CA1-B0-14-640-3B1-MG
    CARLING
    CIRCUIT BREAKER
CA1-B0-14-640-3B1-MG 数据手册
C-Series Hydraulic-Magnetic Circuit Breaker P ROD UC T W E BP A GE request sample, configure part Compact Circuit Breaker with High Amperage and Voltage Capabilities Compact yet robust, the C-Series hydraulic-magnetic circuit breaker is designed for high amperage and voltage applications. C-Series breakers are available as a one to six pole configuration and are rated up to 100 amps, 480VAC/80VDC or 240VAC/125VDC for UL 489 configurations. Parallel pole options offer ratings from 100-250 amps. The C-Series employs a unique arc chute design which allows for higher interrupting capacities of up to 10,000 amps. 1-6 250 Poles Amps Max 480 VAC Max 125 VDC Max Typical Applications ∙ Marine ∙ Datacom/Telecom www.carlingtech.com ∙ Renewable Energy ∙ Generators & Welders 860.793.9281 ∙ Military ∙ Industrial Automation sales@carlingtech.com ∙ Commercial Food ∙ Medical Equipment Tech Spec Mechanical Electrical Maximum Voltage AC, 480 WYE/277 VAC, 50/60 Hz (see Table A.) UL489: AC,240 VAC. (See Table D),50/60 Hz, 125 VDC Endurance 10,000 ON-OFF operations @ 6 per minute; with rated current & voltage. Current Ratings Standard current coils: 0.100, 0.250, 0.500, 0.750, 1.00, 2.50, 5.00, 7.50, 10.0, 15.0, 25.0, 30.0, 35.0, 40.0, 50.0, 60.0, 70.0, 80.0, 90.0 and 100 amps. Other ratings available, see ordering scheme. Trip Free All circuit breakers will trip on overload, even when actuator is forcibly held in the ON position. Trip Indication The operating actuator moves positively to the OFF position when an overload causes the breaker to trip. With mid-trip, handle moves to the mid position on electrical trip of the circuit breaker. With mid trip handle with alarm switch, handle moves to the mid position and the alarm switch actuates when the circuit breaker is electrically tripped. Standard Voltage Coils DC - 6V, 12V; AC - 120V; other ratings available, see ordering scheme. Auxiliary Switch Rating SPDT; 10.1 amps-250VAC, DC Aux.Switch 1.0A, 65 VDC. 0.5A, 80VDC,1/4 HP, 125VAC,VDE & TUV1.0 125 VAC. Insulation Resistance Minimum of 100 Megohms at 500 VDC. Dielectric Strength UL, CSA: 1960 V 50/60 Hz for oneminute between all electrically isolated terminals. C-Series Circuit Breakers comply with the 8mm spacing and 3750V 50/60 Hz dielectric requirements from hazardous voltage to operator accessible surfaces, between adjacent poles and from main circuits to auxiliary circuits per Publications EN 60950 and VDE 0805. Resistance, Impedance Values from Line to Load Terminal -based on Series Trip Circuit Breaker. RESISTANCE, IMPEDANCE VALUES from Line to Load Terminals ) (Values Based on Series Trip Circuit Breaker 1000 CURRENT TOLERANCE 100 10 O H M S Physical Number of Poles 1-6 poles ≤ 50A; 1-4 poles @ 51-70A; 1-2 poles 71-100A. UL489 Handle: 1 pole ≤ 100A, 2 pole ≤50A; Rocker: 1 pole ≤ 100A Internal Circuit Config. Series (with or without auxiliary switch, mid trip & mid trip with alarm switch) Shunt & Relay with current or voltage trip coils, Dual Coil, Switch Only (with or without aux. switch). UL489: Series (with or without auxiliary switch, mid-trip & midtrip with alarm switch). Weight Approx.112 grams/pole ( 3.95 oz). Standard Colors Housing: Black Environmental (AMPS) (%) 0.10 - 5.0 15 Designed and tested in accordance with requirements of specification MIL-PRF-55629 & MIL-STD-202 as follows: 5.1 - 20.0 25 Shock 20.1 - 50.0 35 Withstands 100Gs,6mssawtooth while carrying rated current pernMethod 213, Test Condition “I”. Instantaneous and ultrashort curves tested @ 90% of rated current. Vibration Withstands 0.060” excursion from 10-55 Hz & 10 Gs 55-500 Hz, @ rated current per Method 204C, Test Cond. A. Instantaneous & ultrashort curves tested @ 90% of rated current. Moisture Resistance Method 106D, i.e., ten 24-hour cycles @ +25°C to +65°C, 80-98% RH.. Salt Spray Method 101, Condition A (90-95% RH @ 5% NaCl Solution, 96 hrs). Thermal Shock RH @ 5% NaCl Solution, 96 hrs). Thermal Shock Method 107D, Condition A (five cycles @ -55°C to +25°C to +85°C to +25°C). Operating Temperature -40° C to +85° C 1 0.1 0.01 Multiple of Rated Current Ir 60 Hz 1/2 Cycle Inrush Pulse Tolerance Time Delay Curves 42, 44 & 46 (50 Amps Max.) 25x Time Delay Curves 22, 24 (100 Amps Max.) 26 (70 Amps Max.) 12x 0.001 0.01 1 0.1 10 100 AMPERE RATING t 4.165 8.33 16.67 CURRENT TOLERANCE Pulse Tolerance (AMPS) Curves (%) 60 Hz 1/2 Cycle 0.100 - 5.0 Inrush Pulse Tolerance 5.1 - 20.0 15% 25% 35% FIGURE 1 25x Time Delay Curves 22, 24 (100 Amps Max.) 26 (70 Amps Max.) 12x Multiple of Rated Current Time Delay Curves 20.1 - 100 42, 44 & 46 (50 Amps Max.) Multiple of Rated Current Ir Ir 50 Hz 1/2 Cycle Inrush Pulse Tolerance Time Delay Curves 42, 44 & 46 (50 Amps Max.) 22x Time Delay Curves 22, 24 (100 Amps Max.) 26 (70 Amps Max.) 10x t 4.165 8.33 16.67 t 5.0 10.0 20.0 2. Multiple of ated Current Time in Milliseconds 22x Ir 50 Hz 1/2 Cycle Inrush Pulse Tolerance Time Delay Curves 42, 44 & 46 (50 Amps Max.) *Manufacturer reserves the right to change product specification without prior notice. 10x Time Delay Curves 22, 24 (100 Amps Max.) 26 (70 Amps Max.) Tech Specs Tables Table A: Lists UL Recognized & CSA Accepted configurations and performance capabilities as a component supplementary protector Component Supplementary Protectors Voltage Circuit Configuration Current Rating Max. Frequency Phase Rating Full Load Amps 32 0.02 - 100 48 110 - 150 0.02 - 70 65 80 --- UL / CSA General Purpose With Without Amps Backup Fuse Backup Fuse --- - 71 - 100 --- 71 - 100 --- 71 - 100 0.02 - 70 DC 0.02 - 70 Short Circuit Capacity (Amps) 5,000 --- 7,500 --- 10,000 125 125/250 0.02 - 50 250 Series 5,000 --- 125 50 / 60 1 0.02 - 100 150 DC --- --0.02 - 100 --3,000 80 - 100 5,000 101 - 175 3,500 0.02 - 50 125/250 51 - 100 1 0.02 - 100 0.02 - 50 0.02 - 100 250 0.02 - 90 1 0.02 - 50 480/277 3 1 DC 125/250 250 277 80 277 480/277 50 / 60 3 DC 50 / 60 480 80 277 250 65 --- 50 / 60 DC --1 3 --- 80 125 277 480/277 --- 31 - 50 1 50 / 60 3 1 3 TC1, 2, OL0, U1 TC1, 2, OL0, U1 TC1, 2, OL0, U1 TC1, 2, OL0, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 Must have Agency "L" TC1, 2, OL1, U1 Must have Agency "L". 250 volts requires 2 pole TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, OL1, U2 Per pole rating TC1, 2, OL1, U1 TC1, 2, OL1, U1 Must have Agency "L" TC1, 2, OL0, U3 --- TC1, OL1, U2 TC1, OL1, U2 Must have Agency "L" Must have Agency "L" parallel pole --- TC1, 2, OL1, U2 TC1, 2, OL1, U2 3,500 TC1, 2, OL1, U2 TC1, 2, OL1, U2 2 or 3 poles breaking single phase. Agency "L" 5,000 --- TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, C1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, C1 2 or 3 poles breaking single phase Per pole rating Must have Agency "L" --- TC1, 2, OL0, U2 TC1, 2, OL0, U2 --- 5,000 TC1, 2, OL0, U1 TC1, 2, OL0, U1 TC1, 2, OL1, C1 TC1, 2, OL1, C1 3 poles breaking 3 phase TC1, 2, OL1, C1 2 poles breaking 1 phase 5,000 --- --- -- 3,500 TC1, 2, OL1, C1 TC1, 2, OL1, C1 TC1, 2, OL1, C1 TC1, 2, OL0, C1 TC1, 2, OL0, C1 TC1, 2, OL0, C1 TC1, 2, OL0, C1 TC1, OL1, U2 TC1, OL1, U2 TC1, 2, OL1, C1 TC1, 2, OL1, U1 TC1, OL1, U2 TC1, 2, OL1, U1 TC1, OL1, U2 3 poles breaking 3 phase Must have Agency "L" --- ----- Per pole rating 2 or 3 poles breaking single phase TC1, 2, OL1, U1 TC1, 2, OL1, U1 3,000 TC1, OL0, U2 TC1, OL0, U2 Per pole rating TC1, 2, OL1, C1 3 poles breaking 3 phase 5,000 --- --- 7,500 5,000 TC1, 2, OL1, C1 3,000 3,500 TC1, OL1, U2 TC1, 2, OL1, C1 TC1, 2, OL1, C1 TC1, 2, OL1, U1 TC1, 2, OL1, C1 --- TC1, 2, OL1, C1 7,500 5,000 TC1, OL1, U2 TC1, 2, OL1, C1 TC1, 2, OL1, U1 TC1, 2, OL1, C1 TC1, 2, OL1, C1 TC1, 2, OL1, C1 TC1, 2, OL0, C1 TC1, 2, OL0, C1 TC1, 2, OL0, C1 TC1, 2, OL0, C1 TC1, 2, OL1, C1 --- TC1, 2, OL1, U1 TC1, 2, OL1, C1 TC1, 2, OL1, C1 TC1, 2, OL1, C1 2 or 3 poles breaking single phase --- --- --3 poles breaking 3 phase 3 poles breaking 3 phase --- 2 poles breaking 1 phase TC1, 2, OL1, U1 --- TC1, 2, OL1, C1 3 poles breaking 3 phase TC1, 2, OL1, C1 ------- 0.02 - 100 --- --- --- 2 or 3 poles breaking single phase --- 0.02 - 70 0.02 - 50 --- Must have Agency "L" TC1, OL1, U2 --- 0.02 - 30 Must have Agency "L" 5,000 71 - 100 71 - 100 --- 2 or 3 poles breaking single phase --- 0.02 - 50 --- 125/250 250 31 - 50 TC1, 2, OL1, U1 TC1, 2, OL0, U1 TC1, 2, OL1, C1 --- 0.02 - 30 TC1, 2, OL1, U1 TC1, 2, OL0, U1 3,000 0.02 - 50 0.02 - 30 TC1, OL1, U2 TC1, 2, OL1, U1 3,000 1 TC1, OL1, U2 Construction Notes TC1, 2, OL1, U1 7,500 --- CSA --- --- --- 3 5,000 5,000 --- 0.02 - 30 1 1 DC --- 0.02 - 30 1 250 Switch Only --- 277 125 Relay 0.02 - 100 0.02 - 70 80 Shunt --- 3 480 Dual Coil 51 - 70 50 / 60 UL 3,000 1,000 --- Application Codes 31 - 50 3 poles breaking 3 phase --- Notes: 1. Requires branch circuit backup with a UL LISTED Type K5 or RK5 fuse rated 15A minimum and no more than 4 times full load amps not to exceed 125A for 50 Amp or less rating and not to exceed 175 for 51 through 100 Amp rating 3. Tech Specs Tables Table B: Lists UL Recognized and CSA Accepted configurations and performance capabilities as a Manual Motor Controller. Manual Motor Controllers Circuit Configuration Voltage Max. Rating Frequency Phase 120 1 Series, Shunt & Relay Switch Only Horsepower Ratings Max. HP 0.02 - 50 7 1/2 1 250 1 3 50 / 60 277 1 480 Current Rating Full Load Amps 3 5 0.02 - 20 1 3 3 2 Notes: 1. Requires branch circuit backup with a UL Listed Type K5 or RK5 fuse rated 15A Minimum and no more than 4 times full load amps not to exceed 125A for 50 Amp or less rating and not to exceed 175A for 51 through 100A rating. 2. UL Recognized and CSA Certified at 480V refers to 3 and 4 pole versions used in a 3Ø, WYE connected circuit or a 2 pole version with 2 poles breaking 1Ø and backed up with a series fusing as stated in note 1. * Shunt and Relay Trip - Voltage Coil Construction not current coils 5 Table C: Lists UL Recognized, CSA Accepted, VDE and TUV Certified configurations and performance capabilities as a Component Supplementary Protector. Component Supplementary Protectors Voltage Circuit Configuration Max. Frequency Phase Rating DC 125 --- 250 1 3 --- 71 - 100 7,500 71 - 100 1 - 50 10,000 80 DC 250 50 / 60 80 DC 250 --- 1&3 --- 1&3 50 / 60 415 5,000 --- 0.10 - 70 5,000 0.10 - 100 3 0.10 - 30 VDE TUV General (Inc) (Icn) (Inc) (Icn) Purpose With Without With Without With Without Backup Backup 1 Amps Backup Backup Backup Backup Fuse Fuse Fuse Fuse Fuse Fuse 0.10 - 90 415 Shunt Short Circuit Capacity (Amps) UL / CSA 0.10 - 50 50 / 60 Dual Coil Full Load Amps 0.10 - 70 80 Series Current Rating --- 5,000 2 --7,500 0.10 - 30 5,000 --- 0.10 - 70 7,500 5,000 0.10 - 30 5,000 2 --- --- 5,000 5,000 1,500 --- 5,000 --- 3,000 1,500 3,000 1,500 --- --- 5,000 5,000 3,000 1,500 5,000 2,500 --- 3,000 1,500 --- 5,000 3,000 1,500 5,000 2,500 3,000 5,000 3,000 5,000 3,000 1,500 Application Codes Construction Notes UL / CSA TC1,2,OL1,U1 --- TC1,2,OL0,U1 Agency F, H, J or R TC1,2,OL1,U1 Agency J or R 2P, Agency J or R --- TC1,2,OL1,U1 Agency J or R Rocker TC1,2,OL1,C1 Handle, Agency F, H, J or R TC1,2,OL1,U1 --- TC1,2,OL1,U1 --- TC1,2,OL1,U1 TC1,2,OL1,C1 --- Rocker Handle, Agency F, H, J or R Notes: 1. General Purpose ratings for UL/CSA only. 2. Requires branch circuit backup with a UL LISTED Type K5 or RK5 fuse rated 15A minimum and no more than 4 times full load amps not to exceed 125A for 50 Amp or less rating and not to exceed 175 for 51 through 100 Amp rating. Table D: Lists UL Listed (489), CSA Certified (C22.2 No. 5.1-M) configuration and performance capabilities as a Molded Case Circuit Breaker. UL489 Listed Branch Circuit Breakers Circuit Configuration Voltage Max. Rating Frequency 80 Phase DC --- 101 - 150 151 - 250 51 - 70 0.10 - 50 50 / 60 1 277 120 Notes: 1 Special catalog number required. Consult factory. 4. Without Backup Fuse 0.10 - 50 120 120 / 240 Dual Coil Full Load Amps 0.10 - 100 125 / 250 240 Interrupting Capacity (Amps) 0.10 - 100 125 Series Current Rating 0.10 - 30 0.10 - 20 0.10 - 30 50,000 1 10,000 5,000 10,000 5,000 10,000 1 5,000 10,000 Construction Notes Limited to 2 Poles Max from 71 - 100 Amps 2 Poles - Parallel Poles 3 Poles - Parallel Poles 1 - 3 Poles 1 or 2 Poles (2 poles required for 250 Volts) 1 - 3 Poles 2 or 3 Poles (1 pole of a 3 pole unit is neutral) 1 Pole 2 Poles 1-2 Poles --- Tech Specs Tables Table E: Lists UL Recognized, CSA Accepted configurations and performance capabilities as Protectors, Supplementary for Marine Electrical and Fuel Systems (Guide PEQZ2, File E75596). Ignition Protected per UL 1500. UL Classified Small Craft Electrical Devices, Marine in accordance with ISO 8846 (Guide UZMK, File MQ1515) as Marine Supplementary Protectors. UL1500 (Marine Ignition Protection) Circuit Configuration Voltage Max Rating Frequency Phase Interrupting Capacity (Amps) Full Load Amps Without Backup Fuse UL CSA 5,000 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL0, U1 TC1, 2, OL0, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 0.02 - 100 48 DC 65 Series Current Rating --- 80 101 - 150 0.02 - 100 0.02 - 70 125 50 / 60 1 250 1,500 5,000 71 - 100 0.02 - 70 1,500 71 - 100 Application Codes Construction Notes --- 2 Poles Breaking Single Phase Table F: Lists UL Listed configurations and performance capabilities as Circuit Breakers for use in Communications Equipment (Guide DITT, File E189195), under UL489A. PARALLEL POLE CONSTRUCTION UL489A Listed for Communications Equipment Voltage Circuit Configuration Max. Rating Series 80 Frequency DC Current Rating Interrupting Capacity (Amps) General Purpose Amps Without Backup Fuse 100 - 250 10,000 Time Delay Specs To view all hydraulic-magnetic circuit breaker time delay values, please visit www.carlingtech.com/sites/default/files/documents/Carling-HM-CB-Time-Delays.pdf Agency Approvals 5. UL 1077 Component Recognition Program as Protectors Supplementary (Guide CCN/QVNU2, File E75596) UL 508 Switches, Industrial Control (Guide CCN/NRNT2, File E148683) UL 1500 Protectors, Supplementary for Marine Electrical & Fuel Systems (Guide PEQZ2, File E75596) Ignition Protection UL 489 Circuit Breakers, Molded Case, (Guide DIVQ, File E129899) UL 489A Communications Equipment (Guide CCN/DITT, File E189195) CSA Accepted Component Supplementary Protector under Class 3215 30, FIle 047848 0 000 CSA Standard C22.2 No. 235 CSA Certified Circuit Breaker Model Case (Class 1432 01, File 093910), CSA Standard C22.2 No. 5.1 - M TUV Certified EN60934, under License No. R72040875 VDE Certified EN60934, VDE 0642 under File No. 10537 Ordering Scheme Sample Part Number Selection C A 3 - B 0 - 10 -450 - 1 2 1 - C 1 2 3 4 5 1. SERIES 2 3 Three 4 Four One Two 4. CIRCUIT B C D 4 E 4 F 4 1 Handle, one per pole Handle, one per multipole unit Mid-Trip Handle, one per pole Mid-Trip Handle, one per pole & Alarm Switch 3. POLES A 3 5 Five 6 Six 3 Switch Only (No Coil) Series Trip (Current) Series Trip (Voltage) Shunt Trip (Current) Shunt Trip (Voltage) Relay Trip (Current) G 4 H 4,5 K 4,5 5. AUXILIARY / ALARM SWITCH 0 2 3 4 without Aux Switch 7 S.P.D.T., 0.110 Q.C. Term. S.P.D.T., 0.139 Solder Lug. 8 S.P.S.T., 0.093 Q.C. Term. 9 (Gold Contacts) Relay Trip (Voltage) Dual Coil with Shunt Trip Voltage Coil Dual Coil with Relay Trip Voltage Coil 5 S.P.S.T., 0.139 Solder Lug. (Gold Contacts) S.P.S.T., 0.187 Q.C. Term. S.P.D.T., 0.187 Q.C. Term. 6. FREQUENCY & DELAY 03 10 11 12 14 16 20 21 22 24 26 30 6. 7 8 9 10 CODE AMPERES 2. ACTUATOR 1 2 6 11 7. CURRENT RATING (AMPERES) C A B S T Handle - UL 1077 Recognized DC 50/60Hz, Switch Only DC Instantaneous DC Ultra Short DC Short DC Medium DC Long 50/60Hz Instantaneous 50/60Hz Ultra Short 50/60Hz Short 50/60Hz Medium 50/60Hz Long DC, 50/60Hz Instantaneous 31 DC, 50/60Hz Ultra Short 32 DC, 50/60Hz Short 34 DC, 50/60Hz Medium 36 DC, 50/60Hz Long 42 8 50/60Hz Short, High-inrush 44 8 50/60Hz Medium, High-inrush 46 8 50/60Hz Long, High-inrush 52 8 DC, Short, High-inrush 54 8 DC, Medium, High-inrush 56 DC, Long, High-inrush Notes: 1 Actuator Code: A: Handle tie pin spacer(s) and retainers provided assembled with multi- pole units. B: Handle location as viewed from front of breaker: 2 pole - left pole 3 pole - center pole 4 pole - two handles at center poles 5 pole - three handles at center poles 6 pole - four handles at center poles S: Handle moves to mid-position only upon electrical trip of the breaker. Available with circuit codes B, C, D, E, F, G, H and K. T: Handle moves to mid-position and alarm switch activates only upon electrical trip of the breaker. Available with circuit codes B & C. 2 Standard multipole units have all poles identical except when specifying auxiliary switch and/or mixed poles. 4 pole max with VDE. 5th pole available as Series Trip with Voltage Coil only. 3 Switch Only circuits, rated up to 50 amps and 6 poles, and only available with VDE Certification when tied to a protected pole (Circuit Code B, C, D or H.). For .02 to 30 amps, select Current Code 630. For 35 - 50 amps, select Current Code 650. For 55-70 amps, select Current Code 670. For 75-100 amps, select Current Code 810. 4 Circuit Codes D,E,F,G,H & K available with Terminal Codes 1,2,4 & 5 only. Circuit Codes D, F, H & K available up to 50 amps maximum Current Rating. 5 Consult factory for available Dual Coil options, as special catalog number is required. Dual Coil Voltage Coils with Shunt Trip Construction trip instantaneously on line voltage. Dual Coil Voltage Coils require 30VA minimum power to trip instantaneously and are rated for intermittent duty only. 6 Auxiliary Switch available with Series Trip & Switch Only circuits. On multi-pole breakers, one auxiliary switch is supplied, mounted in the extreme right pole. 7 Voltage coils not rated for continuous duty. Available only with delay codes 10 & 20. 8 Available with Circuit Codes B & D only, and up to 50 amps maximum. 9 Current Ratings 60 - 70 are available up to four poles maximum. Ratings 71 - 100 are available up to two poles maximum. 10 Terminal Code 1 available to 60 amps maximum. 11 Terminal Codes 2, 4, 5 and C available to 50 amps maximum. 12 Terminal Codes 3, 6 & 9 available to 100 amps maximum. 13 Terminal Code 7 available to 25 amps maximum. 14 Terminal Code A available to 100 amps maximum. 15 Terminal Codes 7, 9 & C are not VDE approved. 16 No marking available. Consult factory. VDE/TUV Approval requires dual (I-O, ON-OFF) or I-O markings on all handles. 17 Single pole only. 18 VDE/TUV: 30 amps max.; UL/CSA: 50 amps max.; Available in 2 - 4 poles only and limited to AC Delays. “General Purpose amps” not rated for “full load amps” or to be used in applications with a motor. 020 0.020 235 0.350 430 3.000 025 0.025 240 0.400 435 3.500 030 0.030 245 0.450 440 4.000 035 0.035 250 0.500 445 4.500 040 0.040 255 0.550 450 5.000 045 0.045 260 0.600 455 5.500 050 0.050 265 0.650 460 6.000 055 0.055 270 0.700 465 6.500 060 0.060 275 0.750 470 7.000 065 0.065 280 0.800 475 7.500 070 0.070 285 0.850 480 8.000 075 0.075 290 0.900 485 8.500 080 0.080 295 0.950 490 9.000 085 0.085 410 1.000 495 9.500 090 0.090 512 1.250 610 10.000 095 0.095 415 1.500 710 10.500 210 0.100 517 1.750 611 11.000 215 0.150 420 2.000 711 11.500 220 0.200 522 2.250 612 12.000 225 0.250 425 2.500 712 12.500 230 0.300 527 2.750 613 13.000 OR VOLTAGE COIL (NORMAL RATED VOLTAGE) 7 CODE AMPERES A06 6 DC A12 12 DC A18 18 DC A24 24 DC A32 32 DC A48 48 DC A65 65 DC J06 6 AC 8 .TERMINAL 1 10 2 11 3 12 4 11 5 11 614 14.000 615 15.000 616 16.000 617 17.000 618 18.000 620 20.000 622 22.000 624 24.000 625 25.000 630 30.000 635 35.000 640 40.000 650 50.000 660 9 60.000 670 9 70.000 680 9 80.000 685 9 85.000 690 9 90.000 695 9 95.000 8109 100.000 J12 J18 J24 J48 12 AC 18 AC 24 AC 48 AC J65 65 AC K20 120 AC L40 240 AC 6 12 7 13,15 9 15 A 14 C 11,15 Stud M6 0.250 Double Click Connect 7/16” Clip Terminal Plug-In Stud 5/16” Clip Terminal 15 Stud 10-32 Screw 10-32 Stud 1/4-20 Stud M5 x 0.8 Screw M5 x 0.8 9. ACTUATOR COLOR & LEGEND 16 Actuator Color I-O ON-OFF Dual Legend Color White A B 1 Black Black C D 2 White Red F G 3 White Green H J 4 White Blue K L 5 White Yellow M N 6 Black Gray P Q 7 Black Orange R S 8 Black 17 Black (short handle) T U 9 White 10. MOUNTING / BARRIERS 1 A C 18 2 B D 18 E 17 MOUNTING STYLE BARRIERS VOLTAGE Threaded Insert 6-32 x 0.195 inches no < 300 6-32 X 0.195 inches yes < 300 6-32 X 0.195 inches yes ≥ 300 ISO M3 x 5mm no < 300 ISO M3 x 5mm yes < 300 ISO M3 x 5mm yes ≥ 300 Front panel Snap-In, 1.00” [25.4mm] wide bezel with Handleguard no < 300 11 AGENCY APPROVAL C D E H I L R UL Recognized, CSA Accepted VDE Certified, UL Recognized, CSA Accepted TUV Certified, UL Recognized, CSA Accepted UL489 Construction: VDE Certified, UL Recognized, CSA Accepted UL Recognized STD 1077, UL Recognized 1500 (ignition protected), CSA Accepted UL489 Construction: UL Recognized, CSA Accepted UL489 Construction: TUV Certified, UL Recognized, CSA Accepted Configure Complete Part Number > Browse Standard Parts > Ordering Scheme Sample Part Number Selection C A 2 - P 0 - D4 -820 - 3 2 1 - M T 1 2 3 4 5 6 1. SERIES 2. ACTUATOR White Black Red Green Blue Yellow Gray Orange 1 Handle, one per pole Mid-Trip Handle, one per pole 1 Mid-Trip, one per pole & Alarm Switch 1 3. POLES 4 1 2 4. CIRCUIT M 2 A G J K T 7 DC Ultra Short DC Short DC Medium DC Long 7. CURRENT RATING (AMPERES) CODE AMPERES 810 811 812 912 100.00 110.00 120.00 125.00 8. TERMINAL 3 6 A 7. 10 11 12 Legend ON-OFF B D G J L N Q S Dual Legend Color 1 Black 2 White 3 White 4 White 5 White 6 Black 7 Black 8 Black 813 814 815 816 130.00 140.00 150.00 160.00 4 1/4-20 threaded Stud M6 threaded Stud Plug-In Stud 3 Threaded Insert 6-32 x 0.195 inches ISO M3 x 5mm 817 917 818 819 170.00 175.00 180.00 190.00 80 DC 12. AGENCY APPROVAL without Aux Switch S.P.D.T., 0.110 Q.C. Term. S.P.D.T., 0.139 Solder Lug S.P.D.T., 0.110 Q.C. Term. (Gold Contacts) S.P.S.T., N.O., 0.110 Q.C Term. (Gold Contacts) S.P.S.T., 0.139 Solder Lug S.P.S.T., 0.110 Q.C Term. (Gold Contacts) S.P.S.T., 0.187 Q.C. Term. S.P.D.T., 0.187 Q.C. Term. 6. FREQUENCY & DELAY D1 D2 D4 D6 9 11. MAXIMUM APPLICATION RATING Series Trip (parallel pole) 5 AUXILIARY/ALARM SWITCH 0 2 3 4 5 6 7 8 9 8 10. MOUNTING 1 One 2 Two 3 Three P 7 9 ACTUATOR COLOR & LEGEND C A S T Handle - UL 489 & UL 489A Listed / Parallel Pole 820 200.00 922 225.00 825 250.00 Without Approval UL489 Listed UL489A Listed, TUV Certified UL489A Listed, VDE Certified UL489A Listed UL489A Listed, TUV Certified Notes: 1 Handle moves to Mid-Position only upon electrical trip of C/B when Actuator S is specified. When Actuator Code T is specified, handle moves to Mid Position and Alarm Switch actuates only upon electrical trip of C/B. Code T is only available with Circuit Code N. 2 Standard Handle colors are White, Black, Red & Yellow. 3 Breakers with Terminal Codes 3 & 6 are supplied with bus bars connecting the Line and Load Terminals. For Terminal Code A, Line and Load Terminals must be connected to a copper bus bar having a minimum cross-section of 0.078 square inches. Terminal Code A is not available on the single pole unit. 4 Ratings for 101 to 125 amps are available in 1-pole. Ratings from 110 to 200 amps are available in 2-pole. For ratings from 225-300 amps, specify 3-pole. 5 1 pole only available with terminal codes 3 and 6. 6 Agency codes K and 7 are not available with 1 pole. Agency code J is only available with 1 pole. Agency code G is only available in 2 and 3 pole. Circuit P, ratings 101-150 amps (2 pole) and ratings 151-250 amps (3 pole). Configure Complete Part Number > Browse Standard Parts > Ordering Scheme Sample Part Number Selection C A 3 - B 0 - 14 -450 - 1 2 1 - K G 1 2 3 4 5 6 1. SERIES 7 8 CODE AMPERES 2. ACTUATOR A B S T 1 Handle, one per pole Handle, one per multipole unit Mid-Trip Handle, one per pole Mid-Trip Handle, one per pole & Alarm Switch 3. POLES 2 1 One 2 Two 3 Three 4. CIRCUIT B 5 AUXILIARY/ALARM SWITCH without Aux Switch S.P.D.T., 0.110 Q.C. Term. S.P.D.T., 0.139 Solder Lug S.P.D.T., 0.110 Q.C. Term. S.P.S.T., 0.139 Solder Lug 2 8 9 S.P.S.T., 0.187 Q.C. Term. S.P.D.T., 0.187 Q.C. Term. (Gold Contacts) 10 DC Ultra Short DC Short DC Medium DC Long 50/60Hz Ultra Short 50/60Hz Short 50/60Hz Medium 1 7 2 8 3 9 4 8 5 8 295 0.950 410 1.000 512 1.250 415 1.500 517 1.750 420 2.000 522 2.250 425 2.500 527 2.750 430 3.000 435 3.500 440 4.000 445 4.500 450 5.000 455 5.500 460 6.000 465 6.500 11 470 7.000 475 7.500 480 8.000 485 8.500 490 9.000 495 9.500 610 10.000 710 10.500 611 11.000 711 11.500 612 12.000 712 12.500 613 13.000 614 14.000 615 15.000 616 16.000 617 17.000 618 18.000 620 20.000 622 22.000 624 24.000 625 25.000 630 30.000 635 35.000 640 40.000 660 60.000 670 70.000 680 80.000 685 85.000 690 90.000 695 95.000 810 100.00 6 6 9 9 9 A 10 C 8 Stud 10-32 Screw 10-32 Stud 1/4-20 Stud M5 x 0.8 Screw M5 x 0.8 26 50/60Hz Long 42 4 50/60Hz Short, High-inrush 44 4 50/60Hz Medium, High-inrush 46 4 50/60Hz Long, High-inrush 52 4 DC Short, High-inrush 54 4 DC Medium, High-inrush 56 4 DC Long, High-inrush Notes: 1 Actuator Code: A: Handle tie pin spacer(s) and retainers provided assembled with multipole units. B: Handle located, as viewed from front of breaker in left pole. 2 pole maximum. S: Handle moves to mid-position only upon electrical trip of the breaker. T: Handle moves to mid-position and alarm switch activates only upon electrical trip of the breaker. 2 Standard multipole units have all poles identical except when specifying auxiliary switch and/or mixed poles. 2 & 3 pole circuit breakers required for 120/240 VAC (Maximum application rating code C) applications, have all poles identical except when specifying auxiliary /alarm switch which is normally supplied in extreme right pole per figure B. Terminal barriers are required on all multipole breakers. Third pole is for 120/240 VAC applications requiring neutral disconnect. The 3rd pole has the same construction as poles 1 & 2. 3 On multi-pole breakers, one auxiliary. switch is supplied, mounted in the extreme right pole.VDE approval on auxiliary switch codes 2, 3 & 4 only. Auxiliary / Alarm Switch with Independent Circuit ie: separate from breaker circuit, only available with circuit breakers rated 50 amp maximum at 80 VDC, 125 VDC, and 120 VAC. Auxiliary / Alarm Switch with Dependent Circuit ie: same as circuit breaker, is supplied from factory with common terminal of auxiliary / alarm switch connected to line terminal on 120/240 and 240 VAC ratings. Circuit breakers rated 120 VAC 50 amp maximum can be supplied with Auxiliary/Alarm switch common terminal connected to breaker line terminal. Consult factory for special catalog number. 4 Available up to 50 amps maximum. 5 Current ratings 71 - 100 with VDE approvals are available up to two poles maximum. 6 Terminal Codes 9 & C are not VDE approved. 7 Terminal Code 1 available to 60 amps maximum. 8 Terminal Codes 2, 4, 5 & C available to 50 amps maximum. 9 Terminal Codes 3, 6 & 9 available to 100 amps maximum. 10 Terminal Code A available to 100 amps maximum. 11 VDE and TUV approvals require Dual (I-O, ON-OFF) markings on all handles. 12 Barriers supplied on multi-pole units only. Configure Complete Part Number > Browse Standard Parts > Actuator Color White Black Red Green Blue Yellow Gray Orange Stud M6 7/16” Clip Terminal Plug-In Stud 5/16” Clip Terminal ON-OFF Dual Legend Color B 1 Black D 2 White G 3 White J 4 White L 5 White N 6 Black Q 7 Black S 8 Black 10. MOUNTING 1 2 MOUNTING STYLE Threaded Insert 6-32 x 0.195 inches ISO M3 x 5mm BARRIERS 12 yes yes 11. MAXIMUM APPLICATION RATING B C D K F M 125 DC 120/240 AC 2 240 AC 120 AC 277 AC 80 DC 12. AGENCY APPROVAL A F G J 12 4 9 ACTUATOR COLOR & LEGEND 6. FREQUENCY & DELAY 11 12 14 16 21 22 24 210 0.100 215 0.150 220 0.200 225 0.250 230 0.300 235 0.350 240 0.400 245 0.450 250 0.500 255 0.550 260 0.600 265 0.650 270 0.700 275 0.750 280 0.800 285 0.850 290 0.900 8. TERMINAL Series Trip (Current) 0 2 3 4 6 9 7. CURRENT RATING (AMPERES) C 8. Handle - UL 489 Listed 11 without approvals UL489 Listed, CSA Certified & VDE Certified UL489 Listed & CSA Certified UL489 Listed, CSA Certified & TUV Certified Circuit & Terminal Diagrams Handle inches [millimeters] TERMINAL DESCRIPTION CODE #10-32 STUD DIMENSIONAL DETAIL .723 [18.36] 1 TERMINAL RATING(AMPS) 25 50 100 80 DESCRIPTION CODE .150 [3.81] .250 DOUBLE Q.C. .688 [17.48] M5 STUD 4 #1/4-20 STUD 3 M6 STUD 6 3 M6 MUD 6 #10-32 SCREW M-5 SCREW .173 .320 [4.39] [8.13] 50 80 .250 [6.35] .723 [18.36] .150 [3.81] 7/16” CLIP TERMINALS .675 [17.15] .437 DIA [ 11.10] COMPONENT DIA .644 [16.36] 9 .901 [22.89] .960 [24.38] .235 [5.97] .669 [16.99] .264 [6.71] PUSH-IN STUD 2 5 RATING(AMPS) 25 .400 [10.16] .820 [20.83] 7 .150 [3.81] #1/4-20 STUD DIMENSIONAL DETAIL +.002 -.000 .558 [14.17] CENTERLINE OF PUSH-IN STUD CONTACT AREA _ +.015 _ +.38 .150 [3.81] +.05 -.00 .311 DIA[Ø7.90] A PUSH-IN STUD MATING HOLE _ NOTES: TOLERANCE ON STUD LENGTHS IS _ +.031 [+.79] UNLESS OTHERWISE SPECIFIED. 3 AUXILIARY / ALARM SWITCH TERMINAL DETAIL .070 DIA[Ø 1.80] .312 [7.92] .287 [7.29] .187 [4.75] TAB (Q.C.).187 TIGHTENING TORQUE SPECIFICATIONS THREAD SIZE #6-32[M3]MOUNTING INSERTS TORQUE 7-9 IN-LBS [0.8-1.0 NM] #10-32 & M5 THD STUDS 15-20 IN-LBS [1.7-2.3 NM] #10-32 THD SCREW 15-20 IN-LBS [1.7-2.3 NM] #1/4-20 & M6 THD STUDS 30-35 IN-LBS [3.4-4.0 NM] .110 [2.80] .051 DIA[Ø 1.29] .110 [2.80] .126 [3.20] SOLDER TYPE TAB (Q.C.).110 TERMINAL DESCRIPTION #10-32 STUD M5 STUD TERMINAL HARDWARE CODE AGENCY APPROVAL 1 ALL 4 ALL #1/4-20 STUD 3 ALL M6 STUD 6 ALL #10-32 SCREW 2 & 5 AMPERE RATING .02-50 .02-50 .02-80 81-100 .02-80 81-100 HARDWARE SUPPLIED LOCK WASHER-FLAT WASHER-NUT LOCK WASHER-FLAT WASHER-NUT LOCK WASHER-FLAT WASHER-NUT LOCK WASHER-NUT-(2)FLAT WASHER-NUT LOCK WASHER-FLAT WASHER-NUT UL RECOGNIZED .02-50 LOCK WASHER-NUT-(2)FLAT WASHER-NUT SADDLE CLAMP-FLAT WASHER-SCREW TUV & VDE CERTIFIED TUV & VDE CERTIFIED .02-16 16.1-50 LOCK WASHER-FLAT WASHER-SCREW UL-489 LISTED .02-50 LOCK WASHER-FLAT WASHER-SCREW SADDLE CLAMP-FLAT WASHER-SCREW THE SADDLE CLAMP IS FOR DIRECT WIRE CONNECTION USE. DISCARD SADDLE CLAMP IF WIRE TERMINAL LUG IS USED Notes: 1 Tolerance ±.020 [.51] unless otherwise specified. 2 Available on Series Trip and Switch Only Circuits when called for on multi-pole units. Only one auxiliary switch is normally supplied, as viewed in mulit-pole identification scheme. 9. 100 Circuit & Terminal Diagrams Handle SWITCH ONLY (NO COIL) LINE LINE (NETZ) CIRCUIT SCHEMATIC ANSI CIRCUIT CODE LINE IEC AUX SWITCH CODE ANSI CIRCUIT CODE CIRCUIT SCHEMATIC 1.850 [46.99]TYP IEC SWITCH ONLY (NO COIL) LINE LINE (NETZ) (3) MAIN TERM’S (SEE TABLE-A) _ +.031 I> LOAD _ +.79 .625 [15.88]TYP 2.250 [57.15] LOAD LOAD (LAST) SWITCH ONLY (NO COIL) WITH AUXILIARY SWITCH .675 [17.15] TYP TYP 1.265 [32.13] TYP NO C C NO NO NC NC NC .970 [24.64] AUX SWITCH TERM. (3 PLCS.) LOAD LINE 2 3 4 A D E 0 _ +.031 _ +.79 .812 [20.62]TYP 4 RELAY .646 [16.41] LINE F G I> 4 RELAY (RELAIS) OFF AUX. SWITCH MODE NC O HANDLE POSITION 3 VOLTAGE COIL LOAD MID TRIP C/B STANDARD ALARM SWITCH MODE REVERSE ALARM SWITCH MODE 4 30 30 OFF NO C OFF O NC NO C NC NO C NC NO C NC NO C NC NO C NC NO C ON ON ON 30 ELECTRICAL TRIP NO C NC NO C 30 30 OFF O Notes: 1 Tolerance ±.020 [.51] unless otherwise specified. 2 Schematic shown represents current trip `circuits. 3 Available only as special catalog number. 10. NC 90 K 0 U> VOLTAGE COIL LINE (NETZ) 1 1 4 LOAD (LAST) STANDARD C/B HANDLE POSITION I> VOLTAGE COIL 2 0 2 HANDLE POSITION VS. AUX/ALARM SWITCH MODE CIRCUIT BREAKER MODE 0 DUAL COIL; SERIES TRIP CURRENT COIL, RELAY TRIP VOLTAGE COIL LINE (NETZ) 1 2 RELAY 3 3 4 1 H NC ALARM SWITCH LOAD 2 LOAD 2 I> LOAD(LAST) VOLTAGE COIL RELAY (RELAIS) 3 2 3 4 LINE RELAY TRIP .646 [16.41] NO LOAD LOAD 1 NO DUAL COIL; SERIES TRIP CURRENT COIL, SHUNT TRIP VOLTAGE COIL (3) SHUNT (NEBENSCHLUSS) C NC I> LINE B C LINE (NETZ) (3) STD. AUX. SWITCH C ALARM SWITCH LOAD(LAST) SHUNT O LOAD(LAST) STD. AUX. SWITCH SHUNT TRIP LINE B C SERIES TRIP WITH AUXILIARY/ ALARM SWITCH LINE (NETZ) LINE C LOAD AUX SWITCH CODE inches [millimeters] I> 4 LOAD (LAST) U> 3 VOLTAGE COIL Dimensional Specs Handle inches [millimeters] #6-32 [M3] THREADED x .195[4.95] DEEP (2 PLC’S.)/POLE TYPICAL-OPTIONAL “I-O” OR “ON-OFF” LEGEND 1 POLE (CA1) 1.125 [28.58] .406 [10.31] +.060 - 1.850 [47.00] TYP LINE 1.438 [36.53] LOAD .755 [19.18] MAX .540 [13.72] .135 [3.42] (SHORT HANDLE) .150 [3.81] TYP MULTI-POLE UNITS ARE ASSEMBLED AT FACTORY WITH COMMON HANDLE TIE. 2 POLE (CA2) .750 [19.05] 1.515 [38.48] MAX +.020 - +.51 - .281 [7.14]TYP #10-32 THREADED STUD TERMINALS IN SRIES TRIP CIRCUIT CONFIGURATION SHOWN. FOR OTHER CONFIGURATIONS, SEE CIRCUIT AND TERMINAL DIAGRAMS. 3 POLE (CB3) CA1 CB2 CB3 .750 [19.05] TYP CA2 CB4 CA3 CA4 TOLERANCES +.005[.12] - 2.265 [57.53] MAX 2.850 [72.39] TYP .281 [7.14] TYP LINE 1.940 [49.28] TYP 4 POLE (CB4) 3.015 [76.58] MAX .156DIA[ 3.96] 2 PLC’S TYP. PER POLE PANEL CUTOUT DETAIL .750 [19.05] 4 POLE (CA4) 3.040 [77.22] 2.280 [57.91] 1.520 [38.61] 1.448 [36.78] 2.062 [52.37] .432 [10.97] 3 POLE (CA3) +.51 - 1.940 [49.28] TYP .760 [19.30] 2 POLE (CB2) 2.265 [57.53] MAX 2.500 [63.50] TYP +.020 - 2.062 [52.37] 1.515 [38.48] MAX +1.52 - 2.475 [62.87]TYP 2.750 [69.85] LOAD .750 [19.05] TYP 3.015 [76.58] MAX BARRIER FOR UL-RECOGNIZED MULTI-POLE BREAKERS 3.080 [78.23] LINE .980 [24.89] TYP 1.940 [49.28] LOAD POLE 1 POLE 2 POLE 3 MULTI-POLE INDENTFICATION SCHEME AS VIEWED FROM TERMINAL END OF BREAKER. Notes: 1 Tolerance ±.020 [.51] unless otherwise specified. 11. 1.850 [47.00] BARRIER FOR UL-489 LISTED MULTI-POLE BREAKERS 3.900 [99.06] Dimensional Specs Handleguard inches [millimeters] 1.155 [29.34] .436 [11.07] 2.520 [64.01] TYP 1.895 [48.13]TYP ON 1-POLE (CA1) 2.560 [65.02]TYP LINE TYP 1.438 [36.53]TYP LINE 1.940 [49.28]TYP 2.500 [63.50] TYP F OF .750 [19.05]MAX #6-32 THREAD X.195[4.95] DEEP (2 PLCS)/POLE .281 [7.14]TYP TYPICAL-OPTIONAL “ON-OFF”, I-O LEGEND .156 DIA [3.96] 2 PLCS PER POLE TYP .760 [19.30] PER POLE TYP 2-POLE (CB2) 2-POLE (CA2) LOAD LOAD .105 [2.67] .540 .740 [13.72] [18.80] 1.520 [38.61] 2.062 [52.37] 1.448 [36.78] .750 [19.05]MAX 1.515 [38.48]MAX 1.515 [38.48]MAX .432 [10.97] CA1,CB2,CB3 CB4 PANEL CUT-OUT DETAIL 4-POLE (CB4) 3-POLE (CB3) .750 [19.05]MAX 2.265 [57.53]MAX * Handleguard available as special catalog number only _ +.040 _ +.020 [.50] [1.02] 2.550 [64.77] .625 [15.88] _ +.015 _ +.015 [.38] SNAP-IN [.50] 1.940 [49.28] [.38] .995 [25.27] .687 [17.45] _ +.015 _ +.005 [.12] .760 [19.30] [.38] 1.496 [38.00] LINE _ +.020 .750 [19.05]MAX 3.015 [76.58]MAX _ +.015 [.38] 1.560 [39.62] _ +.015 [.38] 3.188 [80.98] _ +.007 [1.77] 2.938 [74.63] LOAD #10-32 STUD Notes: 1 Tolerance ±.020 [.51] unless otherwise specified. 12. 1.850 [46.99]TYP PANEL CUT-OUT PANEL THICKNESS 0.04 TO 0.10 INCHES [1.01] TO [2.54] INCHES Dimensional Specs Arc Chute Barrier inches [millimeters] 1-POLE (CA1) W/ ARC CHUTE BARRIER 3-POLE (CA3) W/ ARC CHUTE BARRIER 0.768 [19.51] 2.800 [71.12] MAX BREAKER WIDTH 2.256 [57.30]TYP 0.724 [18.40] 2.264 [57.52] LINE 0.297 [7.54] MAX ARC CHUTE CLEARANCE 3.092 [78.52] LOAD 0.065 [1.65] 0.165 [4.19] 1-POLE (CC1, CD1) W/ ARC CHUTE (NO BARRIER) 1.985 [50.42] INDICATE “ON” 3-POLE (CC3, CD3) W/ ARC CHUTE BARRIER 0.762 [19.35] MAX BREAKER WIDTH 2.245 [57.02]TYP 1.142 [29.02] 3.115 [79.12] LINE 0.297 [7.55] MAX ARC CHUTE CLEARANCE 2.795 [71.00] LOAD SCREW TYPE TERMINALS IN SERIES TRIP CIRCUIT CONFIGURATION SHOWN. INDICATE “OFF”/ SINGLE COLOR 3-POLE (CF3, CG3, C13, C23) W/ ARC CHUTE BARRIER 1-POLE (CF1, CG1, C11, C21) W/ ARC CHUTE (NO BARRIER) LOAD MAX ARC CHUTE CLEARANCE 0.297 [7.55] LINE Notes: 1 Only 1-pole and 3-pole configurations shown. Arc chute (without barrier) and arc chute barrier also available for 2-pole construction. 2 Dimensions apply to all variations shown. 3 Notice that line and load terminal orientation for indicate on and indicate off rocker circuit breakers are opposite. 4 Screw type terminals shown for Rocker style (CF1, C11, etc) circuit breakers. For other terminal configurations see circuit and terminal diagrams. 5 Tolerance ± .020 unless otherwise specified. 6 Must be ordered under a special catalog number. 13. Dimensional Specs Parallel Pole inches [millimeters] PARALLEL POLE (CA2-P) #6-32[M3]THREADED x .195[4.95]DEEP (2 PLC’S.)/ POLE _ +.060 TYPICAL-OPTIONAL “ON-OF,I-O” LEGEND 1.438 [36.53] 1.125 [28.58] .406 ON [10.31] _ +1.52 2.475 [62.87]TYP 1.850 [47.00]TYP 1.276 [32.36] _ 2.500 [63.50]TYP _ .625 [15.66] 1.940 [49.28]TYP 2.062 [52.37] 2.565 [65.10] F OF _ +.020 CIRCUIT BREAKER PROFILE _ +.060 ANSI _ +1.52 1.388 [47.00]TYP TYPICAL-OPTIONAL “ON-OF,I-O” LEGEND _ +.51 .281 [7.14]TYP #1/4-20 THREADED STUD SHOWN CIRCUIT SCHEMATIC (CA2-P SHOWN) SWITCH TRIP IEC LOAD LOAD(LAST) LINE(NETZ) .750 [19.05] 2.265 [57.53]MAX C C NO NO NC .255 [5.72] .960 [24.38] .558 [14.17] CENTERLINE OF PUSH-IN STUD CONTACT AREA +.002 -.000 .675 [17.15] .669 [16.99] +.05 -.00 .311 [7.90] .158 [4.01] .392 [9.96] M6 STUD Notes: 1 Tolerance ±.020 [.51] unless otherwise specified. 14. NC 2 3 4 LOAD(LAST) TOLERANCE+005[.12] - #1/4-20 STUD PUSH-IN STUD MATING HOLE I> LOAD P PANEL CUT-OUT DETAIL .158 [4.01] .363 [9.22] PUSH-IN STUD (SEE NOTE 3) 0 SERIES TRIP WITH AUXILIARY SWITCH LINE TERMINAL DETAILS P LINE (NETZ) LINE .400 [10.16] AUX SWITCH CODE PARALLEL POLE (CA3-P) .150 [3.81]TYP .540 [13.72] CIRCUIT CODE .750 [19.05] 1.515 [38.48]MAX .750 [19.05]TYP 2.280 [57.91] 1.520 [38.61] 1.448 [36.78] 2.062 [52.37] .432 [10.97] CA2-P CA3-P .156DIA.[ 3.96] 2 PLC’S. TYP. PER POLE Ordering Scheme Sample Part Number C M 3 - B 0 - 10 -450 - 1 0 1 - C 1 Selection 2 3 4 5 1. SERIES 6 7 8 9 7. CURRENT RATING (AMPERES) C M 1 Sealed Toggle, one per pole 3. POLES 1 One 2 4. CIRCUIT A 2 B C D 3 E 3 F 3 Switch Only (no coil) Series Trip (current) Series Trip (voltage) Shunt Trip (current) Shunt Trip (voltage) Relay Trip (current) 3 Three Two G 3 H 3,4 K 3,4 5. AUXILIARY / ALARM SWITCH 0 2 3 4 without Aux Switch S.P.D.T., 0.110 Q.C. Term. S.P.D.T., 0.139 Solder Lug S.P.D.T., 0.110 Q.C. Term. 6 8 9 Relay Trip (voltage) Dual Coil with Shunt Trip Voltage Coil Dual Coil with Relay Trip Voltage Coil 5 S.P.S.T., 0.139 Solder Lug S.P.S.T., 0.187 Q.C. Term. S.P.D.T., 0.187 Q.C. Term. (Gold Contacts) 6. FREQUENCY & DELAY 03 2 10 6 11 12 14 16 20 6 21 22 24 26 DC 50/60Hz, Switch Only DC Instantaneous DC Ultra Short DC Short DC Medium DC Long 50/60Hz Instantaneous 50/60Hz Ultra Short 50/60Hz Short 50/60Hz Medium 50/60Hz Long 020 0.020 235 0.350 430 3.000 025 0.025 240 0.400 435 3.500 030 0.030 245 0.450 440 4.000 035 0.035 250 0.500 445 4.500 040 0.040 255 0.550 450 5.000 045 0.045 260 0.600 455 5.500 050 0.050 265 0.650 460 6.000 055 0.055 270 0.700 465 6.500 060 0.060 275 0.750 470 7.000 065 0.065 280 0.800 475 7.500 070 0.070 285 0.850 480 8.000 075 0.075 290 0.900 485 8.500 080 0.080 295 0.950 490 9.000 085 0.085 410 1.000 495 9.500 090 0.090 512 1.250 610 10.000 095 0.095 415 1.500 710 10.500 210 0.100 517 1.750 611 11.000 215 0.150 420 2.000 711 11.500 220 0.200 522 2.250 612 12.000 225 0.250 425 2.500 712 12.500 230 0.300 527 2.750 613 13.000 OR VOLTAGE COIL (NORMAL RATED VOLTAGE) 6 A06 A12 A18 A24 6 DC 12 DC 18 DC 24 DC A32 A48 A65 J06 32 DC 48 DC 65 DC 6 AC 8 .TERMINAL 30 31 32 34 36 42 7 44 7 46 7 52 7 54 7 56 DC 50/60Hz Instantaneous DC 50/60Hz Ultra Short DC 50/60Hz Short DC 50/60Hz Medium DC 50/60Hz Long 50/60Hz Short, High-inrush 50/60Hz Medium, High-inrush 50/60Hz Long, High-inrush DC Short, High-inrush DC Medium, High-inrush DC Long, High-inrush Notes: 1 Actuator Code M: Handle location as viewed from front of breaker: 2 pole - right pole 3 pole - center pole 2 Switch Only circuits, rated up to 50 amps and 3 poles, and only available with VDE. For .02 to 30 amps, select Current Code 630. For 35 - 50 amps, select Current Code 650. For 55-70 amps, select Current Code 670. For 75- 100 amps, select Current Code 810. 3 Circuit Codes D,E,F,G,H & K available with Terminal Codes 1,2,4 & 5 only. 4 Consult factory for available Dual Coil options, as special catalog number is required. Dual Coil Voltage Coils with Shunt Trip Construction trip instantaneously on line voltage. Dual Coil Voltage Coils require 30VA minimum power to trip instantaneously and are rated for intermittent duty only. 5 Auxiliary Switch available with Series Trip and Switch Only circuits. On multipole breakers, one auxiliary switch is supplied, mounted in the extreme right pole. 6 Voltage coils not rated for continuous duty. Available only with delay codes 10 & 20. 7 Available with Circuit Codes B & D only, and up to 50 amps maximum. 8 Consult factory for current ratings 71-100, in three pole units, available as special catalog number only. 9 Terminal Code 1 available to 60 amps maximum. 10 Terminal Codes 2, 4, 5 and C available to 50 amps maximum. 11 Terminal Codes 3, 6 & 9 available to 100 amps maximum. 12 Terminal Code 7 available to 25 amps maximum. 13 Terminal Code A available to 100 amps maximum. Configure Complete Part Number > Browse Standard Parts > 1 2 3 4 5 Stud 10-32 9 Screw 10-32 10 Stud 1/4-20 11 Stud M5 x 0.8 10 Screw M5 x 0.8 10 J12 J18 J24 J48 6 7 9 A C 10 11 9 CODE AMPERES 2. ACTUATOR 15. Sealed Toggle - UL 1077 Recognized 12 AC 18 AC 24 AC 48 AC 614 14.000 615 15.000 616 16.000 617 17.000 618 18.000 620 20.000 622 22.000 624 24.000 625 25.000 630 30.000 635 35.000 640 40.000 650 50.000 660 9 60.000 670 9 70.000 680 9 80.000 685 9 85.000 690 9 90.000 695 9 95.000 810 9 100.000 J65 K20 L40 65 AC 120 AC 240 AC Stud M6 11 0.250 Double Click Connect 12 7/16” Clip Terminal 11 Plug-In Stud 13 5/16” Clip Terminal 10 9. LEGEND PLATE 0 No Legend 10. MOUNTING / BARRIERS 1 A MOUNTING STYLE BARRIERS Standard Hex Nut no Standard Hex Nut (multi-pole units only) yes 11 AGENCY APPROVAL C I L UL Recognized & CSA Accepted UL Recognized & CSA Accepted, UL1500 ignition protection UL Recognized & CSA Accepted with listed construction Dimensional Specs Sealed Toggle inches [millimeters] KEYWAY .060[1.52]-.065[1.65]WIDE .030[.76]-.035[.86]DEEP .750 [19.05] .750 [19.05] #6-32 MTG.SCREW FOR HIGH SHOCK MTG. LOCKER WASHER LOAD LOAD 1.380 [34.90] .656 [16.66] 1-POLE (CM1) .755 [19.18] MAX .750 [19.05] 2.500 [63.50] ON 1.940 [49.28] OFF LINE LINE 1/2-32 HEX NUT .740 [18.80] RUBBER “O”RING SCREW TYPE TERMINALS IN SERIES TRIP CIRCUIT CONFIGURATION SHOWN. FOR OTHER CONFIGURATIONS SEE CIRCUIT & TERMINAL DIAGRAMS .750 [19.05] 2-POLE (CM2) 2 & 3-POLES .750 [19.05] .750 [19.05] 1, 2 & 3-POLES 3-POLES 1.490 [37.80] .750 [19.05] .750 [19.05] .156 [3.97] .656 [16.67] .515 [13.09] PANEL CUTOUT DETAIL TOLERANCES _ +.005[.13] 3-POLE (CM3) 2.240 [56.90] Notes: 1 Tolerance ±.020 [.51] unless otherwise specified. 16. Ordering Scheme C C 3 - B 0 - 14 -450 - 1 2 1 - D Sample Part Number 1 Selection 2 3 4 5 1. SERIES 6 7 8 9 7. CURRENT RATING (AMPERES) C 10 1 3. POLES 1 ROCKER STYLE DESCRIPTIONS HORIZONTAL STYLE CODE ”D” INDICATE”ON” INDICATE”OFF” SINGLE COLOR Two Color Visi-Rocker C Indicate ON, vertical legend D Indicate ON, horizontal legend E Indicate ON, no legend F Indicate OFF, vertical legend G Indicate OFF, horizontal legend H Indicate OFF, no legend Push-To-Reset, Visi-Rocker N Indicate OFF, vertical legend O Indicate OFF, horizontal legend P Indicate OFF, no legend Single color J Vertical legend K Horizontal legend L No legend Push-To-Reset, Single color R Vertical legend U Horizontal legend V No legend LINE VERTICAL STYLE LINE CODE ”C” INDICATE COLOR LOCATION CODE ”G” , “O” CODE ”F” , “N” LINE LINE CODE ”K” , “U” CODE ”J” , “R” LINE LINE 2 One 2 3 Three Two 4. CIRCUIT Voltage Coil D 4 Shunt Trip (Current) 4,5 K Dual Coil with Relay Trip E 4 Shunt Trip (Voltage) Voltage Coil 5. AUXILIARY / ALARM SWITCH 0 2 6 3 without Aux Switch S.P.D.T., 0.110 Q.C. Term. S.P.S.T., 0.139 Solder Lug S.P.D.T., 0.139 Solder Lug 6. FREQUENCY & DELAY 03 10 7 11 12 14 16 20 7 21 22 24 26 DC 50/60Hz, Switch Only DC Instantaneous DC Ultra Short DC Short DC Medium DC Long 50/60Hz Instantaneous 50/60Hz Ultra Short 50/60Hz Short 50/60Hz Medium 50/60Hz Long 020 0.020 235 0.350 430 3.000 025 0.025 240 0.400 435 3.500 030 0.030 245 0.450 440 4.000 035 0.035 250 0.500 445 4.500 040 0.040 255 0.550 450 5.000 045 0.045 260 0.600 455 5.500 050 0.050 265 0.650 460 6.000 055 0.055 270 0.700 465 6.500 060 0.060 275 0.750 470 7.000 065 0.065 280 0.800 475 7.500 070 0.070 285 0.850 480 8.000 075 0.075 290 0.900 485 8.500 080 0.080 295 0.950 490 9.000 085 0.085 410 1.000 495 9.500 090 0.090 512 1.250 610 10.000 095 0.095 415 1.500 710 10.500 210 0.100 517 1.750 611 11.000 215 0.150 420 2.000 711 11.500 220 0.200 522 2.250 612 12.000 225 0.250 425 2.500 712 12.500 230 0.300 527 2.750 613 13.000 OR VOLTAGE COIL (NORMAL RATED VOLTAGE) 7 A06 6 DC A32 32 DC J12 12 AC A12 12 DC A48 48 DC J18 18 AC A18 18 DC A65 65 DC J24 24 AC A24 24 DC J06 6 AC J48 48 AC 8. TERMINAL F 4 Relay Trip (Current) A 3 Switch Only (No Coil) G 4 Relay Trip (Voltage) B Series Trip (Current) H 4,5 Dual Coil with Shunt Trip C Series Trip (Voltage) 8 4 9 6 S.P.S.T., 0.187 Q.C. Term. S.P.D.T., 0.110 Q.C. Term. S.P.D.T., 0.187 Q.C. Term. (Gold Contacts) 30 DC 50/60Hz Instantaneous 31 DC 50/60Hz Ultra Short 32 DC 50/60Hz Short 34 DC 50/60Hz Medium 36 DC 50/60Hz Long 42 8 50/60Hz Short, High-inrush 44 8 50/60Hz Medium, High-inrush 46 8 50/60Hz Long, High-inrush 52 8 DC Short, High-inrush 54 8 DC Medium, High-inrush 56 8 DC Long, High-inrush Notes: 1 Push-To-Reset actuators have OFF portion of rocker shrouded. 2 Multi-pole breakers have all poles identical except when specifying Auxiliary switch and/or mixed poles, and have one rocker per breaker. Rocker location as viewed from front panel: 2 pole – left pole; 3 pole – center pole. 3 Switch Only circuits, rated up to 50 amps and 3 poles, and only available with VDE Certification when tied to a protected pole (Circuit Code B, C, D or H.), For .02 to 30 amps, select Current Code 630. For 35 - 50 amps, select Current Code 650. For 55-70 amps, select Current Code 670. For 75-100 amps, select Current Code 810. 4 Circuit Codes D,E,F,G,H & K available with Terminal Codes 1,2,4 & 5 only. Circuit Codes D,F,H & K available up to 50 amps maximum Current Rating. 5 Consult factory for available Dual Coil options, as special catalog number is required. Dual Coil Voltage Coils with Shunt Trip Construction trip instantaneously on line voltage. Dual Coil Voltage Coils require 30VA minimum power to trip instantaneously and are rated for intermittent duty only. 6 Auxiliary Switch available with Series Trip and Switch Only circuits. On multipole breakers, one auxiliary switch is supplied, mounted in the extreme right pole. Auxiliary switch codes 2, 3 & 4 are VDE approved. 7 Voltage coils not rated for continuous duty. Available only with delay codes 10 & 20. 8 Available with Circuit Codes B & D only, and up to 50 amps maximum. 9 Current Ratings 60-70 are available up to four poles maximum. Ratings 71- 100 are available up to two poles maximum. 10 Terminal Code 1 available to 60 amps maximum. 11 Terminal Codes 2,4,5 & C available to 50 amps maximum. 12 Terminal Codes 3,6 & 9 available to 100 amps maximum. 13 Terminal Code 7 available to 25 amps maximum. 14 Terminal Code A available to 100 amps maximum. 15 Terminal Codes 7, 9 & C are not VDE approved. 16 Color shown is visi and legend with remainder of rocker black 17 Legend on Push-to-reset bezel/shroud is white when single color rocker is ordered. Dual = ON-OFF/I-O legend with actuator codes C - G, and J, K, N, O, R, & U. None = no legend with actuator codes H, L, P, V. Rockerguard available with actuator codes C - L. Push-to-reset available with actuator codes N, O, P, R, U, V. 18 VDE/TUV approval requires Dual (I-O, ON-OFF) or I-O markings on rocker. 19 VDE/TUV: 30 amps max.; UL/CSA: 50 amps max.; Available in 2 - 4 poles only and limited to AC Delays. “General Purpose amps” not rated for “full load amps” or to be used in applications with a motor. 1 2 3 4 5 Stud 10-32 10 Screw 10-32 11 Stud 1/4-20 12 Stud M5 x 0.8 11 Screw M5 x 0.8 11 6 7 9 A C 9. ACTUATOR COLOR & LEGEND 11 9 CODE AMPERES 2. ACTUATOR 17. Rocker - UL 1077 Recognized 614 14.000 615 15.000 616 16.000 617 17.000 618 18.000 620 20.000 622 22.000 624 24.000 625 25.000 630 30.000 635 35.000 640 40.000 650 50.000 660 9 60.000 670 9 70.000 680 9 80.000 685 9 85.000 690 9 90.000 695 9 95.000 810 9 100.000 J65 K20 L40 65 AC 120 AC 240 AC Stud M6 12 0.250 Double Click Connect 13 7/16” Clip Terminal Plug-In Stud 14 5/16” Clip Terminal 16,17,18 Actuator or Visi-Color Marking: Marking Color: Single Color Color: I-O ON-OFF Dual/None Rocker/Handle Visi-Rocker White A B 1 Black White Black C D 2 White n/a Red F G 3 White Red Green H J 4 White Green Blue K L 5 White Blue Yellow M N 6 Black Yellow Gray P Q 7 Black Gray Orange R S 8 Black Orange 10 MOUNTING / BARRIERS 1 2 3 19 4 5 6 19 A C E 19 G J L 19 B D F 19 H J M 19 1 STANDARD ROCKER BEZEL 6-32 x 0.195 inches 6-32 x 0.195 inches 6-32 x 0.195 inches ISO M3 x 5mm ISO M3 x 5mm ISO M3 x 5mm ROCKERGUARD BEZEL 6-32 x 0.195 inches 6-32 x 0.195 inches 6-32 x 0.195 inches ISO M3 x 5mm ISO M3 x 5mm ISO M3 x 5mm PUSH-TO-RESET BEZEL 6-32 x 0.195 inches 6-32 x 0.195 inches 6-32 x 0.195 inches ISO M3 x 5mm ISO M3 x 5mm ISO M3 x 5mm BARRIERS no yes yes no yes yes VOLTAGE VOLTAGE COIL RELAY 3 4 _ [+.79] C DUAL COIL; SERIES TRIP CURRENT COIL, SHUNT TRIP VOLTAGE COIL SHUNT (NEBENSCHLUSS) DE 2 LOAD 3 _ +.031 LINE BC LINE(NETZ) NC LINE(NETZ) LOAD SHUNT TRIP (3 TERM’S.) AUX SWITCH CODE CIRCUIT CODE AUX SWITCH CODE NC LOAD(LAST) SHUNT SHUNT TRIP (4 TERM’S.) 2 3 4 SHUNT TRIP LINE 0 LOAD(LAST) LINE A NO NC LOAD BC SERIES TRIP WITH AUXILIARY SWITCH C NO LINE(NETZ) LOAD LINE(NETZ) C C NO NC SERIES TRIP W/AUX. SWITCH (5 TERM’S.) LOAD(LAST) LINE IEC 0 SWITCH INLY (NO COIL) WITH AUXILIARY SWITCH .675 [17.15]TYP .970 [24.64] SWITCH TRIP LINE A LOAD _ [+.79] .625 [5.88]TYP CIRCUIT SCHEMATIC ANSI LINE(NETZ) LINE MAIN TERM’S. (SEE TABLE A) SERIES TRIP (2 TERM’S.) _ +.031 CIRCUIT SCHEMATIC ANSI IEC SWITCH ONLY (NO COIL) CIRCUIT CODE CIRCUIT BREAKER PROFILE 2.160 [54.86] TYP LINE Dimensional Specs Rocker inches [millimeters] INDICATE”ON” SCREW TYPE TERMINALS IN SERIES TRIP CIRCUIT CONFIGURATION SHOWN. FOR OTHER CONFIGURATIONS SEE CIRCUIT AND TERMINAL DIAGRAMS. LOAD 1.245 [31.62] .745 [18.92] MAX ROCKER ADAPTER BRACKET WIDTH 1.660 [42.16] TYP OPTIONAL “ROCKER GUARD” SHOWN IN PHANTOM .310 [7.87] .208 [5.28] CC1 LINE 2.514 [63.85] SCREW TYPE .432 [10.97] .755 [19.180] MAX BREAKER WIDTH OPTIONAL “PUSH-TO-RESET” ACTUATOR 2.500 [63.50] CC2 PANEL CUT-OUT DETAIL +.010 -.000 2.062 [52.37] 2.265 [57.53] MAX .623 [15.82] .055x .205 SLOTTED HOLE (ROCKER OFF ACTUATION) CF2 _ +.005 +.25 -.000 _ +.13 .200 [5.080] P(1) P(2) P(3) (SEE NOTE 2) REAR VIEW OF INDICATE “ON” SERIES TRIP W/ AUX SWITCH CIRCUIT CONFIGRUATION. 1.660 [42.16] .156 DIA [ 3.96] (2) HOLES CF3 P(1) P(2) P(3) (SEE NOTE 2) REAR VIEW OF INDICATE “OFF” SERIES TRIP W/ AUX SWITCH CIRCUIT CONFIGRUATION. Notes: 1 Dimensions apply to all variations shown. Notice that circuit breaker line and load terminal orientation on indicate OFF is opposite of indicate ON. 2 For pole orientation with horizontal legend, rotate front view clockwise 90°. 3 Tolerance ±.020 [.51] unless otherwise specified. 21. .465 [11.81] ROCKER SHROUDED ON “OFF” POSITION SIDE, SHOWN IN DASHED LINES. .750 [19.05] 1.260 [32.00] .750 [19.05] TYP 1.515 [38.48] MAX 1.245 [31.62] 1.940 [49.28] 1.245 [31.62] 1.125 [28.58] OF ROCKER & PANEL CUT-OUT OPTIONAL”ROCKER GUARD” SHOWN IN DASHED LINES CC3 (INDICATE “OFF” SHOWN) 2.160 [54.86] 1.850 [47.00] .420 [10.67] .120 [3.05] 1.125 [28.58] 2.500 [63.50] INDICATE”OFF” & SINGLE COLOR Ordering Scheme C Sample Part Number 1 2 - B 0 - 10 -450 - 1 2 1 - E 1 Selection Flat Rocker - UL 1077 Recognized 2 3 4 5 1. SERIES 6 7 8 7. CURRENT RATING (AMPERES) C 10 3. POLES 1 ROCKER STYLE DESCRIPTIONS INDICATE “OFF” CODE “1”, ”5” VERTICAL STYLE Two Color Visi-Rocker Indicate OFF, vertical legend Indicate OFF, horizontal legend Single color Vertical legend Horizontal legend Push-To-Reset, Visi-Rocker Indicate OFF, vertical legend Indicate OFF, horizontal legend Push-To-Reset , Single color Vertical legend Horizontal legend INDICATE COLOR LOCATION HORIZONTAL STYLE 1 2 3 4 5 6 7 8 1 LINE SINGLE COLOR CODE “3”, ”7” LINE CODE “2”, ”6” LINE CODE “4”, ”8” LINE 2 One 2 3 Three Two 4. CIRCUIT 020 0.020 235 0.350 430 3.000 025 0.025 240 0.400 435 3.500 030 0.030 245 0.450 440 4.000 035 0.035 250 0.500 445 4.500 040 0.040 255 0.550 450 5.000 045 0.045 260 0.600 455 5.500 050 0.050 265 0.650 460 6.000 055 0.055 270 0.700 465 6.500 060 0.060 275 0.750 470 7.000 065 0.065 280 0.800 475 7.500 070 0.070 285 0.850 480 8.000 075 0.075 290 0.900 485 8.500 080 0.080 295 0.950 490 9.000 085 0.085 410 1.000 495 9.500 090 0.090 512 1.250 610 10.000 095 0.095 415 1.500 710 10.500 210 0.100 517 1.750 611 11.000 215 0.150 420 2.000 711 11.500 220 0.200 522 2.250 612 12.000 225 0.250 425 2.500 712 12.500 230 0.300 527 2.750 613 13.000 OR VOLTAGE COIL (NORMAL RATED VOLTAGE) 7 A06 A12 A18 A24 6 DC 12 DC 18 DC 24 DC A32 A48 A65 J06 F 4 Relay Trip (Current) D 4 Shunt Trip (Current) A 3 Switch Only (No Coil) K 4,5 Dual Coil with Relay Trip G 4 Relay Trip (Voltage) E 4 Shunt Trip (Voltage) 8. TERMINAL B Series Trip (Current) Voltage Coil H 4,5 Dual Coil with Shunt Trip 1 Stud 10-32 10 C Series Trip (Voltage) 2 Screw 10-32 with saddle 11 Voltage Coil 3 Stud 1/4-20 12 4 Stud M5 x 0.8 11 5. AUXILIARY / ALARM SWITCH 6 5 Screw M5 x 0.8 11 0 2 3 4 without Aux Switch S.P.D.T., 0.110 Q.C. Term. S.P.D.T., 0.139 Solder Lug S.P.D.T., 0.110 Q.C. Term. (Gold Contacts) 6. FREQUENCY & DELAY 03 10 7 11 12 14 16 20 7 21 22 24 26 DC 50/60Hz, Switch Only DC Instantaneous DC Ultra Short DC Short DC Medium DC Long 50/60Hz Instantaneous 50/60Hz Ultra Short 50/60Hz Short 50/60Hz Medium 50/60Hz Long 6 8 9 30 31 32 34 36 42 8 44 8 46 8 52 8 54 8 56 8 S.P.S.T., 0.139 Solder Lug S.P.S.T., 0.187 Q.C. Term. S.P.D.T., 0.187 Q.C. Term. DC 50/60Hz Instantaneous DC 50/60Hz Ultra Short DC 50/60Hz Short DC 50/60Hz Medium DC 50/60Hz Long 50/60Hz Short, High-inrush 50/60Hz Medium, High-inrush 50/60Hz Long, High-inrush DC Short, High-inrush DC Medium, High-inrush DC Long, High-inrush Notes: 1 Push-to-reset actuators have OFF portion of rocker shrouded. 2 Multi-pole breakers have all poles identical except when specifying Auxiliary switch and/or mixed poles, and have one rocker per breaker. Rocker location as viewed from front panel: 2 pole – left pole; 3 pole – center pole. 3 Switch Only circuits, rated up to 50 amps and 3 poles, and only available with VDE Certification when tied to a protected pole (Circuit Code B, C, D or H.). For .02 to 30 amps, select Current Code 630. For 35 - 50 amps, select Current Code 650. For 55-70 amps, select Current Code 670. For 75-100 amps, select Current Code 810. 4 Circuit Codes D,E,F,G,H & K available with Terminal Codes 1,2,4 & 5 only. Circuit Codes D,F,H & K available up to 50 amps maximum Current Rating. 5 Consult factory for available Dual Coil options, as special catalog number is required. Dual Coil Voltage Coils with Shunt Trip Construction trip instantaneously on line voltage. Dual Coil Voltage Coils require 30VA minimum power to trip instantaneously and are rated for intermittent duty only. 6 Auxiliary Switch available with Series Trip and Switch Only circuits. On multipole breakers, one auxiliary switch is supplied, mounted in the extreme right pole. Auxiliary switch codes 2, 3 & 4 are VDE approved. 7 Voltage coils not rated for continuous duty. Available only with delay codes 10 and 20. 8 Available with Circuit Codes B & D only, and up to 50 amps maximum. 9 Current ratings 60-70 are available up to four poles maximum. Current ratings 71 - 100 are available up to two poles maximum. 10 Terminal Code 1 available to 60 amps maximum. 11 Terminal Codes 2,4,5 & C available to 50 amps maximum. 12 Terminal Codes 3,6 & 9 available to 100 amps maximum. 13 Terminal Code 7 available to 25 amps maximum. 14 Terminal Code A available to 100 amps maximum. 15 Terminal Codes 7, 9 & C are not VDE approved. 16 Color shown is visi & legend with remainder of rocker black. Dual = ON-OFF/I-O legend. 17 Legend on Push-to-reset bezel/shroud is white with single color actuator codes 7 & 8. Legend on Push-to-reset bezel/shroud matches visi-color of rocker with actuator codes 5 & 6. 18 VDE/TUV approval requires Dual (I-O, ON-OFF) or I-O markings on rocker. 19 VDE/TUV: 30 amps max.; UL/CSA: 50 amps max.; Available in 2 & 3 poles only and limited to AC Delays. “General Purpose amps” not rated for “full load amps” or to be used in applications with a motor. 20 Recessed “OFF SIDE” available with actuator codes 1,2,3&4. Legends on rocker are available in ink stamping only. J12 J18 J24 J48 32 DC 48 DC 65 DC 6 AC 6 9 7 A C 11 9 CODE AMPERES 2. ACTUATOR 22. 9 12 AC 18 AC 24 AC 48 AC 614 14.000 615 15.000 616 16.000 617 17.000 618 18.000 620 20.000 622 22.000 624 24.000 625 25.000 630 30.000 635 35.000 640 40.000 650 50.000 660 9 60.000 670 9 70.000 680 9 80.000 685 9 85.000 690 9 90.000 695 9 95.000 810 9 100.000 J65 K20 L40 65 AC 120 AC 240 AC Stud M6 12 7/16” Clip Terminal 0.250 Double Click Connect 13 Plug-In Stud 14 5/16” Clip Terminal 9. ACTUATOR COLOR & LEGEND 16,17,18 Actuator or Visi-Color Marking: Marking Color: Single Color Color: I-O ON-OFF Dual/None Rocker/Handle Visi-Rocker White A B 1 Black White Black C D 2 White n/a Red F G 3 White Red Green H J 4 White Green Blue K L 5 White Blue Yellow M N 6 Black Yellow Gray P Q 7 Black Gray Orange R S 8 Black Orange 10 MOUNTING / BARRIERS STANDARD ROCKER BEZEL 1 6-32 x 0.195 inches 2 6-32 x 0.195 inches 3 19 6-32 x 0.195 inches 4 ISO M3 x 5mm 5 ISO M3 x 5mm 19 6 ISO M3 x 5mm ROCKERGUARD BEZEL A 6-32 x 0.195 inches C 6-32 x 0.195 inches 19 E 6-32 x 0.195 inches G ISO M3 x 5mm J ISO M3 x 5mm L 19 ISO M3 x 5mm PUSH-TO-RESET BEZEL B 6-32 x 0.195 inches D 6-32 x 0.195 inches 19 F 6-32 x 0.195 inches H ISO M3 x 5mm J ISO M3 x 5mm M 19 ISO M3 x 5mm 1 BARRIERS no yes yes no yes yes VOLTAGE
CA1-B0-14-640-3B1-MG 价格&库存
很抱歉,暂时无法提供与“CA1-B0-14-640-3B1-MG”相匹配的价格&库存,您可以联系我们找货
