87 01 560 US
87 01 560 US
    KNIPEX(凯尼派克)
    可调(水泵) 钳子 平头 有齿 22.00"(558.8mm)
87 01 560 US 数据手册
KNIPEX Cobra® XL/XXL Pipe Wrenches and High-Tech Water Pump Pliers DIN ISO 5743 87 0 >> greater gripping capacity and lighter weight than comparable pipe gripping wrenches >> fast push-button adjustment directly on the workpiece, no unintentional slipping of the joint >> fine adjustment for optimum adaptation to different size workpieces and a comfortable gripping position >> self-locking on pipes and nuts: no slipping off the workpiece and low handforce required >> gripping surfaces with special hardened teeth, teeth hardness (approx. 61 HRC): low wear and reliable gripping >> box-joint design: high stability because of double guide >> pinch guard prevents operators´ fingers being pinched >> chrome vanadium electric steel; forged, multi stage oil-hardened Cobra ® 87 01 400 US The KNIPEX Cobra XL and XXL offer the power and comfort of water pump pliers while being lighter in weight and having a greater gripping capacity than comparable pipe wrenches. The Cobra® XL can grip a 3 1/2" pipe coupling and weighs 50% less than 2" pipe wrenches, which have a much lower gripping capacity. With its compact length of 16" (400 mm), the Cobra XL is perfect for the plumber’s toolbox. ® The Cobra® XXL with its capacity of up to 4 1/2" only weighs as much a 2" pipe wrench. It’s 22" size makes it the biggest pliers around! Fine adjustment by pushing a button: fast and comfortable Product Number Packaging Fast and firm adjustment directly on the workpiece Inch mm 87 01 400 US X 16 400 87 01 560 US X 22 560 134 87 01 560 US Pliers Head Handles grey atramentized polished plastic coated   grey atramentized polished plastic coated Ø Inch Ø mm 3 1/2 90 4 1/2 115 Inch mm 3 3/4 95 4 3/4 120 Adjustment positions lbs 27 2.62 20 6.06
87 01 560 US 价格&库存
很抱歉,暂时无法提供与“87 01 560 US”相匹配的价格&库存,您可以联系我们找货
