总公司 三重县四日市市滨田町5番28号 邮政编码 510‒8528 电话(059)354‒6200 传真(059)354‒6318 ■总公司东京 东京都港区元赤坂1丁目3番13号(赤坂中心大厦11楼) 邮政编码 107‒ 0051 电话(03)6384‒5600 传真(03)6384‒5601 Global Network-Sales Office Locations- 销售部门一览 日本国内营业统辖部 Hong Kong Wiring Systems,Ltd. 「China」 【HKWS】 Suites 1701-06, 17th Floor, Chinachem TsuenWan Plaza, 455-457 Castle Peak Road, Tsuen Wan, N.T., HongKong TEL 2411-0806 FAX 2413-6098 (852) (852) 名古屋营业部 名古屋市西区牛岛町6番1号(名古屋朗讯大厦17楼) 邮政编码 451‒ 6025 电话(052)582‒6222 传真(052)582‒6228 东京营业部 东京都港区元赤坂1丁目3番13号(赤坂中心大厦11楼) 邮政编码 107‒ 0051 电话(03)6384‒5604 传真(03)6384‒5608 大阪营业部 大阪市中央区今桥4丁目3番18号(HK今桥大厦3楼) 邮政编码 541‒ 0042 电话(06)6229‒1960 传真(06)6229‒1965 海外营业统辖部 海外事业推进部 名古屋市西区牛岛町6番1号(名古屋朗讯大厦17楼) 邮政编码 451‒ 6025 电话(052)582‒6224 传真(052)582‒6272 Sumitomo Wiring Systems (U.S.A.)Inc.「U.S.A.」 【SWS-USA】 39555 Orchard Hill Place Suite L60 Novi, MI 48375-5523 U.S.A. TEL 248-347-9450 FAX 248-347-9451 (1) (1) SWS China Ltd.「China」 【SWS-C】 Room 1503-1506, TowerB, City Center of Shanghai, 100 Zunyi Rd., Shanghai, China 200051 TEL 21-2028-6588 FAX 21-2024-3251 (86) (86) SWS-Korea Co.,Ltd.「Korea」 【SWS-K】 402, 8 Seongnam-daero 331beon-gil, Bundang-gu, Seongnam-si, Gyeonggi-do, Korea 13558 TEL 31-719-9710 FAX 31-719-9719 (82) (82) SWS Sales & Marketing Co.,Ltd.「Thailand」 (Thailand) 【SWS-T】 33/4 The 9th Towers, Grand Rama 9, Tower A, 15th Fl., RamaRd., Huaykwang, Huaykwang, Bangkok 10310 Thailand TEL 02-001-4301-9 FAX 02-001-4310 (66) (66) SEWS-Components & Electronics Europe, KFT.「Hungary」 【SEWS-CEKFT】 BILK Ipari Park, Europe U, 12/Building L1 Budapest 1239, Hungary TEL 1889-0500 FAX 1889-0501 (36) (36) URL: http://www.sws.co.jp 开发营业部 东京都港区元赤坂1丁目3番13号(赤坂中心大厦11楼) 邮政编码 107-0051 电话(03)6384‒5609 传真(03)6384‒5610   本商品目录的内容截止至2017年5月。 May. 2017L05B
6098-3802 价格&库存
很抱歉,暂时无法提供与“6098-3802”相匹配的价格&库存,您可以联系我们找货
    • 100+1.14413
    库存:14700
    6098-3802
      库存:4000
      6098-3802
        • 1+2.31220
        • 500+1.73360
        • 1000+1.15610
        库存:158
        6098-3910
          库存:35000
          6098-3802
            • 100+1.37370
            库存:800
