AFD01-S33FCA-00
AFD01-S33FCA-00
    JS(钜硕电子)
    SMD,P=0.5mm,卧贴
    间距:0.5mm 触点数量:33P 锁定特性:翻盖式 安装类型:卧贴 触点类型:下接 板上高度:H2.0mm 描述:大焊片
AFD01-S33FCA-00 数据手册
0 1 2 4 3 5 6 8 7 REV. ECN NO. 9 LOCAS. 22.12.01 A B±0.1 B D±0.2 2.0 1.4 C±0.2 ° 5.3 0.80 4.5 0.75 90 C 0.50 0.20 A±0.1 0.10 D 0.5*(n+1)±0.05 0.5*(n-1)±0.05 0.30 0.50 0.30±0.02 .3 R0 2- 6.0 E 2.2 1.9 A±0.1 PROPER CABLE (SCALE 2:1) 0.5 0.3 F H 0.5 1.0 1.25 2.3 技术要求(Technical Index): PC BOARD LAYOUT 1.材质与表面处理(Material And Finish): 基座(Housing)and 盖子(Cover):LCP UL94V-0 Nature Or Black; 端子(Terminal):Phosphor Copper Au/Sn Plated; 焊片(Solder):Copper Alloy Au/Sn Plated; 2.工作温度(Temperature range):-25°C~+85°C. 3.额定电压(Rated voltage):50V,AC/DC. 4.额定电流:0.4A,AC/DC. 5.接触电阻(Contact resistance):≤20mΩ. 6.绝缘电阻(Insulation resistance):≥500MΩ. 7.耐电压(Withstanding Voltage):200V AC/minute. 1 2 3 6 B C D 1.50 2.00 2.50 3.00 3.50 4.00 4.50 5.00 5.50 6.00 6.50 7.00 7.50 8.00 8.50 9.00 9.50 10.00 10.50 11.00 11.50 12.00 12.50 13.00 13.50 14.00 14.50 15.00 15.50 16.00 16.50 17.00 17.50 18.00 18.50 19.00 19.50 20.00 20.50 21.00 21.50 22.00 22.50 23.00 23.50 24.00 24.50 25.00 25.50 26.00 26.50 27.00 27.50 28.00 28.50 29.00 29.50 2.60 3.10 3.60 4.10 4.60 5.10 5.60 6.10 6.60 7.10 7.60 8.10 8.60 9.10 9.60 10.10 10.60 11.10 11.60 12.10 12.60 13.10 13.60 14.10 14.60 15.10 15.60 16.10 16.60 17.10 17.60 18.10 18.60 19.10 19.60 20.10 20.60 21.10 21.60 22.10 22.60 23.10 23.60 24.10 24.60 25.10 25.60 26.10 26.60 27.10 27.60 28.10 28.60 29.10 29.60 30.10 30.60 5.80 6.30 6.80 7.30 7.80 8.30 8.80 9.30 9.80 10.30 10.80 11.30 11.80 12.30 12.80 13.30 13.80 14.30 14.80 15.30 15.80 16.30 16.80 17.30 17.80 18.30 18.80 19.30 19.80 20.30 20.80 21.30 21.80 22.30 22.80 23.30 23.80 24.30 24.80 25.30 25.80 26.30 26.80 27.30 27.80 28.30 28.80 29.30 29.80 30.30 30.80 31.30 31.80 32.30 32.80 33.30 33.80 7.40 7.90 8.40 8.90 9.40 9.90 10.40 10.90 11.40 11.90 12.40 12.90 13.40 13.90 14.40 14.90 15.40 15.90 16.40 16.90 17.40 17.90 18.40 18.90 19.40 19.90 20.40 20.90 21.40 21.90 22.40 22.90 23.40 23.90 24.40 24.90 25.40 25.90 26.40 26.90 27.40 27.90 28.40 28.90 29.40 29.90 30.40 30.90 31.40 31.90 32.40 32.90 33.40 33.90 34.40 34.90 35.40 深圳市钜硕电子有限公司 CHECK: Ke Tian SHENZHEN JUSHUO ELECTRONIC CO.,LTD Youquan Xu TOL DIM 5 A 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 Jenply APPROVED: 4 孔位 DESIGN: X. ±0.25 X.X ±0.20 X.XX ±0.15 X.XXX 0 DESIGN DATE A A G 11 10 DESCRIPTION 7 TITLE: DIM TOL X°. X.X° X.XX° X.XXX° ±3.0° C D E F G FPC 0.5mm翻盖式H2.0下接D型(大焊片) PART NO. AFD01-S**-F**-00 SCALE: REV. A 8 B 9 N/A UNIT: mm 10 H SHEET: 1/1 11
AFD01-S33FCA-00 价格&库存
很抱歉,暂时无法提供与“AFD01-S33FCA-00”相匹配的价格&库存,您可以联系我们找货
AFD01-S33FCA-00
    • 2000+1.16158
    库存:2000
    AFD01-S33FCA-00
    • 5+1.24233
    • 50+0.99306
    • 150+0.88625
    • 500+0.75287
    库存:758
