RF-BM-ND06
RF-BM-ND06
    RF-STAR(信驰达)
    SMD,MODULE_24x20.5mm
    nRF52840蓝牙模块 远距离 Mesh组网RF-BM-ND06
RF-BM-ND06 数据手册
Shenzhen RF-star Technology Co.,Ltd. 低功耗蓝牙模块 RF-BM-ND06 硬件规格书 深圳市信驰达科技有限公司 更新日期:2023 年04月11日 Shenzhen RF-star Technology Co.,Ltd. 目录  选型表 .......................................................................................................................................................3  nRF51系列 ...........................................................................................................................................3  nRF52系列 ...........................................................................................................................................4  概述 .......................................................................................................................................................... 5  模块参数 ...................................................................................................................................................6  模块尺寸与引脚定义 ................................................................................................................................ 7  硬件设计注意事项 .................................................................................................................................. 11  常见问题 .................................................................................................................................................12  传输距离不理想 ................................................................................................................................. 12  易损坏——异常损坏 .......................................................................................................................... 12  误码率太高 .........................................................................................................................................12  回流焊条件 ............................................................................................................................................. 12  静电放电警示 ......................................................................................................................................... 13  版本更新记录 ......................................................................................................................................... 14  联系我们 .................................................................................................................................................14 RF-BM-ND06 硬件规格书_20230411 2 Shenzhen RF-star Technology Co.,Ltd.  选型表  nRF51 系列 芯片 型号 nRF51822 nRF51802 内核 M0 M0 FLASH RAM (Byte) (KB) 256K 256K 发射 功率 (dBm) 16 16 4 4 模块型号 天线 形式 模块 尺寸 (mm) 通信 距离 (M) RF-BM-ND01 PCB 15*24.8 100 RF-BM-ND02 PCB 13.5*16.2 80 RF-BM-ND02I IPEX 13.5*16.2 150 RF-BM-ND01C PCB 15*24.8 100 RF-BM-ND02C PCB 13.5*16.2 80 RF-BM-ND02CI IPEX 13.5*16.2 80 模块照片 (点击可访问) 联系客服或业务 联系客服或业务 注: 1、通信距离为以模块最大发射功率在晴朗天气下空旷无干扰环境下测试所得最远距离。 2、点击图片可跳转至购买链接。 RF-BM-ND06 硬件规格书_20230411 3 Shenzhen RF-star Technology Co.,Ltd.  nRF52 系列 芯片 型号 内核 nRF52832 M4F nRF52810 nRF52811 M4 M4 nRF52840 M4F FLASH RAM (Byte) (KB) 512K 192K 192K 1M 发射 功率 (dBm) 64 24 24 256 模块型号 天线 形式 模块 尺寸 (mm) 通信 距离 (M) RF-BM-ND04 PCB 15*24.8 100 RF-BM-ND04I IPEX 15*24.8 100 RF-BM-ND08 PCB 15.2*11.2 80 RF-BM-ND08I IPEX 15.2*11.2 100 RF-BM-ND04C PCB 15*24.8 100 RF-BM-ND04CI IPEX 15*24.8 100 RF-BM-ND08C PCB 15.2*11.2 80 RF-BM-ND08CI IPEX 15.2*11.2 100 RF-BM-ND04A PCB 15*24.8 100 RF-BM-ND05 PCB 15*24.8 550 RF-BM-ND05I IPEX 15*24.8 550+ RF-BM-ND06 PCB 20.5*24 550 模块照片 (点击可访问) 4 联系客服或 业务 4 4 8 联系客服或 业务 注: 1、通信距离为以模块最大发射功率在晴朗天气下空旷无干扰环境下测试所得最远距离。 2、点击图片可跳转至购买链接。 RF-BM-ND06 硬件规格书_20230411 4 Shenzhen RF-star Technology Co.,Ltd.  概述 深圳信驰达蓝牙模块是低功耗蓝牙(BLE)射频 模块,可广泛应用于短距离无线通信领域。具有功耗 低、体积小、传输距离远、抗干扰能力强等特点。模 块配备高性能倒 F 天线。 RF-BM-ND06 低 功 耗 蓝 牙 模 块 , 采 用 Nordic Semiconductor 的 nRF52840 作为核心处理器。模块 运行在 2.4 GHz ISM band,GFSK 调制方式(高斯频移键控),40 频道2 MHz 的通道间隙,3 个固定的广播通道,37 个自适应自动跳频数据通道,物理层可以和经典蓝牙 RF组合成双模 设备,2 MHz 间隙能更好地防止相邻频道的干扰。宽输出功率调节 (-20 dBm~+8 dBm),96 dBm高增益接收灵敏度。 从 Nordic Semiconductor 推 出 nRF52840 单 芯 片 (SOC) 低 功 耗 蓝 牙 收 发 器 以 来 , nRF52840 就受到了市场强烈的关注。nRF52840 基于配备1 MB flash + 256 KB RAM 的 32 位 ARM® Cortex™ M4F CPU 而构建。具备丰富的模拟和数字周边产品,可以在无需 CPU 参与的情况下通过可编程周边产品互联 (PPI) 系统进行互动。灵活的 46 引脚 GPIO 映射方案 可使I/O (例如串行接口、PWM 和正弦解调器) 根据 PCB 需求指示映射到任何设备引脚。这 可实现完全的设计灵活性及引脚位置和功能。 该款模块可用于开发基于蓝牙 4.0/4.2/5(BLE低功耗蓝牙) 的消费类电子产品,手机外设 产品等,为客户产品与智能移动设备通讯提供快速的BLE解决方案。 图 1. RF-BM-ND06 原理框图 RF-BM-ND06 硬件规格书_20230411 5 Shenzhen RF-star Technology Co.,Ltd.  模块参数 表 1. RF-BM-ND06 参数 芯片型号 nRF52840-QIAA-R 工作电压 1.7 ~ 5.5 V,推荐为 3. 3 V 工作频段 2402 MHz ~ 2480 MHz 最大发射功率 -20 ~ +8 dBm ( 正常0 dBm输出 ) 接收灵敏度 -96 dBm RAM 256 KB FLASH 1 MB GPIO 数量 46 个 晶振频率 32 MHz、32.768 KHz 封装方式 SMT(邮票半孔) 工作温度 - 40 ℃ ~ + 85 ℃ 储存温度 - 40 ℃ ~ + 125 ℃ RF-BM-ND06 硬件规格书_20230411 6 Shenzhen RF-star Technology Co.,Ltd.  模块尺寸与引脚定义 图 2. RF-BM-ND06 尺寸图 图 3. RF-BM-ND06 引脚图(TOP VIEW) RF-BM-ND06 硬件规格书_20230411 7 Shenzhen RF-star Technology Co.,Ltd. 表 2. RF-BM-ND06 模块引脚定义 引脚序号 名称 功能 备注 P0.12 Digital I/O GPIO TRACEDATA1 Trace data Trace buffer TRACEDATA[1] 2 VCC - 1.7V - 3.6V 3 VDD_HV - 2.5V - 5.5V 4 VDD_USB - 4.35V–5.5V 5 D- Digital I/O USB D- 6 D+ Digital I/O USB D+ 7 P0.13 Digital I/O GPIO 8 P0.14 Digital I/O GPIO 9 P0.15 Digital I/O GPIO 10 P0.16 Digital I/O GPIO 11 P0.17 Digital I/O GPIO P0.18 Digital I/O GPIO、QSPI_CSN nRESET — Configurable as pin RESET 13 P0.19 Digital I/O GPIO、QSPI_SCK 14 P0.20 Digital I/O GPIO 15 P0.21 Digital I/O GPIO、QSPI 16 P0.22 Digital I/O GPIO、QSPI 17 P0.23 Digital I/O GPIO、QSPI 18 P0.24 Digital I/O GPIO 19 P0.25 Digital I/O GPIO P1.00 Digital I/O GPIO、QSPI TRACEDATA0 Trace data Trace buffer TRACEDATA[0] 21 SWDIO - 仿真烧录脚 22 SWCLK - 仿真烧录脚 P0.09 Digital I/O Standard drive, low frequency I/O only NFC1 NFC input NFC antenna connection P0.10 Digital I/O Standard drive, low frequency I/O only NFC2 NFC input NFC antenna connection 25 P1.01 Digital I/O GPIO, Standard drive, low frequency I/O only 26 P1.02 Digital I/O GPIO, Standard drive, low frequency I/O only 1 12 20 23 24 RF-BM-ND06 硬件规格书_20230411 8 Shenzhen RF-star Technology Co.,Ltd. 27 P1.03 Digital I/O GPIO, Standard drive, low frequency I/O only 28 P1.04 Digital I/O GPIO, Standard drive, low frequency I/O only 29 P1.05 Digital I/O GPIO, Standard drive, low frequency I/O only 30 P1.06 Digital I/O GPIO, Standard drive, low frequency I/O only 31 RF_OUT - 32 P1.07 Digital I/O GPIO, Standard drive, low frequency I/O only 33 P1.10 Digital I/O GPIO, Standard drive, low frequency I/O only 34 P1.11 Digital I/O GPIO, Standard drive, low frequency I/O only 35 P1.12 Digital I/O GPIO, Standard drive, low frequency I/O only 36 P1.13 Digital I/O GPIO, Standard drive, low frequency I/O only 37 P1.14 Digital I/O GPIO, Standard drive, low frequency I/O only 38 P1.15 Digital I/O GPIO, Standard drive, low frequency I/O only P0.03 Digital I/O GPIO, Standard drive, low frequency I/O only AIN1 Analog input P0.02 Digital I/O AIN0 Analog input P0.28 Digital I/O AIN4 Analog input P0.29 Digital I/O AIN5 Analog input P0.30 Digital I/O AIN6 Analog input P0.31 Digital I/O AIN7 Analog input 45 P0.26 Digital I/O GPIO 46 P0.27 Digital I/O GPIO P0.04 Digital I/O GPIO AIN2 Analog input P0.05 Digital I/O AIN3 Analog input P0.06 Digital I/O GPIO P0.07 Digital I/O GPIO TRACECLK Trace clock Trace buffer clock P0.08 Digital I/O GPIO 39 40 41 42 43 44 47 48 49 50 51 RF-BM-ND06 硬件规格书_20230411 GPIO, Standard drive, low frequency I/O only GPIO, Standard drive, low frequency I/O only GPIO, Standard drive, low frequency I/O only GPIO, Standard drive, low frequency I/O only GPIO, Standard drive, low frequency I/O only GPIO 9 Shenzhen RF-star Technology Co.,Ltd. 52 53 54 55 ~ 63 P1.08 Digital I/O GPIO P1.09 Digital I/O GPIO TRACEDATA3 Trace data Trace buffer TRACEDATA[3] P0.11 Digital I/O GPIO TRACEDATA2 Trace data Trace buffer TRACEDATA[2] GND - RF-BM-ND06 硬件规格书_20230411 10 Shenzhen RF-star Technology Co.,Ltd.  硬件设计注意事项 1、推荐使用直流稳压电源对模块进行供电,电源纹波系数尽量小,模块需可靠接地;请 注意电源正负极的正确连接,如反接可能会导致模块永久性损坏; 2、请检查供电电源,确保在推荐供电电压之间,如超过最大值会造成模块永久性损坏; 请检查电源稳定性,电压不能大幅频繁波动; 3、在针对模块设计供电电路时,往往推荐保留 30% 以上余量,有利于整机长期稳定地 工作;模块应尽量远离电源、变压器、高频走线等电磁干扰较大的部分; 4、高频数字走线、高频模拟走线、电源走线必须避开模块下方,若实在不得已需要经过 模块下方,假设模块焊接在 Top Layer,在模块接触部分的 Top Layer 铺地铜(全部铺铜并良 好接地),必须靠近模块数字部分并走线在 Bottom Layer; 5、假设模块焊接或放置在 Top Layer,在 Bottom Layer 或者其他层随意走线也是错误的, 会在不同程度影响模块的杂散以及接收灵敏度; 6、假设模块周围有存在较大电磁干扰的器件也会极大影响模块的性能,跟据干扰的强度 建议适当远离模块,若情况允许可以做适当的隔离与屏蔽; 7、假设模块周围有存在较大电磁干扰的走线(高频数字、高频模拟、电源走线)也会极 大影响模块的性能,跟据干扰的强度建议适当远离模块,若情况允许可以做适当的隔离与屏 蔽; 8、通信线若使用5V电平, 必须使用电平转换电路; 9、尽量远离部分物理层亦为 2.4 GHz 频段的TTL 协议,例如:USB3.0。 10、模块天线布局请参考下图: 图 4. 布局建议 RF-BM-ND06 硬件规格书_20230411 11 Shenzhen RF-star Technology Co.,Ltd.  常见问题  传输距离不理想 1、当存在直线通信障碍时,通信距离会相应的衰减;温度、湿度,同频干扰,会导致通信 丢包率提高;地面吸收、反射无线电波,靠近地面测试效果较差; 2、海水具有极强的吸收无线电波能力,故海边测试效果差; 3、天线附近有金属物体,或放置于金属壳内,信号衰减会非常严重; 4、功率寄存器设置错误、空中速率设置过高(空中速率越高,距离越近); 5、室温下电源低压低于推荐值,电压越低发功率越小; 6、使用天线与模块匹配程度较差或天线本身品质问题。  易损坏——异常损坏 1、请检查供电电源,确保在推荐供电电压之间,如超过最大值会造成模块永久性损坏; 请检查电源稳定性,电压不能大幅频繁波动; 2、请确保安装使用过程防静电操作,高频器件静电敏感性; 3、请确保安装使用过程湿度不宜过高,部分元件为湿度敏感器件;如果没有特殊需求不建 议在过高、过低温度下使用。  误码率太高 1、附近有同频信号干扰,远离干扰源或者修改频率、信道避开干扰; 2、电源不理想也可能造成乱码,务必保证电源的可靠性; 3、延长线、馈线品质差或太长,也会造成误码率偏高。  回流焊条件 1、加热方法:常规对流或 IR 对流; 2、允许回流焊次数:2 次,基于以下回流焊(条件)(见下图 ); 3、温度曲线:回流焊应按照下列温度曲线(见下图); 4、最高温度:245°C。 RF-BM-ND06 硬件规格书_20230411 12 Shenzhen RF-star Technology Co.,Ltd. 图 5. 部件的焊接耐热性温度曲线(焊接点)  静电放电警示 模块会因静电释放而被损坏,RF-star 建议所有模块应在以下 3 个预防措施下处理: 1、必须遵循防静电措施,不可以裸手拿模块。 2、模块必须放置在能够预防静电的放置区。 3、在产品设计时应该考虑高电压输入或者高频输入处的防静电电路。 静电可能导致的结果为细微的性能下降到整个设备的故障。由于非常小的参数变化都可 能导致设备不符合其认证要求的值限,从而模块会更容易受到损害。 RF-BM-ND06 硬件规格书_20230411 13 Shenzhen RF-star Technology Co.,Ltd.  版本更新记录 文档日期 更新内容 2018/10/26 第一次发布 2018/12/06 更正一些叙述上的错误 更换封装尺寸图风格 2020/01/13 添加模块背面照片 添加原理框图 添加模块选型表 2020/04/26 更新模块选型表 2020/05/15 更新模块选型表 2023/04/11 更新模块引脚定义表  联系我们 深圳市信驰达科技有限公司 Shenzhen RF-star Technology Co., Ltd. Tel(Sales):0755–8632 9829 Tel(FAE):0755-3695 3756 E-mail:sales@szrfstar.com Web: www.szrfstar.com 地址:深圳市南山区高新园科技南一道创维大厦 C 座 601 室 Add:Room 601,Block C,Skyworth Building,Nanshan High-Tech Park,Shenzhen. RF-BM-ND06 硬件规格书_20230411 14
RF-BM-ND06
1. 物料型号:型号为LM358P 2. 器件简介:LM358P是一款双运算放大器集成电路,广泛应用于模拟信号处理领域。 3. 引脚分配:LM358P共有8个引脚,具体分配如下: - 1:非反相输入端 - 2:反相输入端 - 3:输出端 - 4:V+供电 - 5:GND供电 - 6:反相输入端 - 7:输出端 - 8:V+供电 4. 参数特性:LM358P的主要参数包括: - 电源电压范围:3V-32V - 增益带宽积:1MHz - 输入偏置电流:最大100nA - 工作温度范围:-40℃-125℃ 5. 功能详解:LM358P具有差分放大、电压跟随、信号滤波等多种功能。 6. 应用信息:LM358P可用于音频放大、传感器信号调理、仪器放大器等应用。 7. 封装信息:LM358P提供SOIC-8、DIP-8等多种封装形式。
RF-BM-ND06 价格&库存
很抱歉,暂时无法提供与“RF-BM-ND06”相匹配的价格&库存,您可以联系我们找货
