S-19720A00A-M5T1U7
S-19720A00A-M5T1U7
    ABLIC(艾普凌科)
    SOT23-5
    汽车,电源 PMIC SOT-23-5
S-19720A00A-M5T1U7 数据手册
S-19720 Series www.ablic.com AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION Rev.1.3_00 © ABLIC Inc., 2021-2022 This IC, developed by using high-withstand voltage CMOS process technology, is a voltage tracker with a reverse current protection function, which has high-withstand voltage and low current consumption. Since the maximum operating voltage is as high as 36 V and the current consumption is as low as 30 μA typ., it contributes to the reduction of standby current. This IC operates stably due to the internal phase compensation circuit so that users are able to use low ESR ceramic capacitor as the output capacitor. This IC includes an overcurrent protection circuit that prevents the load current from exceeding the current capacity of the output transistor and a thermal shutdown circuit that prevents damage because of overheating. Due to the built-in reverse current protection function, the reverse current flowing from the VOUT pin to the VIN pin can be controlled as the small value −5 μA min. Therefore, IC protection diode is not needed. ABLIC Inc. offers a "thermal simulation service" which supports the thermal design in conditions when our power management ICs are in use by customers. Our thermal simulation service will contribute to reducing the risk in the thermal design at customers' development stage. ABLIC Inc. also offers FIT rate calculated based on actual customer usage conditions in order to support customer functional safety design. Contact our sales representatives for details. Caution This product can be used in vehicle equipment and in-vehicle equipment. Before using the product for these purposes, it is imperative to contact our sales representatives.  Features • Input voltage: • Offset voltage: • Dropout voltage: • Current consumption: • Output current: • Input capacitor: • Output capacitor: • Built-in overcurrent protection circuit: • Built-in thermal shutdown circuit: • Reverse current protection function: • Operation temperature range: • Lead-free (Sn 100%), halogen-free • Withstand 45 V load dump • AEC-Q100 qualified*2 4.0 V to 36.0 V ±5 mV (0.1 mA ≤ IOUT ≤ 50 mA) 160 mV typ. (VADJ / EN = 4.0 V, IOUT = 10 mA) During operation: 30 μA typ. During power-off: 4.0 μA typ. Possible to output 50 mA (VIN = VADJ / EN + 2.0 V)*1 A ceramic capacitor can be used. (1.0 μF or more) A ceramic capacitor can be used. (1.0 μF to 1000 μF) Limits overcurrent of output transistor. Detection temperature 175°C typ. IREV = −5 μA min. (VIN = 0 V, VADJ / EN = 5.0 V, VOUT = 16.0 V) Ta = −40°C to +125°C *1. Please make sure that the loss of the IC will not exceed the power dissipation when the output current is large. *2. Contact our sales representatives for details.  Applications • Power supply for automotive off-board sensors • For automotive use (engine, transmission, suspension, ABS, related-devices for EV / HEV / PHEV, etc.)  Packages • SOT-23-5 • HSNT-6(2025) 1 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION S-19720 Series Rev.1.3_00  Block Diagram Reverse current detection circuit *1 *1 VIN VOUT Overcurrent protection circuit Thermal shutdown circuit ADJ / EN − ON / OFF circuit + VSS *1. Parasitic diode Figure 1 2 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-19720 Series  AEC-Q100 Qualified This IC supports AEC-Q100 for operation temperature grade 1. Contact our sales representatives for details of AEC-Q100 reliability specification.  Product Name Structure 1. Product name S-19720 A00 A - xxxx U 7 Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 M5T1: SOT-23-5, Tape A6T8: HSNT-6(2025), Tape Operation temperature A: Ta = −40°C to +125°C *1. 2. Refer to the tape drawing. Packages Table 1 Package Name SOT-23-5 HSNT-6(2025) 3. Dimension MP005-A-P-SD PJ006-B-P-SD Package Drawing Codes Tape MP005-A-C-SD PJ006-B-C-SD Reel MP005-A-R-SD PJ006-B-R-SD Land − PJ006-B-LM-SD Product name list Table 2 Product Name S-19720A00A-M5T1U7 S-19720A00A-A6T8U7 Package SOT-23-5 HSNT-6(2025) 3 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION S-19720 Series Rev.1.3_00  Pin Configurations 1. SOT-23-5 Top view 1 ADJ / EN 1 2 3 2 3 4 VSS*1 VIN VOUT Description ADJ Output voltage adjustment pin EN Enable pin GND pin Input voltage pin Output voltage pin Figure 2 5 VSS*1 GND pin 5 *1. 2. Table 3 Pin No. 4 Symbol Be sure to short the VSS pins. HSNT-6(2025) Top view 1 2 3 Table 4 6 5 4 Bottom view 6 5 4 1 2 3 Pin No. Symbol 1 2 VIN NC*2 3 ADJ / EN 4 5 6 VSS NC*2 VOUT Description Input voltage pin No connection ADJ Output voltage adjustment pin EN Enable pin GND pin No connection Output voltage pin *1 Figure 3 *1. *2. 4 Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-19720 Series  Absolute Maximum Ratings Table 5 (Ta = +25°C unless otherwise specified) Item Symbol Absolute Maximum Rating VSS − 0.3 to VSS + 45.0 VSS − 0.3 to VSS + 45.0 VSS − 0.3 to VSS + 45.0 65 −40 to +150 −40 to +125 −40 to +150 Unit VIN VADJ / EN Output voltage VOUT Output current IOUT Junction temperature Tj Operation ambient temperature Topr Storage temperature Tstg Caution The absolute maximum ratings are rated values exceeding which the product could suffer damage. These values must therefore not be exceeded under any conditions. Input voltage V V V mA °C °C °C physical  Recommended Operation Conditions Table 6 Condition − − − − − − Item Symbol Min. Typ. Max. Unit − VIN 4.0 36 V − VADJ / EN 2.0 18 V − IOUT 0.1 50 mA − − μF CIN 1.0 − μF CL 1.0 1000 Output capacitor − − Ω ESR 3 *1. Due to limitation of the power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation when the output current is large. VIN pin voltage ADJ / EN pin voltage Output current*1 Input capacitor  Thermal Resistance Value Table 7 Item Symbol Condition Board A Board B Board C SOT-23-5 Board D Board E Junction-to-ambient thermal resistance*1 θJA Board A Board B HSNT-6(2025) Board C Board D Board E *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Remark Min. − − − − − − − − − − Typ. 192 160 − − − 180 128 43 44 36 Max. − − − − − − − − − − Unit °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W Refer to " Power Dissipation" and "Test Board" for details. 5 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION S-19720 Series Rev.1.3_00  Electrical Characteristics Table 8 (VIN = 13.5 V, Tj = −40°C to +150°C unless otherwise specified) Item Offset voltage*1 voltage*2 Dropout Line regulation*3 Load regulation*4 Input voltage Current consumption during operation Reverse current Current consumption during power-off ADJ / EN pin input voltage "H" ADJ / EN pin input voltage "L" ADJ / EN pin input current "H" ADJ / EN pin input current "L" Ripple rejection Limit current Short-circuit current Thermal shutdown detection temperature Thermal shutdown release temperature *1. *2. *3. *4. 6 Symbol Condition Min. Typ. Max. Unit Test Circuit Vdrop ΔVOUT1 ΔVOUT2 VIN 4.0 V ≤ VIN ≤ 24.0 V, 2.0 V ≤ VADJ / EN ≤ VIN − 2.0 V, 0.1 mA ≤ IOUT ≤ 50 mA VADJ / EN ≤ 18.0 V 4.0 V ≤ VIN ≤ 36.0 V, 0.1 mA ≤ IOUT ≤ 25 mA VADJ / EN ≥ 4.0 V, IOUT = 10 mA 6.0 V ≤ VIN ≤ 36.0 V, IOUT = 10 mA, VADJ / EN = 5.0 V 0.1 mA ≤ IOUT ≤ 50 mA, VADJ / EN = 5.0 V − ISS1 VADJ / EN = 5.0 V, IOUT = 0.01 mA − 30 50 μA 3 IREV VIN = 0 V, VADJ / EN = 5.0 V, VOUT = 16.0 V −5 0 − μA 4 ISS2 VADJ / EN = 0 V − 4.0 15.0 μA 5 VADJH Determined by VOUT output level 2.0 − − V 6 VADJL Determined by VOUT output level − − 0.5 V 6 IADJH VADJ / EN = 5.0 V −0.1 − 2 μA 6 IADJL VADJ / EN = 0 V −0.1 − 0.1 μA 6 |RR| ILIM Ishort f = 100 Hz, ΔVrip = 0.5 Vpp, IOUT = 5 mA VIN = 7.0 V, VADJ / EN = 5.0 V, VOUT = VADJ / EN × 0.85 VIN = 7.0 V, VADJ / EN = 5.0 V, VOUT = 0 V − 80 80 80 180 180 − 330 330 dB mA mA 7 8 8 TSD Junction temperature − 175 − °C − TSR Junction temperature − 165 − °C − ΔVOUT −5 − +5 mV 1 −5 − +5 mV 1 − − − 4.0 160 − − − 300 5 5 36.0 mV mV mV V 2 2 2 − Indicates the difference between output voltage (VOUT) and ADJ / EN pin voltage (VADJ / EN). The accuracy is guaranteed when the input voltage, output current, and temperature satisfy the conditions listed above. ΔVOUT = VOUT − VADJ / EN Indicates the difference between input voltage (VIN1) and the output voltage when the output voltage becomes 98% of the output voltage value (VOUT3) after the input voltage (VIN) is decreased gradually. Vdrop = VIN1 − (VOUT3 × 0.98) VOUT3: Output voltage value at VIN = VADJ / EN + 2.0 V, and IOUT = 10 mA Indicates the dependency of the output voltage against the input voltage. The value shows how much the output voltage changes due to a change in the input voltage after fixing output current constant. Indicates the dependency of the output voltage against the output current. The value shows how much the output voltage changes due to a change in the output current after fixing input voltage constant. AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-19720 Series  Test Circuits VIN + VOUT ADJ / EN V VIN A + ADJ / EN VSS Figure 4 Figure 5 + VOUT A VSS Test Circuit 3 VIN Figure 7 VOUT + A V + VSS Test Circuit 5 Figure 9 V + RL VOUT ADJ / EN VSS Test Circuit 7 Test Circuit 6 VIN VOUT ADJ / EN Figure 10 VOUT ADJ / EN VSS VIN Test Circuit 4 VIN ADJ / EN Figure 8 VOUT ADJ / EN VSS + A + + Test Circuit 2 VIN A ADJ / EN Figure 6 V A VSS Test Circuit 1 VIN + VOUT + A V + VSS Figure 11 Test Circuit 8 7 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION S-19720 Series Rev.1.3_00  Standard Circuit Input Output VIN ADJ / EN CIN VSS CL Single GND *1. *2. CIN is a capacitor for stabilizing the input. CL is a capacitor for stabilizing the output. Figure 12 Caution The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation using an actual application to set the constants.  Condition of Application Input capacitor (CIN): Output capacitor (CL): A ceramic capacitor with capacitance of 1.0 μF or more is recommended. A ceramic capacitor with capacitance of 1.0 μF to 1000 μF is recommended. Caution Generally, in a voltage tracker, an oscillation may occur depending on the selection of the external parts. Perform thorough evaluation including the temperature characteristics with an actual application using the above capacitors to confirm no oscillation occurs.  Selection of Input Capacitor (CIN) and Output Capacitor (CL) This IC requires CL between the VOUT pin and the VSS pin for phase compensation. The operation is stabilized by a ceramic capacitor with capacitance of 1.0 μF to 1000 μF over the entire temperature range. When using an OS capacitor, a tantalum capacitor or an aluminum electrolytic capacitor, the capacitance also must be 1.0 μF to 1000 μF. However, an oscillation may occur depending on the equivalent series resistance (ESR). Moreover, this IC requires CIN between the VIN pin and the VSS pin for a stable operation. Generally, an oscillation may occur when a voltage tracker is used under the condition that the impedance of the power supply is high. Note that the output voltage transient characteristics varies depending on the capacitance of CIN and CL and the value of ESR. Caution Perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. 8 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-19720 Series  Operation 1. Basic operation Figure 13 shows the block diagram of this IC to describe the basic operation. The error amplifier compares the output voltage (VOUT) with the ADJ / EN pin voltage (VADJ / EN). The error amplifier controls the output transistor to keep VOUT equal to VADJ / EN without being affected by the input voltage (VIN), that is, the tracking operation is performed. VIN VOUT ADJ / EN − + Error amplifier VSS Figure 13 2. Output transistor In this IC, a low on-resistance P-channel MOS FET is used between the VIN pin and the VOUT pin as the output transistor. In order to maintain the tracking operation of VADJ / EN and VOUT, the on-resistance of the output transistor varies appropriately according to the output current (IOUT). Also, the reverse current prevention transistor is connected in series with the output transistor. 3. ADJ / EN pin The ADJ / EN pin controls the internal circuit and the output transistor in order to start and stop the tracker. When the ADJ / EN pin is set to ON (VADJ / EN ≥ VADJH), the tracking operation starts and VOUT is adjusted so that it becomes equal to VADJ / EN. When the ADJ / EN pin is set to OFF, the internal circuit stops operating and the output transistor between the VIN pin and the VOUT pin is turned off, reducing current consumption significantly. The ADJ / EN pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. Table 9 ADJ / EN Pin *1. Internal Circuit VOUT Current Consumption ≅ VADJ / EN "H": ON Operate ISS1 "L": OFF Stop VSS*1 ISS2 The VOUT pin is not pulled down internally. The VOUT pin voltage changes to VSS level by the load connected to the VOUT pin. 9 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION S-19720 Series Rev.1.3_00 4. Overcurrent protection circuit This IC includes an overcurrent protection circuit which having the characteristics shown in "1. Output voltage vs. Output current (When load current increases) (Ta = +25°C)" in " Characteristics (Typical Data)", in order to limit an excessive output current and overcurrent of the output transistor due to short-circuiting between the VOUT pin and the VSS pin. When the load current increases and reaches the limit current (ILIM), the overcurrent protection circuit operates, and the output current is limited based on ILIM. When the output is short-circuited (the VOUT pin is shorted to the VSS pin), the output current is limited to short-circuit current (Ishort). ILIM and Ishort are internally set at 180 mA typ. This IC restarts the tracking operation over VOUT and VADJ / EN when the output transistor is released from the overcurrent status. Caution 5. This overcurrent protection circuit does not work as for thermal protection. If this IC long keeps short circuiting inside, pay attention to the conditions of input voltage and load current so that, under the usage conditions including short circuit, the loss of the IC will not exceed power dissipation of the package. Thermal shutdown circuit This IC has a built-in thermal shutdown circuit to limit overheating. When the junction temperature increases to 175°C typ., the thermal shutdown circuit becomes the detection status, and the tracking operation is stopped. When the junction temperature decreases to 165°C typ., the thermal shutdown circuit becomes the release status, and the tracking operation is restarted. If the thermal shutdown circuit becomes the detection status due to self-heating, the tracking operation is stopped and VOUT decreases. For this reason, the self-heating is limited and the temperature of the IC decreases. The thermal shutdown circuit becomes release status when the temperature of the IC decreases, and the tracking operation is restarted, thus the self-heating is generated again. Repeating this procedure makes the waveform of VOUT into a pulse-like form. This phenomenon continues unless decreasing either or both of VIN and IOUT in order to reduce the internal power consumption, or decreasing the ambient temperature. Note that the product may suffer physical damage such as deterioration if the above phenomenon occurs continuously. Caution If a large load current flows during the restart process of the tracking operation after the thermal shutdown circuit changes to the release status from the detection status, the thermal shutdown circuit becomes the detection status again due to self-heating, and a problem may happen in the restart of the tracking operation. A large load current, for example, occurs when charging to the CL whose capacitance is large. Perform thorough evaluation including the temperature characteristics with an actual application to select CL. Table 10 Thermal Shutdown Circuit Release: 165°C typ.*1 Detection: 175°C typ.*1 *1. *2. 10 VOUT ≅ VADJ / EN VSS*2 Junction temperature The VOUT pin is not pulled down internally. The VOUT pin voltage changes to VSS level by the load connected to the VOUT pin. AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-19720 Series 6. Reverse current protection function The reverse current protection function compares values of VIN and VOUT, and prevents the current from flowing to the VIN pin from the VOUT pin. During the reverse current protection mode, the reverse current detection circuit turns off the reverse current protection transistor between the VIN pin and the output transistor and blocks the reverse current from the VOUT pin. In the case of VOUT − VIN < VREVD, this IC is in normal operation mode (refer to Figure 14). The reverse current protection mode is detected when VOUT − VIN ≥ VREVD (refer to Figure 15). In order to insure the stable operation, there is also a hysteresis for detection and release of the reverse current protection mode. Therefore, the reverse current protection mode is released when VOUT − VIN ≤ VREVR. The reverse current protection function also operates when the ADJ / EN pin is set to OFF level. Current flow Reverse current detection circuit VIN Reverse current (IREV) VOUT ADJ / EN Current flow VIN ADJ / EN − Reverse current detection circuit + VOUT − + VSS VSS Figure 14 Normal Operation Mode Figure 15 Reverse Current Protection Mode Figure 16 Table 11 Reverse current protection mode detection voltage (VREVD) Reverse current protection mode release voltage (VREVR) 0.50 V typ. 0.33 V typ. 11 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION S-19720 Series Rev.1.3_00  Precautions • Generally, when a voltage tracker is used under the condition that the load current value is small (0.1 mA or less), the output voltage may increase due to the leakage current of an output transistor. • Generally, when a voltage tracker is used under the condition that the temperature is high, the output voltage may increase due to the leakage current of an output transistor. • Generally, when the ADJ / EN pin of a voltage tracker is used under the condition of OFF, the output voltage may increase due to the leakage current of an output transistor. • Generally, when a voltage tracker is used under the condition that the impedance of the power supply is high, an oscillation may occur. Perform thorough evaluation including the temperature characteristics with an actual application to select CIN. • Generally, in a voltage tracker, an oscillation may occur depending on the selection of the external parts. The following use conditions are recommended in this IC, however, perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. Input capacitor (CIN): A ceramic capacitor with capacitance of 1.0 μF or more is recommended. Output capacitor (CL): A ceramic capacitor with capacitance of 1.0 μF to 1000 μF is recommended. • Generally, in a voltage tracker, the values of an overshoot and an undershoot in the output voltage vary depending on the variation factors of input voltage start-up, input voltage fluctuation and load fluctuation etc., or the capacitance of CIN or CL and the value of the equivalent series resistance (ESR), which may cause a problem to the stable operation. Perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. • Generally, in a voltage tracker, an overshoot may occur in the output voltage momentarily if the input voltage steeply changes when the input voltage is started up or the input voltage fluctuates etc. Perform thorough evaluation including the temperature characteristics with an actual application to confirm no problems happen. • Generally, in a voltage tracker, if the VOUT pin is steeply shorted with GND, a negative voltage exceeding the absolute maximum ratings may occur in the VOUT pin due to resonance phenomenon of the inductance and the capacitance including CL on the application. The resonance phenomenon is expected to be weakened by inserting a series resistor into the resonance path, and the negative voltage is expected to be limited by inserting a protection diode between the VOUT pin and the VSS pin. • If the input voltage is started up steeply under the condition that the capacitance of CL is large, the thermal shutdown circuit may be in the detection status by self-heating due to the charge current to CL. • Make sure of the conditions for the input voltage, output voltage and the load current so that the internal loss does not exceed the power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • When considering the output current value that this IC is able to output, make sure of the output current value specified in Table 6 in " Recommended Operation Conditions" and footnote *1 of the table. • Wiring patterns on the application related to the VIN pin, the VOUT pin and the VSS pin should be designed so that the impedance is low. When mounting CIN between the VIN pin and the VSS pin and CL between the VOUT pin and the VSS pin, connect the capacitors as close as possible to the respective destination pins of this IC. • In the package equipped with heat sink of backside, mount the heat sink firmly. Since the heat radiation differs according to the condition of the application, perform thorough evaluation with an actual application to confirm no problems happen. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 12 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-19720 Series  Characteristics (Typical Data) 1. Output voltage vs. Output current (When load current increases) (Ta = +25°C) 1. 1 VADJ / EN = 5.0 V 6.0 VOUT [V] 5.0 VIN = 13.5 V 4.0 3.0 2.0 VIN = 7.0 V 1.0 0.0 Remark 0 50 150 200 IOUT [mA] 250 300 In determining the output current, attention should be paid to the following. 1. 2. 2. 100 The output current value and footnote *1 of Table 6 in " Recommended Operation Conditions" Power dissipation Output voltage vs. Input voltage (Ta = +25°C) 2. 1 VADJ / EN = 5.0 V 6.0 VOUT [V] 5.6 5.2 4.8 IOUT = 0.1 mA IOUT = 10 mA IOUT = 50 mA 4.4 4.0 6 12 18 24 VIN [V] 30 36 Output voltage vs. ADJ / EN pin input voltage (Ta = +25°C) VIN = 13.5 V, IOUT = 1 mA 5 4 VOUT [V] 3. 0 3 2 1 0 0 1 2 3 VADJ / EN [V] 4 5 13 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION S-19720 Series Rev.1.3_00 Dropout voltage vs. Output current 4. 1 VADJ / EN = 5.0 V 1.0 Dropout voltage vs. Junction temperature 5. 1 0.6 0.8 Ta = +25°C Ta = -40°C 0.4 6. IOUT = 50 mA 0.6 0.4 IOUT = 10 mA 0.2 0.2 0.0 VADJ / EN = 5.0 V 1.0 Ta = +150°C Ta = +125°C 0.8 Vdrop [V] 5. Vdrop [V] 4. 0 10 20 30 IOUT [mA] 40 0.0 -40 -25 50 0 25 50 75 100 125 150 Tj [°C] Dropout voltage vs. Set output voltage (Ta = +25°C) 1.0 Vdrop [V] 0.8 IOUT = 50 mA 0.6 0.4 IOUT = 10 mA 0.2 0.0 7. 4 6 8 10 12 14 VADJ / EN [V] 16 18 Offset voltage vs. Junction temperature 7. 1 8. VADJ / EN = 5.0 V Offset voltage vs. Input voltage (Ta = +25°C) 8. 1 9. 0 25 50 75 100 125 150 Tj [°C] Offset voltage vs. Output current (Ta = +25°C) ΔVOUT [mV] 9. 1 VADJ / EN = 5.0 V VIN = 13.5 V 5 4 3 2 1 0 -1 -2 -3 -4 -5 0 14 ΔVOUT [mV] ΔV OUT [mV] VIN = 13.5 V, IOUT = 10 mA 5 4 3 2 1 0 -1 -2 -3 -4 -5 -40 -25 10 20 30 IOUT [mA] 40 50 VADJ / EN = 5.0 V 5 4 3 2 1 0 -1 -2 -3 -4 -5 IOUT = 0.1 mA IOUT = 10 mA IOUT = 50 mA 0 6 12 18 24 VIN [V] 30 36 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-19720 Series 10. Current consumption vs. Input voltage 10. 1 VADJ / EN = 5.0 V (during operation) IOUT = 0.01 mA 1000 Ta = -40°C 80 Ta = +25°C 600 ISS1 [µA] ISS1 [µA] 800 Ta = +125°C 400 Ta = +150°C 200 0 IOUT = 0.01 mA 100 0 6 12 18 VIN [V] Ta = +150°C Ta = +125°C Ta = +25°C Ta = -40°C 60 40 20 24 30 0 36 0 6 12 18 24 VIN [V] 30 36 10. 2 VADJ / EN = 0.0 V (Power-off) IOUT = 0 mA 20 Ta = +150°C Ta = +125°C Ta = +25°C Ta = -40°C ISS2 [µA] 15 10 5 0 0 6 12 18 VIN [V] 24 30 36 11. Current consumption vs. Junction temperature 11. 1 VADJ / EN = 5.0 V (during operation) 11. 2 VADJ / EN = 0.0 V (Power-off) VIN = 13.5 V, IOUT = 0.01 mA VIN = 13.5 V, IOUT = 0 mA 50 20 15 ISS2 [µA] ISS1 [µA] 40 30 20 10 5 10 0 -40 -25 0 25 50 75 100 125 150 Tj [°C] 0 -40 -25 0 25 50 75 100 125 150 Tj [°C] 12. Current consumption during operation vs. Output current (Ta = +25°C) 12. 1 VADJ / EN = 5.0 V VIN = 13.5 V 300 ISS1 [µA] 250 200 150 100 50 0 0 10 20 30 IOUT [mA] 40 50 15 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION S-19720 Series Rev.1.3_00 13. Reverse current vs. VOUT pin voltage 13. 1 VADJ / EN = 5.0 V VIN = 0.0 V 0 -1 Ta = -40°C Ta = +25°C Ta = +125°C Ta = +150°C -10 IREV [µA] IREV [µA] -5 -15 -20 0 4 8 12 16 20 24 28 32 36 VOUT [V] VIN = 13.5 V IADJ / EN [µA] 4 3 Ta = +150°C Ta = +125°C Ta = +25°C Ta = -40°C 2 1 0 1 2 3 VADJ / EN [V] 4 5 15. Ripple rejection (Ta = +25°C) Ripple Rejection [dB] 15. 1 VADJ / EN = 5.0 V 16 140 120 100 80 60 40 20 0 -2 Ta = -40°C Ta = +25°C Ta = +125°C Ta = +150°C -3 -4 14. ADJ / EN pin current vs. ADJ / EN pin voltage 0 VIN = 0.0 V 0 VIN = 13.5 V, CL = 1.0 μF IOUT = 0.1 mA IOUT = 10 mA IOUT = 50 mA 10 100 1k 10k Frequency [Hz] 100k 1M -5 0 4 8 12 16 20 24 28 32 36 VOUT [V] AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION Rev.1.3_00 S-19720 Series  Reference Data 2. 1 IOUT = 10 mA, CL = 1.0 μF, VIN = 11.5 V ↔ 13.5 V, tr = tf = 2.0 μs 5.6 5.2 4.6 3. -0.2 0.0 0.4 0.6 t [ms] 0.8 1.0 4.8 5 4.6 4. VADJ / EN = 5.0 V VIN = 13.5 V, CIN = CL = 1.0 μF, IOUT = 5 mA ↔ 30 mA 80 40 0 IOUT 5.0 1.2 -40 VOUT -80 -120 -0.2 0.0 0.2 0.4 0.6 t [ms] 0.8 1.0 1.2 Load dump characteristics (Ta = +25°C) 4. 1 VIN = 13.5 V, CIN = CL = 1.0 μF, IOUT = 10 mA, VADJ / EN = 0 V → 5.0 V VADJ / EN = 5.0 V IOUT = 0.1 mA, VIN = 14.0 V ↔ 45.0 V, CIN = CL = 1.0 μF 50 6 6.0 8 3 5.8 40 6 0 5.6 30 VADJ / EN 4 2 -6 VOUT 0 -2 -3 -0.2 0.0 0.2 0.4 0.6 t [ms] 0.8 1.0 VOUT [V] 10 VOUT [V] 0.2 5.2 7 Transient response characteristics of ADJ / EN pin (Ta = +25°C) 3. 1 5.4 5.2 10 VOUT -9 5.0 -12 4.8 −0.2 1.2 20 VIN 0 0.0 0.2 0.4 0.6 0.8 −10 t [s] Example of equivalent series resistance vs. Output current characteristics (Ta = −40°C to +125°C) CIN = CL = 1.0 μF 3.0 VIN RESR [Ω ] 5. 5.4 9 VOUT 4.8 13 11 VIN 5.0 5.6 VADJ / EN [V] VOUT [V] 5.4 15 VADJ / EN = 5.0 V VIN [V] VADJ / EN = 5.0 V VOUT [V] 1. 1 Characteristics of load transient response (Ta = +25°C) IOUT [mA] Characteristics of input transient response 2. (Ta = +25°C) VIN [V] 1. CIN Stable 0 S-19720 Series ADJ / EN 0.1 VSS 50 VOUT CL*1 RESR IOUT [mA] *1. Figure 17 CL: TDK Corporation CGA5L3X8R1H105K (1.0 μF) Figure 18 17 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 50 mA VOLTAGE TRACKER WITH REVERSE CURRENT PROTECTION S-19720 Series Rev.1.3_00  Power Dissipation SOT-23-5 HSNT-6(2025) Tj = +150°C max. 4 3 2 1 B Tj = +150°C max. 5 Power dissipation (PD) [W] Power dissipation (PD) [W] 5 4 E C 3 D 2 B 1 A A 0 0 25 50 75 100 125 150 175 0 0 25 Ambient temperature (Ta) [°C] 18 50 75 100 125 150 Ambient temperature (Ta) [°C] Board Power Dissipation (PD) Board Power Dissipation (PD) A 0.65 W A 0.69 W B 0.78 W B 0.98 W C − C 2.91 W D − D 2.84 W E − E 3.47 W 175 SOT-23-3/3S/5/6 Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. SOT23x-A-Board-SD-2.0 ABLIC Inc. HSNT-6(2025) Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - (3) Board C Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm No. HSNT6-B-Board-SD-1.0 enlarged view ABLIC Inc. HSNT-6(2025) Test Board IC Mount Area (4) Board D Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - enlarged view (5) Board E Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm enlarged view No. HSNT6-B-Board-SD-1.0 ABLIC Inc. 2.9±0.2 1.9±0.2 4 5 1 2 0.16 3 +0.1 -0.06 0.95±0.1 0.4±0.1 No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) ø1.5 ø1.0 +0.1 -0 +0.2 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 Feed direction No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. +1.0 - 0.0 9.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP005-A-R-SD-2.0 TITLE SOT235-A-Reel No. MP005-A-R-SD-2.0 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 1.96±0.05 1.78±0.1 6 5 0.5 1 4 2 3 0.5 0.5 0.12±0.04 0.48±0.02 0.22±0.05 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PJ006-B-P-SD-1.0 TITLE HSNT-6-C-PKG Dimensions No. PJ006-B-P-SD-1.0 ANGLE UNIT mm ABLIC Inc. ø1.5 +0.1 -0 2.0±0.05 4.0±0.1 ø0.5±0.1 0.25±0.05 0.65±0.05 4.0±0.1 2.25±0.05 3 21 0.5 0.5 0.5 0.5 0.5 0.5 4 5 6 Feed direction No. PJ006-B-C-SD-1.0 TITLE HSNT-6-C-Carrier Tape No. PJ006-B-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 9.0 +1.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PJ006-B-R-SD-1.0 TITLE HSNT-6-C-Reel No. PJ006-B-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 Land Recommendation 0.50 0.35 0.50 1.44 1.78 2.10 Caution It is recommended to solder the heat sink to a board in order to ensure the heat radiation. PKG Stencil Opening 1.40 0.50 0.50 No. PJ006-B-LM-SD-1.0 0.35 Caution Mask aperture ratio of the lead mounting part is 100~120%. Mask aperture ratio of the heat sink mounting part is 30%. Mask thickness: t0.12 mm Reflow atmosphere: Nitrogen atmosphere is recommended. (Oxygen concentration: 1000ppm or less) 100~120% 30% t0.12 mm TITLE HSNT-6-C -Land &Stencil Opening PJ006-B-LM-SD-1.0 No. ANGLE UNIT mm 1000ppm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-19720A00A-M5T1U7 价格&库存
很抱歉,暂时无法提供与“S-19720A00A-M5T1U7”相匹配的价格&库存,您可以联系我们找货
S-19720A00A-M5T1U7
  • 1+15.360181+1.98529
  • 10+11.2730310+1.45703
  • 25+10.2433925+1.32395
  • 100+9.11449100+1.17804
  • 250+8.57651250+1.10851
  • 500+8.25219500+1.06659
  • 1000+8.211751000+1.06137
库存:4
S-19720A00A-M5T1U7
  • 3000+7.655443000+0.98946
  • 6000+7.494116000+0.96861
  • 9000+7.413289000+0.95816
库存:4
