RF-WM-20CMB1
RF-WM-20CMB1
    RF-STAR(信驰达)
    SMD,MODULE_23x20mm
    RTL8720 WiFi蓝牙二合一模块 串口转WiFi透传 Wi-Fi 4 + BLE 4.2
RF-WM-20CMB1 数据手册
Shenzhen RF-star Technology Co.,Ltd. RF-WM-20CMB1 硬件使用手册 TEL: 0755-86329829 FAX: 0755-86329413 ADD: 深圳市南山区高新园科技南一道创维大厦 C 座 601 室 WEB: www.szrfstar.com Shenzhen RF-star Technology Co.,Ltd. 目录 一、概述 ................................................................................................................................... 3 1.1 模块概述............................................................................................................................ 3 1.2 应用.................................................................................................................................... 3 1.3 方框图................................................................................................................................ 4 二、技术参数 ........................................................................................................................... 5 2.1 基本参数............................................................................................................................. 5 2.2 WiFi..................................................................................................................................... 5 2.3 Bluetooth ............................................................................................................................. 5 三、模块尺寸及定义 ............................................................................................................... 6 3.1 3.2 3.3 3.4 尺寸.................................................................................................................................... 6 引脚图................................................................................................................................ 6 引脚分配表........................................................................................................................ 7 引脚复用表........................................................................................................................ 8 四、硬件设计注意事项 ........................................................................................................... 9 五、回流焊条件 ..................................................................................................................... 10 六、静电放电警示 ................................................................................................................. 10 附录:版本记录 ..................................................................................................................... 11 ⚫ 联系我们 ......................................................................................................................... 11 TEL: 0755-86329829 FAX: 0755-86329413 ADD: 深圳市南山区高新园科技南一道创维大厦 C 座 601 室 WEB: www.szrfstar.com Shenzhen RF-star Technology Co.,Ltd. 一、概述 1.1 模块概述 RF-WM-20CMB1 模块是 RF-star 全新推出的一款嵌入式 Wi-Fi+BT 模块,该 模块采用瑞昱(Realtek)的 SOC Wi-Fi 方案 RTL8720CM 芯片设计,内置高性 能 KM4 MCU,并包含多种外设:UART,SPI,I2C,SDIO,GPIO 等。 模块支持 802.11 b/g/n 的 Wi-Fi 无线标准和蓝牙标准协议,具有大容量存储 空间(FLASH:2MB、ROM:384KB)(FLASH 为外挂,最大可支持 128MB)、运行 空间(SRAM:256KB+PSRAM:4MB)。 1.2 应用 ➢家庭自动化 ➢家电控制 ➢安防系统 ➢智能能源 ➢互联网网关 ➢工业控制 ➢智能插座 ➢传感网络节点 ➢智能玩具 TEL: 0755-86329829 FAX: 0755-86329413 ADD: 深圳市南山区高新园科技南一道创维大厦 C 座 601 室 WEB: www.szrfstar.com Shenzhen RF-star Technology Co.,Ltd. 1.3 方框图 图 1-1 方框图 TEL: 0755-86329829 FAX: 0755-86329413 ADD: 深圳市南山区高新园科技南一道创维大厦 C 座 601 室 WEB: www.szrfstar.com Shenzhen RF-star Technology Co.,Ltd. 二、 技术参数 2.1 基本参数 参数 天线类型 PCB 板载天线 工作电压 3.3±0.3V 工作温度 -20 ~ +85 ℃ 存储温度 -55 ~ +125 ℃ 封装方式 SMT(邮票半孔) 2.2 WiFi 参数 工作频率 2.412-2.484GHz WiFi 标准 802.11 b/g/n 发射功率(典型值) 11b(11Mbps@CCK): 17.0dBm 11g(54Mbps@OFDM): 15.0dBm 11n(72Mbps@MCS7): 13.0dBm 接收灵敏度(典型值) 11b(11Mbps@CCK): -86dBm 11g(54Mbps@OFDM): -73dBm 11n(72Mbps@MCS7): -69dBm 加密方式 WPA/WPA2 2.3 Bluetooth 参数 工作频率 2.402-2.480GHz Bluetooth 标准 BT4.2 无线协议 PHY、SM、ATT、GAP、 GATT 发射功率(典型值) 4.5dBm 接收灵敏度(典型值) -96 dBm TEL: 0755-86329829 FAX: 0755-86329413 ADD: 深圳市南山区高新园科技南一道创维大厦 C 座 601 室 WEB: www.szrfstar.com Shenzhen RF-star Technology Co.,Ltd. 三、 模块尺寸及定义 3.1 尺寸 图 3-1 模块尺寸图 3.2 引脚图 图 3-2 模块引脚图 TEL: 0755-86329829 FAX: 0755-86329413 ADD: 深圳市南山区高新园科技南一道创维大厦 C 座 601 室 WEB: www.szrfstar.com Shenzhen RF-star Technology Co.,Ltd. 3.3 引脚分配表 模块管脚 功能 备注 1 RFOUT 射频信号输出引脚 2 GND 地信号 3 GND 地信号 4 VCC 3.3V 电源输入 5 GPIOA_0 GPIO 引脚,复用功能参考引脚复用表 6 GPIOA_1 GPIO 引脚,复用功能参考引脚复用表 7 GPIOA_2 GPIO 引脚,复用功能参考引脚复用表 8 GPIOA_3 GPIO 引脚,复用功能参考引脚复用表 9 GPIOA_4 GPIO 引脚,复用功能参考引脚复用表 10 NC NC 11 CHIP_EN 芯片使能脚,可用于复位(低电平有效,内部已上拉 10K) 12 GPIOA_13 GPIO 引脚,复用功能参考引脚复用表 13 NC NC 14 NC NC 15 NC NC 16 GPIOA_14 GPIO 引脚,复用功能参考引脚复用表 17 NC NC 18 GND 地信号 19 VCC 3.3V 电源输入 20 NC NC 21 NC NC 22 NC NC 23 NC NC 24 NC NC 25 GPIOA_17 GPIO 引脚,复用功能参考引脚复用表 26 GPIOA_18 GPIO 引脚,复用功能参考引脚复用表 27 GPIOA_19 GPIO 引脚,复用功能参考引脚复用表 28 GPIOA_20 GPIO 引脚,复用功能参考引脚复用表 29 GPIOA_23 GPIO 引脚,复用功能参考引脚复用表 30 GPIOA_15 GPIO 引脚,复用功能参考引脚复用表 31 GPIOA_16 GPIO 引脚,复用功能参考引脚复用表 32 NC NC 33 NC NC 34 GND 信号地 表 3-1 引脚分配表 TEL: 0755-86329829 FAX: 0755-86329413 ADD: 深圳市南山区高新园科技南一道创维大厦 C 座 601 室 WEB: www.szrfstar.com Shenzhen RF-star Technology Co.,Ltd. 注: 1、 CHIP_EN 是模块硬件复位引脚,不清除 WiFi 配网信息。 2、 CHIP_EN 引脚如果不使用保持悬空,其他引脚不使用需要保持悬空。 3、 PIN30、31(GPIOA_15、GPIOA_16)引脚为模块下载程序、调试 LOG 信息输入输出 口。 4、 PIN6(GPIOA_1)作为 Download 辅助引脚,需短接 3.3v 上电进入 Download mode。 3.4 引脚复用表 PIN name JTAG UART Group SPI Group I2C Group PCM Group GPIOA_0 JTAG_CLK UART1_RX PWM0 GPIOA_1 JTAG_TMS UART1_TX PWM1 GPIOA_2 JTAG_TDO UART1_RX SPI_CSn I2C_SCL PWM2 GPIOA_3 JTAG_TDI UART1_TX SPI_SCL I2C_SDA PWM3 GPIOA_4 JTAG_TRST UART1_CTS SPI_MOSI SDIO Group PWM4 GPIOA_13 UART0_ RX PWM7 GPIOA_14 UART0_TX PWM2 SDIO_INT GPIOA_15 UART2_ RX SPI_CSn I2C_SCL PWM3 SD_D2 GPIOA_16 UART2_TX SPI_SCL I2C_SDA PWM4 SD_D3 GPIOA_17 PWM5 SD_CMD GPIOA_18 PWM6 SD_CLK GPIOA_19 UART2_CTS SPI_MOSI I2C_SCL PWM7 SD_D0 GPIOA_20 UART2_RTS SPI_MISO I2C_SDA PWM0 SD_D1 GPIOA_23 PWM7 表 3-2 引脚复用表 TEL: 0755-86329829 FAX: 0755-86329413 ADD: 深圳市南山区高新园科技南一道创维大厦 C 座 601 室 WEB: www.szrfstar.com Shenzhen RF-star Technology Co.,Ltd. 四、 硬件设计注意事项 1、请检查供电电源,确保在推荐供电电压之间,如超过最大值会造成模块永 久性损坏;请检查电源稳定性,电压不能大幅频繁波动; 2、在针对模块设计供电电路时,往往推荐保留30%以上余量,有利于整机长 期稳定地工作;模块应尽量远离电源、变压器、高频走线等电磁干扰较大的部分; 3、高频数字走线、高频模拟走线、电源走线必须避开模块下方,若实在不得 已需要经过模块下方,假设模块焊接在 Top Layer,在模块接触部分的 Top Layer 铺地铜(全部铺铜并良好接地),必须靠近模块数字部分并走线在Bottom Layer; 4、假设模块焊接或放置在Top Layer,在Bottom Layer或者其他层随意走线也是 错误的,会在不同程度影响模块的杂散以及接收灵敏度; 5、假设模块周围有存在较大电磁干扰的器件也会极大影响模块的性能,跟据 干扰的强度建议适当远离模块,若情况允许可以做适当的隔离与屏蔽; 6、假设模块周围有存在较大电磁干扰的走线(高频数字、高频模拟、电源走 线)也会极大影响模块的性能,跟据干扰的强度建议适当远离模块,若情况允许 可以做适当的隔离与屏蔽; 7、通信线若使用5V电平,必须使用电平转换电路; 8、尽量远离部分物理层亦为2.4 GHz频段的TTL 协议,例如:USB3.0。 9、模块天线布局请参考下图。天线的放置直接影响天线的辐射效率,建议客 户在实际的产品上在进行一次天线调试,黄色区域为keep out ,距离建议大于 10 mm: 图 4. 布局建议 TEL: 0755-86329829 FAX: 0755-86329413 ADD: 深圳市南山区高新园科技南一道创维大厦 C 座 601 室 WEB: www.szrfstar.com Shenzhen RF-star Technology Co.,Ltd. 五、 回流焊条件 1、加热方法:常规对流或 IR 对流; 2、允许回流焊次数:2 次,基于以下回流焊(条件)(见图 5); 3、温度曲线:回流焊应按照下列温度曲线(见图 5 ); 4、最高温度:245°C。 图 5. 部件的焊接耐热性温度曲线(焊接点) 六、 静电放电警示 模块会因静电释放而被损坏,RF-star 建议所有模块应在以下 3 个预防措 施下处理: 1、必须遵循防静电措施,不可以裸手拿模块。 2、模块必须放置在能够预防静电的放置区。 3、在产品设计时应该考虑高电压输入或者高频输入处的防静电电路。 静电可能导致的结果为细微的性能下降到整个设备的故障。由于非常小的参 数变化都可能导致设备不符合其认证要求的值限,从而模块会更容易受到损害。 TEL: 0755-86329829 FAX: 0755-86329413 ADD: 深圳市南山区高新园科技南一道创维大厦 C 座 601 室 WEB: www.szrfstar.com Shenzhen RF-star Technology Co.,Ltd. 附录:版本记录 版本 时间 作者 说明 1.0 2021-07-28 Aiden 初版 ⚫ 联系我们 深圳市信驰达科技有限公司 Shenzhen RF-star Technology Co., Ltd. Tel(Sales):0755–8632 9829 Tel(FAE):0755-3695 3756 E-mail:sales@szrfstar.com Web: www.szrfstar.com 地址:深圳市南山区高新园科技南一道创维大厦 C 座 601 室 Add:Room 601,Block C,Skyworth Building,Nanshan High-Tech Park,Shenzhen. TEL: 0755-86329829 FAX: 0755-86329413 ADD: 深圳市南山区高新园科技南一道创维大厦 C 座 601 室 WEB: www.szrfstar.com Shenzhen RF-star Technology Co.,Ltd. Wi-Fi 透传模组 RF-WM-20CMB1 用户手册 深圳市信驰达科技有限公司 更新日期:2022 年 11 月 09日 Shenzhen RF-star Technology Co.,Ltd. 目录  模块介绍 ...................................................................................................................................................3  功能介绍 .............................................................................................................................................. 3  尺寸与引脚图 ....................................................................................................................................... 3  模块操作 ...................................................................................................................................................6  默认参数配置 ....................................................................................................................................... 6  模块使用 .............................................................................................................................................. 6  AT命令 ......................................................................................................................................................8  说明 ......................................................................................................................................................8  命令表 .................................................................................................................................................. 9  版本更新记录 ......................................................................................................................................... 12  联系我们 .................................................................................................................................................12 RF-WM-20CMB1 用户手册_20221109 2 Shenzhen RF-star Technology Co.,Ltd.  模块介绍 功能介绍 该透传软件具有两种操作模式:AT 命令模式和串口数据透传模式;AT 命令模式可以通 过串口 AT 命令对模块进行各种参数配置(具体操作命令详见“AT命令”章节),通过简单的 AT 命令配置后,数据透传模式可以实现把串口数据透明传输到指定的网络设备。模块支持 802.11 b/g/n 无线标准,支持 Station、AP 和 Station + AP 模式。 集成了 TCP/IP 协议及应用的 RF-WM-20CMB1 模块,可用于物联网应用,如:家庭自 动化,家电控制,安防系统,智能能源,互联网网关,工业控制,智能插座,仪表计量,传 感网络节点,智能玩具等等。 尺寸与引脚图 图 1 尺寸图 RF-WM-20CMB1 用户手册_20221109 3 Shenzhen RF-star Technology Co.,Ltd. 图 2 引脚图 表 1. 模块引脚定义表 引脚序号 功能 备注 1 RFOUT 射频信号输出引脚 2~3 GND 地信号 4 VCC 3.3V电源输入 5 GPIOA_0 GPIO引脚, JTAG CLK 6 GPIOA_1 GPIO引脚, JTAG TMS 7 GPIOA_2 GPIO引脚, JTAG TDO 8 GPIOA_3 GPIO引脚, JTAG TDI 9 GPIOA_4 GPIO引脚, JTAG TRST 10 NC 不连接 11 CHIP_EN 芯片使能脚,可用于复位,具体操作参考最小系统 12 GPIOA_13 GPIO引脚,透传UART RX 13 ~ 15 NC 不连接 16 GPIOA_14 GPIO引脚,透传UART TX 17 NC 不连接 RF-WM-20CMB1 用户手册_20221109 4 Shenzhen RF-star Technology Co.,Ltd. 18 GND 地信号 19 VCC 3.3V电源输入 20 ~ 24 NC 不连接 25 GPIOA_17 GPIO引脚 26 GPIOA_18 GPIO引脚 27 GPIOA_19 GPIO引脚 28 GPIOA_20 GPIO引脚 29 GPIOA_23 GPIO引脚 30 GPIOA_15 GPIO引脚,LOG UART RX 31 GPIOA_16 GPIO引脚,LOG UART TX 32 ~ 33 NC 不连接 34 GND 信号地 RF-WM-20CMB1 用户手册_20221109 5 Shenzhen RF-star Technology Co.,Ltd.  模块操作 默认参数配置 1、启动模式预设:AP 模式启动; 2、AP 模式预设网络 SSID:RF-WM-8720-Ap; 3、AP 模式预设密码:123456789; 4、串口预设配置:波特率 115200,数据位 8,校验位无,结束位 1; 5、Socket 预设配置:UDP Server 端,端口 5000。 模块使用 图 3 模块接线图  AP 模式启动操作步骤 1、模块按照接线图接线,并通过 USB 转串口工具连接到电脑; 2、在电脑上打开串口工具,配置好串口参数(115200-8-N-1)并打开串口; 3、模块首次上电,默认进入 AP 模式(AP 模式和 STA 模式切换可以参考 “AT#APSTA” 命令),通过电脑发送串口数据“+++”,让模块进入 AT 命令模式,成功进入 AT 命令 模式返回 “OK↲ ”,之后可以使用 AT 命令对模块进行配置; 4、在 AT 命令模式下,使用 “AT#APID” 和 “AT#APSec” 配置热点的 SSID 和密码并保 存,之后模块以 AP 启动,建立热点; 5、在 AT 命令模式,使用 “AT#NWK↲ ”查询模块网络信息(具体参数说明请参考“AT 命 令”章节的“命令表”),可以获取模块的 I P地址等信息; 6、在 AT 命令模式,使用 “AT#Socket” 查询并设置 socket 信息(具体参数说明请参考 RF-WM-20CMB1 用户手册_20221109 6 Shenzhen RF-star Technology Co.,Ltd. “AT 命令”章节的“命令表”); 7、打开智能手机或者笔记本电脑,根据步骤4的热点信息连接到模块,在智能手机或者笔 记本电脑上打开 socket 工具,根据f步骤的设置建立连接,模块的默认配置为 UDP Server,端口为 5000; 8、手机或者笔记本电脑可以直接发送数据到模块,模块接收到数据会从串口打印出来; 9、模块要发数据给手机或者笔记本电脑,需从 AT 命令模式退出,返回到数据透传模式 (使用 “AT#Exit↲ ”可以从 AT 命令模式退出到数据透传模式)。  STA 模式联网操作步骤 1、模块按照接线图接线,并通过 USB 转串口工具连接到电脑; 2、在电脑上打开串口工具,配置好串口参数(115200-8-N-1)并打开串口; 3、模块首次上电,默认进入 A P模式( AP 模式和 STA 模式切换可以参考 “AT#APSTA” 命令),通过电脑发送串口数据 “+++”,让模块进入 AT 命令模式,成功进入 AT 命令 模式返回 “OK↲ ”,之后可以使用 AT 命令对模块进行配置; 4、在 AT 命令模式下,使用 “AT#StaID” 和 “AT#StaSec” 配置连接到指定路由器;或者 使用 “AT#SCAN↲ ”扫描附近热点,然后使用 “AT#Connect” 命令连接指定路由器(具 体用法请参考“AT命令”章节的“命令表”说明); 5、配置完成后,模块将会自动连接路由器; 6、在 AT命令模式,使用 “AT#NWK↲ ”查询模块网络信息(具体参数说明请参考 “AT命 令”章节的“命令表”),可以获取模块的 IP 地址等信息; 7、在 AT命令模式,使用 “AT#Socket” 查询并设置 socket 信息(具体参数说明请参考 “AT命令”章节的“命令表”); 8、笔记本电脑或智能手机(笔记本电脑或智能手机与模块需在同一个网络中)打开 socket工具,根据步骤7的设置建立连接,模块的默认配置为 UDP Server,端口为 5000; 9、连接成功后,手机或者笔记本电脑可以直接发送数据到模块,模块接收到数据会从串 口打印出来; 10、模块要发数据给手机或者笔记本电脑,需从AT命令模式退出,回到数据透传模式 (使用 “AT#Exit↲ ”可以从AT命令模式退出到数据透传模式)。  恢复出厂设置操作 在AT命令模式下,使用 “AT#Reset↲ ”恢复出厂设置,恢复出厂设置之后,模块会重新 启动。 RF-WM-20CMB1 用户手册_20221109 7 Shenzhen RF-star Technology Co.,Ltd.  AT 命令 说明 1、RF-WM-20CMB1模块提供两种工作模式,分别为数据透传模式和 AT 命令模式;模块 上电或复位后,将自动进入透传模式。从串口发送 “+++”,模块接收到后返回 “OK↲ ” 表示成功进入AT 命令模式;AT命令模式下,从串口发送 “AT#Exit↲ ”,模块接收后返 回 “OK↲ ”表示成功退出 AT 命令模式。 2、串口默认参数:115200-8-N-1:波特率115200、8 位数据长度、无奇偶校验、1 位停 止位。 3、AT 命令格式:“AT#Uart” + “回车”,不带参数表示查询参数,带参数表示配置;在没 有特别说明的情况下,AT 命令中的字母不分大小写;具体格式说明如下: AT命令起始符:AT命令所有命令都要以 “AT” 字符开头,大小写均可; 命令分隔符:“AT”起始字符与命令类型的分隔符,固定为 “#” 字符; AT命令类型:AT命令类型,如:“Uart”、“Socket”,大小写均可; 参数分隔符:用于分隔命令类型与配置参数或分隔多个配置参数,固定为一个空格键; 参数起始符:配置参数起始符,表示该配置参数的开始字符,固定为 “-”; 参数标识符:表示该配置参数的含义,不同的配置参数该标识符会不同,大小写均可, 详情参考命令表各命令参数描述; 配置参数:配置参数值,不同的配置参数有不同的取值范围,详情参考命令表各命令参 数描述; 命令结束符:AT命令结束符,用于表示该命令结束,固定为回车换行符“↲ ”(\r\n); RF-WM-20CMB1 用户手册_20221109 8 Shenzhen RF-star Technology Co.,Ltd. 命令表 表 2. AT命令表 AT命令 参数 说明 AT#Reboot 无 模块重启命令,串口返回“OK↲ ”表示模块进入重启过程; AT#Reset 无 模块所有参数恢复到出厂默认设置状态,串口返回“OK↲ ” AT#Exit 无 -b:表示波特率[支持的波 特 率 有 : 1200 、 2400 、 4800 、 9600 、 19200 、 38400 、 57600 、 115200]。 AT#Uart -d:表示数据位数[支持的 数据位数有:8、7位数据 宽度]。 -p:表示校验位[支持的校 验有:0无校验;1奇校 验;2偶校验]。 -s:表示数据结束位[支持 的停止位数有:1一位停止 位]。 AT#SMTCFG AT#StaID 无 -s:无线网络SSID[最多由 32 个 数 字 / 字 母 / 符 号 组 成]1。 返回“ERROR↲ ”表示命令错误。 之后重新启动;返回“ERROR↲ ”表示命令错误。 串口发送该命令,返回“OK↲ ”表示成功退出AT Command 模式,进入透传模式;返回“ERROR↲ ”表示命令错误。 模块串口配置与查询 “AT#Uart ↲ ” : 查 询 模 块 串 口 参 数 , 返 回 串 口 参 数 : “B115200 -D8 -P0 -S1↲ ”; 返 回 “ERROR ↲ ”表 示 命 令错 误。 “AT#Uart -b9600 -d8 -p0 -s1↲ ”:设置串口为9600波特率, 8个数据位,1个结束位,无校验位,返回“OK↲ ”表示配置 成功,之后模块重新启动;返回“ERROR↲ ”表示命令或者 参数错误。 注:配置串口成功之后,模块自动重新启动。 进入智能联网模式,通过手机APP配置模块连接指定路由 器。 STA连接热点名字的查询与设置 “AT#StaID↲ ”:查询模块STA模式保存的或者当前连接的 AP SSID,返回信息:“-SRFSTAR↲ ”表示保存或者当前连 接的热点为“RFSTAR”。返回“ERROR↲ ”表示命令错误。 “AT#StaID -sRFSTAR↲ ”:配置模块连接SSID为RFSTAR 的路由器,返回“OK↲ ”表示配置成功;返回“ERROR↲ ” 表示命令或者参数错误。 注:“AT#StaID”与“AT#StaSec”需同时使用才能连接指定 AP,两条命令不分先后顺序; AT#StaSec -k:加密密码。 STA连接热点密码的查询与设置 “AT#StaSec↲ ”:查询模块STA模式保存的或者当前连接 的AP 密码,返回信息:“-K123456789↲ ”表示保存或者当 前连接热点的密码为“123456789”;返回“ERROR↲ ”表示 命令错误。 “AT#StaSec -k123456789↲ ”:配置模块STA模式下的无 线网络密码为“123456789”,返回“OK↲ ”表示配置成功; 返回“ERROR↲ ”表示命令或者参数错误。 RF-WM-20CMB1 用户手册_20221109 9 Shenzhen RF-star Technology Co.,Ltd. 注:“AT#StaID”与“AT#StaSec”需同时使用才能连接指定 AP,两条命令不分先后顺序; AT#SCAN 无 “AT#SCAN↲ ”:扫描附近AP信息,并返回如下: “-I1 -R-64 -C11 -TWPA AES -S360WiFi↲ -I2 -R-76 -C11 -TWPA2 AES -S^_^↲ -I3 -R-80 -C6 -TWPA2 AES -SWiFi36↲ -I4 -R-80 -C11 -TWPA AES -SRF_Star↲ -I5 -R-80 -C11 -TWPA TKIP -S3200Demo↲ -I6 -R-82 -C6 -TWPA AES -SMT8919↲ ” 说明:返回了6个附近AP信息,每个信息均以回车换行符 结束,“-I1 -R-64 -C11 -TWPA AES -S360WiFi↲ ”表示:“I1”指的是扫描到的第一个AP信息;“-R-64”指的是信号强 度为-64;“-C11”指的是AP所在的信道;“-TWAP AES”指 该AP 的加 密方式为WPA加密 ;“-S360WiFi”表示 热点的 SSID。 AT#CONNECT AT#APID -I : 表 示 “AT#SCAN” 扫 描 命令返回AP信息列表的序 号,与扫描命令返回信息 中的“-I”参数一致。 -K:表示连接指定AP的密 码。 -s:AP热点的SSID[最多由 32 个 数 字 / 字 母 / 符 号 组 成]1。 “AT#Connect –I1 –K123456789↲ ”: 表示连接AP信息列 表的第一个AP(如上述AP列表第一个为“-I1 -R-64 -C11 TWPA AES -S360WiFi”),密码为123456789。 “AT#Connect –I2 –K123456789↲ ”: 表示连接AP信息列 表的第二个AP(如上述AP列表第二个为“-I2 -R-76 -C11 TWPA2 AES -S^_^”),密码为123456789。 “AT#Connect –I6 –K123456789↲ ”: 表示连接AP信息列 表的第六个AP(如上述AP列表第六个为“-I6 -R-82 -C6 TWPA AES -SMT8919”),密码为123456789。 AP热点SSID的查询与设置 “AT#APID↲ ”:查询模块AP模式的SSID,返回信息:“SRF-WM-8711-Ap↲ ”表示AP的热点信息为“RF-WM-8711Ap”,命令错误返回“ERROR↲ ” “AT#APID -sRFSTAR ↲ ” : 配 置 模 块 AP 模 式 的 SSID 为 “RFSTAR”,返回“OK↲ ”表示配置成功;返回“ERROR↲ ” 表示命令或者参数错误。 注:“AT#APID”与“AT#APSec”需同时使用才能配置AP, 不分先后顺序; AP密码的查询与设置 “AT#APSec↲ ”:查询模块AP模式的密码,返回信息:“K123456789↲ ”表示AP模式当前密码为“123456789”,命 令错误返回“ERROR↲ ” AT#APSec -k:加密密码。 “AT#APSec -k123456789↲ ”:配置模块AP模式的密码为 “123456789”,返回“OK↲ ”表示配置成功;返回“ERROR ↲ ”表示命令或者参数错误。 注:“AT#APID”与“AT#APSec”需同时使用才能配置AP, 不分先后顺序; RF-WM-20CMB1 用户手册_20221109 10 Shenzhen RF-star Technology Co.,Ltd. -c:Socket通道号[0:第0个 通道(暂只支持1个通道, 即通道0)]。 -t:Socket协议类型[0:TCP socket ; 1 : UDP socket]; AT#Socket -m:Socket 模 式 [0 : Server;1:Client]。 -a: socket IP地址[Server模 式时该地址不做处理, Client模式表示通信的对方 IP地址]。 -p:socket 端 口 [Server 模 式 表 示 本 地 建 立 server 的 端 口,Client模式表示通信对 方的socket端口]。 AT#APSTA -M:启动模式 【0】模块以STA模式启动 【1】模块以AP模式启动 Socket信息查询与设置命令 “AT#Socket ↲ ” : 查 询 模 块 Socket 的 相 关 信 息 , 包 括 socket通道号,socket协议类型,socket模式,IP地址, socket端口号,返回信息:“-C0 -T1 -M0 -A192.168.95.12 -P5000 ↲ ” 表 示 通 道 0 UDP Server , 模 块 的 IP 地 址 为 192.168.95.12 , UDP server 的 端 口 为 5000 , 返 回 “ERROR↲ ”表示命令错误。 “AT#Socket -c0 -t0 -m0 -a0.0.0.0 -p8711↲ ”:在socket通 道0上建立端口号为8711的TCP server socket。返回“OK ↲ ”表示配置成功,之后自动重启;返回“ERROR↲ ”表示 命令或者参数错误。 “AT#Socket -c0 -t1 -m0 -a0.0.0.0 -p8722↲ ”:在socket通 道0上建立端口号为8722的UDP server socket,返回“OK ↲ ”表示配置成功,之后自动重启;返回“ERROR↲ ”表示 命令或者参数错误。 “AT#Socket -c0 -t0 -m1 -a192.168.95.6 -p5001 ↲ ” : 在 socket 通 道 0 上 建 立 TCP client , 连 接 到 IP 地 址 为 192.168.95.6,端 口号 为5001 的 TCP Server, 返 回“OK ↲ ”表示配置成功,之后自动重启;返回“ERROR↲ ”表示 命令或者参数错误。 “AT#Socket -c0 -t1 -m1 -a192.168.95.6 -p5001 ↲ ” : 在 socket通道0上建立UDP client,发送数据的目标IP地址为 192.168.95.6,端口号为5001,返回“OK↲ ”表示配置成 功,之后自动重启;返回“ERROR↲ ”表示命令或者参数错 误。 模块启动模式的查询与设置 “AT#APSTA↲ ”:查询模块启动模式,返回信息“-M1↲ ”表 示当前模式为AP模式;返回信息“-M0↲ ”表示当前模式为 STA模式;命令错误返回“ERROR↲ ” “AT#APSTA -M1↲ ”:设置模块以AP模式启动,成功返回 “OK↲ ”,命令错误返回“ERROR↲ ”。 “AT#APSTA -M0↲ ”:设置模块以STA模式启动,成功返 回“OK↲ ”,命令错误返回“ERROR↲ ”。 AT#VER AT#NWK 无 查询模块当前软件版本号, 返回信息:“-V1.0.0↲ ”,命令 错误返回“ERROR↲ ”。 无 查询模块网络参数, 返回信息: “-M00:e0:4c:87:00:00 -A192.168.95.2 -G192.168.95.1 S255.255.255.0 -D0.0.0.0 ↲ ” ; “-M” 表 示 模 块 的 MAC 地 址;“-A”表示模块的IP 地址;“-G”表示默认网关地址;“-S” 表 示 网 络 的 子 网 掩 码 ; “-D” 表 示 DNS 服 务 器 。 返 回 “ERROR↲ ”表示命令错误。 注1:无线网络SSID是区分大小写的,在使用“AT#StaID”和“AT#ApID”配置参数“-s”时需注意;同样在使 用“AT#StaSec”和“AT#ApSec”配置参数“-k”时也需注意。 注2:模块未连接到网络时,连接网络输入密码错误,连接失败。 模块处于连接状态时,连接网络输入密码错误,自动连接原来的网络。 RF-WM-20CMB1 用户手册_20221109 11 Shenzhen RF-star Technology Co.,Ltd.  版本更新记录 版本号 文档日期 V1.0 2022/11/09 更新内容 第一次发布  联系我们 深圳市信驰达科技有限公司 Shenzhen RF-star Technology Co., Ltd. Tel(Sales):0755–8632 9829 Tel(FAE):0755-3695 3756 E-mail:sales@szrfstar.com Web: www.szrfstar.com 地址:深圳市南山区高新园科技南一道创维大厦 C 座 601 室 Add:Room 601,Block C,Skyworth Building,Nanshan High-Tech Park,Shenzhen. RF-WM-20CMB1 用户手册_20221109 12
RF-WM-20CMB1 价格&库存
很抱歉,暂时无法提供与“RF-WM-20CMB1”相匹配的价格&库存,您可以联系我们找货
