MUS-0503.3
MUS-0503.3
    DIWELL
    SIP-4
    隔离模块 直流转换器 1 输出 3.3V 303mA 4.5V - 5.5V 输入
MUS-0503.3 数据手册
MU SERIES 1W UNREGULATED FEATURES            SINGLE IN LINE PACKAGE UP TO 1W UNREGULATED OUTPUT POWER 100% BURN IN HIGH EFFICIENCY INTERNAL SMD TECHNOLOGY LOW COST NO HEATSINK REQUIRED UL 94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE RoHS COMPLIANT 3 YEARS WARRANTY OUTPUT SPECIFICATIONS INPUT SPECIFICATIONS Voltage Set-point Accuracy +/-2% max Input Voltage Range +/-10% max ° Temperature Coefficient +/-0.05%/ C Input Filter 1 Ripple & Noise(20MHz BW) 100mVp-p max Input Reflected Ripple Current 2 Line Regulation 50mAp-p max +/-1.2% max Protection 3 +/-8% max 4 +/-12% max Load Regulation Load Regulation Minimum Load Capacitor Typ 10% of Full Load Short Circuit Protection Fuse Recommended GENERAL SPECIFICATIONS Momentary Efficiency 70%-82% 5 ENVIRONMENTAL SPECIFICATIONS Operating Temperature Humidity Cooling 1500-3000 VDC Isolation Resistance 10 ohms min 9 Isolation Capacitance 80pF max Switching Frequency 100KHz Typ 6 >2,000,000 Hours -25 °C to +71 °C Weight 1.3g Typ MTBF +90°C max Case Material Case Temperature Storage Temperature Isolation Voltage ° ° -55 C to +125 C Case Size 95% max Non-Conductive Plastic 11.7mm*6.0mm*10.2mm 11.7mm*7.5mm*10.1mm Free-Air Convection Conducted Emissions Radiated Emissions EN55022 Class A EN55022 Class B ° ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD AND 25 C UNLESS OTHERWISE NOTED. 1 2 3 4 5 6 Measured with 1uF ceramic capacitor connect to the output pins. Line Regulation is for a 1.0% change in input Voltage. Load Regulation is for output load current change from 20% to 100%. Load Regulation is for output load current change from 20% to 100% when input voltage is 3V and 3.3V. 1500VDC for 10 seconds,3000VDC for 3 seconds. MIL-HDBK-217F @25 °C , Ground Benign. DANUBE http://www.danube.com.tw 1 2010/12/01  SELECTION GUIDE(1) 1W 1500VDC ISOLATION MODEL NUMBER MUS-0303 INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) INPUT 7 CURRENT(mA) EFF ISOLATION FULL NO LOAD LOAD (%)8 (VDC) PACKAGE 3 3 333 475 35 70 1500 B MUS-03.303 3.3 3 333 425 43 71 1500 B MUS-03.303.3 3.3 3.3 303 403 43 75 1500 B 3 5 200 475 50 70 1500 B MUS-03.305 3.3 5 200 404 46 75 1500 B MUS-0503.3 5 3.3 303 282 32 71 1500 B MUS-0505 5 5 200 274 30 73 1500 A MUS-0509 5 9 110 260 27 77 1500 A MUS-0512 5 12 84 253 26 79 1500 A MUS-0515 5 15 67 253 28 79 1500 A MUS-0524 5 24 42 253 28 79 1500 B MUS-1203.3 12 3.3 300 112 11 74 1500 A MUS-1205 12 5 200 112 11 74 1500 A MUS-1209 12 9 110 105 11 79 1500 A MUS-1212 12 12 84 102 11 82 1500 A MUS-1215 12 15 67 102 12 82 1500 A MUS-2403.3 24 3.3 300 57 8 73 1500 B MUS-2405 24 5 200 57 8 73 1500 B MUS-2409 24 9 110 54 8 77 1500 B MUS-2412 24 12 84 54 8 77 1500 B MUS-2415 24 15 67 54 10 77 1500 B MUS-2424 24 24 42 54 10 77 1500 B MUS-4805 48 5 200 29 10 72 1500 B MUS-0305 Note: Other input to output voltages may be available. Please contact factory. 7 8 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 2 2010/12/01  SELECTION GUIDE(2) 1W 3000VDC ISOLATION INPUT MODEL OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT NUMBER (VDC) MUS-03.303.3-3K (VDC) (mA) INPUT 9 CURRENT(mA) EFF ISOLATION FULL NO LOAD LOAD (%)10 (VDC) PACKAGE 3.3 3.3 303 403 43 75 3000 B MUS-0505-3K 5 5 200 274 26 73 3000 B MUS-0509-3K 5 9 110 260 27 77 3000 B MUS-0512-3K 5 12 84 253 26 79 3000 B MUS-0515-3K 5 15 67 253 28 79 3000 B MUS-1203.3-3K 12 3.3 300 112 11 74 3000 B MUS-1205-3K 12 5 200 112 11 74 3000 B MUS-1209-3K 12 9 110 105 11 79 3000 B MUS-1212-3K 12 12 84 102 11 82 3000 B MUS-1215-3K 12 15 67 102 12 82 3000 B MUS-2403.3-3K 24 3.3 300 57 8 73 3000 B MUS-2405-3K 24 5 200 57 8 73 3000 B MUS-2409-3K 24 9 110 54 8 77 3000 B MUS-2412-3K 24 12 84 54 8 77 3000 B MUS-2415-3K 24 15 67 54 10 77 3000 B Note: Other input to output voltages may be available. Please contact factory.  MECHANICAL DIMENSIONS PACKAGE ”A” 11.7[0.46] FRONT VIEW PIN SINGLE 1 -Vin 2 +Vin 3 -Vout 4 +Vout 10.2[0.40] 3.81[0.15] 2.54[0.10] 6.0[0.24] 1 2 3 4 NOTE:Pin Size is Tolerance 0.50Φ ±0.05mm 1.2[0.05] All Dimensions In mm(Inches) BOTTOM VIEW Tolerance .X or .XX= ±0.5mm All dimensions are in mm[inches] 9 10 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 3 2010/12/01 PACKAGE ”B” 11.7[0.46] FRONT VIEW PIN SINGLE 1 -Vin 2 +Vin 3 -Vout 4 +Vout 10.1[0.40] 3.81[0.15] 2.54[0.10] 1 2 3 4 7.5[0.30] NOTE:Pin Size is Tolerance 0.50Φ ±0.05mm 1.2[0.05] All Dimensions In mm(Inches) Tolerance .X BOTTOM VIEW or .XX= ±0.5mm All dimensions are in mm[inches] TOP VIEW 2.54mm 2.54mm  RECOMMENDED FOOTPRINT DETAILS PACKAGE "A" PACKAGE "B" 2.54mm TOP VIEW 1 2 3 4 2.54mm 1 2 3 4  SIMPLIFIED SCHEMATIC  TYPICAL APPLICATIONS INPUT +Vin +Vout OUTPUT +Vin +Vout OSCILLATOR DRIVER -Vout -Vin DC-DC CONVERTER -Vin DANUBE LOAD -Vout http://www.danube.com.tw 4 2010/12/01  TYPICAL PERFORMANCE CURVES Specifications typical at ta=25 °C , nominal input voltage , rated output current unless otherwise specified. VOUT VS LOAD(5Vout Models) 4.2 6.4 3.9 6.0 Vout(V) Vout(V) VOUT VS LOAD(3.3Vout Models) 3.6 5.6 3.3 5.2 3.0 4.8 0 75 150 225 0 300 50 150 200 Output Current(mA) Output Current(mA) VOUT VS LOAD(9Vout Models) VOUT VS LOAD(12Vout Models) 10.4 13.5 10.0 13.0 Vout(V) Vout(V) 100 9.6 9.2 12.5 12.0 8.8 11.5 0 28 56 84 111 0 Output Current(mA) 20 40 60 80 Output Current(mA) VOUT VS LOAD(15Vout Models) EFFICIENCY VS LOAD EFFICIENCY(%) 16.5 Vout(V) 16.0 15.5 15.0 80.0 60.0 40.0 20.0 0.0 14.5 0 15 30 45 0 60 20 40 60 80 100 % OF RATED LOAD(%) Output Current(mA) OUTPUT POWER(%) DERATING CURVES 125% 100% 75% SAFE OPERATING AREA 50% 25% 0% -25 0 25 50 70 100 TA(degree C) DANUBE http://www.danube.com.tw 5 2010/12/01  INPUT FUSE SELECTION GUIDE 2.7-3.6V 4.5-5.5V 10.8-13.2V 21.6-26.4V 43.2-52.8V INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) 1200mA Slow-Blow Type 500mA Slow-Blow Type 300mA Slow-Blow Type 150mA Slow-Blow Type INPUT 100mA Slow-Blow Type OUTPUT Fuse +Vin +Vout DC-DC CONVERTER -Vin -Vout Note: Certain applications may require the installation of external fuse in front of the input. MU SERIES APPLICATION NOTES: EXTERNAL CAPACITANCE REQUIREMENTS: Output filtering is required for operation. A minimum of 10uF is needed. Output capacitance may be increased for additional filtering, not to exceed 220uF. To meet the reflected ripple requirements of the converter, an input impedance of less than 0.5 ohm from DC to 250KHz is required. We Can Offer EMC-Filter According To EN55011/22 Class B. Negative Outputs: A negative output voltage may be obtained by connecting the +OUT to circuit ground and connecting –OUT as the negative output. FOR MORE INFORMATION CALL: Danube Enterprise Co., Ltd. Tel: 886-7-3755165 Fax: 886-7-3755330 Home Page http://www.danube.com.tw DANUBE E-mail: danube@ms10.hinet.net http://www.danube.com.tw 6 2010/12/01
MUS-0503.3 价格&库存
很抱歉,暂时无法提供与“MUS-0503.3”相匹配的价格&库存,您可以联系我们找货
