RSBRS02AI
RSBRS02AI
    RF-STAR(信驰达)
    SMD,MODULE_15.1x11.2mm
    IPEX接口外接天线国产芯片蓝牙5.0串口透传主从一体模块RSBRS02AI
RSBRS02AI 数据手册
Shenzhen RF-star Technology Co.,Ltd. 低功耗蓝牙(BLE)模块 RSBRS02AI 硬件规格书 信驰达科技有限公司 更新日期:2019 年 7 月 30 日 1 Shenzhen RF-star Technology Co.,Ltd. 目录 目录.................................................................................................................................................................................2  概述..........................................................................................................................................................................3  版本更新记录..........................................................................................................................................................4  模块参数..................................................................................................................................................................5  模块引脚定义..........................................................................................................................................................6  PCB 封装尺寸.......................................................................................................................................................... 8  原理框图..................................................................................................................................................................9  参考原理图............................................................................................................................................................10  RF 测试报告...........................................................................................................................................................11  布局建议................................................................................................................................................................12  天线........................................................................................................................................................................13  常用的天线............................................................................................................................................................14  推荐操作条件........................................................................................................................................................15  回流焊条件............................................................................................................................................................16  静电放电警示........................................................................................................................................................17  联系我们................................................................................................................................................................18 附录:模块射频参数测试报告.................................................................................................................................. 19 2 Shenzhen RF-star Technology Co.,Ltd.  概述 深圳信驰达该款蓝牙模块是基于公司 RS02A1 芯片研发的低功耗蓝牙(BLE)射频模块,可 广泛应用于短距离无线通信领域。具有功耗低、体积小、传输距离远、抗干扰能力强等特点。 模块配备高性能蛇形天线;模块采用邮票半孔形式硬件接口设计。 该模块可用于开发基于蓝牙 4.2(BLE,低功耗蓝牙)的消费类电子产品、手机外设产品等, 能提高操作的可靠性;提高信号的传输距离和抗干扰性;还能实现解决不同电子产品间的互操 作问题,电池寿命也可显著延长。为客户产品与智能移动设备通讯提供快速的 BLE 解决方案。 信驰达 RSBRS02AI 模块成为注重电池使用寿命、小型尺寸和简便实用性的各类应用的理想 选择。 3 Shenzhen RF-star Technology Co.,Ltd. 版本更新记录 版本号 文档日期 更新内容 V1.0 2018/10/16  第一次发布 V1.1 2019/07/30  更新封面  更新模块参考原理图 4 Shenzhen RF-star Technology Co.,Ltd.  模块参数 VDD=3.3V,TA = 25°C(除非另有说明),在 RSBRS02AA 模块参考设计包括外部匹配元 件下测量。 Parameter Ratings Test Conditions 工作电压 电池或锂电池 总信道数 信道间隔 2MHz 频率范围 2402~2480MHz Typ. Max. 1.6 3.3 3.6 V 0 dBm 40 -20 输出功率 -94 最佳接收灵敏度 调制方式 Unit Min. dBm GFSK(高斯频移键控) 工作温度 -20 70 °C 储存温度 -40 125 °C 模块尺寸 15.1*11.2 mm 休眠电流 (测试软件 RS02A1_TEST.hex) 5 uA 广播事件电流 (广播间隔为 200ms,0dBm) 90 uA 连接事件电流 (连接间隔为 20ms,0dBm) 0.35 mA 5 Shenzhen RF-star Technology Co.,Ltd.  模块引脚定义 如图 1 显示的是模块的引脚图,表 1 为其各引脚定义。 图 1 模块引脚定义 6 Shenzhen RF-star Technology Co.,Ltd. 表 1 引脚定义 脚位 名称 功能 备注 Pin1 GND 模块地 模块地 Pin2 VCC 电源正极输入 模块电源,可接电池(1.8 V to 3.8 V) 推荐为 3. 3V Pin3 P15 I/O Pin4 P24 I/O Pin5 RESET 复位脚 Pin6 P06 I/O Pin7 SWC SWCLK 接 J-Link 仿真器 SWCLK Pin8 SWD SWDIO 接 J-Link 仿真器 SWDIO Pin9 P21 I/O Pin10 P10 I/O Pin11 P11 I/O Pin12 P12 I/O Pin13 P14 I/O Pin14 P16 I/O Pin15 P17 I/O Pin16 P27 I/O Pin17 P28 I/O Pin18 P03 I/O 7 低电平有效 Shenzhen RF-star Technology Co.,Ltd.  PCB 封装尺寸 模块尺寸为 15.1*11.2*1.65mm。如图 2 为模块尺寸图,模块厚度为 1.65±0.2 mm。 图2 模块尺寸图 8 Shenzhen RF-star Technology Co.,Ltd.  原理框图 如图 3 显示的是模块的原理框图。 图 3 原理框图 9 Shenzhen RF-star Technology Co.,Ltd.  参考原理图 如图 4 所示为模块的参考原理图。 图 4 模块参考原理图 10 Shenzhen RF-star Technology Co.,Ltd.  RF 测试报告 T A = +25°C, V BAT = 3.3V,在第 39 信道(2442MHz)上测量的结果如下表所示,更多测试 数据请参看附录。 测试项目 发射机 接收机 参数 测试值 单位 功率 0.42 dBm 频偏 2.168 khz 灵敏度(8% PER) -93.5 dBm 11 Shenzhen RF-star Technology Co.,Ltd.  布局建议 PCB 上有 IPEX 座子,可以连接外置天线。天线的位置和布局范围是增加数据速率和发射 范围的关键。 因此,关于天线位置的布局建议如下: 采用的外置天线接口为 50 欧阻抗 图 5 模块天线座子区域 12 Shenzhen RF-star Technology Co.,Ltd.  天线 RSBRS02AI 模块使用 IPEX 1 代天线座,天线座的规格如图 3 所示: 图6 IPEX 板端规格 图7 IPEX 板端规格 IPEX 线端规格如图 7 所示: 13 Shenzhen RF-star Technology Co.,Ltd.  常用的天线及接口 图8 常用天线 14 Shenzhen RF-star Technology Co.,Ltd.  推荐操作条件 功能操作在以下表格中各条件参数值的极限之外不能保证其性能,长期在这个极限之外操 作或多或少会影响模块的可靠性。 注意: (1) 操作温度受晶体频率的变化限制; (2) 为了确保无线射频性能,电源上纹波必须小于  300mV。 标识 条件 最小值 典型值 最大值 单位 电源与 IO 电池模式 1.6 3.3 3.6 V 操作温度 / -40 25 85 ℃ 20 ℃/分钟 环境热摆 -20 15 Shenzhen RF-star Technology Co.,Ltd.  回流焊条件 1. 加热方法:常规对流或 IR 对流; 2. 允许回流焊次数:2 次,基于以下回流焊(条件)(见图 7); 3. 温度曲线:回流焊应按照下列温度曲线(见图 7); 4. 最高温度:245°C。 图 9 部件的焊接耐热性温度曲线(焊接点) 16 Shenzhen RF-star Technology Co.,Ltd.  静电放电警示 模块会因静电释放而被损坏,RF STAR 建议所有模块应在以下 3 个预防措施下处理: 1、必须遵循防静电措施,不可以裸手拿模块。 2、模块必须放置在能够预防静电的放置区。 3、在产品设计时应该考虑高电压输入或者高频输入处的防静电电路。 静电可能导致的结果为细微的性能下降到整个设备的故障。由于非常小的参数变化都可能 导致设备不符合其认证要求的值限,从而模块会更容易受到损害。 17 Shenzhen RF-star Technology Co.,Ltd.  联系我们 深圳市信驰达科技有限公司 SHENZHEN RF STAR TECHNOLOGY CO.,LTD. Tel:0755–8632 9829 Web: www.szrfstar.com Fax:0755-86329413 E-mail:sales@szrfstar.com 地址:深圳市南山区高新园科技南一道创维大厦 C 座 601 室 Add:Room 601,Block C,Skyworth Building,Nanshan High-Tech Park,Shenzhen. 18 Shenzhen RF-star Technology Co.,Ltd. 附录:模块射频参数测试报告 一、发射性能参数 除特别说明外,以下参数测试的默认条件为:VDD=3.3V,TA = 25°C,RBW=100K, VBW=300K,Sweep Time 为 100ms。 1、频率范围 频率范围 2402-2480MHz 2、发射功率 中心频率(MHz) 发送功率(dBm) 允许误差(dBm) 2402 -0.19 PASS 2404 -0.17 PASS 2406 -0.13 PASS 2408 -0.08 PASS 2410 -0.05 PASS 2412 0.00 PASS 2414 0.04 PASS 2416 0.07 PASS 2418 0.12 PASS 2420 0.16 PASS 2422 0.19 2424 0.23 PASS 2426 0.27 PASS 2428 0.29 PASS 2430 0.33 PASS 2432 0.35 PASS 2434 0.37 PASS 2436 0.39 PASS 2438 0.41 PASS 2440 0.41 PASS 2442 0.42 PASS 0dBm(±2dBm) 19 结果 PASS Shenzhen RF-star Technology Co.,Ltd. 2444 0.44 PASS 2446 0.44 PASS 2448 0.46 PASS 2450 0.46 PASS 2452 0.46 PASS 2454 0.45 PASS 2456 0.44 PASS 2458 0.43 PASS 2460 0.40 PASS 2462 0.39 PASS 2464 0.37 PASS 2466 0.34 PASS 2468 0.31 PASS 2470 0.28 PASS 2472 0.25 PASS 2474 0.22 PASS 2476 0.17 PASS 2478 0.13 PASS 2480 0.09 PASS 3、频率误差 波形输出=CW。 FCC 允许偏移范围(KHz) 结果 中心频率(MHz) 频率偏移(KHz) 2402 2.334 PASS 2404 2.167 PASS 2406 2.168 PASS 2408 2.334 PASS 2410 2.167 2412 2.168 PASS 2414 2.226 PASS 2416 2.168 PASS 2418 2.35 PASS ±40KHz 20 PASS Shenzhen RF-star Technology Co.,Ltd. 2420 2.334 PASS 2422 2.54 PASS 2424 2.342 PASS 2426 2.325 PASS 2428 2.167 PASS 2430 2.334 PASS 2432 2.223 PASS 2434 2.334 PASS 2436 2.167 PASS 2438 2.168 PASS 2440 3.666 PASS 2442 2.168 PASS 2444 2.35 PASS 2446 2.334 PASS 2448 2.54 PASS 2450 2.334 PASS 2452 2.35 PASS 2454 2.334 PASS 2456 2.54 PASS 2458 2.334 PASS 2460 2.334 PASS 2462 2.167 PASS 2464 2.168 PASS 2466 2.334 PASS 2468 2.167 PASS 2470 2.168 PASS 2472 2.54 PASS 2474 2.334 PASS 2476 2.233 PASS 2478 2.242 PASS 2480 2.167 PASS 21 Shenzhen RF-star Technology Co.,Ltd. 4、带内杂散。 测试条件:PTX=0dBm。 中心频率(MHz) 实际数据(dBm) 2402±2MHz -43.21 2440±2MHz -42.88 2480±2MHz -43.32 22 RF-PHY.TS.4.2.2 标准 参考范围(dBm) 结果 ≤-20dBm PASS Shenzhen RF-star Technology Co.,Ltd. 中心频率(MHz) 实际数据(dBm) 2402±3MHz -47.24 2440±3MHz -46.25 2480±3MHz -47.38 中心频率(MHz) 实际数据(dBm) 23 RF-PHY.TS.4.2.2 标准 参考范围(dBm) 结果 ≤-30dBm PASS RF-PHY.TS.4.2.2 标准 结果 Shenzhen RF-star Technology Co.,Ltd. 参考范围(dBm) 2402±5MHz -43.04 2440±5MHz -42.3 2480±5MHz -42.57 PASS ≤-30dBm 5、带外杂散 ·CE 传导谐波带外杂散限值 测试条件:PTX=0dBm。测试依据 CE 标准 EN300328V1.8.1。 频率(MHz) 电平(dBm) 标准(standard) Unit Record(Max) level /dBm EN300 328 Spec RBW/VBW 30MHz~47MHz 32 -80 -36 100k/300k PASS 47MHz~74MHz 64 -69.5 -54 100k/300k PASS 74MHz~87.5MHz 75 -70.39 -36 100k/300k PASS 87.5MHz~118MHz 96 -71 -54 100k/300k PASS 118MHz~174MHz 128 -65 -36 100k/300k PASS 230MHz~470MHz 256 -59 -36 100k/300k PASS 470MHz~862MHz 480 -71 -54 100k/300k PASS 862MHz~1GMHz 864 -69 -36 100k/300k PASS 1GHz~2.36GHz 2.30 -48.6 -30 1M/3M PASS 2.5235GHz~12.75GHz 2.523 -41.66 -30 1M/3M PASS Band 24 结果 Shenzhen RF-star Technology Co.,Ltd. ·FCC 传导谐波带外杂散限值 测试依据 FCC 标准 PART 15.247。 载波频率(MHz) 谐波频率(MHz) 2402 2440 2480 FCC 要求: < -41.2dBm 结果 实测(dBm) 余量(dB) 4810 -42 0.8 PASS 7215 -65 23.8 PASS 4880 -42.3 1.1 PASS 7320 -64 22.8 PASS 4960 -43.5 2.3 PASS 7440 -64.12 22.92 PASS 25 Shenzhen RF-star Technology Co.,Ltd. 二、接收性能参数 除特别说明外,以下参数默认的测试条件为:VDD=3.3V,TA = 25°C,RBW=100K, VBW=300K。 1、接收灵敏度(丢包率 PER=1%) RS02A 数据手册 灵敏度范围(dBm 中心频率(MHz) 接收灵敏度(dBm) 2402 -93.5 PASS 2404 -93.5 PASS 2406 -93.4 PASS 2408 -93.3 PASS 2410 -93.6 PASS 2412 -93.8 PASS 2414 -93.8 PASS 2416 -93.4 PASS 2418 -93.6 PASS 2420 -93.1 PASS 2422 -93.8 PASS 2424 -93.8 PASS 2426 -93.6 PASS 2428 -93.5 PASS 2430 -93.7 PASS 2432 -93.5 PASS 2434 -93.3 2436 -93.5 2438 -93.2 PASS 2440 -93.4 PASS 2442 -93.5 PASS 2444 -93.4 PASS 2446 -93.4 PASS 2448 -93.3 PASS 2450 -93.1 PASS 2452 -93.4 PASS 2454 -93.4 PASS 2456 -93.2 PASS 2458 -93.5 PASS 2460 -93.3 PASS 2462 -93.5 PASS 2464 -93.5 PASS 2466 -93.5 PASS 2468 -93.6 PASS -94dBm 26 结果 PASS PASS Shenzhen RF-star Technology Co.,Ltd. 70 -93.4 PASS 2472 -93.4 PASS 2474 -93.6 PASS 2476 -93.4 PASS 2478 -93.6 PASS 2480 -93.4 PASS 2、C/I 阻塞性能 中心频率(MHz) 2402 2440 2480 输入电平(dBm) 偏移频率(MHz) CI 电平(dB) -67 -3 -33 -67 -2 -23 -67 -1 -5 -67 0 5 -67 1 -5 -67 2 -34 -67 3 -46 -67 -3 -33 -67 -2 -24 -67 -1 -4 -67 0 5 -67 1 -5 -67 2 -38 -67 -3 -46 -67 -2 -23 -67 -1 -4 -67 0 5 -67 1 -5 -67 2 -35 -67 3 -46 27
RSBRS02AI 价格&库存
很抱歉,暂时无法提供与“RSBRS02AI”相匹配的价格&库存,您可以联系我们找货
