LM-CS0806S
ULTRA LOW CAPACITANCE TVS DIODE ARRAY
Features
Ultra low capacitance: 0.3pF typical (I/O to I/O)
Ultra low leakage: nA level
Low operating voltage: 5V
Low clamping voltage
Up to 4 lines protects
Leadless flow-through package
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±25kV
Dimensions DFN2510P10
Pin Configuration
– IEC61000-4-5 (Lightning) 5A (8/20µs)
RoHS Compliant
Applications
HDMI 1.3 & 1.4& 2.0, USB 2.0 & 3.0 and MDDI ports
10/100/1000 Ethernet
Monitors and flat panel displays
Set-top box and Digital TV
Video graphics cards
Digital Video Interface (DVI)
Notebook Computers
PCI Express and Serial SATA Ports
Marking Information
0524S
YYWW
0524S = Device Marking
Code YYWW = Code
Dot denotes Pin1
Mechanical Characteristics
Package: DFN2510-10 (2.5×1.0×0.5mm)
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 1 per J-STD-020
Terminal Connections: See Diagram Below
Marking Information: See Below
Rev : 17.10.2021
Ordering Information
Part Number
LM-CS0806S
1/9
Packaging
Reel Size
3000/Tape & Reel
7 inch
www.leiditech.com
LM-CS0806S
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
75
W
Peak Pulse Current (8/20µs)
IPP
5
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±25
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Reverse Working Voltage
Breakdown Voltage
Symbol
Min
Typ
VRWM
VBR
Max
Unit
5
V
Any I/O pin to ground
V
IT = 1mA, any I/O pin to ground
6
Test Condition
Reverse Leakage Current
IR
0.1
µA
VRWM = 5V, any I/O pin to ground
Clamping Voltage
VC
9.8
V
IPP = 1A (8 x 20µs pulse), any I/O
pin to ground
Clamping Voltage
VC
15
V
IPP = 5A (8 x 20µs pulse), any I/O
pin to ground
Junction Capacitance
CJ
0.4
pF
VR = 0V, f = 1MHz, between I/O
pins
CJ
0.8
pF
VR = 0V, f = 1MHz, any I/O pin to
ground
Rev : 17.10.2021
0.3
2/9
www.leiditech.com
LM-CS0806S
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
16
Clamping Voltage_Vc (V)
Junction Capacitance_Cj (pF)
1
0.8
0.6
0.4
0.2
10
8
6
4
2
2
3
4
Reverse Voltage_VR (V)
5
Junction Capacitance vs. Reverse Voltage
1
2
3
4
5
Peak Pulse Current_Ipp (A)
6
Clamping Voltage vs. Peak Pulse Current
120
100
90
100
80
% of Rated Power
% of Peak Pulse Current
14
70
60
50
40
30
60
40
Time_t(uS)
60
80
8 X 20uS Pulse Waveform
25
50
75
100 125
Ambient Temperature_Ta(℃)
150
Power Derating Curve
ESD Clamping Voltage
8 kV Contact per IEC61000−4−2
Rev : 17.10.2021
3/9
www.leiditech.com
LM-CS0806S
Typical Application
The LM-CS0806S is designed for easy PCB layout by all owing the traces to run straight through the devic.eThe
PCB traces could be used to connect the pin pairs for each line. For example, line 1 enters at pin 1 and exits at pin
10 and the PCB trace connects Pin 1 and Pin 10 together. Ground is connected at Pin 3 and Pin 8.
1
10
2
9
3
8
4
7
5
6
LM-CS0806S on USB 3.0 Port Application
Vbus
Vbus
DD+
ID
GND
MicB_SSTX-
MicB_SSTX+
GND_DRAIN
MicB_SSRX-
MicB_SSRX+
Rev : 17.10.2021
4/9
www.leiditech.com
LM-CS0806S
LM-CS0806S on DVI Port Application
Rev : 17.10.2021
5/9
www.leiditech.com
LM-CS0806S
LM-CS0806S on HDMI Port Application
TMDS D2+
GND
TMDS D2TMDS D1+
GND
TMDS D1TMDS D0+
GND
TMDS D0HDMI Graphic Video
Controller
TMDS Clock+
GND
TMDS ClockCEC
NC
SCL
SDA
GND
5V Power
Hot Plug Detect
Rev : 17.10.2021
6/9
www.leiditech.com
LM-CS0806S
LM-CS0806S on VGA Port Application
LM-CS0806S on eSATA Port Application
Rev : 17.10.2021
7/9
www.leiditech.com
LM-CS0806S
LM-CS0806S on MDDI Port Application
LM-CS0806S
LM-CS0806S
ULC0511CDN
ULC0511CDN
ULC0511CDN
SD05
ULC0511CDN
SD05
LM-CS0806S on 10/100 Base Ethernet Port Application
Rev : 17.10.2021
8/9
www.leiditech.com
LM-CS0806S
DFN2510-10 Package Outline Drawing
INCHES
NOM
MAX
E
SYM
DIMENSIONS
MILLIMETERS
MIN
NOM
MAX
MIN
TOP VIEW
L2
L1
L
SIDE VIEW
A
0.45
0.50
0.55
0.018
0.020
0.022
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.15
0.20
0.25
0.006
0.008
0.010
b1
0.35
0.40
0.45
0.014
0.016
0.018
b2
0.20
0.25
0.30
0.008
0.010
0.012
c
0.10
0.15
0.20
0.004
0.006
0.008
D
2.45
2.50
2.55
0.098
0.100
0.102
e
0.50BSC
0.020BSC
Nd
2.00BSC
0.080BSC
E
0.95
1.00
1.05
0.038
0.040
0.042
L
0.35
0.40
0.45
0.014
0.016
0.018
L1
0.075REF
0.003REF
L2
0.050REF
0.002REF
h
0.08
0.12
0.15
0.003
0.005
0.006
R
0.05
0.10
0.15
0.002
0.004
0.006
BOTTOM VIEW
Suggested Land Pattern
SYM
DIMENSIONS
MILLIMETERS
INCHES
X1
0.200
0.008
X2
0.400
0.016
X3
0.500
0.020
Y
0.600
0.024
Z
1.400
0.056
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 17.10.2021
9/9
www.leiditech.com
很抱歉,暂时无法提供与“LM-CS0806S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.44887
- 100+0.35764
- 300+0.31202
- 3000+0.26640
- 6000+0.23903
- 9000+0.22525
- 国内价格
- 20+0.31000
- 200+0.29000
- 500+0.27000
- 1000+0.25000
- 3000+0.24000
- 6000+0.22600
