PUC1220035D2BG
PUC1220035D2BG
    FLEX(伟创力)
    SIP5 模块
    隔离模块 直流转换器 2 输出 20V -3.5V 90mA,80mA 10.8V - 13.2V 输入
PUC1220035D2BG 数据手册
PUBLIC PRODUCT TABLE OF CONTENTS SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou Approved (Document resp) 1/1301-BMR808 Checked PUC-2BG series DC/DC Converters jidgezou George Zou Isolated 2W Unregulated Dual Output Date 3/17/2023 1 (1) (5) Technical Specification Rev 28701-BMR808 E B Z Rev. B March 2023 © Flex Key Features • Industry standard SIP-7 package 19.5 x 9.8 x 12.5 mm (0.77 x 0.385 x 0.49 in) • High efficiency, typ. 81% at +15/-9 Vout full load • 6200 Vdc input to output isolation • Reinforced insulation - 250Vac rated working voltage • Ultra low isolation capacitance, typically < 6 pF • Meets safety requirements according to IEC/EN/UL62368-1 • Wide operating temperature from -40°C to 100°C • No minimum load required • Continuous output short-circuit protection • MTBF 13 Mhrs General Characteristics • • • • • 2 Watt output power Safety Compliance to EN 62368-1 ISO 9001/14001 certified supplier 12 V, 15 V & 24 V inputs +15 V / -3 V; +15 V / -5 V; +18 V / -2.5 V; +18 V / -5 V; +20 V / -3.5 V; +20 V / -5 V; +15 V / -9 V; +17 V / -9 V; +18 V / -9 V & ±15 V outputs Safety Approvals Design for Environment Meets requirements in hightemperature lead-free soldering processes. Contents Ordering Information General Information Safety Specification Absolute Maximum Ratings ............................................................. 2 ............................................................. 2 ............................................................. 3 ............................................................. 5 Electrical Specification 12-24 VI / 2.5-20 VO, 0.05-0.11 A / 2 W PUC-2BG Series .................................. 6 EMC Specification Operating Information Thermal Consideration Connections Mechanical Information Soldering Information Delivery Information Product Qualification Specification ........................................................... 12 ........................................................... 13 ........................................................... 14 ........................................................... 14 ........................................................... 15 ........................................................... 16 ........................................................... 16 ........................................................... 17 Prepared (Subject resp) 1/1301-BMR808 Approved (Document resp) Checked Date PUC-2BG series DC/DC Converters jidgezou George Zou 3/17/2023 Isolated 2W Unregulated Dual Output Nominal Input 12 V 12 V 12 V 12 V 12 V 12 V 12 V 12 V 12 V 12 V 15 V 15 V 15 V 15 V 15 V 15 V 15 V 15 V 15 V 15 V 24 V 24 V 24 V 24 V 24 V 24 V 24 V 24 V 24 V 24 V Technical Specification Rev March 2023 28701-BMR808 E Z Rev. B © Flex General Information Ordering Information PUC1215030D2BG PUC1215050D2BG PUC1218025D2BG PUC1218050D2BG PUC1220035D2BG PUC1220050D2BG PUC1215090D2BG PUC1217090D2BG PUC1218090D2BG PUC1215150D2BG PUC1515030D2BG PUC1515050D2BG PUC1518025D2BG PUC1518050D2BG PUC1520035D2BG PUC1520050D2BG PUC1515090D2BG PUC1517090D2BG PUC1518090D2BG PUC1515150D2BG PUC2415030D2BG PUC2415050D2BG PUC2418025D2BG PUC2418050D2BG PUC2420035D2BG PUC2420050D2BG PUC2415090D2BG PUC2417090D2BG PUC2418090D2BG PUC2415150D2BG 2 (5) No. jidgezou George Zou Product 2 PUBLIC PRODUCT SPECIFICATION Reliability Output +15 V/+110 mA, -3 V/-100 mA +15 V/+100 mA, -5 V/-100 mA +18 V/+80 mA, -2.5 V/-80 mA +18 V/+90 mA, -5 V/-90 mA +20 V/+90 mA, -3.5 V/-80 mA +20 V/+80 mA, -5 V/-80 mA +15 V/+100 mA, -9 V/-60 mA +17 V/+90 mA, -9 V/-50 mA +18 V/+90 mA, -9 V/-50 mA ±15 V/±67 mA +15 V/+110 mA, -3 V/-100 mA +15 V/+100 mA, -5 V/-100 mA +18 V/+80 mA, -2.5 V/-80 mA +18 V/+90 mA, -5 V/-90 mA +20 V/+90 mA, -3.5 V/-80 mA +20 V/+80 mA, -5 V/-80 mA +15 V/+100 mA, -9 V/-60 mA +17 V/+90 mA, -9 V/-50 mA +18 V/+90 mA, -9 V/-50 mA ±15 V/±67 mA +15 V/+110 mA, -3 V/-100 mA +15 V/+100 mA, -5 V/-100 mA +18 V/+80 mA, -2.5 V/-80 mA +18 V/+90 mA, -5 V/-90 mA +20 V/+90 mA, -3.5 V/-80 mA +20 V/+80 mA, -5 V/-80 mA +15 V/+100 mA, -9 V/-60 mA +17 V/+90 mA, -9 V/-50 mA +18 V/+90 mA, -9 V/-50 mA ±15 V/±67 mA Product number and Packaging PUCX1X2X3X4X5X6X7n1n2n3n4* Options n1 n2 Single/Dual output ο Output Power n3 n4 ο ο Form factor Custom suffix ο The failure rate (λ) and mean time between failures (MTBF= 1/λ) is calculated at max output power and an operating ambient temperature (TA) of +25°C. Flex uses MIL-HDBK-217F, Notice 2 to calculate the mean steadystate failure rate. In MIL-HDBK-217F, all part reliability models include the effects of environmental stresses through the environmental factor, πE. It encompasses the major areas of equipment use, here we use ground benign, GB. Mean steady-state failure rate, λ MTBF 76.9 nFailures/h 13 Mhrs Compatibility with RoHS requirements The products are compatible with the relevant clauses and requirements of the RoHS directive 2011/65/EU and have a maximum concentration value of 0.1% by weight in homogeneous materials for lead, mercury, hexavalent chromium, PBB and PBDE and of 0.01% by weight in homogeneous materials for cadmium. Exemptions in the RoHS directive utilized in Flex products are found in the Statement of Compliance document. Flex fulfills and will continuously fulfill all its obligations under regulation (EC) No 1907/2006 concerning the registration, evaluation, authorization and restriction of chemicals (REACH) as they enter into force and is through product materials declarations preparing for the obligations to communicate information on substances in the products. Quality Statement The products are designed and manufactured in an industrial environment where quality systems and methods like ISO 9000, Six Sigma, and SPC are intensively in use to boost the continuous improvements strategy. Infant mortality or early failures in the products are screened out and they are subjected to an ATE-based final test. Conservative design rules, design reviews and product qualifications, plus the high competence of an engaged work force, contribute to the high quality of the products. Options Description Warranty n1 n2 n3 n4 D 2 B G Warranty period and conditions are defined in Flex General Terms and Conditions of Sale. Dual Output 2W SIP7 Gate Driver Example a 24 Vdc nominal input, Dual +15/-5 Vdc output, 2 W SIP7 product would be PUC2415050D2BG. * X1X2 = Nominal input voltage X3X4 = Positive output voltage X5X6X7 = Negative output voltage Limitation of Liability Flex does not make any other warranties, expressed or implied including any warranty of merchantability or fitness for a particular purpose (including, but not limited to, use in life support applications, where malfunctions of product can cause injury to a person’s health or life). PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou Approved (Document resp) 1/1301-BMR808 Checked PUC-2BG series DC/DC Converters jidgezou George Zou Isolated 2W Unregulated Dual Output © Flex 2023 The information and specifications in this technical specification is believed to be correct at the time of publication. However, no liability is accepted for inaccuracies, printing errors or for any consequences thereof. Flex reserves the right to change the contents of this technical specification at any time without prior notice. Date 3/17/2023 Rev 3 (5) Technical Specification 28701-BMR808 E Z Rev. B © Flex 3 March 2023 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou Approved (Document resp) 1/1301-BMR808 Checked PUC-2BG series DC/DC Converters jidgezou George Zou Isolated 2W Unregulated Dual Output Safety Specification General information Flex Power DC/DC converters and DC/DC regulators are designed in accordance with the safety standards IEC 62368-1, EN 62368-1 and UL 62368-1 Audio/video, information and communication technology equipment Part 1: Safety requirements IEC/EN/UL 62368-1 contains requirements to prevent injury or damage due to the following hazards: • • • • • • Electrical shock Electrically-caused fire Injury caused by hazardous substances Mechanically-caused injury Skin burn Radiation-caused injury On-board DC/DC converters, Power interface modules and DC/DC regulators are defined as component power supplies. As components they cannot fully comply with the provisions of any safety requirements without “conditions of acceptability”. Clearance between conductors and between conductive parts of the component power supply and conductors on the board in the final product must meet the applicable safety requirements. Certain conditions of acceptability apply for component power supplies with limited stand-off (see Mechanical Information for further information). It is the responsibility of the installer to ensure that the final product housing these components complies with the requirements of all applicable safety standards and regulations for the final product. Component power supplies for general use shall comply with the requirements in IEC/EN/UL 62368-1. Product related standards, e.g. IEEE 802.3af Power over Ethernet, and ETS-300132-2 Power interface at the input to telecom equipment, operated by direct current (dc) are based on IEC/EN/UL 62368-1 with regards to safety. Flex Power DC/DC converters, Power interface modules and DC/DC regulators are UL 62368-1 recognized and certified in accordance with EN 62368-1. The flammability rating for all construction parts of the products meet requirements for V-0 class material according to IEC 60695-11-10, Fire hazard testing, test flames – 50 W horizontal and vertical flame test methods. Isolated DC/DC converters & Power interface modules The product may provide basic or functional insulation between input and output according to IEC/EN/UL 62368-1 (see Safety Certificate), different conditions shall be met if the output of a basic or a functional insulated product shall be considered as ES1 energy source. For basic insulated products (see Safety Certificate) the output is considered as ES1 energy source if one of the Date 3/17/2023 Rev 4 4 (5) Technical Specification 28701-BMR808 E Z Rev. B March 2023 © Flex following conditions is met: • The input source provides supplementary or double or reinforced insulation from the AC mains according to IEC/EN/UL 62368-1. • The input source provides functional or basic insulation from the AC mains and the product’s output is reliably connected to protective earth according to IEC/EN/UL 62368-1. For functional insulated products (see Safety Certificate) the output is considered as ES1 energy source if one of the following conditions is met: • The input source provides double or reinforced insulation from the AC mains according to IEC/EN/UL 62368-1. • The input source provides basic or supplementary insulation from the AC mains and the product’s output is reliably connected to protective earth according to IEC/EN/UL 62368-1. • The input source is reliably connected to protective earth and provides basic or supplementary insulation according to IEC/EN/UL 62368-1 and the maximum input source voltage is 60 Vdc. Galvanic isolation between input and output is verified in an electric strength test and the isolation voltage (Viso) meets the voltage strength requirement for basic insulation according to IEC/EN/UL 62368-1. It is recommended to use a slow blow fuse at the input of each DC/DC converter. If an input filter is used in the circuit the fuse should be placed in front of the input filter. In the rare event of a component problem that imposes a short circuit on the input source, this fuse will provide the following functions: • Isolate the fault from the input power source so as not to affect the operation of other parts of the system • Protect the distribution wiring from excessive current and power loss thus preventing hazardous overheating Non - isolated DC/DC regulators The DC/DC regulator output is ES1 energy source if the input source meets the requirements for ES1 according to IEC/EN/UL 62368-1. Prepared (Subject resp) 1 (8) No. jidgezou George Zou Approved (Document resp) 5 PUBLIC PRODUCT SPECIFICATION 2/1301-BMR808 Checked PUC-2BG seriesZou DC/DC Converters jidgezou George Isolated 2W Unregulated Dual Output Date 3/17/2023 Technical Specification Rev March 2023 28701-BMR808 Rev. B C © Flex Absolute Maximum Ratings Characteristics min TP1 Operating Temperature (see Thermal Consideration section) -40 TCASE Max. case temperature TS Storage temperature -55 VI Input voltage Range (base on nominal input voltage) -10 Viso Isolation voltage (input to output test voltage in 1minute) typ max Unit +100 °C +115 °C +125 °C +10 % 6200 Vdc Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the Electrical Specification section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Fundamental Circuit Diagram 6 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2 (8) No. jidgezou George Zou Technical Specification 2/1301-BMR808 Approved (Document resp) Checked Date PUC-2BG seriesZou DC/DC Converters jidgezou George Isolated 2W Unregulated Dual Output Rev March 2023 28701-BMR808 Rev. B C 3/17/2023 © Flex Electrical Specification PUC-2BG series Typical values given at: TP1 = +25°C, unless otherwise specified under Conditions. Part Number Input Voltage (±10%) Output Voltage Output Current Efficiency (typ.) 50% of max IO Efficiency (typ.) max IO PUC1215030D2BG PUC1215050D2BG PUC1218025D2BG PUC1218050D2BG PUC1220035D2BG PUC1220050D2BG PUC1215090D2BG PUC1217090D2BG PUC1218090D2BG PUC1215150D2BG PUC1515030D2BG PUC1515050D2BG PUC1518025D2BG PUC1518050D2BG PUC1520035D2BG PUC1520050D2BG PUC1515090D2BG PUC1517090D2BG PUC1518090D2BG PUC1515150D2BG PUC2415030D2BG PUC2415050D2BG PUC2418025D2BG PUC2418050D2BG PUC2420035D2BG PUC2420050D2BG PUC2415090D2BG PUC2417090D2BG PUC2418090D2BG PUC2415150D2BG V 12 12 12 12 12 12 12 12 12 12 15 15 15 15 15 15 15 15 15 15 24 24 24 24 24 24 24 24 24 24 V +15 / -3 +15 / -5 +18 / -2.5 +18 / -5 +20 / -3.5 +20 / -5 +15 / -9 +17 / -9 +18 / -9 +15 / -15 +15 / -3 +15 / -5 +18 / -2.5 +18 / -5 +20 / -3.5 +20 / -5 +15 / -9 +17 / -9 +18 / -9 +15 / -15 +15 / -3 +15 / -5 +18 / -2.5 +18 / -5 +20 / -3.5 +20 / -5 +15 / -9 +17 / -9 +18 / -9 +15 / -15 mA +110 / -100 +100 / -100 +80 / -80 +90 / -90 +90 / -80 +80 / -80 +100 / -60 +90 / -50 +90 / -50 +67 / -67 +110 / -100 +100 / -100 +80 / -80 +90 / -90 +90 / -80 +80 / -80 +100 / -60 +90 / -50 +90 / -50 +67 / -67 +110 / -100 +100 / -100 +80 / -80 +90 / -90 +90 / -80 +80 / -80 +100 / -60 +90 / -50 +90 / -50 +67 / -67 % 64 70 66 66 69 69 69 66 67 66 64 66 64 69 67 69 67 67 65 68 68 72 68 68 69 69 70 68 68 68 % 79 78 77 78 79 80 81 78 79 80 77 79 77 81 78 80 79 81 78 77 80 78 77 79 78 80 79 80 78 78 Characteristics CI Internal input capacitance PO Output power CLOAD Capacitive Load, see Note 2 RISO Isolation resistance Conditions min typ Isolation capacitance (typ.) (note 1) pF 4.8 4.9 5.2 4.8 6.3 6.5 5.5 4.4 4.4 5.5 5.7 5.2 5.4 5.4 6.5 6.1 6.4 6.3 5.1 5.5 4.9 4.8 6.1 6.8 5.2 5.5 5.7 5.6 4.9 5.5 max 1 Unit μF 2 100 10 W μF GΩ PUCxx15xxxD2BG, PUCxx17xxxD2BG, PUCxx18xxxD2BG. -5 +5 % PUCxx20xxxD2BG -8 +2 % Minimum load TP1 = +25°C 0 Line regulation, see Note 3 VLL to VHL, max IO 1.2 %/% Load regulation ILL - IHL, at typ. Vin 5 % fs Switching frequency 100 % of max IO (at typ. Vin) VOac Output ripple & noise 20 MHz BW, see Note 4 Voltage accuracy at typ. Vin, TP1 = +25°C, IO = max IO. VOi Note 1: The test condition of isolation capacitance is Freq: 1 kHz/Vs: 1 V Note 2: The maximum capacitive load is tested by normal input and constant resistive load. Note 3: The output voltage changes per input voltage changing. Note 4: The Output ripple & noise is under nominal Vin and max IO with 0.1 μF and 10 μF /50 V MLCC. % 20 30 130 kHz 50 mVp-p Prepared (Subject resp) 2/1301-BMR808 Approved (Document resp) Checked Date PUC-2BG seriesZou DC/DC Converters jidgezou George Isolated 2W Unregulated Dual Output 3/17/2023 Technical Specification Rev © Flex PUC-2BG series 100% 100% 80% 80% 60% 1215030 1215090 1218025 1217090 1218050 0 1215050 1215150 1220050 1218090 1220035 10 20 30 40 50 60 70 60 80 100 Load (%) PUC12-2BG Efficiency vs. load current at TP1 = +25°C. 100% Efficiency 80% 2415030 2415090 2418025 2417090 2418050 40% 20% 0% 0 2415050 2415150 2420050 2418090 2420035 10 20 30 40 50 60 70 80 90 100 Load (%) PUC24-2BG Efficiency vs. load current at TP1 = +25°C. Operating Ambient Temperature Curve Load (%) 100 80 60 40 20 0 Nat. Conv. -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 110 Available load vs. ambient air temperature. See Thermal Consideration section. 60% 1515030 1515090 1518025 1517090 1518050 40% 20% 0% 0 [°C] 1515050 1515150 1520050 1518090 1520035 10 20 30 40 50 60 70 80 90 100 Load (%) PUC15-2BG Efficiency vs. load current at TP1 = +25°C. Efficiency 60% Efficiency Efficiency Efficiency Efficiency 0% March 2023 28701-BMR808 Rev. B C Typical Characteristics 20% 3 (8) No. jidgezou George Zou 40% 7 PUBLIC PRODUCT SPECIFICATION 8 PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 4 (8) No. jidgezou George Zou Technical Specification 2/1301-BMR808 Approved (Document resp) Checked Date PUC-2BG seriesZou DC/DC Converters jidgezou George Isolated 2W Unregulated Dual Output Rev © Flex Typical Characteristics PUC-2BG series Output Voltage Accuracy Output Voltage Accuracy 30% 12Vin 13.5Vin 15Vin 20% 13.2Vin Accuracy Accuracy 30% 10.8Vin 20% 10% 0% -10% 16.5Vin 10% 0% -10% -20% 0 10 20 30 40 50 60 Load (%) 70 80 90 100 -20% 0 PUC12-2BG Output voltage accuracy vs. load current at TP1 = +25°C. 20 30 40 50 60 Load (%) 70 80 20% 21.6Vin 24Vin 20% Regulation 10% 12Vin 13.2Vin 10% 0% -10% 0 10 20 30 40 50 60 Load (%) 70 80 90 5% 0% 100 PUC24-2BG Output voltage accuracy vs. load current at TP1 = +25°C. 0 10 20 30 40 50 60 Load (%) 70 80 90 100 PUC12-2BG Output voltage with load variation vs. load current at TP1 = +25°C Load Regulation Load Regulation 13.5Vin 15Vin 15% 20% 21.6Vin 24Vin 15% 16.5Vin 10% Regulation 20% 26.4Vin 10% 5% 0% 100 10.8Vin 15% 26.4Vin -20% 90 Load Regulation 30% Accuracy 10 PUC15-2BG Output voltage accuracy vs. load current at TP1 = +25°C. Output Voltage Accuracy Regulation March 2023 28701-BMR808 Rev. B C 3/17/2023 5% 0 10 20 30 40 50 60 Load (%) PUC15-2BG 70 80 90 100 Output voltage with load variation vs. load current at TP1 = +25°C 0% 0 10 20 30 40 50 60 Load (%) PUC24-2BG 70 80 90 100 Output voltage with load variation vs. load current at TP1 = +25°C PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou Approved (Document resp) 2/1301-BMR808 Checked PUC-2BG seriesZou DC/DC Converters jidgezou George Isolated 2W Unregulated Dual Output Date 3/17/2023 Rev © Flex Output Ripple & Noise Top trace: Input voltage (10 V/div.). Middle trace: +Output voltage (10 mV/div.). Bottom trace: -Output voltage (10 mV/div.) Time scale: (10 µs/div.). Output Ripple & Noise Output voltage ripple at: TP1 = +25°C, VI = 12 V, VO = +20 / -5 V IO = +80 / -80 mA resistive load. 20 MHz bandwidth filter +10 µF &0.1 µF Top trace: Input voltage (10 V/div.). Middle trace: +Output voltage (10 mV/div.). Bottom trace: -Output voltage (10 mV/div.) Time scale: (10 µs/div.). Output Ripple & Noise Top trace: Input voltage (10 V/div.). Middle trace: +Output voltage (10 mV/div.). Bottom trace: -Output voltage (10 mV/div.) Time scale: (10 µs/div.). Output Ripple & Noise Output voltage ripple at: TP1 = +25°C, VI = 24 V, VO = +15 /-5 V IO = +100 / -100 mA resistive load. 20 MHz bandwidth filter +10 µF & 0.1 µF March 2023 PUC-2BG series Output Ripple & Noise Output voltage ripple at: TP1 = +25°C, VI = 15 V, VO = +15 / -5 V IO = +100 / -100 mA resistive load. 20 MHz bandwidth filter +10 µF & 0.1 µF 5 (8) Technical Specification 28701-BMR808 Rev. B C Typical Characteristics Output voltage ripple at: TP1 = +25°C, VI = 12 V, VO = +15 / -5 V IO = +100 / -100 mA resistive load. 20 MHz bandwidth filter +10 µF & 0.1 µF 9 Output voltage ripple at: TP1 = +25°C, VI = 15 V, VO = +20 / -5 V IO = +80 / -80 mA resistive load. 20 MHz bandwidth filter +10 µF & 0.1 µF Top trace: Input voltage (10 V/div.). Middle trace: +Output voltage (10 mV/div.). Bottom trace: -Output voltage (10 mV/div.) Time scale: (10 µs/div.). Output Ripple & Noise Top trace: Input voltage (10 V/div.). Middle trace: +Output voltage (10 mV/div.). Bottom trace: -Output voltage (10 mV/div.) Time scale: (10 µs/div.). Output voltage ripple at: TP1 = +25°C, VI = 24 V, VO = +20 /-5 V IO = +80 / -80 mA resistive load. 20 MHz bandwidth filter +10 µF & 0.1 µF Top trace: Input voltage (10 V/div.). Middle trace: +Output voltage (10 mV/div.). Bottom trace: -Output voltage (10 mV/div.) Time scale: (10 µs/div.). PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou Approved (Document resp) 2/1301-BMR808 Checked PUC-2BG seriesZou DC/DC Converters jidgezou George Isolated 2W Unregulated Dual Output Date 3/17/2023 Rev © Flex Shut-down Top trace: Input voltage (10 V/div.). Middle trace: +Output voltage (5 V/div.). Bottom trace: -Output voltage (5 V/div.). Time scale: (2 ms/div.). Start-up Start-up, enabled by connecting VI at: TP1 = +25°C, VI = 12 V, VO = +15 / -5 V IO = +100 / -100 mA resistive load. Top trace: Input voltage (10 V/div.). Middle trace: +Output voltage (5 V/div.). Bottom trace: -Output voltage (5 V/div.). Time scale: (2 ms/div.). Shut-down Top trace: Input voltage (10 V/div.). Middle trace: +Output voltage (10 V/div.). Bottom trace: -Output voltage (5 V/div.). Time scale: (2ms/div.). Start-up Start-up, enabled by connecting VI at: TP1 = +25°C, VI = 15 V, VO = +15 / -5 V IO = +100 / -100 mA resistive load. March 2023 PUC-2BG series Start-up Start-up, enabled by connecting VI at: TP1 = +25°C, VI = 12 V, VO = +20 / -5 V IO = +80 / -80 mA resistive load. 6 (8) Technical Specification 28701-BMR808 Rev. B C Typical Characteristics Start-up, enabled by connecting VI at: TP1 = +25°C, VI = 12 V, VO = +15 / -5 V IO = +100 / -100 mA resistive load. 10 Start-up, enabled by connecting VI at: TP1 = +25°C, VI = 12 V, VO = +20 / -5 V IO = +80 / -80 mA resistive load. Top trace: Input voltage (10 V/div.). Middle trace: +Output voltage (10 V/div.). Bottom trace: -Output voltage (5 V/div.). Time scale: (2ms/div.). Shut-down Top trace: Input voltage (10 V/div.). Middle trace: +Output voltage (5 V/div.). Bottom trace: -Output voltage (5 V/div.). Time scale: (2 ms/div.). Start-up, enabled by connecting VI at: TP1 = +25°C, VI = 15 V, VO = +15 / -5 V IO = +100 / -100 mA resistive load. Top trace: Input voltage (10 V/div.). Middle trace: +Output voltage (5 V/div.). Bottom trace: -Output voltage (5 V/div.). Time scale: (2 ms/div.). PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) No. jidgezou George Zou Approved (Document resp) 2/1301-BMR808 Checked PUC-2BG seriesZou DC/DC Converters jidgezou George Isolated 2W Unregulated Dual Output Date 3/17/2023 Rev © Flex Shut-down Top trace: Input voltage (10 V/div.). Middle trace: +Output voltage (10 V/div.). Bottom trace: -Output voltage (5 V/div.). Time scale: (2 ms/div.). Start-up Start-up, enabled by connecting VI at: TP1 = +25°C, VI = 15 V, VO = +20 / -5 V IO = +80 / -80 mA resistive load. Top trace: Input voltage (10 V/div.). Middle trace: +Output voltage (10 V/div.). Bottom trace: -Output voltage (5 V/div.). Time scale: (2 ms/div.). Shut-down Top trace: Input voltage (20 V/div.). Middle trace: +Output voltage (5 V/div.). Bottom trace: -Output voltage (5 V/div.). Time scale: (2 ms/div.). Start-up Start-up, enabled by connecting VI at: TP1 = +25°C, VI = 24 V, VO = +20 / -5 V IO = +80 / -80 mA resistive load. March 2023 PUC-2BG series Start-up Start-up, enabled by connecting VI at: TP1 = +25°C, VI = 24 V, VO = +15 / -5 V IO = +100 / -100 mA resistive load. 7 (8) Technical Specification 28701-BMR808 Rev. B C Typical Characteristics Start-up, enabled by connecting VI at: TP1 = +25°C, VI = 15 V, VO = +20 / -5 V IO = +80 / -80 mA resistive load. 11 Start-up, enabled by connecting VI at: TP1 = +25°C, VI = 24 V, VO = +15 / -5 V IO = +100 / -100 mA resistive load. Top trace: Input voltage (20 V/div.). Middle trace: +Output voltage (5 V/div.). Bottom trace: -Output voltage (5 V/div.). Time scale: (2 ms/div.). Shut-down Top trace: Input voltage (20 V/div.). Middle trace: +Output voltage (10 V/div.). Bottom trace: -Output voltage (5 V/div.). Time scale: (2 ms/div.). Start-up, enabled by connecting VI at: TP1 = +25°C, VI = 24 V, VO = +20 / -5 V IO = +80 / -80 mA resistive load. Top trace: Input voltage (20 V/div.). Middle trace: +Output voltage (10 V/div.). Bottom trace: -Output voltage (5 V/div.). Time scale: (2 ms/div.). PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 12 1 (4) No. jidgezou George Zou 3/1301-BMR808 Approved (Document resp) Checked PUC-2BG series DC/DC Converters jidgezou George Zou Date 2/15/2022 Isolated 2W Unregulated Dual Output Rev Technical Specification 28701-BMR808 Rev. B A March 2023 © Flex EMC Specification Conducted EMI measured according to EN55032, CISPR 32 and FCC part 15J (see test set-up). See Design Note 029 for further information. The minimum switching frequency is 20 kHz. The EMI characteristics below is measured at max IO. Optional external filter for class B Suggested external input filter in order to meet class B in EN 55032, CISPR 32 and FCC part 15J. Test set-up Layout recommendations The radiated EMI performance of the product will depend on the PWB layout and ground layer design. It is also important to consider the stand-off of the product. If a ground layer is used, it should be connected to the output of the product and to the equipment ground or chassis. Series C1 L1 C2 PUC12xxxxxD2BG 10 μF 0.91 mH 10 μF PUC15xxxxxD2BG 10 μF 0.91 mH 10 μF PUC24xxxxxD2BG 10 μF 0.91 mH 10 μF A ground layer will increase the stray capacitance in the PWB and improve the high frequency EMC performance. Output ripple and noise Output ripple and noise is measured according to figure below. See Design Note 022 for detailed information. Base on different application or PCB layout condition, the EMI requirement maybe different. Output ripple and noise test setup PUC1215050D2BG EMI with filter PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 2 (4) No. jidgezou George Zou Approved (Document resp) 13 3/1301-BMR808 Checked PUC-2BG series DC/DC Converters jidgezou George Zou Isolated 2W Unregulated Dual Output Operating Information Input Voltage Converter with 10% input voltage range, mainly for isolated power in industrial applications. For example, the input voltage range 10.8 to 13.2 Vdc meets requirement of general industrial used for 12Vdc system. The input voltage should never exceed the absolute voltage of the converter, and the ambient temperature must be limited to absolute max +100°C. The output voltage related to input voltage. Take 12Vin and ± 15Vo product as an example, if input voltage above 12V, the output voltage will higher than ±15V. Below 12V and the output voltage starts to track the input voltage. Short duration transient disturbances can occur on the DC distribution and input of the product when a short circuit fault occurs on the equipment side of a protective device (fuse or circuit breaker). The voltage level, duration and energy of the disturbance are dependent on the particular DC distribution network characteristics and can be sufficient to damage the product unless measures are taken to suppress or absorb this energy. The transient voltage can be limited by capacitors and other energy absorbing devices like Zener diodes connected across the positive and negative input conductors at a number of strategic points in the distribution network. The end-user must secure that the transient voltage will not exceed the value stated in the Absolute maximum ratings. ETSI TR 100 283 examines the parameters of DC distribution networks and provides guidelines for controlling the transient and reduce its harmful effect. Turn-off Input Voltage The products do not have under voltage lock-out function. Please make sure the input voltage of each module is correct working range. Input and Output Impedance The impedance of both the input source and the load will interact with the impedance of the product. It is important that the input source has low characteristic impedance.The product are designed for stable operation without external capacitors. With a 10uF capacitors connected to the input could reduce the input noise cause by parasitic inductance. External Decoupling Capacitors When powering loads with significant dynamic current requirements, the voltage regulation at the load can be improved by addition of decoupling capacitors at the load. The most effective technique is to locate low ESR ceramic and electrolytic capacitors as close to the load as possible, using several parallel capacitors to lower the effective ESR. The ceramic capacitors will handle high-frequency dynamic load changes while the electrolytic capacitors are used to handle Date 2/15/2022 Rev Technical Specification 28701-BMR808 Rev. B A March 2023 © Flex low frequency dynamic load changes. It is equally important to use low resistance and low inductance PWB layouts and cabling. External decoupling capacitors will become part of the product’s control loop. The control loop is optimized for a wide range of external capacitance and the maximum and minimum recommended value that could be used without any additional analysis is found in the Electrical specification. The ESR of the capacitors is a very important parameter. Stable operation is guaranteed with a verified ESR value of >1 mΩ across the output connections. For further information please contact your local Flex Power Modules representative. Parallel Operation This product is not designed for paralleling without using external current sharing circuits. See Design Note 006 for detailed information. Short Circuit Protection (SCP) The products include short circuit protection for protect converter short circuit at output. The SCP works in a hiccup mode and will make continous attempts to start up and will resume normal operation automatically after removal of the over current condition. PUBLIC PRODUCT SPECIFICATION Prepared (Subject resp) 3 (4) No. jidgezou George Zou Approved (Document resp) Isolated 2W Unregulated Dual Output Date Rev 28701-BMR808 Rev. B A 2/15/2022 © Flex Connections Thermal Consideration General The products are designed to operate in different thermal environments and sufficient cooling must be provided to ensure reliable operation. For products mounted on a PWB without a baseplate attached, cooling is achieved mainly by conduction, from the pins to the host board, and convection, which is dependant on the airflow across the product. Increased airflow enhances the cooling of the product. The Output Current Derating graph found in the Output section for each model provides the available output current vs. ambient air temperature and air velocity. The product is tested on a 95 x 85 mm, 35 µm (1 oz), 2-layer test board mounted horizontally in a space with a volume of 300(L) x 300(W) x 200(H) mm. Definition of product operating temperature The temperature at the positions (TP1) should not exceed the maximum temperatures in the table below. The number of measurement points may vary with different thermal design and topology. Temperatures above maximum measured at the reference point P1 are not allowed and may cause permanent damage. Position Description Max Temp. Driver, Reference point Pin side (baseplate module) Technical Specification 3/1301-BMR808 Checked PUC-2BG series DC/DC Converters jidgezou George Zou P1 14 TP1=115º C Bottom View PUCxxxxxxxD2BG series Pin 1 Designation +Vin Function Positive Input 2 -Vin Negative Input 5 -Vo Negative Output 6 COM Com 7 +Vo Positive Output March 2023 PUBLIC PRODUCT SPEC. MECHANICAL Prepared (Subject resp) No. jidgezou George Zou Approved (Document resp) Checked Date 2/18/2022 1 (2) Technical Specification 4/1301-BMR808 PUC-2BG series DC/DC Converters jidgezou George Zou Isolated 2W Unregulated Dual Output 15 Rev 28701-BMR808 Rev. B B March 2023 © Flex Mechanical Information – Through Hole Mounting Recommended Footprint All component placements – whether shown as physical components or symbolical outline – are for reference only and are subject to change throughout the product’s life cycle, unless explicitly described and dimensioned in this drawing. 16 PUBLIC PRODUCT SPEC. Prepared (Subject resp) 1 (3) No. jidgezou George Zou 5/1301 - BMR808 Approved (Document resp) Checked PUC-2BG series DC/DC Converters jidgezou George Zou Isolated 2W Unregulated Dual Output Soldering Information – Through Hole Mounting The hole mounted product is intended for plated through hole mounting by wave or manual soldering. The pin temperature is specified to maximum to 260°C for maximum 5 seconds. A maximum preheat rate of 4°C/s and maximum preheat temperature of 150°C is suggested. When soldering by hand, care should be taken to avoid direct contact between the hot soldering iron tip and the pins for more than a few seconds in order to prevent overheating. A no-clean flux is recommended to avoid entrapment of cleaning fluids in cavities inside the product or between the product and the host board. The cleaning residues may affect long time reliability and isolation voltage. Delivery Package Information The products are delivered in antistatic tube. Tube Specifications – SIP Material Antistatic PS Surface resistance 105 < Ohm/square < 1012 Tube length 520 mm 20.47 [ inch] Tube capacity 25 products (25 full tubes/box) Tube weight 35.4 g empty, 135.4 g full tube Module weight 4 g / pc 1 Tube=25 pcs 1 BOX = 25 (pcs/tube) * 5 (tube/bundle) * 5 (bundle) = 625 pcs 1 BOX = 625 converters All dimensions in mm Note: pick up positions refer to center of pocket. See mechanical drawing for exact location on product. Date 3/17/2023 Rev Technical Specification 28701-BMR808 Rev. B B © Flex March 2023 17 PUBLIC PRODUCT SPEC. Prepared (Subject resp) 2 (3) No. jidgezou George Zou 5/1301 - BMR808 Approved (Document resp) Checked PUC-2BG series DC/DC Converters jidgezou George Zou Isolated 2W Unregulated Dual Output Date 3/17/2023 Technical Specification Rev 28701-BMR808 Rev. B B © Flex Product Qualification Specification Characteristics External visual inspection IPC-A-610 Change of temperature (Temperature cycling) MI-STD-202G, method 107G Temperature range Number of cycles Dwell/transfer time -55 to 125°C 300 30 min/0-1 min Cold (in operation) IEC 60068-2-1 Ad Temperature TA Duration -40°C 72 h Damp heat MIL-STD-202G, Method 103B Temperature Humidity Duration 85°C 95 % RH 1000 hours Dry heat IEC 60068-2-2 Bd Temperature Duration 125°C 1000 h Electrostatic discharge susceptibility IEC 61000-4-2 Air model Contact model 15 kV 8 kV Mechanical shock MIL-STD-202G, method 213B Peak acceleration Duration 100 g 6 ms Operational life test MIL-STD-202G, method 108A Duration 1000 h Resistance to soldering heat 1 MIL-STD-202G, method 210F Solder temperature Duration 260°C 10 s Robustness of terminations IEC 60068-2-21 Test Ua1 IEC 60068-2-21 Test Ue1 Through hole mount products Surface mount products All leads All leads Solderability J-STD-002 Preconditioning Temperature, Pb-free Steam ageing 8 h 245°C Vibration MIL-STD-202G, method 201A Frequency Displacement Duration 10 to 55 Hz 0.06 inch 2 h in each direction Notes 1 Only for products intended for wave soldering (plated through hole products) March 2023
PUC1220035D2BG 价格&库存
很抱歉,暂时无法提供与“PUC1220035D2BG”相匹配的价格&库存,您可以联系我们找货
