MECF-08-01-L-DV-WT
MECF-08-01-L-DV-WT
    SAMTEC(申泰)
    SMD,P=1.27mm
    16 位置 母头 连接器 非指定 - 双边 镀金 0.050"(1.27mm) 黑色
MECF-08-01-L-DV-WT 数据手册
MICRO EDGE CARD SYSTEMS 0.50 mm, 0.635 mm, 0.80 mm, 1.00 mm, 1.27 mm, 2.00 mm PITCH FEATURES & BENEFITS • Up to 56 Gbps PAM4 • PCI Express® 4.0 (MEC5 Series) • Solutions for .062" (1.60 mm), and .093" (2.36 mm) thick cards • Choice of pitch: 0.50 mm, 0.635 mm, 0.80 mm, 1.00 mm, 1.27 mm, 2.00 mm • Vertical, right-angle, edge mount Staggered press-fit tails (MEC8-VP) • Available in surface mount and through-hole Justification beam ensures card and body are flushed (MEC5) KEY SPECIFICATIONS SERIES PITCH TOTAL POSITIONS INSULATOR MATERIAL CONTACT MATERIAL OPERATING TEMP RANGE CURRENT RATING VOLTAGE RATING LEAD-FREE SOLDERABLE MEC5 0.50 mm 60-200 Black LCP Phosphor Bronze -55 ℃ to +125 ℃ 1.5 A (2 pins) 125 VAC Yes MEC6 0.635 mm 20-140 Black LCP Phosphor Bronze -55 ℃ to +125 ℃ 2.4 A (2 pins) 195 VAC Yes MEC8 0.80 mm 20-140 Black LCP Phosphor Bronze -55 ℃ to +125 ℃ 1.8 A (4 pins) 185 VAC Yes MEC1 1.00 mm 20-140 Black LCP Phosphor Bronze -55 ℃ to +125 ℃ 2.2 A (2 pins) 250 VAC Yes MECF 1.27 mm 10-100 Black/Natural LCP BeCu -55 ℃ to +125 ℃ 3.5 A (2 pins) 280 VAC Yes MEC2 2.00 mm 10-100 Black/Natural LCP BeCu -55 ℃ to +125 ℃ 3.5 A (2 pins) 238 VAC Yes F-221 samtec.com/EdgeCard Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. 25 G b p s (1.27 mm) .050" PITCH • MINI EDGE CARD SOCKET MECF - POSITIONS PER ROW - –05, –08, –20, –30, –40, –50 - CARD THICKNESS –01 - PLATING OPTION - DV –L = (1.60 mm) .062" thick card Leave blank for tubes = Weld Tabs (Standard on –02 card thickness, optional on –01 card thickness) = (2.36 mm) .093" thick card –TR = Tape & Reel –K –FR Polyimide film pick & place pad (–“X”R only) MECF = Full ReelTape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) A POSITIONS PER ROW Card Mates: (1.60 mm) .062" thick card (2.36 mm) .093" thick card (2.54) .100 –05 (5.60) .220 –20 –05, –08, –20, –30, –40, –50 CARD THICKNESS –01 = (1.60 mm) .062" thick card –02 - - PLATING OPTION –L =10 µ" (0.25 µm) Gold on contact, Matte Tin on tail = (2.36 mm) .093" thick card (-DV option only) Card Mates: (1.60 mm) .062" thick card (2.36 mm) .093" thick card MEC2-TH Card Mates: (1.60 mm) .062" thick card Note: Some sizes, styles and options are non-standard, non-returnable. - TAIL OPTION –05 3, 4 –20 15, 16 –40 31, 32 5, 6 21, 22 –30 41, 42 –50 - OPTION –DV Vertical Surface Mount –TH1 Leave blank for tubes –K = Tape & Reel (05 thru 30 positions only) (Not available with -TH1) Polyimide film pick & place pad (–”X”R & –DV only) A A –TR C –FR (1.60) .063 (1.60) .063 (5.60) .220 (5.60) .220 (8.78) .346 (8.50) .335 B B “X”R –WT = Weld Tabs (standard on –02 card, optional on –01 card) Through-hole MEC2-DV (67.61) 2.662 (65.79) 2.590 –08 G b p s (2.00 mm) .0787" PITCH • MINI EDGE CARD SOCKET - (8.64) .340 (12.45) .490 (6.30) .248 (29.51) 1.162 (27.69) 1.090 (54.91) 2.162 (53.09) 2.090 –40 (7.50) .295 –50 14 View complete specifications at: samtec.com?MECF-DV POSITIONS PER ROW (10.46) .412 POSITIONS POLARIZED POSITIONS D PER ROW (No Contact) B - B (42.21) 1.662 (40.39) 1.590 –30 (8.78) .346 C A (14.27) .562 –08 (8.50) .335 MEC2 “X”R –WT =10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –02 - OPTION (7.50) .295 –TH1 –DV (8.75) .344 = Full Reel Tape & Reel (must order max. quantity per (6.30) reel; contact Samtec for .248 quantity breaks) (05 thru 30 positions only) (Not available with -TH1) D POLARIZED POSITIONS POSITIONS PER ROW A B POSITIONS PER ROW –05 (13.40) .528 (11.50) .453 –05 –08 (19.40) .764 (17.50) .689 –08 5, 6 –20 (43.40) 1.709 (41.50) 1.634 –20 15, 16 (No Contact) 3, 4 –30 (63.40) 2.496 (61.50) 2.421 –30 21, 22 –40 (83.40) 3.283 (81.50) 3.209 –40 31, 32 –50 (103.40) 4.071 (101.50) 3.996 –50 41, 42 View complete specifications at: samtec.com?MEC2-DV & samtec.com?MEC2-TH samtec.com/EdgeCard Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Samtec: MECF-20-01-L-DV-WT MECF-20-01-L-DV MECF-08-01-L-DV MECF-05-01-L-DV-K-TR MECF-05-01-L-DV-WT MECF-05-02-L-DV-WT MECF-08-01-L-DV-WT MECF-05-01-L-DV MECF-05-01-L-DV-TR MECF-08-01-L-DV-K-TR MECF-05-01-L-DV-NP-K-TR MECF-40-01-L-DV-WT-K-TR MECF-40-02-L-DV-WT-TR MECF-30-01-L-DV-WT-K-TR MECF-08-01-L-DV-WT-K-TR MECF-20-02-L-DV-WT-K-TR MECF-20-01-L-DV-NP-WT MECF-20-01-L-DV-WT-TR MECF-40-02-L-DV-WT MECF-08-02-L-DV-WT-TR MECF-08-01-L-DV-NP-WT MECF-40-02-L-DV-WT-K-TR MECF08-02-L-DV-NP-K-TR MECF-20-01-L-DV-K-TR MECF-20-02-L-DV-WT-TR MECF-08-01-L-DV-NP MECF-40-01-L-DV MECF-40-01-L-DV-K-TR MECF-20-01-L-DV-NP-K-TR MECF-05-01-L-DV-WT-K-TR MECF-05-01-L-DV-WT-TR MECF-30-01-L-DV-NP MECF-30-02-L-DV-WT MECF-40-01-L-DV-WT MECF-50-01-L-DV-WT MECF-08-02-L-DV-WT MECF-30-02-L-DV-WT-K-TR MECF-40-01-L-DV-TR MECF-30-01-L-DV-K-TR MECF-30-01-L-DV-WT MECF-20-01L-DV-NP MECF-20-01-L-DV-TR MECF-50-01-L-DV MECF-50-02-L-DV-WT MECF-05-01-L-DV-NP MECF-20-02-LDV-WT MECF-20-01-L-DV-WT-K-TR MECF-30-01-L-DV MECF-20-01-L-DV-NP-TR MECF-08-02-L-DV-NP-WT-TR MECF-08-01-L-DV-NP-WT-K-TR MECF-30-01-L-DV-TR MECF-08-02-L-DV-NP-WT MECF-30-01-L-DV-WT-TR MECF-08-02-L-DV-WT-K-TR MECF-05-01-L-DV-NP-WT-K-TR MECF-50-01-L-DV-WT-K-TR MECF-08-02-L-DV-NPWT-K-TR MECF-40-01-L-DV-WT-TR MECF-50-01-L-DV-K-TR MECF-08-01-L-DV-TR MECF-08-01-L-DV-NP-K-TR MECF-08-01-L-DV-WT-TR MECF-08-01-L-DV-NP-TR MECF-05-01-L-DV-NP-WT MECF-05-02-L-DV-NP-WT-K-TR MECF-20-01-L-DV-NP-WT-K-TR MECF-05-02-L-DV-NP-WT MECF-50-02-L-DV-WT-K-TR
MECF-08-01-L-DV-WT 价格&库存
很抱歉,暂时无法提供与“MECF-08-01-L-DV-WT”相匹配的价格&库存,您可以联系我们找货
