SN74HC112N
SN74HC112N
    XBLW(芯伯乐)
    DIP16
    双路负边触发JK触发器,工作电压 2-6V,静态电流1uA
SN74HC112N 数据手册
XBLW SN74HC/HCT112 General Description The SN74HC/HCT112 is a dual negative-edge triggered JK flip-flop. Features  Supply voltage range: SN74HC112: 2~6V SN74HCT112: 4.5~5.5V  Input levels: SN74HC112: CMOS level SN74HCT112: TTL level  Temperature range:-40℃ to +125℃  Packaging information: DIP16/SOP16/TSSOP16 Ordering Information Product Model XBLW SN74HC112N XBLW SN74HC112DTR XBLW SN74HC112TDTR XBLW SN74HCT112N XBLW SN74HCT112DTR XBLW SN74HCT112TDTR Package Type DIP-16 SOP-16 TSSOP-16 DIP-16 SOP-16 TSSOP-16 Marking 74HC112N 74HC112 74HC112 74HCT112N 74HCT112 74HCT112 Packing Tube Tape Tape Tube Tape Tape Packing Qty 1000Pcs/Box 2500Pcs/Reel 3000Pcs/Reel 1000Pcs/Box 2500Pcs/Reel 3000Pcs/Reel Block Diagram And Pin Description Block Diagram Figure 1. Functional diagram Pin Configurations XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 1 / 14 XBLW SN74HC/HCT112 Pin Description Pin No. Pin Name 1 1CP 1K 1J 2 3 4 Description clock input (HIGH-to-LOW; edge-triggered) data input data input set input (active LOW) 1S 1Q 5 6 1Q 7 2Q GND 2Q 8 9 10 11 12 2S 2J 2K 13 2CP 14 2R true flip-flop output complement flip-flop output complement flip-flop output ground (0V) true flip-flop output set input (active LOW) data input data input clock input (HIGH-to-LOW; edge-triggered) reset input (active LOW) — 15 reset input (active LOW) 1R VCC 16 Function Table supply voltage Inputs S L H L H R H L L H H H H H H H ↓ ↓ ↓ ↓ H H H H= High Level (Steady State) CP X X X Outputs J K X X X L X X X L H L H L Q Q H L L H H(Note 1) H(Note 1) No Change L L H H H Toggle H X X No Change L= Low Level (Steady State) X= Don’t Care ↓= High-to-Low Transition NOTE 1: Output states unpredictable if both S and R go High simultaneously after both being low at the sametime XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 2 / 14 XBLW SN74HC/HCT112 Electrical Parameter Absolute Maximum Ratings (Tamb=25℃, All voltage referenced to Vss, unless otherwise specified) Parameter supply voltage Symbol Conditions Max. +7 Unit VCC ground current IGND - -50 - mA input clamping current IIK VI < -0.5V or VI > VCC+0.5V - ±20 mA output clamping current IOK VO < -0.5V or VO > VCC+0.5V - ±20 mA output current IO -0.5V < VO < VCC+0.5V ±25 mA storage temperature Tstg - -65 +150 ℃ soldering temperature Min. -0.5 - 10s TL DIP SOP/TSSOP V 245 260 ℃ Electrical Characteristics DC Characteristics 1 (Tamb=-40℃ to +85℃, voltages are referenced to VSS (ground=0V), unless otherwise specified.) Parameter Symbol VCC Conditions 2.0V - Min. Typ. Max. Unit - V SN74HC112 HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VIH 4.5V 4.2 3.2 - - - V 0.8 0.5 V - 2.1 1.35 V 1.9 2.8 1.8 V 2.0V IO=-20uA 2.0 V 4.5V IO=-20uA 4.4 4.5 - 6.0V IO=-20uA 5.9 6.0 4.5V IO=-4.0mA 3.84 4.32 6.0V IO=-5.2mA 5.34 5.81 4.5V 6.0V VOL - V 2.0V VOH 1.2 2.4 - 6.0V VIL 1.5 3.15 - 2.0V IO=20uA 4.5V - IO=20uA 6.0V - IO=20uA 4.5V - IO=4.0mA - - V V - V 0.1 V 0 V 0 0.1 V 0 0.1 V 0.15 0.33 V 0.33 V 6.0V IO=5.2mA - 0.16 input leakage current II 6.0V VI=VCC or GND - - ±1 uA supply current ICC 6.0V VI=VCC or GND;IO=0A - - 80 uA - 2.0 1.6 - V - - 1.2 0.8 V IO=-20uA 4.4 4.5 V IO=-4.0mA 3.84 4.32 - SN74HCT112 HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH XBLWversion1.0 4.5~ 5.5V 4.5~ 5.5V 4.5V www.xinboleic.com Technical Support:4009682003 - V 3 / 14 XBLW SN74HC/HCT112 LOW-level output voltage VOL 4.5V input leakage current II supply current additional supply current 0 0.1 V - 0.15 0.33 V VI=VCC or GND - - ±1 uA VI=VCC or GND;IO=0A One input at VI=VCC-2.1V; Other inputs at VCC or GND; IO=0A - - 80 uA - - 135 uA IO=20uA IO=4.0mA 5.5V ICC 6.0V ΔICC 4.5~ 5.5V - DC Characteristics 2 (Tamb=-40℃ to +125℃, voltages are referenced to VSS (ground=0V), unless otherwise specified.) Parameter Symbol VCC Conditions 2.0V - Min. Typ. Max. Unit 1.5 - - V - - V - 0.5 V V 1.35 V V V SN74HC112 HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VIH 4.5V 6.0V - 4.2 - - - - - - 2.0V IO=-20uA 1.9 - 1.8 4.5V - - - - - - - - V - 0.1 V V 0.1 V 0.1 V 0.4 V V 2.0V VIL 4.5V 6.0V VOH VOL - 3.15 IO=-20uA 4.4 6.0V IO=-20uA 5.9 4.5V IO=-4.0mA 3.7 6.0V IO=-5.2mA 5.2 2.0V IO=20uA 4.5V - - IO=20uA 6.0V - - IO=20uA 4.5V - - IO=4.0mA - - 6.0V IO=5.2mA - - 0.4 V V input leakage current II 6.0V VI=VCC or GND - - ±1 uA supply current ICC 6.0V VI=VCC or GND;IO=0A - - 160 uA - 2.0 - - V - - - 0.8 V IO=-20uA 4.4 - V IO=-4.0mA 3.7 - V IO=20uA 0.1 V V SN74HCT112 4.5~ 5.5V 4.5~ 5.5V HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH 4.5V LOW-level output voltage VOL 4.5V input leakage current II supply current additional supply current XBLWversion1.0 - - IO=4.0mA - - 0.4 5.5V VI=VCC or GND - - ±1 uA ICC 6.0V - - 160 uA ΔICC 4.5~ 5.5V VI=VCC or GND;IO=0A One input at VI=VCC-2.1V; Other inputs at VCC or GND; IO=0A - - 147 uA www.xinboleic.com Technical Support:4009682003 4 / 14 XBLW SN74HC/HCT112 AC Characteristics 1 (Tamb=-40℃ to +85℃, VSS=0V, unless otherwise specified.) Parameter Symbol VCC Conditions Min. Typ. Max. Unit - 55 220 ns - 20 44 ns - 17 ns SN74HC112 nCP tonQ propagation delay — — nCP tonQ propagation delay tPLH, tPHL — — nR tonQ 、 nQ propagation delay — — nS tonQ 、nQ propagation delay transition time nCP HIGH or LOW pulse width — tTHL , tTLH tw — nS,nR LOW pulse width — — nR tonCP recovery time trec — — nS tonCP recovery time nJ and nK ton — CP set-up time nJ and nK ton — CP hold time maxiumum frequency XBLWversion1.0 tsu th fmax 2.0V CL=50pF 4.5V CL=50pF 5.0V CL=15pF see Figure 5 - 16 37 - 55 220 ns - 20 44 ns - 17 ns CL=50pF - 16 37 2.0V CL=50pF - 58 225 ns 4.5V CL=50pF 45 ns 5.0V CL=15pF - 21 - 18 ns 6.0V CL=50pF 17 2.0V CL=50pF - 38 - 50 295 ns 4.5V CL=50pF - 18 39 ns 5.0V CL=15pF - 15 ns 6.0V CL=50pF - 14 33 2.0V CL=50pF - 19 95 ns 4.5V CL=50pF - 7 19 ns 6.0V CL=50pF 16 ns 2.0V CL=50pF 100 6 22 - ns 4.5V CL=50pF 20 8 ns 6.0V CL=50pF - 17 6 ns 2.0V CL=50pF 100 - 22 - ns 4.5V CL=50pF 20 8 - ns 6.0V CL=50pF 17 6 - ns 2.0V CL=50pF 125 22 ns 4.5V CL=50pF 25 8 - ns 6.0V CL=50pF 2.0V CL=50pF 4.5V CL=50pF 5.0V CL=15pF 6.0V see Figure 5 see Figure 6 see Figure 6 see Figure 5 see Figure 5 see Figure 6 see Figure 6 ns ns ns ns 6.0V CL=50pF 21 6 - ns 2.0V CL=50pF 100 -19 - ns 4.5V CL=50pF 20 -7 - ns 6.0V CL=50pF 17 -6 - ns 2.0V CL=50pF 100 19 - ns see Figure 6 see Figure 5 4.5V CL=50pF 20 7 - ns 6.0V CL=50pF 17 6 - ns 2.0V CL=50pF 0 -11 - ns 4.5V CL=50pF 0 -4 - ns see Figure 5 6.0V CL=50pF 0 -3 - ns 2.0V CL=50pF 4.8 20 CL=50pF 24 60 - MHz 4.5V - MHz 5.0V CL=15pF - 66 - MHz see Figure 5 www.xinboleic.com Technical Support:4009682003 5 / 14 XBLW SN74HC/HCT112 6.0V CL=50pF 4.5V CL=50pF 28 71 - MHz - 21 44 ns - 19 - ns - 23 50 ns - 19 - ns - 22 46 ns - 19 - ns - 18 40 ns - 15 - ns SN74HCT112 nCP tonQ propagation delay — — nCP tonQ propagation delay — — nR tonQ 、 nQ propagation delay — tPLH, tPHL — nS tonQ 、nQ propagation delay transition time nCP HIGH or LOW pulse width — — tTHL, tTLH CL=15pF 4.5V CL=50pF 5.0V CL=15pF 4.5V CL=50pF 5.0V CL=15pF 4.5V CL=50pF see Figure 5 see Figure 6 see Figure 6 5.0V CL=15pF 4.5V CL=50pF see Figure 5 - 7 19 ns 4.5V CL=50pF see Figure 5 20 8 - ns 4.5V CL=50pF see Figure 6 23 10 - ns 4.5V CL=50pF see Figure 6 25 11 - ns 4.5V CL=50pF see Figure 6 25 -8 - ns tw nS,nR LOW pulse width — 5.0V see Figure 5 — nR tonCP recovery time — — nS tonCP recovery time trec nJ and nK ton — CP set-up time tsu 4.5V CL=50pF see Figure 5 20 7 - ns nJ and nK ton — CP hold time th 4.5V CL=50pF see Figure 5 0 -7 - ns maxiumum frequency fmax 4.5V CL=50pF 24 64 CL=15pF - 70 - MHz 5.0V - MHz Min. Typ. Max. Unit - - 265 ns - - 53 ns - - 45 ns - - 265 ns - - 53 ns - - 45 ns - - 270 ns - - - - - - see Figure 5 AC Characteristics 2 (Tamb=-40℃ to +125℃, VSS=0V, unless otherwise specified.) Parameter Symbol VCC Conditions SN74HC112 nCP tonQ propagation delay — — nCP tonQ propagation delay — — nR tonQ 、 nQ propagation delay tPLH, tPHL 2.0V CL=50pF 4.5V CL=50pF 6.0V CL=50pF 2.0V CL=50pF 4.5V CL=50pF 6.0V CL=50pF 2.0V CL=50pF see Figure 3 see Figure 3 see Figure 4 4.5V CL=50pF 6.0V CL=50pF nS tonQ 、nQ 2.0V CL=50pF XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 — — see Figure 4 54 ns 46 ns 235 ns 6 / 14 XBLW SN74HC/HCT112 propagation delay transition time nCP HIGH or LOW pulse width — tTHL , tTLH tw — nS,nR LOW pulse width — — nR tonCP recovery time trec 4.5V CL=50pF 6.0V CL=50pF 2.0V CL=50pF 4.5V CL=50pF 6.0V CL=50pF 2.0V CL=50pF 4.5V CL=50pF 6.0V CL=50pF 20 2.0V CL=50pF 120 4.5V CL=50pF 6.0V CL=50pF 20 2.0V CL=50pF 150 4.5V CL=50pF 6.0V CL=50pF 26 120 see Figure 3 see Figure 3 see Figure 4 see Figure 4 47 ns 40 ns 110 ns 22 ns - 19 ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - - - ns MHZ - - - - NHZ - - - - - - - - 120 24 24 30 nS tonCP recovery time 2.0V CL=50pF 4.5V CL=50pF 6.0V CL=50pF 20 nJ and nK ton — CP set-up time 2.0V CL=50pF 120 4.5V CL=50pF 6.0V CL=50pF 20 2.0V CL=50pF 0 4.5V CL=50pF 6.0V CL=50pF 0 2.0V CL=50pF 4.0 4.5V CL=50pF 6.0V CL=50pF 4.5V CL=50pF see Figure 3 - - 53 ns 4.5V CL=50pF see Figure 3 - - 60 ns 4.5V CL=50pF see Figure 4 - - 56 ns 4.5V CL=50pF see Figure 4 - - 48 Ns 4.5V CL=50pF see Figure 3 - - 22 ns 4.5V CL=50pF see Figure 3 24 - - ns 4.5V CL=50pF see Figure 4 27 - - ns 4.5V CL=50pF see Figure 4 30 - - ns — — nJ and nK ton — CP hold time maxiumum frequency tsu th fmax see Figure 4 see Figure 3 see Figure 3 see Figure 3 24 24 0 20 24 SN74HCT112 nCP tonQ propagation delay — MHZ — nCP tonQ propagation delay — — nR tonQ 、 nQ propagation delay — tPLH, tPHL — nS tonQ 、nQ propagation delay transition time nCP HIGH or LOW pulse width — — tTHL , tTLH tw nS,nR LOW pulse width — — nR tonCP recovery time XBLWversion1.0 trec www.xinboleic.com Technical Support:4009682003 7 / 14 XBLW SN74HC/HCT112 — — nS tonCP recovery time nJ and nK ton — CP set-up time nJ and nK ton — CP hold time maxiumum frequency XBLWversion1.0 4.5V CL=50pF see Figure 4 30 - - ns tsu 4.5V CL=50pF see Figure 3 24 - - ns th 4.5V CL=50pF see Figure 3 0 - - ns fmax 4.5V CL=50pF see Figure 3 20 - - MHZ www.xinboleic.com Technical Support:4009682003 8 / 14 XBLW SN74HC/HCT112 Testing Circuit AC Testing Circuit Figure 2 Load circuit CL includes probe and jig capacitance. AC Testing Waveforms Figure 3 Clock propagation delays, output transition time, pulse width, set-up, hold times, and maximum frequency XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 9 / 14 XBLW SN74HC/HCT112 Figure 4 Set and reset propagation delays, pulse widths and recovery time Measurement Points Input Type Output VM SN74HC112 0.5×VCC 1.3V SN74HCT112 VM VX VY 0.5×VCC 1.3V 0.1×VCC 0.9×VCC 0.1×VCC 0.9×VCC Test Data Type Input VEXT Load VI tr = tf CL tPLH /tPHL tPLZ/tPZL tPHZ/tPZH SN74HC112 VCC 6.0ns 50pF Open VCC GND SN74HCT112 3.0V 6.0ns 50pF Open VCC GND XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 10 / 14 XBLW SN74HC/HCT112 Package Information DIP16 XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 11 / 14 XBLW SN74HC/HCT112 SOP16 XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 12 / 14 XBLW SN74HC/HCT112 TSSOP16 XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 13 / 14 XBLW SN74HC/HCT112 Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  This document is for referenceonly,and the actual use should be based on the application test results.  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 14 / 14
SN74HC112N 价格&库存
很抱歉,暂时无法提供与“SN74HC112N”相匹配的价格&库存,您可以联系我们找货
