RAHHD19SFTR
RAHHD19SFTR
    SWITCHCRAFT
    HDMI连接器 19Pin
RAHHD19SFTR 数据手册
FEED DIRECTION DATE CODE 0.354 9.00 0.004 4X 0.059+-0.000 +0.10 1.50 0.00 YYMMDD 18X 0.020 0.50 4X 0.035 0.90 POS 19 POS 1 0.102 2.60 0.081 2.06 2X 0.098 2.50 0.004 2X 0.122+-0.000 0.551±0.002 14.00±0.05 +0.10 3.10 0.00 FRONT OF PART 0.425 10.80 0.354 9.00 TAPE LAYOUT 0.065±0.008 1.65±0.20 0.295 7.50 0.004 2X 0.091+-0.000 0.478±0.008 12.14±0.20 +0.10 2.30 0.00 0.235 5.96 19X 0.011±0.001 0.28±0.03 2X 0.067 1.70 2X THROUGH HOLE SOLDER PADS 0.571 14.50 POS 19 POS 1 0.179±0.002 4.55±0.05 2X 0.020±0.002 0.50±0.05 PCB EDGE RECOMMENDED PCB LAYOUT COMPONENT SIDE M3 X 0.5 THREAD POS 18 0.376 9.55 0.3927 9.975 0.134 3.40 0.315 8.00 0.571±0.008 14.50±0.20 0.084 2.13 POS 2 0.632 16.05 UNSPECIFIED TOLERANCES 0.002 [0.05] 0.283 7.20 0.243 6.18 0.002 0.004+-0.006 0.219 5.55 +0.05 0.10 - 0.15 0.057 1.45 2X 0.079±0.004 2.00±0.10 2X 0.047±0.004 1.20±0.10 0.181 4.60 0.235 5.96 NOTES: A 1. PARTS SUPPLIED ON TAPE AND REEL. REEL SIZE 15.0 [380] PLASTIC, 150 PARTS PER REEL TAPE CONFROMS TO ANSI/EIA-481 2. MATERIALS: HOUSING - BLACK LCP SHELL - BRASS, NICKEL PLATED CONTACTS - BRASS, GOLD FLASH IN CONTACT AREA, TIN IN SOLDER AREA 3. ELECTRICAL CHARACTERSTICS: CURRENT RATING - 0.5 AMP VOLTAGE RATING - 40V 4. MECHANICAL CHARACTERISTICS: INSERTION FORCE - 4.5Kgf MAX WITHDRAWAL FORCE - 1.0~1.4 Kgf (INITIAL) LIFE TEST - 5,000 CYCLES OPERATING TEMPERATURE -25 C TO +85 C 5. THIS PRODUCT IS RoHS COMPLIANT. CUSTOMER DRAWING THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED 0.04±0.01 1.0±0.2 1. ALL DIMENSIONS IN INCHES [mm] 0.020 0.50 TYP 0.354±0.002 9.00±0.05 19X 0.008±0.002 0.20±0.05 A REV 28330 ECO NUMBER 12/8/20 DATE REVISIONS PC BY SIZE MULT FINISH - TWO PLACE DECIMALS 0.02 [0.5] - THREE PLACE DECIMALS 0.005 [0.13] DATE DRAWN BY 8/4/20 FM DO NOT SCALE DRAWING SolidWorks CAD File NAME TEMPER SPEC No. SCALE CHKD FM 8/4/20 4:1 APVD TJK 8/27/20 HDMI TYPE A, RIGHT ANGLE FEMALE SMT, W/SCREW FLANGE, RoHS B LBS/M MATERIAL SPEC No. FIRST USED ON TJK APVD WIDTH SHEET PART No. 1 OF RAHHD19SFTR 1 REV A
RAHHD19SFTR 价格&库存
很抱歉,暂时无法提供与“RAHHD19SFTR”相匹配的价格&库存,您可以联系我们找货
RAHHD19SFTR
    • 1+11.89080
    • 150+4.75200
    • 450+4.59000
    • 1050+4.51440
    RAHHD19SFTR
    • 1+17.923571+2.31832
    库存:457
    RAHHD19SFTR
    • 150+12.29549150+1.59036
    • 300+11.70847300+1.51443
    • 450+11.37819450+1.47171
    库存:457
