汽车用接插件
CONTENTS
unsealed / Connector
sealed
Series
非防水/防水 接插件系列
Terminal
Tab Size
端子大小
0.64
(025)
1.5
(060)
2.3
(090)
4.8
(187)
8.0
(312)
TS
0.64+1.5
No. of Way
Variation
极数种类
2, 5, 10, 14, 16, 19, ,22,
24, 28, 32, 36, ,40
0.13 - 0.5
A-02
2, 4, 8, 12
0.13 - 2.0
A-07
2, 6, 8, 9, 10, 11, 12, 13,
16, 20
0.22 - 2.0
A-10
1, 2, 3, 4, 6, 8, 10
0.3 - 3.0
A-14
1, 2, 3, 4
0.5 - 8.0
A-18
12, 18, 20
A-20
0.64+2.3
17, 18, 20
A-21
0.64+4.8
A-22
14, 15, 20
A-22
16, 33, 36, 56, 60, 68
A-24
A-26
2, 3, 4, 6, 7, 10, 12, 16,
20, 24, 34
0.22 - 0.75
C-02
2, 5, 6, 8, 13, 17, 21
0.22 - 0.85
C-06
2, 3, 4, 5, 6, 8, 10, 14,
16, 20
0.3 - 2.0
C-09
2, 4, 5
0.3 - 3.0
C-12
2.0 - 10.0
C-14
12, 13, 18, 20, 23, 28
C-16
1.0+2.3
9, 10, 14, 23
C-18
1.0+4.8
12, 14
C-19
2.3+4.8
8, 14, 16, 18, 20
C-20
4.8+8.0
6
C-21
1.0
13
C-22
1.0+2.3
23
C-22
1.0+4.8
14
C-23
2.3
6
C-23
0.22 - 0.75
F-02
Hybrid
2.3+4.8
0.64
PCB
0.64+1.5
0.64
(025)
1.0
(040)
2.3
(090)
4.8
(187)
9.5
(375)
1, 2
0.64+2.3
unsealed
HE
Hybrid
PCB
NH
0.64
(025)
Hybrid
Hybrid
DL
0.64+2.3
1.5
(060)
2.3
(090)
2.8
(110)
SL
Applicable Page
Cable Size
适用电线大小 刊登页
1.5+2.8
0.64
(025)
1.0
(040)
2.3
(090)
3, 4, 8, 10, 12, 16, 24, 32,
40
F-07
4, 12, 14, 16
0.3 - 2.0
I-02
2, 4, 6, 12, 14, 16, 18
0.3 - 2.0
I-05
4
0.3 - 3.0
I-08
14
I-10
2
0.22 - 0.75
K-02
0.3 - 1.25
K-04
0.3 - 2.0
K-07
2, 4, 6, 10, 14, 16
Contact Resistance
接触电阻(包括压接部)
Leak
Current
漏电流
Insulation
Resistance
绝缘电阻
Seal
密封性
8mΩ max.(initial)
16mΩ max.(after durability tests)
3mΩ max.(initial)
10mΩ max.(after durability tests)
3mA max.
100MΩ min.
8mΩ max.(initial)
3mΩ max.(initial)
8mΩ max.(initial)
8mΩ max.(initial)
Material
材质
接插件护套
端子
Housing / PBT
Terminal / Brass, Heat-Resistant Copper Alloy
接插件护套
端子
Housing / PBT, PA6T
接插件护套
端子
Housing / PBT
接插件护套
端子
接插件护套
端子
Housing / PBT, SPS
Terminal / Brass
Housing / LCP
Terminal / Brass
接插件护套
端子
Housing / PBT
接插件护套
端子
Housing / PBTG30
Terminal / Brass
接插件护套
端子
Housing / PBT
接插件护套
端子
接插件护套
端子
Housing / PBT
Terminal / Heat-Resistant Copper Alloy
Housing / PBT
接插件护套
端子
Housing / PBT
接插件护套
端子
Housing / PBT
5mΩ max.(initial)
3mΩ max.(initial)
2mΩ max.(initial)
4mΩ max.(after durability tests)
5mΩ max.(initial)
1mA max.
100MΩ min.
3mΩ max.(initial)
5mΩ max.(initial)
3mΩ max.(initial)
10mΩ max.(initial)
30mΩ max.(after durability tests)
3mΩ max.(initial)
1mA max.
3mA max.
100MΩ min.
100MΩ min.
5mΩ max.(initial)
3mΩ max.(initial)
3mA max.
100MΩ min.
sealed
Series
非防水/防水 接插件系列
Terminal
Tab Size
端子大小
0.64
(025)
0.64W
(025W)
No. of Way
Variation
极数种类
2, 3, 4, 5, 6, 8, 10, 12,
13, 15, 17, 20, 30
4
Hybrid 0.64W+2.3+4.8 38, 46
TS
sealed
sealed
HX
sealed
Hybrid
B-02
0.3 - 0.6
B-08
B-10
2, 3, 4, 5, 6, 7
0.3 - 2.0
B-12
4.8
(187)
1, 2, 3
0.3 - 3.0
B-19
8.0
(312)
1, 2
0.5 - 8.0
B-23
0.64+2.3
10, 13, 26
B-26
0.64+4.8
4, 24, 34, 40, 46
B-27
B-28
2.3+4.8
4, 5, 6, 11
B-29
4.8+8.0
3
B-30
0.3 - 1.25
D-02
1.0
(040)
2, 3, 4, 5, 6, 10
1.0
(040)
1, 2, 3, 5, 6, 7
1.0
(040)
23, 33
Joint
Connector
Hybrid
Joint
Connector
0.13 - 0.5
2.3
(090)
Hybrid 0.64+2.3+4.8 42, 52
HV/HVG
sealed
Applicable Page
Cable Size
适用电线大小 刊登页
22
1.5
(060)
2, 3, 4, 8, 12
2.3
(090)
1, 2, 3, 4
Leak
Current
漏电流
8mΩ max.(initial)
50μA max.
3mΩ max.(initial)
100μA max.
8mΩ max.(initial)
50μA max.
3mΩ max.(initial)
100μA max.
5mΩ max.(initial)
100μA max.
Insulation
Resistance
绝缘电阻
Seal
密封性
Material
材质
100MΩ min
50kPa min. (initial)
30kPa min. (after durability tests)
接插件护套
端子
电线密封栓
Housing / PBT, PA6T
Wire Seal / Silicon
100MΩ min
98kPa min. (initial)
49kPa min. (after durability tests)
接插件护套
端子
电线密封栓
Housing / PBT
Wire Seal / Silicon
接插件护套
端子
电线密封栓
Housing / PBT
Wire Seal / Silicon
接插件护套
端子
电线密封栓
Housing / PBT
Wire Seal / Silicon, NBR
接插件护套
端子
电线密封栓
接插件护套
端子
电线密封栓
Housing / PBT
Wire Seal / Silicon
Housing / PBT
Wire Seal / Silicon
E-02
0.3 - 1.25
E-06
E-08
23
0.64+1.0
Contact Resistance
接触电阻(包括压接部)
E-10
0.13 - 2.0
E-13
0.3 - 2.0
E-17
1.0+4.8
13
E-21
1.5+4.8
4, 5
E-21
2.3+4.8
10
E-22
5mΩ max.(initial)
3mΩ max.(initial)
100μA max.
100MΩ min
5mΩ max.(initial)
3mΩ max.(initial)
RS
2.3
(090)
1, 2, 3, 4, 5, 6, 8
0.3 - 2.0
G-02
3mΩ max.(initial)
10μA max.
100MΩ min
98kPa min. (after durability tests)
TL
2.3
(090)
1, 2, 4, 5
0.3 - 2.0
H-02
5mΩ max.(initial)
50μA max.
100MΩ min
1.5
(060)
2, 3, 14
0.3 - 2.0
J-02
2.3
(090)
1, 2, 3, 4, 6
0.3 - 2.0
J-06
3mΩ max.(initial)
100μA max.
100MΩ min
49.0kPa min. (initial)
29.4kPa min. (after durability tests)
Housing / PBT
Wire Seal / Silicon
8.0
(312)
接插件护套
端子
电线密封栓
2
2.0 - 8.0
J-09
2.3
(090)
1, 2, 3, 4, 6, 8, 10, 12, 16
0.3 - 2.0
L-02
3mΩ max.(initial)
100μA max.
100MΩ min
接插件护套
端子
电线密封栓
Housing / PBT
Wire Seal / NBR
SL
sealed
DL
sealed
Introduction 前言
Safety, amenity, and functionality, measure the essential performance of an automobile and these
predominately depend on in-vehicle electronic controls.
A variety of car electronic devices are systematically connected with each other using “automotive
connectors”, and the connectors for this purpose are required to be smaller, lighter, and provide
direct connection and advanced performance.
At Sumitomo Wiring Systems, we are actively researching and developing components, including
terminals and housings, with respect to the “total wiring system,” using our experience as an all-round
automotive wiring harness manufacturer. This is how we are able to achieve high reliability for our
products.
In addition, we are searching for the optimum wiring system and layout, using as little space for
wiring as is effectively possible. These are part of our activities to provide services that will further
satisfy our customers, and we sincerely ask to be favored with your request for connectors made by
Sumitomo Wiring Systems.
对汽车的安全性、舒适性以及功能性等要求,大多取决于电子控制。
这些具有系统性连接各种汽车电子模块功能的「汽车用接插件」
,通常要求具有轻量化、小型化、直结化、高功能化等
性能。
住友电装以汽车线束综合生产厂商的丰富经验以及“综合汽车线束系统”的视点,积极研究与开发端子、接插件等汽车
构成部品,为提高产品的高信赖性而进行着不断的努力。
并且利用有限的配线空间内,不断地追求高效率的汽车线束系统,及其最佳配线布局。为客户提供更满意的服务,敬请
定购使用住友电装的汽车用接插件。
General Notes 关于汽车用接插件目录的查阅方法
2
◦ All length and area units in this catalog shall marked millimeter(mm)and square millimeter(mm )
◦ This catalog focuses on series of terminals, housings, and does not include terminals and housings not
involved in these series. Similarly, some other series and custom-made parts are not included.
Please contact our sales staff for details.
◦We have also prepared a separate “Automotive Wire, Convoluted Tube” catalog, made by Sumitomo Wiring
Systems, and suitable for the connectors. This catalog can be obtained from our sales staff.
◦该目录中的长度单位全部为 mm( 毫米)、面积的单位全部为 mm2(平方毫米)。
◦该目录主要是以成为系列的端子、接插件编写。未包括在系列中的端子、接插件护套及一部分系列、定制开发产品未予记载,详
细内容请向敝公司销售负责人问讯。
◦另外,还备有最适合接插件的住友电装的「汽车用电线、波纹管」目录,需要时请向敝公司销售负责人索取。
Digital catalog 电子目录
A digital connector catalog is available on the Sumitomo Wiring Systems home page.
Digital catalogue has connectors which are not on this catalogue.
住友电装主页中刊登有「接插件电子目录」
在电子目录中还刊登有该目录中未予记载的接插件。
URL: http://www.sws.co.jp
* Product specifi cations may be subject to change without notice.
Before using the product, please obtain a “customer drawing” “Specifi cations” “Instruction Manuals” from
our sales staff.
※产品式样变更时可能不另行告知。
使用产品时,
请向敝公司销售负责人索取「客户用图纸」
「仕样书」
「使用说明书」。
TS SERIES
Features
The TS connector series has a mechanism
of terminal position assurance.
This series consists of 0.64mm, 1.5mm,
2.3mm, 4.8mm and 8.0mm types classified
according to terminal size, covering an
extensive array of applications from signal
to power circuits.
◦ The connector mechanism only allows
the retainer to be set when the terminal
is completely inserted.
◦ R e t a i n e r s a r e p r e - m o u n t e d o n
connector housings, and are structured
to enable setting by the same simple
operation regardless of the number of
ways, improving operability.
◦ T hese connectors can be directly
secured to a support on the car body.
◦ P CB models are also available for
connection to printed circuit boards.
◦ RoHS/ELV Compliant
特 点
TS 系列接插件具有检测端子插入不足的功能。
按照端子尺寸划分为0.64mm·1.5mm·2.3mm·
4.8mm·8.0mm,从信号回路到电源回路,能广
泛应用。
◦它具有当端子在半插入状态时,锁片无法安装
的结构。
◦锁片预先组装在接插件护套上,无论多少极数
都能通过简单操作进行组合,有助于提高操作
效率。
◦接插件可以直接固定在车体的支架上。
◦我们还设定了能适用于印制线路板的 PCB 接插
件。
◦可对应欧盟 RoHS 和 ELV 指令
TS SERIES for STANDARD
0.64mm
(025)
A- 02
Structure/构造
Housing M
Terminal M
Retainer sliding direction
通过压入锁片能够检知端子是否
插入到位
Retainer
Connector M
Connector F
Terminal F
Housing F
通过压入锁片能够检知端子是否
插入到位
Retainer
0.64mm
(025)
Terminal(UNIT : mm)
端子(毫米)
(S)
(S)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
Au
Cable size(mm2)
0.13
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
22.3
0.64
表面处理
0.13
Brass
黄铜
Gold-plated
镀金
0.64
15.5
1.5
F
(8240-0182)
Cable size(mm2)
适用电线大小
Material
2
材 质
Surface treatment
表面处理
M
(8230-5136)
15.5
1.5
0.13
Heat-resistant
copper alloy
Tin-plated
镀锡
(M)
F(8240-0338)
Cable size(mm2)
适用电线大小
Material
2
材 质
Surface treatment
表面处理
Cable size(mm )
适用电线大小
Material
材 质
Surface treatment
表面处理
Cable size(mm )
0.22〜0.35
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
22.3
0.64
M
(8100-3622)
15.5
1.5
表面处理
0.22〜0.35
Brass
黄铜
Gold-plated
镀金
Cable size(mm2)
适用电线大小
材 质
Surface treatment
表面处理
22.3
0.64
0.64
F
(8100-3624)
Material
2
0.22〜0.35
Heat-resistant
copper alloy
Tin-plated
镀锡
(L)
M
(8100-3626)
15.5
1.5
F(8100-3628)
Cable size(mm2)
适用电线大小
Material
2
材 质
Surface treatment
表面处理
0.22〜0.35
Heat-resistant
copper alloy
Gold-plated
镀金
(L)
Cable size(mm )
2
适用电线大小
Material
材 质
Surface treatment
Au
Cable size(mm )
2
0.3〜0.5
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
22.3
0.64
表面处理
0.3〜0.5
Brass
黄铜
Gold-plated
镀金
M
(8100-3623)
15.5
0.64
F
(8100-3625)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
22.3
0.64
0.64
2
Heat-resistant
copper alloy
Gold-plated
镀金
Au
2
0.64
1.5
0.13
(M)
2
表面处理
A- 03
0.64
0.3〜0.5
Heat-resistant
copper alloy
Tin-plated
镀锡
M
(8100-3627)
1.5
2
15.5
F(8100-3629)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
0.3〜0.5
Heat-resistant
copper alloy
Gold-plated
镀金
TS SERIES
M
(8230-4878)
22.3
0.64
2way
0.64mm
(025)
Color
Natural
自然色
颜 色
12.9
A- 04
12.6
M
(6098-6653)
Housing(UNIT : mm)
35.2
F(6098-6662)
接插件护套
(毫米)
Ref: Terminal part No.
端子参照页
Material
A-02
11.8
11.6
PBT
材 质
21
Color
5way
10way
Color
Color
Natural
自然色
颜 色
Natural
自然色
颜 色
12.8
15.8
16.4
M
(6098-3802)
33.9
16.4
F
(6098-3810)
M
(6098-3869)
12.8
13.2
33.9
F(6098-3909)
15.8
21
13.2
Color
21
Color
Natural
自然色
颜 色
颜 色
Natural
自然色
14way
14way
Color
F(6098-7241)
Natural
自然色
颜 色
15
15.8
20.8
33.9
18.8
21
Color
颜 色
M
(6098-3877)
F
(6098-3917)
15.8
17.6
Natural
自然色
颜 色
21
Color
颜 色
Natural
自然色
Natural
自然色
16way
16way
Color
F(6098-6688)
Natural
自然色
颜 色
13.75
12.8
29.6
26.4
33.9
A- 05
21
Color
颜 色
M
(6098-7336)
F
(6098-4008)
TS SERIES
Natural
自然色
16way
F(6098-6694)
12.8
12.8
21
26.4
26.4
Color
颜 色
21
Color
Natural
自然色
19way
Natural
自然色
颜 色
22way
F
(6098-7231)
Color
Natural
自然色
颜 色
15
15.8
21
23.2
Color
颜 色
29.6
Natural
自然色
M
(6098-3885)
33.9
F(6098-3925)
15.8
26.4
21
Color
颜 色
24way
24way
F
(6098-4010)
F(6098-6682)
12.8
35.2
12.8
21
Color
颜 色
Natural
自然色
28way
35.2
21
Color
颜 色
Natural
自然色
32way
F
(6098-4756)
F(6098-4013)
12.8
39.6
Natural
自然色
12.8
21
44
Color
颜 色
Natural
自然色
21
Color
颜 色
Natural
自然色
40way
36way
F(6098-4015)
F
(6098-4740)
12.8
A- 06
48.4
12.8
52.8
21
Color
颜 色
Natural
自然色
40way
F
(6098-4831)
12.8
52.8
21
Color
颜 色
Natural
自然色
21
Color
颜 色
Natural
自然色
1.5mm
(060)
A- 07
Structure/构造
TS SERIES
Housing M
Terminal M
通过压入锁片能够检知端子是否
插入到位
Retainer
Connector M
Connector F
Terminal F
Housing F
Retainer
通过压入锁片能够检知端子是否
插入到位
1.5mm(060)
A- 08
Terminal(UNIT : mm)
端子(毫米)
(3S)
(S)
F
(8240-0339)
Cable size(mm2)
0.3〜0.5
适用电线大小
Material
1.75
Cable size(mm )
2
17.5
2.4
适用电线大小
Material
材 质
Surface treatment
表面处理
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
0.13
Heat-resistant
copper alloy
Tin-plated
镀锡
表面处理
M
(8230-4925)
(SS)
24
1.5
F(8240-0215)
F
(8240-0279)
1.75
Cable size(mm2)
18
2.4
适用电线大小
Material
材 质
Surface treatment
表面处理
0.22〜0.35
Heat-resistant
copper alloy
Tin-plated
镀锡
(M)
Cable size(mm )
适用电线大小
Material
材 质
Surface treatment
适用电线大小
Material
材 质
Surface treatment
表面处理
Cable size(mm2)
0.75〜1.25
0.3〜0.5
Heat-resistant
copper alloy
Tin-plated
镀锡
Material
Surface treatment
表面处理
24
F
(8240-0213)
Cable size(mm2)
18
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
M
(8230-4924)
1.75
2.0
适用电线大小
Brass
黄铜
Tin-plated
镀锡
1.5
2.4
2.4
Cable size(mm2)
18
(L)
2
表面处理
1.75
适用电线大小
Material
材 质
Surface treatment
表面处理
0.75〜1.25
Heat-resistant
copper alloy
Tin-plated
镀锡
24
1.5
M
(8230-4923)
1.75
2.4
F(8240-0214)
Cable size(mm2)
18
适用电线大小
Material
材 质
Surface treatment
表面处理
2.0
Heat-resistant
copper alloy
Tin-plated
镀锡
1.5mm(060)
A- 09
TS SERIES
Housing(UNIT : mm)
接插件护套
(毫米)
端子参照页
A-08
Material
材 质
PBT
2way
4way
Color
Natural
自然色
颜 色
Color
Natural
自然色
颜 色
13.05
13.05
36.4
M
(6098-6050)
36.4
20.6
14.1
F
(6098-6053)
M
(6098-5668)
F(6098-5677)
12
12
21
11.7
21
17.4
Color
Natural
自然色
颜 色
Color
Natural
自然色
颜 色
8way
12way
Color
Color
Natural
自然色
颜 色
Natural
自然色
颜 色
16.25
16.25
M
(6098-5686)
36.4
36.4
19.1
25.5
F
(6098-5695)
M
(6098-5704)
F(6098-5713)
15.2
15.2
16
21
22.4
Color
颜 色
Natural
自然色
21
Color
颜 色
Natural
自然色
2.3mm(090)
A- 10
Structure/构造
Housing M
Terminal M
通过压入锁片能够检知端子是否
插入到位
Retainer
Connector M
Connector F
Terminal F
Housing F
Retainer
2.3mm(090)
通过压入锁片能够检知端子是否
插入到位
(SS)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
0.22〜0.35
Brass
黄铜
Tin-plated
镀锡
2.3
26.7
0.64
M
(8230-4742)
3
Terminal(UNIT : mm)
端子(毫米)
18
F(8240-0029)
Cable size(mm2)
适用电线大小
Material
2.8
材 质
Surface treatment
表面处理
0.22〜0.35
Brass
黄铜
Tin-plated
镀锡
(S)Au
(S)
Cable size(mm2)
Cable size(mm2)
0.3〜0.5
适用电线大小
Material
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
表面处理
材 质
26.7
2.3
Surface treatment
表面处理
0.3〜0.5
Brass
黄铜
Gold-plated
镀金
2.3
0.64
3
0.64
F
(8240-4882)
M
(8100-1341)
3
18
Cable size(mm2)
适用电线大小
Material
材 质
2.8
Surface treatment
表面处理
0.3〜0.5
Brass
黄铜
Tin-plated
镀锡
(M)
18
F(8100-1346)
Cable size(mm2)
适用电线大小
Material
材 质
2.8
Surface treatment
表面处理
Cable size(mm )
Cable size(mm2)
0.5〜1.25
适用电线大小
Material
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
表面处理
材 质
26.7
2.3
M
(8230-4502)
3
Surface treatment
表面处理
Brass
黄铜
Gold-plated
镀金
2.3
Cable size(mm2)
Material
2.8
材 质
Surface treatment
表面处理
0.5〜1.25
Brass
黄铜
Tin-plated
镀锡
(L)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
M
(8100-1342)
3
18
2.0
Brass
黄铜
Tin-plated
镀锡
26.7
2.3
0.64
M(8230-4512)
18
F
(8240-4942)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
26.7
0.64
F(8240-4892)
适用电线大小
2.8
Brass
黄铜
Gold-plated
镀金
0.5〜1.25
0.64
3
0.3〜0.5
(M)Au
2
表面处理
A- 11
2.0
Heat-resistant
copper alloy
Tin-plated
镀锡
18
F(8100-1347)
Cable size(mm2)
适用电线大小
2.8
Material
材 质
Surface treatment
表面处理
0.5〜1.25
Brass
黄铜
Gold-plated
镀金
TS SERIES
M
(8230-4492)
26.7
2way
2.3mm(090)
Material
材 质
Color
PA6T
Natural
自然色
颜 色
14.6
A- 12
37.5
15.2
M
(6520-0549)
Housing(UNIT : mm)
6.7
接插件护套
(毫米)
端子参照页
F(6520-0550)
22
12.2
Material
PA6T
材 质
A-10
Color
Natural
自然色
颜 色
6way
Material
材 质
Color
颜 色
Note
备 注
Material
PBT
材 质
Color
Natural
自然色
With clamp for 7mm dia.
带φ7用卡钉
PBT
Natural
自然色
With body fastening clamp.
带防转卡钉
颜 色
Note
备 注
24.1
24.1
42.5
14.7
42.5
14.7
M
(6240-1107)
M
(6249-1243)
F(6240-5118)
17
10.8
22
Material
PBT
材 质
Color
Natural
自然色
颜 色
6way
9way
M
(6240-1120)
Material
材 质
Color
Natural
自然色
颜 色
16.4
PBT
19.4
21.1
38
Material
材 质
Color
颜 色
PBT
39.5
31.1
Natural
自然色
M
(6249-1229)
F(6248-5270)
8way
M
(6240-1077)
13.3
16.4
25.1
38
Material
材 质
Color
颜 色
PBT
Natural
自然色
26.8
22
Material
材 质
Color
颜 色
PBT
Natural
自然色
10way
Material
材 质
Color
11way
Material
PBT
Color
Natural
自然色
颜 色
19.4
41
F
(6248-5276)
18.4
22
30.8
Material
Material
PBT
Color
Natural
自然色
Natural
自然色
颜 色
22.4
21.4
40
25.1
F(6520-1004)
M
(6240-1122)
18.3
Material
22
21.1
PBT
材 质
Color
F(6240-5175)
Material
22
PBT
材 质
Color
Natural
自然色
颜 色
Natural
自然色
颜 色
16way
20way
Material
PBT
材 质
Color
Natural
自然色
颜 色
16.4
46.7
M
(6240-1158)
PBT
Natural
自然色
16.4
54.7
38
F(6240-5088)
12
M
(6240-1033)
38
F(6240-5035)
12
42.7
39.3
17
22.8
颜 色
PBT
材 质
M
(6520-1009)
Color
Natural
自然色
颜 色
13way
27.1
材 质
PBT
Color
12way
Material
Material
材 质
Natural
自然色
颜 色
颜 色
F(6248-5275)
22
PBT
材 质
Color
Color
M
(6249-1234)
13.3
22.8
材 质
39.5
35.1
22
Material
材 质
Color
颜 色
51.7
PBT
Natural
自然色
22
Material
材 质
Color
颜 色
PBT
Natural
自然色
A- 13
TS SERIES
M
(6249-1235)
Natural
自然色
颜 色
22
27.1
Material
PBT
材 质
4.8mm(187)
A- 14
Structure/构造
Terminal M
Housing M
Retainer
通过压入锁片能够检知端子是否
插入到位
Connector M
Connector F
Housing F
Terminal F
Retainer
通过压入锁片能够检知端子是否
插入到位
4.8mm
(187)
Terminal(UNIT : mm)
端子(毫米)
(S)
(M)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
Cable size(mm2)
0.3〜0.5
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
材 质
4.8
26.7
Surface treatment
表面处理
0.5〜1.25
Brass
黄铜
Tin-plated
镀锡
4.8
0.8
6
18
F
(8240-4912)
适用电线大小
Material
3.8
材 质
Surface treatment
表面处理
18
Cable size(mm2)
Brass
黄铜
Tin-plated
镀锡
适用电线大小
Material
3.8
材 质
Surface treatment
表面处理
0.5〜1.25
Brass
黄铜
Tin-plated
镀锡
(L)
Cable size(mm )
2
适用电线大小
Material
材 质
Surface treatment
F(8100-1555)
2.0〜3.0
Brass
黄铜
Tin-plated
镀锡
4.8
6
适用电线大小
材 质
3.8
Surface treatment
表面处理
2.0〜3.0
Heat-resistant
copper alloy
Tin-plated
镀锡
F(8240-4932)
Cable size(mm2)
适用电线大小
3.8
Cable size(mm2)
Material
M
(8230-4542)
18
18
26.7
0.8
6
F(8240-4922)
0.3〜0.5
(L)
表面处理
M
(8230-4532)
6
Cable size(mm2)
A- 15
0.8
Material
材 质
Surface treatment
表面处理
2.0〜3.0
Brass
黄铜
Tin-plated
镀锡
1way
4.8mm
(187)
Color
Natural
自然色
颜 色
16.25
39
16.3
M
(6098-0822)
F(6098-0824)
Housing(UNIT : mm)
接插件护套
(毫米)
14.8
端子参照页
A-14
Material
材 质
PBT
12.4
22
Color
颜 色
Natural
自然色
TS SERIES
M
(8230-4522)
26.7
2way
2way
Color
Color
Natural
自然色
颜 色
Natural
自然色
颜 色
17.4
A- 16
17.4
39
20.4
M
(6098-0323)
39
20.4
F
(6098-0325)
M
(6098-0469)
18.75
F
(6098-0471)
18.75
22
18.1
18.1
Color
22
Color
Natural
自然色
颜 色
Natural
自然色
颜 色
3way
4way
Color
Natural
自然色
颜 色
Color
Natural
自然色
颜 色
21.5
29.8
23.3
M
(6098-0149)
39
F
(6098-0151)
22.8
M
(6098-1851)
39.5
F(6098-1489)
25.9
20.1
19.4
22
20.1
Color
22
Natural
自然色
颜 色
Color
颜 色
6way
Natural
自然色
8way
Color
F(6098-0518)
Natural
自然色
颜 色
26.6
29.8
42.5
29.6
M(6098-2211)
F
(6098-1716)
22
Color
颜 色
22
Color
颜 色
25.9
26.9
30.1
Natural
自然色
Natural
自然色
10way
Color
Natural
自然色
颜 色
21
47.6
F
(6098-0156)
20.1
43.7
22
Color
颜 色
Natural
自然色
A- 17
TS SERIES
M
(6098-0154)
39
8.0mm(312)
A- 18
Structure/构造
Housing M
Terminal M
通过压入锁片能够检知端子是否
插入到位
Retainer
Connector M
Connector F
Terminal F
Housing F
通过压入锁片能够检知端子是否
插入到位
Retainer
8.0mm(312)
(S)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
0.5〜1.25
Brass
黄铜
Tin-plated
镀锡
8
32.3
0.8
M
(8100-0520)
9.2
F(8100-0707)
23.4
Cable size(mm2)
Terminal(UNIT : mm)
端子(毫米)
适用电线大小
5
Material
材 质
Surface treatment
表面处理
0.5〜1.25
Brass
黄铜
Tin-plated
镀锡
(M)
(L)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
Cable size(mm2)
2.0〜3.0
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
材 质
32.3
8
Surface treatment
表面处理
5.0〜8.0
Brass
黄铜
Tin-plated
镀锡
32.3
8
A- 19
0.8
0.8
9.2
F
(8100-2493)
23.4
9.2
Cable size(mm2)
适用电线大小
Material
5
M
(8100-0522)
材 质
Surface treatment
表面处理
F
(8100-1553)
23.4
Cable size(mm2)
2.0〜3.0
5.0〜8.0
适用电线大小
Heat-resistant
copper alloy
Tin-plated
镀锡
Material
5
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
Surface treatment
表面处理
1way
8.0mm
(312)
Color
Natural
自然色
颜 色
20.5
20.5
44.8
M
(6240-1093)
Housing(UNIT : mm)
F(6098-0441)
16.6
接插件护套
(毫米)
22.7
端子参照页
A-18
Material
材 质
PBT
27.8
Color
颜 色
Natural
自然色
3way
2way
Color
F(6520-1466)
Natural
自然色
颜 色
24.55
19.85
28.3
M
(6098-1278)
29.7
47.8
27.8
Color
颜 色
Natural
自然色
F
(6098-1104)
4way
F(6098-2137)
20.65
20.15
24
44.2
27.8
Color
颜 色
Natural
自然色
27.8
Color
颜 色
Natural
自然色
TS SERIES
M
(8100-0521)
0.64mm, 1.5mm
(025, 060)
A- 20
Housing(UNIT : mm)
接插件护套(毫米)
端子参照页
[0.64mm]
A-02
[1.5mm] A-08
TS SERIES
for HYBRID
No. of way/( )corresponds to 0.64mm, 1.5mm, in order from left to right.
极数/( )内显示 :从左向右为0.64mm 极数、1.5mm 极数
12way(4+8)
12way(6+6)
Color
Material
材 质
Color
Natural
自然色
颜 色
PBT
Natural
自然色
颜 色
17.15
16.95
36.4
36.4
26.3
M
(6098-6055)
25.5
F
(6098-6083)
15.7
M
(6098-6104)
F(6098-6111)
15.9
21
21
23.2
22.4
Color
Color
Natural
自然色
颜 色
18way(8+10)
12way(8+4)
Color
Color
Natural
自然色
颜 色
Natural
自然色
颜 色
Natural
自然色
颜 色
16.95
20.15
36.4
36.4
24.3
M
(6098-6090)
F
(6098-6097)
25.5
M
(6098-5650)
F(6098-5659)
15.7
15.7
21
21
21.2
22.4
Color
颜 色
Natural
自然色
Color
颜 色
Natural
自然色
18way(12+6)
18way(10+8)
Color
Color
Natural
自然色
颜 色
Natural
自然色
颜 色
16.95
16.95
36.4
36.4
35.1
32.9
F
(6098-5604)
M
(6098-5631)
F(6098-5641)
15.7
15.7
21
21
32
29.8
Color
Color
Natural
自然色
颜 色
Natural
自然色
颜 色
20way(16+4)
Color
Natural
自然色
颜 色
16.95
36.4
33.1
M
(6098-5613)
F
(6098-5622)
15.7
30
21
Color
颜 色
Natural
自然色
17way(8+9)
0.64mm, 2.3mm
(025, 090)
Color
Natural
自然色
颜 色
23.9
25.4
Housing(UNIT : mm)
M
(6098-3893)
F(6098-3933)
接插件护套
(毫米)
端子参照页
Material
材 质
[0.64mm]A-02
[2.3mm] A-10
23.9
PBT
No. of way/( )corresponds to 0.64mm, 2.3mm, in order from left to right.
极数/( )内显示 :从左向右为0.64mm 极数、2.3mm 极数
22.2
36
22
Color
颜 色
Natural
自然色
TS SERIES
M
(6098-5594)
A- 21
18way(10+8)
Color
20way(16+4)
Color
Natural
自然色
颜 色
Natural
自然色
颜 色
20.25
20.25
A- 22
32.6
M
(6098-3901)
36
F
(6098-3941)
31.2
M
(6098-3818)
16.75
29.4
36
F(6098-3826)
16.75
22
22
28
Color
颜 色
Color
Natural
自然色
Natural
自然色
颜 色
0.64mm, 4.8mm
(025, 187)
Housing(UNIT : mm)
20way(18+2)
接插件护套
(毫米)
端子参照页
Material
材 质
F(6098-5903)
[0.64mm]A-02
[4.8mm] A-14
16.6
PBT
38.9
No. of way/( )corresponds to 0.64mm, 4.8mm, in order from left to right.
极数/( )内显示 :从左向右为0.64mm 极数、4.8mm 极数
22
Color
Natural
自然色
颜 色
14way(12+2)
2.3mm, 4.8mm
(090, 187)
Color
颜 色
Natural
自然色
23.9
34.8
Housing(UNIT : mm)
M
(6241-0261)
40
F(6245-0281)
接插件护套
(毫米)
端子参照页
Material
材 质
[2.3mm]A-10
[4.8mm]A-14
20.1
PBT
No. of way/( )corresponds to 2.3mm, 4.8mm, in order from left to right.
极数/( )内显示 :从左向右为2.3mm 极数、4.8mm 极数
30.9
22
Color
颜 色
Natural
自然色
15way(12+3)
Color
20way(18+2)
Natural
自然色
颜 色
Color
颜 色
Natural
自然色
23.9
30.2
F
(6245-0261)
F(6245-0301)
20.1
26.4
25.6
M
(6241-0281)
40
38.9
22
Color
颜 色
Natural
自然色
22
Color
颜 色
Natural
自然色
TS SERIES
M
(6241-0241)
A- 23
42.8
40
29.5
0.64mm
(025)
A- 24
TS SERIES
for PCB
Housing(UNIT : mm)
接插件护套(毫米)
16way
M
(6098-6790)
●Detailed dimension
详细尺寸
10
Connector F part No.
母端接插件产品号码
Material
材 质
Color
颜 色
6098-4008(A-05)
24.47
PBT
●Recommended demension of Circuit board
电路板推荐尺寸
38.3
Natural
自然色
t=1.6
16way
M
(6098-6793)
●Detailed dimension
详细尺寸
10
母端接插件产品号码
Material
材 质
Color
颜 色
电路板推荐尺寸
6098-4008(A-05)
24.47
SPS
38.3
Natural
自然色
t=1.6
33way
M
(6098-7229)
●Detailed dimension
详细尺寸
11.5
母端接插件产品号码
Material
材 质
Color
颜 色
电路板推荐尺寸
6098-7231(A-05)
6098-7241(A-04)
SPS
Natural
自然色
50.1
21.3
t=1.6
36way
M
(6098-6796)
●Detailed dimension
详细尺寸
10
母端接插件产品号码
材 质
Color
颜 色
24.47
PBT
A- 25
电路板推荐尺寸
60.3
Natural
自然色
t=1.6
36way
M
(6098-6798)
●Detailed dimension
详细尺寸
10
母端接插件产品号码
Material
材 质
Color
颜 色
电路板推荐尺寸
6098-4740(A-06)
24.47
SPS
60.3
Natural
自然色
t=1.6
56way(16+16+24)
M
(6098-6848)
●Detailed dimension
详细尺寸
10
母端接插件产品号码
Material
材 质
Color
颜 色
6098-6688(A-05)
6098-6694(A-05)
6098-6682(A-05)
103.3
SPS
24.47
电路板推荐尺寸
Natural
自然色
t=1.6
60way(36+24)
M
(6098-6803)
●Detailed dimension
详细尺寸
10
母端接插件产品号码
Material
材 质
Color
颜 色
电路板推荐尺寸
6098-4010(A-05)
6098-4740(A-06)
SPS
97.2
24.47
Natural
自然色
t=1.6
68way(40+28)
M
(6098-6805)
●Detailed dimension
详细尺寸
10
母端接插件产品号码
Material
材 质
Color
颜 色
电路板推荐尺寸
6098-4756(A-05)
6098-4831(A-06)
PBT
Natural
自然色
106
24.47
t=1.6
TS SERIES
Material
6098-4740(A-06)
68way(40+28)
M
(6098-7102)
●Detailed dimension
详细尺寸
10
A- 26
母端接插件产品号码
Material
材 质
Color
颜 色
电路板推荐尺寸
6098-4756(A-05)
6098-4831(A-06)
SPS
24.47
106
Natural
自然色
t=1.6
68way(40+28)
M
(6098-6810)
母端接插件产品号码
Material
材 质
Color
颜 色
●Detailed dimension
详细尺寸
电路板推荐尺寸
6098-4756(A-05)
6098-4015(A-06)
PBT
Blue
蓝
t=1.6
0.64mm, 1.5mm
(025, 060)
Housing(UNIT : mm)
接插件护套
(毫米)
20way(14+6)
M
(6098-6869)
●Detailed dimension
详细尺寸
8.5
母端接插件产品号码
Material
材 质
Color
颜 色
电路板推荐尺寸
6098-6876(A-●)
LCP
Black
黒
41.4
25
t=1.2
TS SEALED SERIES
Features
The TS sealed connector series has a
mechanism of terminal position assurance.
This series consists of 0.64mm, 2.3mm,
4. 8mm and 8.0 mm t ypes classified
to power circuits.
◦ Retainers are pre-mounted on the
connector housing, and are structured
secured to a bracket on the car body.
特 点
TS 防水系列接插件具有检测端子插入不足的结构。
按照端子尺寸划分为0.64mm·2.3mm·4.8mm·
8.0mm,从信号回路到电源回路,能广泛应用。
都能通过简单操作组合,有助于提高操作效率。
◦接插件可以直接固定在车体的支架上。
TS SEALED SERIES for STANDARD
0.64mm
(025)
B- 02
Structure/构造
Wire seal
Terminal M
Wire seal
Housing M
Retainer
Terminal M
Housing M
Connector M
Retainer
Connector F
Housing F
Wire seal
Housing F
Connector Seal
Terminal F
Front holder
Wire seal
Connector seal
Retainer
Front holder
Retainer
Terminal F
0.64mm
(025)
B- 03
TS SEALED SERIES
Terminal(UNIT : mm)
端子(毫米)
(S)
F
(8240-0336)
(S)
F(8240-0337)
2
1.5
2
15.8
Cable size(mm2)
适用电线大小
Material
材 质
2
Surface treatment
表面处理
1.5
0.13
Heat-resistant
copper alloy
Tin-plated
镀锡
适用电线大小
Material
材 质
Surface treatment
表面处理
Cable size(mm2)
适用电线大小
Material
材 质
2
Surface treatment
表面处理
Cable size(mm2)
0.22〜0.5
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
材 质
23.5
0.64
M
(8100-3617)
Surface treatment
表面处理
F
(8100-3455)
Cable size(mm2)
Material
材 质
2
Surface treatment
表面处理
0.22〜0.35
Heat-resistant
copper alloy
Tin-plated
镀锡
0.22〜0.5
Brass
黄铜
Gold-plated
镀金
23.5
0.64
F(8100-3456)
1.5
15.8
Cable size(mm2)
适用电线大小
Material
材 质
2
Surface treatment
表面处理
0.22〜0.35
Heat-resistant
copper alloy
Gold-plated
镀金
(L)
(L)
Au
F(8240-0288)
F(8240-0287)
2
2
15.8
Cable size(mm2)
适用电线大小
Material
2
Heat-resistant
copper alloy
Gold-plated
镀金
2
15.8
适用电线大小
1.5
0.13
Au
M
(8100-3708)
2
1.5
15.8
(M)
(M)
Cable size(mm2)
Au
材 质
Surface treatment
表面处理
0.5
Heat-resistant
copper alloy
Tin-plated
镀锡
1.5
15.8
Cable size(mm2)
适用电线大小
Material
2
材 质
Surface treatment
表面处理
0.5
Heat-resistant
copper alloy
Gold-plated
镀金
0.64mm
(025)
B- 04
Wire seals(UNIT : mm)
(3S)
(7165-1423)
电线密封栓
(毫米)
Cable size(mm )
2
◦ The wire seals are common to M and F.
*A wireseal depends on a chosen cable.
适用电线大小
◦电线密封栓为公端、母端共用。
材 质
(7165-1043)
Cable overall diameter(mm)
带绝缘层外径
Material
材 质
Color
颜 色
φ 2.75
(CHFUS/0.22)
带绝缘层外径
Material
材 质
Color
颜 色
材 质
Color
颜 色
(7165-1198)
适用电线大小
适用电线大小
Material
7.4
(AVSS/0.3)
(AVSSH/0.3)
(AESSX/0.3)
φ 2.9
Silicon
硅
Dark Yellow
深黄色
7
(CHFUS/0.35〜0.5)
φ 2.9
1.1〜1.4
Silicon
硅
Violet
紫
7.4
(7165-1199)
Cable size(mm2)
带绝缘层外径
Material
7.4
Silicon
硅
Light Brown
浅棕
(L)
适用电线大小
1.4〜1.5
0.85〜0.95
(7165-1312)
Cable size(mm2)
带绝缘层外径
Silicon
硅
Green
绿
φ 2.9
(S)
0.95〜1.05
(M)
Cable size(mm2)
Material
颜 色
(SS)
适用电线大小
带绝缘层外径
Color
※不同的电线使用不同的电线密封栓。
Cable size(mm2)
(CHFUS/0.13)
材 质
Color
颜 色
(AVSS/0.5)
(AVSSH/0.5)
(AVSSX/0.5)
(AESSX/0.5)
φ 2.9
1.6〜1.7
Silicon
硅
Red Violet
紫红
7.4
0.64mm
(025)
Dummy plugs(UNIT : mm)
盲塞(毫米)
(7165-0797)
◦ Dummy plugs are common to M and F.
◦ Dummy plugs are used to blind unused
terminal holes.
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
φ 2.8
Material
材 质
Color
颜 色
NBR
Light Gray
浅灰
6.4
2way
0.64mm(025)
Color
Black
黒
颜 色
39.2
24.5
Housing(UNIT : mm)
18
M
(6188-4797)
端子参照页
B-03
Ref: wire seal No.
电线密封栓参照页
B-04
Ref: Dummy plug No.
盲塞参照页
B-04
Material
材 质
PBT
F(6189-1161)
16.8
17.4
21.9
Color
Black
黒
颜 色
2way
3way
F
(6189-7020)
Color
Black
黒
颜 色
16.8
18.3
17.4
21.9
39.2
Color
颜 色
18.2
Black
黒
M
(6188-4920)
F
(6189-1129)
2way
F
(6189-7073)
16.8
16.8
17.4
21.9
20.4
Color
颜 色
21.9
Color
Gray
灰
颜 色
Black
黒
4way
3way
F(6189-1231)
F
(6189-1132)
19.8
16.8
20.4
21.9
Color
颜 色
17.4
Gray
灰
4way
21.9
Color
颜 色
Gray
灰
5way
F
(6189-7401)
F(6189-1046)
16.8
16.8
23.4
21.9
Color
颜 色
Black
黒
26.4
21.9
Color
颜 色
Black
黒
TS SEALED SERIES
接插件护套
(毫米)
B- 05
6way
6way
Color
F(6189-1083)
Natural
自然色
颜 色
16.8
18.6
B- 06
29.4
39.2
11.4
21.9
Color
Black
黒
颜 色
M
(6188-0706)
F
(6189-1142)
6way
F
(6189-7100)
24.8
16.8
15.2
29.4
21.9
Color
Natural
自然色
颜 色
21.9
Color
Black
黒
颜 色
8way
10way
Color
Color
Gray
灰
颜 色
Black
黒
颜 色
21.6
20.8
M
(6188-0779)
18.6
39.2
F
(6189-1240)
39.2
23.8
M
(6188-0696)
F(6189-1134)
19.8
19.8
23.4
26.4
21.9
Color
颜 色
21.9
Color
Gray
灰
12way
Black
黒
颜 色
13way
F(6189-1128)
Color
Gray
灰
颜 色
19.8
21.7
29.4
21.9
39.2
Color
颜 色
Black
黒
29.8
M
(6188-4914)
F(6189-1092)
12way
F(6189-1133)
19.8
19.8
29.4
32.4
21.9
Color
颜 色
Gray
灰
21.9
Color
颜 色
Gray
灰
15way
17way
F
(6189-1135)
F(6189-7110)
30.8
30.8
32.3
32.3
48.2
Color
颜 色
57.2
Gray
灰
颜 色
Gray
灰
30way
F
(6189-7167)
32.1
F
(6189-6987)
33.5
32.3
34.55
57.2
63
Color
颜 色
Black
黒
Color
颜 色
Gray
灰
B- 07
TS SEALED SERIES
20way
Color
0.64W
(025W)
B- 08
Structure/构造
Wire seal
Housing M
Terminal M
Retainer
Housing M
Terminal M
Wire seal
Connector M
Connector F
Housing F
Housing F
Retainer
Connector Seal
Wire seal
Terminal F
Front holder
Wire seal
Retainer
Connector seal
Front holder
Retainer
Terminal F
防水0.64W 型接插件与0.64型相比,因为扩大了端子孔腔间的距离,所以不具备互换性。
(为了区别于现有的防水0.64型,称呼为防水0.64W 型。
Since 0.64W has wider terminal pitch, there is no compatibility between 0.64 and 0.64W.
(These connectors are called "0.64W series" to distinguish from existing 0.64 series.)
0.64W
(025W)
Terminal(UNIT : mm)
端子(毫米)
Ref; 0.64mm Terminal detail
0.64mm端子参照页
M(Sn)M
(8100-3617)
B-03
M(Au)M
(8100-3708)
B-03
F(8100-3455)
B-03
F(8100-3456)
B-03
(LL)
(LL)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
FPW/0.6 CIVUS/0.5
AVSS/0.5 AVSSX/0.5
AVSSH/0.5 IVSSH/0.5
AESSX/0.5 CHFUS/0.5
HFSS/0.5
Brass
黄铜
Tin-plated
镀锡
Cable size(mm2)
15.8
适用电线大小
Material
材 质
2
适用电线大小
23.5
0.64
Surface treatment
表面处理
Material
材 质
Surface treatment
表面处理
CIVUS/0.5 AVSS/0.5
AVSSX/0.5 AVSSH/0.5
IVSSH/0.5 AESSX/0.5
CHFUS/0.5 HFSS/0.5
Brass
黄铜
Gold-plated
镀金
23.5
0.64
B- 09
F
(8240-0500)
2
1.5
Cable size(mm2)
FPW/0.6 CIVUS/0.5
AVSS/0.5 AVSSX/0.5
AVSSH/0.5 IVSSH/0.5
AESSX/0.5 CHFUS/0.5
HFSS/0.5
Heat resistant copper-alloy
耐熱铜合金
Tin-plated
镀锡
M
(8230-5361)
F(8240-0501)
2
1.5
15.8
Cable size(mm2)
适用电线大小
Material
2
材 质
Surface treatment
表面处理
CIVUS/0.5 AVSS/0.5
AVSSX/0.5 AVSSH/0.5
IVSSH/0.5 AESSX/0.5
CHFUS/0.5 HFSS/0.5
耐熱铜合金
Gold-plated
镀金
0.64W
(025W)
(S)
(7165-1608)
Cable size(mm2)
电线密封栓
(毫米)
适用电线大小
带绝缘层外径
Material
电线密封栓为公端、母端共用。
Color
材 质
颜 色
(M)
(7165-1607)
Cable size(mm )
2
适用电线大小
带绝缘层外径
Material
材 质
Color
颜 色
AVSS/0.3 AVSSH/0.3
IVSSH/0.35 HFSS/0.35
φ 3.5
Silicon
硅
Dark Green
墨绿
Cable size(mm2)
适用电线大小
带绝缘层外径
Material
7
φ 3.5
1.1〜1.4
Silicon
硅
Dark Gray
深灰
7
(L)
1.3〜1.5
CIVUS/0.35〜0.5
CHFUS/0.35〜0.5
材 质
Color
颜 色
FPW/0.6 AVSS/0.5
AVSSH/0.5 AVSSX/0.5
IVSSH/0.5 HFSS/0.5
(7165-1606)
φ 3.5
1.51〜1.73
Silicon
硅
Dark Brown
深棕
7
TS SEALED SERIES
M
(8230-5360)
Au
0.64W
(025W)
B- 10
盲塞(毫米)
(7165-1605)
terminal holes.
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
φ 3.4
Material
Silicon
硅
Indian Red
印度紅
材 质
Color
颜 色
6.4
4way
0.64W
(025W)
Color
Black
黒
颜 色
18.2
39.2
Housing(UNIT : mm)
接插件护套
(毫米)
16.3
M
(6188-5516)
端子参照页
B-08
Ref: wire seal No.
电线密封栓参照页
B-09
Ref: Dummy plug No.
盲塞参照页
B-10
Material
材 质
PA6T
F(6189-7449)
24.75
19.4
24.4
Color
颜 色
Black
黒
0.64W, 2.3mm, 4.8mm
(025W, 090, 187)
Housing(UNIT : mm)
接插件护套(毫米)
TS SEALED SERIES
for HYBRID
端子参照页
[0.64W] B-08
[2.3mm] B-13(for P06)
[4.8mm] B-19
Ref: wire seal No.
电线密封栓参照页
[0.64W]
B-09
[2.3mm] B-14(for P06)
[4.8mm] B-20
Ref: Dummy plug No.
盲塞参照页
[0.64W] B-10
[2.3mm] B-15(for P06)
[4.8mm] B-21
Material
材 质
PBT
No. of way/( )corresponds to 0.64W, 2.3mm, 4.8mm in order from left to right.
极数/( )内显示 :从左向右为0.64mm 极数、2.3mm 极数、4.8mm 极数
Slide Lever
38way (34+2+2)
F
(6189-7435)
29.9
Slide Lever
38way (34+2+2)
F(6189-7436)
29.9
41.7
41.7
80.3
Color
颜 色
80.3
Black
黒
颜 色
F(6189-7433)
29.9
37.3
Black
黒
B- 11
Swing + Slide Lever
38way (34+2+2)
F(6189-7434)
29.9
37.3
77.3
Color
颜 色
77.3
Black
黒
Color
颜 色
Black
黒
Lever Assy
F
(6911-5774)
88.3
43.5
Color
31.2
Black
黒
颜 色
Slide Lever
46way(38+4+4)
F
(6189-7546)
29.9
43.6
Slide Lever
46way(38+4+4)
F(6189-7547)
29.9
43.6
95.5
Color
颜 色
Black
黒
95.5
Color
颜 色
Black
黒
TS SEALED SERIES
Swing + Slide Lever
38way (34+2+2)
Color
2.3mm
(090)
B- 12
Structure/构造
Wire seal
Housing M
Wire seal
Terminal M
Retainer
Housing M
Terminal M
Retainer
Connector M
Connector F
Housing F
Connector Seal
Wire seal
Terminal F
Retainer
Housing F
Wire seal
Connector seal
Retainer
2.3mm
(090)
Terminal(UNIT : mm)
端子(毫米)
Terminal F
(S)
(S)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
Au
Cable size(mm2)
0.3〜0.5
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
材 质
25.9
2.3
Surface treatment
表面处理
0.3〜0.5
Brass
黄铜
Gold-plated
镀金
0.64
3
17
F
(8100-0460)
M
(8100-1340)
3
Cable size(mm2)
适用电线大小
Material
2.8
0.64
材 质
Surface treatment
表面处理
17
0.3〜0.5
Heat-resistant
copper alloy
Tin-plated
镀锡
(M)
F(8100-1344)
Cable size(mm2)
适用电线大小
Material
2.8
材 质
Surface treatment
表面处理
Cable size(mm )
适用电线大小
Material
材 质
Surface treatment
表面处理
Cable size(mm )
0.5〜1.25
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
材 质
25.9
2.3
M
(8100-0458)
3
Surface treatment
表面处理
0.5〜1.25
Brass
黄铜
Gold-plated
镀金
17
Material
2.8
M
(8100-1007)
3
Cable size(mm2)
材 质
Surface treatment
表面处理
25.9
2.3
0.64
F
(8100-0461)
适用电线大小
17
0.5〜1.25
Heat-resistant
copper alloy
Tin-plated
镀锡
(L)
F
(8100-0594)
Cable size(mm2)
适用电线大小
Material
2.8
材 质
Surface treatment
表面处理
0.5〜1.25
Heat-resistant
copper alloy
Gold-plated
镀金
(L)
Cable size(mm )
2
适用电线大小
Material
材 质
Surface treatment
Au
Cable size(mm )
2
2.0
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
材 质
25.9
2.3
Surface treatment
表面处理
2.0
Brass
黄铜
Gold-plated
镀金
M
(8100-0459)
17
0.64
F
(8100-0462)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
25.9
2.3
0.64
2.8
Heat-resistant
copper alloy
Gold-plated
镀金
Au
2
0.64
3
0.3〜0.5
(M)
2
表面处理
B- 13
M
(8100-1008)
3
2.0
Heat-resistant
copper alloy
Tin-plated
镀锡
17
F
(8100-0817)
Cable size(mm2)
适用电线大小
2.8
Material
材 质
Surface treatment
表面处理
2.0
Heat-resistant
copper alloy
Gold-plated
镀金
TS SEALED SERIES
M
(8100-0457)
25.9
2.3
2.3mm(090)
B- 14
电线密封栓
(毫米)
◦ P5 : For 5mm pitch housing/Please inquire us
for the details.
◦ P6 : For 6mm pitch housing
电线密封栓为公端、母端共用。
◦ P5 :5mm 间距用/请另行咨询。
◦ P6 :6mm 间距用
(SS)
(P6)
(7165-0842)
Cable size(mm2)
适用电线大小
带绝缘层外径
Material
材 质
Color
颜 色
(CHFUS/0.35〜0.5)
1.1〜1.4
φ 5.7
Silicon
硅
Blue
蓝
8.5
(S)
(P6)
(S)
(P5)
(7165-0342)
(7165-0349)
Cable size(mm2)
适用电线大小
带绝缘层外径
Material
材 质
Color
颜 色
(AVX・AEX/0.3)
(AVS/0.3)
(AVSS/0.3〜0.85)
(AVSSX・AESSX/0.3〜0.75)
(CAVUS/0.85〜1.25)
1.4〜2.0
Cable size(mm2)
适用电线大小
φ 5.7
带绝缘层外径
Material
Silicon
硅
Dark Brown
深棕
材 质
Color
颜 色
8.5
(M)
(P6)
(AVX・AEX/0.3)
(AVS/0.3)
(AVSS/0.3〜0.85)
(CAVUS/0.85〜1.25)
1.4〜2.0
适用电线大小
带绝缘层外径
Material
材 质
Color
颜 色
(AV/0.5)
(AVX・AEX/0.5〜0.75)
(AVS/0.5〜0.85)
(AVSS/1.25)
(AVSSX・AESSX/1.25)
2.0〜2.5
(P5)
(7165-0343)
Cable size(mm2)
适用电线大小
φ 5.7
带绝缘层外径
Material
Silicon
硅
Dark Green
墨绿
材 质
Color
颜 色
8.5
(L)
(P6)
(AV/0.5)
(AVX・AEX/0.5〜0.75)
(AVS/0.5〜0.85)
(AVSS/1.25)
(AVSSX・AESSX/1.25)
2.0〜2.5
适用电线大小
带绝缘层外径
Material
材 质
Color
颜 色
(AV/1.25)
(AVX・AEX/1.25)
(AVS/1.25)
(AVSS/2.0)
(AVSSX・AESSX/2.0)
2.5〜2.9
Silicon
硅
Dark Gray
深灰
(P5)
(7165-0344)
适用电线大小
带绝缘层外径
Material
材 质
Color
8.5
8.5
(L)
Cable size(mm2)
φ 5.7
φ 4.9
Silicon
硅
Black
黒
(7165-0351)
Cable size(mm2)
8.5
(M)
(7165-0395)
Cable size(mm2)
φ 4.9
Silicon
硅
Brown
棕
颜 色
(AV/1.25)
(AVX・AEX/1.25)
(AVS/1.25)
(AVSS/2.0)
(AVSSX・AESSX/2.0)
2.5〜2.9
Silicon
硅
Dark Blue
藏青
φ 4.9
8.5
(P6)
2.3mm
(090)
(7160-9465)
φ 5.6
盲塞(毫米)
Material
NBR
材 质
Color
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
◦ P6 :6mm 间距用
(P5)
(7161-9787)
φ 4.7
Material
NBR
材 质
Color
6.4
Brown
棕
颜 色
2way
2.3mm(090)
Color
Gray
灰
颜 色
19.1
37.7
19.9
Housing(UNIT : mm)
接插件护套
(毫米)
M
(6188-0047)
端子参照页
B-13
Ref: wire seal No.
电线密封栓参照页
B-14
Ref: Dummy plug No.
盲塞参照页
B-15
Material
材 质
PBT
F(6189-0100)
26.3
30
23.7
Color
Gray
灰
颜 色
2way
2way
Color
Gray
灰
颜 色
Color
Gray
灰
颜 色
17.9
22.1
17.2
M
(6188-0108)
17.4
37.7
F
(6189-0199)
M
(6188-0266)
F(6189-0249)
21.25
24.9
24
24
21
20.7
Color
颜 色
37.2
Gray
灰
Color
颜 色
Gray
灰
B- 15
TS SEALED SERIES
terminal holes.
for the details.
6.4
Black
黒
颜 色
2way
2way
Color
Gray
灰
颜 色
Color
Natural
自然色
颜 色
21.65
17.9
43.2
B- 16
M
(6188-0229)
37.2
17.4
19.5
F
(6189-0388)
15.1
M
(6188-0624)
F(6189-0264)
21.25
14.2
24
24
Color
20.7
Gray
灰
颜 色
Color
Gray
灰
颜 色
P5
2way
P5
2way
F(6189-0573)
F
(6189-0566)
21.8
21.8
Ref: Wire seal No.
B-10(For P5)
电线密封栓参照页
31
Ref: Dummy plug No.
B-11(For P5)
Color
Gray
灰
盲塞参照页
22
颜 色
Ref: Wire seal No.
B-10(For P5)
Ref: Dummy plug No.
B-11(For P5)
Color
Gray
灰
电线密封栓参照页
31
盲塞参照页
22
颜 色
P5
2way
F(6189-0611)
26
24
Ref: Wire seal No.
B-10(For P5)
Ref: Dummy plug No.
B-11(For P5)
Color
Gray
灰
电线密封栓参照页
盲塞参照页
15.55
颜 色
3way(T Type)
2way
Color
Gray
灰
颜 色
Color
Gray
灰
颜 色
25.9
13.6
M
(6188-0470)
37.7
20.8
17.2
F
(6189-0682)
23
M
(6188-0099)
F(6189-0179)
28.9
28
24
22.8
Color
颜 色
Gray
灰
24.5
Color
颜 色
Gray
灰
3way(E Type)
4way
Color
F(6189-0694)
Gray
灰
颜 色
18.9
26.4
38.2
25.2
26
Color
26.3
F
(6189-0443)
B- 17
4way
F(6189-7398)
24
19.3
28.4
26
Material
29.5
Color
颜 色
PA6T
材 质
24.05
Gray
灰
Color
Black
黒
颜 色
4way
4way
Color
Color
Black
黒
颜 色
Gray
灰
颜 色
21.75
37.7
27.7
M
(6188-0517)
37.7
21.8
20.35
F
(6189-0629)
M
(6188-0066)
F(6189-0126)
30.1
30.85
30
24
24.05
25.6
Color
Color
Gray
灰
颜 色
Gray
灰
颜 色
4way
4way
Color
Color
Gray
灰
颜 色
Gray
灰
颜 色
28.4
30.6
43.2
42.6
20.3
18.8
M
(6188-0141)
Plate thickness range for clamp:
t=0.7〜2.2
F
(6189-0381)
F(6189-0372)
21.2
21.4
14.2
M
(6188-0217)
15.5
24
Color
颜 色
Gray
灰
24
Color
颜 色
Gray
灰
TS SEALED SERIES
M
(6188-0282)
Black
黒
颜 色
5way
4way
Color
Color
Gray
灰
颜 色
Gray
灰
颜 色
18.3
37.9
24.1
B- 18
M
(6188-0472)
F
(6189-0685)
M
(6188-0327)
F(6189-0504)
26.2
31.7
24
25.6
Color
28
Gray
灰
颜 色
Color
Gray
灰
颜 色
6way
6way
Color
Color
Gray
灰
颜 色
Gray
灰
颜 色
25.5
23.7
28.2
42.2
M
(6188-0173)
F
(6189-0319)
24
24
37.9
F(6189-0323)
28.5
30.9
Color
Color
Gray
灰
颜 色
Gray
灰
颜 色
7way
6way
颜 色
M
(6188-0175)
21.8
20.8
Color
25.6
Color
Gray
灰
Gray
灰
颜 色
31.4
33.7
43.2
37.7
25.5
25.2
t=0.7〜2.2
M
(6188-0209)
F
(6189-0368)
M
(6188-0067)
F(6189-0127)
36.2
21.8
22.2
30
24
Color
颜 色
Gray
灰
29
Color
颜 色
Gray
灰
4.8mm
(187)
Structure/构造
B- 19
Wire seal
Wire seal
Terminal M
Retainer
Housing M
Terminal M
Retainer
Connector M
Connector F
Connector Seal
Housing F
Retainer
Wire seal
Terminal F
Retainer
Housing F
Wire seal
Connector seal
4.8mm(187)
Terminal F
(S)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
0.3〜0.5
Brass
黄铜
Tin-plated
镀锡
4.8
28.4
0.8
M
(8100-0463)
6
F(8100-0466)
19.5
Cable size(mm2)
Terminal(UNIT : mm)
端子(毫米)
适用电线大小
3.8
Material
材 质
Surface treatment
表面处理
0.3〜0.5
Brass
黄铜
Tin-plated
镀锡
TS SEALED SERIES
Housing M
(M)
(L)
Cable size(mm2)
Cable size(mm2)
0.5〜1.25
适用电线大小
Material
材 质
Surface treatment
表面处理
2.0〜3.0
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
4.8
表面处理
28.4
4.8
0.8
B- 20
M
(8100-0464)
6
0.8
F
(8100-0467)
M
(8100-0465)
6
19.5
Cable size(mm2)
Material
Cable size(mm2)
Surface treatment
表面处理
2.0〜3.0
适用电线大小
Brass
黄铜
Tin-plated
镀锡
材 质
F
(8100-0468)
19.5
0.5〜1.25
适用电线大小
3.8
28.4
Material
3.8
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
Surface treatment
表面处理
4.8mm(187)
电线密封栓
(毫米)
电线密封栓为公端、母端共用。
(M)
(S)
(7165-0347)
(7165-0346)
Cable size(mm2)
适用电线大小
带绝缘层外径
Material
(AVS/0.3)
(AVSS/0.3〜0.85)
(AVSSX・AESSX/0.5〜0.75)
(CAVUS/0.85〜1.25)
Color
颜 色
适用电线大小
φ8
1.4〜2.0
带绝缘层外径
Material
Silicon
硅
Dark Brown
深棕
材 质
Cable size(mm2)
Color
颜 色
(7165-0356)
(7165-0348)
Cable size(mm )
2
适用电线大小
Material
材 质
Color
颜 色
11.7
(LL)
(L)
带绝缘层外径
φ8
2.0〜2.9
Silicon
硅
Dark Green
墨绿
材 质
11.7
(AV/0.5〜1.25)
(AVX・AEX/0.5〜1.25)
(AVS/0.5〜1.25)
(AVSS/1.25〜2.0)
(AVSSX・AESSX/1.25〜2.0)
Cable size(mm )
2
(AV/2.0)
(AVX・AEX/2.0)
(AVS/2.0)
2.9〜3.5
Silicon
硅
Dark Gray
深灰
适用电线大小
φ8
带绝缘层外径
Material
材 质
Color
11.7
颜 色
(AV/3.0)
(AVX・AEX/3.0)
(AVS/3.0)
3.5〜4.1
Silicon
硅
Dark Blue
藏青
φ8
11.7
4.8mm(187)
B- 21
盲塞(毫米)
(7165-0145)
terminal holes.
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
φ8
Material
NBR
材 质
Color
Gray
灰
颜 色
8
1way
4.8mm(187)
Color
Gray
灰
颜 色
24.3
44
Housing(UNIT : mm)
16.4
接插件护套
(毫米)
M
(6188-0083)
端子参照页
B-19
Ref: wire seal No.
电线密封栓参照页
B-20
Ref: Dummy plug No.
盲塞参照页
B-21
Material
材 质
PBT
F(6189-0145)
26.2
34.9
20.2
Color
Gray
灰
颜 色
1way
2way
F
(6189-0413)
13.9
Color
Gray
灰
颜 色
25.5
20.18
28.9
Color
颜 色
Black
黒
23.7
M
(6188-0259)
44
F(6189-0425)
26.5
27.5
28.9
Color
颜 色
Gray
灰
TS SEALED SERIES
3way
Color
Gray
灰
颜 色
25.7
44
32.1
B- 22
M
(6188-0129)
F
(6189-0165)
28.6
34.9
35.9
Color
颜 色
Gray
灰
8.0mm
(312)
Structure/构造
B- 23
Wire seal
Retainer
Terminal M
Retainer
Housing M
Terminal M
Connector M
Connector F
Connector seal
Housing F
Wire seal
Wire seal
Terminal F
Retainer
Housing F
Retainer
Connector seal
8.0mm(312)
Terminal F
(S)
Cable size(mm2)
0.5〜1.25
适用电线大小
带绝缘层外径
Material
材 质
Surface treatment
表面处理
2.0〜2.7
Brass
黄铜
Tin-plated
镀锡
8.0
0.64
M
(8100-0506)
9.2
31.3
F(8100-0451)
Cable size(mm2)
22.4
适用电线大小
Terminal(UNIT : mm)
端子(毫米)
带绝缘层外径
Material
5
材 质
Surface treatment
表面处理
0.5〜1.25
2.0〜2.7
Brass
黄铜
Tin-plated
镀锡
TS SEALED SERIES
Housing M
Wire seal
(M)
(L)
Cable size(mm2)
Cable size(mm2)
2.0〜3.0
适用电线大小
带绝缘层外径
Material
2.6〜4.1
带绝缘层外径
8.0
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
表面处理
表面处理
F
(8100-0452)
Cable size(mm2)
2.0〜3.0
适用电线大小
带绝缘层外径
Material
Surface treatment
表面处理
8.0
31.3
0.64
M
(8100-0508)
F(8100-2980)
Cable size(mm2)
9.2
22.4
2.6〜4.1
5.0〜8.0
适用电线大小
带绝缘层外径
Material
Brass
黄铜
Tin-plated
镀锡
材 质
5
4.4〜5.8
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
M
(8100-0507)
22.4
Material
31.3
0.64
B- 24
9.2
5.0〜8.0
适用电线大小
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
5
4.4〜5.8
Surface treatment
表面处理
8.0mm
(312)
电线密封栓
(毫米)
电线密封栓为公端、母端共用。
(SS)
(S)
(7165-0683)
Cable size(mm2)
适用电线大小
φ 11.5
(AVS・AVX/0.5〜1.25)
(7165-0400)
Cable size(mm2)
适用电线大小
Cable overall diameter(mm) Over 2.0 mm less than 2.9 mm
Material
Material
超过2.0mm在2.9mm以下
Silicon
硅
Dark Brown
深棕
带绝缘层外径
材 质
Color
颜 色
带绝缘层外径
(M)
Color
颜 色
Cable size(mm )
2
适用电线大小
Material
材 质
Color
颜 色
13.5
(L)
(7165-0392)
带绝缘层外径
φ 11.5
3.6〜4.1
Silicon
硅
Dark Gray
深灰
材 质
13.5
(AV/3.0)
(AVX・AEX/3.0)
(AVS/3.0)
(AV/5.0)
(AVX・AEX/5.0)
(AVS/5.0)
φ 11.5
Cable size(mm )
适用电线大小
4.4〜4.9
Silicon
硅
Dark Blue
藏青
(7165-0393)
2
带绝缘层外径
Material
材 质
13.5
Color
颜 色
(AV/8.0)
(AVX・AEX/8.0)
(AVS/8.0)
φ 11.5
5.3〜5.8
Silicon
硅
Black
黒
13.5
8.0mm
(312)
B- 25
盲塞(毫米)
(7165-0180)
terminal holes.
φ 11.5
Material
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
NBR
材 质
Color
9.3
Gray
灰
颜 色
1way
8.0mm
(312)
Color
Gray
灰
颜 色
25.7
49.4
20.2
Housing(UNIT : mm)
接插件护套
(毫米)
M
(6188-0049)
端子参照页
B-23
Ref: wire seal No.
电线密封栓参照页
B-24
Ref: Dummy plug No.
盲塞参照页
B-25
Material
材 质
PBT
F(6189-0101)
29.9
45.3
24
Color
颜 色
Gray
灰
2way
2way
Color
F(6189-0856)
Gray
灰
颜 色
31.6
22.35
60
40.6
35.2
Color
32.2
M
(6188-0096)
颜 色
Gray
灰
F
(6189-0172)
2way
F(6189-6953)
18.85
31.6
33.3
40.6
29
Color
颜 色
Gray
灰
35.2
Color
颜 色
Gray
灰
TS SEALED SERIES
2way
Color
Gray
灰
颜 色
49.4
23
40
B- 26
M
(6188-5295)
F
(6189-7256)
40.5
37.8
43.4
Color
Gray
灰
颜 色
0.64mm, 2.3mm
(025, 090)
Housing(UNIT : mm)
接插件护套(毫米)
端子参照页
[0.64mm] B-03
[2.3mm] B-13
Ref: wire seal No.
电线密封栓参照页
[0.64mm] B-04
[2.3mm] B-14
Ref: Dummy plug No.
盲塞参照页
[0.64mm] B-04
[2.3mm] B-15
TS SEALED SERIES
for HYBRID
10way(6+4)
13way(10+3)
Material
材 质
PBT
F
(6189-7691)
F
(6189-7077)
33.5
26.8
34.55
24
63
35.5
Color
颜 色
Black
黒
26way(23+3)
F
(6189-6934)
33.5
34.55
63
Color
颜 色
Black
黒
Color
颜 色
Gray
灰
4way(2+2)
0.64mm, 4.8mm
(025, 187)
Color
Black
黒
颜 色
30.8
Housing(UNIT : mm)
46.3
接插件护套
(毫米)
22.4
[0.64mm] B-03
[4.8mm] B-19
Ref: wire seal No.
电线密封栓参照页
[0.64mm] B-04
[4.8mm] B-20
Ref: Dummy plug No.
盲塞参照页
[0.64mm] B-04
[4.8mm] B-21
Material
材 质
M
(6188-5103)
B- 27
F(6189-1048)
31.3
PBT
28.9
25.6
No. of way( )corresponds to 0.64mm, 4.8mm, in order from left to right.
24way(22+2)
Color
颜 色
Black
黒
34way(30+4)
F
(6189-7426)
F(6189-6978)
31.7
42
30.2
28.9
76.8
68.7
Color
颜 色
Color
Gray
灰
颜 色
Black
黒
34way(30+4)
34way(30+4)
F(6189-6980)
F
(6189-6979)
42
42
28.9
28.9
68.7
Color
颜 色
68.7
Gray
灰
Color
颜 色
Black
黒
40way(36+4)
34way(30+4)
F
(6189-1160)
F
(6189-6981)
28.9
28.9
42
42
68.7
Color
颜 色
80.2
Gray
灰
Color
颜 色
Gray
灰
46way(42+4)
46way(42+4)
F
(6189-6894)
F
(6189-1136)
28.9
28.9
42
42
80.2
Color
颜 色
Black
黒
80.2
Color
颜 色
Black
黒
TS SEALED SERIES
端子参照页
0.64mm, 2.3mm, 4.8mm
(025, 090, 187)
Housing(UNIT : mm)
接插件护套
(毫米)
B- 28
端子参照页
Ref: wire seal No.
电线密封栓参照页
Ref: Dummy plug No.
盲塞参照页
Material
材 质
[0.64mm]
[2.3mm]
[4.8mm]
[0.64mm]
[2.3mm]
[4.8mm]
[0.64mm]
[2.3mm]
[4.8mm]
B-03
B-13
B-19
B-04
B-14
B-20
B-04
B-15
B-21
52way(42+4+6)
F
(6189-7809)
49.3
28.9
Color
颜 色
Black
黒
Lever Assy
(6911-5948)
95.4
48.7
43.9
F(6189-7094)
42
PBT
No. of way/ ( ) corresponds to 0.64mm, 2.3mm, 4.8mm in order
from left to right.
72.4
42way(36+2+4)
Color
颜 色
Black
黒
80.2
28.9
Color
颜 色
Black
黒
4way(2+2)
2.3mm, 4.8mm
(090, 187)
Color
Gray
灰
颜 色
29.9
Housing(UNIT : mm)
47
接插件护套
(毫米)
25.6
[2.3mm]B-13
[4.8mm]B-19
Ref: wire seal No.
电线密封栓参照页
[2.3mm]B-14(For P6)
[4.8mm]B-20
Ref: Dummy plug No.
盲塞参照页
[2.3mm]B-15(For P6)
[4.8mm]B-21
Material
材 质
M
(6188-0415)
F(6189-0144)
28.3
PBT
22.4
28.9
No. of way/ ( )corresponds to 2.3mm, 4.8mm in order from left to right.
颜 色
Color
Gray
灰
颜 色
5way(3+2)
5way(3+2)
Color
B- 29
Color
Gray
灰
Gray
灰
颜 色
30.9
33.4
50.5
24.4
27.8
M
(6188-0091)
F
(6189-0166)
M
(6188-0101)
44
F(6189-0181)
34.2
28.7
28.2
24.5
28.9
34.9
Color
Color
Gray
灰
颜 色
6way(4+2)
Color
颜 色
Gray
灰
颜 色
11way(8+3)
Color
Gray
灰
颜 色
Gray
灰
41.5
26.9
49
32.55
M
(6188-0187)
F
(6189-0143)
51.9
33.9
M
(6188-0221)
28.3
F(6189-0376)
42.2
27.8
30.7
28.9
28.9
Color
颜 色
Gray
灰
Color
颜 色
Gray
灰
TS SEALED SERIES
端子参照页
4.8mm, 8.0mm
(187, 312)
Housing(UNIT : mm)
B- 30
接插件护套
(毫米)
端子参照页
[4.8mm]B-19
[8.0mm]B-23
Ref: wire seal No.
电线密封栓参照页
[4.8mm]B-20
[8.0mm]B-24
Ref: Dummy plug No.
盲塞参照页
[4.8mm]B-21
[8.0mm]B-25
Material
材 质
3way(1+2)
F(6189-7156)
33.8
PBT
No. of way/( )corresponds to 4.8mm, 8.0mm in order from left to right.
极数/( )内显示 :从左向右为4.8mm 极数、8.0mm 极数
52.5
37.75
Color
颜 色
Black
黒
HE SERIES
Features
The HE connector series is the highly reliable
improved version of the conventional HD
series, with a mechanism that minimizes the
possibility of terminal back out and semiengagement of connectors.
This series consists of 0.64mm, 1.0mm,
2.3mm, 4.8mm and 9.5mm types (0.64mm,
1.0mm, 2.3mm, 4.8mm and 8.0mm types for
the hybrid model) classified according to
terminal size, supporting use in a variety of
control circuits and low power circuits.
◦A
n incompletely inserted terminal is
automatically adjusted to the correct
position by setting a retainer.
◦R
◦A
n extra clip can be attached to the
connector housing to secure it to the
car body, and multiple connectors can
be joined.
◦P
特 点
HE 系列是将以往的 HD 系列改良后,提高了可信
性的接插件。
具有不易发生端子脱落及接插件半嵌合的构造。
按照端子尺寸划分为0.64mm·1.0mm·2.3mm·
4.8mm·9.5mm( 混 合 型 为 0.64mm·1.0mm·
2.3mm·4.8mm·8.0mm),可以应用于各种控制
回路与低功率。
◦未完全插入的端子能够通过安装锁片插入到正
确的位置。
◦在接插件护套上可安装卡钉(卡子)用以固定在
车体上,并且可以将各个接插件相互连接。
◦我们还设计了能适用于印刷电路板的 PCB 接插
件。
HE SERIES for STANDARD
0.64mm
(025)
Structure/构造
C-02
Housing M
Terminal M
Retainer
Before setting retainer
After setting retainer
锁片安装到位前
锁片安装到位后
Housing M
Retainer
Terminal M
Connector M
Housing F
Connector F
Terminal F
锁片安装到位前
锁片安装到位后
Housing F
Retainer
Retainer
Terminal F
0.64mm
(025)
Terminal(UNIT : mm)
端子(毫米)
(S)
(M)
Cable size(mm2)
Cable size(mm2)
0.22〜0.35
适用电线大小
带绝缘层外径
Material
0.95〜1.4
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
表面处理
22.3
0.64
带绝缘层外径
Material
表面处理
F
(8100-4029)
1.25〜1.6
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
M
(8100-4028)
22.3
0.64
M
(8100-4027)
F(8100-4030)
2
Cable size(mm2)
15.5
0.22〜0.35
适用电线大小
带绝缘层外径
Material
材 质
Surface treatment
表面处理
1.5
Cable size(mm2)
15.5
0.5〜0.75
适用电线大小
0.95〜1.4
带绝缘层外径
Material
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
Surface treatment
表面处理
1.25〜1.6
Heat-resistant
copper alloy
Tin-plated
镀锡
2way
0.64mm
(025)
Color
颜 色
Natural
自然色
12.2
34.7
12.2
M
(6098-5070)
F(6098-5071)
Housing(UNIT : mm)
端子参照页
7.7
C-02
19
6.6
Material
材 质
PBT
Color
Natural
自然色
颜 色
4way
3way
F
(6098-5833)
Color
颜 色
Natural
自然色
4.1
12.4
8.8
19
34.7
Color
颜 色
13.2
Natural
自然色
M
(6098-4944)
F(6098-4978)
4.1
10
21
Color
颜 色
Natural
自然色
C-03
HE SERIES
2
1.5
0.5〜0.75
适用电线大小
6way
7way
Color
F(6098-5000)
Natural
自然色
颜 色
4.1
12.4
21
16.6
34.7
Color
17.6
C-04
M
(6098-4943)
Natural
自然色
颜 色
F
(6098-4979)
10way
F(6098-4982)
4.1
7.1
14.4
21
Color
颜 色
Color
Natural
自然色
颜 色
12.9
12.9
M
(6098-4675)
F
(6098-4640)
7.1
M
(6098-4333)
34.7
F(6098-4339)
7.1
15.4
19.8
21
Color
颜 色
21
Color
Natural
自然色
20way
颜 色
23
34.7
18.6
Color
Green
绿
16way
Natural
自然色
颜 色
Color
颜 色
12way
Color
21
13.2
Natural
自然色
颜 色
Natural
自然色
24way
Color
Natural
自然色
颜 色
M
(6098-4589)
F
(6098-4595)
Color
颜 色
Natural
自然色
Natural
自然色
M
(6098-4588)
F(6098-4594)
Color
颜 色
Natural
自然色
34way
Color
颜 色
Natural
自然色
M
(6098-4590)
F
(6098-4596)
C-05
HE SERIES
Color
颜 色
Natural
自然色
1.0mm(040)
Structure/构造
C-06
Housing M
Terminal M
锁片安装到位前
锁片安装到位后
Housing M
Retainer
Retainer
Retainer
Terminal M
Connector M
Connector F
Retainer
Housing F
锁片安装到位前
锁片安装到位后
Housing F
Retainer
Terminal F
Retainer
Retainer
Terminal F
1.0mm
(040)
Terminal(UNIT : mm)
端子(毫米)
(SS)
(S)
Cable size(mm2)
带绝缘层外径
Material
材 质
Surface treatment
表面处理
Cable size(mm2)
0.22〜0.35
适用电线大小
0.95〜1.1
带绝缘层外径
Brass
黄铜
Tin-plated
镀锡
Material
表面处理
F
(8100-4308)
带绝缘层外径
15.9
Material
材 质
Surface treatment
表面处理
M
(8100-2972)
F(8100-2971)
Cable size(mm2)
0.22〜0.35
适用电线大小
23.8
1
0.3〜0.85
适用电线大小
2.55
0.95〜1.1
Heat-resistant
copper alloy
Tin-plated
镀锡
带绝缘层外径
Material
15.9
1.8
材 质
Surface treatment
表面处理
1.4〜1.8
Heat-resistant
copper alloy
Tin-plated
镀锡
2way
1.0mm(040)
F(6098-5888)
9.4
20.6
7.5
Color
颜 色
Light Gray
浅灰
5way
Housing(UNIT : mm)
F(6098-2779)
接插件护套
(毫米)
9.65
端子参照页
C-06
Material
材 质
PBT
16.7
Color
颜 色
6way
Color
颜 色
20.6
8way
F(6098-2782)
Natural
自然色
9.65
14.45
34.4
22.6
24.2
20.6
Color
颜 色
M
(6098-2780)
F
(6098-2781)
9.65
19.2
Natural
自然色
20.6
Color
颜 色
Natural
自然色
Natural
自然色
C-07
HE SERIES
Cable size(mm2)
1.8
Surface treatment
23.8
1
1.4〜1.8
Brass
黄铜
Tin-plated
镀锡
材 质
M
(8100-4307)
2.55
0.3〜0.85
适用电线大小
13way
Color
17way
Color
Natural
自然色
颜 色
Natural
自然色
颜 色
18.1
18.1
34.4
32.6
27.6
C-08
M
(6098-2788)
F
(6098-2784)
M
(6098-3369)
34.4
F(6098-2785)
10.8
10.8
29.2
20.6
24.2
Color
Color
Natural
自然色
颜 色
颜 色
21way
Color
Natural
自然色
颜 色
18.1
34.4
37.6
M
(6098-2789)
F
(6098-2764)
10.8
34.2
20.6
Color
颜 色
Natural
自然色
20.6
Natural
自然色
2.3mm
(090)
Structure/构造
Retainer
Housing M
锁片安装到位前
锁片安装到位后
Housing M
HE SERIES
Retainer
Terminal M
Retainer
Retainer
Terminal M
Connector M
Connector F
Retainer
Housing F
锁片安装到位前
锁片安装到位后
Retainer
Housing F
Terminal F
Retainer
Retainer
Terminal F
2.3mm(090)
(S)
Cable size(mm2)
0.3〜0.5
适用电线大小
带绝缘层外径
Material
1.4〜2.1
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
表面处理
2.3
M
(8100-1571)
27.7
F(8100-1470)
Cable size(mm2)
适用电线大小
2.4
Terminal(UNIT : mm)
端子(毫米)
C-09
3
21
带绝缘层外径
Material
材 质
Surface treatment
表面处理
0.3〜0.5
1.4〜2.1
Brass
黄铜
Tin-plated
镀锡
(M)
(L)
Cable size(mm2)
带绝缘层外径
Material
Surface treatment
表面处理
2.0〜2.9
带绝缘层外径
Material
2.3
27.7
F
(8100-1472)
Cable size(mm2)
3
带绝缘层外径
21
Material
材 质
Surface treatment
表面处理
Surface treatment
表面处理
2.3
27.7
M
(8100-1572)
F(8100-1471)
Cable size(mm2)
0.5〜1.25
适用电线大小
2.6〜3.1
Brass
黄铜
Tin-plated
镀锡
材 质
M
(8100-1573)
2.4
2.0
适用电线大小
Brass
黄铜
Tin-plated
镀锡
材 质
C-10
Cable size(mm2)
0.5〜1.25
适用电线大小
2.0〜2.9
Brass
黄铜
Tin-plated
镀锡
2.0
适用电线大小
2.4
3
带绝缘层外径
21
Material
材 质
Surface treatment
表面处理
2.6〜3.1
Heat-resistant
copper alloy
Tin-plated
镀锡
2way
2.3mm(090)
Color
Natural
自然色
颜 色
16.3
36.9
14.3
M
(6098-4901)
F(6098-4069)
Housing(UNIT : mm)
接插件护套
(毫米)
端子参照页
C-09
Material
材 质
PBT
7.0
24.5
10.9
Color
Natural
自然色
颜 色
3way
4way
Color
Natural
自然色
颜 色
Color
Natural
自然色
颜 色
16.3
13.15
37.4
37.4
21.3
17.3
M
(6098-5049)
F
(6098-4071)
6.85
M
(6098-4902)
F(6098-4073)
6.85
13.9
24
17.9
Color
颜 色
Natural
自然色
24
Color
颜 色
Natural
自然色
5way
6way
Color
Color
Natural
自然色
颜 色
Sky Blue
天蓝
颜 色
13.15
17.7
37.4
25.3
M
(6098-4664)
F
(6098-4669)
38.4
23.9
M
(6098-1373)
F(6098-1377)
C-11
HE SERIES
11.3
6.85
24
21.9
20.5
Color
24
Color
Natural
自然色
颜 色
颜 色
8way
Sky Blue
天蓝
8way
Color
F(6098-1378)
Natural
自然色
颜 色
11.3
17.7
24.5
38.4
27.4
24
Color
颜 色
M
(6098-4661)
Green
绿
F
(6098-4670)
10way
F(6240-5378)
11.3
11.3
24
24
28
Color
24
Natural
自然色
颜 色
Color
颜 色
14way
Natural
自然色
16way
Color
F(6098-3563)
Natural
自然色
颜 色
11.3
17.7
40
38.4
39.4
24
Color
颜 色
M
(6098-4662)
Natural
自然色
F
(6098-4050)
20way
F(6098-1380)
11.3
11.3
36
24
52.5
Color
颜 色
Natural
自然色
24
Color
颜 色
Green
绿
4.8mm(187)
C-12
(S)
4.8mm(187)
Cable size(mm2)
适用电线大小
带绝缘层外径
Material
材 质
Surface treatment
表面处理
0.3
1.4〜1.9
Brass
黄铜
Tin-plated
镀锡
26.7
4.8
M
(8100-1506)
F(8100-1507)
Cable size(mm2)
3.4
0.3
适用电线大小
Terminal(UNIT : mm)
6
18
Material
表面处理
(M)
(L)
Cable size(mm )
2
适用电线大小
带绝缘层外径
Material
材 质
Surface treatment
Cable size(mm2)
0.5〜1.25
适用电线大小
1.6〜2.9
带绝缘层外径
Material
Brass
黄铜
Tin-plated
镀锡
材 质
26.7
Surface treatment
表面处理
2.0〜3.0
2.6〜3.8
Brass
黄铜
Tin-plated
镀锡
26.7
4.8
4.8
M
(8100-0664)
F
(8100-0606)
Cable size(mm2)
适用电线大小
3.4
带绝缘层外径
6
1.4〜1.9
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
Surface treatment
端子(毫米)
表面处理
带绝缘层外径
18
Material
材 质
Surface treatment
表面处理
0.5〜1.25
M
(1500-0166)
Cable size(mm2)
3.4
适用电线大小
1.6〜2.9
Heat-resistant
copper alloy
Tin-plated
镀锡
F(8100-0782)
带绝缘层外径
6
18
Material
材 质
Surface treatment
表面处理
2.0〜3.0
2.6〜3.8
Heat-resistant
copper alloy
Tin-plated
镀锡
2way
4.8mm(187)
Color
Natural
自然色
颜 色
18.1
38.4
19.1
M
(6098-5120)
F(6098-5119)
HE SERIES
Housing(UNIT : mm)
接插件护套
(毫米)
端子参照页
8.25
C-13
24.1
15.7
Material
材 质
PBT
Color
Natural
自然色
颜 色
4way
5way
F
(6098-4971)
Color
Natural
自然色
颜 色
8.25
21.3
29.3
24.1
Color
颜 色
C-13
38.4
33.3
Natural
自然色
M
(6098-4663)
F(6098-4667)
14.4
29
9.9
9
22.1
Color
颜 色
Natural
自然色
9.5mm(375)
C-14
(S)
9.5mm(375)
F(8240-0152)
Cable size(mm2)
2.0〜3.0
适用电线大小
5
带绝缘层外径
27.5
11.1
Material
2.6〜4.1
Copper alloy
铜合金
Tin-plated
镀锡
材 质
Surface treatment
表面处理
(M)
F(8240-0153)
Cable size(mm2)
5.0〜8.0
适用电线大小
带绝缘层外径
Terminal(UNIT : mm)
Material
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
Surface treatment
端子(毫米)
4.4〜5.8
表面处理
(L)
F(8240-0154)
Cable size(mm2)
10.0
适用电线大小
带绝缘层外径
Material
材 质
Surface treatment
表面处理
6.5〜6.9
Heat-resistant
copper alloy
Tin-plated
镀锡
1way
9.5mm(375)
rib A
F(6098-4973)
10.95
13.9
32.4
Color
颜 色
Housing(UNIT : mm)
Natural
自然色
1way
rib B
F(6098-4974)
接插件护套
(毫米)
端子参照页
C-15
Material
材 质
PBT
10.95
13.9
32.4
Color
颜 色
Black
黒
1way
rib C
2way
F
(6098-4975)
10.95
10.95
13.9
F(6098-4977)
32.4
26.2
Color
颜 色
Dark Green
墨绿
32.4
Color
颜 色
Green
绿
C-15
HE SERIES
0.64mm, 2.3mm
(025, 090)
Housing(UNIT : mm)
C-16
接插件护套(毫米)
端子参照页
[0.64mm] C-02
[2.3mm] C-09
HE SERIES
for HYBRID
12way(6+6)
13way(9+4)
Color
Material
材 质
Color
Natural
自然色
颜 色
颜 色
PBT
Natural
自然色
23.5
15.4
42.9
28
M
(6098-6161)
F
(6098-6162)
37.4
27.9
M
(6098-5180)
F(6098-6562)
12.35
24
19.7
Color
Color
Natural
自然色
颜 色
20way(16+4)
18way(9+9)
Color
Color
Natural
自然色
颜 色
Natural
自然色
颜 色
颜 色
Natural
自然色
12.9
23.4
42.9
39.4
37.4
22.9
M
(6098-4908)
F
(6098-6478)
F(6098-4597)
7.1
17.35
19.7
M
(6098-4591)
36.2
24
Color
颜 色
Natural
自然色
24
Color
颜 色
Natural
自然色
23way(14+9)
Color
28way(24+4)
Color
Natural
自然色
颜 色
Natural
自然色
颜 色
15.3
20.4
M
(6098-4707)
48.2
42.9
27.3
F
(6098-6559)
M
(6098-4725)
37.4
F(6098-4726)
HE SERIES
7.1
17.2
24.1
45
24
Color
颜 色
Natural
自然色
C-17
24
Color
颜 色
Natural
自然色
9way(2+7)
1.0mm, 2.3mm
(040, 090)
F(6098-4075)
7.2
34.7
24
Color
颜 色
C-18
Natural
自然色
Housing(UNIT : mm)
10way(2+8)
接插件护套
(毫米)
端子参照页
Material
材 质
[1.0mm]
[2.3mm]
C-06
C-09
F(6098-4076)
7.2
PBT
39.1
24
No. of way/( )corresponds to 1.0mm, 2.3mm, in order from left to right.
极数/( )内显示 :从左向右为1.0mm 极数、2.3mm 极数
Color
颜 色
Natural
自然色
10way(8+2)
10way(6+4)
F(6098-3600)
F
(6098-4666)
10.8
12.5
24
24
17.8
Color
颜 色
22.9
Natural
自然色
14way(10+4)
Color
颜 色
Natural
自然色
23way(19+4)
F
(6098-3601)
10.8
F(6098-3571)
10.8
29.4
24
24
40.2
Color
颜 色
Natural
自然色
23way(19+4)
F
(6098-4367)
10.8
40.2
24
Color
颜 色
Brown
棕
Color
颜 色
Natural
自然色
12way(10+2)
1.0mm, 4.8mm
(040, 187)
Color
Natural
自然色
颜 色
20.2
32.6
Housing(UNIT : mm)
M
(6098-3370)
37.4
F(6098-2786)
端子参照页
Material
材 质
[1.0mm]
[4.8mm]
C-06
C-13
12.9
PBT
29.2
No. of way/( )corresponds to 1.0mm, 4.8mm, in order from left to right.
极数/( )内显示 :从左向右为1.0mm 极数、4.8mm 极数
14way(10+4)
F
(6098-4017)
12.9
36.7
HE SERIES
接插件护套
(毫米)
21.1
Color
颜 色
Natural
自然色
C-19
21.1
Color
颜 色
Natural
自然色
8way(6+2)
2.3mm, 4.8mm
(090, 187)
Color
Natural
自然色
颜 色
21.05
38.4
31.4
C-20
Housing(UNIT : mm)
M
(6098-5218)
F(6098-5217)
接插件护套
(毫米)
端子参照页
[2.3mm]
[4.8mm]
C-09
C-13
19.6
Material
材 质
PBT
28
24
14way(12+2)
Color
Color
颜 色
16way(14+2)
F(6950-1054)
Natural
自然色
颜 色
Natural
自然色
13.2
19.65
47.5
38.4
43.4
24
Color
颜 色
M
(6098-4660)
F
(6098-3565)
Green
绿
18way(14+4)
F(6950-1055)
13.2
13.2
40
24
55.5
Color
颜 色
Natural
自然色
20way(16+4)
F
(6950-1056)
13.2
59.5
24
Color
颜 色
Green
绿
24
Color
颜 色
Green
绿
(S)
8.0mm(312)
Cable size(mm2)
0.5〜1.25
适用电线大小
带绝缘层外径
Material
1.6〜2.9
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
表面处理
32.3
8
0.8
M
(8100-0520)
F(8100-0707)
带绝缘层外径
Terminal(UNIT : mm)
Material
5
Surface treatment
表面处理
(M)
(L)
Cable size(mm2)
材 质
Surface treatment
表面处理
Cable size(mm2)
2.0〜3.0
适用电线大小
Material
5.0〜8.0
适用电线大小
2.6〜4.1
带绝缘层外径
Brass
黄铜
Tin-plated
镀锡
32.3
8
Material
材 质
Surface treatment
表面处理
4.4〜5.8
Brass
黄铜
Tin-plated
镀锡
M
(8100-0521)
0.8
F
(8100-0706)
Cable size(mm2)
23.4
5
2.0〜3.0
适用电线大小
带绝缘层外径
Material
材 质
Surface treatment
表面处理
32.3
8
0.8
9.2
1.6〜2.9
Brass
黄铜
Tin-plated
镀锡
材 质
端子(毫米)
带绝缘层外径
0.5〜1.25
适用电线大小
23.4
HE SERIES
Cable size(mm2)
9.2
M
(8100-0522)
5.0〜8.0
适用电线大小
23.4
2.6〜4.1
Brass
黄铜
Tin-plated
镀锡
F(8100-1553)
Cable size(mm2)
9.2
带绝缘层外径
Material
5
4.4〜5.8
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
Surface treatment
表面处理
6way(4+2)
4.8mm, 8.0mm
(187, 312)
Color
Natural
自然色
颜 色
22.9
48.8
34.7
Housing(UNIT : mm)
M
(6098-3567)
F(6098-3569)
接插件护套
(毫米)
端子参照页
Material
材 质
[4.8mm]
[8.0mm]
C-13
C-21
15.6
PBT
27.8
31.3
No. of way/( )corresponds to 4.8mm, 8.0mm, in order from left to right.
Color
颜 色
Natural
自然色
C-21
1.0mm
(040)
C-22
Housing(UNIT : mm)
HE SERIES
for PCB
接插件护套(毫米)
Material
材 质
PBT G30
(Vertical type)
(垂直)
13way
M
(6098-3239)
●Detailed dimension
详细尺寸
17.2
6098-2784(C-08)
Color
Natural
自然色
母端接插件产品号码
颜 色
电路板推荐尺寸
24.5
27.6
1.0mm, 2.3mm
(040, 090)
Housing(UNIT : mm)
接插件护套
(毫米)
Material
材 质
PBT G30
(Vertical type)
(垂直)
23way
M
(6098-3572)
●Detailed dimension
详细尺寸
17.2
6098-3571(C-19)
Color
Natural
自然色
母端接插件产品号码
颜 色
43.6
21.1
电路板推荐尺寸
1.0mm, 4.8mm
(040, 187)
C-23
HE SERIES
Housing(UNIT : mm)
接插件护套
(毫米)
Material
材 质
PBT G30
(Vertical type)
(垂直)
14way
M
(6098-4018)
●Detailed dimension
详细尺寸
19.3
6098-4017(C-20)
Color
Natural
自然色
母端接插件产品号码
颜 色
22.1
电路板推荐尺寸
40.1
2.3mm(090)
Housing(UNIT : mm)
接插件护套
(毫米)
Material
材 质
PBT G30
(Vertical type)
(垂直)
6way
M
(6098-3616)
●Detailed dimension
详细尺寸
16.9
母端接插件产品号码
Color
颜 色
6098-1377(C-11)
Sky Blue
天蓝
电路板推荐尺寸
22.9
22.1
C-24
HE SERIES
COMMON USE
PARTS
Body fastening clamp(mm)
The clamp can be installed to connector M, if necessary, to fasten
into the body side hole.
公端接插件在需要时可以安装卡钉用以固定在车体上。
(6810-1203)
Clamp fitting hole size(mm)
适合孔穴尺寸
Clamp fitting thickness(mm)
卡钉适合板厚
Material
材 质
Color
颜 色
(6810-1217)
φ7
适合孔穴尺寸
t=0.65〜1.6
卡钉适合板厚
11.8
Material
6 Nylon
12
Red
红
材 质
Color
颜 色
φ7
t=1.6〜2.6
12.8
6 Nylon
Brown
棕
12
(6810-1204)
适合孔穴尺寸
卡钉适合板厚
Material
材 质
Color
颜 色
(6810-1462)
φ10
适合孔穴尺寸
t=0.65〜1.6
卡钉适合板厚
11.8
Material
6 Nylon
Natural
自然色
12
材 质
Color
颜 色
6×12(Square hole)
t=0.65〜1.6
11.8
6 Nylon
12
Orange
橙
(6910-0119)
14.8
Bracket direction
插入支架的方向
Material
材 质
Color
颜 色
Connector mating direction
接插件嵌合方向
6 Nylon
Connector M can be accoupled with clamp, if necessary, to
fasten to the body side bracket.
17.2
Red
红
(6910-0120)
(Bracket type)(mm)
7.2
14.8
Bracket direction
插入支架的方向
Material
材 质
Color
颜 色
Anti clock wise
接插件嵌合的反方向
7.2
6 Nylon
Natural
自然色
17.2
HV/HVG SEALED SERIES
Features
The HV sealed connector series is an
improved version of the existing HX sealed
connector series and it is a highly reliable
connector series.
Also the HVG sealed series is what is added
a finger holding portion to the side wall of
the female connector of the HV sealed
se r ies so as to imp rov ing mat t ing
performance. It has a mechanism that
detects terminal incomplete insertion.
◦ T he connector mechanism only allows
特 点
HV 防水系列是将以往的 HX 防水系列改良后,提
高了可信性的接插件系列。
此外,HVG 防水系列在 HV 防水系列的母端接插
件的侧壁上还增加了指扣,提高了接插件插入作
业的操作性。
具备检测端子插入不到位的构造。
◦具有当端子在半插入状态时,锁片无法组装到
位的检知构造。
◦接插件可以直接固定在车体支架上。
HV/HVG SEALED SERIES for STANDARD
1.0mm
(040)
Structure/构造
Retainer M
D- 02
Connector M
Wire seal
Terminal M
Connector M
Connector F
Connector seal
Housing F
Wire seal
Retainer F
Terminal F
1.0mm
(040)
1.0mm
(040)
电线密封栓(毫米)
Ref; 1.0mm Wire Seals detail
1.0mm电线密封栓参照页
Terminal(UNIT : mm)
SS
(7165-1075)
S
(7165-0621)
端子(毫米)
M
(7165-0622)
Ref; 1.0mm Terminal detail
1.0mm端子参照页
S M(8100-3177)
E-02
M M(8100-3178)
E-02
F
(8100-3067)
F
(8100-3068)
E-03
E-03
E-03
E-02
E-02
电线密封栓为公端、母端共用。
1.0mm(040)
盲塞(毫米)
Ref; 1.0mm Dummy plug detail
1.0mm盲塞参照页
(7165-0432)
D- 03
E-04
terminal holes.
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
2way
1.0mm
(040)
F(6189-7036)
19.3
7.5
15.4
9.4
Retainer No.
(6918-1835)
24.5
Housing(UNIT : mm)
Color
Black
黒
颜 色
接插件护套
(毫米)
端子参照页
E-02
Ref: wire seal No.
电线密封栓参照页
E-03
Ref: Dummy plug No.
盲塞参照页
E-04
Material
材 质
PBT
F(6189-7052)
7.5
15.7
9.4
19.3
Retainer No.
(6918-1835)
24.5
Color
(Rib difference)
(Rib差异)
3way
F(6189-7058)
Black
黒
颜 色
7.5
15.7
13.5
35.7
20.1
17.7
23.4
Retainer No.
(6918-1833)
24.5
Color
颜 色
M
(6188-4775)
F
(6189-7037)
7.5
15.4
13.5
23.4
Dark Gray
深灰
颜 色
3way
Color
(Rib difference)
(Rib差异)
2way
24.5
NOTE1)
Color
颜 色
Retainer No.
(6918-1833)
Black
黒
Dark Gray
深灰
4way
5way
Color
F(6189-6909)
Black
黒
颜 色
7.5
15.7
21.7
30.3
38.3 23.6
17.4
24.5
NOTE1)
Color
Black
黒
颜 色
M
(6188-4776)
Retainer No.
(6918-2128)
F
(6189-7039)
D- 04
13.2
21.4
10.4
19.3
26.1
Retainer No.
(6918-2810)
NOTE1)
Color
Black
黒
颜 色
10way
6way
Color
Color
Black
黒
颜 色
Black
黒
颜 色
21.5
38.3
23.8
13.1
35.7
31.8
26.5
26.25
Retainer No.
(6918-2804)
M
(6188-4908)
F(6189-7040)
13.2
21.4
14.5
23.4
26.1
NOTE1)
Color
颜 色
NOTE1) HV SEALED SERIES
Retainer No.
(6918-2913)
Black
黒
M
(6181-6481)
F
(6189-6906)
12.7
27.5
40.65
26.1
Retainer No.
(6918-2806)
24.5
Color
颜 色
Black
黒
HX SEALED SERIES
Features
The HX sealed connector series is the highly
rel iable imp roved ve r s ion of the
conventional HW sealed series, with a
mechanism that detects when terminals are
not inserted completely.
This series consists of 1.0mm・1.5mm・2.3mm
types (0.64mm・1.0mm・1.5mm・2.3mm・4.8mm
types for the hybrid model) classified
according to terminal size, supporting use in
a variety of control circuits and low power
circuits.
◦ T he hybrid model can be directly
secured to a bracket on the car body,
but this is only possible when the locking
mechanism ensures the connectors are
completely engaged, preventing semiengagement.
特 点
HX 系列是将以往的 HW 系列改良后、提高了可信
性的接插件。
具有检测端子插入不足的结构。
按照端子尺寸划分为1.0mm·1.5mm·2.3mm
(混
合 为 0.64mm · 1.0mm · 1.5mm · 2.3mm·
4.8mm),可以应用于各种控制回路与低功率回路。
◦拥有当端子在半插入状态时,锁片无法组装到
位的检知构造。
◦混合型的接插件具有在未完全嵌合的状态下,
无法固定到车体支架上的锁定构造。
◦混合型的接插件可以直接固定在车体的支架上。
HX SEALED SERIES for STANDARD
1.0mm
(040)
Structure/构造
Retainer M
E- 02
Connector M
Wire seal
Terminal M
Connector M
Connector F
Connector seal
Housing F
Wire seal
Retainer F
Terminal F
1.0mm
(040)
Terminal(UNIT : mm)
端子(毫米)
(M)
(S)
Cable size(mm )
2
Cable size(mm2)
0.3〜0.5
适用电线大小
带绝缘层外径
Material
Surface treatment
表面处理
1.4〜2.0
Material
24
1
表面处理
F
(8100-3067)
24
1
M
(8100-3178)
F(8100-3068)
2.2
2.2
Cable size(mm2)
17
适用电线大小
带绝缘层外径
Material
2
1.4〜2.0
Surface treatment
表面处理
0.75〜1.25
适用电线大小
17
带绝缘层外径
Material
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
E- 03
Cable size(mm2)
0.3〜0.5
1.8〜2.2
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
Surface treatment
表面处理
1.0mm
(040)
(SS)
(7165-1075)
Cable size(mm )
2
电线密封栓
(毫米)
适用电线大小
带绝缘层外径
Material
材 质
Color
电线密封栓为公端、母端共用。
颜 色
(S)
(AVSS/0.3)
(AVSSX/0.3)
(AVSSH/0.3)
(CHFUS/0.35)
(CHFS/0.5)
1.1〜1.6
Silicon
硅
Orange
橙
适用电线大小
带绝缘层外径
Material
材 质
Color
颜 色
5.7
(M)
(7165-0621)
Cable size(mm2)
φ 4.1
(AVS/0.3)
(AVSS/0.5)
(AVSSX/0.5)
(AVSSH/0.5)
(CHFS/0.75)
φ 4.1
适用电线大小
1.6〜1.9
Silicon
硅
Light Green
淡绿
(7165-0622)
Cable size(mm2)
带绝缘层外径
Material
材 质
5.7
Color
颜 色
(AVS/0.5)
(AVS/0.85)
(AVSS/0.75〜1.25)
(AVSSX/0.75〜1.25)
(AVSSH/0.75〜1.25)
(AVX/0.5)
(AVX/0.75)
(CHFS/1.0)
φ 4.1
1.8〜2.2
Silicon
硅
Violet
紫
5.7
HX SEALED SERIES
2
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
Surface treatment
M
(8100-3177)
2.2
1.8〜2.2
带绝缘层外径
Brass
黄铜
Tin-plated
镀锡
材 质
0.75〜1.25
适用电线大小
2.2
1.0mm(040)
盲塞(毫米)
E- 04
(7165-0432)
terminal holes.
φ4
Material
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
材 质
Color
颜 色
NBR
Black
黒
6
1way
1.0mm(040)
Color
颜 色
Black
黒
35.7
15.2
17.55
Housing(UNIT : mm)
接插件护套
(毫米)
M
(6188-0657)
端子参照页
E-02
Ref: wire seal No.
电线密封栓参照页
E-03
Ref: Dummy plug No.
盲塞参照页
E-04
Material
材 质
PBT
16.4
7.5
5.3
15.4
颜 色
Color
Black
黒
颜 色
(Rib difference)
(Rib差异)
2way
Color
Black
黒
颜 色
35.7
16
M
(6188-0589)
7.5
Retainer No.
(6918-1835)
Color
颜 色
Black
黒
35.7
16
M
(6188-0590)
17.7
F(6189-0891)
7.5
15.4
9.4
24.5
Dark Gray
深灰
17.7
F
(6189-0890)
15.4
17.6
Retainer No.
(6918-1979)
24.5
2way
Color
F(6189-0940)
9.4
17.6
24.5
Retainer No.
(6918-1835)
Color
颜 色
Dark Gray
深灰
3way
(Rib difference)
(Rib差异)
3way
Color
F(6189-0968)
Black
黒
颜 色
7.5
17.7
20.1
13.5
24.5
35.7
21.7
Retainer No.
(6918-1833)
15.4
Color
Black
黒
颜 色
M
(6188-4739)
F
(6189-0887)
5way
F(6189-1081) E 05
7.5
13.5
24.5
21.7
Retainer No.
(6918-1833)
Color
7.5
15.7
21.7
30.1
24.5
Black
黒
颜 色
Retainer No.
(6918-2128)
Color
Black
黒
颜 色
7way
6way
Color
F
(6189-0855)
Black
黒
颜 色
7.5
16
35.7
32.8
18.1
29.9
38.5
24.5
Retainer No.
(6918-1762)
Color
颜 色
M
(6188-0658)
F
(6189-1012)
7.5
15.7
25.8
34.2
24.5
Retainer No.
(6918-2056)
Color
颜 色
Black
黒
Black
黒
HX SEALED SERIES
15.4
HX SEALED SERIES for 23way and 33way
1.0mm
(040)
Structure/构造
Dummy Plug
Terminal F
E- 06
Retainer M
Housing F
Housing M
Retainer F
Terminal M
Housing F
Housing F
(Lock Type)
Joint Connector
Housing M
(Lever Type)
Housing F
1.0mm
(040)
Terminal(UNIT : mm)
端子(毫米)
(S)
(M)
Cable size(mm2)
Cable size(mm2)
0.3〜0.5
适用电线大小
Material
材 质
Surface treatment
表面处理
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
材 质
27.75
1
M
(8100-3508)
F
(8100-3082)
Surface treatment
表面处理
0.75〜1.25
Heat-resistant
copper alloy
Tin-plated
镀锡
27.75
1
M
(8100-3507)
F(8100-3083)
E- 07
17.25
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
0.3〜0.5
17.25
2
Cable size(mm2)
0.75〜1.25
适用电线大小
Material
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
Surface treatment
表面处理
1.0mm(040)
Heat-resistant
copper alloy
Tin-plated
镀锡
(6914-0050)
Material
PP
材 质
Color
颜 色
20.6
φ 1.5
Brown
棕
盲塞(毫米)
terminal holes.
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
23way
1.0mm
(040)
Color
Black
黒
颜 色
40.3
19.5
23.3
32.7
58
Retainer No.
(6918-2131)
Housing(UNIT : mm)
M
(6188-0660)
F(6189-1082)
接插件护套
(毫米)
30.4
端子参照页
E-07
Ref: Dummy plug No.
盲塞参照页
E-07
Material
材 质
PBT
19.1
34.1
32.3
Retainer No.
(6918-2132)
47.25
Color
颜 色
Black
黒
HX SEALED SERIES
2
23way
Joint Connector
Coupling circuit is connected with busbers as shown gray hatched cavities.
E- 08
M
(6188-4787)
Color
39.7
Black
黒
颜 色
38.3
39.7
39.7
M
(6188-4789)
Color
38.3
Dark Gray
深灰
颜 色
39.7
39.7
M
(5010-8627)
Color
38.3
Dark Blue
藏青
颜 色
39.7
39.7
M(5011-1590)
Color
38.3
Brown
棕
颜 色
39.7
39.7
M
(5011-6687)
Color
38.3
Blue
蓝
颜 色
39.7
F
(6189-1082)
Lever
Lock
30.4
F
(6189-6914)
27.8
19.1
34.1
32.3
19.1
27.8
32.3
Retainer No.
(6918-2132)
47.25
Color
颜 色
Black
黒
Retainer No.
(6918-2132)
42.9
Color
颜 色
Black
黒
33way
(Rib difference)
(Rib差异)
33way
Color
Color
Black
黒
颜 色
Dark Gray
深灰
颜 色
51.3
51.3
19.5
40.5
19.5
23.3
44.3
40.5
Retainer No.
(6918-2103)
Retainer No.
(6918-2103)
M
(6188-0697)
F
(6189-1050)
30.4
M
(6188-0698)
E- 09
19.1
40.1
34.1
Retainer No.
(6918-2104)
Color
Retainer No.
(6918-2104)
55.05
Black
黒
颜 色
Color
Dark Gray
深灰
颜 色
Bracket Holder
Bracket Holder
(6920-0886)
(6920-0861)
25.7
25.7
Color
颜 色
87.5
45.8
51
Color
Black
黒
颜 色
Bracket Holder
Black
黒
51
Bracket Holder
(6920-2376)
(6920-2377)
25.7
25.7
77.6
Color
颜 色
Dark Blue
藏青
78.6
Color
60.9
颜 色
Bracket Holder
Black
黒
Bracket Holder
(6920-0884)
Color
颜 色
60.9
Black
黒
40.3
(6920-2466)
25.8
9.8
Color
颜 色
Black
黒
40.3
25.7
HX SEALED SERIES
40.1
34.1
F(6189-1051)
30.4
19.1
55.05
23.3
44.3
HX SEALED SERIES 22way Joint Connector
HYBRID 0.64mm,1.0mm(025, 040)
Structure/构造
Dummy Plug
E- 10
Joint Connector
Terminal F
Housing F
Retainer F
(Lever Type)
(Lock Type)
Retainer F
(Lever Type)
Housing F
(Lock Type)
Dummy Plug
Terminal F
Joint Connector
0.64mm(025)
(SS)
F(8240-0408)
Cable size(mm2)
Terminal(UNIT : mm)
端子(毫米)
适用电线大小
Material
材 质
Surface treatment
表面处理
AVSSH0.22
Heat-resistant
copper alloy
Tin-plated
镀锡
1.96
15.8
(S)
(M)
F
(8240-0409)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
AVSSH0.3〜0.5
Heat-resistant
copper alloy
Tin-plated
镀锡
F(8240-0410)
Cable size(mm2)
1.96
1.0mm
(040)
15.8
适用电线大小
Material
材 质
Surface treatment
表面处理
AVSSH0.75
Heat-resistant
copper alloy
Tin-plated
镀锡
1.96
15.8
(S)
F(8240-0411)
适用电线大小
Material
材 质
Surface treatment
表面处理
AVSSH0.3
〜AVSSH0.5
Heat-resistant
copper alloy
Tin-plated
镀锡
2
16
(M)
F(8240-0412)
Cable size(mm2)
Terminal(UNIT : mm)
端子(毫米)
适用电线大小
Material
材 质
Surface treatment
表面处理
AVSSH0.75
〜AVSSH1.25
Heat-resistant
copper alloy
Tin-plated
镀锡
2
0.64mm,1.0mm
(025,040)
(6914-0127)
Material
材 质
Color
颜 色
盲塞(毫米)
terminal holes.
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
16
PBT
Blue
蓝
φ 1.7
13.4
HX SEALED SERIES
Cable size(mm2)
E- 11
0.64mm,1.0mm
(025,040)
Housing(UNIT : mm)
接插件护套
(毫米)
E- 12
端子参照页
[0.64mm] E-10
[1.0mm] E-11
Ref: Dummy plug No.
盲塞参照页
[0.64mm] E-11
[1.0mm] E-11
Material
材 质
PBT
22way (10+12)
Joint Connector
58.9
M
(5011-6818)
Color
Brown
棕
颜 色
32.5
M(5011-7740)
Color
39.35
58.9
Black
黒
颜 色
32.5
58.9
M
(5011-7860)
Color
Dark Gray
深灰
颜 色
39.35
32.5
F
(6189-7264)
39.35
Lever
Lock
35.7
30.4
18.1
28.3
33.7
43.3
Retainer No.
(6918-3166)
Color
颜 色
Black
黒
F
(6189-7263)
18.1
28.3
27.8
30.4
Retainer No.
(6918-3166)
Color
颜 色
Black
黒
1.5mm(060)
Structure/构造
Terminal M
E- 13
Housing F
Terminal F
1.5mm
(060)
Terminal(UNIT : mm)
端子(毫米)
HX SEALED SERIES
Housing M
(SS)
(S)
Cable size(mm2)
Cable size(mm2)
0.13〜0.22
适用电线大小
Material
材 质
Surface treatment
表面处理
0.3〜0.5
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
材 质
1.5
M
(8230-5306)
22.35
F
(8240-0489)
Surface treatment
表面处理
Brass
黄铜
Tin-plated
镀锡
22.35
1.5
M
(8230-5307)
F(8240-0490)
E- 14
15.5
2.6
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
0.13〜0.22
15.5
Cable size(mm2)
适用电线大小
Material
Heat-resistant
copper alloy
Tin-plated
镀锡
(M)
材 质
Surface treatment
表面处理
0.3〜0.5
Heat-resistant
copper alloy
Tin-plated
镀锡
(L)
Cable size(mm )
2
Cable size(mm2)
0.75〜1.25
适用电线大小
Material
材 质
Surface treatment
表面处理
Material
Brass
黄铜
Tin-plated
镀锡
15.5
2.0
适用电线大小
材 质
1.5
M
(8230-5308)
2.6
2.6
22.35
F(8240-0491)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
0.75〜1.25
Surface treatment
表面处理
Brass
黄铜
Tin-plated
镀锡
M
(8230-5309)
2.6
15.5
F
(8240-0492)
Cable size(mm2)
适用电线大小
Material
Heat-resistant
copper alloy
Tin-plated
镀锡
22.35
1.5
材 质
Surface treatment
表面处理
2.0
Heat-resistant
copper alloy
Tin-plated
镀锡
1.5mm(060)
(SS)
(7165-1562)
电线密封栓
(毫米)
电线密封栓为公端、母端共用。
φ 4.6
Cable overall diameter(㎜)
0.85〜1.2
带绝缘层外径
Silicon
Material
硅
材 质
Violet
Color
紫
颜 色
8.2
(S)
(M)
(7165-1563)
φ 4.6
1.05〜1.5
带绝缘层外径
Silicon
Material
硅
材 质
Sky Blue
Color
天蓝
颜 色
8.2
(L)
(7165-1564)
φ 4.6
1.35〜1.9
带绝缘层外径
Silicon
Material
硅
材 质
Light Green
Color
淡绿
颜 色
8.2
(LL)
(7165-1565)
(7165-1566) E- 15
φ 4.6
φ 4.6
8.2
2.4〜3
带绝缘层外径
Silicon
Material
硅
材 质
Dark Yellow
Color
深黄色
颜 色
8.2
1.5mm
(060)
盲塞(毫米)
Ref; 1.5mm Dummy plug detail
1.5mm盲塞参照页
(7165-0193)
J-07
terminal holes.
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
2way
1.5mm
(060)
Color
Black
黒
颜 色
35.8
17.25
Housing(UNIT : mm)
接插件护套
(毫米)
17
M
(6181-6851)
Ref: Terminal part No.
端子参照页
E-14
Ref: wire seal No.
电线密封栓参照页
E-14
Ref: Dummy plug No.
盲塞参照页
J-07
Material
材 质
PBT
F(6189-7408)
16.25
19
23.25
Color
颜 色
Black
黒
HX SEALED SERIES
1.75〜2.4
带绝缘层外径
Silicon
Material
硅
材 质
Blue
Color
蓝
颜 色
3way
4way
F
(6189-7494)
Color
Black
黒
颜 色
35.8
16.25
23.6
23.25
21.85
Color
Black
黒
颜 色
17
M
(6181-6783)
F(6189-7409)
E- 16
20.85
19
23.25
Color
Black
黒
颜 色
8way
12way
Color
Color
Black
黒
颜 色
Black
黒
颜 色
35.8
35.8
22.75
26.2
M
(6181-6850)
F(6189-7423)
22.75
35.4
M
(6181-6784)
F(6189-7410)
23.25
21.75
29
21.75
38.2
Color
颜 色
Black
黒
23.25
Color
颜 色
Black
黒
2.3mm
(090)
Structure/构造
Retainer M
E- 17
Terminal M
Connector M
Connector F
Connector seal
Housing F
Wire seal
Terminal F
2.3mm(090)
Terminal(UNIT : mm)
端子(毫米)
Ref; 2.3mm Terminal detail
2.3mm端子参照页
(S)
F(8240-4862)
Cable size(mm )
2
适用电线大小
S M(8230-4472) L-02
M M(8230-4562) L-02
Material
L M(8230-4552) L-02
Surface treatment
带绝缘层外径
材 质
表面处理
0.3〜0.5
1.4〜2.4
Heat-resistant
copper alloy
Tin-plated
镀锡
2.4
3
18
HX SEALED SERIES
Connector M
Wire seal
(L)
(M)
F(8240-4952)
F
(8240-4992)
Cable size(mm )
2
0.75〜0.85
适用电线大小
1.8〜2.6
带绝缘层外径
Material
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
Surface treatment
表面处理
E- 18
Cable size(mm )
2
适用电线大小
2.4
18
3
带绝缘层外径
Material
材 质
Surface treatment
表面处理
1.25〜2.0
2.1〜2.9
Heat-resistant
copper alloy
Tin-plated
镀锡
2.4
18
3
2.3mm(090)
(SS)
(7165-0385)
Cable size(mm2)
电线密封栓
(毫米)
适用电线大小
带绝缘层外径
Material
颜 色
(S)
φ5
1.2〜1.7
Silicon
硅
Gray
灰
材 质
Color
电线密封栓为公端、母端共用。
(AVSS/0.3〜0.5)
(AVSSX/0.5)
6.4
(M)
(7165-0194)
Cable size(mm )
2
适用电线大小
(AV/0.5)
(AVX・AEX/0.5〜0.75)
(AVS/0.3〜0.85)
(AVSS/0.85〜1.25)
(AVSSX/0.75〜1.25)
带绝缘层外径
Material
材 质
Color
颜 色
1.7〜2.4
Silicon
硅
Green
绿
2.3mm
(090)
盲塞(毫米)
Ref; 2.3mm Dummy plug detail
2.3mm盲塞参照页
(7165-0193)
J-07
terminal holes.
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
(7165-0198)
Cable size(mm )
2
适用电线大小
带绝缘层外径
Material
材 质
Color
颜 色
(AV/0.5〜1.25)
(AVX・AEX/0.75〜1.25)
(AVS/0.85〜1.25)
(AVSS/1.25〜2.0)
(AVSSX/1.25〜2.0)
2.1〜2.9
Silicon
硅
Yellow
黄
1way
2.3mm(090)
Color
Black
黒
颜 色
15.8
9.6
17.6
9.6
Housing(UNIT : mm)
Retainer No.
(6918-2665)
接插件护套
(毫米)
M
(6181-0803)
E-17
Ref: wire seal No.
电线密封栓参照页
E-18
Ref: Dummy plug No.
盲塞参照页
Material
材 质
F(6189-0591)
9.4
21.6
J-07
19.4
PBT
Retainer No.
(6918-1370)
28.3
Color
(Rib difference)
(Rib差异)
2way
2way
F
(6189-0593)
F
(6189-0552)
9.4
9.4
28.3
21.4
13
Note)
21.6
Color
13
28.3
Retainer No.
(6918-1260)
Note)
21.4
Black
黒
颜 色
Retainer No.
(6918-1260)
Color
Brown
棕
颜 色
4way
3way
F(6189-0617)
F(6189-0596)
9.4
23.1
29.0
Black
黒
颜 色
21.6
E- 19
9.4
19
28.3
Note)
Color
颜 色
Retainer No.
(6918-1371)
Black
黒
9.4
21.6
34.0
28.3
22
Note)
Color
颜 色
Retainer No.
(6918-1469)
Black
黒
HX SEALED SERIES
端子参照页
38
E- 20
HX SEALED SERIES
for HYBRID
(S)
4.8mm
(187)
F(8100-0661)
Cable size(mm2)
适用电线大小
带绝缘层外径
Material
材 质
Surface treatment
表面处理
Terminal(UNIT : mm)
端子(毫米)
1.4〜2.4
6
19.5
Heat-resistant
copper alloy
Tin-plated
镀锡
(M)
F(8100-0660)
Ref; 4.8mm Terminal detail
4.8mm端子参照页
Cable size(mm2)
适用电线大小
S M(8100-0463)B-19
M M(8100-0464) B-19
Material
L M(8100-0465) B-19
0.3〜0.5
3.8
带绝缘层外径
材 质
F
(8100-0468) B-19
4.8mm
(187)
Surface treatment
表面处理
0.5〜1.25
1.6〜2.6
(7165-0172)
带绝缘层外径
Material
(AVS/0.3)
(AVSS/0.3〜0.85)
(AVSSX/0.5〜0.75)
Color
1.4〜1.9
Brown
棕
颜 色
(M)
9
for 2.3mm, 4.8mm 10way
(7165-0130)
Cable size(mm )
2
适用电线大小
带绝缘层外径
电线密封栓为公端、母端共用。
φ8
NBR
材 质
19.5
适用电线大小
电线密封栓
(毫米)
6
Heat-resistant
copper alloy
Tin-plated
镀锡
(S)
Cable size(mm2)
3.8
Material
材 质
Color
颜 色
(AV/0.5〜1.25)
(AVX/0.5〜1.25)
(AVS/0.3〜1.25)
(AVSS/0.85〜2.0)
(AVSSX/0.75〜2.0)
φ8
1.8〜2.9
NBR
Gray
灰
9
(L)
(7165-0131)
Cable size(mm )
2
适用电线大小
带绝缘层外径
Material
材 质
Color
颜 色
(AV/2.0〜3.0)
(AVX/2.0〜3.0)
(AVS/2.0〜3.0)
3.0〜4.1
NBR
Black
黒
(M)
for 1.0mm, 4.8mm 13way
(L)
(7165-0148)
(7165-0147)
Cable size(mm2)
带绝缘层外径
Material
材 质
Color
颜 色
(AVS/0.3〜1.25)
适用电线大小
1.8〜2.9
带绝缘层外径
Silicon
硅
Dark Green
墨绿
Material
材 质
9
Color
颜 色
3.0〜4.1
Silicon
硅
Dark Blue
藏青
9
13way(12+1)
1.0mm, 4.8mm
(040, 187)
Color
Black
黒
颜 色
Housing(UNIT : mm)
29.65
15.9
35.1
接插件护套
(毫米)
端子参照页
[1.0mm]
[4.8mm]
E-02
E-20
Ref: wire seal No.
电线密封栓参照页
[1.0mm]
[4.8mm]
E-03
E-21
Ref: Dummy plug No.
盲塞参照页
[1.0mm]
[4.8mm]
E-04
B-21
Material
材 质
φ8
(AVS/2.0〜3.0)
40.9
45.9
Retainer No.
(6181-6465)
M
(6181-6464)
F(6189-6863)
16.3
35.5
29.9
PBT
31.1
50.05
Retainer No.
(6185-4596)
Color
Black
黒
颜 色
4way(2+2)
1.5mm, 4.8mm
(060, 187)
Color
Black
黒
颜 色
44.8
Housing(UNIT : mm)
21.85
23.8
接插件护套
(毫米)
端子参照页
[1.5mm]
[4.8mm]
E-14
E-20
Ref: wire seal No.
电线密封栓参照页
[1.5mm]
[4.8mm]
E-15
E-20
Ref: Dummy plug No.
盲塞参照页
[1.5mm]
[4.8mm]
J-07
B-21
Material
材 质
PBT
No. of way/( )corresponds to 1.5mm, 4.8mm, in order from left to right.
极数/( )内显示 :从左向右为1.5mm 极数、4.8mm 极数
M
(6181-6785)
F(6189-7411)
25.55
25.8
28.9
Color
颜 色
Black
黒
E- 21
HX SEALED SERIES
适用电线大小
Cable size(mm2)
φ8
5way(3+2)
Color
Dark gray
深灰
颜 色
44.8
21.85
23.8
M
(6181-6921)
F
(6189-7567)
E- 22
25.55
25.8
28.9
Color
颜 色
Dark gray
深灰
10way(8+2)
2.3mm, 4.8mm
(090, 187)
Color
34.8
Housing(UNIT : mm)
24.7
接插件护套
(毫米)
[2.3mm]
[4.8mm]
E-17
E-20
Ref: wire seal No.
电线密封栓参照页
[2.3mm]
[4.8mm]
E-18
E-21
Ref: Dummy plug No.
盲塞参照页
[2.3mm]
[4.8mm]
J-07
B-21
Retainer No.
(6918-1263)
M
(6181-0381)
F(6189-0555)
24.5
43.1
24.5
PBT
43.2
32.3
24.7
端子参照页
Material
材 质
Dark gray
深灰
颜 色
34.2
35.5
Retainer No.
(6918-1267)
Color
颜 色
Dark gray
深灰
NH SERIES
Features
The NH series connector is a highly reliable
for connector mating and terminal insertion.
This series consist of 0.64mm and hybrid
type(0.64mm+2.3mm) terminal usable for
control circuit and low power circuit.
◦ T he front mask of Female connector
assists allure male terminal.
◦ B y set ti ng TPA ( Te r m i na l Position
Assur rance) adjust the incomplete
inserted terminal to the correct position.
◦A
body.
◦ RoHS/ELV Compliant
特 点
NH 系列在接插件嵌合或端子插入不足等方面提高
了可信性。
端子尺寸由0.64mm 与混合型 (0.64mm+2.3mm)
构成,可以应用于信号回路与低功率回路。
◦母端接插件由于采用了前锁制,在接插件嵌合
时提高了公端子的引导性。
◦未完全插入的端子能够通过锁片的安装插入到
正确的位置。
◦接插件护套能够安装夹钉以固定在车体上。
◦可对应欧盟 RoHS 和 ELV 指令
NH SERIES for STANDARD
0.64mm
(025)
Structure/构造
Housing M
Terminal M
F- 02
Retainer
Connector M
Connector F
Housing F
Terminal F
Retainer
0.64mm
(025)
Terminal(UNIT : mm)
端子(毫米)
(S)
(M)
Cable size(mm2)
Cable size(mm2)
0.22〜0.5
适用电线大小
Material
材 质
Surface treatment
表面处理
0.75
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
表面处理
0.64
M
(8230-5379)
0.64
22.6
F
(8240-0552)
1.7
M
(8230-5380)
22.6
F(8240-0523)
1.7
Cable size(mm2)
16.5
0.22〜0.5
适用电线大小
Material
16.5
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
Surface treatment
表面处理
1.6
适用电线大小
Material
材 质
Surface treatment
表面处理
F- 03
0.75
Heat-resistant
copper alloy
Tin-plated
镀锡
0.64mm
(025)
3way
Housing(UNIT : mm)
F(6098-7063)
接插件护套
(毫米)
12.25
端子参照页
F-02
Material
材 质
PBT
21
6.4
Color
Natural
自然色
颜 色
4way
8way
Color
Natural
自然色
颜 色
Color
Natural
自然色
颜 色
15.1
12.15
33.9
33.9
14
M
(6098-5310)TH 04 MW-NH
TH 04 FW-NH
14.2
F
(6098-5267)
M
(6098-5271)TH 08 MW-NH
TH 08 FW-NH
F
(6098-5269)
10.05
15.45
19
11.8
21
Color
颜 色
Natural
自然色
11
Color
颜 色
Natural
自然色
NH SERIES
1.6
Cable size(mm2)
8way
8way
TH 08 FB-NH
F
(6098-6451)
TH 08 FGY-NH
F
(6098-6452)
15.45
15.45
21
21
Color
13
Black
黒
颜 色
Color
13
Gray
灰
颜 色
8way
8way
TH 08 FL-NH
F- 04
F
(6098-6522)
TH 08 FG-NH
15.45
F(6098-6523)
15.45
21
21
13
Color
13
Blue
蓝
颜 色
Color
Green
绿
颜 色
8way
10way
TH 08 FW-1V-NH
F
(6098-5312)
TH 10 FB-NH
15.45
10.5
21
21.8
F(6098-5273)
21
Color
14.54
Natural
自然色
颜 色
Color
Black
黒
颜 色
10way
10way
TH 10 FW-NH
F
(6098-7066)
TH 10 FGY-NH
15.45
15.45
21
16.54
F
(6098-7067)
Color
16.54
Natural
自然色
颜 色
12way
21
Color
Gray
灰
颜 色
12way
Color
TH 12 FB-NH
Natural
自然色
颜 色
15.45
15.1
33.9
18.6
M
(6098-5277)TH 12 MW-NH
TH 12 FW-NH
F(6098-6455)
21
17.4
Color
颜 色
Black
黒
F
(6098-5275)
12way
TH 12 FGY-NH
15.45
15.45
21
15.4
F(6098-6456)
21
Color
颜 色
Natural
自然色
17.4
Color
颜 色
Gray
灰
12way
12way
TH 12 FL-NH
F
(6098-6457)
TH 12 FG-NH
F(6098-6524)
15.45
21
Color
17.4
Blue
蓝
颜 色
Color
Green
绿
颜 色
16way
16way
Color
TH 16 FB-NH ASSY
Natural
自然色
颜 色
F- 05
15.1
15.45
21.8
23
TH 16 FW-NH
21
Color
Black
黒
颜 色
F
(6098-5279)
16way
TH 16 FGY-NH ASSY
15.45
F
(6098-7100)
15.45
21
19.8
Color
21.8
Natural
自然色
颜 色
颜 色
Color
Gray
灰
颜 色
24way
24way
Color
21
TH 24 FB-NH
Natural
自然色
F(6098-7060)
15.1
15.45
33.9
28.6
31.8
M(6098-5285)TH 24 MW-NH
TH 24 FW-NH
21
Color
颜 色
Black
黒
F(6098-5283)
24way
TH 24 FGY-NH
15.45
15.45
21
28.6
F(6098-7061)
Color
颜 色
Natural
自然色
28.6
21
Color
颜 色
Gray
灰
NH SERIES
33.9
M(6098-5281)TH 16 MW-NH
F
(6098-7099)
32way
40way
Color
Color
Natural
自然色
颜 色
Natural
自然色
颜 色
15.1
15.1
33.9
33.9
49.4
40.6
M
(6098-5289)TH 32 MW-NH
F- 06
TH 32 FW-NH
F
(6098-5287)
M
(6098-5585)TH 40 MW-NH
15.45
TH 40 FW-NH
F(6098-5291)
15.45
21
21
37.4
46.2
Color
Color
Natural
自然色
颜 色
40way
颜 色
Natural
自然色
40way
TH 40 FB-NH
F
(6098-5293)
TH 40 FGY-NH
15.45
46.2
15.45
21
Color
颜 色
Black
黒
40way
TH 40 FG-NH
F
(6098-5297)
15.45
46.2
F(6098-5295)
21
Color
颜 色
Green
绿
46.2
21
Color
颜 色
Gray
灰
NH SERIES
for HYBRID
F- 07
NH SERIES
(SS)
2.3mm
(090)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
0.22
Brass
黄铜
Tin-plated
镀锡
2.3
M
(8230-5168)
23.6
F(8240-0367)
2.55
Cable size(mm2)
Terminal(UNIT : mm)
3
17.4
适用电线大小
Material
材 质
Surface treatment
端子(毫米)
表面处理
(S)
0.22
Heat-resistant
copper alloy
Tin-plated
镀锡
(M)
Cable size(mm )
2
适用电线大小
Material
材 质
Surface treatment
表面处理
Cable size(mm2)
0.3〜0.5
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
2.3
M
(8230-5169)
表面处理
0.75〜1.0
Brass
黄铜
Tin-plated
镀锡
2.3
23.6
F(8240-0368)
2.55
M
(8230-5170)
23.6
F(8240-0369)
2.55
Cable size(mm2)
3
17.4
适用电线大小
Material
材 质
Surface treatment
表面处理
Cable size(mm2)
0.3〜0.5
Heat-resistant
copper alloy
Tin-plated
镀锡
3
17.4
适用电线大小
Material
材 质
Surface treatment
表面处理
0.75〜1.0
Heat-resistant
copper alloy
Tin-plated
镀锡
(L)
(LL)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
Cable size(mm2)
1.25
Material
Brass
黄铜
Tin-plated
镀锡
Brass
黄铜
Tin-plated
镀锡
材 质
Surface treatment
表面处理
2.3
M
(8230-5171)
F- 08
2.0〜2.5
适用电线大小
2.3
23.6
F
(8240-0370)
2.55
M
(8230-5172)
23.6
F(8240-0371)
2.55
Cable size(mm2)
3
17.4
适用电线大小
Material
材 质
Surface treatment
表面处理
Cable size(mm2)
1.25
3
Heat-resistant
copper alloy
Tin-plated
镀锡
适用电线大小
17.4
Material
材 质
Surface treatment
表面处理
2.0〜2.5
Heat-resistant
copper alloy
Tin-plated
镀锡
0.64mm, 2.3mm
(025, 090)
Housing(UNIT : mm)
20way(18+2)
接插件护套
(毫米)
NH 18 FW-CS2
[0.64mm] F-03
[2.3mm] F-07
端子参照页
Material
材 质
PBT
15.55
22
No. of way/( )corresponds to 0.64mm, 2.3mm, in order from left to right.
20way(10+10)
Color
颜 色
F(6098-7261)
30.6
Color
Natural
自然色
颜 色
20way(10+10)
Color
Natural
自然色
Black
黒
颜 色
35.35
38.3
M
(6098-5989)NH 10 MW-CS10
NH 10 FW-CS10
35.35
19.65
F
(6098-5988)
38.3
M
(6098-7254)NH 10 MW-CS10-B
16.75
36.5
NH 10 FW-CS10-B
19.65
F(6098-7253)
16.75
21.55
Color
颜 色
Natural
自然色
36.5
21.55
Color
颜 色
Black
黒
RS SERIES
Features
RS series consists of a 2.3mm type classified
circuits.
◦ The RS-standard type connectors adopt
an inertia locking system to prevent
semi-engagement (this system is not
incorporated in some connectors).
*Please contact our sales representative
for product numbers.
特 点
RS 系列的端子尺寸由2.3mm 构成,可以应用于各
种控制回路与低功率回路。
◦ RS 标准类型接插件采用惯性锁闭方式,使接
插件不易发生半插入。
RS SERIES for STANDARD Type1
2.3mm
(090)
Structure/构造
Retainer
Wire seal
Housing M
Retainer
G-02
Wire seal
Terminal M
Housing M
Terminal M
Connector M
Connector F
Terminal F
Housing F
Wire seal
Retainer
Wire seal
Terminal F
Retainer
2.3mm
(090)
Terminal(UNIT : mm)
端子(毫米)
Housing F
(S)
(S)
Cable size(mm2)
0.3〜0.5
适用电线大小
Material
Surface treatment
表面处理
Material
Surface treatment
表面处理
M
(8100-3803)
适用电线大小
Material
材 质
表面处理
Heat-resistant
copper alloy
Tin-plated
镀锡
F(8240-0266)
Cable size(mm2)
0.3〜0.5
(M)
适用电线大小
18
3
Material
材 质
Surface treatment
表面处理
0.3〜0.5
Heat-resistant
copper alloy
Gold-plated
镀金
(M)
Cable size(mm )
2
Material
Cable size(mm )
Surface treatment
表面处理
Material
Surface treatment
表面处理
M
(8100-3804)
适用电线大小
Material
材 质
Surface treatment
表面处理
2.3
23.6
F
(8240-0264)
Cable size(mm2)
3
Brass
黄铜
Gold-plated
镀金
材 质
2.3
18
0.85〜1.25
适用电线大小
Brass
黄铜
Tin-plated
镀锡
材 质
Au
2
0.85〜1.25
适用电线大小
M
(8100-3806)
Heat-resistant
copper alloy
Tin-plated
镀锡
适用电线大小
18
3
23.6
F(8240-0267)
Cable size(mm2)
0.85〜1.25
(L)
Material
材 质
Surface treatment
表面处理
0.85〜1.25
Heat-resistant
copper alloy
Gold-plated
镀金
(L)
Cable size(mm )
2
Material
Cable size(mm )
Surface treatment
表面处理
Material
Brass
黄铜
Gold-plated
镀金
材 质
Surface treatment
表面处理
2.3
M
(8100-4172)
适用电线大小
Material
材 质
Surface treatment
表面处理
2.3
23.6
F
(8240-0265)
Cable size(mm2)
18
2.0
适用电线大小
Brass
黄铜
Tin-plated
镀锡
材 质
Au
2
2.0
适用电线大小
3
M
(8100-3805)
23.6
M
(8100-4173)
Heat-resistant
copper alloy
Tin-plated
镀锡
F(8240-0268)
Cable size(mm2)
2.0
3
18
23.6
适用电线大小
Material
材 质
Surface treatment
表面处理
2.0
Heat-resistant
copper alloy
Gold-plated
镀金
G-03
RS SERIES
Surface treatment
2.3
23.6
F
(8240-0263)
Cable size(mm2)
3
Brass
黄铜
Gold-plated
镀金
材 质
2.3
18
0.3〜0.5
适用电线大小
Brass
黄铜
Tin-plated
镀锡
材 质
Au
Cable size(mm2)
(US)
2.3mm
(090)
(7165-0474)
Cable size(mm )
2
适用电线大小
带绝缘层外径
Material
(AVSS/0.3)
(CAVUS/0.3〜0.5)
Silicon
硅
Orange
橙
材 质
Color
颜 色
φ 5.4
1.0〜1.4
φ 4.2
7
(S)
(7165-0473)
Cable size(mm2)
电线密封栓
(毫米)
G-04
适用电线大小
带绝缘层外径
Material
Color
颜 色
φ 5.4
1.5〜1.9
Silicon
硅
Light Blue
淡蓝
材 质
电线密封栓为公端、母端共用。
(AVSS/0.5〜0.85)
(CAVUS/0.85〜1.25)
φ 4.2
(L)
(M)
(7165-0471)
(7165-0472)
Cable size(mm2)
适用电线大小
带绝缘层外径
Material
材 质
Color
颜 色
Cable size(mm )
2
(AVSS/1.25)
φ 5.4
2.0〜2.4
Silicon
硅
Violet
紫
适用电线大小
带绝缘层外径
φ 4.2
Material
7
材 质
Color
颜 色
7
(AVSS/2.0)
φ 5.4
2.5〜2.9
Silicon
硅
Light Green
淡绿
φ 4.2
7
2.3mm(090)
盲塞(毫米)
(7165-1131)
terminal holes.
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
Material
材 质
Color
颜 色
Silicon
硅
Blue
蓝
5.45
8
1way
2.3mm
(090)
Housing(UNIT : mm)
8.9
19.4
接插件护套
(毫米)
端子参照页
G-02
Ref: wire seal No.
电线密封栓参照页
G-04
Ref: Dummy plug No.
盲塞参照页
G-04
Material
材 质
PBT
42.2
5.05
20.4
Retainer No.
(6918-1773)
M
(6188-0551)RS 01 MB
RS 01 FB
8.9
※ Detail dimensions for mounting portion of the
bracket are specifi ed in the offi cial drawing.
Please contact our sales staff.
16.2
Retainer No.
(6918-1773)
2way
22.9
8.9
42.2
8.7
22.9
8.9
22.1
22.1
Retainer No.
(6918-1774)
Retainer No.
(6918-1774)
M
(6188-0554)RS 02 MGY
RS 02 FGY
F
(6185-0867)
M
(6188-0552)RS 02 MB
8.7
8.9
26.25
Retainer No.
(6918-1774)
8.9
22.9
8.7
26.25
20.4
8.9
Retainer No.
(6918-1774)
42.2
14.3
22.3
8.9
42.2
27.7
22.1
Retainer No.
(6918-1774)
M
(6188-0553)RS 02 MBR
M
(6188-0663)RS 02 MBR-DGY
Retainer No.
(6918-1775)
RS 02 FBR
RS 02 FBR-DGY
F(6185-0866)
F(6185-1101)
M
(6188-0556)RS 03 MGY
19.7
20.4
F
(6185-0865)
3way
2way
8.7
RS 02 FB
19.7
19.7
20.4
42.2
26.25
RS 03 FGY
F(6185-0869)
18.4
8.7
8.9
Retainer No.
(6918-1774)
26
14.3
8.9
26.25
Retainer No.
(6918-1775)
RS SERIES
2way
G-05
5.05
26.25
18.7
※关于固定用支架相关事宜,请向敝公司销售负责人问讯。
8.7
F(6185-0862)
3way
14.3
4way
22.3
8.9
8.9
8.7
26.2
42.2
42.2
22.2
27.7
Retainer No.
(6918-1776)
Retainer No.
(6918-1775)
M
(6188-0555)RS 03 MB
RS 03 FB
F(6185-0868)
M
(6188-0558)RS 04 MGY
14.3
26.25
26
8.9
8.7
4way
Retainer No.
(6918-1776)
6way
8.9
26.2
14.3
8.9
26.4
42.2
42.2
27.8
22.2
Retainer No.
(6918-1779)
Retainer No.
(6918-1776)
M
(6188-0557)RS 04 MB
RS 04 FB-PR
F
(6185-1169)
M
(6188-5540)RS 06 MGY
23.05
RS 06 FGY-PR
8.7
8.9
14.3
26.1
6way
8.9
26.25
Retainer No.
(6918-1776)
Retainer No.
(6918-1779)
8way
8.9
26.4
19.9
26.8
8.9
42.2
27.8
42.2
35.4
Retainer No.
(6918-1780)
Retainer No.
(6918-1779)
M
(6188-5539)RS 06 MB
RS 06 FB-PR
F(6185-5175)
M
(6188-5544)RS 08 MGY-PR
23.25
RS 08 FGY-PR
F(6185-5181)
22.15
14.3
26.1
F(6185-5177)
23.25
26.25
20.5
14.3
8.9
26.25
20.5
Retainer No.
(6918-1775)
8.7
F(6185-1171)
23.05
18.4
G-06
RS 04 FGY-PR
8.9
26.25
19.9
31.7
Retainer No.
(6918-1779)
8.9
26.25
Retainer No.
(6918-1780)
8way
19.9
26.8
8.9
42.2
35.4
Retainer No.
(6918-1780)
M
(6188-5542)RS 08 MB-PR
RS 08 FB-PR
F
(6185-5179)
22.15
31.7
26.25
19.9
8.9
RS SERIES
Retainer No.
(6918-1780)
G-07
RS SERIES for STANDARD Type2
2.3mm
(090)
Structure/构造
Housing M
Retainer M
Wire seal
Wire seal
G-08
Housing M
Terminal M
Terminal M
Retainer M
Connector M
Connector F
Housing F
Terminal F
Wire seal
Retainer F
Wire seal
Terminal F
Housing F
Retainer F
2way
2.3mm
(090)
10.8
19.7
9
13.9
Housing(UNIT : mm)
接插件护套
(毫米)
端子参照页
G-02
Ref: wire seal No.
电线密封栓参照页
G-04
Ref: Dummy plug No.
盲塞参照页
G-04
Material
材 质
PBT
37.4
19.7
Retainer No.
(6918-1653)
M
(6181-0515)RS 02 MSB
M
(6181-0670)RS 02 MSB-B
RS 02 FSB
RS 02 FSB-B
20.6
23.4
F(6189-0951)
F
(6189-1107)
10.2
28.7
13.3
8.3
Retainer No.
(6918-1651)
2way
10.8
3way
19.7
9
13.9
10.8
20.3
37.4
20.45
RS 02 FLGY
F
(6189-0950)
37.4
27.1
Retainer No.
(6918-1654)
Retainer No.
(6918-1653)
M
(6181-0532)RS 02 MLGY
19.7
9
M
(6181-0516)RS 03 MSB
M
(6181-0671)RS 03 MSB-GY
RS 03 FSB
RS 03 FSB-GY
19.6
10.2
20.6
28.7
8.3
13.3
23.4
10.2
8.3
28.7
29.8
19.7
16.7
Retainer No.
(6918-1652)
4way
9
16.7
26
9
26
15.6
15.6
40.2
22.8
Retainer No.
(6918-1598)
M
(6181-0513)RS 04 MG
M
(6181-0668)RS 04 MG-GY
RS 04 FG
RS 04 FG-GY
27.5
F(6189-7756)
F(6189-7757)
28.5
26.4
M
(6181-0514)RS 04 ML
M
(6181-0669)RS 04 ML-B
RS 04 FL
RS 04 FL-B
27.5
16.1
32.05
15
8.7
16.7
32.05
28.5
26.4
8.7
15
Retainer No.
(6918-1599)
6way
9
26
16.7
9
26
21.2
21.2
40.2
Retainer No.
(6918-1600)
28.4
M
(6181-0511)RS 06 MG
M
(6181-0665)RS 06 MG-DGY
RS 06 FG
RS 06 FG-DGY
27.5
32.0
F
(6189-7758)
F
(6189-7759)
16.1
Retainer No.
(6918-1599)
6way
40.2
22.8
Retainer No.
(6918-1598)
32.05
28.5
F(6189-7760)
F(6189-7761)
16.1
8.7
20.6
Retainer No.
(6918-1601)
40.2
Retainer No.
(6918-1600)
28.4
M
(6181-0536)RS 06 ML
M
(6181-0664)RS 06 ML-B
RS 06 FL
RS 06 FL-B
16.1
27.5
32.0
F(6189-7762)
F(6189-7763)
32.05
28.5
8.7
20.6
Retainer No.
(6918-1601)
G-09
RS SERIES
Retainer No.
(6918-1651)
4way
F(6189-0928)
F
(6189-1104)
8way
8way
16.7
16.7
9
40.2
34
Retainer No.
(6918-1602)
M
(6181-0512)RS 08 MG
M
(6181-0667)RS 08 MG-GY
RS 08 FG
RS 08 FG-GY
27.5
37.6
26
26.8
26.8
G-10
9
26
F
(6189-0954)
F
(6189-1108)
16.1
32.05
28.5
8.7
26.2
Retainer No.
(6918-1603)
40.2
34
Retainer No.
(6918-1602)
M
(6181-0522)RS 08 ML
M
(6181-0666)RS 08 ML-B
RS 08 FL
RS 08 FL-B
16.1
27.5
32.05
37.6
F
(6189-0955)
F
(6189-1109)
28.5
8.7
26.2
Retainer No.
(6918-1603)
RS SERIES for E-RS
2.3mm
(090)
Structure/构造
Housing F
Mating portion
(Connector M)
Connector F
(After setting retainer)
G-11
Housing F
RS SERIES
Retainer F
Wire seal
Wire seal
Retainer F
Terminal F
Terminal F
1way
2.3mm(090)
E 01 FGY-RS
20.3
Housing(UNIT : mm)
19.1
F(6098-2329)
8.9
8.6
26.9
8.9
Retainer No.
(6918-1636)
接插件护套
(毫米)
端子参照页
G-02
Ref: wire seal No.
电线密封栓参照页
G-04
Ref: Dummy plug No.
盲塞参照页
G-04
Material
材 质
PBT
2way
E 02 FGY-RS
20.6
F(6189-0772)
10.2
9.3
22.8
28.3
12.7
Retainer No.
(6918-1594)
2way
2way
E 02 FB-RS
F
(6189-0773)
E 02 FBR-RS
E 02 FBR-RS-GY
20.6
20.6
10.2
10.2
9.3
22.8
12.7
28.3
22.8
Retainer No.
(6918-1594)
F(6189-0775)
E 02 FG-RS-LGY F
(6189-1094)
E 02 FR-RS
E 02 FG-RS
E 02 FR-RS-GY
20.6
20.6
9.3
28.3
12.7
22.8
9.3
28.3
12.7
Retainer No.
(6918-1594)
Retainer No.
(6918-1594)
2way
2way
E 02 FL-RS
E 02 FL-RS-LGY
20.6
F
(6189-0777)
F
(6189-1096)
E 02 FPU-RS
E 02 FPU-RS-B
10.2
9.3
28.3
F
(6189-0778)
F
(6189-1097)
20.6
10.2
12.7
22.8
3way
9.3
28.3
12.7
Retainer No.
(6918-1594)
Retainer No.
(6918-1594)
3way
E 03 FGY-RS
F(6189-7471)
E 03 FBR-RS
E 03 FBR-RS-B
19.6
28.3
F
(6189-7710)
F(6189-7711)
19.6
10.2
29.8
F
(6189-0776)
F
(6189-1095)
10.2
10.2
22.8
12.7
2way
2way
22.8
9.3
28.3
Retainer No.
(6918-1594)
G-12
F
(6189-0774)
F
(6189-1093)
10.2
9.3
19.7
29.8
19.7
Retainer No.
(6918-1595)
4way
9.3
28.3
Retainer No.
(6918-1595)
4way
E 04 FGY-RS
F(6189-7469)
E 04 FBR-RS
E 04 FBR-RS-LGY
19.6
19.6
10.2
F(6189-7713)
F(6189-7714)
10.2
9.3
32.8
28.3
9.3
22.7
32.8
28.3
Retainer No.
(6918-1596)
5way
22.7
Retainer No.
(6918-1596)
5way
E 05 FGY-RS
F(6189-7470)
E 05 FBR-RS
E 05 FBR-RS-B
19.6
19.6
10.2
28.3
37.8
F(6189-7716)
F(6189-7717)
10.2
9.3
27.7
Retainer No.
(6918-1604)
9.3
37.8
28.3
27.7
Retainer No.
(6918-1604)
6way
E 06 FGY-RS
F
(6189-7393)
19.6
10.2
42.8
28.3
32.7
9.3
Retainer No.
(6918-1597)
G-13
RS SERIES
TL SEALED SERIES
Features
The TL sealed connector series has a
mechanism that detects terminal incomplete
insertion by using a dedicated jig.
This series consists of 2.3mm type supporting
use in a variety of control circuits and low
power circuits.
◦ T o restrain from incomplete engagement,
this series is adopted a lock mechanism
with effective clear sound.
◦These male connectors can be directly
secured to a bracket on the car body.
(Note: Please contact our sales staff, if you
have any questions regarding the
dedicated jig.)
◦RoHS/ELV Compliant
特 点
TL 防水系列采用了以专用治具检测出端子半插入
的构造。
TL 系列的端子尺寸由2.3mm 构成,可以应用于各
种控制回路与低功率回路。
◦为防止接插件半嵌合的发生,采用了增强锁闭
音的锁闭构造。
◦公端接插件可以直接固定在车体支架上。
注意 :有关专用导通治具的详情请向敝公司销售
负责人确认。
TL SEALED SERIES for STANDARD
2.3mm
(090)
Structure/构造
Housing M
Housing M
Wire seal
Terminal M
Retainer
Wire seal
Terminal M
Housing M
Body fastening braket mount
车体固定用支架安装部位
Terminal M
H- 02
Connector M
Connector F
Housing F
Housing F
Housing F
Wire seal
Wire seal
Terminal F
Terminal F
Retainer
Connector seal
Terminal F
Connector seal
2.3mm
(090)
2.3mm
(090)
Terminal(UNIT : mm)
Wire seals(UNIT : mm)
端子(毫米)
电线密封栓(毫米)
2.3mm端子参照页
S M(8230-4472) L-02
Ref; 2.3mm Wire Seals detail
2.3mm电线密封栓参照页
M M(8230-4562) L-02
F
(8100-1427)
F
(8100-1429)
L M(8230-4552) L-02
F
(8100-1428)
L-02
S
(7165-0516)
M
(7165-0515)
L-02
L(7165-0514)
L-02
J-06
J-06
J-06
2.3mm
(090)
Dummy plugs(UNIT : mm)
盲塞(毫米)
2.3mm盲塞参照页
(7165-0193)
J-07
◦ Dummy plugs are common to M and F.
◦ Dummy plugs are used to blind unused
terminal holes.
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
H- 03
TL SEALED SERIES
1way
2.3mm(090)
Color
Black
黒
颜 色
18.35
Housing(UNIT : mm)
接插件护套
(毫米)
M
(6181-6658)
端子参照页
L-02
Ref: wire seal No.
电线密封栓参照页
J-06
Ref: Dummy plug No.
盲塞参照页
J-07
Material
材 质
PBT
40.3
13.7
F(6189-7214)
22.2
16
26.3
Color
颜 色
2way
Black
黒
4way
F
(6189-7189)
F
(6189-7188)
22.2
22.2
21
31
26.3
Color
颜 色
Black
黒
5way
F(6189-7190)
22.2
36
26.3
Color
颜 色
Black
黒
26.3
Color
颜 色
Black
黒
SL SERIES
Features
The SL connector series is adopted a
This series consists of 1.5mm, 2.3mm and
2.8mm types classified according to the
terminal size, covering an extensive array of
applications from signal circuits to low
power circuits.
◦ T hese connectors can be directly secured
to a bracket on the car body. In addition,
an extra clip can be attached to the
connector to secure it to the car body.
dedicated jig.)
◦RoHS/ELV Compliant
特 点
SL 系列接插件采用了以专用治具检测端子半插入
的构造。
按照端子尺寸划分为1.5mm·2.3mm·2.8mm 类
型,从信号回路到电源回路,能广泛运用。
◦接插件可以直接固定在车体的支架上。还可以
在接插件上安装用于固定到车体上的卡钉(卡
子)。
负责人确认。
SL SERIES for STANDARD
1.5mm
(060)
Structure/构造
Terminal M
Housing M
Terminal M
Housing M
I- 02
Connector M
Connector F
Housing F
Terminal F
Housing F
Terminal F
1.5mm
(060)
Terminal(UNIT : mm)
端子(毫米)
Note) L size terminal can be used for 14 poled connectors with
insertion cavity specifi ed.
For details please contact our sales staff.
※ L 尺寸端子的可用接插件有限制。
务必向敝公司销售负责人问讯。
(S)
(S)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
Au
Cable size(mm2)
0.3〜0.5
适用电线大小
Material
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
27.3
Surface treatment
表面处理
0.3〜0.5
Heat-resistant
copper alloy
Gold-plated
镀金
1.5
M
(8100-3382)
适用电线大小
Material
材 质
2.8
1.5
F
(8100-3391)
Cable size(mm2)
18
2.6
Surface treatment
表面处理
0.3〜0.5
M
(8230-4883)
18
2.6
F(8240-0135)
Cable size(mm2)
适用电线大小
Heat-resistant
copper alloy
Tin-plated
镀锡
Material
2.8
材 质
Surface treatment
表面处理
0.3〜0.5
Heat-resistant
copper alloy
Gold-plated
镀金
(L)
Cable size(mm )
2
适用电线大小
Material
材 质
Surface treatment
表面处理
Cable size(mm2)
0.75, 0.85〜1.25
适用电线大小
Material
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
Surface treatment
27.3
表面处理
2.0
Heat-resistant
copper alloy
Tin-plated
镀锡
1.5
M
(8100-3383)
18
Cable size(mm2)
适用电线大小
2.8
Material
材 质
Surface treatment
表面处理
27.3
1.5
F
(8100-3392)
0.75, 0.85〜1.25
M
(8100-3384)
18
2.6
F(8100-3393)
Cable size(mm2)
适用电线大小
Heat-resistant
copper alloy
Tin-plated
镀锡
Material
2.8
材 质
Surface treatment
表面处理
2.0
Heat-resistant
copper alloy
Tin-plated
镀锡
1.5mm(060)
Housing(UNIT : mm)
接插件护套
(毫米)
端子参照页
I-02
Material
材 质
PBT
Note) Connector can be used together with 2mm2 wire are 14
poled connectors.
For details of each product, please contact our sales staff.
※ L 尺寸端子的可用接插件有限制。
务必向敝公司销售负责人问讯。
I- 03
SL SERIES
(M)
2.6
27.3
4way
F(6098-3456)
10.4
17.35
22
Color
颜 色
Natural
自然色
12way
12way
Color
F(6098-4876)
Natural
自然色
颜 色
13.75
14.95
22.4
41
25.6
22
Color
颜 色
M
(6098-3449)
Natural
自然色
F
(6098-8482)
14way
F
(6098-4877)
Note)
11.75
13.75
22.4
22
26.7
Color
颜 色
I- 04
Natural
自然色
16way
F(6098-3453)
17.35
29.4
22
Color
颜 色
Natural
自然色
22
Color
颜 色
Natural
自然色
2.3mm(090)
Structure/构造
Connector F
I- 05
Terminal F
SL SERIES
Housing F
2.3mm
(090)
Terminal(UNIT : mm)
端子(毫米)
2.3mm端子参照页
S M
(8230-4492)
A-10 F(8240-4882)
A-10
M M
(8230-4502)
A-10 F(8240-4892)
A-10
L M
(8230-4512)
A-10 F(8240-4942)
A-10
Regarding "Gold-plated Terminal", please refer "A-10".
镀金端子记载在A-10上
2way
2.3mm(090)
F(6240-5337)
6.8
22
12.3
Color
Natural
自然色
颜 色
4way
Housing(UNIT : mm)
F
(6098-8478)
接插件护套
(毫米)
端子参照页
A-10
Material
材 质
PBT
12.1
22
10.8
Color
I- 06
6way
Natural
自然色
颜 色
6way
F(6240-5339)
Color
颜 色
Note
备 注
15.5
Natural
自然色
With body fastening clamp
带防转卡钉
14.7
18.8
22
Color
颜 色
Natural
自然色
42.5
24.1
Plate thickness range for clamp :
t=0.6〜2.0mm
Hole=7.2mm×12mm
M
(6098-2679)
F(6098-2680)
10.8
19.1
22
Color
颜 色
Natural
自然色
14way
12way
F
(6098-1747)
F(6098-1714)
15.5
14.5
26.8
22
Color
颜 色
Natural
自然色
34.8
22
Color
颜 色
Natural
自然色
14way
14way
F(6098-1774)
F(6098-2101)
15.5
12
33.1
22
Color
颜 色
Natural
自然色
34.8
22
Color
颜 色
Black
黒
16way
Color
颜 色
18way
F(6098-1627)
Natural
自然色
14.5
19.5
39.5
43.1
38.8
22
Color
颜 色
M
(6098-1744)
Natural
自然色
F
(6098-1746)
15.5
38.8
22
Color
颜 色
Natural
自然色
I- 07
SL SERIES
2.8mm
(110)
Structure/构造
Terminal M
Housing M
Terminal M
Housing M
I- 08
Connector M
Connector F
Housing F
Terminal F
Housing F
2.8mm(110)
Terminal F
(S)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
0.3〜0.5
Heat-resistant
copper alloy
Tin-plated
镀锡
27.3
2.8
M
(8100-3385)
Terminal(UNIT : mm)
端子(毫米)
4.1
18
3.1
F(8100-3394)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
0.3〜0.5
Heat-resistant
copper alloy
Tin-plated
镀锡
(M)
(L)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
Cable size(mm2)
0.85〜1.25
适用电线大小
Material
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
27.3
2.8
M
(8100-3386)
18
4.1
3.1
F
(8100-3395)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
0.85〜1.25
Surface treatment
表面处理
2.0〜3.0
Heat-resistant
copper alloy
Tin-plated
镀锡
27.3
2.8
M
(8100-3387)
F(8100-3396)
18
4.1
Heat-resistant
copper alloy
Tin-plated
镀锡
Cable size(mm2)
适用电线大小
Material
3.1
材 质
Surface treatment
表面处理
2.0〜3.0
Heat-resistant
copper alloy
Tin-plated
镀锡
SL SERIES
4way
2.8mm
(110)
Color
Natural
自然色
带防转卡钉
颜 色
Note
备 注
19.8
41
14.6
Plate thickness range for clamp:
t=0.6〜2.0mm
Hole=7.2mm×10.2mm
M
(6098-3452)
F(6098-8480)
Housing(UNIT : mm)
接插件护套
(毫米)
16.6
端子参照页
Material
材 质
I-08
11.4
PBT
22
Color
颜 色
I- 09
Natural
自然色
1.5mm, 2.8mm
(060, 110)
Housing(UNIT : mm)
端子参照页
Material
材 质
I- 10
极数/( )内显示 :1.5mm 极数、2.8mm 极数
※ L 尺寸端子的可用接插件有限制。
务必向敝公司销售负责人问讯。
14way(10+4)
颜 色
Natural
自然色
Note)
16.1
41
32.4
M
(6098-3450)
F
(6098-3458)
15.7
29.2
22
Note)
Color
颜 色
PBT
No. of way/( )corresponds to 1.5mm, 2.8mm, in order from left to right.
poled connectors.
SL SERIES
for HYBRID
Color
[1.5mm] I-02
[2.8mm] I-08
Natural
自然色
SL SEALED SERIES
Features
The SL sealed connector series is adopted a
8.0mm types classified according to the
power circuits.
dedicated jig.)
◦RoHS/ELV Compliant
特 点
SL 防水系列接插件采用了以专用治具检测端子半
插入的构造。
按照端子尺寸划分为1.5mm·2.3mm·8.0mm 类
型,从信号回路到电源回路,能广泛运用。
◦接插件可以直接固定在车体的支架上。另外在
接插件上可安装为固定到车体的卡钉(卡子)
负责人确认。
SL SEALED SERIES for STANDARD
1.5mm(060)
Structure/构造
Housing M
Wire seal
Wire seal
Housing M
Terminal M
Terminal M
Connector M
J- 02
Connector F
Stopper
Connector seal
Wire seal
Terminal F
Terminal F
Wire seal
Stopper
Housing F
Housing F
Body fastening clamp and
Body fastening bracket mount
车体固定用卡钉以及
车体固定用支架安装部位
Connector seal
1.5mm
(060)
Terminal(UNIT : mm)
端子(毫米)
※ For terminal selection, please contact our sales staff.
※选定端子时,请一定向敝公司销售负责人问讯。
(S)
(S)
Cable size(mm2)
0.3〜0.5
适用电线大小
Material
Surface treatment
表面处理
Material
27.3
1.5
F
(8100-3397)
18
Cable size(mm2)
适用电线大小
Material
2.8
材 质
Surface treatment
表面处理
0.3〜0.5
Heat-resistant
copper alloy
Tin-plated
镀锡
(M)
Surface treatment
表面处理
M
(8100-3504)
2.6
Material
材 质
Surface treatment
表面处理
F(8100-3402)
18
Cable size(mm2)
适用电线大小
Material
2.8
材 质
Surface treatment
表面处理
0.3〜0.5
Heat-resistant
copper alloy
Gold-plated
镀金
Heat-resistant
copper alloy
Tin-plated
镀锡
Cable size(mm2)
适用电线大小
27.3
Material
材 质
Surface treatment
表面处理
M
(8100-3389)
F
(8100-3398)
Cable size(mm2)
18
适用电线大小
Material
2.8
材 质
Surface treatment
表面处理
0.75〜0.85
Heat-resistant
copper alloy
Tin-plated
镀锡
(L)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
1.25〜2.0
Heat-resistant
copper alloy
Tin-plated
镀锡
1.5
M
(8100-3390)
18
Au
M
(8100-3403)
0.75〜0.85
1.5
2.8
27.3
27.3
F
(8100-3399)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
1.25〜2.0
Heat-resistant
copper alloy
Tin-plated
镀锡
0.75〜0.85
Heat-resistant
copper alloy
Gold-plated
镀金
1.5
27.3
J- 03
SL SEALED SERIES
适用电线大小
2.6
1.5
(M)
Cable size(mm2)
2.6
Heat-resistant
copper alloy
Gold-plated
镀金
材 质
M
(8100-3388)
2.6
0.3〜0.5
适用电线大小
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
Au
Cable size(mm2)
1.5mm(060)
1.5mm
(060)
电线密封栓
(毫米)
盲塞(毫米)
Ref; 1.5mm Terminal detail
1.5mm端子参照页
S
(7165-0516)
M
(7165-0515)
L
(7165-0514)
J- 04
1.5mm盲塞参照页
J-07
(7161-9787)
(7165-0193)
J-07
J-07
B-15
J-07
2way
1.5mm
(060)
Color
颜 色
Note
备 注
Black
黒
J-11
Clamp:TYPE2
15.9
37.6
14.9
Housing(UNIT : mm)
接插件护套
(毫米)
M
(6181-6614)
端子参照页
J-02
Ref: wire seal No.
电线密封栓参照页
J-06
Ref: Dummy plug No.
盲塞参照页
B-15
J-07
Material
材 质
PBT
20.45
颜 色
Note
备 注
28.4
18.1
Color
2way
Color
Dark Gray
深灰
J-11
Clamp:TYPE2
颜 色
Note
备 注
Black
黒
J-11
Clamp:TYPE2
15.9
14.5
14.9
M
(6181-6509)
37.6
F(6189-1073)
20.45
18.1
Black
黒
颜 色
2way
Color
F(6189-1076)
14.9
M
(6181-6492)
37.6
F(6189-1115)
24.4
28.4
Color
颜 色
Dark Gray
深灰
18.1
28.4
Color
颜 色
Note
备 注
Black
黒
J-11
Clamp:TYPE1
2way
2way
F(6189-1144)
F
(6189-1147)
24
18
18.7
26.9
27.8
17
Color
颜 色
Color
Black
黒
Black
黒
颜 色
2way
2way
F(6189-1149)
F
(6189-1150)
22.3
21.95
16.8
28.25
Color
颜 色
Dark Gray
深灰
3way
28.25
16.8
Color
J- 05
14way
Color
颜 色
Dark Gray
深灰
20.25
24.7
28.8
Color
颜 色
34.5
Black
黒
M
(6181-0629)
40.3
F(6189-7262)
Color
颜 色
Note
备 注
Dark Gray
深灰
J-11
Clamp:TYPE1
SL SEALED SERIES
F
(6189-7115)
22.8
Dark Gray
深灰
颜 色
2.3mm(090)
Structure/构造
Terminal M
Wire seal
Housing M
Terminal M
Housing M
Wire seal
Connector M
Connector seal
J- 06
Connector F
Stopper
Wire seal
Terminal F
Wire seal
Stopper
Housing F
Connector seal
2.3mm
(090)
Housing F
车体固定用卡钉以及
车体固定用支架安装部位
2.3mm
(090)
Terminal(UNIT : mm)
端子(毫米)
2.3mm端子参照页
S
(8230-4472) L-02
M
(8230-4562) L-02
F
(8100-1427)
F
(8100-1429)
L
(8230-4552)
F
(8100-1428)
L-02
L-02
L-02
电线密封栓(毫米)
L-02
Regarding "Gold-plated Terminal", please refer "L-02".
镀金端子记载在L-02上
The wire seals are common to M and F.
电线密封栓为公端、母端共用。
(S)
(M)
(7165-0516)
Cable overall diameter(mm) Over than 1.4 mm below 1.6 mm
带绝缘层外径
Material
材 质
Color
颜 色
φ 4.7
φ 4.7
超过1.4mm在1.6mm以下
Silicon
硅
Black
黒
(7165-0515)
Cable overall diameter(mm) Over than 1.6 mm below 2.4 mm
带绝缘层外径
Material
材 质
8.3
Color
颜 色
超过1.6mm在2.4mm以下
Silicon
硅
Gray
灰
8.3
(L)
(7165-0514)
Cable overall diameter(mm) Over than 2.4 mm below 2.7 mm
带绝缘层外径
Material
材 质
Color
颜 色
φ 4.7
超过2.4mm在2.7mm以下
Silicon
硅
Dark Green
墨绿
8.3
J- 07
SL SEALED SERIES
2.3mm(090)
盲塞(毫米)
2.3mm盲塞参照页
(7161-9787)
B-15
(7165-0193)
terminal holes.
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
φ 4.7
Material
材 质
Color
颜 色
Silicon
硅
Green
绿
6.4
1way
2.3mm(090)
Color
颜 色
Dark Gray
深灰
16.3
14
38
Housing(UNIT : mm)
接插件护套
(毫米)
M
(6181-0436)
端子参照页
L-02
Ref: wire seal No.
电线密封栓参照页
J-06
Ref: Dummy plug No.
盲塞参照页
B-11
J-07
Material
材 质
PBT
F(6189-0639)
21.2
17.2
28
Color
颜 色
Note
备 注
Dark Gray
深灰
J-11
Clamp:TYPE1
2way
Color
颜 色
3way
Color
Dark Gray
深灰
颜 色
Dark Gray
深灰
14.7
14.7
19
M
(6181-0437)
38
25
F
(6189-0640)
28
21.3
Color
Dark Gray
深灰
J-11
Clamp:TYPE1
颜 色
Note
备 注
4way
Color
颜 色
F(6189-7784)
19.5
19.5
J- 08
M
(6181-0438)
38
28
27.3
Color
Dark Gray
深灰
J-11
Clamp:TYPE1
颜 色
Note
备 注
6way
Color
Dark Gray
深灰
颜 色
Dark Gray
深灰
20.1
20.1
20.8
M
(6181-0439)
38
F
(6189-0643)
25.7
M
(6181-0440)
38
F(6189-0648)
24.9
24.9
23.1
28
Color
颜 色
Note
备 注
Dark Gray
深灰
J-11
Clamp:TYPE1
28
28
Color
颜 色
Note
备 注
Dark Gray
深灰
J-11
Clamp:TYPE1
8.0mm
(312)
Structure/构造
Housing M
Wire seal
Housing M
Terminal M
Terminal M
Wire seal
Connector M
Connector F
Connector seal
Stopper
Terminal F
Stopper
Terminal F
Wire seal
Housing F
Housing F
车体固定用卡钉以及
车体固定用支架安装部位
Connector seal
8.0mm
(312)
Terminal(UNIT : mm)
端子(毫米)
※For terminal selection, please contact our sales staff.
SL SEALED SERIES
Wire seal
J- 09
(M)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
(L)
Cable size(mm2)
2.0〜3.0
适用电线大小
Material
Brass
黄铜
Tin-plated
镀锡
32
8
材 质
Surface treatment
表面处理
5.0〜8.0
Brass
黄铜
Tin-plated
镀锡
2.8
M
(8100-3259)
9
24.4
适用电线大小
Material
4.2
材 质
Surface treatment
表面处理
J- 10
2.8
F
(8100-3257)
Cable size(mm2)
32
8
M
(8100-3260)
9
2.0〜3.0
F(8100-3258)
24.4
Cable size(mm2)
5.0〜8.0
适用电线大小
Material
Heat-resistant
copper alloy
Tin-plated
镀锡
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
4.2
Surface treatment
表面处理
8.0mm
(312)
8.0mm(312)
电线密封栓
(毫米)
盲塞(毫米)
Ref; 8.0mm Wire Seals detail
8.0mm电线密封栓参照页
Ref; 8.0mm Dummy plug detail
8.0mm盲塞参照页
SS(7165-0683) B-24
S
(7165-0400) B-24
(7165-0180)
M
(7165-0392) B-24
L(7165-0393) B-24
B-25
terminal holes.
电线密封栓为公端、母端共用。
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
2way
8.0mm(312)
Color
颜 色
Dark Gray
深灰
18.4
30.4
Housing(UNIT : mm)
接插件护套
(毫米)
M
(6181-0613)
端子参照页
J-09
Ref: wire seal No.
电线密封栓参照页
B-24
Ref: Dummy plug No.
盲塞参照页
B-25
Material
材 质
PBT
50
F(6189-0915)
25.6
33.6
38.7
Color
颜 色
Note
备 注
Dark Gray
深灰
J-11
Clamp:TYPE1
SL SEALED SERIES
COMMON USE
PARTS
车体固定用卡钉(毫米)
1.5mm standard type, 2.3mm standard type and 8.0mm standard
type connectors, the clamp can be installed.
※ The detail dimensions for the mounting portion are specifi ed in drawing
根据需要,可以在1.5mm 标准·2.3mm 标准·8.0mm 标准的接插件上,安装
用于固定在车体上的卡钉。
※安装部位的详细尺寸另行图纸规定。
Type 1
J- 11
Type 2
材 质
Color
颜 色
hole size
孔 径
卡钉适合板厚
PBT
14.3
Material
Brown
棕
材 质
Color
7.2×10.2
t=0.7〜2.0
(6810-4982)
颜 色
15.6
卡钉适合板厚
PA66
Natural
自然色
t=2.0
16.1
25
SL SEALED SERIES
(6810-1584)
Material
DL SERIES
Features
The DL connector series has a mechanism
that detects when terminals are not inserted
completely.
This series consists of 0.64mm, 1.0mm and
2.3mm types classified according to the
◦The connector mechanism only allows the
retainer to be set when the terminal is
completely inserted.
◦ These connectors can be directly secured
◦RoHS/ELV Compliant
特 点
DL 系列接插件具有检验端子插入不足的构造。
类型,可以应用于各种控制回路与低功率回路。
◦具有当端子在半插入狀態時,鎖片無法安裝到
位的檢驗功能︒
◦接插件可以直接固定在车体的支架上。
DL SERIES for STANDARD
0.64mm
(025)
Structure/构造
安装锁片后
Housing M
Terminal M
Connector M
Connector F
K- 02
安装锁片后
Terminal F
Housing F
0.64mm
(025)
Terminal(UNIT : mm)
端子(毫米)
Ref; 0.64mm Terminal detail
0.64mm端子参照页
S M(8100-4028) C-02 F
(8100-4029)C-02
M M(8100-4027) C-02 F
(8100-4030)C-02
0.64mm
(025)
Housing(UNIT : mm)
接插件护套(毫米)
端子参照页
C-02
Material
材 质
PBT
2way
Color
颜 色
Color
Natural
自然色
颜 色
Note
备 注
Natural
自然色
With body fastening clamp.
带防转卡钉
10.9
14.3
35.7
M
(6098-4569)
35.7
11.8
Plate thickness range for clamp;
t=0.6〜2.0mm
Hole=7.2mm×10.2mm
12.6
M
(6098-4567)
F(6098-4565)
9.8
9
20.4
Color
颜 色
Natural
自然色
K- 03
DL SERIES
1.0mm(040)
This connector has a terminal pitch of 2.5 mm.
端子间间距2.5mm的接插件
Structure/构造
Housing M
Terminal M
Retainer
Retainer sliding direction
通过压入锁片能够检知端子是否
插入到位
K- 04
Connector M
Connector F
Terminal F
Housing F
Retainer
通过压入锁片能够检知端子是否
插入到位
1.0mm
(040)
Terminal(UNIT : mm)
端子(毫米)
Note)M size terminal can be used connector
with insertion cavity specified. For details
※ Surface treatment of gold-plated is available to
meet your needs.
Thick size is for the time being now.
注)M 尺寸端子的可用接插件有限制。
请一定向敝公司销售负责人问讯。
※ 有关镀金式样,根据需要可以定制。
此外、厚度仅供临时参考。
(S)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
(S)
Au
F(8240-0300)
0.3〜0.5
Brass
黄铜
Tin-plated
镀锡
1
Cable size(mm2)
1.8
22.0
2.55
15.25
适用电线大小
Material
材 质
Surface treatment
表面处理
M
(8100-2512)
1.8
2.55
15.25
0.3〜0.5
Heat-resistant
copper alloy
Gold-plated
镀金
F(8100-1710)
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
0.3〜0.5
Heat-resistant
copper alloy
Tin-plated
镀锡
(M)
Cable size(mm2)
适用电线大小
材 质
Surface treatment
表面处理
Brass
黄铜
Tin-plated
镀锡
Note)
1
M
(8100-2513)
DL SERIES
Material
K- 05
0.75, 0.85〜1.25
22.0
F
(8100-2514)
Note)
Cable size(mm2)
1.8
2.55
15.25
适用电线大小
Material
材 质
Surface treatment
表面处理
0.75, 0.85〜1.25
Heat-resistant
copper alloy
Tin-plated
镀锡
4way
1.0mm
(040)
Color
颜 色
Natural
自然色
12.8
Housing(UNIT : mm)
32.8
17.6
接插件护套
(毫米)
端子参照页
K-04
Material
材 质
PBT
with insertion cavity specifi ed. For details
注)M 尺寸端子的可用接插件有限制。
M
(6098-2158)
F(6098-2013)
10.3
14.4
18.5
Color
颜 色
Natural
自然色
8way
12way
Color
F(6098-2289)
Natural
自然色
颜 色
Note)
15.8
22.0
16.1
M
(6098-2206)
19.4
32.8
18.5
Color
颜 色
F
(6098-2208)
Natural
自然色
16way
F(6098-1624)
13.5
15.8
15.5
18.5
Note)
Color
颜 色
K- 06
Natural
自然色
20way
F
(6098-1626)
13.5
29.4
18.5
Color
颜 色
Natural
自然色
24.4
18.5
Color
颜 色
Natural
自然色
2.3mm
(090)
Structure/构造
Housing M
Terminal M
Retainer
通过压入锁片能够检知端子是否
插入到位
Connector M
Connector F
DL SERIES
Terminal F
Housing F
通过压入锁片能够检知端子是否
插入到位
Retainer
2.3mm(090)
2.3mm
(090)
Terminal(UNIT : mm)
端子(毫米)
2.3mm端子参照页
S M(8230-4492)
A-10 F
(8240-4882) A-10
M M(8230-4502)
A-10 F
(8240-4892) A-10
L M(8230-4512) A-10 F
(8240-4942) A-10
镀金端子记载在A-10上
K- 07
Housing(UNIT : mm)
接插件护套(毫米)
端子参照页
A-10
Material
材 质
Low water absorption
Nylon
2way
4way
Color
Color
Natural
自然色
颜 色
Natural
自然色
颜 色
20.4
14.6
37.5
38
15.2
M
(6249-1248)
14.6
F
(6249-1251)
14.1
M
(6249-1249)
17
22
22
12.2
Color
10.7
Natural
自然色
颜 色
K- 08
F
(6249-1252)
Color
Natural
自然色
颜 色
6way
10way
Color
F(6248-5311)
Natural
自然色
颜 色
22.1
18.6
19.5
39.5
23.1
M
(6249-1250)
22
22.8
Color
Natural
自然色
颜 色
F(6249-1253)
15.5
13.3
22
18.8
Color
Natural
自然色
颜 色
14way
16way
Color
Color
Natural
自然色
颜 色
Natural
自然色
颜 色
19.5
19.5
39.1
M
(6249-1265)
F
(6248-5309)
13.3
22
Color
颜 色
Natural
自然色
39.5
43.1
M
(6249-1266)
F
(6248-5310)
13.3
15.5
34.8
39.5
15.5
34.8
22
Color
颜 色
Natural
自然色
DL SEALED SERIES
Features
The DL sealed connector series has a
The series consists of 2.3mm type covering
an extensive array of applications from
signal circuits to power circuits.
the retainer to be set when the terminal is
◦These connectors can be directly secured
◦ In addition, an extra clip can be attached
to the connector to secure it to the car
body.
◦RoHS/ELV Compliant
特 点
DL 防水系列接插件具有检验端子插入不足的功
能。
尺寸为2.3mm 的端子可广泛应用于信号回路或低
功率回路等。
◦具有当端子在半插入状态时,锁片无法安装到
正确位置的检知功能。
◦接插件可以直接固定在车体的支架上。
◦另外在接插件上可安装为固定到车体的卡钉(卡
子)。
DL SEALED SERIES for STANDARD
2.3mm(090)
Structure/构造
Detecting structure for
incomplete terminal insertion
Retainer
检知端子插入不到位的构造
Terminal M
Wire seal
Retainer
Housing M
Housing M
Terminal M
Detection for incomplete
terminal insertion
Wire seal
L- 02
检知端子插入不到位的状态
Connector M
Connector F
Wire seal
Connector seal
Wire seal
检知端子插入不到位的构造
Retainer
Terminal F
Housing F
Connector seal
Retainer
Housing F
车体固定用卡钉以及
车体固定用支架安装部位
terminal insertion
检知端子插入不到位的状态
2.3mm
(090)
Terminal(UNIT : mm)
端子(毫米)
sales staff.
(S)
(S)Au
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
Cable size(mm2)
0.3〜0.5
适用电线大小
2
Brass
黄铜
Tin-plated
镀锡
Material
材 质
26.4
2.3
M
(8230-4472)
F
(8100-1427)
2.4
表面处理
2
Brass
黄铜
Gold-plated
镀金
26.4
2.3
M
(1500-0159)
F(8100-1458)
2.4
18
3
Cable size(mm2)
0.3〜0.5
适用电线大小
Material
3
18
Surface treatment
表面处理
(M)
Cable size(mm2)
Material
Heat-resistant
copper alloy
Gold-plated
镀金
材 质
Surface treatment
表面处理
(M)Au
Cable size(mm2)
适用电线大小
Material
材 质
表面处理
Cable size(mm2)
0.75〜0.85
适用电线大小
2
Brass
黄铜
Tin-plated
镀锡
Material
材 质
26.4
2.3
M
(8230-4562)
F(8100-1429)
2.4
Surface treatment
表面处理
0.75〜0.85
L- 03
2
Brass
黄铜
Gold-plated
镀金
26.4
2.3
M
(1500-0169)
F(8100-1460)
2.4
18
3
Cable size(mm2)
0.75〜0.85
适用电线大小
Material
3
18
Surface treatment
表面处理
(L)
0.75〜0.85
适用电线大小
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
Cable size(mm2)
Material
Heat-resistant
copper alloy
Gold-plated
镀金
材 质
Surface treatment
表面处理
(L)Au
Cable size(mm )
2
适用电线大小
Material
材 质
Surface treatment
F(8100-1459)
1.25〜2.0
2
Brass
黄铜
Tin-plated
镀锡
2
2.4
26.4
2.3
3
18
Cable size(mm2)
适用电线大小
2.3
Material
材 质
Surface treatment
表面处理
M(8230-4552)
F
(8100-1428)
2.4
18
Cable size(mm2)
适用电线大小
Material
材 质
Surface treatment
表面处理
1.25〜2.0
Heat-resistant
copper alloy
Tin-plated
镀锡
1.25〜2.0
26.4
Heat-resistant
copper alloy
Gold-plated
镀金
DL SEALED SERIES
Surface treatment
3
0.3〜0.5
适用电线大小
Heat-resistant
copper alloy
Tin-plated
镀锡
材 质
表面处理
Surface treatment
0.3〜0.5
2.3mm(090)
(SS)
(7165-0210)
φ5
电线密封栓
(毫米)
Cable overall diameter(mm) Over than 1.1 mm below 1.5 mm
带绝缘层外径
◦ The wire seals are common to M and F.
Material
◦电线密封栓为公端、母端共用。
Color
材 质
颜 色
(S)
(7165-0118)
L- 04
超过1.1mm在1.5mm以下
NBR
6.1
Red
红
(M)
(7165-0119)
φ5
Cable overall diameter(mm) Over than 1.5 mm below 2.0 mm
带绝缘层外径
Material
材 质
Color
颜 色
超过1.5mm在2.0mm以下
带绝缘层外径
Material
NBR
Blue
蓝
2.3mm(090)
盲塞(毫米)
2.3mm盲塞参照页
(7161-9787)
B-15
(7165-0193) J-07
terminal holes.
◦盲塞为公端、母端共用。
◦盲塞用于堵塞不使用的端子孔。
φ5
Cable overall diameter(mm) Over than 2.0 mm below 2.9 mm
6.1
材 质
Color
颜 色
超过2.0mm在2.9mm以下
NBR
Brown
棕
6.1
1way
2.3mm(090)
Color
颜 色
Dark Gray
深灰
16.3
14
Housing(UNIT : mm)
接插件护套
(毫米)
M
(6195-0240)
端子参照页
L-02
Ref: wire seal No.
电线密封栓参照页
L-04
Ref: Dummy plug No.
盲塞参照页
B-11
J-07
Material
材 质
PBT or Low water
absorption Nylon
颜 色
F(6195-0066)
21.2
16.6
Color
28
Note
3way
Color
Dark Gray
深灰
颜 色
Dark Gray
深灰
L- 05
19
M
(6195-0006)
F(6195-0003)
M
(6195-0012)
21.3
28
Color
27.3
Dark Gray
深灰
L-07
Bracket Clamp : TYPE2
颜 色
Note
备 注
4way
F
(6195-0009)
28
Color
Dark Gray
深灰
L-07
颜 色
Note
备 注
6way
Color
Dark Gray
深灰
颜 色
Dark Gray
深灰
20.1
20.1
20.8
M
(6195-0018)
25.7
38
F(6195-0015)
M
(6195-0024)
38
F
(6195-0021)
24.3
24.3
23.1
38
18.9
18.9
颜 色
25
38
28
Color
颜 色
Note
备 注
Dark Gray
深灰
L-07
28
28
Color
颜 色
Note
备 注
Dark Gray
深灰
L-07
DL SEALED SERIES
14.7
14.7
Color
Dark Gray
深灰
L-07
颜 色
备 注
2way
Color
38
8way
Color
颜 色
10way
Color
Dark Gray
深灰
Light Gray
浅灰
颜 色
20.1
25.7
31.7
30.5
38
M
(6195-0054)
F
(6195-0051)
24.3
F(6195-0164)
31
Color
34
28
Dark Gray
深灰
L-07
颜 色
Note
备 注
12way
Color
L- 06
M
(6195-0167)
40
颜 色
33.2
Color
Light Gray
浅灰
L-07
颜 色
Note
备 注
16way
Color
Dark Gray
深灰
Dark Gray
深灰
L-07
Bracket Clamp : TYPE1
颜 色
Note
备 注
25.7
31.7
M(6195-0152)
33.8
40
F
(6195-0149)
31
34.4
28
33.1
M
(6188-0495)
45.3
F(6189-0715)
29.3
28
Color
颜 色
Note
备 注
Dark Gray
深灰
L-07
30.6
25.5
Color
颜 色
Dark Gray
深灰
DL SEALED SERIES
COMMON USE
PARTS
2.3mm standard type connectors, the clamp can be installed.
※ The detail dimensions for the mounting portion are specified in drawing
根据需求可以在2.3mm 标准的接插件上,安装用于固定在车体上的卡钉。
※安装部位的详细尺寸另行图纸规定。
L- 07
DL SEALED SERIES
Type 1
Type 2
(6810-2653)
Material
材 质
PA6T
Color
Natural
自然色
hole size
φ7.0
颜 色
孔 径
卡钉适合板厚
t=0.6〜1.6
(6810-1584)
Material
材 质
14.3
Color
颜 色
hole size
18
孔 径
卡钉适合板厚
PBT
14.3
Brown
棕
7.2×10.2
t=0.7〜2.0
15.6
HFCⅢ SERIES
Features
HFCⅢ (High Frequency Connector) series are
connectors that connect on-board multimedia
devices, such as GPS, TV, VICS and etc., and
coaxial wires. These are also suitable for
mobile telephone and sensor circuit.
◦ It reduces reflection/transmission loss and
restraints noise radiation. It achieved
smaller size with higher performance.
◦H
ybrid types for high frequency coaxial
wire and automobile wire (AV) are
estabished. (It supports diversity receiving
system).
◦Retainer for secondary lock is preloaded
and the strucrure allows the high
frequency coaxial wire and AV wire to be
s et by on e op e r at i on. T h e r efo r e
improvement of assembling operation can
be planned.
◦RoHS/ELV Compliant
特 点
HFC Ⅲ系列(高频接插件)使用于 GPS·TV·VICS
等车载多媒体模块相同的同轴线连接用接插件,
也适用于车载电话、传感器回路上。
◦制止传送损失、反射、杂讯放射、实现了小型
高性能化。
◦设定了高频同轴线和汽车用电线
(AV)的混合型。
(可以应用于多样性收信方式。)
◦通过预先安装双重锁定锁片、高频同轴线与 AV
线都能够通过简单的操作进行安装,可提高效
率。
HFCⅢ SERIES for STANDARD
Structure/构造
Inner conductor terminal
内导体端子
Interlock
Female Housing
Dielectric
母端接插件护套
感应体
Outer conductor terminal
外导体端子
Female Retainer
母端锁片
Male Retainer
公端锁片
Male Housing
M-02
公端接插件护套
Outer Conductor terminal
Standard bracket fixing part
外导体端子
标准支架固定部
Earthing terminal
接地线端子
Dielectric
感应体
内导体端子
Secondary lock part
(End of stabilizer of outer conductor terminal)
Primary lock part
(End of box part of outer conductor terminal)
1次锁定部(外导体端子的箱部后端)
2次锁定部(外导体端子的稳定器后端)
Secondary lock structure of HFCⅢ
HFCⅢ的双重锁定结构
Basic specification/基本规格
Inner conductor
1 way coaxial wire
2 way coaxial wire + 1way AV wire
3 way coaxial wire
4 way coaxial wire + 2way AV wire
Contact
resistance
接触电阻
M Terminal
2 way coaxial wire + 2way AV wire
Type
Coaxial wire
AV wire
Insulation resistance
材质
Inner conductor
内导体
F Terminal
Outer conductor
外导体
Min. 100MΩ
绝缘电阻
黄铜(镀锡)
Material
Max. 8mΩ
(Initial/初期)
AV线
Brass (Sn plating)
Outer conductor
外导体
Max. 20mΩ(Initial/初期)
同轴线
内导体
Heat resistant cooper-alloy
(Au plating)
耐热铜合金(镀金)
Brass (Sn plating)
黄铜(镀锡)
(Note) AV wire = MAX. AVSS 0.5mm2 (Terminal is TS 0.64 type: Ref. A-02).
注)AV线=最大AVSS 0.5mm(端子为TS0.64:参照A-02)
2
Working temperature
-40℃〜+105℃
使用温度
〜180MHz
75Ω系
〜770MHz
VSWR
50Ω系
〜3GHz
Wire to Wire
PCB to Wire
Wire to Wire
PCB to Wire
Max. 1.2
Max. 1.4
Wire to Wire
Max. 1.4
PCB to Wire
Max. 1.3
(mm)/内导体端子
(毫米)
(M)
(F)
S
(8230-5015)M(8230-5016)L
(8230-5017)
S
(8240-0276)M
(8240-0277)L(8240-0278)
M-03
HFC Ⅲ SERIES
(mm)/外导体端子
(毫米)
(M)
(F)
S
M(8230-5482)L
(8230-5481)
(8230-5484)
转 播 用:S
(8240-0382)M
(8240-0383)F
(8240-0619)
无线电用:S
(8240-0387)M
(8240-0388)
(Note) The terminal for radio can connecta condenser inside. On this occasion,
a common crimping terminal is necessary.
注)
无线电用端子内部可以连接电容器。
此时需要共同的压接端子(8110-4493)。
Applicable coaxial wire/适用同轴线
Applicable coaxial wire (Note 1)
1.5C-2V
1.5C-2W
1.5D-2V
1.5D-2W
2.5D
内导体端子
S
S
M
M
L
外导体端子
S
M
S
S
F
适用同轴线 注1)
(Note 1) For some coaxial wire and wire makers, it might be inapplicable. Please
contact our sales representative for more details.
注1)
由于各电线商家的同轴线不同,
是否适用请向敝公司的销售负责人问询
(Note 2) When crimping the forming coaxial wire, need the sleeve.
注2)
泡沫聚乙烯绝缘同轴线压接时需要使用套管。
Housing(UNIT : mm)
接插件护套
(毫米)
端子参照页
coaxial wire
同轴线
M-03
AV wire
AV线
A-02
1way coaxial wire
Color
Rib R1
颜 色
1way coaxial wire
Color
Blue
蓝
颜 色
M-04
Rib L1
Gray
灰
13
13
27.7
27.7
13.2
M
(6098-7143)
13.2
F
(6098-6321)
M
(6098-6835)
12.8
12.8
8
18.15
Color
8
Blue
蓝
颜 色
1way coaxial wire
Color
18.15
Color
Rib R2
1way coaxial wire
Color
Rib L2
Natural
自然色
颜 色
13
13
27.7
27.7
13.2
13.2
M
(6098-7544)
F
(6098-7445)
M
(6098-7546)
12.8
8
Gray
灰
颜 色
Black
黒
颜 色
F(6098-6323)
F(6098-7446)
12.8
18.15
Color
颜 色
Black
黒
8
18.15
Color
颜 色
Natural
自然色
2 way coaxial wire + 1 way AV wire
Color
Rib R
Color
Gray
灰
颜 色
颜 色
Gray
灰
17.9
17.9
32.95
32.95
18.3
M
(6098-6331)
18.3
M
(6098-6373)
F
(6098-6336)
10.9
13
21
Color
Gray
灰
颜 色
Color
Rib L
Color
Natural
自然色
颜 色
颜 色
Natural
自然色
M-05
17.9
17.9
18.3
M
(6098-6328)
M
(6098-6370)
F
(6098-6333)
10.9
13
21
Color
Natural
自然色
颜 色
2 way coaxial wire + 2 way AV wire
Color
Rib R
Color
Gray
灰
颜 色
颜 色
Natural
自然色
21.4
21.4
32.95
32.95
13
13
M
(6098-7151)
Rib L
F
(6098-7153)
M
(6098-7145)
F(6098-7148)
16.2
16.2
12.8
18.35
Color
颜 色
Gray
灰
12.8
18.35
Color
颜 色
Natural
自然色
HFC Ⅲ SERIES
32.95
32.95
18.3
3 way coaxial wire
Color
Color
Blue
蓝
颜 色
颜 色
Blue
蓝
20.8
20.8
27.7
18.2
27.7
18.2
M
(6098-6340)
M
(6098-6369)
F
(6098-6343)
13.6
18.15
12.8
Color
Blue
蓝
颜 色
3 way coaxial wire
Color
4 way coaxial wire + 2 way AV wire
Color
Blue
蓝
颜 色
颜 色
M-06
Natural
自然色
13
15.7
27.7
24.2
M
(6098-6838)
F
(6098-6841)
M
(6098-6844)
12.8
19
32.95
37.6
F(6098-6702)
12.3
18.35
32.4
Color
颜 色
Blue
蓝
18.35
Color
颜 色
Natural
自然色
HFCⅢ SERIES
for PCB
Housing(UNIT : mm)
接插件护套(毫米)
Through Hall Type(Rib R) M-07
1 way coaxial wire
M
(6098-6157)
13.4
25.57
Connector F part No.
6098-6321(M-04)
Color
Blue
蓝
母端接插件产品号码
颜 色
●Recommended demension of
Circuit board
电路板推荐尺寸
19.45
Through Hall Type(Rib L)
1 way coaxial wire
M
(6098-6159)
●Detailed dimension
详细尺寸
13.4
6098-6323(M-04)
Color
Gray
灰
母端接插件产品号码
颜 色
25.57
Circuit board
电路板推荐尺寸
19.45
Through Hall Type
M
(6098-6700)
●Detailed dimension
详细尺寸
14.7
6098-6702(M-06)
Color
Natural
自然色
母端接插件产品号码
颜 色
HFC Ⅲ SERIES
●Detailed dimension
详细尺寸
43.4
19.85
Circuit board
电路板推荐尺寸
SMT Type(Rib R1)
1 way coaxial wire
M
(6098-7132)
●Detailed dimension
详细尺寸
13
6098-6321(M-04)
Color
Blue
蓝
母端接插件产品号码
颜 色
24.6
Circuit board
电路板推荐尺寸
13.1
SMT Type(Rib R2)
1 way coaxial wire
M
(6098-7449)
●Detailed dimension
详细尺寸
13
母端接插件产品号码
Color
颜 色
M-08
24.6
6098-7445(M-04)
Circuit board
电路板推荐尺寸
13.1
Black
黒
SMT Type(Rib L1)
1 way coaxial wire
M
(6098-7134)
●Detailed dimension
详细尺寸
13
母端接插件产品号码
Color
颜 色
24.6
6098-6323(M-04)
Circuit board
电路板推荐尺寸
13.1
Gray
灰
SMT Type(Rib L2)
1 way coaxial wire
M
(6098-7450)
●Detailed dimension
详细尺寸
13
母端接插件产品号码
Color
颜 色
24.6
6098-7446(M-04)
Natural
自然色
13.1
Circuit board
电路板推荐尺寸
HFCⅢ SERIES
for RADIO
Color
Natural
自然色
颜 色
M-09
21.2
HFC Ⅲ SERIES
40.05
13.45
M
(6098-6861)
F
(6098-6037)
21.25
27.1
12.45
Color
Natural
自然色
颜 色
Through Hall Type
M
(6098-5761)
●Detailed dimension
详细尺寸
28.9
6098-6037(M-09)
Color
Natural
自然色
母端接插件产品号码
颜 色
13.45
36.6
Circuit board
电路板推荐尺寸
INDEX
INDEX
Part No.
Page
Part No.
Page
Part No.
Page
Part No.
Page
1500-0159
L-03
6098-2680
I-06
6098-4018
C-23
6098-4975
C-15
1500-0166
C-12
6098-2764
C-08
6098-4050
C-11
6098-4977
C-15
1500-0169
L-03
6098-2779
C-07
6098-4069
C-10
6098-4978
C-03
5010-8627
E-08
6098-2780
C-07
6098-4071
C-10
6098-4979
C-04
5011-1590
E-08
6098-2781
C-07
6098-4073
C-10
6098-4982
C-04
5011-6687
E-08
6098-2782
C-07
6098-4075
C-18
6098-5000
C-04
5011-6818
E-12
6098-2784
C-08
6098-4076
C-18
6098-5049
C-10
5011-7740
E-12
6098-2785
C-08
6098-4333
C-04
6098-5070
C-03
5011-7860
E-12
6098-2786
C-19
6098-4339
C-04
6098-5071
C-03
6098-0149
A-16
6098-2788
C-08
6098-4367
C-18
6098-5119
C-13
6098-0151
A-16
6098-2789
C-08
6098-4565
K-03
6098-5120
C-13
6098-0154
A-17
6098-3239
C-22
6098-4567
K-03
6098-5180
C-16
6098-0156
A-17
6098-3369
C-08
6098-4569
K-03
6098-5217
C-20
6098-0323
A-16
6098-3370
C-19
6098-4588
C-04
6098-5218
C-20
6098-0325
A-16
6098-3449
I-04
6098-4589
C-04
6098-5267
F-03
6098-0441
A-19
6098-3450
I-10
6098-4590
C-05
6098-5269
F-03
6098-0469
A-16
6098-3452
I-09
6098-4591
C-16
6098-5271
F-03
6098-0471
A-16
6098-3453
I-04
6098-4594
C-04
6098-5273
F-04
6098-0518
A-16
6098-3456
I-03
6098-4595
C-04
6098-5275
F-04
6098-0822
A-15
6098-3458
I-10
6098-4596
C-05
6098-5277
F-04
6098-0824
A-15
6098-3563
C-11
6098-4597
C-16
6098-5279
F-05
6098-1104
A-19
6098-3565
C-20
6098-4640
C-04
6098-5281
F-05
6098-1278
A-19
6098-3567
C-21
6098-4660
C-20
6098-5283
F-05
6098-1373
C-11
6098-3569
C-21
6098-4661
C-11
6098-5285
F-05
6098-1377
C-11
6098-3571
C-18
6098-4662
C-11
6098-5287
F-06
6098-1378
C-11
6098-3572
C-22
6098-4663
C-13
6098-5289
F-06
6098-1380
C-11
6098-3600
C-18
6098-4664
C-11
6098-5291
F-06
6098-1489
A-16
6098-3601
C-18
6098-4666
C-18
6098-5293
F-06
6098-1624
K-06
6098-3616
C-23
6098-4667
C-13
6098-5295
F-06
6098-1626
K-06
6098-3802
A-04
6098-4669
C-11
6098-5297
F-06
6098-1627
I-07
6098-3810
A-04
6098-4670
C-11
6098-5310
F-03
6098-1714
I-06
6098-3818
A-22
6098-4675
C-04
6098-5312
F-04
6098-1716
A-16
6098-3826
A-22
6098-4707
C-17
6098-5585
F-06
6098-1744
I-07
6098-3869
A-04
6098-4725
C-17
6098-5594
A-21
6098-1746
I-07
6098-3877
A-04
6098-4726
C-17
6098-5604
A-21
6098-1747
I-06
6098-3885
A-05
6098-4740
A-06
6098-5613
A-21
6098-1774
I-06
6098-3893
A-21
6098-4756
A-05
6098-5622
A-21
6098-1851
A-16
6098-3901
A-22
6098-4831
A-06
6098-5631
A-21
6098-2013
K-05
6098-3909
A-04
6098-4876
I-04
6098-5641
A-21
6098-2101
I-06
6098-3917
A-04
6098-4877
I-04
6098-5650
A-20
6098-2137
A-19
6098-3925
A-05
6098-4901
C-10
6098-5659
A-20
6098-2158
K-05
6098-3933
A-21
6098-4902
C-10
6098-5668
A-09
6098-2206
K-06
6098-3941
A-22
6098-4908
C-16
6098-5677
A-09
6098-2208
K-06
6098-4008
A-05
6098-4943
C-04
6098-5686
A-09
6098-2211
A-16
6098-4010
A-05
6098-4944
C-03
6098-5695
A-09
6098-2289
K-06
6098-4013
A-05
6098-4971
C-13
6098-5704
A-09
6098-2329
G-11
6098-4015
A-06
6098-4973
C-14
6098-5713
A-09
6098-2679
I-06
6098-4017
C-19
6098-4974
C-14
6098-5761
M-09
Part No.
Page
Part No.
Page
Part No.
Page
Part No.
Page
6098-5833
C-03
6098-6793
A-24
6181-0439
J-08
6185-5181
G-06
6098-5888
C-07
6098-6796
A-25
6181-0440
J-08
6188-0047
B-15
6098-5903
A-22
6098-6798
A-25
6181-0511
G-09
6188-0049
B-25
6098-5988
F-08
6098-6803
A-25
6181-0512
G-10
6188-0066
B-17
6098-5989
F-08
6098-6805
A-25
6181-0513
G-09
6188-0067
B-18
6098-6037
M-09
6098-6810
A-26
6181-0514
G-09
6188-0083
B-21
6098-6050
A-09
6098-6835
M-04
6181-0515
G-08
6188-0091
B-29
6098-6053
A-09
6098-6838
M-06
6181-0516
G-09
6188-0096
B-25
6098-6055
A-20
6098-6841
M-06
6181-0522
G-10
6188-0099
B-16
6098-6083
A-20
6098-6844
M-06
6181-0532
G-09
6188-0101
B-29
6098-6090
A-20
6098-6848
A-25
6181-0536
G-09
6188-0108
B-15
6098-6097
A-20
6098-6861
M-09
6181-0613
J-10
6188-0129
B-22
6098-6104
A-20
6098-6869
A-26
6181-0629
J-05
6188-0141
B-17
6098-6111
A-20
6098-7060
F-05
6181-0664
G-09
6188-0173
B-18
6098-6157
M-07
6098-7061
F-05
6181-0665
G-09
6188-0175
B-18
6098-6159
M-07
6098-7063
F-03
6181-0666
G-10
6188-0187
B-29
6098-6161
C-16
6098-7066
F-04
6181-0667
G-10
6188-0209
B-18
6098-6162
C-16
6098-7067
F-04
6181-0668
G-09
6188-0217
B-17
6098-6321
M-04
6098-7099
F-05
6181-0669
G-09
6188-0221
B-29
6098-6323
M-04
6098-7100
F-05
6181-0670
G-08
6188-0229
B-16
6098-6328
M-05
6098-7102
A-26
6181-0671
G-09
6188-0259
B-21
6098-6331
M-05
6098-7132
M-08
6181-0803
E-19
6188-0266
B-15
6098-6333
M-05
6098-7134
M-08
6181-6464
E-21
6188-0282
B-17
6098-6336
M-05
6098-7143
M-04
6181-6465
E-21
6188-0327
B-18
6098-6340
M-06
6098-7145
M-05
6181-6481
D-04
6188-0415
B-29
6098-6343
M-06
6098-7148
M-05
6181-6492
J-04
6188-0470
B-16
6098-6369
M-06
6098-7151
M-05
6181-6509
J-04
6188-0472
B-18
6098-6370
M-05
6098-7153
M-05
6181-6614
J-04
6188-0495
L-06
6098-6373
M-05
6098-7229
A-24
6181-6658
H-03
6188-0517
B-17
6098-6451
F-04
6098-7231
A-05
6181-6783
E-16
6188-0551
G-05
6098-6452
F-04
6098-7241
A-04
6181-6784
E-16
6188-0552
G-05
6098-6455
F-04
6098-7253
F-08
6181-6785
E-21
6188-0553
G-05
6098-6456
F-04
6098-7254
F-08
6181-6850
E-16
6188-0554
G-05
6098-6457
F-05
6098-7261
F-08
6181-6851
E-15
6188-0555
G-06
6098-6478
C-16
6098-7336
A-05
6181-6921
E-22
6188-0556
G-05
6098-6522
F-04
6098-7445
M-04
6185-0862
G-05
6188-0557
G-06
6098-6523
F-04
6098-7446
M-04
6185-0865
G-05
6188-0558
G-06
6098-6524
F-05
6098-7449
M-08
6185-0866
G-05
6188-0589
E-04
6098-6559
C-17
6098-7450
M-08
6185-0867
G-05
6188-0590
E-04
6098-6562
C-16
6098-7544
M-04
6185-0868
G-06
6188-0624
B-16
6098-6653
A-04
6098-7546
M-04
6185-0869
G-05
6188-0657
E-04
6098-6662
A-04
6098-8478
I-06
6185-1101
G-05
6188-0658
E-05
6098-6682
A-05
6098-8480
I-09
6185-1169
G-06
6188-0660
E-07
6098-6688
A-05
6098-8482
I-04
6185-1171
G-06
6188-0663
G-05
6098-6694
A-05
6181-0381
E-22
6185-4596
E-21
6188-0696
B-06
6098-6700
M-07
6181-0436
J-07
6185-5175
G-06
6188-0697
E-09
6098-6702
M-06
6181-0437
J-08
6185-5177
G-06
6188-0698
E-09
6098-6790
A-24
6181-0438
J-08
6185-5179
G-07
6188-0706
B-06
INDEX
INDEX
INDEX
Part No.
Page
Part No.
Page
Part No.
Page
Part No.
Page
6188-0779
B-06
6189-0593
E-19
6189-1096
G-12
6189-7156
B-30
6188-4739
E-05
6189-0596
E-19
6189-1097
G-12
6189-7167
B-07
6188-4775
D-03
6189-0611
B-16
6189-1104
G-09
6189-7188
H-03
6188-4776
D-04
6189-0617
E-19
6189-1107
G-08
6189-7189
H-03
6188-4787
E-08
6189-0629
B-17
6189-1108
G-10
6189-7190
H-03
6188-4789
E-08
6189-0639
J-07
6189-1109
G-10
6189-7214
H-03
6188-4797
B-05
6189-0640
J-08
6189-1115
J-04
6189-7256
B-26
6188-4908
D-04
6189-0643
J-08
6189-1128
B-06
6189-7262
J-05
6188-4914
B-06
6189-0648
J-08
6189-1129
B-05
6189-7263
E-12
6188-4920
B-05
6189-0682
B-16
6189-1132
B-05
6189-7264
E-12
6188-5103
B-27
6189-0685
B-18
6189-1133
B-06
6189-7393
G-13
6188-5295
B-26
6189-0694
B-17
6189-1134
B-06
6189-7398
B-17
6188-5516
B-10
6189-0715
L-06
6189-1135
B-07
6189-7401
B-05
6188-5539
G-06
6189-0772
G-11
6189-1136
B-27
6189-7408
E-15
6188-5540
G-06
6189-0773
G-12
6189-1142
B-06
6189-7409
E-16
6188-5542
G-07
6189-0774
G-12
6189-1144
J-05
6189-7410
E-16
6188-5544
G-06
6189-0775
G-12
6189-1147
J-05
6189-7411
E-21
6189-0100
B-15
6189-0776
G-12
6189-1149
J-05
6189-7423
E-16
6189-0101
B-25
6189-0777
G-12
6189-1150
J-05
6189-7426
B-27
6189-0126
B-17
6189-0778
G-12
6189-1160
B-27
6189-7433
B-11
6189-0127
B-18
6189-0855
E-05
6189-1161
B-05
6189-7434
B-11
6189-0143
B-29
6189-0856
B-25
6189-1231
B-05
6189-7435
B-11
6189-0144
B-29
6189-0887
E-05
6189-1240
B-06
6189-7436
B-11
6189-0145
B-21
6189-0890
E-04
6189-6863
E-21
6189-7449
B-10
6189-0165
B-22
6189-0891
E-04
6189-6894
B-27
6189-7469
G-12
6189-0166
B-29
6189-0915
J-10
6189-6906
D-04
6189-7470
G-12
6189-0172
B-25
6189-0928
G-09
6189-6909
D-04
6189-7471
G-12
6189-0179
B-16
6189-0940
E-04
6189-6914
E-08
6189-7494
E-16
6189-0181
B-29
6189-0950
G-09
6189-6934
B-26
6189-7546
B-11
6189-0199
B-15
6189-0951
G-08
6189-6953
B-25
6189-7547
B-11
6189-0249
B-15
6189-0954
G-10
6189-6978
B-27
6189-7567
E-22
6189-0264
B-16
6189-0955
G-10
6189-6979
B-27
6189-7691
B-26
6189-0319
B-18
6189-0968
E-05
6189-6980
B-27
6189-7710
G-12
6189-0323
B-18
6189-1012
E-05
6189-6981
B-27
6189-7711
G-12
6189-0368
B-18
6189-1046
B-05
6189-6987
B-07
6189-7713
G-12
6189-0372
B-17
6189-1048
B-27
6189-7020
B-05
6189-7714
G-12
6189-0376
B-29
6189-1050
E-09
6189-7036
D-03
6189-7716
G-12
6189-0381
B-17
6189-1051
E-09
6189-7037
D-03
6189-7717
G-12
6189-0388
B-16
6189-1073
J-04
6189-7039
D-04
6189-7756
G-09
6189-0413
B-21
6189-1076
J-04
6189-7040
D-04
6189-7757
G-09
6189-0425
B-21
6189-1081
E-05
6189-7052
D-03
6189-7758
G-09
6189-0443
B-17
D-03
6189-7759
G-09
B-18
E-07
E-08
6189-7058
6189-0504
6189-1082
6189-7073
B-05
6189-7760
G-09
6189-0552
E-19
6189-1083
B-06
6189-7077
B-26
6189-7761
G-09
6189-0555
E-22
6189-1092
B-06
6189-7094
B-28
6189-7762
G-09
6189-0566
B-16
6189-1093
G-12
6189-7100
B-06
6189-7763
G-09
6189-0573
B-16
6189-1094
G-12
6189-7110
B-07
6189-7784
J-08
6189-0591
E-19
6189-1095
G-12
6189-7115
J-05
6189-7809
B-28
Part No.
Page
Part No.
Page
Part No.
Page
Part No.
Page
6195-0003
L-05
6249-1250
K-08
6918-1653
G-09
7165-0147
E-21
6195-0006
L-05
6249-1251
K-08
6918-1654
G-09
7165-0148
E-21
6195-0009
L-05
6249-1252
K-08
6918-1762
E-05
7165-0172
E-20
6195-0012
L-05
6249-1253
K-08
6918-1773
G-05
6195-0015
L-05
6249-1265
K-08
6918-1774
G-05
7165-0180
B-25
J-10
6195-0018
L-05
6249-1266
K-08
6195-0021
L-05
6520-0549
A-12
6918-1775
G-05
G-06
6195-0024
L-05
6520-0550
A-12
6918-1776
G-06
6195-0051
L-06
6520-1004
A-13
6918-1779
G-06
7165-0193
6195-0054
L-06
6520-1009
A-13
6195-0066
L-05
6520-1466
A-19
6918-1780
G-06
G-07
E-07
E-18
H-03
J-04
J-07
L-04
6195-0149
L-06
6810-1203
C-24
E-18
L-06
6810-1204
C-24
D-03
E-05
7165-0194
6195-0152
6918-1833
7165-0198
E-18
6918-1835
D-03
E-04
7165-0210
L-04
7165-0342
B-14
6195-0164
L-06
6810-1217
C-24
6195-0167
L-06
6810-1462
C-24
6195-0240
L-05
6810-1584
J-11
6918-1979
E-04
7165-0343
B-14
6240-1033
A-13
6810-1584
L-07
6918-2056
E-05
7165-0344
B-14
6240-1077
A-12
6810-2653
L-07
6918-2103
E-09
7165-0346
B-20
6240-1093
A-19
6810-4982
J-11
6918-2104
E-09
7165-0347
B-20
6240-1107
A-12
6910-0119
C-24
B-20
A-12
6910-0120
C-24
D-04
E-05
7165-0348
6240-1120
6918-2128
7165-0349
B-14
6240-1122
A-13
6911-5774
B-11
6918-2131
E-07
7165-0351
B-14
6918-2132
E-07
E-08
7165-0356
B-20
7165-0385
E-18
7165-0392
B-24
J-10
7165-0393
B-24
J-10
7165-0395
B-14
7165-0400
B-24
J-10
7165-0432
D-03
E-04
6240-1158
A-13
6911-5948
B-28
6240-5035
A-13
6914-0050
E-07
6240-5088
A-13
6914-0127
E-11
6918-2665
E-19
6240-5118
A-12
6918-1260
E-19
6918-2804
D-04
6240-5175
A-13
6918-1263
E-22
6918-2806
D-04
6240-5337
I-06
6918-1267
E-22
6918-2810
D-04
6240-5339
I-06
6918-1370
E-19
6918-2913
D-04
6240-5378
C-11
6918-1371
E-19
6918-3166
E-12
E-09
6241-0241
A-23
6918-1469
E-19
6920-0861
6241-0261
A-22
6918-1594
G-11
6920-0884
E-09
E-09
6241-0281
A-23
6918-1594
G-12
6920-0886
6245-0261
A-23
6918-1595
G-12
6920-2376
E-09
7165-0471
G-04
6245-0281
A-22
6918-1596
G-12
6920-2377
E-09
7165-0472
G-04
6245-0301
A-23
6918-1597
G-13
6920-2446
E-09
7165-0473
G-04
6248-5270
A-12
6918-1598
G-09
6950-1054
C-20
7165-0474
G-04
6248-5275
A-13
6918-1599
G-09
6950-1055
C-20
6248-5276
A-13
6918-1600
G-09
6950-1056
C-20
7165-0514
6248-5309
K-08
6918-1601
G-09
7160-9465
B-15
H-02
J-04
J-07
6248-5310
K-08
6918-1602
G-10
7161-9787
B-15
J-04
L-04
7165-0515
H-02
J-04
J-07
7165-0516
H-02
J-04
J-07
7165-0621
D-02
E-03
6248-5311
K-08
6918-1603
G-10
6249-1229
A-12
6918-1604
G-12
6249-1234
A-13
6918-1636
G-11
7165-0118
L-04
6249-1235
A-13
A-12
G-08
G-09
L-04
6249-1243
6918-1651
7165-0119
7165-0130
E-20
6249-1248
K-08
6918-1652
G-09
7165-0131
E-21
6249-1249
K-08
6918-1653
G-08
7165-0145
B-21
INDEX
INDEX
INDEX
Part No.
Page
Part No.
Page
Part No.
Page
Part No.
Page
7165-0622
D-02
E-03
8100-0522
A-19
C-21
8100-2971
C-07
8100-3627
A-03
8100-2972
C-07
8100-3628
A-03
7165-0683
B-24
8100-0594
B-13
8100-2980
B-24
8100-3629
A-03
7165-0683
J-10
8100-0606
C-12
8100-3067
D-02
E-03
8100-3708
B-03
8100-3803
G-03
8100-3068
D-02
E-03
8100-3804
G-03
8100-3805
G-03
8100-3806
G-03
8100-4027
C-03
K-02
8100-4028
C-03
K-02
8100-4029
C-03
K-02
8100-4030
C-03
K-02
7165-0797
B-04
8100-0660
E-20
7165-0842
B-14
8100-0661
E-20
7165-1043
B-04
8100-0664
C-12
7165-1075
D-02
E-03
8100-0706
C-21
8100-3082
E-07
8100-0707
A-18
C-21
8100-3083
E-07
8100-3177
D-02
E-03
7165-1131
G-04
7165-1198
B-04
8100-0782
C-12
7165-1199
B-04
8100-0817
B-13
7165-1312
B-04
8100-1007
B-13
7165-1423
B-04
8100-1008
B-13
8100-3257
J-10
7165-1562
E-14
8100-1340
B-13
8100-3258
J-10
7165-1563
E-15
8100-1341
A-11
8100-3259
J-10
7165-1564
E-15
8100-1342
A-11
8100-3260
J-10
8100-4172
G-03
7165-1565
E-
