50033-18AW-2
50033-18AW-2
    LONGSUN(朗森)
    弯插,P=5mm
    端子,3*6pin,50033-18AW-2,5.0mm,弯插,PCB焊接,20A,黑色,本松PBTV2.0
50033-18AW-2 数据手册
乐清市朗森电气有限公司 NO.: PS2726 产品规格承认书 PRODUCT SPECIFICATION 顾客Client: 产品型号: Product Type: 产品名称: Product Name: 产品编码: Part Number 版本号: Version Number: 供应商:朗森电气 50033系列 50033-(N)AW-2 / A/0 B/0 内部确认 制定 Edit 周莉 审核 胡兴翠 Check 批准 Approval 客户确认 采购部 Stocks 工程部 品质部 Eng.Dept Q.C.Dept 乐清市朗森电气有限公司 电话(TEL):0577-61388804 传真(FAX):0577-61388801 E-mail: L3ls@foxmail.com htpp://www. Http://www.3ls.com.cn 地址:浙江省乐清市城东街道永兴二路3号 ADD: Zhejiang yueqing city east street yongxing 2 no. 3 Page 1 of 9 刘兵 乐清市朗森电气有限公司 CONTENT 封面 The Cover...................................................................................................................................................1 目次 To Discuss................................................................................................................................................ 2 0 更改记录 HISTORY RECORD .....................................................................................................................3 1 产品简图 Outline drawing ....................................................................................................................... 3 1.1 材质报告 Material report ................................................................................................................. 3 1.2 物料明细表 BOM ................................................................................................................................... 3 2 总体要求 General ........................................................................................................................................ 4 2.1 功能描述 Functional description ............................................................................................................... 4 2.2 安装位置 Mounting location ...................................................................................................................... 4 2.3 温度范围 Ambient temperature range ....................................................................................................... 4 2.4 电压范围 Voltage range ............................................................................................................................. 4 3 默认测试条件 Default test conditions ................................................................................................. 4 4 产品性能 Performance ..............................................................................................................................4 项目 ....................................................................................................................................................................... 4 Item ........................................................................................................................................................................ 4 4.1 外观 Appearance ......................................................................................................................................... 4 4.2 电压降 Voltage Drop .................................................................................................................................4 4.3 接触电阻 Contact resistance ...................................................................................................................... 5 4.4 绝缘电阻 Insulation resistance ............................................................................................................... 5 4.5 耐电压 Withstand voltage ........................................................................................................................... 5 4.6 漏电流 Current leakage ............................................................................................................................5 4.7 可焊性 Solder ability ................................................................................................................................... 6 4.8 耐焊接热 Resistance to solder heat ........................................................................................................... 5 4.9 耐高温性 High Temperature Test .......................................................................................................... 5 4.10 耐低温性 Low temperature testing ......................................................................................................... 6 4.11 温度循环 Temperature Cycling ............................................................................................................... 7 4.12 恒定湿热 Humidity heat, Constant ..........................................................................................................7 4.13 盐雾 Salt spray .................................................................................................................................... 7 4.14 随机振动 Random vibration ..............................................................................................................8 5. 包装 运输 贮存 Packaging Transportation Storage ...................................................................... 9 6、修订 Revise ....................................................................................................................................................... 9 Page 2 of 9 司 公 限 有 气 电 森 乐 朗 市 清 PRODUCT DATA SHEET(产品物性表) BASEN® T180G6 HW BK 1 Description(产品说明) DC­T100010/B Modified polybutylene terephthalate/polyethylene terephthalate,reinforced with 30% glass fiber,no flame retardant,complying with RoHS standard, for injection molding. 改性PBT/PET材料,玻纤增强30%,不阻燃,满足RoHS环保要求,注塑级产品。 Applications(主要应用) The product offers high dimentional stability, low warpage, good appearance with high gloss and excellent chemical resistance.It is mainly used in household appliances,automotiveetc.such as covers and housings etc. The product is available in nature, and in colors on request. 该产品尺寸稳定性好,低翘曲,外观良好光泽度高,耐化学性能优异。主要应用于家用 电器和汽车领域,如盖板以及壳体等,主要应用于家用电器,汽车领域。如盖板以及壳体 等。 该产品为本色材料,也可根据需求进行调色。 Test Condition Standard Unit Typical Value (典型数据) (测试条件) (引用标准) (单位) DAM(干态) 23℃ ISO 1183­1 g/cm3 1.56 23℃,泡水,24H ISO 62 % 0.1 Property (检测项目) Physical properties (物理属性) Density(密度) Water absorption(吸水质量分数) Rheological properties (流变性能) ★注:表中所提供的收缩率数值是根据国际标准收缩率片测得,我们保证数据的真实性。但不同产品模具结构差异较大,实际开模收缩率与表中提供的收缩率 数据可能存在较大的差异,如需准确的开模收缩率数据,请联系我司相关人员。 Moulding shrinkage(模塑收缩率) 60×60×2mm(料温 260℃,模温80℃) ISO 294­4 % ­ Parallel shrinkage(平行收缩率) 23℃,50%RH,24H ISO 294­4 % 0.10~0.30 Transverse shrinkage(垂直收缩率) 23℃,50%RH,24H ISO 294­4 % 0.50~0.80 Charpy unnotched impact strength(简支梁无缺口冲击强度) 23℃,4J ISO 179­1 kJ/㎡ 50 Charpy notched impact strength(简支梁缺口冲击强度) 23℃,1J ISO 179­1 kJ/㎡ 8.5 Tensile strength(拉伸强度) 2mm/min ISO 527­1 MPa 150 Tensile strain at break(拉伸断裂应变) 2mm/min ISO 527­1 % 2.5 Flexural strength(弯曲强度) 2mm/min ISO 178 MPa 200 Flexural modulus(弯曲模量) 2mm/min ISO 178 MPa 8200 1.8Mpa ISO 75­1 ℃ 195 DSC,10℃/min ISO 11357­3 ℃ 222 Flammability UL94(垂直燃烧) 2.0mm UL 94 class HB Glow­wire flammability index(灼热丝可燃性指数) 2.0mm IEC 60695­2­12 ℃ 700 3mm,Solution A IEC 60112 V 500 Dry Volume resistivity(体积电阻率) Φ100×3mm IEC 60693 Ωꞏm 1.00E+14 Dry surface resistivity(表面电阻率) Φ100×3mm IEC 60693 Ω 1.00E+15 Mechanical properties (机械性能), 23℃, 50%RH Thermal properties (热性能) Heat deflection temperature(负荷变形温度) Melting temperature(熔融峰温) Flammability (阻燃性能) Electrical properties (电性能) Comparative tracking index(相比电痕化指数) Page:1/2 Processing (推荐加工工艺) ★注:以下加工参数仅供参考,可根据不同机型、不同模具以及产品要求,对加工工艺做适当调整。 Injection(注塑) Unit(单位) Range(范围) Processing moisture content (加工水分要求) % ≤0.05 Drying temperature (干燥温度) ℃ 120~140 Drying time (干燥时间) h 4~6 Nozzle temperature (喷嘴温度) ℃ 245~265 Front Temperature of screw(螺杆前段温度) ℃ 245~265 Middle Temperature of screw(螺杆中段温度) ℃ 240~260 Rear Temperature of screw(螺杆后段温度) ℃ 240~260 Mold temperature (模具温度) ℃ 60~100 Declaration: [1] The information submitted herein is authentic. It is based on our current knowledge and experience, and on the tests and experiments carried out in our laboratories. [2] The data herein is typical and not to be construed as specifications. In view of the many factors that may affect processing and application, this information is intended to be used only as a guideline for product engineer. Observation on a “trial and error” basis may be required to achieve desired results. [3] Pigments can affect properties, so unless otherwise specified, all data listed is for natural colored materials. [4] The information will be updated along with accumulating of our knowledge and experience, please visit our wetsite or contract us timely to get the latest version. 说明: [1] 此处提供的信息是基于我们当时的知识和经验,通过在我们的试验室进行测试和试验所获得,我们可以保证信息的真实性。 [2] 此份物性表提供的数据仅代表产品的典型值,不作为材料的技术证明。由于材料加工和测试时的人、机、料、法、环等因素会影响材料 的判断和应用,因此此信息仅为工程师选材或加工时提供参考,为了达到贵公司的预期效果,需要进行试验。 [3] 颜料可能会影响产品的性能,因此,除非另有规定,物性表中的数据代表的是本色材料的性能。 [4] 随着我们知识和经验的积累,物性表中的信息将会不断更新,为了获得最新版本的物性表,请及时登录我们的网站或直接联系我们。 Page:2/2 乐清市朗森电气有限公司 0 更改记录 HISTORY RECORD 序号 No.: 版本号 Version Number 更改前描述 Description Before Modification 更改后描述 Description After Modification 1 A/0 首次发放 Original release / 批准 Approval 2 3 4 5 6 1 产品简图 Outline drawing (附页) 1.1 物料明细表 BOM 7 6 5 4 BCL50033W4291 铜针 N 高精黄铜 3 BCL50033W3421 铜针 N 高精黄铜 2 BCL50033W2551 铜针 N 高精黄铜 1 C025003300020 基座 1 本松 PBT 序号 Item 物料号 Part Number 物料名称 Product Name 数量 Quantity 备注 Mark Page 3 of 9 日期 Date 乐清市朗森电气有限公司 2 总体要求 General 2.1 功能描述 Functional description 本产品主要用于:线板端连接 2.2 安装位置 Mounting location 本产品安装在位置;电气系统 2.3 温度范围 Temperature range 工作温度Operating temperature : -40℃~+125℃ 2.4 电压范围 Voltage range 产品的标称电压rated voltage:28V DC; 3 默认测试条件 Default test conditions 在具体试验方法中如无其他规定,试验样品应先在下述条件下放置24h后,然后再进行试验,样品的预处理 条件和和默认的试验条件如下:环境温度:(18~28)℃ 空气相对湿度:45%~75% 大气压力:86kPa~106kPa In the absence of any other provision in the specific test method,the test sample shall be placed for 24h under the following conditions before being tested,Sample pretreatment conditions and the default test conditions are as follows:Ambient temperature: (18~28)℃ Relative humidity: 90%~95%Atmospheric pressure: 86kPa~106kP 4 产品性能 Performance 项目 Item 测试设备 Equipment 照相机、摄像机、放大镜等放大 设备(如需要) 4.1 外观 Appearance 4.2电压降 Voltage Drop Camera, Video Recorder, Magnification Apparatus (as required) 万用表、恒流源、欧姆表 Current-temperature tester, multimeter Ohmmeter 测试条件和方法 Condition & Method 规格要求 Requirement 目视检查 视力:1.0 以上 照明:(200~300)lx 目测距离:(0.3~0.5)m 1.塑料件表面应无明显疤痕、凹陷、开裂及 影响使用的变形。 2.标志、其它零部件外观符合相应规范。 3.金属件表面无锈蚀、氧化 、无明显的机 械损伤等缺陷。 1. Plastic part: smooth and flat surface Visual examination without discolor, broken, crack, vision: > 1.0, atnormal distortion defects is acceptable. strength of vision and color 2.The contact crimp,identification, other perception. component shall be checked against illumination:(200~300)lx the relevant specification. viewing distance:(0.3~0.5) 3.Metal part: bright and even surface m without rust, oxide, fog and obvious physical damage defects is acceptable. 对配后通过最大3A的电流 持续30分 钟 Mated connectors, measure by dry current of 2A maximum 30min. Page 4 of 9 ≤10mV/A 乐清市朗森电气有限公司 4.3接触电阻 Contact resistance 4.4 绝缘电阻 Insulation resistance 4.5耐电压 Withstand voltage 4.6 漏电流 Current leakage 4.8耐焊接热 Resistance to solder heat 4.9耐高温性 High Temperature Test 毫欧姆电阻分选仪 Ohmmeter 插配阴阳连接器后,用小功率电路进 行测试(干电路:开路电压是 20mV, 最大电流是 10 mA) Carefully mate 接触电阻≤0.02Ω the contact pair (male contact, female contact) to the appropriate Contact resistance:≤0.02Ω depth under low energy (Dry circuit: 20mV open circuit voltage and 10 mA current limit.) 绝缘电阻表或绝缘电阻测试仪 Insulation resistance tester 在连接器的相邻插针或与地线之间, 用500V DC的电压进行测试,时间:1 分钟. Apply 500V DC between the adjacent contacts and ground in the connectors for 1 Min. 线束插接器的接触件间的绝缘电阻 应至少为100MΩ insulation resistance for desiccation bound: 100MΩ; 恒压源 Constant voltage tester 用有效值1000 V 的交流电压(50 Hz)通过所有连接在一起的插接件和 装着护套的插接件保持1 min,要求 45%~75%的相对湿度。 Apply 1000V AC(RMS),50Hz for 1 minute between adjacent terminals 不能有电介质断裂或击穿现象 No dielectric crack or breakdown shall occur 恒压源,万用表 Constant voltage tester, multimeter 在连接器的相邻插针或与地线之间, 用500V (50Hz)的电压进行测试, 时间:1分钟. Apply 500V (50Hz) between the adjacent contacts and ground in the connectors for 1 Min.. 1mA Max 把试验样品需要焊接的部位浸入焊 锡炉中{锡炉温度(260±5)℃}, (10±1)s 后,在正常条件下恢复 1h。 焊槽 Solder pot Soldering Time : (10±1) s Solder Temperature: (260±5)℃ The dipped part shall be allowed to cool in air for 1h. 高温试验箱 Temperature chamber capable of maintaining the specified temperature conditions 将试样放在 125℃的高温箱内,温度 偏差为±2℃,时间为 4h,再在常温 下放置 24h 后检查。 Place the test samples in a test chamber and leave them there at the temperature 125℃±2℃ for 4 h. The sample shall be allowed to cool in air for 24 h. Page 5 of 9 应能经受焊接热试验的影响,而无 由于试验造成的损伤。 Any evidence of mechanical damage shall be considered a failure. 试验后进行检查外观无损伤,测量 接触电阻≤0.02Ω,绝缘电阻≥ 100MΩ。 The sample shall fulfill visual examination, contact resistance ≤ 0.02Ω, and insulation resistance ≥ 100MΩ after high temperature exposure. Failure of any specified measurement, or evidence of mechanical damage shall be considered a failure. 乐清市朗森电气有限公司 在可焊性试验之前应进行老化试验。 蒸汽老化试验在蒸汽中 4 小时。在每 次试验之前应首先用一块合适的材 料把熔融焊料的表面刮的清洁光亮, 试验应在刮后立即进行。在试验室温 度下,首先将被试验的引出端浸渍到 焊剂中。然后立即将引出端以纵轴线 方向浸渍到焊槽中去,焊槽中焊料的 温度为(260±5)℃。引出端的浸渍 点与槽壁之间的距离不应小于 10mm。浸渍速度为(25±2.5) mm/min。引出端在槽内保持浸渍状 态的时间应为(2.0±0.5)s。然后试 验样品以(25±2.5)mm/min 的速度 取出。 4.7可焊性 Solder ability 4.10耐低温性 Low temperature testing 焊槽 Solder pot 低温试验箱 Temperature chamber capable of maintaining the specified temperature conditions Prior to flux application and subsequent solder dip, all devices shall be subjected to aging by exposure to steam in a steam chamber for 4h. Contacts shall be immersed in flux, to the minimum depth necessary to effectively cover the surface to be tested. The dross shall be skimmed from the surface of the molten solder. The molten solder shall be maintained at a uniform temperature of (235 5) C. The surface of the molten solder shall be skimmed just prior to immersing the leads in the solder. The part shall be immersed once in the molten solder to the depth, and in the same manner. The immersion and emersion rates shall be(25±2.5) mm/min and the dwell time shall be (2.0±0.5)s. The dipped part shall be allowed to cool in air. 将试样放在-40℃的低温箱内,温度偏 差为±2℃,时间为 4h,再在常温下 放置 24h 后检查。 Place the test sample in a test chamber and leave them there at the temperature -40℃±2℃ for 4 h. The sample shall be allowed to cool in air for 24 h. Page 6 of 9 进行外观检查,借助肉眼或 4~10 倍的放大镜来检查。浸渍过的表面 必须覆盖上一层光滑明亮的焊料 层,只允许有少量分散的诸如针孔 不润湿或弱润湿区域之类的缺陷, 且这缺陷不应集中在一块。 上锡率≥90%。 The part shall be visually examined using 4X to 10X magnification. The tested areas shall be essentially bright and smooth with no imperfections. The remaining may contain scattered imperfections such as pin holes, rough spots, or dewetted areas These imperfections shall not be concentrated in one area. 90% of immersed area must show no voids, pin holes 试验后进行检查外观无损伤,测量 接触电阻≤0.02Ω,绝缘电阻≥ 100MΩ。 The sample shall fulfill visual examination, contact resistance ≤ 0.02Ω, and insulation resistance ≥ 100MΩ after high temperature exposure. Failure of any specified measurement, or evidence of mechanical damage shall be considered a failure. 乐清市朗森电气有限公司 4.11温度循环 Temperature Cycling 4.12恒定湿热 Humidity heat, Constant 高低温交变试验箱 temperature chamber capable of changing from one temperature extreme to the other within the specified transition time 把试验样品分别放入高低温交变试 验箱中,按下列步骤调试温度: a 在(-40±2)℃的恒温下放置 2h; b 在(125±2)℃的恒温下放置 2h; 温度之间的转换时间不超过 180s,a 到 b 为一个循环周期,至少进行 5 个 循环。 Procedure: a)(-40±2)℃ 2h b)(125±2)℃ 2h the time of temperature change could not more than 180 s. After finishing not less than 5 cycles, condition prior to testing 试验后进行检查外观无损伤,测量 接触电阻≤0.02Ω,绝缘电阻≥ 100MΩ。 The sample shall fulfill visual examination, contact resistance ≤ 0.02Ω, and insulation resistance ≥ 100MΩ after high temperature exposure. Failure of any specified measurement, or evidence of mechanical damage shall be considered a failure. 高低温交变湿热试验箱 TemperatureHumidity chamber capable of maintaining the specified condition on a continuous basis. 把试验样品(线束插接器不插合)放 入高低温交变湿热试验箱中,将温度 升到(30±2)℃,待平衡后保温 1h, 然后放入水汽,在 1h 内使温度达到 +2 (30±2)℃,相对湿度达到(93 -3 )%, 搁置 96h 后取出试验样品,在常温下 恢复 24h 后检查。 Place the test samples in the chamber(shall not match the contact pair).Raise the temperature to the (30 ±2)℃, During the temperature transition, the humidity need not be controlled. Then raise the humidity to +2 (93 -3 )% within 1h.Hold the test +2 samples to (30±2)℃ at (93 -3 )% RH for 96h. The sample shall be allowed to cool in air for 24 h 试验后进行检查外观无损伤,测量 接触电阻≤0.02Ω,绝缘电阻≥ 100MΩ。 The sample shall fulfill visual examination, contact resistance ≤ 0.02Ω, and insulation resistance ≥ 100MΩ after high temperature exposure. Failure of any specified measurement, or evidence of mechanical damage shall be considered a failure. Page 7 of 9 乐清市朗森电气有限公司 4.13盐雾Salt spray 项目 4.14 随机振 动 Random vibration 盐雾试验箱 Salt spray chamber 测试设备 振动试验台 Vibration tester 把试验样品从试验箱顶悬挂下来(平 板试验样品需使受试面与垂直方向 成 300 角),采用浓度为(5±0.1)%(质 量百分比)的氯化钠溶液,PH 值在 6.5~7.2 之间;温度(35±2) ℃;连 续雾化 24h,试验后用流动的蒸馏水 轻轻洗去表面沉积物。在常温常湿条 件下恢复(1~2)h 后检查试验样品。 The salt solution concentration shall be 5%.The 5% solution shall be prepared by dissolving 5 ± 1 parts by weight of salt in 95 parts by weight of distilled or other water. Apply it to mated connectors fitted with the full complement of contacts and cables connected. The duration of the test shall be 24h. The pH shall be maintained between 6.5 and 7.2. The test shall be conducted with a temperature in the exposure zone that is maintained at (35±2) ℃. Salt deposits shall be removed by a gentle wash or a dip in running water and a light brushing. The sample shall resume at room temperature for 1~2h. 测试条件和方法 对配件在三个互相垂直轴的每个轴 向施加 8 小时的振动 The mated connectors shall vibrated in each of three mutually perpendicular planes for the period of 8h in each plane 外观检查。试验后,五金件应无露 出底金属的严重锈蚀。(使用预镀 好的型材,其落料面允许有不影响 其性能的轻微腐蚀。) Visual examination The following appearance shall not be allowed: Exposure of base metals, pitting and porosity of finishes. Cracking and delaminating of components or finishes, or both. 规格要求 瞬断要求:不允许连接电阻 ≥100.0Ω, 瞬断时间≥1μs Testing: Discontinuity (when R>100ohm) 1 us max; 试验后:接触电阻≤20mΩ After test: Contact resistance: 20 mΩ max 试验后:电压降≤10mV/A After test: Voltage drop
50033-18AW-2 价格&库存
很抱歉,暂时无法提供与“50033-18AW-2”相匹配的价格&库存,您可以联系我们找货
