FEWS-2405A20T
FEWS-2405A20T
    DIWELL
    DIP6 模块
    隔离模块 直流转换器 1 输出 5V 4A 18V - 75V 输入
FEWS-2405A20T 数据手册
FEW SERIES 20~30W WIDE INPUT RANGE FEATURES          20~30W DIL PACKAGE INDUSTRY STANDARD PACKAGE 9-18V,18-36V,36-75V,9-36V,18-75V WIDE INPUT RANGE REGULATED OUTPUT INPUT UVLO & OVLO HIGH EFFICIENCY UL 94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE 3 YEARS WARRANTY OUTPUT SPECIFICATIONS INPUT SPECIFICATIONS Voltage Set-point Accuracy +/-2% max. Input Voltage Range Temperature Coefficient +/-0.05%/°C Input Filter Pi Network 150mVp-p max. Protection Fuse Recommended Ripple & Noise(20MHz BW)1 2:1 or 4:1 Input Range Line Regulation2 +/-0.3% max. OVLO(Over Voltage Lockout) See Page 6 Load Regulation3 +/-0.5% max. UVLO(Under Voltage Lockout) See Page 6 Minimum Load 4 10% of Full Load OVLO & UVLO Circuit Restart Short Circuit Protection Continuous Short Circuit Restart Automatic GENERAL SPECIFICATIONS Automatic Efficiency Over Load Protection 130%~180% Isolation Voltage5 Transient Response6 500uS max. Isolation Resistance External Trim Adj. Range Vout:5V External Trim Adj. Range Vout:12V,15V 88% typ. 1500VDC min. 9 10 ohms min. +/-10% Isolation Capacitance 3000pF max. -20%~+10% Switching Frequency 300 KHz typ. ENVIRONMENTAL SPECIFICATIONS 7 >300,000 Hours Operating Temperature (20W) -40°C to +75°C Weight 31.2g typ. Operating Temperature (30W) -40°C to +55°C Case Material Case Temperature Storage Temperature Humidity Cooling MTBF +100°C max. Case Size Six-Side Shielded Case 50.8mm*25.4mm*11.2mm -55°C to +125°C Radiated Emissions EN55022 Class A 95% max. Free-Air Convection ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD, AND 25 °C UNLESS OTHERWISE NOTED. 1 2 3 4 5 6 7 Measured with 1uF ceramic capacitor connect to the output pins. High Line to Low Line. Load Regulation is for output load current change from 10% to 100%. FEWS-XXXXA20T Minimum load 20% of full load. For 10 seconds. 25% Step Load Change. MIL-HDBK-217F @25°C, Ground Benign. DANUBE http://www.danube.com.tw 1 2016/09/20  SELECTION GUIDE 2:1 20W OUTPUT INPUT8 MODEL NUMBER INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) CAPACITOR CURRENT(mA) EFF FULL 9 NO (%) LOAD PACKAGE (Max) LOAD LOAD FEWS-1203.3A20 9-18 3.3 5000 1617 65 85 1000uF FEWS-1205A20 9-18 5 4000 1893 65 88 1000uF FEWS-1212A20 9-18 12 1666 1893 20 88 220uF FEWS-1215A20 9-18 15 1333 1872 20 89 100uF FEWD-1212A20 9-18 +/-12 +/-833 1893 20 88 +/-100uF FEWD-1215A20 9-18 +/-15 +/-667 1872 20 89 +/-47uF FEWS-2403.3A20 18-36 3.3 5000 809 45 85 1000uF FEWS-2405A20 18-36 5 4000 947 45 88 1000uF FEWS-2412A20 18-36 12 1666 936 20 89 220uF FEWS-2415A20 18-36 15 1333 926 20 90 100uF FEWD-2412A20 18-36 +/-12 +/-833 936 20 89 +/-100uF FEWD-2415A20 18-36 +/-15 +/-667 926 20 89 +/-47uF FEWS-4803.3A20 36-75 3.3 5000 404 40 85 1000uF FEWS-4805A20 36-75 5 4000 473 40 88 1000uF FEWS-4812A20 36-75 12 1666 473 10 88 220uF FEWS-4815A20 36-75 15 1333 468 10 89 100uF FEWD-4812A20 36-75 +/-12 +/-833 473 10 88 +/-100uF FEWD-4815A20 36-75 +/-15 +/-667 473 10 88 +/-47uF A Note: Other input to output voltages may be available. Please contact factory. 8 9 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 2 2016/09/20  SELECTION GUIDE 4:1 20W OUTPUT INPUT10 INPUT OUTPUT OUTPUT MODEL NUMBER VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) CAPACITOR CURRENT EFF (mA) FULL (%)11 NO LOAD PACKAGE (Max) LOAD LOAD FEWS-1203.3A20T 9-36 3.3 5000 1617 80 85 1000uF FEWS-1205A20T 9-36 5 4000 1915 80 87 1000uF FEWS-1212A20T 9-36 12 1666 1914 20 87 220uF FEWS-1215A20T 9-36 15 1333 1915 20 87 100uF FEWS-2403.3A20T 18-75 3.3 5000 808 60 85 1000uF FEWS-2405A20T 18-75 5 4000 957 60 87 1000uF FEWS-2412A20T 18-75 12 1666 957 20 87 220uF FEWS-2415A20T 18-75 15 1333 957 20 87 100uF A Note: Other input to output voltages may be available. Please contact factory. 10 11 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 3 2016/09/20  SELECTION GUIDE 2:1 30W OUTPUT INPUT12 MODEL NUMBER INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) CAPACITOR CURRENT(mA) EFF FULL 13 NO (%) LOAD PACKAGE (Max) LOAD LOAD FEWS-1203.3B30 9-18 3.3 7000 2292 180 85 1000uF FEWS-1205B30 9-18 5 6000 2841 165 88 1000uF FEWS-1212B30 9-18 12 2500 2793 140 89.5 220uF FEWS-1215B30 9-18 15 2000 2793 120 89.5 100uF FEWS-2403.3B30 18-36 3.3 7000 1119 120 86 1000uF FEWS-2405B30 18-36 5 6000 1412 95 88.5 1000uF FEWS-2412B30 18-36 12 2500 1404 40 89 220uF FEWS-2415B30 18-36 15 2000 1389 40 90 100uF FEWS-4803.3B30 36-75 3.3 7000 566 85 85 1000uF FEWS-4805B30 36-75 5 6000 710 60 88 1000uF FEWS-4812B30 36-75 12 2500 702 55 89 220uF FEWS-4815B30 36-75 15 2000 694 30 90 100uF B Note: Other input to output voltages may be available. Please contact factory. 12 13 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 4 2016/09/20  PART NUMBERS STRUCTURE Model Name Difference FEWv-x1x2x3x4T-zzz FE=Series Name W=Wide Input Range v=Type of output voltage (S=Single output;D=Dual output) x1=12V (9~18V;9~36V Input voltage) 24V (18~36V;18~75V Input voltage) 48V (36~75V Input voltage) x2=Output voltage(3.3V;5V;12V;15V) x3=Package(A;B) x4=Power(20W;30W) T= 4:1 Input voltage zzz= 0~9,A~Z or blank for market purpose.  MECHANICAL DIMENSIONS PACKAGE "A" PIN SINGLE DUAL 1 +Vin +Vin 2 -Vin -Vin 3 +Vout +Vout 4 Trim Common 5 -Vout -Vout 6 Remote On/Off Remote On/Off NOTE: All dimensions are in millimeters [inches] Pin Size is Tolerance 1.0Φ ±0.10mm Tolerance .X or .XX= ±0.80mm PACKAGE "B" 50.8[2.00] SIDE VIEW PIN SINGLE 1 +Vin 2 -Vin 3 Remote On/Off 4 +Vout 5 -Vout 6 Trim 11.20[0.44] 5.8[0.23] 1 2 4 BOTTOM VIEW 3 5 10.16[0.4] 20.32[0.8] 25.4[1.0] 5.08[0.2] 15.24[0.6] 45.72[1.8] 6 NOTE: All dimensions are in millimeters [inches] 50.8[2.00] Pin Size is Tolerance 1.0Φ ±0.10mm Al l di me ns ions are i n m ill im ete rs [inc he s] DANUBE Tolerance .X or .XX= ±0.80mm http://www.danube.com.tw 5 2016/09/20  RECOMMENDED FOOTPRINT DETAILS PACKAGE "A" PACKAGE "B" GRID:2.54 mm GRID:2.54 mm TOP VIEW TOP VIEW 6 6 5 3 2 4 5 1 2 1 . 2Φ+0.2/-0 1 . 2Φ+0.2/-0 1 3 4 Remote On/Off Control Control Input Package A:PIN6 Package B:PIN3 Control Common Control Voltage ON PIN2 Converter Shutdown Idle Current >+2.5VDC or Open Circuit CMOS or Open Logic Compatibility OFF 10mA Collector TTL
FEWS-2405A20T 价格&库存
很抱歉,暂时无法提供与“FEWS-2405A20T”相匹配的价格&库存,您可以联系我们找货
