AUS-03.303.3-0.1W
AUS-03.303.3-0.1W
    DIWELL
    DIP4 模块
    隔离模块 直流转换器 1 输出 3.3V 30mA 2.97V - 3.63V 输入
AUS-03.303.3-0.1W 数据手册
AUS-0.1W SERIES 0.1W UNREGULATED FEATURES          DUAL IN LINE PACKAGE 100% BURN IN INTERNAL SMD TECHNOLOGY LOW COST UL 94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE MTBF>1,000,000 HOURS RoHS COMPLIANT 3 YEARS WARRANTY OUTPUT SPECIFICATIONS INPUT SPECIFICATIONS Voltage Set-point Accuracy +/-2% max. Input Voltage Range Temperature Coefficient +/-0.05%/°C Input Filter Capacitor Type Protection Fuse Recommended Ripple & Noise(20MHz BW)1 Line Regulation2 Load Regulation3 Minimum Load Short Circuit Protection 100mVp-p max. +/-10% max. +/-1.5% max. +/-12% max. GENERAL SPECIFICATIONS 10% of Full Load Efficiency Momentary Isolation 50% typ. Voltage4 1500 VDC min. 9 Isolation Resistance 10 ohms min. Isolation Capacitance 80pF max. ENVIRONMENTAL SPECIFICATIONS Switching Frequency 100KHz typ. Operating Temperature MTBF5 >1,000,000 Hours +100°C max. Weight 1.5g typ. Case Temperature Storage Temperature -40 °C to +85 °C -55 °C to +125 °C Case Material Humidity 95% max. Case Size Cooling Free-Air Convection Radiated Emissions Non-Conductive Plastic 9.40mm*8.80mm*6.35mm EN55022 Class B ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD AND 25 °C UNLESS OTHERWISE NOTED. 1 2 3 4 5 Measured with 1uF ceramic capacitor connect to the output pins. Line Regulation is for a 1.0% change in input Voltage. Load Regulation is for output load current change from 20% to 100%. 1500VDC for 10 seconds. MIL-HDBK-217F @25 °C , Ground Benign. DANUBE http://www.danube.com.tw 1 2019/12/24  SELECTION GUIDE INPUT6 INPUT MODEL NUMBER OUTPUT OUTPUT CURRENT(mA) VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) FULL NO LOAD LOAD EFF (%)7 ISOLATION (VDC) AUS-03.303.3-0.1W 3.3 3.3 30 61 20 50 1500 AUS-03.305-0.1W 3.3 5 20 61 20 50 1500 AUS-0503.3-0.1W 5 3.3 30 41 20 50 1500 AUS-0505-0.1W 5 5 20 41 20 50 1500 AUS-1203.3-0.1W 12 3.3 30 17 9 50 1500 AUS-1205-0.1W 12 5 20 17 9 50 1500 8  PARTNUMBES STRUCTURE Model Name Difference AUv-x1x2 A=Series Name U=Unregulated v=Type of output voltage (S=single output) x1=input voltage(03.3;05;12;24) x2=Output voltage(03.3;05;09;12;15)  MECHANICAL DIMENSIONS & RECOMMENDED FOOTPRINT DETAILS PIN SINGLE 1 -Vin 3 +Vin 4 +Vout 5 -Vout NOTE : All dimensions are in mm [inches] 1. Pin Size is 0.50x0.30mm[0.02x0.01”] 2. Pin is Tolerance .XX= ±0.05mm 3. Tolerance .X 6 7 8 or .XX= ±0.5mm NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. 1500VDC for 10 seconds. DANUBE http://www.danube.com.tw 2 2019/12/24 DANUBE http://www.danube.com.tw 3 2019/12/24  TYPICAL APPLICATIONS SINGLE OUTPUT INPUT OUTPUT +Vin +Vout DC-DC CONVERTER -Vin LOAD -Vout  SIMPLIFIED SCHEMATIC SINGLE OUTPUT +Vin +Vout OSCILLATOR DRIVER -Vout -Vin  TYPICAL PERFORMANCE CURVES DERATING CURVE DANUBE http://www.danube.com.tw 4 2019/12/24  INPUT FUSE SELECTION GUIDE 2.97V-3.63V 4.5V-5.5V INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) 200mA Slow-Blow Type 150mA Slow-Blow Type INPUT OUTPUT +Vin +Vout Fuse DC-DC CONVERTER -Vin -Vout Note: Certain applications may require the installation of external fuse in front of the input. AUS-0.1W SERIES APPLICATION NOTES: EXTERNAL CAPACITANCE REQUIREMENTS: Output filtering is required for operation. A minimum of 10uF is needed. Output capacitance may be increased for additional filtering, not to exceed 220uF. To meet the reflected ripple requirements of the converter, an input impedance of less than 0.5 ohm from DC to 250KHz is required. We Can Offer EMC-Filter According To EN55011/22 Class B. Negative Outputs: A negative output voltage may be obtained by connecting the +OUT to circuit ground and connecting –OUT as the negative output. FOR MORE INFORMATION CALL: Danube Enterprise Co., Ltd. Tel: 886-7-3755165 Fax: 886-7-3755330 Home Page http://www.danube.com.tw DANUBE E-mail: danube@ms10.hinet.net http://www.danube.com.tw 5 2019/12/24
AUS-03.303.3-0.1W 价格&库存
很抱歉,暂时无法提供与“AUS-03.303.3-0.1W”相匹配的价格&库存,您可以联系我们找货
