BUK9M31-60ELX
BUK9M31-60ELX
    NEXPERIA(安世)
    SOT-1210,LFPAK33-8-5Pin
    表面贴装型 N 通道 60 V 35A(Ta) 62W(Ta) LFPAK33
BUK9M31-60ELX 数据手册
BUK9M31-60EL Single N-channel 60 V, 21 mOhm logic level MOSFET in LFPAK33 using Enhanced SOA technology 9 May 2022 Product data sheet 1. General description Single, logic level, N-channel MOSFET in LFPAK33 using Application specific (ASFET) Enhanced SOA technology. This product has been designed and qualified to AEC-Q101 for use in linear mode in airbag applications. 2. Features and benefits • • • Fully automotive qualified to AEC-Q101 at 175 °C Enhanced SOA technology for improved linear mode performance LFPAK copper clip package technology: • High robustness and current handling capability • Gull wing leads for easy AOI inspection and exceptional board level reliability 3. Applications • • 12 V automotive systems Airbag squib voltage regulator MOSFET 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - - 60 V ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 - - 35 A Ptot total power dissipation Tmb = 25 °C; Fig. 1 - - 62 W VGS = 10 V; ID = 10 A; Tj = 25 °C; Fig. 12 11.6 16.5 20.6 mΩ ID = 10 A; VDS = 48 V; VGS = 4.5 V; Tj = 25 °C; Fig. 14; Fig. 15 - 6 12 nC [1] Static characteristics RDSon drain-source on-state resistance Dynamic characteristics QGD [1] gate-drain charge 35 A continuous current has been successfully demonstrated during application tests. Practically the current will be limited by PCB, thermal design and operating temperature. BUK9M31-60EL Nexperia Single N-channel 60 V, 21 mOhm logic level MOSFET in LFPAK33 using Enhanced SOA technology 5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 S source 2 S source 3 S source 4 G gate mb D Mounting base; connected to drain Graphic symbol D G 1 2 3 mbb076 4 S LFPAK33 (SOT1210) 6. Ordering information Table 3. Ordering information Type number Package BUK9M31-60EL Name Description Version LFPAK33 Plastic, single ended surface mounted package (LFPAK33); 8 leads; 0.65 mm pitch SOT1210 7. Marking Table 4. Marking codes Type number Marking code BUK9M31-60EL 9316EL 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134).Tj = 25 °C unless otherwise stated. Symbol Parameter Conditions Min Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - 60 V VGS gate-source voltage DC; Tj ≤ 175 °C -10 10 V Ptot total power dissipation Tmb = 25 °C; Fig. 1 - 62 W ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 - 35 A VGS = 10 V; Tmb = 100 °C; Fig. 2 - 25.6 A IDM peak drain current pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3; Fig. 4 - 145 A Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C [1] Source-drain diode IS source current Tmb = 25 °C - 35 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 145 A - 40.4 mJ Avalanche ruggedness EDS(AL)S BUK9M31-60EL Product data sheet non-repetitive drainID = 27.3 A; Vsup ≤ 60 V; RGS = 50 Ω; source avalanche energy VGS = 10 V; Tj(init) = 25 °C; unclamped; tp = 36 µs; Fig. 5 All information provided in this document is subject to legal disclaimers. 9 May 2022 [2] [3] © Nexperia B.V. 2022. All rights reserved 2 / 12 BUK9M31-60EL Nexperia Single N-channel 60 V, 21 mOhm logic level MOSFET in LFPAK33 using Enhanced SOA technology Symbol Parameter IAS non-repetitive avalanche Vsup ≤ 60 V; VGS = 10 V; Tj(init) = 25 °C; current RGS = 50 Ω; Fig. 5 [1] [2] [3] [4] Conditions [2] [3] [4] Min Max Unit - 27.3 A 35 A continuous current has been successfully demonstrated during application tests. Practically the current will be limited by PCB, thermal design and operating temperature. Single-pulse avalanche rating limited by maximum junction temperature of 175 °C. Refer to application note AN10273 for further information. Protected by 100% test. 03aa16 120 ID (A) Pder (%) aaa-034755 40 (1) 30 80 20 40 10 0 Fig. 1. 0 50 100 150 Tmb (°C) 0 200 25 50 75 100 125 150 175 Tmb (°C) 200 VGS ≥ 10 V (1) 35 A continuous current has been successfully demonstrated during application tests. Practically the current will be limited by PCB, thermal design and operating temperature. Normalized total power dissipation as a function of mounting base temperature Fig. 2. ID (A) 0 Continuous drain current as a function of mounting base temperature aaa-034757 103 102 Limit RDSon = VDS / ID tp = 10 µs 100 µs 10 DC 1 ms 1 10 ms 100 ms 10-1 1 10 VDS (V) 102 Tmb = 25 °C; IDM is a single pulse Fig. 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage BUK9M31-60EL Product data sheet All information provided in this document is subject to legal disclaimers. 9 May 2022 © Nexperia B.V. 2022. All rights reserved 3 / 12 BUK9M31-60EL Nexperia Single N-channel 60 V, 21 mOhm logic level MOSFET in LFPAK33 using Enhanced SOA technology ID (A) aaa-034766 103 102 Limit RDSon = VDS / ID tp = 10 µs 10 100 µs 1 ms 1 DC 10-1 10-1 1 10 10 ms 100 ms VDS (V) 102 Tmb = 125 °C; IDM is a single pulse Fig. 4. Safe operating area; continuous and peak drain currents as a function of drain-source voltage IAL (A) aaa-034756 102 (1) 10 (2) 1 (3) 10-1 10-2 10-3 10-2 10-1 1 tAL (ms) 10 (1) Tj (init) = 25 °C; (2) Tj (init) = 150 °C; (3) Repetitive Avalanche Fig. 5. Avalanche rating; avalanche current as a function of avalanche time 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-mb) Conditions thermal resistance from Fig. 6 junction to mounting base BUK9M31-60EL Product data sheet All information provided in this document is subject to legal disclaimers. 9 May 2022 Min Typ Max Unit - 2.01 2.43 K/W © Nexperia B.V. 2022. All rights reserved 4 / 12 BUK9M31-60EL Nexperia Single N-channel 60 V, 21 mOhm logic level MOSFET in LFPAK33 using Enhanced SOA technology aaa-020686 10 Zth(j-mb) (K/W) 1 δ = 0.5 0.2 0.1 10-1 0.05 P 0.02 δ= T single shot t tp 10-2 10-6 Fig. 6. tp 10-5 10-4 10-3 10-2 T 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit ID = 250 µA; VGS = 0 V; Tj = 25 °C 60 66 - V ID = 250 µA; VGS = 0 V; Tj = -40 °C - 62 - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 54 61 - V ID = 1 mA; VDS=VGS; Tj = 25 °C; Fig. 10; Fig. 11 1.4 1.82 2.1 V ID = 1 mA; VDS=VGS; Tj = -55 °C; Fig. 11 - - 2.45 V ID = 1 mA; VDS=VGS; Tj = 175 °C; Fig. 11 0.5 - - V VDS = 60 V; VGS = 0 V; Tj = 25 °C - 0.01 1 µA VDS = 60 V; VGS = 0 V; Tj = 175 °C - 21 500 µA VGS = 10 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = -10 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 10 A; Tj = 25 °C; Fig. 12 11.6 16.5 20.6 mΩ VGS = 10 V; ID = 10 A; Tj = 105 °C; Fig. 13 17.6 26 33.5 mΩ VGS = 10 V; ID = 10 A; Tj = 125 °C; Fig. 13 19.3 28.7 37.2 mΩ VGS = 10 V; ID = 10 A; Tj = 175 °C; Fig. 13 23.8 36 47.3 mΩ VGS = 4.5 V; ID = 10 A; Tj = 25 °C; Fig. 12 17.3 24.7 33 mΩ VGS = 4.5 V; ID = 10 A; Tj = 105 °C; Fig. 13 26 38 53 mΩ VGS = 4.5 V; ID = 10 A; Tj = 125 °C; Fig. 13 28 42 58 mΩ VGS = 4.5 V; ID = 10 A; Tj = 175 °C; Fig. 13 34 52 73 mΩ Static characteristics V(BR)DSS VGS(th) drain-source breakdown voltage gate-source threshold voltage IDSS drain leakage current IGSS gate leakage current RDSon drain-source on-state resistance BUK9M31-60EL Product data sheet All information provided in this document is subject to legal disclaimers. 9 May 2022 © Nexperia B.V. 2022. All rights reserved 5 / 12 BUK9M31-60EL Nexperia Single N-channel 60 V, 21 mOhm logic level MOSFET in LFPAK33 using Enhanced SOA technology Symbol Parameter Conditions Min Typ Max Unit RG gate resistance f = 1 MHz; Tj = 25 °C - 1.85 - Ω ID = 10 A; VDS = 48 V; VGS = 4.5 V; Tj = 25 °C; Fig. 14; Fig. 15 - 13 18 nC ID = 10 A; VDS = 48 V; VGS = 10 V; Tj = 25 °C; Fig. 14; Fig. 15 - 26 37 nC ID = 10 A; VDS = 48 V; VGS = 4.5 V; Tj = 25 °C; Fig. 14; Fig. 15 - 3.7 5.5 nC - 6 12 nC VDS = 25 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; Fig. 16 - 1334 1867 pF - 135 162 pF - 79 108 pF - 8 - ns - 18 - ns Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time - 17 - ns tf fall time - 13 - ns gfs transfer conductance VDS = 8 V; ID = 10 A; Fig. 17 - 24 - S VDS = 48 V; RL = 5 Ω; VGS = 5 V; RG(ext) = 5 Ω; Tj = 25 °C Source-drain diode VSD source-drain voltage IS = 10 A; VGS = 0 V; Tj = 25 °C; Fig. 18 - 0.83 1 V trr reverse recovery time - 26 - ns Qr recovered charge IS = 10 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 30 V; Tj = 25 °C; Fig. 19 [1] - 28.5 - nC [1] includes capacitive recovery ID (A) aaa-034758 30 10 V aaa-034759 60 RDSon (mΩ) 50 4.5 V 24 3.5 V 40 18 30 12 VGS = 3 V 20 2.8 V 6 10 2.6 V 0 Fig. 7. 2.4 V 0 1 2 3 VDS (V) 0 4 0 2 4 6 8 10 12 14 VGS (V) 16 Tj = 25 °C Tj = 25 °C; ID = 10 A Output characteristics; drain current as a Fig. 8. function of drain-source voltage; typical values Drain-source on-state resistance as a function of gate-source voltage; typical values BUK9M31-60EL Product data sheet All information provided in this document is subject to legal disclaimers. 9 May 2022 © Nexperia B.V. 2022. All rights reserved 6 / 12 BUK9M31-60EL Nexperia Single N-channel 60 V, 21 mOhm logic level MOSFET in LFPAK33 using Enhanced SOA technology ID (A) aaa-034761 30 ID (A) 25°C 24 10-2 175°C 18 003aah026 10-1 min 10-3 12 10-4 6 10-5 typ max Tj = -55°C 0 0 1 2 3 4 VGS (V) 10-6 5 VDS = 8 V Fig. 9. 0 1 2 3 V GS (V) Tj = 25 °C; VDS = 5 V Transfer characteristics; drain current as a function of gate-source voltage; typical values 003aah025 3 VGS(th) (V) 2.5 Fig. 10. Sub-threshold drain current as a function of gate-source voltage aaa-034762 170 RDSon (mΩ) 3.5 V 2.6 V 2.8 V 3 V 136 max 2 102 typ 1.5 68 min 1 0 -60 0 60 120 Tj (° C) 0 180 Fig. 11. Gate-source threshold voltage as a function of junction temperature Product data sheet VGS = 10 V 0 6 12 18 24 ID (A) 30 Tj = 25 °C ID = 1 mA ; VDS = VGS BUK9M31-60EL 4.5 V 34 0.5 Fig. 12. Drain-source on-state resistance as a function of drain current; typical values All information provided in this document is subject to legal disclaimers. 9 May 2022 © Nexperia B.V. 2022. All rights reserved 7 / 12 BUK9M31-60EL Nexperia Single N-channel 60 V, 21 mOhm logic level MOSFET in LFPAK33 using Enhanced SOA technology a aaa-034850 2.4 VGS (V) 10 V aaa-034763 10 8 1.8 VGS = 4.5 V 6 1.2 48 V 4 VDS = 14 V 0.6 0 -60 2 -30 0 30 60 90 120 150 Tj (°C) 0 180 0 7 13 20 27 33 QG (nC) 40 Tj = 25 °C; ID = 10 A Fig. 13. Normalized drain-source on-state resistance factor as a function of junction temperature Fig. 14. Gate-source voltage as a function of gate charge; typical values aaa-034764 104 C (pF) VDS ID 103 Ciss VGS(pl) 102 VGS(th) Coss Crss VGS QGS2 QGS1 QGS 10 10-1 QGD QG(tot) BUK9M31-60EL Product data sheet 10 VDS (V) 102 VGS = 0 V; f = 1 MHz 003aaa508 Fig. 15. Gate charge waveform definitions 1 Fig. 16. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. 9 May 2022 © Nexperia B.V. 2022. All rights reserved 8 / 12 BUK9M31-60EL Nexperia Single N-channel 60 V, 21 mOhm logic level MOSFET in LFPAK33 using Enhanced SOA technology gfs (S) aaa-034760 40 IS (A) aaa-034765 80 30 60 20 40 Tj = 25°C 10 -55°C 20 175°C 0 0 5 10 15 20 25 ID (A) 0 30 Tj = 25 °C; VDS = 8 V 0 0.2 0.4 0.6 0.8 1 VSD (V) 1.2 VGS = 0 V Fig. 17. Forward transconductance as a function of drain current; typical values Fig. 18. Source-drain (diode forward) current as a function of source-drain (diode forward) voltage; typical values 003aal160 ID (A) trr ta tb 0 0.25 IRM IRM t (s) Fig. 19. Reverse recovery timing definition BUK9M31-60EL Product data sheet All information provided in this document is subject to legal disclaimers. 9 May 2022 © Nexperia B.V. 2022. All rights reserved 9 / 12 BUK9M31-60EL Nexperia Single N-channel 60 V, 21 mOhm logic level MOSFET in LFPAK33 using Enhanced SOA technology 11. Package outline Plastic single ended surface mounted package (LFPAK33); 8 leads E A e1 A c1 b1 L1 SOT1210 D2 mounting base D1 (D) H E1 L 1 4 b e w A A1 C X c Lp y C detail X 0 2.5 5 mm scale Dimensions Unit(1) A A1 b(1) max 0.90 0.10 0.35 nom min 0.80 0.00 0.25 mm b1(1) c c1 2.4 0.20 0.30 2.2 0.10 0.20 D ref 2.60 D1 2.35 1.90 D2 0.50 E(1) E1 3.40 2.45 3.20 2.00 e e1 0.65 0.65 H L L1 Lp 3.40 0.65 0.25 0.50 3.20 0.45 0.13 0.30 w 0.20 0.10 Note 1. Plastic or metal protrusions of 0.15 mm per side are not included. Outline version sot1210_po References IEC JEDEC y JEITA European projection Issue date 14-04-25 16-08-09 SOT1210 Fig. 20. Package outline LFPAK33 (SOT1210) BUK9M31-60EL Product data sheet All information provided in this document is subject to legal disclaimers. 9 May 2022 © Nexperia B.V. 2022. All rights reserved 10 / 12 BUK9M31-60EL Nexperia Single N-channel 60 V, 21 mOhm logic level MOSFET in LFPAK33 using Enhanced SOA technology equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 12. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or BUK9M31-60EL Product data sheet All information provided in this document is subject to legal disclaimers. 9 May 2022 © Nexperia B.V. 2022. All rights reserved 11 / 12 BUK9M31-60EL Nexperia Single N-channel 60 V, 21 mOhm logic level MOSFET in LFPAK33 using Enhanced SOA technology Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 2 9. Thermal characteristics............................................... 4 10. Characteristics............................................................ 5 11. Package outline........................................................ 10 12. Legal information......................................................11 © Nexperia B.V. 2022. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 9 May 2022 BUK9M31-60EL Product data sheet All information provided in this document is subject to legal disclaimers. 9 May 2022 © Nexperia B.V. 2022. All rights reserved 12 / 12
BUK9M31-60ELX 价格&库存
很抱歉,暂时无法提供与“BUK9M31-60ELX”相匹配的价格&库存,您可以联系我们找货
BUK9M31-60ELX
  • 1+10.764061+1.39901
BUK9M31-60ELX
  • 50+8.48520
  • 100+8.31441
库存:1485
BUK9M31-60ELX
  • 5+8.74763
  • 50+8.48520
  • 100+8.31441
库存:1485
