TJ-LF5RGBMYTLFCYHQ-A3
    TOGIALED(台湾统佳)
    插件,P=1.3mm
    发光二极管/LED φ5mm 圆头雾状RGB 共阳极 有边 直插 4Pin
TJ-LF5RGBMYTLFCYHQ-A3 数据手册
TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 承 認 書 Specification For Approval Customer: (客戶) Description: (產品描述) 5MM圓頭霧狀共陽RGB Part number:(產品型號) TJ-LF5RGBMYTLFCYHQ-A3 Date: (日期) Approved By: (客戶承認) Prepared By:(我司承認) Approval 核准 Check Design 審核 製作 Sales 業務 Customer Service Hotline:400-676-8616 TEL:0769-8662 5999 0769-8200 2226 E-MIAL∶dg@togialed.com FAX:0769-8200 2227 WEB:www.togi aled. c om TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 1.overview * Low power consumption * Low power * General equipment on the PCB board or panel * with ICSupporting the use/ Low current requirement 2.Product appearance size figure (unit:mm) 1、RED 2、COMMON 3、GREEN 4、BLUE common anode 4 1 32 + 0.5 pin*4 Note: 1:All dimensions are in millimeters (inches). 2:Tolerance is ±0.25mm (.010”) unless otherwise noted. 3: Specifications are subject to change without notices. 4:This specification is for reference only for one year 2/8 TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 4. parameter 4.1The limit parameter(room temperature 25℃) parameter The numerical Unit 320 mW Pulse current (1/10 work loops 0.1 millisecond pulse width ) 100 mA Working current (IF) 30 mA Reverse voltage (VR) 5 V Dissipation power Working temperature range -20℃ ~ +80℃ Storage temperature range -30℃ ~ +100℃ Soldering temperature from the roots (4.0 mm) 260℃ for 5 Seconds Photoelectric parameters At room temperature 25℃ Parameter Luminous intensity The wavelength(λ) electric voltage Red Green Blue Red Green Blue Red Green Blue min Avg max Unit Test Condition 200 800 100 620 515 460 1.8 2.8 2.8 400 1500 300 ----525 --------------------- ------------630 530 470 2.4 3.4 3.4 5 mcd mcd mcd Nm Nm Nm V V V µA If=20mA If=20mA If=20mA If=20mA If=20mA If=20mA If=20mA If=20mA If=20mA Vr=5V Reverse current Selection Guide: Colloid color White Diffused Chip Material GaASP/Gap InGaN/GaN InGaN/GaN 3/8 Emitting light colors Red Blue Green λp (nm) 620 465 520 TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 5、Under the condition of 25 ℃ electrical diagram: Spectral Radiance (Peak@620nm) 1.0 0.8 Normalized Response Normalized Response 0.8 0.6 0.4 0.2 0.0 0.6 0.4 0.2 0.0 380 400 420 440 460 480 500 520 540 560 580 600 620 640 660 680 700 720 740 760 780 Wave Length(nm) 380 400 420 440 460 480 500 520 540 560 580 600 620 640 660 680 700 720 740 760 780 Wave Length(nm) Forward Current vs Forward Voltaga 35 Forward Current vs Forward Voltaga 35 30 30 Forward Current IF(mA) Forward Current IF(mA) Spectral Radiance (Peak@520nm) 1.0 25 20 15 10 5 25 20 15 10 5 0 1.6 1.8 2.2 2.4 2.6 Forward Voltaga VF(V) 2.8 3.0 0 Relative Luminous Intensity vs Forward Voltaga 3 1.0 3 2.5 2.7 2.9 3.1 3.3 3.5 Forward Voltaga VF(V) 3.7 3.9 Spectral Radiance (Peak@465nm) 2.5 0.8 2.5 Normalized Response Relative Intensity (LOP@20mA=1) 2.0 2 1.5 1 0.5 0 0.6 0.4 0.2 0 5 10 15 20 25 Forward Current IF(mA) 30 35 0.0 380 400 420 440 460 480 500 520 540 560 580 600 620 640 660 680 700 720 740 760 780 5 15 20 35 Wave Length(nm) 4/8 TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 6.Not dry glue label P/N: Product number VF: Forward voltage BIN: points light IV: Luminous intensity WL: Color/wavelength QTY: number QC: Production order 7.packaging Desiccant 纸板 Aluminum moisture-proof bag The packing way:Electrostatic bag packing Packing specification:White light color packing 1000PCS/bag, puguang 1000PCS/bag。 Pay attention to:Above belongs to the normal packing specification, if you have any special requirements according to customer requirements 5/8 TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 8.The cautions of stent deformation Stent deformation must be conducted before welding, plastic, stent bend position must be at least 3 mm at the bottom of the encapsulating resin, at the same time, avoid bent many times on the same position. When the deformation, fixed bracket, please use the right tools to avoid resin pressure. Especially not as a pivot pin connected with the resin part, so the stress within the product on light emitting structure directly into damage, lead to the change of product features and even damaged. For the same reason, in the assembly of products, the distance between welding PCB hole must be in the pin spacing of the products strictly match, as shown in the figure below: 6/8 TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 9.Reliability of the experimental project and conditions serial number Test project The test conditions The sample quantity Acceptance/ rejection 1 Life test Test current:20MA The temperature:25℃ The test of time:1000 hours 20 0/1 2 High temperature high humidity(sta tic test) The temperature:=+65℃ humidity:90% RH The test of time:240 hours 20 0/1 3 Cold and hot shock -40℃ ~ +100℃ 20min 10s 20min Test time: 100 loops 20 0/1 4 High temperature storage The high temperature:100℃ The test of time:1000 hours 20 0/1 5 Low temperature storage The low temperature:-40℃ The test of time:1000 hours 20 0/1 6 Temperature loop -40℃ ~ +100℃ 60min 20s 60min Test time: 20 loops 20 0/1 7 Reflow soldering 260℃(Max) , the maximum of no more than 5 seconds 20 0/1 Reliability experiment unqualified judgement standard IV: Attenuation is more than 30% VF: Change is more than 20% note:1)Same project the results of the test must be completed within 2 hours。 2)Testing must be completed in each experiment. Material return to normal conditions。 7/8 TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 11.ESD protective LED is a semiconductor device, the static sensitive, especially for white, green, blue, purple LED to make efforts to prevent electrostatic generation and eliminate static electricity。 11.1The generation of static electricity a. Friction: in daily life, any two objects of different material contact after the separation, can produce static, and the one of the most common method of generation of static electricity, is the electrification. The insulation material, the better, the easier the electrification. In addition, any two objects of different material contact again after separation, also can produce static electricity。 b. Induction: in view of the conductive material, because electrons can flow freely in its surface, such as to be put in the electric field, due to the same, opposites attract, the positive and negative ions will move, can produce electric charge on the surface。 c. Conduction: in view of the conductive material, because electrons can flow freely in surface, such as contact with a charged object, the charge transfer will occur。 11.2The dangers of static electricity on the LED: a. For the moment's electric field or electric current produced by the heat, the LED local injury。 b. Because of destruction of the electric field or current LED insulation layer, the device will not work (destroyed) characterized by death lamp。 11.3Electrostatic protection and measures to eliminate For the entire process (production, testing, packaging, etc.) all employees in direct contact with the LED to measures to prevent and eliminate static electricity, mainly: a. Laying anti-static workshop floor and well grounded。 b. Workbench for esd workstation, production machines grounding is good。 c. Operators wear anti-static clothing, anti-static hand ring, gloves or foot ring。 d. Application of ion fan, the welding electric grounding measures。 e. Packing with antistatic materials。 8/8
1. 物料型号:TJ-LF5RGBMYTLFCYHQ-A3 2. 器件简介:低功耗、通用设备上的PCB板或面板、支持IC使用、低电流需求。 3. 引脚分配:共阳RGB LED,引脚数为4,尺寸为0.5mm。 4. 参数特性: - 耗散功率:320mW - 脉冲电流:100mA(1/10工作循环,0.1ms脉冲宽度) - 工作电流:30mA - 反向电压:5V - 工作温度范围:-20°C至+80°C - 存储温度范围:-30°C至+100°C - 焊接温度(根部4.0mm):260°C持续5秒 5. 功能详解:包括光电参数,如发光强度、波长、正向电压和反向电流。 6. 应用信息:适用于一般设备上的PCB板或面板。 7. 封装信息:封装尺寸图,所有尺寸单位为毫米,公差±0.25mm,规格如有变更不另行通知,规格书有效期为一年。
TJ-LF5RGBMYTLFCYHQ-A3 价格&库存
很抱歉,暂时无法提供与“TJ-LF5RGBMYTLFCYHQ-A3”相匹配的价格&库存,您可以联系我们找货
