PDWS-4805
PDWS-4805
    DIWELL
    SIP6 模块
    隔离模块 直流转换器 1 输出 5V 1.6A 36V - 75V 输入
PDWS-4805 数据手册
PDW SERIES 9W WIDE INPUT RANGE FEATURES             LEAD FREE 1500VDC ISOLATION SINGLE IN LINE PACKAGE UP TO 9W REGULATED OUTPUT POWER NO EXTERNAL COMPONENTS REQUIRED INTERNAL FILTERING 100% BURN IN HIGH EFFICIENCY UL 94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE ROHS COMPLIANT 3 YEARS WARRANTY OUTPUT SPECIFICATIONS INPUT SPECIFICATIONS Voltage Set-point Accuracy +/-2% max. Input Voltage Range Temperature Coefficient +/-0.05%/°C Input Filter Capacitor Type 150mVp-p max. Protection Fuse Recommended 1 Ripple & Noise(20MHz BW) Line Regulation2 2:1 Input Range +/-0.5% max. Start up Time(Nominal Input) 3 Load Regulation 10mS max. +/-0.5% max. Remote ON/OFF Control Minimum Load Table 1 10% of Full Load Short Circuit Protection Continuous Short Circuit Restart Automatic Over Load Protection GENERAL SPECIFICATIONS 150% typ. Efficiency Transient Response4 85% min. 500uS max. Isolation Voltage5 1500VDC min. 9 Isolation Resistance 10 ohms min. Isolation Capacitance ENVIRONMENTAL SPECIFICATIONS Operating Temperature 80pF max. Switching Frequency 400 KHz typ. -40°C to 55°C MTBF6 Output=12V&15V -40°C to 60°C Weight Output=5V Case Temperature Storage Temperature Humidity Cooling +110°C max. Case Material -55°C to +125°C Case Size >270,000 Hours 5.0g typ. Non-Conductive Plastic 24.0mm*9.6mm*11.2mm 95% max. Potting Material Free-Air Convection Radiated Emissions Epoxy(UL94V-0) EN55032 Class A (with external filter) ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD AND 25 OC UNLESS OTHERWISE NOTED. 1 2 3 4 5 6 Measured with 1uF ceramic capacitor connects to the output pins. High Line to Low Line. Load Regulation is for output load current change from 10% to 100%. 25% Step Load Change. 1500VDC for 10 seconds. MIL-HDBK-217F @25°C , Ground Benign. DANUBE http://www.danube.com.tw 1 2017/11/02  SELECTION GUIDE 2:1 8-9W OUTPUT Specifications typical at ta=25°C,nominal input voltage , rated output current unless otherwise specified. INPUT7 INPUT OUTPUT OUTPUT CURRENT(mA) EFF FULL NO (%)8 (VDC) Load Max LOAD LOAD MODEL NUMBER VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) ISOLATION9 Capacitive PDWS-1205 9-18 5 1600 784 80 85 1500 1000uF PDWS-1212 9-18 12 750 852 80 88 1500 220uF PDWS-1215 9-18 15 600 852 80 88 1500 100uF PDWS-2405 18-36 5 1600 392 40 85 1500 1000uF PDWS-2412 18-36 12 750 426 40 88 1500 220uF PDWS-2415 18-36 15 600 421 40 89 1500 100uF PDWS-4805 36-75 5 1600 196 20 85 1500 1000uF PDWS-4812 36-75 12 750 213 20 88 1500 220uF PDWS-4815 36-75 15 600 211 20 89 1500 100uF Note: Other input to output voltages may be available. Please contact factory. 7 8 9 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. 1500VDC for 10 seconds. DANUBE http://www.danube.com.tw 2 2017/11/02  MECHANICAL DIMENSIONS & RECOMMENDED FOOTPRINT DETAILS PIN SINGLE 1 -Vin 2 +Vin 3 Remote On/Off 6 +Vout 7 -Vout 8 NC NOTE : All dimensions are in mm[inches] 1. Pin Size is 0.50x0.30mm[0.02x0.01”] 2. Pin is Tolerance .XX= ±0.05mm 3. Tolerance .X or .XX= ±0.5mm  Table1 (Remote On/Off Control) Remote On/Off Control Control Input PIN3 Control Common Control Voltage ON Converter Shutdown Idle Current >+2.5VDC or Open Circuit
PDWS-4805 价格&库存
很抱歉,暂时无法提供与“PDWS-4805”相匹配的价格&库存,您可以联系我们找货
