KAWD-2415EL
KAWD-2415EL
    DIWELL
    DIP6 模块
    隔离模块 直流转换器 2 输出 15V -15V 1A,1A 18V - 36V 输入
KAWD-2415EL 数据手册
KAW-EL SERIES 30W WIDE INPUT RANGE FEATURES         30W DIL PACKAGE INDUSTRY STANDARD PACKAGE 9-18V,18-36V,36-72V, 9-36V ,18-72V WIDE INPUT RANGE 100% BURN-IN HIGH EFFICIENCY UL 94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE RoHS COMPLIANT OUTPUT SPECIFICATIONS INPUT SPECIFICATIONS Voltage Set-point Accuracy Input Voltage Range 2:1 or 4:1 Input Range Single Output +/-2% max. Input Filter Pi Network Dual Output +/-2% max. Protection Fuse Recommended 6800uF max. Capacitive load Over Voltage Protection Built-in Efficiency 78% min. +/-0.05/°C Isolation Voltage1 Temperature Coefficient Ripple & Noise(20MHz BW) GENERAL SPECIFICATIONS 2 Line Regulation3 Single Dual 1500 VDC min. 9 150mVp-p max. Isolation Resistance 10 ohms min. Isolation Capacitance 2500pF max. +/-0.5% max. Switching Frequency 250KHz min. 4 >400,000 Hours Weight 90g typ. +/-0.5% max. MTBF Load Regulation5 Single +/-0.5% max. Case Material Six-Side Shielded Case Dual +/-0.5% max. 50.8mm*50.8mm*11mm Minimum load Short Circuit Protection Short Circuit Restart 10% of Full Load Potting Material Continuous Radiated Emissions Automatic Epoxy(UL 94V-0) EN55022 Class A ENVIRONMENTAL SPECIFICATIONS Over Load Protection 150% typ. Case Temperature -40°C to +71°C +90°C max. Transient Response6 500uS max. Storage Temperature -50°C to +100°C External Trim Adj. Range +/-10% Operating Temperature Humidity Cooling 95% max. Free-Air Convection ° ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD, AND 25 C UNLESS OTHERWISE NOTED. 1 2 3 4 5 6 For 10 seconds. Measured with 1uF ceramic capacitor connect to the output pins. High Line to Low Line. MIL-HDBK-217F @25 °C, Ground Benign. Load Regulation is for output load current change from 50% to 100%. 50% Step Load Change. DANUBE http://www.danube.com.tw 1 2016/08/24  SELECTION GUIDE(1) 2:1 25W-30W OUTPUT MODEL NUMBER INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) INPUT7 CURRENT(mA) EFF ISOLATION FULL NO (%)8 (VDC) LOAD LOAD KAWS-1205EL 9-18 5 6000 3125 40 80 1500 KAWS-1209EL 9-18 9 3333 3125 40 80 1500 KAWS-1212EL 9-18 12 2500 3125 40 80 1500 KAWS-1215EL 9-18 15 2000 3125 40 80 1500 KAWS-1224EL 9-18 24 1250 3125 40 80 1500 KAWD-1205EL 9-18 +/-5 +/-2500 2604 40 80 1500 KAWD-1212EL 9-18 +/-12 +/-1250 3125 40 80 1500 KAWD-1215EL 9-18 +/-15 +/-1000 3125 40 80 1500 KAWS-2403.3EL 18-36 3.3 6000 1052 20 78 1500 KAWS-2405EL 18-36 5 6000 1453 20 86 1500 KAWS-2409EL 18-36 9 3333 1560 20 80 1500 KAWS-2412EL 18-36 12 2500 1560 20 80 1500 KAWS-2415EL 18-36 15 2000 1560 20 80 1500 KAWS-2424EL 18-36 24 1250 1560 20 80 1500 KAWD-2405EL 18-36 +/-5 +/-2500 1302 20 80 1500 KAWD-2412EL 18-36 +/-12 +/-1250 1560 20 80 1500 KAWD-2415EL 18-36 +/-15 +/-1000 1560 20 80 1500 KAWS-4803.3EL 36-72 3.3 6000 529 20 78 1500 KAWS-4805EL 36-72 5 6000 781 10 80 1500 KAWS-4809EL 36-72 9 3333 781 10 80 1500 KAWS-4812EL 36-72 12 2500 781 10 80 1500 KAWS-4815EL 36-72 15 2000 781 10 80 1500 KAWS-4824EL 36-72 24 1250 781 10 80 1500 KAWD-4805EL 36-72 +/-5 +/-2500 651 10 80 1500 KAWD-4812EL 36-72 +/-12 +/-1250 781 10 80 1500 KAWD-4815EL 36-72 +/-15 +/-1000 781 10 80 1500 Note: Other input to output voltages may be available. Please contact factory. 7 8 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 2 2016/08/24  SELECTION GUIDE(2) 4:1 25W-30W OUTPUT MODEL NUMBER INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) INPUT9 CURRENT(mA) EFF ISOLATION FULL NO (%)10 (VDC) LOAD LOAD KAWS-1205TEL 9-36 5 6000 3125 30 80 1500 KAWS-1209TEL 9-36 9 3333 3125 30 80 1500 KAWS-1212TEL 9-36 12 2500 2976 30 84 1500 KAWS-2405TEL 18-72 5 6000 1488 20 84 1500 KAWS-2409TEL 18-72 9 3333 1560 20 80 1500 KAWS-2412TEL 18-72 12 2500 1560 20 80 1500 KAWS-2415TEL 18-72 15 2000 1560 20 80 1500 KAWS-2424TEL 18-72 24 1250 1560 20 80 1500 Note: Other input to output voltages may be available. Please contact factory. 9 10 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 3 2016/08/24  SIMPLIFIED SCHEMATIC SINGLE OUTPUT DUAL OUTPUT +Vin +Vout +Vin +Vout Common -Vout -Vout -Vin -Vin PWM CONTROLLER REFERENCE & ERROR AMP ISOLATION PWM CONTROLLER ISOLATION REFERENCE & ERROR AMP  MECHANICAL DIMENSIONS 30.48[1.20] 11[0.43] 5 6 7 8 BOTTOM VIEW 50.8[2.00] 45.72[1.80] SIDE VIEW 4 3 2 1 22.9[0.90] 15.24[0.60] 2.54[0.10] 5.8[0.23] 50.8[2.00] PIN SINGLE DUAL 1 Remote On/Off 2 NO PIN 3 -Vin -Vin 4 +Vin +Vin 5 NO PIN +Vout 6 +Vout Common 7 -Vout -Vout 8 TRIM NO PIN All dimensions are in millimeters[inches] Remote On/Off Control Control Input PIN1 Control Common Control Voltage ON Converter Shutdown Idle Current >+2.5VDC or Open Circuit 10mA CMOS or Open Logic Compatibility OFF PIN3
KAWD-2415EL 价格&库存
很抱歉,暂时无法提供与“KAWD-2415EL”相匹配的价格&库存,您可以联系我们找货
