TJ-LF3KR12RLT69-A3
TJ-LF3KR12RLT69-A3
    TOGIALED(台湾统佳)
    插件,P=2.54mm
    发光二极管/LED 3连体带座 3MM 红色光
TJ-LF3KR12RLT69-A3 数据手册
DONGGUAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 承 認 書 Specification For Approval Customer: (客戶) Description:(產品描述) 3连体带座 3MM 3红光 Part number:(產品型號) Date: TJ-LF3KR12RLT69-A3 (日期) Approved By: (客戶承認) Prepared By:(我司承認) Approval 核准 Check Design Sales 審核 製作 業務 Customer Service Hotline:400-676-8616 TEL:0769-8662 5999 0769-8200 2226 E-MIAL∶ dg@togialed.com FAX:0769-8200 2227 WEB: www.togialed.com DONGGUAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 1. overview * Low power consumption * Low power * General equipment on the PCB board or panel * with ICSupporting the use/ Low current requirement 2. Product appearance size figure Unit : mm 3.5(.098) TYP. 4.5(.170) R R 15.5 R 11.7(.461) 11.5(.453) 3.0(.118) 12.7(.50) 7.62(.30) R 2.54(.10) 0.5(.02) SQ.TYP 90 CATHODE 7.58(.298) 2.54(.100) Note: 1:All dimensions are in millimeters (inches). 2:Tolerance is ±0.25mm (.010”) unless otherwise noted. 3: Specifications are subject to change without notices. 4:This specification is for reference only for one year 2.54(.100) 2.54(.100) 5 DONGGUAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Absolute maximum ratings (TA=25℃) Parameter Value Symbol Power dissipation Pd R R 70 72 Unit mW Forward current If 20 mA Reverse voltage Vr 5 V Operating temperature Top -40 ~+85 ℃ Storage temperature Tstg -40 ~+85 ℃ Ifp 55 mA Peak pulsing current (1/8 duty f=1kHz) Electro-optical characteristics (TA=25℃) Parameter Test Condition Value Symbol Wavelength at peak emission If=20mA λp Spectral half bandwidth If=20mA △λ Dominant wavelength If=20mA λd Forward voltage If=20mA Vf Unit Min Typ Max R -- 620 -- R -- 630 -- -- 20 -- R 620 -- 630 R 620 -- 630 1.8 -- 2.4 R 80 --- 150 R 80 --- 150 R R R R nm nm nm V Luminous intensity If=20mA Iv Viewing angle at 50% Iv If=10mA 2θ1/2 -- 30 -- Deg Vr=5V Ir -- -- 10 A Reverse current mcd DONGGUAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Optical characteristic curves (Red Spectral Radiance (Peak@565nm) 1.0 0.6 0.4 0.2 380 400 420 440 460 480 500 520 540 560 580 600 620 640 660 680 700 720 740 760 780 Wave Length(nm) Forward Current vs. Forward Voltage Forward Current (mA) Directive Characteristics 0° 10° 20° 30° Relative radiant intensity 0.0 Forward Voltage (V) Normalized Response 0.8 40° 1.0 50° 60° 0.8 70° 80° 90° 0.5 0 DONGGUAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Optical characteristic curves(Red) Spectral Radiance (Peak@625nm) 1.0 0.6 0.4 0.2 380 400 420 440 460 480 500 520 540 560 580 600 620 640 660 680 700 720 740 760 780 Wave Length(nm) Forward Current vs. Forward Voltage Voltage Forward (mA) Current Directive Characteristics 0° 10° 20° 30° Relative radiant intensity 0.0 Forward (V) Normalized Response 0.8 40° 1.0 50° 60° 0.8 70° 80° 90° 0.5 0 4/9 DONGGUAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Reflow Profile  Reflow Temp/Time 300 (℃ ) 10 S Max. 260℃ Max. 250 230℃ 4℃ /S Max. 200 150~180℃ 4℃ /S Max. Temperature 150 60~120 S 100 30~50 S 50 25℃ 0 50 100 150 200 250 Time 300 (sec) Notes: 1.We recommend the reflow temperature 245℃(±5℃).the maximum soldering temperature should be limited to 260℃. 2.Don’t cause stress to the epoxy resin while it is exposed to high temperature. 3.Number of reflow process shall be 2 times or less. Soldering iron Basic spec is  5sec when 260℃. If temperature is higher, time should be shorter (+10℃ -1sec ).Power dissipation of iron should be smaller than 20W, and temperatures should be controllable .Surface temperature of the device should be under 230℃ . Rework 1.Customer must finish rework within 5 sec under 260℃. 2.The head of iron can not touch copper foil 3.Twin-head type is preferred. Correct( ) Mistake( )  Avoid rubbing or scraping the resin by any object, during high temperature, for example reflow solder etc. Test circuit and handling precautions DONGGUAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD  Test circuit + - R V LED  Handling precautions 1. Over-current-proof Customer must apply resistors for protection; otherwise slight voltage shift will cause big current change (Burn out will happen). 2. Storage 2.1 It is recommended to store the products in the following conditions: Humidity: 60% R.H. Max. Temperature : 5℃~30℃(41℉~86℉) 2.2 Shelf life in sealed bag: 12 month at <5℃~30℃ and <30% R.H. after the package is Opened, the products should be used within a week or they should be keeping to stored at≦20 R.H. with zip-lock sealed. 3. Baking It is recommended to baking before soldering when the pack is unsealed after 72hrs. The Conditions are as followings: 3.1 60±3℃ x(12~24hrs) and <5%RH, taped reel type 3.2 100±3℃ x(45min~1hr), bulk type 3.3 130±3℃ x(15~30min), bulk type Test items and results of reliability DONGGUAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Operation Sequence Environmental Sequence Type Number of Test Item Test Conditions Note Temperature Cycle -20℃ 30min ↑↓ 80℃ 30min 100 cycle 0/22 Thermal Shock -20℃ 15min ↑↓ 80℃ 15min 100 cycle 0/22 High Humidity Heat Cycle 30℃ 65℃ 90%RH 24hrs/1cycle 10 cycle 0/22 High Temperature Storage Ta=80℃ 1000 hrs 0/22 Humidity Heat Storage Ta=60℃ RH=90% 1000 hrs 0/22 Low Temperature Storage Ta=-30℃ 1000 hrs 0/22 Life Test Ta=25℃ IF=20mA 1000 hrs 0/22 High Humidity Heat Life Test 60℃ RH=90% IF=10mA 500 hrs 0/22 Low Temperature Life Test Ta=-20℃ IF=20mA 1000 hrs 0/22 Damaged
TJ-LF3KR12RLT69-A3 价格&库存
很抱歉,暂时无法提供与“TJ-LF3KR12RLT69-A3”相匹配的价格&库存,您可以联系我们找货
