PNA2405S3S
PNA2405S3S
    FLEX(伟创力)
    SMD17 模块
    9-36VIN; 0.9-5.5VOUT; 6A; NON-IS
PNA2405S3S 数据手册
INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) jidgjian Grace Jiang Approved (Document resp) PNA series jidgjian GracePoL JiangRegulators 1 (4) No. Checked Rainbo Input 9-36 V, Output up to 6 A / 33 W 1/1301-BMR661 Technical Specification Date 2021/3/24 Rev 1/28701 - BMR661 Rev. A A © Flex Z April 2021 Key Features • Small size 13.0 x 12.35 x 6.2 mm (0.512 x 0.486 x 0.244 in) • 0.9 V – 5.5V output voltage range • 6 A maximum output current • High efficiency, typ. 93.8% at 24 Vin, 5.5 Vout, 6A load • Control loop with fast load transient response • Allows synchronization to an external clock • Meets safety requirements according to IEC/EN/UL 62368-1 • MTBF 71.84 Mh General Characteristics • • • • • • • • Output voltage adjust function Output over current protection Over temperature protection Remote control Power Good Soft start and Output voltage tracking Highly automated manufacturing ensures quality ISO 9001/14001 certified supplier Safety Approvals Design for Environment Meets requirements in hightemperature lead-free soldering processes. Contents Ordering Information General Information Safety Specification Absolute Maximum Ratings ............................................................. 2 ............................................................. 2 ............................................................. 3 ............................................................. 4 Electrical Specification 0.9 V/ 6 A 1.8 V/ 6 A 3.3 V/ 6 A 5.5 V/ 6 A ............................................................. 5 ............................................................. 8 ........................................................... 11 ........................................................... 14 Operating Information Thermal Consideration Connections Mechanical Information Delivery Package Information Product Qualification Specification ........................................................... 18 ........................................................... 20 ........................................................... 21 ........................................................... 22 ........................................................... 24 ........................................................... 25 INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgjian Grace Jiang Approved (Document resp) Checked PNA series jidgjian GracePoL JiangRegulators Rainbo Input 9-36 V, Output up to 6 A / 33 W Ordering Information Product number PNA2405S3S Output 0.9-5.5V, 6 A/ 33 W 1/1301-BMR661 Technical Specification Date 2021/3/24 Rev 1/28701 - BMR661 Rev. A A © Flex Z 2 (4) 2 April 2021 the registration, evaluation, authorization and restriction of chemicals (REACH) as they enter into force and is through product materials declarations preparing for the obligations to communicate information on substances in the products. Quality Statement Product number and Packaging PNA2405S3n1 n2 Options n1 ο mechanical n2 Delivery package information Options ο Description n1 S Surface mount (solder bump) n2 C Tape and reel (One full reel contains 400 pcs products.) Example: PNA2405S3S C means a Solder bump, positive logic product with tape and reel packaging. The reel capacity is 400 pcs products per reel. General Information Reliability The failure rate (λ) and mean time between failures (MTBF= 1/λ) is calculated at max output power and an operating ambient temperature (TA) of +40°C. Flex Power uses Telcordia SR-332 Issue 4 Method 1 to calculate the mean steady-state failure rate and standard deviation (σ). Telcordia SR-332 Issue 4 also provides techniques to estimate the upper confidence levels of failure rates based on the mean and standard deviation. Mean steady-state failure rate, λ Std. deviation, σ 14 nFailures/h 3.6 nFailures/h MTBF (mean value) for the PMU series = 71.84 Mh. MTBF at 90% confidence level = 53.99 Mh Compatibility with RoHS requirements The products are compatible with the relevant clauses and requirements of the RoHS directive 2011/65/EU and 2015/863 and have a maximum concentration value of 0.1% by weight in homogeneous materials for lead, mercury, hexavalent chromium, PBB, PBDE, DEHP, BBP, DBP, DIBP and of 0.01% by weight in homogeneous materials for cadmium. Exemptions in the RoHS directive utilized in Flex Power products are found in the Statement of Compliance document. Flex Power fulfills and will continuously fulfill all its obligations under regulation (EC) No 1907/2006 concerning The products are designed and manufactured in an industrial environment where quality systems and methods like ISO 9000, Six Sigma, and SPC are intensively in use to boost the continuous improvements strategy. Infant mortality or early failures in the products are screened out and they are subjected to an ATE-based final test. Conservative design rules, design reviews and product qualifications, plus the high competence of an engaged work force, contribute to the high quality of the products. Warranty Warranty period and conditions are defined in Flex Power General Terms and Conditions of Sale. Limitation of Liability Flex Power does not make any other warranties, expressed or implied including any warranty of merchantability or fitness for a particular purpose (including, but not limited to, use in life support applications, where malfunctions of product can cause injury to a person’s health or life). © Flex Power 2021 The information and specifications in this technical specification is believed to be correct at the time of publication. However, no liability is accepted for inaccuracies, printing errors or for any consequences thereof. Flex Power reserves the right to change the contents of this technical specification at any time without prior notice. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgjian Grace Jiang Approved (Document resp) PNA series jidgjian GracePoL JiangRegulators Checked Rainbo Input 9-36 V, Output up to 6 A / 33 W Safety Specification General information Flex DC/DC converters and DC/DC regulators are designed in accordance with the safety standards IEC 62368-1, EN 62368-1 and UL 62368-1 Audio/video, information and communication technology equipment Part 1: Safety requirements IEC/EN/UL 62368-1 contains requirements to prevent injury or damage due to the following hazards: • • • • • • Electrical shock Electrically-caused fire Injury caused by hazardous substances Mechanically-caused injury Skin burn Radiation-caused injury On-board DC/DC converters, Power interface modules and DC/DC regulators are defined as component power supplies. As components they cannot fully comply with the provisions of any safety requirements without “conditions of acceptability”. Clearance between conductors and between conductive parts of the component power supply and conductors on the board in the final product must meet the applicable safety requirements. Certain conditions of acceptability apply for component power supplies with limited stand-off (see Mechanical Information for further information). It is the responsibility of the installer to ensure that the final product housing these components complies with the requirements of all applicable safety standards and regulations for the final product. Component power supplies for general use shall comply with the requirements in IEC/EN/UL 62368-1. Product related standards, e.g. IEEE 802.3af Power over Ethernet, and ETS-300132-2 Power interface at the input to telecom equipment, operated by direct current (dc) are based on IEC/EN/UL 60950-1 with regards to safety. Flex DC/DC converters, Power interface modules and DC/DC regulators are UL 62368-1 recognized and certified in accordance with EN 62368-1. The flammability rating for all construction parts of the products meet requirements for V-0 class material according to IEC 60695-11-10, Fire hazard testing, test flames – 50 W horizontal and vertical flame test methods. Non - isolated DC/DC regulators The DC/DC regulator output is ES1 energy source if the input source meets the requirements for ES1 according to IEC/EN/UL 62368-1. 1/1301-BMR661 Technical Specification Date 2021/3/24 Rev 1/28701 - BMR661 Rev. A A © Flex Z 3 (4) 3 April 2021 INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) jidrguaa Rainbo Gu Approved (Document resp) 1 (14) No. Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY 2/1301- BMRTechnical 661 Specification Date 4/21/2021 4 Rev 1/28701 - BMR661 Rev. A April 2021 A © Flex Absolute Maximum Ratings Characteristics min max Unit TP1 Operating Temperature (See Thermal Consideration section) -40 +125 °C TS Storage temperature -55 +150 °C VI Input voltage 9 36 V VRC Remote Control pin voltage (see Operating Information section) -0.3 36 V Positive logic typ Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the Electrical Specification section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Typical Application Diagram INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) 2 (14) No. jidrguaa Rainbo Gu Approved (Document resp) Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY 2/1301- BMRTechnical 661 Specification Date Rev 1/28701 - BMR661 Rev. A 4/21/2021 A 5 April 2021 © Flex Electrical Specification 0.9 V, 6 A / 5.4 W PNA2405S3S TP1 = -40 to +85 ºC, VI = 9 to 28 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 24 V, max IO, unless otherwise specified under Conditions. Additional Cin = 100 µF Electrolytic1 + 2 x 4.7 µF Ceramic, Cout = 2 x 47 µF Ceramic. Characteristics Conditions min typ 92 max Unit 28 V VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7 VIon Turn-on input voltage Increasing input voltage 8 V CI Internal input capacitance 1.1 μF PO Output power 0 V 5.4 50% of max IO 72.5 max IO 75.9 50% of max IO, VI = 12 V 83.2 W η Efficiency max IO, VI = 12 V 83.0 Pd Power Dissipation max IO 1.7 W Pli Input idling power IO = 0 A, VI = 24 V 0.1 W PRC Input standby power VI = 24 V (turned off with RC) 50 mW fs Switching frequency 0-100 % of max IO 450 kHz VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 24 V, IO = 6 A 0.9 V Idling voltage IO = 0 A 0.9 V Line regulation max IO 9 mV Load regulation VI = 24 V, 0-100 % of max IO 9 mV VO Vtr Load transient voltage deviation ttr Load transient recovery time tr Ramp-up time ts tf (from 10−90% of VOi) Start-up time ±50 VI = 24 V, Load step 25-75-25% of max IO, di/dt = 1 A/μs (from VI off to 10% of VOi) µs 3 ms 4 ms VI = 24 V, IO = max IO 30 ms 4 ms VI = 24 V, IO = max IO tRC RC start-up time max IO RC Trigger level Increasing RC-voltage IO Output current Ilim Current limit threshold TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, RMS 1.7 VOac Output ripple & noise See ripple & noise section, VOi 6.1 (from VRC connection to 90% of VOi) mV 80 (from VI connection to 90% of VOi) Shut-down time % 1.2 0 8 8.5 V 6 A 10 A 9 mVp-p A Note 1. Elyctrolytic capacitor UPS2A101MHD from Nichicon with typical ESR value 0.18 Ω (20℃ 100 kHz). Note 2. Minimum input voltage is increased for high output voltages. For output voltages below 5.0V, input undervoltage lockut threshold is recommended to set to 7V. For output voltages above 5.0V, input undervoltage lockut threshold is recommended to set to 9V. See Remote control and input undervoltage lockout (EN/UVLO) section for detailed information. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) 3 (14) No. jidrguaa Rainbo Gu Approved (Document resp) 2/1301- BMRTechnical 661 Specification Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY Date 4/21/2021 Rev 1/28701 - BMR661 Rev. A April 2021 A © Flex Typical Characteristics 0.9 V, 6 A / 5.4 W PNA2405S3S Efficiency Power Dissipation [%] [W] 90 4 80 3 9V 70 12 V 60 24 V 50 40 6 0 1 2 3 4 5 6 9V 2 12 V 24 V 1 0 [A] 0 Thermal Derating [V] 8.00 0.94 Nat Conv. 0.5 m/s 6.00 4.00 1.0 m/s 2.0 m/s 2.00 50 4 5 6 [A] 0.92 75 100 125 150 [°C] Load current vs. ambient air temperature and airflow. VI = 24 V 9V 12V 0.9 24V 0.88 0.86 25 3 Load Regulation [A] 0 2 Dissipated power vs. load current and input voltage at TP1 = +25°C. Efficiency vs. load current and input voltage at TP1 = +25°C. 0.00 1 0 1 2 3 4 5 6 [A] Output voltage vs. load current and input voltage at TP1 = +25°C. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) jidrguaa Rainbo Gu Approved (Document resp) Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY 2/1301- BMRTechnical 661 Specification Date 4/21/2021 Rev 1/28701 - BMR661 Rev. A A April 2021 PNA2405S3S Start-up Shut-down Top trace: output voltage 1 V/div. Bottom trace: input voltage 20 V/div. Time scale: 5 ms/div. Output Ripple & Noise Output voltage ripple at: TP1 = +25°C, VI = 24 V, IO = 6 A electrionic load. 7 © Flex Typical Characteristics 0.9 V, 6 A / 5.4 W Start-up enabled by connecting VI at: TP1 = +25°C, VI = 24 V, IO = 6 A resistive load. 4 (14) No. Shut-down enabled by disconnecting VI at: TP1 = +25°C, VI = 24 V, IO = 6 A resistive load. Top trace: output voltage 1 V/div. Bottom trace: input voltage 20 V/div. Time scale: 50 ms/div. Output Load Transient Response Trace: output voltage 5 mV/div. Time scale: 2 µs/div. 20 MHz bandwidth. Output voltage response to load current stepchange 1.5-4.5-1.5 A at: TP1 =+25°C, VI = 24 V. COUT = 2x47 µF Ceramic + 330 µF Polymer Top trace: output voltage 50 mV/div. Bottom trace: load current 2 A/div. Time scale: 200 µs/div. Slew rate: 1A/µs. 20 MHz bandwidth. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) 5 (14) No. jidrguaa Rainbo Gu Approved (Document resp) Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY 2/1301- BMRTechnical 661 Specification Date Rev 1/28701 - BMR661 Rev. A 4/21/2021 A 8 April 2021 © Flex Electrical Specification 1.8 V, 6 A / 10.8 W PNA2405S3S TP1 = -40 to +85 ºC, VI = 9 to 36 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 24 V, max IO, unless otherwise specified under Conditions. Additional Cin = 100 µF Electrolytic1 + 2 x 4.7 µF Ceramic, Cout = 2 x 47 µF Ceramic. Characteristics Conditions min typ 92 max Unit 36 V VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7 VIon Turn-on input voltage Increasing input voltage 8 V CI Internal input capacitance 1.1 μF PO Output power 0 V 10.8 50% of max IO 83.6 max IO 85.8 50% of max IO, VI = 12 V 90.3 W η Efficiency max IO, VI = 12 V 90.0 Pd Power Dissipation max IO 1.8 W Pli Input idling power IO = 0 A, VI = 24 V 0.2 W PRC Input standby power VI = 24 V (turned off with RC) 50 mW fs Switching frequency 0-100 % of max IO 450 kHz VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 24 V, IO = 6 A 1.78 V Idling voltage IO = 0 A 1.78 V Line regulation max IO 18 mV Load regulation VI = 24 V, 0-100 % of max IO 18 mV VO Vtr Load transient voltage deviation ttr Load transient recovery time tr Ramp-up time ts tf (from 10−90% of VOi) Start-up time ±60 VI = 24 V, Load step 25-75-25% of max IO, di/dt = 1 A/μs (from VI off to 10% of VOi) µs 3 ms 4.5 ms VI = 24 V, IO = max IO 25 ms 4 ms VI = 24 V, IO = max IO tRC RC start-up time max IO RC Trigger level Increasing RC-voltage IO Output current Ilim Current limit threshold TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, RMS VOac Output ripple & noise See ripple & noise section, VOi (from VRC connection to 90% of VOi) mV 80 (from VI connection to 90% of VOi) Shut-down time % 1.2 0 8 8.5 V 6 A 10 A 18 mVp-p 1.7 7 A Note 1. Elyctrolytic capacitor UPS2A101MHD from Nichicon with typical ESR value 0.18 Ω (20℃ 100 kHz). Note 2. Minimum input voltage is increased for high output voltages. For output voltages below 5.0V, input undervoltage lockut threshold is recommended to set to 7V. For output voltages above 5.0V, input undervoltage lockut threshold is recommended to set to 9V. See Remote control and input undervoltage lockout (EN/UVLO) section for detailed information. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) 6 (14) No. jidrguaa Rainbo Gu Approved (Document resp) 2/1301- BMRTechnical 661 Specification Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY Date 4/21/2021 Rev 1/28701 - BMR661 Rev. A 9 April 2021 A © Flex Typical Characteristics 1.8 V, 6 A /10.8 W PNA2405S3S Efficiency Power Dissipation [%] [W] 100 4 90 9V 12 V 80 3 9V 12 V 2 24 V 36 V 70 60 0 1 2 3 4 5 6 24 V 36 V 1 0 [A] 0 Thermal Derating [V] 8.00 1.82 Nat Conv. 0.5 m/s 6.00 4.00 1.0 m/s 2.0 m/s 2.00 50 4 5 6 [A] 1.8 75 100 125 150 [°C] Load current vs. ambient air temperature and airflow. VI = 24 V 9V 12V 1.78 24V 36V 1.76 1.74 25 3 Load Regulation [A] 0 2 Dissipated power vs. load current and input voltage at TP1 = +25°C. Efficiency vs. load current and input voltage at TP1 = +25°C. 0.00 1 0 1 2 3 4 5 6 [A] Output voltage vs. load current and input voltage at TP1 = +25°C. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) jidrguaa Rainbo Gu Approved (Document resp) Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY 2/1301- BMRTechnical 661 Specification Date 4/21/2021 Rev 1/28701 - BMR661 Rev. A A April 2021 PNA2405S3S Start-up Shut-down Top trace: output voltage 1 V/div. Bottom trace: input voltage 20 V/div. Time scale: 5 ms/div. Output Ripple & Noise Output voltage ripple at: TP1 = +25°C, VI = 24 V, IO = 6 A electrionic load. 10 © Flex Typical Characteristics 1.8 V, 6 A / 10.8 W Start-up enabled by connecting VI at: TP1 = +25°C, VI = 24 V, IO = 6 A resistive load. 7 (14) No. Shut-down enabled by disconnecting VI at: TP1 = +25°C, VI = 24 V, IO = 6 A resistive load. Top trace: output voltage 1 V/div. Bottom trace: input voltage 20 V/div. Time scale: 50 ms/div. Output Load Transient Response Trace: output voltage 10 mV/div. Time scale: 2 µs/div. 20 MHz bandwidth. Output voltage response to load current stepchange 1.5-4.5-1.5 A at: TP1 =+25°C, VI = 24 V. COUT = 2x47 µF Ceramic + 330 µF Polymer Top trace: output voltage 50 mV/div. Bottom trace: load current 2 A/div. Time scale: 200 µs/div. Slew rate: 1A/µs. 20 MHz bandwidth. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) 8 (14) No. jidrguaa Rainbo Gu Approved (Document resp) Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY 2/1301- BMRTechnical 661 Specification Date Rev 1/28701 - BMR661 Rev. A 4/21/2021 A 11 April 2021 © Flex Electrical Specification 3.3 V, 6 A /19.8 W PNA2405S3S TP1 = -40 to +85 ºC, VI = 9 to 36 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 24 V, max IO, unless otherwise specified under Conditions. Additional Cin = 100 µF Electrolytic1 + 2 x 4.7 µF Ceramic, Cout = 2 x 47 µF Ceramic. Characteristics Conditions min typ 92 max Unit 36 V VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7 VIon Turn-on input voltage Increasing input voltage 8 V CI Internal input capacitance 1.1 μF PO Output power 0 V 19.8 50% of max IO 89.6 max IO 91.2 50% of max IO, VI = 12 V 93.7 W η Efficiency max IO, VI = 12 V 93.4 Pd Power Dissipation max IO 1.9 W Pli Input idling power IO = 0 A, VI = 24 V 0.7 W PRC Input standby power VI = 24 V (turned off with RC) 50 mW fs Switching frequency 0-100 % of max IO 450 kHz VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 24 V, IO = 6 A 3.27 V Idling voltage IO = 0 A 3.27 V Line regulation max IO 33 mV Load regulation VI = 24 V, 0-100 % of max IO 33 mV VO Vtr Load transient voltage deviation ttr Load transient recovery time tr Ramp-up time ts tf (from 10−90% of VOi) Start-up time ±60 VI = 24 V, Load step 25-75-25% of max IO, di/dt = 1 A/μs (from VI off to 10% of VOi) µs 3 ms 4 ms VI = 24 V, IO = max IO 20 ms 4 ms VI = 24 V, IO = max IO tRC RC start-up time max IO RC Trigger level Increasing RC-voltage IO Output current Ilim Current limit threshold TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, RMS 1.7 VOac Output ripple & noise See ripple & noise section, VOi 10 (from VRC connection to 90% of VOi) mV 100 (from VI connection to 90% of VOi) Shut-down time % 1.2 0 8 8.5 V 6 A 11 A 33 mVp-p A Note 1. Elyctrolytic capacitor UPS2A101MHD from Nichicon with typical ESR value 0.18 Ω (20℃ 100 kHz). Note 2. Minimum input voltage is increased for high output voltages. For output voltages below 5.0V, input undervoltage lockut threshold is recommended to set to 7V. For output voltages above 5.0V, input undervoltage lockut threshold is recommended to set to 9V. See Remote control and input undervoltage lockout (EN/UVLO) section for detailed information. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) 9 (14) No. jidrguaa Rainbo Gu Approved (Document resp) 2/1301- BMRTechnical 661 Specification Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY Date 4/21/2021 Rev 1/28701 - BMR661 Rev. A 12 April 2021 A © Flex Typical Characteristics 3.3 V, 6 A / 19.8 W PNA2405S3S Power Dissipation Efficiency [%] [W] 100 4 90 9V 12 V 80 3 9V 12 V 2 24 V 36 V 70 60 0 1 2 3 4 5 6 24 V 36 V 1 0 [A] 0 Thermal Derating [V] 8.00 3.32 Nat Conv. 0.5 m/s 6.00 4.00 1.0 m/s 2.0 m/s 2.00 50 4 5 6 [A] 3.3 75 100 125 150 [°C] Load current vs. ambient air temperature and airflow. VI = 24 V 9V 12V 3.28 24V 36V 3.26 3.24 25 3 Load Regulation [A] 0 2 Dissipated power vs. load current and input voltage at TP1 = +25°C. Efficiency vs. load current and input voltage at TP1 = +25°C. 0.00 1 0 1 2 3 4 5 6 [A] Output voltage vs. load current and input voltage at TP1 = +25°C. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) 2/1301- BMRTechnical 661 Specification jidrguaa Rainbo Gu Approved (Document resp) Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY Date 4/21/2021 Rev 1/28701 - BMR661 Rev. A A April 2021 PNA2405S3S Start-up Shut-down Top trace: output voltage 2 V/div. Bottom trace: input voltage 20 V/div. Time scale: 50 ms/div. Output Ripple & Noise Output voltage ripple at: TP1 = +25°C, VI = 24 V, IO = 6 A electrionic load. 13 © Flex Typical Characteristics 3.3 V, 6 A / 19.8 W Start-up enabled by connecting VI at: TP1 = +25°C, VI = 24 V, IO = 6 A resistive load. 10 (14) No. Shut-down enabled by disconnecting VI at: TP1 = +25°C, VI = 24 V, IO = 6 A resistive load. Top trace: output voltage 2 V/div. Bottom trace: input voltage 20 V/div. Time scale: 50 ms/div. Output Load Transient Response Trace: output voltage 5 mV/div. Time scale: 2 µs/div. 20 MHz bandwidth. Output voltage response to load current stepchange 1.5-4.5-1.5 A at: TP1 =+25°C, VI = 24 V. COUT = 2x47 µF Ceramic + 330 µF Polymer Top trace: output voltage 100 mV/div. Bottom trace: load current 2 A/div. Time scale: 100 µs/div. Slew rate: 1A/µs. 20 MHz bandwidth. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) 11 (14) No. jidrguaa Rainbo Gu Approved (Document resp) Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY 2/1301- BMRTechnical 661 Specification Date Rev 1/28701 - BMR661 Rev. A 4/21/2021 A 14 April 2021 © Flex Electrical Specification 5.5 V, 6 A / 33 W PNA2405S3S TP1 = -40 to +85 ºC, VI = 12 to 36 V, unless otherwise specified under Conditions. Typical values given at: TP1 = +25°C, VI= 24 V, max IO, unless otherwise specified under Conditions. Additional Cin = 100 µF Electrolytic1+ 2 x 4.7 µF Ceramic, Cout = 2 x 47 µF Ceramic. Characteristics Conditions min typ 112 max Unit 36 V VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage 7 VIon Turn-on input voltage Increasing input voltage 8 V CI Internal input capacitance 1.1 μF PO Output power 0 V 33 50% of max IO 92.4 max IO 93.8 50% of max IO, VI = 12 V 95.7 W η Efficiency max IO, VI = 12 V 95.5 Pd Power Dissipation max IO 2.2 W Pli Input idling power IO = 0 A, VI = 24 V 0.8 W PRC Input standby power VI = 24 V (turned off with RC) 40 mW fs Switching frequency 0-100 % of max IO 450 kHz VOi Output voltage initial setting and accuracy TP1 = +25°C, VI = 24 V, IO = 6 A 5.49 V Idling voltage IO = 0 A 5.49 V Line regulation max IO Load regulation VI = 24 V, 0-100 % of max IO VO Vtr Load transient voltage deviation ttr Load transient recovery time tr Ramp-up time ts tf (from 10−90% of VOi) Start-up time 2 (from VI off to 10% of VOi) mV 55 mV mV 100 µs 3 ms 4 ms VI = 24 V, IO = max IO 16 ms 4 ms VI = 24 V, IO = max IO tRC RC start-up time max IO RC Trigger level Increasing RC-voltage IO Output current Ilim Current limit threshold TP1 < max TP1 Isc Short circuit current TP1 = 25ºC, RMS 1.6 VOac Output ripple & noise See ripple & noise section, VOi 14 (from VRC connection to 90% of VOi) 55 ±50 VI = 24 V, Load step 25-75-25% of max IO, di/dt = 1 A/μs (from VI connection to 90% of VOi) Shut-down time % 1.2 0 8 10 V 6 A 11 A 55 mVp-p A Note 1. Elyctrolytic capacitor UPS2A101MHD from Nichicon with typical ESR value 0.18 Ω (20℃ 100 kHz). Note 2. Minimum input voltage is increased for high output voltages. For output voltages below 5.0V, input undervoltage lockut threshold is recommended to set to 7V. For output voltages above 5.0V, input undervoltage lockut threshold is recommended to set to 9V. See Remote control and input undervoltage lockout (EN/UVLO) section for detailed information. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) 12 (14) No. jidrguaa Rainbo Gu Approved (Document resp) 2/1301- BMRTechnical 661 Specification Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY Date 4/21/2021 Rev 1/28701 - BMR661 Rev. A April 2021 A © Flex Typical Characteristics 5.5 V, 6 A / 33 W PNA2405S3S Efficiency Power Dissipation [%] [W] 100 4 95 3 90 12 V 85 24 V 80 36 V 75 70 0 1 2 3 4 5 6 12 V 2 24 V 36 V 1 0 [A] 0 1 2 3 4 5 6 [A] Dissipated power vs. load current and input voltage at TP1 = +25°C. Efficiency vs. load current and input voltage at TP1 = +25°C. Thermal Derating Load Regulation [V] [A] 5.5 8.00 6.00 4.00 Nat Conv. 0.5 m/s 5.49 1.0 m/s 5.47 2.0 m/s 2.00 0.00 15 25 50 75 100 125 150 [°C] Load current vs. ambient air temperature and airflow. VI = 24 V 24V 36V 5.46 5.45 0 12V 5.48 0 1 2 3 4 5 6 [A] Output voltage vs. load current and input voltage at TP1 = +25°C. INTERNAL USE ONLY PRODUCT SPECIFICATION Prepared (Subject resp) jidrguaa Rainbo Gu Approved (Document resp) Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY 2/1301- BMRTechnical 661 Specification Date 4/21/2021 Rev 1/28701 - BMR661 Rev. A A April 2021 PNA2405S3S Start-up Shut-down Top trace: output voltage 5 V/div. Bottom trace: input voltage 20 V/div. Time scale: 10 ms/div. Output Ripple & Noise Output voltage ripple at: TP1 = +25°C, VI = 24 V, IO = 6 A electrionic load. 16 © Flex Typical Characteristics 5.5 V, 6 A / 33 W Start-up enabled by connecting VI at: TP1 = +25°C, VI = 24 V, IO = 6 A resistive load. 13 (14) No. Shut-down enabled by disconnecting VI at: TP1 = +25°C, VI = 24 V, IO = 6 A resistive load. Top trace: output voltage 5 V/div. Bottom trace: input voltage 20 V/div. Time scale: 50 ms/div. Output Load Transient Response Trace: output voltage 5 mV/div. Time scale: 2 µs/div. 20 MHz bandwidth. Output voltage response to load current stepchange 1.5-4.5-1.5 A at: TP1 =+25°C, VI = 24 V. COUT = 2x47 µF Ceramic + 330 µF Polymer Top trace: output voltage 100 mV/div. Bottom trace: load current 2 A/div. Time scale: 200 µs/div. Slew rate: 1A/µs. 20 MHz bandwidth. Prepared (Subject resp) 1 (6) 3/1301-BMRTechnical 661 Specification 17 No. jidrguaa Rainbo Gu Approved (Document resp) Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY VOUT cout Tantalum Capacitor 10 µF Ceramic Capacitor 0.1 µF Load Output ripple and noise Output ripple and noise measured according to figure below. +S INTERNAL USE ONLY PRODUCT SPECIFICATION PGND BNC-contact to oscilloscope Output ripple and noise test setup The module is designed for low ripple voltage at the module output and will meet the maximum output ripple specification with 0.1 µF ceramic and 10 µF tantalum at the output of the module. The loop compensation setting is designed to provide stability, accurate line and load regulation and good transient performance for a wide range of operating conditions. Inherent from the implementation and normal to the product there will be some low frequency ripple at the output, in addition to the fundamental switching frequency output ripple. This low frequency ripple is not related to instability of control loop. The total output ripple and noise is maintained at a low level. VI = 24 V, VOUT = 5.5 V, IO = 6 A, COUT = 2 x 47 μF, 20 mV/div, 1 ms/div Example of low frequency ripple at the output. Date 4/21/2021 Rev 1/28701 - BMR661 Rev. A A © Flex April 2021 Prepared (Subject resp) Checked 3/1301-BMRTechnical 661 Specification 18 Date PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY 4/21/2021 Rev 1/28701 - BMR661 Rev. A A April 2021 © Flex The required ceramic capacitors must be placed as close as possible to VIN pins to minimize the input voltage ripple. Operating information Input Voltage The input voltage range is 9 to 36 Vdc meets typical requirements in 12 V DC and 24 V DC system used in telecom, datacom, industrial and medical equipment. Remote control and input undervoltage lockout (EN/UVLO) The products are fitted with a remote control function referenced to the negative input connection (-In). The remote control function allows the product to be turned on/off by an external device like a semiconductor or mechanical switch. The standard product is provided with “positive logic”. An external pull up resistor is required for EN pin. To turn on the product, EN pin should be left open. To turn off the product, EN pin should be connected to -In. The device also supports adjustable input undervoltage lockout setting by adding a voltage divider on EN/UVLO pin. When EN voltage is below 0.37V, the device is in shutdown mode. When it exceeds 1.2V, an internal 10 µA current source is enabled and flows through the external voltage divider to provide hysteresis. The high side and low side resistor values could be calculated by Equation 1 and 2. 𝑉𝑉𝐼𝐼𝐼𝐼(𝑂𝑂𝑂𝑂) − 𝑉𝑉𝐼𝐼𝐼𝐼(𝑂𝑂𝑂𝑂𝑂𝑂) 𝑅𝑅𝑈𝑈𝑈𝑈𝑈𝑈 = 10𝜇𝜇𝜇𝜇 1.2 𝑅𝑅𝑈𝑈𝑈𝑈𝑈𝑈 = 𝑅𝑅𝑈𝑈𝑈𝑈𝑈𝑈 ∗ 𝑉𝑉𝐼𝐼𝐼𝐼(𝑂𝑂𝑂𝑂) − 1.2 2 (6) No. jidrguaa Rainbo Gu Approved (Document resp) INTERNAL USE ONLY PRODUCT SPECIFICATION Equation 1 Equation 2 Input and Output Impedance The impedance of both the input source and the load will interact with the impedance of the product. It is important that the input source has low characteristic impedance. If the input voltage source contains significant inductance, the addition of a capacitor with low ESR across the input of the product will ensure stable operation. External Input Capacitors It is recommended to use a combination of ceramic capacitors and an electrolytic capacitor on the input side. Additional 100 µF of non-ceramic capacitance is recommended for applications with large transient load requirements. At least 50 V voltage rating is recommended for both type of capacitors to cover the wide input voltage range. External Output Capacitors The output capacitors must have low ESR value to achieve low output ripple voltage. External output capacitors must be placed as close as possible to VOUT pins of the product. Minimum two 47 µF ceramic capacitors are recommended. It is important to use low resistance and low inductance PCB layout and cabling for effective capacitance. Remote Sense (+S) The products have remote sense that can be used to compensate for voltage drops between the output and the point of load. The sense traces should be located close to the PWB ground layer to reduce noise susceptibility. The internal resistor between +S and VOUT is 47Ω. If the remote sense is not needed, +S should be connected to VOUT. Over Current Protection The product is protected from over current conditions in hiccup mode. When overcurrent condition exists for 128 continuous clock cycles, a hiccup event is triggerred and SS is pulled low for 8192 clock cycles. The product will resume normal operation after removal of the overload. Synchronization (SYNC) It is possible to synchronize the product with an external clock signal. Requirements for the external clock are listed. • • • • • Clock frequency: 360 kHz to 675 kHz Clock maximum voltage amplitude: 13 V Clock minimum pulse width: 50 ns Clock minimum input logic high: 2 V Clock maximum input low: 0.8 V Power Good (PG) The power good signal indicates proper operation of the product and can also be used as an error flag indicator. The PG pin is internally pulled up to VIN with 22kΩ resistor. If the output voltage is greater than 108% or lower than 92% of its nominal value. The Power Good signal will be low to indicate that the output voltage is out of regulation. Soft Start and Output Voltage Tracking (SS/TRK) Once EN/UVLO pin voltage exceeds 1.2V increasing threshold, the device initiates soft-start process. The soft start time tss is set by Css from SS/TRK pin to AGND. A 47nF capacitor is connected internally by default. The total capacitance should be calculated by Equation 3. 𝐶𝐶𝑠𝑠𝑠𝑠 (𝑛𝑛𝑛𝑛) = 12.5 ∗ 𝑡𝑡𝑠𝑠𝑠𝑠 (𝑚𝑚𝑚𝑚) Equation 3 Prepared (Subject resp) 3 (6) 3/1301-BMRTechnical 661 Specification 19 No. jidrguaa Rainbo Gu Approved (Document resp) INTERNAL USE ONLY PRODUCT SPECIFICATION Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY The SS/TRK could also be used as tracking pin when master-slave power supply tracking is required. The function is achieved by dividing output voltage of master device through resistor network RTKR1 and RTKR2. A common application of coincident tracking is shown below. Coincident tracking forces the master and slave channels have the same output voltage ramp rate until the slave voltage reaches its setpoint. Typical coincident tracking diagram Simply select same voltage divider for both master and slave devices to implement a coincident tracking. Choose RTRK1=RSET1 and RTRK2=RSET2. Conversely, different voltage dividers for master and slave implement ratiometric tracking, which sets output voltage of slave to a fraction of master output voltage. In all cases, ensure the final value of SS/TRK voltage of slave should be at least 0.1V above VSET reference voltage 0.8V. Output Voltage Setting (VSET) The products support output voltage setting by connecting resistor RSET between VSET and AGND. Typical output voltages and corresponding RSET values are listed in table below. VOUT (V) RSET (kΩ) 0.9 1.0 1.8 2.5 3.3 5.0 5.5 80.6 39.2 8.2 4.7 3.24 1.89 1.71 Date 4/21/2021 Rev 1/28701 - BMR661 Rev. A A April 2021 © Flex Follow Equation 4 to calculate RSET for other output voltage point between 0.9V and 5.5V. 𝑅𝑅𝑆𝑆𝑆𝑆𝑆𝑆 = 8 (𝑘𝑘Ω) 𝑉𝑉𝑂𝑂 − 0.8 Equation 4 Prepared (Subject resp) 4 (6) 3/1301-BMRTechnical 661 Specification 20 No. jidrguaa Rainbo Gu Approved (Document resp) INTERNAL USE ONLY PRODUCT SPECIFICATION Checked Date PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY Thermal Consideration General The products are designed to operate in different thermal environments and sufficient cooling must be provided to ensure reliable operation. For products mounted on a PWB without a heat sink attached, cooling is achieved mainly by conduction, from the pins to the host board, and convection, which is dependent on the airflow across the product. Increased airflow enhances the cooling of the product. The Output Current Derating graph found in the Output section for provides the available output current vs. ambient air temperature and air velocity at VI = 24 V. 4/21/2021 Rev 1/28701 - BMR661 Rev. A April 2021 A © Flex osition Description Max Temp. P1 M1, Inductor, Reference point TP1=125 ºC P2 T1, MOSFET TP2=125 ºC P3 T2, MOSFET TP3=125 ºC P4 N1, Controller TP4=125 ºC Note that the maximum value is the absolute maximum rating and the Electrical Specification is guaranteed up to Tref +85 °C. P2 P3 P1 The product is tested on a 254 x 254 mm, 35 µm (1 oz), 8-layer test board mounted vertically in a wind tunnel with a cross-section of 608 x 203 mm. P4 AIR FLOW Over Temperature Protection (OTP) The internal thermal shutdown circuitry forces the device to stop switching if TP4 exceeds 155 °C. The device reinitiates the power up sequence with typical 8°C hysteresis. Layout recommendations The radiated EMI performance of the product will depend on the PCB layout and ground layer design. If a ground layer is used, it should be connected to the output of the product and the equipment ground or chassis. A ground layer will increase the stray capacitance in the PCB and improve the high frequency EMC performance. Further layout recommendations are listed below. • Definition of product operating temperature The product operating temperatures is used to monitor the temperature of the product, and proper thermal conditions can be verified by measuring the temperature at positions P1, P2, P3 and P4. The temperature at these positions TP1, TP2, TP3 and TP4 should not exceed the maximum temperatures in the table below. The number of measurement points may vary with different thermal design and topology. Temperatures above maximum TP1, measured at the reference point P1 are not allowed and may cause permanent damage. Besides the terminals, there are extra pads for production test located at the bottom side of the modules. (see Figure 1 Test Pads) Don’t place conductive trace, voids and other pads beneath the module to prevent unexpected short. Figure 1 Test pads Prepared (Subject resp) 5 (6) 3/1301-BMRTechnical 661 Specification 21 No. jidrguaa Rainbo Gu Approved (Document resp) Checked PNA series PoLGu Regulators jidrguaa Rainbo Diamond Input 9-36 V, Output up to 6 A / 33 WY • Resistors RUVH, RUVL and RSET should be placed as close as possible to their respective pins. • The capacitors CIN and COUT should be placed as close as possible to VIN and VOUT pins with low impedance connections. • Use large copper areas for power planes to minimize conduction loss and thermal stress. • Keep AGND and PGND separate from one another. The connection is made internally. • Use multiple via to connect the power planes to internal layers for improved thermal performance. • Only S+ pin is provided on device. If negative sense resistor is added from PGND to external S- terminal. The sensing connections should be routed as differential pair and preferably between ground planes. Avoid areas of high electric or magnetic fields. Connections Bottom view Pin INTERNAL USE ONLY PRODUCT SPECIFICATION Designation Function 1, 2, 3 VOUT Output voltage 4 S+ Possitive sense 5 EN/UVLO Remote control and input under voltage lockout threshold setting 6 VSET Ouput voltage setting 7 SS/TRK Soft start and output voltage tracking 8 PG Power good indicator 9 AGND Pin strap reference 10, 15, 16 PGND Power ground 11, 12, 13, 14 VIN Input voltage 17 SYNC Synchronizaiton input Date 4/21/2021 Rev 1/28701 - BMR661 Rev. A A © Flex April 2021 Technical Specification PNA series PoL Regulators Input 9-36 V, Output up to 6 A / 33 W 1/28701 - BMR661 Rev. A 22 April 2021 © Flex Mechanical Information - Surface Mount Version with Solder Bumps All component placements – whether shown as physical components or symbolical outline – are for reference only and are subject to change throughout the product’s life cycle, unless explicitly described and dimensioned in this drawing. INTERNAL USE ONLY PRODUCT SPECIFICATION MECHANICAL Prepared (Subject resp) Technical Specification No. jidjliaa Jessie LI PNA series PoL Regulators Approved (Document resp) Checked Input V, LI Output up to 6 A / 33 WSee §1 jidjliaa9-36 Jessie 5/1301-BMR661 Uen Date 1 (4) 1/28701 - BMR661 Rev. A 3/26/2021 Rev 23 April 2021 ©PA1 Flex Soldering Information - Surface Mounting Lead-free (Pb-free) solder processes The surface mount product is intended for forced convection or vapor phase reflow soldering in SnPb or Pb-free processes. For Pb-free solder processes, a pin temperature (TPIN) in excess of the solder melting temperature (TL, 217 to 221°C for SnAgCu solder alloys) for more than 60 seconds and a peak temperature of 245°C on all solder joints is recommended to ensure a reliable solder joint. The reflow profile should be optimised to avoid excessive heating of the product. It is recommended to have a sufficiently extended preheat time to ensure an even temperature across the host PWB and it is also recommended to minimize the time in reflow. A no-clean flux is recommended to avoid entrapment of cleaning fluids in cavities inside the product or between the product and the host board, since cleaning residues may affect long time reliability and isolation voltage. General reflow process specifications SnPb eutectic Pb-free Average ramp-up (TPRODUCT) 3°C/s max 3°C/s max Typical solder melting (liquidus) temperature TL Minimum reflow time above TL 183°C 221°C 60 s 60 s 210°C 235°C Peak product temperature TPRODUCT 225°C 260°C Average ramp-down (TPRODUCT) 6°C/s max 6°C/s max Maximum time 25°C to peak 6 minutes 8 minutes Temperature Pin profile Time in preheat / soak zone Time 25°C to peak Time in reflow For SnPb solder processes, the product is qualified for MSL 1 according to IPC/JEDEC standard J-STD-020C. Pb-free solder processes TPIN TL SnPb solder processes During reflow TPRODUCT must not exceed 225 °C at any time. Minimum pin temperature TPRODUCT maximum TPIN minimum Maximum Product Temperature Requirements Top of the product PWB near pin 17 is chosen as reference location for the maximum (peak) allowed product temperature (TPRODUCT) since this will likely be the warmest part of the product during the reflow process. Product profile Time Minimum Pin Temperature Recommendations Pin number 16 is chosen as reference location for the minimum pin temperature recommendation since this will likely be the coolest solder joint during the reflow process. For Pb-free solder processes, the product is qualified for MSL 3 according to IPC/JEDEC standard J-STD-020C. During reflow TPRODUCT must not exceed 260 °C at any time. Dry Pack Information Surface mount versions of the products are delivered in standard moisture barrier bags according to IPC/JEDEC standard J-STD-033 (Handling, packing, shipping and use of moisture/reflow sensitivity surface mount devices). Using products in high temperature Pb-free soldering processes requires dry pack storage and handling. In case the products have been stored in an uncontrolled environment and no longer can be considered dry, the modules must be baked according to J-STD-033. Thermocoupler Attachment Top of PWB near pin 17 for measurement of maximum product temperature, TPRODUCT SnPb solder processes For SnPb solder processes, a pin temperature (TPIN) in excess of the solder melting temperature, (TL, 183°C for Sn63Pb37) for more than 60 seconds and a peak temperature of 220°C is recommended to ensure a reliable solder joint. For dry packed products only: depending on the type of solder paste and flux system used on the host board, up to a recommended maximum temperature of 245°C could be used, if the products are kept in a controlled environment (dry pack handling and storage) prior to assembly. Pin 16 for measurement of minimum pin (solder joint) temperature, TPIN INTERNAL USE ONLY PRODUCT SPECIFICATION MECHANICAL Prepared (Subject resp) Technical Specification No. jidjliaa Jessie LI PNA series PoL Regulators Approved (Document resp) Checked Input V, LI Output up to 6 A / 33 WSee §1 jidjliaa9-36 Jessie 2 (4) 5/1301-BMR661 Uen 1/28701 - BMR661 Rev. A Date 3/26/2021 Rev 24 April 2021 ©PA1 Flex Surface Mount Assembly For double-sided assemblies, the solder joints on the topside of the board are inverted and reflowed again. During the second reflow, the module will be held in place by the surface tension, which may prevent the components from falling off under the gravitational force. According to our test, this module is capable for upside-down second reflow process. It also should be noted that different process configuration might have different performance for upside-down reflow, in that case, gluing might be required to secured the module from falling off. Delivery Package Information The products are delivered in antistatic carrier tape (EIA 481 standard). Carrier Tape Specifications Material Antistatic PS Surface resistance < 1011 Ohm/square Bakeability The tape is not bakable Tape width, W 24 mm [0.94 inch] Pocket pitch, P1 20 mm [0.79 inch] Pocket depth, K0 6.9 mm [0.27 inch] Reel diameter 330 mm [13 inch] Reel capacity 400 products /reel Reel weight 1.6 kg/full reel EIA standard carrier tape Side view User tape feed direction Top view Pocket depth, K0 Round holes Tape width, W Automatic pick and place equipment should be used to mount the product on the host board. The use of a vision system, utilizing the fiducials on the bottom side of the product, will ensure adequate accuracy. Manual mounting of products is not recommended. Pin 1 Pocket pitch, P1 Elongated holes INTERNAL USE ONLY PRODUCT SPECIFICATION MECHANICAL Prepared (Subject resp) No. jidjliaa Jessie LI PNA series PoL Regulators Approved (Document resp) Checked Input V, LI Output up to 6 A / 33 WSee §1 jidjliaa9-36 Jessie 3 (4) Technical Specification 5/1301-BMR661 Uen Date 3/26/2021 1/28701 - BMR661 Rev. A Rev 25 April 2021 ©PA1 Flex Product Qualification Specification Characteristics External visual inspection IPC-A-610 Change of temperature (Temperature cycling) IEC 60068-2-14 Na Temperature range Number of cycles Dwell/transfer time -40 to 100°C 1000 15 min/0-1 min Cold (in operation) IEC 60068-2-1 Ad Temperature TA Duration -45°C 72 h Damp heat IEC 60068-2-67 Cy Temperature Humidity Duration 85°C 85 % RH 1000 hours Dry heat IEC 60068-2-2 Bd Temperature Duration 125°C 1000 h Electrostatic discharge susceptibility IEC 61340-3-1, JESD 22-A114 IEC 61340-3-2, JESD 22-A115 Human body model (HBM) Machine Model (MM) Class 2, 2000 V Class 3, 200 V Immersion in cleaning solvents IEC 60068-2-45 XA, method 2 Water Glycol ether {Isopropyl alcohol} 55°C 35°C {35°C} Mechanical shock IEC 60068-2-27 Ea Peak acceleration Duration 100 g 6 ms Moisture reflow sensitivity 1 J-STD-020E Level 1 (SnPb-eutectic) Level 3 (Pb Free) 225°C 260°C Operational life test MIL-STD-202G, method 108A Duration 1000 h Robustness of terminations IEC 60068-2-21 Test Ua1 IEC 60068-2-21 Test Ue1 Through hole mount products Surface mount products All leads All leads Solderability IEC 60068-2-58 test Td 1 Preconditioning Temperature, SnPb Eutectic Temperature, Pb-free 150°C dry bake 16 h 215°C 235°C Vibration, broad band random IEC 60068-2-64 Fh, method 1 Frequency Spectral density Duration 10 to 500 Hz 0.07 g2/Hz 10 min in each direction Notes 1 Only for products intended for reflow soldering (surface mount products)
PNA2405S3S 价格&库存
很抱歉,暂时无法提供与“PNA2405S3S”相匹配的价格&库存,您可以联系我们找货
