PTVSUC3D3V3B
1-Line Low Capacitance Bi-directional TVS Diode
Features
400W peak pulse power (8/20µs)
Ultra low capacitance: 0.6pF typical
Ultra low leakage: nA leel
Low operating voltage: 3.3V
Low clamping voltage
Protects one power line or data line
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 80A (5/50ns)
– IEC61000-4-5 (Lightning) 20A (8/20)
RoHS Compliant
Dimensions SOD-323
Pin Configuration
Applications
USB Ports
Smart Phones
Wireless Systems
Ethernet 10/100/1000 Base T
Mechanical Characteristics
Package: SOD-323
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Device Marking: CC
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Ppp
VESD
Value
Unit
400
W
± 30
Kv
± 30
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev 2.0 : 01.06.2021
1/4
www.leiditech.com
PTVSUC3D3V3B
Electrical Characteristics(TA=25°C unless otherwise specified)
Symbol
Parameter
VRWM
Reverse Working Peak Voltage
VBR
Reverse Breakdown Voltage
Conditions
IT = 1mA
Min
Typ
Max
Unit
3.3
V
V
4
VRWM = 3.3V
0.2
µA
Clamping Voltage
IPP = 1 A (8/20µs)
7
V
VC
Clamping Voltage
IPP = 20 A (8/20µs)
V
CJ
Capacitance
VR = 0V, f = 1MHz
IR
Reverse Leakage Current
VC
2/4
0.6
pF
www.leiditech.com
PTVSUC3D3V3B
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
30
Vc-Clamping Voltage(V)
CJ-Junction Capacitance (pF)
2
1.8
1.6
1.4
1.2
1
0.8
0.6
0.4
25
10
5
0.2
1
1.5
2
2.5
3
VR—Reverse Voltage(V)
2
4
6
8
10 12 14 16 18 20 22
Ipp-Peak Pulse Current(A)
Clamping Voltage vs. Peak Pulse Current
Junction Capacitance vs. Reverse Voltage
Voltage (V)
Peak Power_Ppp(kW)
10
1
0.1
-20
0.1
1.0
10.0
Pulse Duration_tp(uS)
100
100
Ipp-Peak Pulse Current-%of Ipp
% of Rated Power
120
80
60
40
75
100
125
150
60
80
100
80
60
40
-20
Ambient Temperature_Ta(℃)
60
T-Time(us)
8 X 20us Pulse Waveform
Power Derating Curve
40
IEC61000−4−2 Pulse Waveform
120
25
Time (nS)
Peak Pulse Power vs. Pulse Time
3/4
www.leiditech.com
PTVSUC3D3V3B
SOD-323 Package Outline & Dimensions
DIMENSIONS
SYM
MILLIMETERS
INCHES
MIN
MAX
MIN
MAX
A
1.50
1.80
0.060
0.071
B
1.20
1.40
0.045
0.054
C
2.30
2.70
0.090
0.107
D
1.10
0.043
E
0.30
0.40
0.012
0.016
F
0.10
0.25
0.004
0.010
H
0.10
0.004
Suggested Land Pattern
SYM
DIMENSIONS
MILLIMETERS
INCHES
A
3.15
0.120
B
0.80
0.031
C
0.80
0.031
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
4/4
www.leiditech.com
很抱歉,暂时无法提供与“PTVSUC3D3V3B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.44950
- 200+0.42050
- 500+0.39150
- 1000+0.36250
- 3000+0.34800
- 6000+0.32770
